[ Upstream commit b14878ccb7fac0242db82720b784ab62c467c0dc ]
Currently, it is possible to create an SCTP socket, then switch
auth_enable via sysctl setting to 1 and crash the system on connect:
Oops[#1]:
CPU: 0 PID: 0 Comm: swapper Not tainted 3.14.1-mipsgit-20140415 #1
task: ffffffff8056ce80 ti: ffffffff8055c000 task.ti: ffffffff8055c000
Call Trace:
[<ffffffff8043c4e8>] sctp_auth_asoc_set_default_hmac+0x68/0x80
[<ffffffff8042b300>] sctp_process_init+0x5e0/0x8a4
[<ffffffff8042188c>] sctp_sf_do_5_1B_init+0x234/0x34c
[<ffffffff804228c8>] sctp_do_sm+0xb4/0x1e8
[<ffffffff80425a08>] sctp_endpoint_bh_rcv+0x1c4/0x214
[<ffffffff8043af68>] sctp_rcv+0x588/0x630
[<ffffffff8043e8e8>] sctp6_rcv+0x10/0x24
[<ffffffff803acb50>] ip6_input+0x2c0/0x440
[<ffffffff8030fc00>] __netif_receive_skb_core+0x4a8/0x564
[<ffffffff80310650>] process_backlog+0xb4/0x18c
[<ffffffff80313cbc>] net_rx_action+0x12c/0x210
[<ffffffff80034254>] __do_softirq+0x17c/0x2ac
[<ffffffff800345e0>] irq_exit+0x54/0xb0
[<ffffffff800075a4>] ret_from_irq+0x0/0x4
[<ffffffff800090ec>] rm7k_wait_irqoff+0x24/0x48
[<ffffffff8005e388>] cpu_startup_entry+0xc0/0x148
[<ffffffff805a88b0>] start_kernel+0x37c/0x398
Code: dd0900b8 000330f8 0126302d <dcc60000> 50c0fff1 0047182a a48306a0
03e00008 00000000
---[ end trace b530b0551467f2fd ]---
Kernel panic - not syncing: Fatal exception in interrupt
What happens while auth_enable=0 in that case is, that
ep->auth_hmacs is initialized to NULL in sctp_auth_init_hmacs()
when endpoint is being created.
After that point, if an admin switches over to auth_enable=1,
the machine can crash due to NULL pointer dereference during
reception of an INIT chunk. When we enter sctp_process_init()
via sctp_sf_do_5_1B_init() in order to respond to an INIT chunk,
the INIT verification succeeds and while we walk and process
all INIT params via sctp_process_param() we find that
net->sctp.auth_enable is set, therefore do not fall through,
but invoke sctp_auth_asoc_set_default_hmac() instead, and thus,
dereference what we have set to NULL during endpoint
initialization phase.
The fix is to make auth_enable immutable by caching its value
during endpoint initialization, so that its original value is
being carried along until destruction. The bug seems to originate
from the very first days.
Fix in joint work with Daniel Borkmann.
Reported-by: Joshua Kinard <kumba@gentoo.org>
Signed-off-by: Vlad Yasevich <vyasevic@redhat.com>
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Tested-by: Joshua Kinard <kumba@gentoo.org>
[ Upstream commit 1e1cdf8ac78793e0875465e98a648df64694a8d0 ]
In function sctp_wake_up_waiters(), we need to involve a test
if the association is declared dead. If so, we don't have any
reference to a possible sibling association anymore and need
to invoke sctp_write_space() instead, and normally walk the
socket's associations and notify them of new wmem space. The
reason for special casing is that otherwise, we could run
into the following issue when a sctp_primitive_SEND() call
from sctp_sendmsg() fails, and tries to flush an association's
outq, i.e. in the following way:
sctp_association_free()
`-> list_del(&asoc->asocs) <-- poisons list pointer
asoc->base.dead = true
sctp_outq_free(&asoc->outqueue)
`-> __sctp_outq_teardown()
`-> sctp_chunk_free()
`-> consume_skb()
`-> sctp_wfree()
`-> sctp_wake_up_waiters() <-- dereferences poisoned pointers
if asoc->ep->sndbuf_policy=0
Therefore, only walk the list in an 'optimized' way if we find
that the current association is still active. We could also use
list_del_init() in addition when we call sctp_association_free(),
but as Vlad suggests, we want to trap such bugs and thus leave
it poisoned as is.
Why is it safe to resolve the issue by testing for asoc->base.dead?
Parallel calls to sctp_sendmsg() are protected under socket lock,
that is lock_sock()/release_sock(). Only within that path under
lock held, we're setting skb/chunk owner via sctp_set_owner_w().
Eventually, chunks are freed directly by an association still
under that lock. So when traversing association list on destruction
time from sctp_wake_up_waiters() via sctp_wfree(), a different
CPU can't be running sctp_wfree() while another one calls
sctp_association_free() as both happens under the same lock.
Therefore, this can also not race with setting/testing against
asoc->base.dead as we are guaranteed for this to happen in order,
under lock. Further, Vlad says: the times we check asoc->base.dead
is when we've cached an association pointer for later processing.
In between cache and processing, the association may have been
freed and is simply still around due to reference counts. We check
asoc->base.dead under a lock, so it should always be safe to check
and not race against sctp_association_free(). Stress-testing seems
fine now, too.
