Fengguang reported the following sparse warning:
>> net/ipv6/proc.c:198:41: sparse: incorrect type in argument 1 (different address spaces)
net/ipv6/proc.c:198:41: expected void [noderef] <asn:3>*mib
net/ipv6/proc.c:198:41: got void [noderef] <asn:3>**pcpumib
Fixes: commit 698365fa1874aa7635d51667a3 (net: clean up snmp stats code)
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Redefined local_bh_{disable|enable} to sctp_local_bh_{disable|enable}
for user space friendly code which we haven't use in years, so removing them.
Signed-off-by: Wang Weidong <wangweidong1@huawei.com>
fix checkpatch errors below:
ERROR: "(foo*)" should be "(foo *)"
ERROR: "foo * bar" should be "foo *bar"
ERROR: "foo* bar" should be "foo *bar"
Several files refer to an old address for the Free Software Foundation
in the file header comment. Resolve by replacing the address with
the URL <http://www.gnu.org/licenses/> so that we do not have to keep
updating the header comments anytime the address changes.
CC: Vlad Yasevich <vyasevich@gmail.com>
CC: Neil Horman <nhorman@tuxdriver.com>
UIDs are printed in the proc_fs as signed int, whereas
they are unsigned int.
Signed-off-by: Francesco Fusco <ffusco@redhat.com>
With the restructuring of the lksctp.org site, we only allow bug
reports through the SCTP mailing list linux-sctp@vger.kernel.org,
not via SF, as SF is only used for web hosting and nothing more.
While at it, also remove the obvious statement that bugs will be
fixed and incooperated into the kernel.
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
The SCTP mailing list address to send patches or questions
to is linux-sctp@vger.kernel.org and not
lksctp-developers@lists.sourceforge.net anymore. Therefore,
update all occurences.
A trailing newline has been forgotten to add into the WARN().
This clearly states a BUG somewhere in the SCTP code as e.g. fixed once
in f28156335 ("sctp: Use correct sideffect command in duplicate cookie
handling"). If this ever happens, throw a trace in the sideeffect engine
where assocs clearly must have a primary_path assigned.
When in sctp_seq_dump_local_addrs() also throw a WARN and bail out since
we do not need to panic for printing this one asterisk. Also, it will
avoid the not so obvious case when primary != NULL test passes and at a
later point in time triggering a NULL ptr dereference caused by primary.
While at it, also fix up the white space.
sctp: Add buffer utilization fields to /proc/net/sctp/assocs
This patch adds the following fields to /proc/net/sctp/assocs output:
- sk->sk_wmem_alloc as "wmema" (transmit queue bytes committed)
- sk->sk_wmem_queued as "wmemq" (persistent queue size)
- sk->sk_sndbuf as "sndbuf" (size of send buffer in bytes)
- sk->sk_rcvbuf as "rcvbuf" (size of receive buffer in bytes)
When small DATA chunks containing 136 bytes data are sent the TX_QUEUE
(assoc->sndbuf_used) reaches a maximum of 40.9% of sk_sndbuf value when
peer.rwnd = 0. This was diagnosed from sk_wmem_alloc value reaching maximum
value of sk_sndbuf.
TX_QUEUE (assoc->sndbuf_used), sk_wmem_alloc and sk_wmem_queued values are
incremented in sctp_set_owner_w() for outgoing data chunks. Having access to
the above values in /proc/net/sctp/assocs will provide a better understanding
of SCTP buffer management.
With patch applied, example output when peer.rwnd = 0
where:
ASSOC ffff880132298000 is sender
ffff880125343000 is receiver
ASSOC SOCK STY SST ST HBKT ASSOC-ID TX_QUEUE RX_QUEUE \
ffff880132298000 ffff880124a0a0c0 2 1 3 29325 1 214656 0 \
ffff880125343000 ffff8801237d7700 2 1 3 36210 2 0 524520 \
UID INODE LPORT RPORT LADDRS <-> RADDRS HBINT INS OUTS \
0 25108 3455 3456 *10.4.8.3 <-> *10.5.8.3 7500 2 2 \
0 27819 3456 3455 *10.5.8.3 <-> *10.4.8.3 7500 2 2 \
MAXRT T1X T2X RTXC wmema wmemq sndbuf rcvbuf
4 0 0 72 525633 440320 524288 524288
4 0 0 0 1 0 524288 524288
Signed-off-by: Dilip Daya <dilip.daya@hp.com>
I'm not sure why, but the hlist for each entry iterators were conceived
list_for_each_entry(pos, head, member)
The hlist ones were greedy and wanted an extra parameter:
hlist_for_each_entry(tpos, pos, head, member)
Why did they need an extra pos parameter? I'm not quite sure. Not only
they don't really need it, it also prevents the iterator from looking
exactly like the list iterator, which is unfortunate.
