path: root/net/sched
2011-06-06net: Rework netdev_drivername() to avoid warning.David S. Miller
This interface uses a temporary buffer, but for no real reason. And now can generate warnings like: net/sched/sch_generic.c: In function dev_watchdog net/sched/sch_generic.c:254:10: warning: unused variable drivername Just return driver->name directly or "". Reported-by: Connor Hansen <cmdkhh@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-25sch_sfq: fix peek() implementationEric Dumazet
Since commit eeaeb068f139 (sch_sfq: allow big packets and be fair), sfq_peek() can return a different skb that would be normally dequeued by sfq_dequeue() [ if current slot->allot is negative ] Use generic qdisc_peek_dequeued() instead of custom implementation, to get consistent result. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Jarek Poplawski <jarkao2@gmail.com> CC: Patrick McHardy <kaber@trash.net> CC: Jesper Dangaard Brouer <hawk@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-23sch_sfq: avoid giving spurious NET_XMIT_CN signalsEric Dumazet
While chasing a possible net_sched bug, I found that IP fragments have litle chance to pass a congestioned SFQ qdisc : - Say SFQ qdisc is full because one flow is non responsive. - ip_fragment() wants to send two fragments belonging to an idle flow. - sfq_enqueue() queues first packet, but see queue limit reached : - sfq_enqueue() drops one packet from 'big consumer', and returns NET_XMIT_CN. - ip_fragment() cancel remaining fragments. This patch restores fairness, making sure we return NET_XMIT_CN only if we dropped a packet from the same flow. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Patrick McHardy <kaber@trash.net> CC: Jarek Poplawski <jarkao2@gmail.com> CC: Jamal Hadi Salim <hadi@cyberus.ca> CC: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-22net: avoid synchronize_rcu() in dev_deactivate_manyEric Dumazet
dev_deactivate_many() issues one synchronize_rcu() call after qdiscs set to noop_qdisc. This call is here to make sure they are no outstanding qdisc-less dev_queue_xmit calls before returning to caller. But in dismantle phase, we dont have to wait, because we wont activate again the device, and we are going to wait one rcu grace period later in rollback_registered_many(). After this patch, device dismantle uses one synchronize_net() and one rcu_barrier() call only, so we have a ~30% speedup and a smaller RTNL latency. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Patrick McHardy <kaber@trash.net>, CC: Ben Greear <greearb@candelatech.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1446 commits) macvlan: fix panic if lowerdev in a bond tg3: Add braces around 5906 workaround. tg3: Fix NETIF_F_LOOPBACK error macvlan: remove one synchronize_rcu() call networking: NET_CLS_ROUTE4 depends on INET irda: Fix error propagation in ircomm_lmp_connect_response() irda: Kill set but unused variable 'bytes' in irlan_check_command_param() irda: Kill set but unused variable 'clen' in ircomm_connect_indication() rxrpc: Fix set but unused variable 'usage' in rxrpc_get_transport() be2net: Kill set but unused variable 'req' in lancer_fw_download() irda: Kill set but unused vars 'saddr' and 'daddr' in irlan_provider_connect_indication() atl1c: atl1c_resume() is only used when CONFIG_PM_SLEEP is defined. rxrpc: Fix set but unused variable 'usage' in rxrpc_get_peer(). rxrpc: Kill set but unused variable 'local' in rxrpc_UDP_error_handler() rxrpc: Kill set but unused variable 'sp' in rxrpc_process_connection() rxrpc: Kill set but unused variable 'sp' in rxrpc_rotate_tx_window() pkt_sched: Kill set but unused variable 'protocol' in tc_classify() isdn: capi: Use pr_debug() instead of ifdefs. tg3: Update version to 3.119 tg3: Apply rx_discards fix to 5719/5720 ... Fix up trivial conflicts in arch/x86/Kconfig and net/mac80211/agg-tx.c as per Davem.