Fixes: cd253f9f357d ("net: sctp: wake up all assocs if sndbuf policy is per socket")
Cc: Vlad Yasevich <vyasevic@redhat.com>
Acked-by: Vlad Yasevich <vyasevic@redhat.com>
[ Upstream commit 52c35befb69b005c3fc5afdaae3a5717ad013411 ]
SCTP charges chunks for wmem accounting via skb->truesize in
sctp_set_owner_w(), and sctp_wfree() respectively as the
reverse operation. If a sender runs out of wmem, it needs to
wait via sctp_wait_for_sndbuf(), and gets woken up by a call
to __sctp_write_space() mostly via sctp_wfree().
__sctp_write_space() is being called per association. Although
we assign sk->sk_write_space() to sctp_write_space(), which
is then being done per socket, it is only used if send space
is increased per socket option (SO_SNDBUF), as SOCK_USE_WRITE_QUEUE
is set and therefore not invoked in sock_wfree().
Commit 4c3a5bdae293 ("sctp: Don't charge for data in sndbuf
again when transmitting packet") fixed an issue where in case
sctp_packet_transmit() manages to queue up more than sndbuf
bytes, sctp_wait_for_sndbuf() will never be woken up again
unless it is interrupted by a signal. However, a still
remaining issue is that if net.sctp.sndbuf_policy=0, that is
accounting per socket, and one-to-many sockets are in use,
the reclaimed write space from sctp_wfree() is 'unfairly'
handed back on the server to the association that is the lucky
one to be woken up again via __sctp_write_space(), while
the remaining associations are never be woken up again
(unless by a signal).
The effect disappears with net.sctp.sndbuf_policy=1, that
is wmem accounting per association, as it guarantees a fair
share of wmem among associations.
Therefore, if we have reclaimed memory in case of per socket
accounting, wake all related associations to a socket in a
fair manner, that is, traverse the socket association list
starting from the current neighbour of the association and
issue a __sctp_write_space() to everyone until we end up
waking ourselves. This guarantees that no association is
preferred over another and even if more associations are
taken into the one-to-many session, all receivers will get
messages from the server and are not stalled forever on
high load. This setting still leaves the advantage of per
socket accounting in touch as an association can still use
up global limits if unused by others.
Fixes: 4eb701dfc618 ("[SCTP] Fix SCTP sendbuffer accouting.")
Cc: Thomas Graf <tgraf@suug.ch>
Cc: Neil Horman <nhorman@tuxdriver.com>
[ Upstream commit ffd5939381c609056b33b7585fb05a77b4c695f3 ]
SCTP's sctp_connectx() abi breaks for 64bit kernels compiled with 32bit
emulation (e.g. ia32 emulation or x86_x32). Due to internal usage of
'struct sctp_getaddrs_old' which includes a struct sockaddr pointer,
sizeof(param) check will always fail in kernel as the structure in
64bit kernel space is 4bytes larger than for user binaries compiled
in 32bit mode. Thus, applications making use of sctp_connectx() won't
be able to run under such circumstances.
Introduce a compat interface in the kernel to deal with such
situations by using a 'struct compat_sctp_getaddrs_old' structure
where user data is copied into it, and then sucessively transformed
into a 'struct sctp_getaddrs_old' structure with the help of
compat_ptr(). That fixes sctp_connectx() abi without any changes
needed in user space, and lets the SCTP test suite pass when compiled
in 32bit and run on 64bit kernels.
Fixes: f9c67811ebc0 ("sctp: Fix regression introduced by new sctp_connectx api")
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
[ Upstream commit 88362ad8f9a6cea787420b57cc27ccacef000dbe ]
This was originally reported in [1] and posted by Neil Horman [2], he said:
Fix up a missed null pointer check in the asconf code. If we don't find
a local address, but we pass in an address length of more than 1, we may
dereference a NULL laddr pointer. Currently this can't happen, as the only
users of the function pass in the value 1 as the addrcnt parameter, but
its not hot path, and it doesn't hurt to check for NULL should that ever
be the case.
The callpath from sctp_asconf_mgmt() looks okay. But this could be triggered
from sctp_setsockopt_bindx() call with SCTP_BINDX_REM_ADDR and addrcnt > 1
while passing all possible addresses from the bind list to SCTP_BINDX_REM_ADDR
so that we do *not* find a single address in the association's bind address
list that is not in the packed array of addresses. If this happens when we
have an established association with ASCONF-capable peers, then we could get
a NULL pointer dereference as we only check for laddr == NULL && addrcnt == 1
and call later sctp_make_asconf_update_ip() with NULL laddr.
BUT: this actually won't happen as sctp_bindx_rem() will catch such a case
and return with an error earlier. As this is incredably unintuitive and error
prone, add a check to catch at least future bugs here. As Neil says, its not
hot path. Introduced by 8a07eb0a5 ("sctp: Add ASCONF operation on the
single-homed host").