Besides the semantic patch, there was some manual work required:
- Fix up the actual hlist iterators in linux/list.h
- Fix up the declaration of other iterators based on the hlist ones.
- A very small amount of places were using the 'node' parameter, this
was modified to use 'obj->member' instead.
- Coccinelle didn't handle the hlist_for_each_entry_safe iterator
properly, so those had to be fixed up manually.
The semantic patch which is mostly the work of Peter Senna Tschudin is here:
iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host;
type T;
expression a,c,d,e;
identifier b;
statement S;
-T b;
<+... when != b
hlist_for_each_entry(a,
- b,
c, d) S
hlist_for_each_entry_continue(a,
- b,
c) S
hlist_for_each_entry_from(a,
- b,
c) S
hlist_for_each_entry_rcu(a,
- b,
c, d) S
hlist_for_each_entry_rcu_bh(a,
- b,
c, d) S
hlist_for_each_entry_continue_rcu_bh(a,
- b,
c) S
for_each_busy_worker(a, c,
- b,
d) S
ax25_uid_for_each(a,
- b,
c) S
ax25_for_each(a,
- b,
c) S
inet_bind_bucket_for_each(a,
- b,
c) S
sctp_for_each_hentry(a,
- b,
c) S
sk_for_each(a,
- b,
c) S
sk_for_each_rcu(a,
- b,
c) S
sk_for_each_from
-(a, b)
+(a)
S
+ sk_for_each_from(a) S
sk_for_each_safe(a,
- b,
c, d) S
sk_for_each_bound(a,
- b,
c) S
hlist_for_each_entry_safe(a,
- b,
c, d, e) S
hlist_for_each_entry_continue_rcu(a,
- b,
c) S
nr_neigh_for_each(a,
- b,
c) S
nr_neigh_for_each_safe(a,
- b,
c, d) S
nr_node_for_each(a,
- b,
c) S
nr_node_for_each_safe(a,
- b,
c, d) S
- for_each_gfn_sp(a, c, d, b) S
+ for_each_gfn_sp(a, c, d) S
- for_each_gfn_indirect_valid_sp(a, c, d, b) S
+ for_each_gfn_indirect_valid_sp(a, c, d) S
for_each_host(a,
- b,
c) S
for_each_host_safe(a,
- b,
c, d) S
for_each_mesh_entry(a,
- b,
c, d) S
[akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c]
[akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c]
[akpm@linux-foundation.org: checkpatch fixes]
[akpm@linux-foundation.org: fix warnings]
[akpm@linux-foudnation.org: redo intrusive kvm changes]
Tested-by: Peter Senna Tschudin <peter.senna@gmail.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Gleb Natapov <gleb@redhat.com>
peer.transport_addr_list is currently only protected by sk_sock
which is inpractical to acquire for procfs dumping purposes.
This patch adds RCU protection allowing for the procfs readers to
enter RCU read-side critical sections.
Modification of the list continues to be serialized via sk_lock.
V2: Use list_del_rcu() in sctp_association_free() to be safe
Skip transports marked dead when dumping for procfs
Cc: Vlad Yasevich <vyasevich@gmail.com>
Cc: Neil Horman <nhorman@tuxdriver.com>
Signed-off-by: Thomas Graf <tgraf@suug.ch>
address_list is protected via the socket lock or RCU. Since we don't want
to take the socket lock for each assoc we dump in procfs a RCU read-side
critical section must be entered.
V2: Skip local addresses marked as dead
Acked-by: Vlad Yasevich <vyasevic@gmail.com>
Commit 13d782f ("sctp: Make the proc files per network namespace.")
changed the /proc/net/sctp/ struct file_operations opener functions to
use single_open_net() and seq_open_net().
Avoid leaking memory by using single_release_net() and seq_release_net()
as the release functions.
Discovered with Trinity (the syscall fuzzer).
Signed-off-by: Tommi Rantala <tt.rantala@gmail.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
This is an initial merge in of Eric Biederman's work to start adding
user namespace support to the networking.
struct seq_net_private has no struct net
if CONFIG_NET_NS is not enabled
Signed-off-by: Ulrich Weber <ulrich.weber@sophos.com>
Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com>
- Convert all of the files under /proc/net/sctp to be per
network namespace.
