path: root/net/sctp/ipv6.c
2014-02-06net: sctp: fix initialization of local source address on accepted ipv6 socketsMatija Glavinic Pecotic
commit efe4208f47f907b86f528788da711e8ab9dea44d: 'ipv6: make lookups simpler and faster' broke initialization of local source address on accepted ipv6 sockets. Before the mentioned commit receive address was copied along with the contents of ipv6_pinfo in sctp_v6_create_accept_sk. Now when it is moved, it has to be copied separately. This also fixes lksctp's ipv6 regression in a sense that test_getname_v6, TC5 - 'getsockname on a connected server socket' now passes. Signed-off-by: Matija Glavinic Pecotic <matija.glavinic-pecotic.ext@nsn.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-26sctp: fix checkpatch errors with space required or prohibitedwangweidong
fix checkpatch errors while the space is required or prohibited to the "=,()++..." Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Wang Weidong <wangweidong1@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-21ipv6: move ip6_sk_accept_pmtu from generic pmtu update path to ipv6 oneHannes Frederic Sowa
In commit 93b36cf3425b9b ("ipv6: support IPV6_PMTU_INTERFACE on sockets") I made a horrible mistake to add ip6_sk_accept_pmtu to the generic sctp_icmp_frag_needed path. This results in build warnings if IPv6 is disabled which were luckily caught by Fengguang's kbuild bot. But it also leads to a kernel panic IPv4 frag-needed packet is received. Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-19Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/klassert/ipsec-next Steffen Klassert says: ==================== pull request (net-next): ipsec-next 2013-12-19 1) Use the user supplied policy index instead of a generated one if present. From Fan Du. 2) Make xfrm migration namespace aware. From Fan Du. 3) Make the xfrm state and policy locks namespace aware. From Fan Du. 4) Remove ancient sleeping when the SA is in acquire state, we now queue packets to the policy instead. This replaces the sleeping code. 5) Remove FLOWI_FLAG_CAN_SLEEP. This was used to notify xfrm about the posibility to sleep. The sleeping code is gone, so remove it. 6) Check user specified spi for IPComp. Thr spi for IPcomp is only 16 bit wide, so check for a valid value. From Fan Du. 7) Export verify_userspi_info to check for valid user supplied spi ranges with pfkey and netlink. From Fan Du. 8) RFC3173 states that if the total size of a compressed payload and the IPComp header is not smaller than the size of the original payload, the IP datagram must be sent in the original non-compressed form. These packets are dropped by the inbound policy check because they are not transformed. Document the need to set 'level use' for IPcomp to receive such packets anyway. From Fan Du. Please pull or let me know if there are problems. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-06sctp: Fix FSF address in file headersJeff Kirsher
Several files refer to an old address for the Free Software Foundation in the file header comment. Resolve by replacing the address with the URL <http://www.gnu.org/licenses/> so that we do not have to keep updating the header comments anytime the address changes. CC: Vlad Yasevich <vyasevich@gmail.com> CC: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-06net: Remove FLOWI_FLAG_CAN_SLEEPSteffen Klassert
FLOWI_FLAG_CAN_SLEEP was used to notify xfrm about the posibility to sleep until the needed states are resolved. This code is gone, so FLOWI_FLAG_CAN_SLEEP is not needed anymore. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2013-11-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/emulex/benet/be.h drivers/net/netconsole.c net/bridge/br_private.h Three mostly trivial conflicts. The net/bridge/br_private.h conflict was a function signature (argument addition) change overlapping with the extern removals from Joe Perches. In drivers/net/netconsole.c we had one change adjusting a printk message whilst another changed "printk(KERN_INFO" into "pr_info(". Lastly, the emulex change was a new inline function addition overlapping with Joe Perches's extern removals. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-23net: sctp: fix ASCONF to allow non SCTP_ADDR_SRC addresses in ipv6Daniel Borkmann