[1] http://www.spinics.net/lists/linux-sctp/msg02132.html
[2] http://www.spinics.net/lists/linux-sctp/msg02133.html
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Cc: Michio Honda <micchie@sfc.wide.ad.jp>
Acked-By: Neil Horman <nhorman@tuxdriver.com>
[ Upstream commit a0fb05d1aef0f5df936f80b726d1b3bfd4275f95 ]
If we do not add braces around ...
mask |= POLLERR |
sock_flag(sk, SOCK_SELECT_ERR_QUEUE) ? POLLPRI : 0;
... then this condition always evaluates to true as POLLERR is
defined as 8 and binary or'd with whatever result comes out of
sock_flag(). Hence instead of (X | Y) ? A : B, transform it into
X | (Y ? A : B). Unfortunatelty, commit 8facd5fb73 ("net: fix
smatch warnings inside datagram_poll") forgot about SCTP. :-(
Introduced by 7d4c04fc170 ("net: add option to enable error queue
packets waking select").
Cc: Jacob Keller <jacob.e.keller@intel.com>
Acked-by: Jacob Keller <jacob.e.keller@intel.com>
While stress testing sctp sockets, I hit the following panic:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000020
IP: [<ffffffffa0490c4e>] sctp_endpoint_free+0xe/0x40 [sctp]
PGD 7cead067 PUD 7ce76067 PMD 0
Oops: 0000 [#1] SMP
Modules linked in: sctp(F) libcrc32c(F) [...]
CPU: 7 PID: 2950 Comm: acc Tainted: GF 3.10.0-rc2+ #1
Hardware name: Dell Inc. PowerEdge T410/0H19HD, BIOS 1.6.3 02/01/2011
task: ffff88007ce0e0c0 ti: ffff88007b568000 task.ti: ffff88007b568000
RIP: 0010:[<ffffffffa0490c4e>] [<ffffffffa0490c4e>] sctp_endpoint_free+0xe/0x40 [sctp]
RSP: 0018:ffff88007b569e08 EFLAGS: 00010292
RAX: 0000000000000000 RBX: ffff88007db78a00 RCX: dead000000200200
RDX: ffffffffa049fdb0 RSI: ffff8800379baf38 RDI: 0000000000000000
RBP: ffff88007b569e18 R08: ffff88007c230da0 R09: 0000000000000001
R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000000
R13: ffff880077990d00 R14: 0000000000000084 R15: ffff88007db78a00
FS: 00007fc18ab61700(0000) GS:ffff88007fc60000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 0000000000000020 CR3: 000000007cf9d000 CR4: 00000000000007e0
Stack:
ffff88007b569e38 ffff88007db78a00 ffff88007b569e38 ffffffffa049fded
ffffffff81abf0c0 ffff88007db78a00 ffff88007b569e58 ffffffff8145b60e
0000000000000000 0000000000000000 ffff88007b569eb8 ffffffff814df36e
Call Trace:
[<ffffffffa049fded>] sctp_destroy_sock+0x3d/0x80 [sctp]
[<ffffffff8145b60e>] sk_common_release+0x1e/0xf0
[<ffffffff814df36e>] inet_create+0x2ae/0x350
[<ffffffff81455a6f>] __sock_create+0x11f/0x240
[<ffffffff81455bf0>] sock_create+0x30/0x40
[<ffffffff8145696c>] SyS_socket+0x4c/0xc0
[<ffffffff815403be>] ? do_page_fault+0xe/0x10
[<ffffffff8153cb32>] ? page_fault+0x22/0x30
[<ffffffff81544e02>] system_call_fastpath+0x16/0x1b
Code: 0c c9 c3 66 2e 0f 1f 84 00 00 00 00 00 e8 fb fe ff ff c9 c3 66 0f
1f 84 00 00 00 00 00 55 48 89 e5 53 48 83 ec 08 66 66 66 66 90 <48>
8b 47 20 48 89 fb c6 47 1c 01 c6 40 12 07 e8 9e 68 01 00 48
RIP [<ffffffffa0490c4e>] sctp_endpoint_free+0xe/0x40 [sctp]
RSP <ffff88007b569e08>
---[ end trace e0d71ec1108c1dd9 ]---
I did not hit this with the lksctp-tools functional tests, but with a
small, multi-threaded test program, that heavily allocates, binds,
listens and waits in accept on sctp sockets, and then randomly kills
some of them (no need for an actual client in this case to hit this).
Then, again, allocating, binding, etc, and then killing child processes.
This panic then only occurs when ``echo 1 > /proc/sys/net/sctp/auth_enable''
is set. The cause for that is actually very simple: in sctp_endpoint_init()
we enter the path of sctp_auth_init_hmacs(). There, we try to allocate
our crypto transforms through crypto_alloc_hash(). In our scenario,
it then can happen that crypto_alloc_hash() fails with -EINTR from
crypto_larval_wait(), thus we bail out and release the socket via
sk_common_release(), sctp_destroy_sock() and hit the NULL pointer
dereference as soon as we try to access members in the endpoint during
sctp_endpoint_free(), since endpoint at that time is still NULL. Now,
if we have that case, we do not need to do any cleanup work and just
leave the destruction handler.
Fix to return a negative error code from the error handling
case instead of 0, as returned elsewhere in this function.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Currently, when a socket receives something on the error queue it only wakes up
the socket on select if it is in the "read" list, that is the socket has
something to read. It is useful also to wake the socket if it is in the error
list, which would enable software to wait on error queue packets without waking
up for regular data on the socket. The main use case is for receiving
timestamped transmit packets which return the timestamp to the socket via the
error queue. This enables an application to select on the socket for the error
queue only instead of for the regular traffic.