- Don't print anything for /proc/net/sctp/snmp except in
the initial network namespaces as the snmp counters still
have to be converted to be per network namespace.
Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Cc: Sridhar Samudrala <sri@us.ibm.com>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
These files are non modular, but need to export symbols using
the macros now living in export.h -- call out the include so
that things won't break when we remove the implicit presence
of module.h from everywhere.
The %pK format specifier is designed to hide exposed kernel pointers,
specifically via /proc interfaces. Exposing these pointers provides an
easy target for kernel write vulnerabilities, since they reveal the
locations of writable structures containing easily triggerable function
pointers. The behavior of %pK depends on the kptr_restrict sysctl.
If kptr_restrict is set to 0, no deviation from the standard %p behavior
occurs. If kptr_restrict is set to 1, the default, if the current user
(intended to be a reader via seq_printf(), etc.) does not have CAP_SYSLOG
(currently in the LSM tree), kernel pointers using %pK are printed as 0's.
If kptr_restrict is set to 2, kernel pointers using %pK are printed as
0's regardless of privileges. Replacing with 0's was chosen over the
default "(null)", which cannot be parsed by userland %p, which expects
"(nil)".
The supporting code for kptr_restrict and %pK are currently in the -mm
tree. This patch converts users of %p in net/ to %pK. Cases of printing
pointers to the syslog are not covered, since this would eliminate useful
information for postmortem debugging and the reading of the syslog is
already optionally protected by the dmesg_restrict sysctl.
Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com>
Cc: Thomas Graf <tgraf@infradead.org>
Cc: Eugene Teo <eugeneteo@kernel.org>
Cc: Kees Cook <kees.cook@canonical.com>
Cc: Eric Paris <eparis@parisplace.org>
This patch removes from net/ (but not any netfilter files)
all the unnecessary return; statements that precede the
last closing brace of void functions.
It does not remove the returns that are immediately
preceded by a label as gcc doesn't like that.
Done via:
$ grep -rP --include=*.[ch] -l "return;\n}" net/ | \
xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }'
Add __percpu sparse annotations to net.
These annotations are to make sparse consider percpu variables to be
in a different address space and warn if accessed without going
through percpu accessors. This patch doesn't affect normal builds.
The macro and type tricks around snmp stats make things a bit
interesting. DEFINE/DECLARE_SNMP_STAT() macros mark the target field
as __percpu and SNMP_UPD_PO_STATS() macro is updated accordingly. All
snmp_mib_*() users which used to cast the argument to (void **) are
updated to cast it to (void __percpu **).
Cc: Vlad Yasevich <vladislav.yasevich@hp.com>
Cc: netdev@vger.kernel.org
create_proc_entry() is deprecated (not formally, though).
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
Commit 20c2c1fd6c842caf70dcb1d94b9d58861949fd3d
(sctp: add sctp/remaddr table to complete RFC remote address table OID)
added an unused sctp_assoc_proc_exit() function that seems to have been
unintentionally created when copying the assocs code.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Add support for RFC3873 remote address table OID.
+--(5) sctpAssocRemAddrTable
| |--(-) sctpAssocId (shared index)
| +--(1) sctpAssocRemAddrType (index)
. +--(2) sctpAssocRemAddr (index)
+--(3) sctpAssocRemAddrActive
+--(4) sctpAssocRemAddrHBActive
+--(5) sctpAssocRemAddrRTO
+--(6) sctpAssocRemAddrMaxPathRtx
+--(7) sctpAssocRemAddrRtx
+--(8) sctpAssocRemAddrStartTime
This patch places all the requsite data in /proc/net/sctp/remaddr.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Replacing (almost) all invocations of list_for_each() with
list_for_each_entry() tightens up the code and allows for the deletion
of numerous list iterator variables that are no longer necessary.
Recently I posted a patch to add some informational items to
/proc/net/sctp/assocs. All the information is correct, but because
of how the seqfile show operation is laid out, some of the formatting
is backwards. This patch corrects that formatting, so that the new
information appears at the end of each line, rather than in the middle.
net/mac80211/rc80211_pid_algo.c
sctp_association->hbinterval is unsigned long. Replace %8d with %8lu.