Commit 8a07eb0a50 ("sctp: Add ASCONF operation on the single-homed host") implemented possible use of IPv4 addresses with non SCTP_ADDR_SRC state as source address when sending ASCONF (ADD) packets, but IPv6 part for that was not implemented in 8a07eb0a50. Therefore, as this is not restricted to IPv4-only, fix this up to allow the same for IPv6 addresses in SCTP. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Cc: Michio Honda <micchie@sfc.wide.ad.jp> Acked-by: Michio Honda <micchie@sfc.wide.ad.jp> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-09ipv6: make lookups simpler and fasterEric Dumazet
TCP listener refactoring, part 4 : To speed up inet lookups, we moved IPv4 addresses from inet to struct sock_common Now is time to do the same for IPv6, because it permits us to have fast lookups for all kind of sockets, including upcoming SYN_RECV. Getting IPv6 addresses in TCP lookups currently requires two extra cache lines, plus a dereference (and memory stall). inet6_sk(sk) does the dereference of inet_sk(__sk)->pinet6 This patch is way bigger than its IPv4 counter part, because for IPv4, we could add aliases (inet_daddr, inet_rcv_saddr), while on IPv6, it's not doable easily. inet6_sk(sk)->daddr becomes sk->sk_v6_daddr inet6_sk(sk)->rcv_saddr becomes sk->sk_v6_rcv_saddr And timewait socket also have tw->tw_v6_daddr & tw->tw_v6_rcv_saddr at the same offset. We get rid of INET6_TW_MATCH() as INET6_MATCH() is now the generic macro. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-16net: sctp: rfc4443: do not report ICMP redirects to user spaceDaniel Borkmann
Adapt the same behaviour for SCTP as present in TCP for ICMP redirect messages. For IPv6, RFC4443, section 2.4. says: ... (e) An ICMPv6 error message MUST NOT be originated as a result of receiving the following: ... (e.2) An ICMPv6 redirect message [IPv6-DISC]. ... Therefore, do not report an error to user space, just invoke dst's redirect callback and leave, same for IPv4 as done in TCP as well. The implication w/o having this patch could be that the reception of such packets would generate a poll notification and in worst case it could even tear down the whole connection. Therefore, stop updating sk_err on redirects. Reported-by: Duan Jiong <duanj.fnst@cn.fujitsu.com> Reported-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Suggested-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-12net: sctp: fix ipv6 ipsec encryption bug in sctp_v6_xmitDaniel Borkmann
Alan Chester reported an issue with IPv6 on SCTP that IPsec traffic is not being encrypted, whereas on IPv4 it is. Setting up an AH + ESP transport does not seem to have the desired effect: SCTP + IPv4: 22:14:20.809645 IP (tos 0x2,ECT(0), ttl 64, id 0, offset 0, flags [DF], proto AH (51), length 116) 192.168.0.2 > 192.168.0.5: AH(spi=0x00000042,sumlen=16,seq=0x1): ESP(spi=0x00000044,seq=0x1), length 72 22:14:20.813270 IP (tos 0x2,ECT(0), ttl 64, id 0, offset 0, flags [DF], proto AH (51), length 340) 192.168.0.5 > 192.168.0.2: AH(spi=0x00000043,sumlen=16,seq=0x1): SCTP + IPv6: 22:31:19.215029 IP6 (class 0x02, hlim 64, next-header SCTP (132) payload length: 364) fe80::222:15ff:fe87:7fc.3333 > fe80::92e6:baff:fe0d:5a54.36767: sctp 1) [INIT ACK] [init tag: 747759530] [rwnd: 62464] [OS: 10] [MIS: 10] Moreover, Alan says: This problem was seen with both Racoon and Racoon2. Other people have seen this with OpenSwan. When IPsec is configured to encrypt all upper layer protocols the SCTP connection does not initialize. After using Wireshark to follow packets, this is because the SCTP packet leaves Box A unencrypted and Box B believes all upper layer protocols are to be encrypted so it drops this packet, causing the SCTP connection to fail to initialize. When IPsec is configured to encrypt just SCTP, the SCTP packets are observed unencrypted. In fact, using `socat sctp6-listen:3333 -` on one end and transferring "plaintext" string on the other end, results in cleartext on the wire where SCTP eventually does not report any errors, thus in the latter case that Alan reports, the non-paranoid user might think he's communicating over an encrypted transport on SCTP although he's not (tcpdump ... -X): ... 