2011-05-19networking: NET_CLS_ROUTE4 depends on INETRandy Dunlap
IP_ROUTE_CLASSID depends on INET and NET_CLS_ROUTE4 selects IP_ROUTE_CLASSID, but when INET is not enabled, this kconfig warning is produced, so fix it by making NET_CLS_ROUTE4 depend on INET. warning: (NET_CLS_ROUTE4) selects IP_ROUTE_CLASSID which has unmet direct dependencies (NET && INET) Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-19pkt_sched: Kill set but unused variable 'protocol' in tc_classify()David S. Miller
I checked the history and this has been like this since the beginning of time. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-07net,act_police,rcu: remove rcu_barrier()Lai Jiangshan
There is no callback of this module maybe queued since we use kfree_rcu(), we can safely remove the rcu_barrier(). Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-05-07net,rcu: convert call_rcu(tcf_police_free_rcu) to kfree_rcu()Lai Jiangshan
[PATCH 05/17] net,rcu: convert call_rcu(tcf_police_free_rcu) to kfree_rcu() The rcu callback tcf_police_free_rcu() just calls a kfree(), so we use kfree_rcu() instead of the call_rcu(tcf_police_free_rcu). Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-05-07net,rcu: convert call_rcu(tcf_common_free_rcu) to kfree_rcu()Lai Jiangshan
The rcu callback tcf_common_free_rcu() just calls a kfree(), so we use kfree_rcu() instead of the call_rcu(tcf_common_free_rcu). Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-04-22inet: constify ip headers and in6_addrEric Dumazet
Add const qualifiers to structs iphdr, ipv6hdr and in6_addr pointers where possible, to make code intention more obvious. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/smsc911x.c
2011-04-04pkt_sched: QFQ - quick fair queue schedulerstephen hemminger
This is an implementation of the Quick Fair Queue scheduler developed by Fabio Checconi. The same algorithm is already implemented in ipfw in FreeBSD. Fabio had an earlier version developed on Linux, I just cleaned it up. Thanks to Eric Dumazet for testing this under load. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-04ipv4: Remove flowi from struct rtable.David S. Miller
The only necessary parts are the src/dst addresses, the interface indexes, the TOS, and the mark. The rest is unnecessary bloat, which amounts to nearly 50 bytes on 64-bit. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-03Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bnx2x/bnx2x.h
2011-03-03net_sched: reduce fifo qdisc sizeEric Dumazet
Because of various alignements [SLUB / qdisc], we use 512 bytes of memory for one {p|b}fifo qdisc, instead of 256 bytes on 64bit arches and 192 bytes on 32bit ones. Move the "u32 limit" inside "struct Qdisc" (no impact on other qdiscs) Change qdisc_alloc(), first trying a regular allocation before an oversized one. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-25sched: protocol only needed when CONFIG_NET_CLS_ACT is enabledHagen Paul Pfeifer
Signed-off-by: Hagen Paul Pfeifer <hagen@jauu.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-24sch_netem: Need to include vmalloc.hDavid S. Miller
2011-02-24sch_choke: add choke_skb_cbEric Dumazet
Better document choke skb->cb[] use, like we did in netem and sfb This adds a compile time check to make sure we dont exhaust skb->cb[] space. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Stephen Hemminger <shemminger@vyatta.com> CC: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-24netem: update version and cleanupstephen hemminger
Get rid of debug message that are not useful, and enable the log messages in case of error. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-24netem: revised correlated loss generatorstephen hemminger
This is a patch originated with Stefano Salsano and Fabio Ludovici. It provides several alternative loss models for use with netem. This patch adds two state machine based loss models. See: http://netgroup.uniroma2.it/twiki/bin/view.cgi/Main/NetemCLG Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-24Revert "sch_netem: Remove classful functionality"stephen hemminger
Many users have wanted the old functionality that was lost to be able to use pfifo as inner qdisc for netem. The reason that netem could not be classful with the older API was because of the limitations of the old dequeue/requeue interface; now that qdisc API has a peek function, there is no longer a problem with using any inner qdisc's. This reverts commit 02201464119334690fe209849843881b8e9cfa9f. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-24netem: define NETEM_DIST_MAXstephen hemminger