-v2-
* Added the SO_SELECT_ERR_QUEUE socket option to every architechture specific file
* Modified every socket poll function that checks error queue
Signed-off-by: Jacob Keller <jacob.e.keller@intel.com>
Cc: Jeffrey Kirsher <jeffrey.t.kirsher@intel.com>
Cc: Richard Cochran <richardcochran@gmail.com>
Cc: Matthew Vick <matthew.vick@intel.com>
Pull networking fixes from David Miller:
"A moderately sized pile of fixes, some specifically for merge window
introduced regressions although others are for longer standing items
and have been queued up for -stable.
I'm kind of tired of all the RDS protocol bugs over the years, to be
honest, it's way out of proportion to the number of people who
actually use it.
1) Fix missing range initialization in netfilter IPSET, from Jozsef
Kadlecsik.
2) ieee80211_local->tim_lock needs to use BH disabling, from Johannes
Berg.
3) Fix DMA syncing in SFC driver, from Ben Hutchings.
4) Fix regression in BOND device MAC address setting, from Jiri
Pirko.
5) Missing usb_free_urb in ISDN Hisax driver, from Marina Makienko.
6) Fix UDP checksumming in bnx2x driver for 57710 and 57711 chips,
fix from Dmitry Kravkov.
7) Missing cfgspace_lock initialization in BCMA driver.
8) Validate parameter size for SCTP assoc stats getsockopt(), from
Guenter Roeck.
9) Fix SCTP association hangs, from Lee A Roberts.
10) Fix jumbo frame handling in r8169, from Francois Romieu.
11) Fix phy_device memory leak, from Petr Malat.
12) Omit trailing FCS from frames received in BGMAC driver, from Hauke
Mehrtens.
13) Missing socket refcount release in L2TP, from Guillaume Nault.
14) sctp_endpoint_init should respect passed in gfp_t, rather than use
GFP_KERNEL unconditionally. From Dan Carpenter.
15) Add AISX AX88179 USB driver, from Freddy Xin.
16) Remove MAINTAINERS entries for drivers deleted during the merge
window, from Cesar Eduardo Barros.
17) RDS protocol can try to allocate huge amounts of memory, check
that the user's request length makes sense, from Cong Wang.
18) SCTP should use the provided KMALLOC_MAX_SIZE instead of it's own,
bogus, definition. From Cong Wang.
19) Fix deadlocks in FEC driver by moving TX reclaim into NAPI poll,
from Frank Li. Also, fix a build error introduced in the merge
window.
20) Fix bogus purging of default routes in ipv6, from Lorenzo Colitti.
21) Don't double count RTT measurements when we leave the TCP receive
fast path, from Neal Cardwell."
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (61 commits)
tcp: fix double-counted receiver RTT when leaving receiver fast path
CAIF: fix sparse warning for caif_usb
rds: simplify a warning message
net: fec: fix build error in no MXC platform
net: ipv6: Don't purge default router if accept_ra=2
net: fec: put tx to napi poll function to fix dead lock
sctp: use KMALLOC_MAX_SIZE instead of its own MAX_KMALLOC_SIZE
rds: limit the size allocated by rds_message_alloc()
MAINTAINERS: remove eexpress
MAINTAINERS: remove drivers/net/wan/cycx*
MAINTAINERS: remove 3c505
caif_dev: fix sparse warnings for caif_flow_cb
ax88179_178a: ASIX AX88179_178A USB 3.0/2.0 to gigabit ethernet adapter driver
sctp: use the passed in gfp flags instead GFP_KERNEL
ipv[4|6]: correct dropwatch false positive in local_deliver_finish
l2tp: Restore socket refcount when sendmsg succeeds
net/phy: micrel: Disable asymmetric pause for KSZ9021
bgmac: omit the fcs
phy: Fix phy_device_free memory leak
bnx2x: Fix KR2 work-around condition
I'm not sure why, but the hlist for each entry iterators were conceived
list_for_each_entry(pos, head, member)
The hlist ones were greedy and wanted an extra parameter:
hlist_for_each_entry(tpos, pos, head, member)
Why did they need an extra pos parameter? I'm not quite sure. Not only
they don't really need it, it also prevents the iterator from looking
exactly like the list iterator, which is unfortunate.
Besides the semantic patch, there was some manual work required:
- Fix up the actual hlist iterators in linux/list.h
- Fix up the declaration of other iterators based on the hlist ones.
- A very small amount of places were using the 'node' parameter, this
was modified to use 'obj->member' instead.
- Coccinelle didn't handle the hlist_for_each_entry_safe iterator
properly, so those had to be fixed up manually.
