[ Upstream commit 90f62cf30a78721641e08737bda787552428061e ]
It is possible by passing a netlink socket to a more privileged
executable and then to fool that executable into writing to the socket
data that happens to be valid netlink message to do something that
privileged executable did not intend to do.
To keep this from happening replace bare capable and ns_capable calls
with netlink_capable, netlink_net_calls and netlink_ns_capable calls.
Which act the same as the previous calls except they verify that the
opener of the socket had the desired permissions as well.
Reported-by: Andy Lutomirski <luto@amacapital.net>
[ Upstream commit bf63ac73b3e132e6bf0c8798aba7b277c3316e19 ]
Kelly reported the following crash:
IP: [<ffffffff817a993d>] tcf_action_exec+0x46/0x90
PGD 3009067 PUD 300c067 PMD 11ff30067 PTE 800000011634b060
Oops: 0000 [#1] SMP DEBUG_PAGEALLOC
CPU: 1 PID: 639 Comm: dhclient Not tainted 3.15.0-rc4+ #342
Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
task: ffff8801169ecd00 ti: ffff8800d21b8000 task.ti: ffff8800d21b8000
RIP: 0010:[<ffffffff817a993d>] [<ffffffff817a993d>] tcf_action_exec+0x46/0x90
RSP: 0018:ffff8800d21b9b90 EFLAGS: 00010283
RAX: 00000000ffffffff RBX: ffff88011634b8e8 RCX: ffff8800cf7133d8
RDX: ffff88011634b900 RSI: ffff8800cf7133e0 RDI: ffff8800d210f840
RBP: ffff8800d21b9bb0 R08: ffffffff8287bf60 R09: 0000000000000001
R10: ffff8800d2b22b24 R11: 0000000000000001 R12: ffff8800d210f840
R13: ffff8800d21b9c50 R14: ffff8800cf7133e0 R15: ffff8800cad433d8
FS: 00007f49723e1840(0000) GS:ffff88011a800000(0000) knlGS:0000000000000000
CR2: ffff88011634b8f0 CR3: 00000000ce469000 CR4: 00000000000006e0
Stack:
ffff8800d2170188 ffff8800d210f840 ffff8800d2171b90 0000000000000000
ffff8800d21b9be8 ffffffff817c55bb ffff8800d21b9c50 ffff8800d2171b90
ffff8800d210f840 ffff8800d21b0300 ffff8800d21b9c50 ffff8800d21b9c18
Call Trace:
[<ffffffff817c55bb>] tcindex_classify+0x88/0x9b
[<ffffffff817a7f7d>] tc_classify_compat+0x3e/0x7b
[<ffffffff817a7fdf>] tc_classify+0x25/0x9f
[<ffffffff817b0e68>] htb_enqueue+0x55/0x27a
[<ffffffff817b6c2e>] dsmark_enqueue+0x165/0x1a4
[<ffffffff81775642>] __dev_queue_xmit+0x35e/0x536
[<ffffffff8177582a>] dev_queue_xmit+0x10/0x12
[<ffffffff818f8ecd>] packet_sendmsg+0xb26/0xb9a
[<ffffffff810b1507>] ? __lock_acquire+0x3ae/0xdf3
[<ffffffff8175cf08>] __sock_sendmsg_nosec+0x25/0x27
[<ffffffff8175d916>] sock_aio_write+0xd0/0xe7
[<ffffffff8117d6b8>] do_sync_write+0x59/0x78
[<ffffffff8117d84d>] vfs_write+0xb5/0x10a
[<ffffffff8117d96a>] SyS_write+0x49/0x7f
[<ffffffff8198e212>] system_call_fastpath+0x16/0x1b
This is because we memcpy struct tcindex_filter_result which contains
struct tcf_exts, obviously struct list_head can not be simply copied.
This is a regression introduced by commit 33be627159913b094bb578
(net_sched: act: use standard struct list_head).
It's not very easy to fix it as the code is a mess:
if (old_r)
memcpy(&cr, r, sizeof(cr));
else {
memset(&cr, 0, sizeof(cr));
tcf_exts_init(&cr.exts, TCA_TCINDEX_ACT, TCA_TCINDEX_POLICE);
tcf_exts_change(tp, &cr.exts, &e);
memcpy(r, &cr, sizeof(cr));
the above code should equal to:
tcindex_filter_result_init(&cr);
if (old_r)
cr.res = r->res;
if (old_r)
tcf_exts_change(tp, &r->exts, &e);
else
r->res = cr.res;
after this change, since there is no need to copy struct tcf_exts.