Rather than magic constant in code, expose the maximum size of packet distribution table in API. In iproute2, q_netem defines MAX_DIST as 16K already. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-24netem: use vmalloc for distribution tablestephen hemminger
The netem probability table can be large (up to 64K bytes) which may be too large to allocate in one contiguous chunk. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-24netem: cleanup dump codestephen hemminger
Use nla_put_nested to update netlink attribute value. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-23em_meta: fix sparse warningstephen hemminger
gfp_t needs to be cast to integer. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-23mqprio: cleanupsstephen hemminger
* make qdisc_ops local * add sparse annotation about expected unlock/unlock in dump_class_stats * fix indentation Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-23net_sched: SFB flow schedulerEric Dumazet
This is the Stochastic Fair Blue scheduler, based on work from : W. Feng, D. Kandlur, D. Saha, K. Shin. Blue: A New Class of Active Queue Management Algorithms. U. Michigan CSE-TR-387-99, April 1999. http://www.thefengs.com/wuchang/blue/CSE-TR-387-99.pdf This implementation is based on work done by Juliusz Chroboczek General SFB algorithm can be found in figure 14, page 15: B[l][n] : L x N array of bins (L levels, N bins per level) enqueue() Calculate hash function values h{0}, h{1}, .. h{L-1} Update bins at each level for i = 0 to L - 1 if (B[i][h{i}].qlen > bin_size) B[i][h{i}].p_mark += p_increment; else if (B[i][h{i}].qlen == 0) B[i][h{i}].p_mark -= p_decrement; p_min = min(B[0][h{0}].p_mark ... B[L-1][h{L-1}].p_mark); if (p_min == 1.0) ratelimit(); else mark/drop with probabilty p_min; I did the adaptation of Juliusz code to meet current kernel standards, and various changes to address previous comments : http://thread.gmane.org/gmane.linux.network/90225 http://thread.gmane.org/gmane.linux.network/90375 Default flow classifier is the rxhash introduced by RPS in 2.6.35, but we can use an external flow classifier if wanted. tc qdisc add dev $DEV parent 1:11 handle 11: \ est 0.5sec 2sec sfb limit 128 tc filter add dev $DEV protocol ip parent 11: handle 3 \ flow hash keys dst divisor 1024 Notes: 1) SFB default child qdisc is pfifo_fast. It can be changed by another qdisc but a child qdisc MUST not drop a packet previously queued. This is because SFB needs to handle a dequeued packet in order to maintain its virtual queue states. pfifo_head_drop or CHOKe should not be used. 2) ECN is enabled by default, unlike RED/CHOKe/GRED With help from Patrick McHardy & Andi Kleen Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Juliusz Chroboczek <Juliusz.Chroboczek@pps.jussieu.fr> CC: Stephen Hemminger <shemminger@vyatta.com> CC: Patrick McHardy <kaber@trash.net> CC: Andi Kleen <andi@firstfloor.org> CC: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-22cls_u32: fix sparse warningsstephen hemminger
The variable _data is used in asm-generic to define sections which causes sparse warnings, so just rename the variable. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-20net: Fix more stale on-stack list_head objects.Eric W. Biederman
From: Eric W. Biederman <ebiederm@xmission.com> In the beginning with batching unreg_list was a list that was used only once in the lifetime of a network device (I think). Now we have calls using the unreg_list that can happen multiple times in the life of a network device like dev_deactivate and dev_close that are also using the unreg_list. In addition in unregister_netdevice_queue we also do a list_move because for devices like veth pairs it is possible that unregister_netdevice_queue will be called multiple times. So I think the change below to fix dev_deactivate which Eric D. missed will fix this problem. Now to go test that. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-14sch_mqprio: Always set num_tc to 0 in mqprio_destroy()Ben Hutchings
All the cleanup code in mqprio_destroy() is currently conditional on priv->qdiscs being non-null, but that condition should only apply to the per-queue qdisc cleanup. We should always set the number of traffic classes back to 0 here. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-02-02sch_choke: Need linux/vmalloc.hDavid S. Miller
2011-02-02sched: CHOKe flow schedulerstephen hemminger