0x0030: 5d70 8e1a 0003 001a 177d eb6c 0000 0000 ]p.......}.l.... 0x0040: 0000 0000 706c 6169 6e74 6578 740a 0000 ....plaintext... Only in /proc/net/xfrm_stat we can see XfrmInTmplMismatch increasing on the receiver side. Initial follow-up analysis from Alan's bug report was done by Alexey Dobriyan. Also thanks to Vlad Yasevich for feedback on this. SCTP has its own implementation of sctp_v6_xmit() not calling inet6_csk_xmit(). This has the implication that it probably never really got updated along with changes in inet6_csk_xmit() and therefore does not seem to invoke xfrm handlers. SCTP's IPv4 xmit however, properly calls ip_queue_xmit() to do the work. Since a call to inet6_csk_xmit() would solve this problem, but result in unecessary route lookups, let us just use the cached flowi6 instead that we got through sctp_v6_get_dst(). Since all SCTP packets are being sent through sctp_packet_transmit(), we do the route lookup / flow caching in sctp_transport_route(), hold it in tp->dst and skb_dst_set() right after that. If we would alter fl6->daddr in sctp_v6_xmit() to np->opt->srcrt, we possibly could run into the same effect of not having xfrm layer pick it up, hence, use fl6_update_dst() in sctp_v6_get_dst() instead to get the correct source routed dst entry, which we assign to the skb. Also source address routing example from 625034113 ("sctp: fix sctp to work with ipv6 source address routing") still works with this patch! Nevertheless, in RFC5095 it is actually 'recommended' to not use that anyway due to traffic amplification [1]. So it seems we're not supposed to do that anyway in sctp_v6_xmit(). Moreover, if we overwrite the flow destination here, the lower IPv6 layer will be unable to put the correct destination address into IP header, as routing header is added in ipv6_push_nfrag_opts() but then probably with wrong final destination. Things aside, result of this patch is that we do not have any XfrmInTmplMismatch increase plus on the wire with this patch it now looks like: SCTP + IPv6: 08:17:47.074080 IP6 2620:52:0:102f:7a2b:cbff:fe27:1b0a > 2620:52:0:102f:213:72ff:fe32:7eba: AH(spi=0x00005fb4,seq=0x1): ESP(spi=0x00005fb5,seq=0x1), length 72 08:17:47.074264 IP6 2620:52:0:102f:213:72ff:fe32:7eba > 2620:52:0:102f:7a2b:cbff:fe27:1b0a: AH(spi=0x00003d54,seq=0x1): ESP(spi=0x00003d55,seq=0x1), length 296 This fixes Kernel Bugzilla 24412. This security issue seems to be present since 2.6.18 kernels. Lets just hope some big passive adversary in the wild didn't have its fun with that. lksctp-tools IPv6 regression test suite passes as well with this patch. [1] http://www.secdev.org/conf/IPv6_RH_security-csw07.pdf Reported-by: Alan Chester <alan.chester@tekelec.com> Reported-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Cc: Steffen Klassert <steffen.klassert@secunet.com> Cc: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-09net: sctp: trivial: update bug report in header commentDaniel Borkmann
With the restructuring of the lksctp.org site, we only allow bug reports through the SCTP mailing list linux-sctp@vger.kernel.org, not via SF, as SF is only used for web hosting and nothing more. While at it, also remove the obvious statement that bugs will be fixed and incooperated into the kernel. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-02sctp: Don't lookup dst if transport dst is still validfan.du