And it also fixes other places zero'ing struct's contains struct tcf_exts.
Fixes: commit 33be627159913b0 (net_sched: act: use standard struct list_head)
Reported-by: Kelly Anderson <kelly@xilka.com>
Tested-by: Kelly Anderson <kelly@xilka.com>
[ Upstream commit f6a082fed1e6407c2f4437d0d963b1bcbe5f9f58 ]
hhf_change() takes the sch_tree_lock and releases it but misses the
error cases. Fix the missed case here.
To reproduce try a command like this,
# tc qdisc change dev p3p2 root hhf quantum 40960 non_hh_weight 300000
Signed-off-by: John Fastabend <john.r.fastabend@intel.com>
Resizing fq hash table allocates memory while holding qdisc spinlock,
with BH disabled.
This is definitely not good, as allocation might sleep.
We can drop the lock and get it when needed, we hold RTNL so no other
changes can happen at the same time.
Fixes: afe4fd062416 ("pkt_sched: fq: Fair Queue packet scheduler")
The WARN_ON(root == &noop_qdisc)) added in qdisc_list_add()
can trigger in normal conditions when devices are not up.
It should be done only right before the list_add_tail() call.
Fixes: e57a784d8cae4 ("pkt_sched: set root qdisc before change() in attach_default_qdiscs()")
Reported-by: Valdis Kletnieks <Valdis.Kletnieks@vt.edu>
Tested-by: Mirco Tischler <mt-ml@gmx.de>
The allocated child qdisc is not freed in error conditions.
Defer the allocation after user configuration turns out to be
valid and acceptable.
Fixes: cc106e441a63b ("net: sched: tbf: fix the calculation of max_size")
Signed-off-by: Hiroaki SHIMODA <shimoda.hiroaki@gmail.com>
Cc: Yang Yingliang <yangyingliang@huawei.com>
Fix incorrect comment reported by Norbert Kiesel. Edit another comment to add
more details. Also add references to algorithm (IETF draft and paper) to top of
file.
Signed-off-by: Vijay Subramanian <subramanian.vijay@gmail.com>
CC: Mythili Prabhu <mysuryan@cisco.com>
CC: Norbert Kiesel <nkiesel@gmail.com>
This moves part of Eric Dumazets skb_gso_seglen helper from tbf sched to
skbuff core so it may be reused by upcoming ip forwarding path patch.
If the class in skb->priority is not a leaf, apply filters from the
selected class, not the qdisc. This lets netfilter or user space
partially classify the packet.
Signed-off-by: Harry Mason <harry.mason@smoothwall.net>
Jakub Zawadzki noticed that some divisions by reciprocal_divide()
were not correct [1][2], which he could also show with BPF code
after divisions are transformed into reciprocal_value() for runtime
invariance which can be passed to reciprocal_divide() later on;
reverse in BPF dump ended up with a different, off-by-one K in
some situations.
This has been fixed by Eric Dumazet in commit aee636c4809fa5
("bpf: do not use reciprocal divide"). This follow-up patch
improves reciprocal_value() and reciprocal_divide() to work in
all cases by using Granlund and Montgomery method, so that also
future use is safe and without any non-obvious side-effects.
Known problems with the old implementation were that division by 1
always returned 0 and some off-by-ones when the dividend and divisor
where very large. This seemed to not be problematic with its
current users, as far as we can tell. Eric Dumazet checked for
the slab usage, we cannot surely say so in the case of flex_array.
Still, in order to fix that, we propose an extension from the
original implementation from commit 6a2d7a955d8d resp. [3][4],
by using the algorithm proposed in "Division by Invariant Integers
Using Multiplication" [5], Torbjörn Granlund and Peter L.
Montgomery, that is, pseudocode for q = n/d where q, n, d is in
u32 universe:
1) Initialization:
int l = ceil(log_2 d)
uword m' = floor((1<<32)*((1<<l)-d)/d)+1
int sh_1 = min(l,1)
int sh_2 = max(l-1,0)
2) For q = n/d, all uword:
uword t = (n*m')>>32
q = (t+((n-t)>>sh_1))>>sh_2
The assembler implementation from Agner Fog [6] also helped a lot
while implementing. We have tested the implementation on x86_64,
ppc64, i686, s390x; on x86_64/haswell we're still half the latency
compared to normal divide.
Joint work with Daniel Borkmann.
