With the recent fix, the callers of sctp_primitive_ABORT()
need to create an ABORT chunk and pass it as an argument rather
than msghdr that was passed earlier.
Adrian Bunk:
Ported to 2.6.16.
Signed-off-by: Sridhar Samudrala <sri@us.ibm.com>
When using ASSOCINFO socket option, we need to limit the number of
maximum association retransmissions to be no greater than the sum
of all the path retransmissions. This is specified in Section 7.1.2
of the SCTP socket API draft.
However, we only do this if the association has multiple paths. If
there is only one path, the protocol stack will use the
assoc_max_retrans setting when trying to retransmit packets.
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
Make SCTP handle broadcast properly
sctp_make_abort_user() now takes the msg_len along with the msg
so that we don't have to recalculate the bytes in iovec.
It also uses memcpy_fromiovec() so that we don't go beyond the
length allocated.
It is good to have this fix even if verify_iovec() is fixed to
return error on overflow.
Acked-by: David Miller <davem@davemloft.net>
We currently count the initial INIT/COOKIE_ECHO chunk toward the
retransmit count and thus sends a total of sctp_max_retrans_init chunks.
The correct behavior is to retransmit the chunk sctp_max_retrans_init in
addition to sending the original.
Validate and update the sk in sctp_rcv() to avoid the race where an
assoc/ep could move to a different socket after we get the sk, but before
the skb is added to the backlog.
Also migrate the skb's in backlog queue to new sk when doing a peeloff.
Change all the structure members that hold jiffies to be of type
unsigned long. This also corrects bad sysctl formating on 64 bit
architectures.
net: Use <linux/capability.h> where capable() is used.
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
This removes more unneeded casts on the return value for kmalloc(),
sock_kmalloc(), and vmalloc().
Signed-off-by: Kris Katterjohn <kjak@users.sourceforge.net>
Acked-by: James Morris <jmorris@namei.org>
Signed-off-by: Frank Filz <ffilz@us.ibm.com>
This patch adds support to set/get heartbeat interval, maximum number of
retransmissions, pathmtu, sackdelay time for a particular transport/
association/socket as per the latest SCTP sockets api draft11.
Make sctp_writeable() use sk_wmem_alloc rather than sk_wmem_queued to
determine the sndbuf space available. It also removes all the modifications
to sk_wmem_queued as it is not currently used in SCTP.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
This patch fixes an issue where it is possible to get valid data after
a ENOTCONN error. It returns socket errors only after data queued on
socket receive queue is consumed.
Also introduces a sysctl option to configure the receive buffer
accounting policy to be either at socket or association level.
Default is all the associations on the same socket share the
receive buffer.
The socket level timeout values are maintained in sctp_sock and
association level timeouts are in sctp_association. So there is
no need for ep->timeouts.
Signed-off-by: Vladislav Yasevich <vladislav.yasevich@hp.com>
privileged ports.
Signed-off-by: Ivan Skytte Jorgensen <isj-sctp@i1.dk>
Rename SCTP specific control message flags to use SCTP_ prefix rather than
MSG_ prefix as per the latest sctp sockets API draft.
The old socket options are marked with a _OLD suffix so that the
existing 32-bit apps on 32-bit kernels do not break.
Signed-off-by: Ivan Skytte Jørgensen <isj-sctp@i1.dk>
Since the patch to add a NULL short-circuit to crypto_free_tfm() went in,
there's no longer any need for callers of that function to check for NULL.
This patch removes the redundant NULL checks and also a few similar checks
for NULL before calls to kfree() that I ran into while doing the
crypto_free_tfm bits.
I've succesfuly compile tested this patch, and a kernel with the patch
applied boots and runs just fine.
When I posted the patch to LKML (and other lists/people on Cc) it drew the
following comments :
J. Bruce Fields commented
"I've no problem with the auth_gss or nfsv4 bits.--b."
Sridhar Samudrala said
"sctp change looks fine."
Herbert Xu signed off on the patch.
So, I guess this is ready to be dropped into -mm and eventually mainline.
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
Remove the "list" member of struct sk_buff, as it is entirely
redundant. All SKB list removal callers know which list the
SKB is on, so storing this in sk_buff does nothing other than
taking up some space.
Two tricky bits were SCTP, which I took care of, and two ATM
drivers which Francois Romieu <romieu@fr.zoreil.com> fixed
up.
Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
Implements sctp_connectx() as defined in the SCTP sockets API draft by
tunneling the request through a setsockopt().
Signed-off-by: Frank Filz <ffilzlnx@us.ibm.com>
This patch replaces the spin_lock_irqsave call on the receive queue
lock in SCTP with spin_lock_bh. Despite the proliferation of
spin_lock_irqsave calls in this stack, it is only entered from the
IPv4/IPv6 stack and user space. That is, it is never entered from
hardirq context.
The call in question is only called from recvmsg which means that
IRQs aren't disabled. Therefore it is safe to replace it with
spin_lock_bh.
- Include chunk and skb sizes in sendbuffer accounting.
- 2 policies are supported. 0: per socket accouting, 1: per association
accounting
DaveM: I've made the default per-socket.
Signed-off-by: Neil Horman <nhorman@redhat.com>
infrastructure for it.
Let it rip!