The semantic patch which is mostly the work of Peter Senna Tschudin is here:
iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host;
type T;
expression a,c,d,e;
identifier b;
statement S;
-T b;
<+... when != b
hlist_for_each_entry(a,
- b,
c, d) S
hlist_for_each_entry_continue(a,
- b,
c) S
hlist_for_each_entry_from(a,
- b,
c) S
hlist_for_each_entry_rcu(a,
- b,
c, d) S
hlist_for_each_entry_rcu_bh(a,
- b,
c, d) S
hlist_for_each_entry_continue_rcu_bh(a,
- b,
c) S
for_each_busy_worker(a, c,
- b,
d) S
ax25_uid_for_each(a,
- b,
c) S
ax25_for_each(a,
- b,
c) S
inet_bind_bucket_for_each(a,
- b,
c) S
sctp_for_each_hentry(a,
- b,
c) S
sk_for_each(a,
- b,
c) S
sk_for_each_rcu(a,
- b,
c) S
sk_for_each_from
-(a, b)
+(a)
S
+ sk_for_each_from(a) S
sk_for_each_safe(a,
- b,
c, d) S
sk_for_each_bound(a,
- b,
c) S
hlist_for_each_entry_safe(a,
- b,
c, d, e) S
hlist_for_each_entry_continue_rcu(a,
- b,
c) S
nr_neigh_for_each(a,
- b,
c) S
nr_neigh_for_each_safe(a,
- b,
c, d) S
nr_node_for_each(a,
- b,
c) S
nr_node_for_each_safe(a,
- b,
c, d) S
- for_each_gfn_sp(a, c, d, b) S
+ for_each_gfn_sp(a, c, d) S
- for_each_gfn_indirect_valid_sp(a, c, d, b) S
+ for_each_gfn_indirect_valid_sp(a, c, d) S
for_each_host(a,
- b,
c) S
for_each_host_safe(a,
- b,
c, d) S
for_each_mesh_entry(a,
- b,
c, d) S
[akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c]
[akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c]
[akpm@linux-foundation.org: checkpatch fixes]
[akpm@linux-foundation.org: fix warnings]
[akpm@linux-foudnation.org: redo intrusive kvm changes]
Tested-by: Peter Senna Tschudin <peter.senna@gmail.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Gleb Natapov <gleb@redhat.com>
Building sctp may fail with:
In function ‘copy_from_user’,
inlined from ‘sctp_getsockopt_assoc_stats’ at
net/sctp/socket.c:5656:20:
arch/x86/include/asm/uaccess_32.h:211:26: error: call to
‘copy_from_user_overflow’ declared with attribute error: copy_from_user()
buffer size is not provably correct
if built with W=1 due to a missing parameter size validation
before the call to copy_from_user.
In sctp_setsockopt_auth_key, we create a temporary copy of the user
passed shared auth key for the endpoint or association and after
internal setup, we free it right away. Since it's sensitive data, we
should zero out the key before returning the memory back to the
allocator. Thus, use kzfree instead of kfree, just as we do in
sctp_auth_key_put().
SCTP_GET_ASSOC_STATS call
The current SCTP stack is lacking a mechanism to have per association
statistics. This is an implementation modeled after OpenSolaris'
SCTP_GET_ASSOC_STATS.
Userspace part will follow on lksctp if/when there is a general ACK on
this.
V4:
- Move ipackets++ before q->immediate.func() for consistency reasons
- Move sctp_max_rto() at the end of sctp_transport_update_rto() to avoid
returning bogus RTO values
- return asoc->rto_min when max_obs_rto value has not changed
V3:
- Increase ictrlchunks in sctp_assoc_bh_rcv() as well
- Move ipackets++ to sctp_inq_push()
- return 0 when no rto updates took place since the last call
V2:
- Implement partial retrieval of stat struct to cope for future expansion
- Kill the rtxpackets counter as it cannot be precise anyway
- Rename outseqtsns to outofseqtsns to make it clearer that these are out
of sequence unexpected TSNs
- Move asoc->ipackets++ under a lock to avoid potential miscounts
- Fold asoc->opackets++ into the already existing asoc check
- Kill unneeded (q->asoc) test when increasing rtxchunks
- Do not count octrlchunks if sending failed (SCTP_XMIT_OK != 0)
- Don't count SHUTDOWNs as SACKs
- Move SCTP_GET_ASSOC_STATS to the private space API
- Adjust the len check in sctp_getsockopt_assoc_stats() to allow for
future struct growth
- Move association statistics in their own struct
- Update idupchunks when we send a SACK with dup TSNs
- return min_rto in max_rto when RTO has not changed. Also return the
transport when max_rto last changed.
Signed-off: Michele Baldessari <michele@acksyn.org>
Consider the following program, that sets the second argument to the
sendto() syscall incorrectly:
#include <string.h>
#include <arpa/inet.h>
#include <sys/socket.h>
int main(void)
int fd;
struct sockaddr_in sa;
fd = socket(AF_INET, SOCK_STREAM, 132 /*IPPROTO_SCTP*/);
if (fd < 0)
return 1;
memset(&sa, 0, sizeof(sa));
sa.sin_family = AF_INET;
sa.sin_addr.s_addr = inet_addr("127.0.0.1");
sa.sin_port = htons(11111);
sendto(fd, NULL, 1, 0, (struct sockaddr *)&sa, sizeof(sa));
return 0;
We get -ENOMEM:
$ strace -e sendto ./demo
sendto(3, NULL, 1, 0, {sa_family=AF_INET, sin_port=htons(11111), sin_addr=inet_addr("127.0.0.1")}, 16) = -1 ENOMEM (Cannot allocate memory)
Propagate the error code from sctp_user_addto_chunk(), so that we will
tell user space what actually went wrong:
sendto(3, NULL, 1, 0, {sa_family=AF_INET, sin_port=htons(11111), sin_addr=inet_addr("127.0.0.1")}, 16) = -1 EFAULT (Bad address)
Noticed while running Trinity (the syscall fuzzer).