[1] http://www.wireshark.org/~darkjames/reciprocal-buggy.c
[2] http://www.wireshark.org/~darkjames/set-and-dump-filter-k-bug.c
[3] https://gmplib.org/~tege/division-paper.pdf
[4] http://homepage.cs.uiowa.edu/~jones/bcd/divide.html
[5] http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.1.2556
[6] http://www.agner.org/optimize/asmlib.zip
Reported-by: Jakub Zawadzki <darkjames-ws@darkjames.pl>
Cc: Austin S Hemmelgarn <ahferroin7@gmail.com>
Cc: Jesse Gross <jesse@nicira.com>
Cc: Jamal Hadi Salim <jhs@mojatatu.com>
Cc: Stephen Hemminger <stephen@networkplumber.org>
Cc: Matt Mackall <mpm@selenic.com>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Andy Gospodarek <andy@greyhouse.net>
Cc: Veaceslav Falico <vfalico@redhat.com>
Cc: Jay Vosburgh <fubar@us.ibm.com>
Cc: Jakub Zawadzki <darkjames-ws@darkjames.pl>
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Many functions have open coded a function that returns a random
number in range [0,N-1]. Under the assumption that we have a PRNG
such as taus113 with being well distributed in [0, ~0U] space,
we can implement such a function as uword t = (n*m')>>32, where
m' is a random number obtained from PRNG, n the right open interval
border and t our resulting random number, with n,m',t in u32 universe.
Lets go with Joe and simply call it prandom_u32_max(), although
technically we have an right open interval endpoint, but that we
have documented. Other users can further be migrated to the new
prandom_u32_max() function later on; for now, we need to make sure
to migrate reciprocal_divide() users for the reciprocal_divide()
follow-up fixup since their function signatures are going to change.
Joint work with Hannes Frederic Sowa.
So that we will not expose struct tcf_common to modules.
Signed-off-by: Jamal Hadi Salim <jhs@mojatatu.com>
Every action ops has a pointer to hash info, so we don't need to
hard-code it in each module.
It is not actually implemented.
Replace some magic numbers which describe states of 4-state model
loss generator with enumerate.
Signed-off-by: Yang Yingliang <yangyingliang@huawei.com>
The error code was not set if change indev fail, so the error
condition wasn't reflected in the return value. Fix to return a
negative error code from this error handling case instead of 0.
Fixes: 2519a602c273 ('net_sched: optimize tcf_match_indev()')
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
In tcf_register_action() we check either ->type or ->kind to see if
there is an existing action registered, but ipt action registers two
actions with same type but different kinds. They should have different
types too.
Acked-by: Jamal Hadi Salim <jhs@mojatatu.com>
This patch removes the net_random and net_srandom macros and replaces
them with direct calls to the prandom ones. As new commits only seem to
use prandom_u32 there is no use to keep them around.
This change makes it easier to grep for users of prandom_u32.
Signed-off-by: Aruna-Hewapathirane <aruna.hewapathirane@gmail.com>
Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
It is not necessary at all.
tp->root is a void* pointer, no need to cast it.
tcf_match_indev() is called in fast path, it is not wise to
search for a netdev by ifindex and then compare by its name,
just compare the ifindex.
Also, dev->name could be changed by user-space, therefore
the match would be always fail, but dev->ifindex could
be consistent.
BTW, this will also save some bytes from the core struct of u32.
It will be needed by the next patch.
Refactor tcf_add_notify() and factor out tcf_del_notify().
There is no need to store the index separatedly
since tcf_hashinfo is allocated statically too.
This is to be compatible with the use of "get_time" (i.e. default
time unit in us) in iproute2 patch for HHF as requested by Stephen.
Signed-off-by: Terry Lam <vtlam@google.com>
Acked-by: Nandita Dukkipati <nanditad@google.com>
Currently, the tx queue were selected implicitly in ndo_dfwd_start_xmit(). The
will cause several issues:
- NETIF_F_LLTX were removed for macvlan, so txq lock were done for macvlan
instead of lower device which misses the necessary txq synchronization for
lower device such as txq stopping or frozen required by dev watchdog or
control path.
- dev_hard_start_xmit() was called with NULL txq which bypasses the net device
watchdog.
- dev_hard_start_xmit() does not check txq everywhere which will lead a crash
when tso is disabled for lower device.
Fix this by explicitly introducing a new param for .ndo_select_queue() for just
selecting queues in the case of l2 forwarding offload. netdev_pick_tx() was also
extended to accept this parameter and dev_queue_xmit_accel() was used to do l2
forwarding transmission.