When sctp sits on IPv6, sctp_transport_dst_check pass cookie as ZERO, as a result ip6_dst_check always fail out. This behaviour makes transport->dst useless, because every sctp_packet_transmit must look for valid dst. Add a dst_cookie into sctp_transport, and set the cookie whenever we get new dst for sctp_transport. So dst validness could be checked against it. Since I have split genid for IPv4 and IPv6, also delete/add IPv6 address will also bump IPv6 genid. So issues we discussed in: http://marc.info/?l=linux-netdev&m=137404469219410&w=4 have all been sloved for this patch. Signed-off-by: Fan Du <fan.du@windriver.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-24net: sctp: trivial: update mailing list addressDaniel Borkmann
The SCTP mailing list address to send patches or questions to is linux-sctp@vger.kernel.org and not lksctp-developers@lists.sourceforge.net anymore. Therefore, update all occurences. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-01net: sctp: rework debugging framework to use pr_debug and friendsDaniel Borkmann
We should get rid of all own SCTP debug printk macros and use the ones that the kernel offers anyway instead. This makes the code more readable and conform to the kernel code, and offers all the features of dynamic debbuging that pr_debug() et al has, such as only turning on/off portions of debug messages at runtime through debugfs. The runtime cost of having CONFIG_DYNAMIC_DEBUG enabled, but none of the debug statements printing, is negligible [1]. If kernel debugging is completly turned off, then these statements will also compile into "empty" functions. While we're at it, we also need to change the Kconfig option as it /now/ only refers to the ifdef'ed code portions in outqueue.c that enable further debugging/tracing of SCTP transaction fields. Also, since SCTP_ASSERT code was enabled with this Kconfig option and has now been removed, we transform those code parts into WARNs resp. where appropriate BUG_ONs so that those bugs can be more easily detected as probably not many people have SCTP debugging permanently turned on. To turn on all SCTP debugging, the following steps are needed: # mount -t debugfs none /sys/kernel/debug # echo -n 'module sctp +p' > /sys/kernel/debug/dynamic_debug/control This can be done more fine-grained on a per file, per line basis and others as described in [2]. [1] https://www.kernel.org/doc/ols/2009/ols2009-pages-39-46.pdf [2] Documentation/dynamic-debug-howto.txt Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-17net: sctp: remove SCTP_STATIC macroDaniel Borkmann
SCTP_STATIC is just another define for the static keyword. It's use is inconsistent in the SCTP code anyway and it was introduced in the initial implementation of SCTP in 2.5. We have a regression suite in lksctp-tools, but this is for user space only, so noone makes use of this macro anymore. The kernel test suite for 2.5 is incompatible with the current SCTP code anyway. So simply Remove it, to be more consistent with the rest of the kernel code. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-17net: sctp: get rid of t_new macro for kzallocDaniel Borkmann
t_new rather obfuscates things where everyone else is using actual function names instead of that macro, so replace it with kzalloc, which is the function t_new wraps. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-13sctp: Correct byte order of access to skb->{network, transport}_headerSimon Horman
Corrects an byte order conflict introduced by 158874cac61245b84e939c92c53db7000122b7b0 ("sctp: Correct access to skb->{network, transport}_header"). The values in question are host byte order. Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-28sctp: Correct access to skb->{network, transport}_headerSimon Horman