Signed-off-by: Tommi Rantala <tt.rantala@gmail.com>
Allow privileged users in any user namespace to bind to
privileged sockets in network namespaces they control.
drivers/net/ethernet/broadcom/bnx2x/bnx2x_main.c
Minor conflict between the BCM_CNIC define removal in net-next
and a bug fix added to net. Based upon a conflict resolution
patch posted by Stephen Rothwell.
Correct spelling typo in net/sctp/socket.c
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Currently sctp allows for the optional use of md5 of sha1 hmac algorithms to
generate cookie values when establishing new connections via two build time
config options. Theres no real reason to make this a static selection. We can
add a sysctl that allows for the dynamic selection of these algorithms at run
time, with the default value determined by the corresponding crypto library
availability.
This comes in handy when, for example running a system in FIPS mode, where use
of md5 is disallowed, but SHA1 is permitted.
Note: This new sysctl has no corresponding socket option to select the cookie
hmac algorithm. I chose not to implement that intentionally, as RFC 6458
contains no option for this value, and I opted not to pollute the socket option
namespace.
Change notes:
v2)
* Updated subject to have the proper sctp prefix as per Dave M.
* Replaced deafult selection options with new options that allow
developers to explicitly select available hmac algs at build time
as per suggestion by Vlad Y.
CC: Vlad Yasevich <vyasevich@gmail.com>
CC: "David S. Miller" <davem@davemloft.net>
CC: netdev@vger.kernel.org
Pull vfs update from Al Viro:
- big one - consolidation of descriptor-related logics; almost all of
that is moved to fs/file.c
(BTW, I'm seriously tempted to rename the result to fd.c. As it is,
we have a situation when file_table.c is about handling of struct
file and file.c is about handling of descriptor tables; the reasons
are historical - file_table.c used to be about a static array of
struct file we used to have way back).
A lot of stray ends got cleaned up and converted to saner primitives,
disgusting mess in android/binder.c is still disgusting, but at least
doesn't poke so much in descriptor table guts anymore. A bunch of
relatively minor races got fixed in process, plus an ext4 struct file
leak.
- related thing - fget_light() partially unuglified; see fdget() in
there (and yes, it generates the code as good as we used to have).
- also related - bits of Cyrill's procfs stuff that got entangled into
that work; _not_ all of it, just the initial move to fs/proc/fd.c and
switch of fdinfo to seq_file.
- Alex's fs/coredump.c spiltoff - the same story, had been easier to
take that commit than mess with conflicts. The rest is a separate
pile, this was just a mechanical code movement.
- a few misc patches all over the place. Not all for this cycle,
there'll be more (and quite a few currently sit in akpm's tree)."
Fix up trivial conflicts in the android binder driver, and some fairly
simple conflicts due to two different changes to the sock_alloc_file()
interface ("take descriptor handling from sock_alloc_file() to callers"
vs "net: Providing protocol type via system.sockprotoname xattr of
/proc/PID/fd entries" adding a dentry name to the socket)
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (72 commits)
MAX_LFS_FILESIZE should be a loff_t
compat: fs: Generic compat_sys_sendfile implementation
fs: push rcu_barrier() from deactivate_locked_super() to filesystems
btrfs: reada_extent doesn't need kref for refcount
coredump: move core dump functionality into its own file
coredump: prevent double-free on an error path in core dumper
usb/gadget: fix misannotations
fcntl: fix misannotations
ceph: don't abuse d_delete() on failure exits
hypfs: ->d_parent is never NULL or negative
vfs: delete surplus inode NULL check
switch simple cases of fget_light to fdget
new helpers: fdget()/fdput()
switch o2hb_region_dev_write() to fget_light()
proc_map_files_readdir(): don't bother with grabbing files
make get_file() return its argument
vhost_set_vring(): turn pollstart/pollstop into bool
switch prctl_set_mm_exe_file() to fget_light()
switch xfs_find_handle() to fget_light()
switch xfs_swapext() to fget_light()
Both modular callers of sock_map_fd() had been buggy; sctp one leaks
descriptor and file if copy_to_user() fails, 9p one shouldn't be
exposing file in the descriptor table at all.
Switch both to sock_alloc_file(), export it, unexport sock_map_fd() and
make it static.
This trickles up through sctp_sm_lookup_event up to sctp_do_sm
and up further into sctp_primitiv_NAME before the code reaches
places where struct net can be reliably found.
- Move the address lists into struct net
- Add per network namespace initialization and cleanup
- Pass around struct net so it is everywhere I need it.
- Rename all of the global variable references into references
to the variables moved into struct net
- Add struct net into the port hash table hash calculation
- Add struct net inot the struct sctp_bind_bucket so there
is a memory of which network namespace a port is allocated in.
No need for a ref count because sctp_bind_bucket only exists
when there are sockets in the hash table and sockets can not
change their network namspace, and sockets already ref count
their network namespace.
- Add struct net into the key comparison when we are testing
to see if we have found the port hash table entry we are
looking for.
With these changes lookups in the port hash table becomes
safe to use in multiple network namespaces.
I've seen several attempts recently made to do quick failover of sctp transports
by reducing various retransmit timers and counters. While its possible to
implement a faster failover on multihomed sctp associations, its not
particularly robust, in that it can lead to unneeded retransmits, as well as
false connection failures due to intermittent latency on a network.