With this fixes, NETIF_F_LLTX could be preserved for macvlan and there's no need
to check txq against NULL in dev_hard_start_xmit(). Also there's no need to keep
a dedicated ndo_dfwd_start_xmit() and we can just reuse the code of
dev_queue_xmit() to do the transmission.
In the future, it was also required for macvtap l2 forwarding support since it
provides a necessary synchronization method.
Cc: John Fastabend <john.r.fastabend@intel.com>
Cc: Neil Horman <nhorman@tuxdriver.com>
Cc: e1000-devel@lists.sourceforge.net
Signed-off-by: Jason Wang <jasowang@redhat.com>
Acked-by: John Fastabend <john.r.fastabend@intel.com>
drivers/net/ethernet/qlogic/qlcnic/qlcnic_sriov_pf.c
net/ipv6/ip6_tunnel.c
net/ipv6/ip6_vti.c
ipv6 tunnel statistic bug fixes conflicting with consolidation into
generic sw per-cpu net stats.
qlogic conflict between queue counting bug fix and the addition
of multiple MAC address support.
action flushing missaccounting
Account only for deleted actions
Remove unnecessary checks for act->ops
(suggested by Eric Dumazet).
Proportional Integral controller Enhanced (PIE) is a scheduler to address the
bufferbloat problem.
>From the IETF draft below:
" Bufferbloat is a phenomenon where excess buffers in the network cause high
latency and jitter. As more and more interactive applications (e.g. voice over
IP, real time video streaming and financial transactions) run in the Internet,
high latency and jitter degrade application performance. There is a pressing
need to design intelligent queue management schemes that can control latency and
jitter; and hence provide desirable quality of service to users.
We present here a lightweight design, PIE(Proportional Integral controller
Enhanced) that can effectively control the average queueing latency to a target
value. Simulation results, theoretical analysis and Linux testbed results have
shown that PIE can ensure low latency and achieve high link utilization under
various congestion situations. The design does not require per-packet
timestamp, so it incurs very small overhead and is simple enough to implement
in both hardware and software. "
Many thanks to Dave Taht for extensive feedback, reviews, testing and
suggestions. Thanks also to Stephen Hemminger and Eric Dumazet for reviews and
suggestions. Naeem Khademi and Dave Taht independently contributed to ECN
support.
For more information, please see technical paper about PIE in the IEEE
Conference on High Performance Switching and Routing 2013. A copy of the paper
can be found at ftp://ftpeng.cisco.com/pie/.
Please also refer to the IETF draft submission at
http://tools.ietf.org/html/draft-pan-tsvwg-pie-00
All relevant code, documents and test scripts and results can be found at
For problems with the iproute2/tc or Linux kernel code, please contact Vijay
Subramanian (vijaynsu@cisco.com or subramanian.vijay@gmail.com) Mythili Prabhu
(mysuryan@cisco.com)
Signed-off-by: Mythili Prabhu <mysuryan@cisco.com>
CC: Dave Taht <dave.taht@bufferbloat.net>
Pablo Neira Ayuso says:
netfilter/IPVS updates for net-next
The following patchset contains Netfilter updates for your net-next tree,
they are:
* Add full port randomization support. Some crazy researchers found a way
to reconstruct the secure ephemeral ports that are allocated in random mode
by sending off-path bursts of UDP packets to overrun the socket buffer of
the DNS resolver to trigger retransmissions, then if the timing for the
DNS resolution done by a client is larger than usual, then they conclude
that the port that received the burst of UDP packets is the one that was
opened. It seems a bit aggressive method to me but it seems to work for
them. As a result, Daniel Borkmann and Hannes Frederic Sowa came up with a
new NAT mode to fully randomize ports using prandom.
* Add a new classifier to x_tables based on the socket net_cls set via
cgroups. These includes two patches to prepare the field as requested by
Zefan Li. Also from Daniel Borkmann.
* Use prandom instead of get_random_bytes in several locations of the
netfilter code, from Florian Westphal.
* Allow to use the CTA_MARK_MASK in ctnetlink when mangling the conntrack
mark, also from Florian Westphal.
* Fix compilation warning due to unused variable in IPVS, from Geert
Uytterhoeven.
* Add support for UID/GID via nfnetlink_queue, from Valentina Giusti.
* Add IPComp extension to x_tables, from Fan Du.
Zefan Li requested [1] to perform the following cleanup/refactoring:
- Split cgroupfs classid handling into net core to better express a
possible more generic use.