CHOKe ("CHOose and Kill" or "CHOose and Keep") is an alternative packet scheduler based on the Random Exponential Drop (RED) algorithm. The core idea is: For every packet arrival: Calculate Qave if (Qave < minth) Queue the new packet else Select randomly a packet from the queue if (both packets from same flow) then Drop both the packets else if (Qave > maxth) Drop packet else Admit packet with proability p (same as RED) See also: Rong Pan, Balaji Prabhakar, Konstantinos Psounis, "CHOKe: a stateless active queue management scheme for approximating fair bandwidth allocation", Proceeding of INFOCOM'2000, March 2000. Help from: Eric Dumazet <eric.dumazet@gmail.com> Patrick McHardy <kaber@trash.net> Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-02sfq: deadlock in error pathstephen hemminger
The change to allow divisor to be a parameter (in 2.6.38-rc1) commit 817fb15dfd988d8dda916ee04fa506f0c466b9d6 introduced a possible deadlock caught by sparse. The scheduler tree lock was left locked in the case of an incorrect divisor value. Simplest fix is to move test outside of lock which also solves problem of partial update. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-26net_sched: sch_mqprio: dont leak kernel memoryEric Dumazet
mqprio_dump() should make sure all fields of struct tc_mqprio_qopt are initialized. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-24Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/sched/sch_hfsc.c net/sched/sch_htb.c net/sched/sch_tbf.c
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
2011-01-21net_sched: TCQ_F_CAN_BYPASS generalizationEric Dumazet
Now qdisc stab is handled before TCQ_F_CAN_BYPASS test in __dev_xmit_skb(), we can generalize TCQ_F_CAN_BYPASS to other qdiscs than pfifo_fast : pfifo, bfifo, pfifo_head_drop and sfq SFQ is special because it can have external classifiers, and in these cases, we cannot bypass queue discipline (packet could be dropped by classifier) without admin asking it, or further changes. Its worth doing this, especially for SFQ, avoiding dirtying memory in case no packets are already waiting in queue. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-20net_sched: accurate bytes/packets stats/ratesEric Dumazet
In commit 44b8288308ac9d (net_sched: pfifo_head_drop problem), we fixed a problem with pfifo_head drops that incorrectly decreased sch->bstats.bytes and sch->bstats.packets Several qdiscs (CHOKe, SFQ, pfifo_head, ...) are able to drop a previously enqueued packet, and bstats cannot be changed, so bstats/rates are not accurate (over estimated) This patch changes the qdisc_bstats updates to be done at dequeue() time instead of enqueue() time. bstats counters no longer account for dropped frames, and rates are more correct, since enqueue() bursts dont have effect on dequeue() rate. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-20net_sched: RCU conversion of stabEric Dumazet
This patch converts stab qdisc management to RCU, so that we can perform the qdisc_calculate_pkt_len() call before getting qdisc lock. This shortens the lock's held time in __dev_xmit_skb(). This permits more qdiscs to get TCQ_F_CAN_BYPASS status, avoiding lot of cache misses and so reducing latencies. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Patrick McHardy <kaber@trash.net> CC: Jesper Dangaard Brouer <hawk@diku.dk> CC: Jarek Poplawski <jarkao2@gmail.com> CC: Jamal Hadi Salim <hadi@cyberus.ca> CC: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-20net_sched: move TCQ_F_THROTTLED flagEric Dumazet
In commit 371121057607e (net: QDISC_STATE_RUNNING dont need atomic bit ops) I moved QDISC_STATE_RUNNING flag to __state container, located in the cache line containing qdisc lock and often dirtied fields. I now move TCQ_F_THROTTLED bit too, so that we let first cache line read mostly, and shared by all cpus. This should speedup HTB/CBQ for example. Not using test_bit()/__clear_bit()/__test_and_set_bit allows to use an "unsigned int" for __state container, reducing by 8 bytes Qdisc size. Introduce helpers to hide implementation details. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Patrick McHardy <kaber@trash.net> CC: Jesper Dangaard Brouer <hawk@diku.dk> CC: Jarek Poplawski <jarkao2@gmail.com> CC: Jamal Hadi Salim <hadi@cyberus.ca> CC: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-20net_sched: sfq: allow divisor to be a parameterEric Dumazet
