path: root/net/sched/sch_hfsc.c
2008-08-27pkt_sched: Fix gen_estimator locksJarek Poplawski
While passing a qdisc root lock to gen_new_estimator() and gen_replace_estimator() dev could be deactivated or even before grafting proper root qdisc as qdisc_sleeping (e.g. qdisc_create), so using qdisc_root_lock() is not enough. This patch adds qdisc_root_sleeping_lock() for this, plus additional checks, where necessary. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-04net_sched: Add qdisc __NET_XMIT_BYPASS flagJarek Poplawski
Patrick McHardy <kaber@trash.net> noticed that it would be nice to handle NET_XMIT_BYPASS by NET_XMIT_SUCCESS with an internal qdisc flag __NET_XMIT_BYPASS and to remove the mapping from dev_queue_xmit(). David Miller <davem@davemloft.net> spotted a serious bug in the first version of this patch. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-04net_sched: Add qdisc __NET_XMIT_STOLEN flagJarek Poplawski
Patrick McHardy <kaber@trash.net> noticed: "The other problem that affects all qdiscs supporting actions is TC_ACT_QUEUED/TC_ACT_STOLEN getting mapped to NET_XMIT_SUCCESS even though the packet is not queued, corrupting upper qdiscs' qlen counters." and later explained: "The reason why it translates it at all seems to be to not increase the drops counter. Within a single qdisc this could be avoided by other means easily, upper qdiscs would still increase the counter when we return anything besides NET_XMIT_SUCCESS though. This means we need a new NET_XMIT return value to indicate this to the upper qdiscs. So I'd suggest to introduce NET_XMIT_STOLEN, return that to upper qdiscs and translate it to NET_XMIT_SUCCESS in dev_queue_xmit, similar to NET_XMIT_BYPASS." David Miller <davem@davemloft.net> noticed: "Maybe these NET_XMIT_* values being passed around should be a set of bits. They could be composed of base meanings, combined with specific attributes. So you could say "NET_XMIT_DROP | __NET_XMIT_NO_DROP_COUNT" The attributes get masked out by the top-level ->enqueue() caller, such that the base meanings are the only thing that make their way up into the stack. If it's only about communication within the qdisc tree, let's simply code it that way." This patch is trying to realize these ideas. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-20net_sched: Add accessor function for packet length for qdiscsJussi Kivilinna
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-20net_sched: Add qdisc_enqueue wrapperJussi Kivilinna
2008-07-17pkt_sched: Add and use qdisc_root() and qdisc_root_lock().David S. Miller
When code wants to lock the qdisc tree state, the logic operation it's doing is locking the top-level qdisc that sits of the root of the netdev_queue. Add qdisc_root_lock() to represent this and convert the easiest cases. In order for this to work out in all cases, we have to hook up the noop_qdisc to a dummy netdev_queue. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08netdev: Move queue_lock into struct netdev_queue.David S. Miller
The lock is now an attribute of the device queue. One thing to notice is that "suspicious" places emerge which will need specific training about multiple queue handling. They are so marked with explicit "netdev->rx_queue" and "netdev->tx_queue" references. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08pkt_sched: Remove 'dev' member of struct Qdisc.David S. Miller
It can be obtained via the netdev_queue. So create a helper routine, qdisc_dev(), to make the transformations nicer looking. Now, qdisc_alloc() now no longer needs a net_device pointer argument. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08netdev: Create netdev_queue abstraction.David S. Miller
A netdev_queue is an entity managed by a qdisc. Currently there is one RX and one TX queue, and a netdev_queue merely contains a backpointer to the net_device. The Qdisc struct is augmented with a netdev_queue pointer as well. Eventually the 'dev' Qdisc member will go away and we will have the resulting hierarchy: net_device --> netdev_queue --> Qdisc Also, qdisc_alloc() and qdisc_create_dflt() now take a netdev_queue pointer argument. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-05net-sched: sch_hfsc: use dynamic class hash helpersPatrick McHardy
Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-01net-sched: fix filter destruction in atm/hfsc qdisc destructionPatrick McHardy
Filters need to be destroyed before beginning to destroy classes since the destination class needs to still be alive to unbind the filter. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-01net-sched: change tcf_destroy_chain() to clear start of filter listPatrick McHardy
Pass double tcf_proto pointers to tcf_destroy_chain() to make it clear the start of the filter list for more consistency. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-03netlink: Improve returned error codesThomas Graf
Make nlmsg_trim(), nlmsg_cancel(), genlmsg_cancel(), and nla_nest_cancel() void functions. Return -EMSGSIZE instead of -1 if the provided message buffer is not big enough. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET_SCHED]: Use nla_policy for attribute validation in packet schedulersPatrick McHardy
2008-01-28[NET_SCHED]: Use nla_nest_start/nla_nest_endPatrick McHardy
Use nla_nest_start/nla_nest_end for dumping nested attributes. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET_SCHED]: Propagate nla_parse return valuePatrick McHardy
nla_parse() returns more detailed errno codes, propagate them back on error. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET_SCHED]: Convert packet schedulers from rtnetlink to new netlink APIPatrick McHardy
Convert packet schedulers to use the netlink API. Unfortunately a gradual conversion is not possible without breaking compilation in the middle or adding lots of casts, so this patch converts them all in one step. The patch has been mostly generated automatically with some minor edits to at least allow seperate conversion of classifiers and actions. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Move Qdisc_class_ops and Qdisc_ops in appropriate sections.Eric Dumazet