- Disable module support for cgroupfs bits as the majority of other
cgroupfs subsystems do not have that, and seems to be not wished
from cgroup side. Zefan probably might want to follow-up for netprio
later on.
- By this, code can be further reduced which previously took care of
functionality built when compiled as module.
cgroupfs bits are being placed under net/core/netclassid_cgroup.c, so
that we are consistent with {netclassid,netprio}_cgroup naming that is
under net/core/ as suggested by Zefan.
No change in functionality, but only code refactoring that is being
done here.
[1] http://patchwork.ozlabs.org/patch/304825/
Suggested-by: Li Zefan <lizefan@huawei.com>
Cc: Zefan Li <lizefan@huawei.com>
Cc: Thomas Graf <tgraf@suug.ch>
Cc: cgroups@vger.kernel.org
Acked-by: Li Zefan <lizefan@huawei.com>
This reverts commit de6fb288b1246a5c4e00c0cdbfe3a838a360b3f4.
Otherwise we got:
net/sched/cls_cgroup.c:106:29: error: static declaration of ‘net_cls_subsys’ follows non-static declaration
static struct cgroup_subsys net_cls_subsys = {
In file included from include/linux/cgroup.h:654:0,
from net/sched/cls_cgroup.c:18:
include/linux/cgroup_subsys.h:35:29: note: previous declaration of ‘net_cls_subsys’ was here
SUBSYS(net_cls)
make[2]: *** [net/sched/cls_cgroup.o] Error 1
Doesn't need to be global.
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
No need to export functions only used in one file.
Signed-off-by: Zhi Yong Wu <wuzhy@linux.vnet.ibm.com>
Add a new attribute to support 64bit rates so that
tc can use them to break the 32bit limit.
Acked-by: Stephen Hemminger <stephen@networkplumber.org>
With TSO/GSO/GRO packets, skb->len doesn't represent
a precise amount of bytes on wire.
This patch replace skb->len with qdisc_pkt_len(skb)
which is more precise.
In dsmark_drop(), the function name printed by pr_debug
is "dsmark_reset", correct it to "dsmark_drop" by using
__func__ .
BTW, replace the other function names with __func__ .
Do not use C99 // comments and correct a spelling typo.
Prefer pr_warn(... to pr_warning(...
This is a bug fix. The existing code tries to kill many
birds with one stone: Handling binding of actions to
filters, new actions and replacing of action
attributes. A simple test case to illustrate:
XXXX
moja@fe1:~$ sudo tc actions add action drop index 12
moja@fe1:~$ actions get action gact index 12
action order 1: gact action drop
random type none pass val 0
index 12 ref 1 bind 0
moja@fe1:~$ sudo tc actions replace action ok index 12
index 12 ref 2 bind 0
XXXX
The above shows the refcounf being wrongly incremented on replace.
There are more complex scenarios with binding of actions to filters
that i am leaving out that didnt work as well...
When we set burst to 1514 with low rate in userspace,
the kernel get a value of burst that less than 1514,
which doesn't work.
Because it may make some loss when transform burst
to buffer in userspace. This makes burst lose some
bytes, when the kernel transform the buffer back to
burst.
This patch adds two new attributes to support sending
burst/mtu to kernel directly to avoid the loss.
This module shouldn't be randomly exporting symbols
list_for_each_entry(a, &act_base, head) doesn't
exit with a = NULL if we reached the end of the list.
tcf_unregister_action(), tc_lookup_action_n() and tc_lookup_action()
need fixes.
Remove tc_lookup_action_id() as its unused and not worth 'fixing'
Fixes: 1f747c26c48b ("net_sched: convert tc_action_ops to use struct list_head")
Cc: Cong Wang <xiyou.wangcong@gmail.com>
Reviewed-by: Cong Wang <xiyou.wangcong@gmail.com>
list_for_each_entry(t, &tcf_proto_base, head) doesn't
exit with t = NULL if we reached the end of the list.
Fixes: 3627287463b4 ("net_sched: convert tcf_proto_ops to use struct
list_head")
This patch fixes:
1) pass mask rather than size to tcf_hashinfo_init()
2) the cleanup should be in reversed order in mirred_cleanup_module()
Reported-by: Eric Dumazet <eric.dumazet@gmail.com>
Fixes: 369ba56787d7469c0afd ("net_sched: init struct tcf_hashinfo at register time")
It already has a NULL pointer check of rtab in qdisc_put_rtab().
Remove the check outside of qdisc_put_rtab().