Instead, lets implement the new ietf quick failover draft found here:
http://tools.ietf.org/html/draft-nishida-tsvwg-sctp-failover-05
This will let the sctp stack identify transports that have had a small number of
errors, and avoid using them quickly until their reliability can be
re-established. I've tested this out on two virt guests connected via multiple
isolated virt networks and believe its in compliance with the above draft and
works well.
CC: Sridhar Samudrala <sri@us.ibm.com>
CC: linux-sctp@vger.kernel.org
CC: joe@perches.com
drivers/net/ethernet/intel/ixgbevf/ixgbevf_main.c
A few days ago Dave Jones reported this oops:
[22766.294255] general protection fault: 0000 [#1] PREEMPT SMP
[22766.295376] CPU 0
[22766.295384] Modules linked in:
[22766.387137] ffffffffa169f292 6b6b6b6b6b6b6b6b ffff880147c03a90
ffff880147c03a74
[22766.387135] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 00000000000
[22766.387136] Process trinity-watchdo (pid: 10896, threadinfo ffff88013e7d2000,
[22766.387137] Stack:
[22766.387140] ffff880147c03a10
[22766.387140] ffffffffa169f2b6
[22766.387140] ffff88013ed95728
[22766.387143] 0000000000000002
[22766.387143] 0000000000000000
[22766.387143] ffff880003fad062
[22766.387144] ffff88013c120000
[22766.387144]
[22766.387145] Call Trace:
[22766.387145] <IRQ>
[22766.387150] [<ffffffffa169f292>] ? __sctp_lookup_association+0x62/0xd0
[sctp]
[22766.387154] [<ffffffffa169f2b6>] __sctp_lookup_association+0x86/0xd0 [sctp]
[22766.387157] [<ffffffffa169f597>] sctp_rcv+0x207/0xbb0 [sctp]
[22766.387161] [<ffffffff810d4da8>] ? trace_hardirqs_off_caller+0x28/0xd0
[22766.387163] [<ffffffff815827e3>] ? nf_hook_slow+0x133/0x210
[22766.387166] [<ffffffff815902fc>] ? ip_local_deliver_finish+0x4c/0x4c0
[22766.387168] [<ffffffff8159043d>] ip_local_deliver_finish+0x18d/0x4c0
[22766.387169] [<ffffffff815902fc>] ? ip_local_deliver_finish+0x4c/0x4c0
[22766.387171] [<ffffffff81590a07>] ip_local_deliver+0x47/0x80
[22766.387172] [<ffffffff8158fd80>] ip_rcv_finish+0x150/0x680
[22766.387174] [<ffffffff81590c54>] ip_rcv+0x214/0x320
[22766.387176] [<ffffffff81558c07>] __netif_receive_skb+0x7b7/0x910
[22766.387178] [<ffffffff8155856c>] ? __netif_receive_skb+0x11c/0x910
[22766.387180] [<ffffffff810d423e>] ? put_lock_stats.isra.25+0xe/0x40
[22766.387182] [<ffffffff81558f83>] netif_receive_skb+0x23/0x1f0
[22766.387183] [<ffffffff815596a9>] ? dev_gro_receive+0x139/0x440
[22766.387185] [<ffffffff81559280>] napi_skb_finish+0x70/0xa0
[22766.387187] [<ffffffff81559cb5>] napi_gro_receive+0xf5/0x130
[22766.387218] [<ffffffffa01c4679>] e1000_receive_skb+0x59/0x70 [e1000e]
[22766.387242] [<ffffffffa01c5aab>] e1000_clean_rx_irq+0x28b/0x460 [e1000e]
[22766.387266] [<ffffffffa01c9c18>] e1000e_poll+0x78/0x430 [e1000e]
[22766.387268] [<ffffffff81559fea>] net_rx_action+0x1aa/0x3d0
[22766.387270] [<ffffffff810a495f>] ? account_system_vtime+0x10f/0x130
[22766.387273] [<ffffffff810734d0>] __do_softirq+0xe0/0x420
[22766.387275] [<ffffffff8169826c>] call_softirq+0x1c/0x30
[22766.387278] [<ffffffff8101db15>] do_softirq+0xd5/0x110
[22766.387279] [<ffffffff81073bc5>] irq_exit+0xd5/0xe0
[22766.387281] [<ffffffff81698b03>] do_IRQ+0x63/0xd0
[22766.387283] [<ffffffff8168ee2f>] common_interrupt+0x6f/0x6f
[22766.387283] <EOI>
[22766.387284]
[22766.387285] [<ffffffff8168eed9>] ? retint_swapgs+0x13/0x1b
[22766.387285] Code: c0 90 5d c3 66 0f 1f 44 00 00 4c 89 c8 5d c3 0f 1f 00 55 48
89 e5 48 83
ec 20 48 89 5d e8 4c 89 65 f0 4c 89 6d f8 66 66 66 66 90 <0f> b7 87 98 00 00 00
48 89 fb
49 89 f5 66 c1 c0 08 66 39 46 02
[22766.387307]
[22766.387307] RIP
[22766.387311] [<ffffffffa168a2c9>] sctp_assoc_is_match+0x19/0x90 [sctp]
[22766.387311] RSP <ffff880147c039b0>
[22766.387142] ffffffffa16ab120
[22766.599537] ---[ end trace 3f6dae82e37b17f5 ]---
[22766.601221] Kernel panic - not syncing: Fatal exception in interrupt
It appears from his analysis and some staring at the code that this is likely
occuring because an association is getting freed while still on the
sctp_assoc_hashtable. As a result, we get a gpf when traversing the hashtable
while a freed node corrupts part of the list.