This corrects an regression introduced by "net: Use 16bits for *_headers fields of struct skbuff" when NET_SKBUFF_DATA_USES_OFFSET is not set. In that case sk_buff_data_t will be a pointer, however, skb->{network,transport}_header is now __u16. Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-13net: sctp: sctp_v6_get_dst: fix boolean test in dst cacheDaniel Borkmann
We walk through the bind address list and try to get the best source address for a given destination. However, currently, we take the 'continue' path of the loop when an entry is invalid (!laddr->valid) *and* the entry state does not equal SCTP_ADDR_SRC (laddr->state != SCTP_ADDR_SRC). Thus, still, invalid entries with SCTP_ADDR_SRC might not 'continue' as well as valid entries with SCTP_ADDR_{NEW, SRC, DEL}, with a possible false baddr and matchlen as a result, causing in worst case dst route to be false or possibly NULL. This test should actually be a '||' instead of '&&'. But lets fix it and make this a bit easier to read by having the condition the same way as similarly done in sctp_v4_get_dst. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-30sctp: fix CONFIG_SCTP_DBG_MSG=y null pointer dereference in sctp_v6_get_dst()Tommi Rantala
Trinity (the syscall fuzzer) triggered the following BUG, reproducible only when the kernel is configured with CONFIG_SCTP_DBG_MSG=y. When CONFIG_SCTP_DBG_MSG is not set, the null pointer is never dereferenced. ---[ end trace a4de0bfcb38a3642 ]--- BUG: unable to handle kernel NULL pointer dereference at 0000000000000100 IP: [<ffffffff8136796e>] ip6_string+0x1e/0xa0 PGD 4eead067 PUD 4e472067 PMD 0 Oops: 0000 [#1] PREEMPT SMP Modules linked in: CPU 3 Pid: 21324, comm: trinity-child11 Tainted: G W 3.7.0-rc7+ #61 ASUSTeK Computer INC. EB1012/EB1012 RIP: 0010:[<ffffffff8136796e>] [<ffffffff8136796e>] ip6_string+0x1e/0xa0 RSP: 0018:ffff88004e4637a0 EFLAGS: 00010046 RAX: ffff88004e4637da RBX: ffff88004e4637da RCX: 0000000000000000 RDX: ffffffff8246e92a RSI: 0000000000000100 RDI: ffff88004e4637da RBP: ffff88004e4637a8 R08: 000000000000ffff R09: 000000000000ffff R10: 0000000000000000 R11: 0000000000000000 R12: ffffffff8289d600 R13: ffffffff8289d230 R14: ffffffff8246e928 R15: ffffffff8289d600 FS: 00007fed95153700(0000) GS:ffff88005fd80000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000100 CR3: 000000004eeac000 CR4: 00000000000007e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process trinity-child11 (pid: 21324, threadinfo ffff88004e462000, task ffff8800524b0000) Stack: ffff88004e4637da ffff88004e463828 ffffffff81368eee 000000004e4637d8 ffffffff0000ffff ffff88000000ffff 0000000000000000 000000004e4637f8 ffffffff826285d8 ffff88004e4637f8 0000000000000000 ffff8800524b06b0 Call Trace: [<ffffffff81368eee>] ip6_addr_string.isra.11+0x3e/0xa0 [<ffffffff81369183>] pointer.isra.12+0x233/0x2d0 [<ffffffff810a413a>] ? vprintk_emit+0x1ba/0x450 [<ffffffff8110953d>] ? trace_hardirqs_on_caller+0x10d/0x1a0 [<ffffffff81369757>] vsnprintf+0x187/0x5d0 [<ffffffff81369c62>] vscnprintf+0x12/0x30 [<ffffffff810a4028>] vprintk_emit+0xa8/0x450 [<ffffffff81e5cb00>] printk+0x49/0x4b [<ffffffff81d17221>] sctp_v6_get_dst+0x731/0x780 [<ffffffff81d16e15>] ? sctp_v6_get_dst+0x325/0x780 [<ffffffff81d00a96>] sctp_transport_route+0x46/0x120 [<ffffffff81cff0f1>] sctp_assoc_add_peer+0x161/0x350 [<ffffffff81d0fd8d>] sctp_sendmsg+0x6cd/0xcb0 [<ffffffff81b55bf0>] ? inet_create+0x670/0x670 [<ffffffff81b55cfb>] inet_sendmsg+0x10b/0x220 [<ffffffff81b55bf0>] ? inet_create+0x670/0x670 [<ffffffff81a72a64>] ? sock_update_classid+0xa4/0x2b0 [<ffffffff81a72ab0>] ? sock_update_classid+0xf0/0x2b0 [<ffffffff81a6ac1c>] sock_sendmsg+0xdc/0xf0 [<ffffffff8118e9e5>] ? might_fault+0x85/0x90 [<ffffffff8118e99c>] ? might_fault+0x3c/0x90 [<ffffffff81a6e12a>] sys_sendto+0xfa/0x130 [<ffffffff810a9887>] ? do_setitimer+0x197/0x380 [<ffffffff81e960d5>] ? sysret_check+0x22/0x5d [<ffffffff81e960a9>] system_call_fastpath+0x16/0x1b Code: 01 eb 89 66 2e 0f 1f 84 00 00 00 00 00 55 48 89 f8 31 c9 48 89 e5 53 eb 12 0f 1f 40 00 48 83 c1 01 48 83 c0 04 48 83 f9 08 74 70 <0f> b6 3c 4e 89 fb 83 e7 0f c0 eb 04 41 89 d8 41 83 e0 0f 0f b6 RIP [<ffffffff8136796e>] ip6_string+0x1e/0xa0 RSP <ffff88004e4637a0> CR2: 0000000000000100 ---[ end trace a4de0bfcb38a3643 ]--- Signed-off-by: Tommi Rantala <tt.rantala@gmail.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-14sctp: Make the mib per network namespaceEric W. Biederman
Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-14sctp: Enable sctp in all network namespacesEric W. Biederman
- Fix the sctp_af operations to work in all namespaces - Enable sctp socket creation in all network namespaces. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-14sctp: Make the address lists per network namespaceEric W. Biederman
- Move the address lists into struct net - Add per network namespace initialization and cleanup - Pass around struct net so it is everywhere I need it. - Rename all of the global variable references into references to the variables moved into struct net Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-14sctp: Make the association hashtable handle multiple network namespacesEric W. Biederman
- Use struct net in the hash calculation - Use sock_net(association.base.sk) in the association lookups. - On receive calculate the network namespace from skb->dev. - Pass struct net from receive down to the functions that actually do the association lookup. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-12ipv6: Add redirect support to all protocol icmp error handlers.David S. Miller
2011-11-22net: remove ipv6_addr_copy()Alexey Dobriyan
C assignment can handle struct in6_addr copying. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-27ipv6: tcp: fix TCLASS value in ACK messages sent from TIME_WAITEric Dumazet
commit 66b13d99d96a (ipv4: tcp: fix TOS value in ACK messages sent from TIME_WAIT) fixed IPv4 only. This part is for the IPv6 side, adding a tclass param to ip6_xmit() We alias tw_tclass and tw_tos, if socket family is INET6. [ if sockets is ipv4-mapped, only IP_TOS socket option is used to fill TOS field, TCLASS is not taken into account ] Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-02sctp: Add Auto-ASCONF support (core).Michio Honda
SCTP reconfigure the IP addresses in the association by using ASCONF chunks as mentioned in RFC5061. For example, we can start to use the newly configured IP address in the existing association. This patch implements automatic ASCONF operation in the SCTP stack with address events in the host computer, which is called auto_asconf. Signed-off-by: Michio Honda <micchie@sfc.wide.ad.jp> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Acked-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1446 commits) macvlan: fix panic if lowerdev in a bond tg3: Add braces around 5906 workaround. tg3: Fix NETIF_F_LOOPBACK error macvlan: remove one synchronize_rcu() call networking: NET_CLS_ROUTE4 depends on INET irda: Fix error propagation in ircomm_lmp_connect_response() irda: Kill set but unused variable 'bytes' in irlan_check_command_param() irda: Kill set but unused variable 'clen' in ircomm_connect_indication() rxrpc: Fix set but unused variable 'usage' in rxrpc_get_transport() be2net: Kill set but unused variable 'req' in lancer_fw_download() irda: Kill set but unused vars 'saddr' and 'daddr' in irlan_provider_connect_indication() atl1c: atl1c_resume() is only used when CONFIG_PM_SLEEP is defined. rxrpc: Fix set but unused variable 'usage' in rxrpc_get_peer(). rxrpc: Kill set but unused variable 'local' in rxrpc_UDP_error_handler() rxrpc: Kill set but unused variable 'sp' in rxrpc_process_connection() rxrpc: Kill set but unused variable 'sp' in rxrpc_rotate_tx_window() pkt_sched: Kill set but unused variable 'protocol' in tc_classify() isdn: capi: Use pr_debug() instead of ifdefs. tg3: Update version to 3.119 tg3: Apply rx_discards fix to 5719/5720 ... Fix up trivial conflicts in arch/x86/Kconfig and net/mac80211/agg-tx.c as per Davem.