Qdisc_class_ops are const, and Qdisc_ops are mostly read. Using "const" and "__read_mostly" qualifiers helps to reduce false sharing. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-20[PKT_SCHED]: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-15[NET_SCHED]: Kill CONFIG_NET_CLS_POLICEPatrick McHardy
The NET_CLS_ACT option is now a full replacement for NET_CLS_POLICE, remove the old code. The config option will be kept around to select the equivalent NET_CLS_ACT options for a short time to allow easier upgrades. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NET_SCHED]: Remove unnecessary includesPatrick McHardy
2007-07-10[NET_SCHED]: Remove unnecessary stats_lock pointersPatrick McHardy
Remove stats_lock pointers from qdisc-internal structures, in all cases it points to dev->queue_lock. The only case where it is necessary is for top-level qdiscs, where it might also point to dev->ingress_lock in case of the ingress qdisc. Also remove it from actions completely, it always points to the actions internal lock. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NET_SCHED]: Remove CONFIG_NET_ESTIMATOR optionPatrick McHardy
The generic estimator is always built in anways and all the config options does is prevent including a minimal amount of code for setting it up. Additionally the option is already automatically selected for most cases. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET_SCHED]: Unline tcf_destroyPatrick McHardy
Uninline tcf_destroy and add a helper function to destroy an entire filter chain. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET_SCHED]: turn PSCHED_GET_TIME into inline functionPatrick McHardy
2007-04-25[NETLINK]: Use nlmsg_trim() where appropriateArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Convert skb->tail to sk_buff_data_tArnaldo Carvalho de Melo
So that it is also an offset from skb->head, reduces its size from 8 to 4 bytes on 64bit architectures, allowing us to combine the 4 bytes hole left by the layer headers conversion, reducing struct sk_buff size to 256 bytes, i.e. 4 64byte cachelines, and since the sk_buff slab cache is SLAB_HWCACHE_ALIGN... :-) Many calculations that previously required that skb->{transport,network, mac}_header be first converted to a pointer now can be done directly, being meaningful as offsets or pointers. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET_SCHED]: kill jiffie conversion macrosPatrick McHardy
Now that all packet schedulers have been converted to hrtimers most users of PSCHED_JIFFIE2US and PSCHED_US2JIFFIE are gone. The remaining users use it to convert external time units to packet scheduler clock ticks, so use PSCHED_TICKS_PER_SEC instead. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET_SCHED]: sch_hfsc: use hrtimer based watchdogPatrick McHardy
2007-04-25[NET_SCHED]: Use ktime as clocksourcePatrick McHardy
Get rid of the manual clock source selection mess and use ktime. Also use a scalar representation, which allows to clean up pkt_sched.h a bit more and results in less ktime_to_ns() calls in most cases. The PSCHED_US2JIFFIE/PSCHED_JIFFIE2US macros are implemented quite inefficient by this patch, following patches will convert all qdiscs to hrtimers and get rid of them entirely. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-27[NET_SCHED]: sch_htb/sch_hfsc: fix oops in qlen_notifyPatrick McHardy
During both HTB and HFSC class deletion the class is removed from the class hash before calling qdisc_tree_decrease_qlen. This makes the ->get operation in qdisc_tree_decrease_qlen fail, so it passes a NULL pointer to ->qlen_notify, causing an oops. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-13[NET_SCHED]: sch_hfsc: replace ASSERT macro by WARN_ONPatrick McHardy
2007-02-10[NET] SCHED: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET_SCHED]: Fix endless loops (part 5): netem/tbf/hfsc ->requeue failuresPatrick McHardy
When peeking at the next packet in a child qdisc by calling dequeue/requeue, the upper qdisc qlen counter may get out of sync in case the requeue fails. The qdisc and the child qdisc both have their counter decremented, but since no packet is given to the upper qdisc it won't decrement its counter itself. requeue should not fail, so this is mostly for "correctness". Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET_SCHED]: Fix endless loops (part 3): HFSCPatrick McHardy
Convert HFSC to use qdisc_tree_decrease_len() and add a callback for deactivating a class when its child queue becomes empty. All queue purging goes through hfsc_purge_queue(), which is used in three cases: grafting, class creation (when a leaf class is turned into an intermediate class by attaching a new class) and class deletion. In all cases qdisc_tree_decrease_len() is needed. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET_SCHED]: Set parent classid in default qdiscsPatrick McHardy
Set parent classids in default qdiscs to allow walking up the tree from outside the qdiscs. This is needed by the next patch. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-21[NET]: Conversions from kmalloc+memset to k(z|c)alloc.Panagiotis Issaris
Signed-off-by: Panagiotis Issaris <takis@issaris.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-11[NET_SCHED]: HFSC: fix thinko in hfsc_adjust_levels()Patrick McHardy
When deleting the last child the level of a class should drop to zero. Noticed by Andreas Mueller <andreas@stapelspeicher.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-09[PKT_SCHED]: Fix qdisc return code.Jamal Hadi Salim
The mapping between TC_ACTION_SHOT and the qdisc return codes is better suited to NET_XMIT_BYPASS so as not to confuse TCP Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-09[PKT_SCHED]: Use USEC_PER_SECPatrick McHardy