Signed-off-by: Denis V. Lunev <den@openvz.org>
RFC 3873 specifies several MIB objects that can't be obtained by the
current data set exported by /proc/sys/net/sctp/assoc. This patch
adds the missing pieces of data that allow us to compute all the
objects in the sctpAssocTable object.
In addition to commit 160f17 ("[SCTP]: Use proc_create() to setup
->proc_fops first") use proc_create in two more places.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Use proc_create() to make sure that ->proc_fops be setup before gluing
PDE to main tree.
Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com>
SCPT already depends in INET, so this doesn't create additional
dependencies.
Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com>
I was notified by Randy Stewart that lksctp claims to be
"the reference implementation". First of all, "the
refrence implementation" was the original implementation
of SCTP in usersapce written ty Randy and a few others.
Second, after looking at the definiton of 'reference implementation',
we don't really meet the requirements.
Convert the custom hash list traversals to use hlist functions.
Make all initialized struct seq_operations in net/ const
Signed-off-by: Philippe De Muyter <phdm@macqel.be>
Many struct file_operations in the kernel can be "const". Marking them const
moves these to the .rodata section, which avoids false sharing with potential
dirty data. In addition it'll catch accidental writes at compile time to
these shared resources.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Users adjusted.
instances of ->cmp_addr() are fine with switching both arguments
to net-endian; callers other than in sctp_cmp_addr_exact() (both
as ->cmp_addr(...) and direct calls of instances) adjusted;
sctp_cmp_addr_exact() switched to net-endian itself and adjustment
is done in its callers
No actual modifications of method instances are needed -
they don't look at port numbers. Switch callers...
Part 1: rename sctp_chunk->source, sctp_sockaddr_entry->a,
sctp_transport->ipaddr and sctp_transport->saddr (to ..._h)
The next patch will reintroduce these fields and keep them as
net-endian mirrors of the original (renamed) ones. Split in
two patches to make sure that we hadn't forgotten any instanes.
Later in the series we'll eliminate uses of host-endian variants
(basically switching users to net-endian counterparts as we
progress through that mess). Then host-endian ones will die.
Other embedded host-endian sctp_addr will be easier to switch
directly, so we leave them alone for now.
Show the true receive buffer usage.
Signed-off-by: Sridhar Samudrala <sri@us.ibm.com>
This patch adds more statistics info under /proc/net/sctp/snmp
that should be useful for debugging. The additional events that
are counted now include timer expirations, retransmits, packet
and data chunk discards.
The Data chunk discards include all the cases where a data chunk
is discarded including high tsn, bad stream, dup tsn and the most
useful one(out of receive buffer/rwnd).
Also moved the SCTP MIB data structures from the generic include
directories to include/sctp/sctp.h.
for_each_cpu() actually iterates across all possible CPUs. We've had mistakes
in the past where people were using for_each_cpu() where they should have been
iterating across only online or present CPUs. This is inefficient and
possibly buggy.
We're renaming for_each_cpu() to for_each_possible_cpu() to avoid this in the
future.
This patch replaces for_each_cpu with for_each_possible_cpu under /net
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Acked-by: "David S. Miller" <davem@davemloft.net>
This patch corrects the panic by casting the argument to the
pointer of correct size. On big-endian systems we ended up loading
only 32 bits of data because we are treating the pointer as an int*.
By treating this pointer as loff_t*, we'll load the full 64 bits
and then let regular integer demotion take place which will give us
the correct value.
Signed-off-by: Vlad Yaseivch <vladislav.yasevich@hp.com>
When creating a very large number of associations (and endpoints),
/proc/assocs and /proc/eps will not show all of them. As a result
netstat will not show all of the either. This is particularly evident
when creating 1000+ associations (or endpoints). As an example with
1500 tcp style associations over loopback, netstat showed 1420 on my
system instead of 3000.
The reason for this is that the seq_operations start method is invoked
multiple times bacause of the amount of data that is provided. The
start method always increments the position parameter and since we use
the position as the hash bucket id, we end up skipping hash buckets.
This patch corrects this situation and get's rid of the silly hash-1
decrement.
In 'net' change the explicit use of for-loops and NR_CPUS into the
general for_each_cpu() or for_each_online_cpu() constructs, as
appropriate. This widens the scope of potential future optimizations
of the general constructs, as well as takes advantage of the existing
optimizations of first_cpu() and next_cpu(), which is advantageous
when the true CPU count is much smaller than NR_CPUS.
Signed-off-by: John Hawkes <hawkes@sgi.com>
Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