2011-05-07net,rcu: convert call_rcu(sctp_local_addr_free) to kfree_rcu()Lai Jiangshan
The rcu callback sctp_local_addr_free() just calls a kfree(), so we use kfree_rcu() instead of the call_rcu(sctp_local_addr_free). Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-04-27sctp: clean up route lookup callsVlad Yasevich
Change the call to take the transport parameter and set the cached 'dst' appropriately inside the get_dst() function calls. This will allow us in the future to clean up source address storage as well. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-27sctp: remove useless arguments from get_saddr() callVlad Yasevich
There is no point in passing a destination address to a get_saddr() call. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-27sctp: make sctp over IPv6 work with IPsecVlad Yasevich
SCTP never called xfrm_output after it's v6 route lookups so that never really worked with ipsec. Additioanlly, we never passed port nubmers and protocol in the flowi, so any port based policies were never applied as well. Now that we can fixed ipv6 routing lookup code, using ip6_dst_lookup_flow() and pass port numbers. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-27sctp: cache the ipv6 source after route lookupVlad Yasevich
The ipv6 routing lookup does give us a source address, but instead of filling it into the dst, it's stored in the flowi. We can use that instead of going through the entire source address selection again. Also the useless ->dst_saddr member of sctp_pf is removed. And sctp_v6_dst_saddr() is removed, instead by introduce sctp_v6_to_addr(), which can be reused to cleanup some dup code. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-27sctp: fix sctp to work with ipv6 source address routingWeixing Shi
In the below test case, using the source address routing, sctp can not work. Node-A 1)ifconfig eth0 inet6 add 2001:1::1/64 2)ip -6 rule add from 2001:1::1 table 100 pref 100 3)ip -6 route add 2001:2::1 dev eth0 table 100 4)sctp_darn -H 2001:1::1 -P 250 -l & Node-B 1)ifconfig eth0 inet6 add 2001:2::1/64 2)ip -6 rule add from 2001:2::1 table 100 pref 100 3)ip -6 route add 2001:1::1 dev eth0 table 100 4)sctp_darn -H 2001:2::1 -P 250 -h 2001:1::1 -p 250 -s root cause: Node-A and Node-B use the source address routing, and at begining, source address will be NULL,sctp will search the routing table by the destination address, because using the source address routing table, and the result dst_entry will be NULL. solution: walk through the bind address list to get the source address and then lookup the routing table again to get the correct dst_entry. Signed-off-by: Weixing Shi <Weixing.Shi@windriver.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-22inet: constify ip headers and in6_addrEric Dumazet
Add const qualifiers to structs iphdr, ipv6hdr and in6_addr pointers where possible, to make code intention more obvious. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-12ipv6: Convert to use flowi6 where applicable.David S. Miller
2011-03-12net: Put flowi_* prefix on AF independent members of struct flowiDavid S. Miller
I intend to turn struct flowi into a union of AF specific flowi structs. There will be a common structure that each variant includes first, much like struct sock_common. This is the first step to move in that direction. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-26net/sctp: Use pr_fmt and pr_<level>Joe Perches
Change SCTP_DEBUG_PRINTK and SCTP_DEBUG_PRINTK_IPADDR to use do { print } while (0) guards. Add SCTP_DEBUG_PRINTK_CONT to fix errors in log when lines were continued. Add #define pr_fmt(fmt) KBUILD_MODNAME ": " fmt Add a missing newline in "Failed bind hash alloc" Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-15net: replace ipfragok with skb->local_dfShan Wei
As Herbert Xu said: we should be able to simply replace ipfragok with skb->local_df. commit f88037(sctp: Drop ipfargok in sctp_xmit function) has droped ipfragok and set local_df value properly. The patch kills the ipfragok parameter of .queue_xmit(). Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-03SCTP: Change to use ipv6_addr_copy()Brian Haley
Change SCTP IPv6 code to use ipv6_addr_copy() Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-30sctp: Use ipv6_addr_diff() in sctp_v6_addr_match_len().YOSHIFUJI Hideaki / 吉藤英明
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-20ipv6: convert idev_list to list macrosstephen hemminger
Convert to list macro's for the list of addresses per interface in IPv6. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-17net: remove INIT_RCU_HEAD() usageAlexey Dobriyan
call_rcu() will unconditionally reinitialize RCU head anyway. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-05sctp: ipv6: avoid touching device refcountEric Dumazet
Avoid touching device refcount in sctp/ipv6, thanks to RCU Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-05net: drop capability from protocol definitionsEric Paris
struct can_proto had a capability field which wasn't ever used. It is dropped entirely. struct inet_protosw had a capability field which can be more clearly expressed in the code by just checking if sock->type = SOCK_RAW. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-14net: constify struct inet6_protocolAlexey Dobriyan