SFQ currently uses a 1024 slots hash table, and its internal structure (sfq_sched_data) allocation needs order-1 page on x86_64 Allow tc command to specify a divisor value (hash table size), between 1 and 65536. If no value is provided, assume the 1024 default size. This allows admins to setup smaller (or bigger) SFQ for specific needs. This also brings back sfq_sched_data allocations to order-0 ones, saving 3KB per SFQ qdisc. Jesper uses ~55.000 SFQ in one machine, this patch should free 165 MB of memory. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Patrick McHardy <kaber@trash.net> CC: Jesper Dangaard Brouer <hawk@diku.dk> CC: Jarek Poplawski <jarkao2@gmail.com> CC: Jamal Hadi Salim <hadi@cyberus.ca> CC: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-20Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-next-2.6
2011-01-19net_sched: cleanupsEric Dumazet
Cleanup net/sched code to current CodingStyle and practices. Reduce inline abuse Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-19net_sched: implement a root container qdisc sch_mqprioJohn Fastabend
This implements a mqprio queueing discipline that by default creates a pfifo_fast qdisc per tx queue and provides the needed configuration interface. Using the mqprio qdisc the number of tcs currently in use along with the range of queues alloted to each class can be configured. By default skbs are mapped to traffic classes using the skb priority. This mapping is configurable. Configurable parameters, struct tc_mqprio_qopt { __u8 num_tc; __u8 prio_tc_map[TC_BITMASK + 1]; __u8 hw; __u16 count[TC_MAX_QUEUE]; __u16 offset[TC_MAX_QUEUE]; }; Here the count/offset pairing give the queue alignment and the prio_tc_map gives the mapping from skb->priority to tc. The hw bit determines if the hardware should configure the count and offset values. If the hardware bit is set then the operation will fail if the hardware does not implement the ndo_setup_tc operation. This is to avoid undetermined states where the hardware may or may not control the queue mapping. Also minimal bounds checking is done on the count/offset to verify a queue does not exceed num_tx_queues and that queue ranges do not overlap. Otherwise it is left to user policy or hardware configuration to create useful mappings. It is expected that hardware QOS schemes can be implemented by creating appropriate mappings of queues in ndo_tc_setup(). One expected use case is drivers will use the ndo_setup_tc to map queue ranges onto 802.1Q traffic classes. This provides a generic mechanism to map network traffic onto these traffic classes and removes the need for lower layer drivers to know specifics about traffic types. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-19Merge branch 'master' of /repos/git/net-next-2.6Patrick McHardy
2011-01-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (47 commits) GRETH: resolve SMP issues and other problems GRETH: handle frame error interrupts GRETH: avoid writing bad speed/duplex when setting transfer mode GRETH: fixed skb buffer memory leak on frame errors GRETH: GBit transmit descriptor handling optimization GRETH: fix opening/closing GRETH: added raw AMBA vendor/device number to match against. cassini: Fix build bustage on x86. e1000e: consistent use of Rx/Tx vs. RX/TX/rx/tx in comments/logs e1000e: update Copyright for 2011 e1000: Avoid unhandled IRQ r8169: keep firmware in memory. netdev: tilepro: Use is_unicast_ether_addr helper etherdevice.h: Add is_unicast_ether_addr function ks8695net: Use default implementation of ethtool_ops::get_link ks8695net: Disable non-working ethtool operations USB CDC NCM: Don't deref NULL in cdc_ncm_rx_fixup() and don't use uninitialized variable. vxge: Remember to release firmware after upgrading firmware netdev: bfin_mac: Remove is_multicast_ether_addr use in netdev_for_each_mc_addr ipsec: update MAX_AH_AUTH_LEN to support sha512 ...
2011-01-14Merge branch 'master' of git://1984.lsi.us.es/net-next-2.6Patrick McHardy
Conflicts: net/ipv4/route.c Signed-off-by: Patrick McHardy <kaber@trash.net>
2011-01-14netfilter: fix Kconfig dependenciesPatrick McHardy
Fix dependencies of netfilter realm match: it depends on NET_CLS_ROUTE, which itself depends on NET_SCHED; this dependency is missing from netfilter. Since matching on realms is also useful without having NET_SCHED enabled and the option really only controls whether the tclassid member is included in route and dst entries, rename the config option to IP_ROUTE_CLASSID and move it outside of traffic scheduling context to get rid of the NET_SCHED dependeny. Reported-by: Vladis Kletnieks <Valdis.Kletnieks@vt.edu> Signed-off-by: Patrick McHardy <kaber@trash.net>