Nominally I would think that an mibalanced refcount was responsible for this,
but I can't seem to find any obvious imbalance. What I did note however was
that the two places where we create an association using
sctp_primitive_ASSOCIATE (__sctp_connect and sctp_sendmsg), have failure paths
which free a newly created association after calling sctp_primitive_ASSOCIATE.
sctp_primitive_ASSOCIATE brings us into the sctp_sf_do_prm_asoc path, which
issues a SCTP_CMD_NEW_ASOC side effect, which in turn adds a new association to
the aforementioned hash table. the sctp command interpreter that process side
effects has not way to unwind previously processed commands, so freeing the
association from the __sctp_connect or sctp_sendmsg error path would lead to a
freed association remaining on this hash table.
I've fixed this but modifying sctp_[un]hash_established to use hlist_del_init,
which allows us to proerly use hlist_unhashed to check if the node is on a
hashlist safely during a delete. That in turn alows us to safely call
sctp_unhash_established in the __sctp_connect and sctp_sendmsg error paths
before freeing them, regardles of what the associations state is on the hash
list.
I noted, while I was doing this, that the __sctp_unhash_endpoint was using
hlist_unhsashed in a simmilar fashion, but never nullified any removed nodes
pointers to make that function work properly, so I fixed that up in a simmilar
fashion.
I attempted to test this using a virtual guest running the SCTP_RR test from
netperf in a loop while running the trinity fuzzer, both in a loop. I wasn't
able to recreate the problem prior to this fix, nor was I able to trigger the
failure after (neither of which I suppose is suprising). Given the trace above
however, I think its likely that this is what we hit.
Reported-by: davej@redhat.com
CC: davej@redhat.com
This adjusts the call to dst_ops->update_pmtu() so that we can
transparently handle the fact that, in the future, the dst itself can
be invalidated by the PMTU update (when we have non-host routes cached
in sockets).
Standardize the net core ratelimited logging functions.
Coalesce formats, align arguments.
Change a printk then vprintk sequence to use printf extension %pV.
getsockopt(..., SCTP_EVENTS, ...) performs a length check and returns
an error if the user provides less bytes than the size of struct
sctp_event_subscribe.
Struct sctp_event_subscribe needs to be extended by an u8 for every
new event or notification type that is added.
This obviously makes getsockopt fail for binaries that are compiled
against an older versions of <net/sctp/user.h> which do not contain
all event types.
This patch changes getsockopt behaviour to no longer return an error
if not enough bytes are being provided by the user. Instead, it
returns as much of sctp_event_subscribe as fits into the provided buffer.
This leads to the new behavior that users see what they have been aware
of at compile time.
The setsockopt(..., SCTP_EVENTS, ...) API is already behaving like this.
Signed-off-by: Thomas Graf <tgraf@suug.ch>
Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com>
lookup sctp_association within sctp_do_peeloff() to enable its use outside of
the sctp code with minimal knowledge of the former.
Signed-off-by: Benjamin Poirier <bpoirier@suse.de>
net/bluetooth/l2cap_core.c
Just two overlapping changes, one added an initialization of
a local variable, and another change added a new local variable.
Commit 8ffd3208 voids the previous patches f6778aab and 810c0719 for
limiting the autoclose value. If userspace passes in -1 on 32-bit
platform, the overflow check didn't work and autoclose would be set
to 0xffffffff.
This patch defines a max_autoclose (in seconds) for limiting the value
and exposes it through sysctl, with the following intentions.
1) Avoid overflowing autoclose * HZ.
2) Keep the default autoclose bound consistent across 32- and 64-bit
platforms (INT_MAX / HZ in this patch).
3) Keep the autoclose value consistent between setsockopt() and
getsockopt() calls.
Suggested-by: Vlad Yasevich <vladislav.yasevich@hp.com>
Signed-off-by: Xi Wang <xi.wang@gmail.com>
Instead of testing defined(CONFIG_IPV6) || defined(CONFIG_IPV6_MODULE)
C assignment can handle struct in6_addr copying.
These files are non modular, but need to export symbols using
the macros now living in export.h -- call out the include so
that things won't break when we remove the implicit presence
of module.h from everywhere.
closing socket
Trigger user ABORT if application closes a socket which has data
queued on the socket receive queue or chunks waiting on the
reassembly or ordering queue as this would imply data being lost
which defeats the point of a graceful shutdown.
This behavior is already practiced in TCP.
We do not check the input queue because that would mean to parse
all chunks on it to look for unacknowledged data which seems too
much of an effort. Control chunks or duplicated chunks may also
be in the input queue and should not be stopping a graceful
shutdown.
Signed-off-by: Thomas Graf <tgraf@infradead.org>
We forgot to send up SCTP_SENDER_DRY_EVENT notification when
user app subscribes to this event, and there is no data to be
sent or retransmit.
This is required by the Socket API and used by the DTLS/SCTP
implementation.
Reported-by: Michael Tüxen <Michael.Tuexen@lurchi.franken.de>
Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com>
Tested-by: Robin Seggelmann <seggelmann@fh-muenster.de>
Make the case labels the same indent as the switch.
git diff -w shows useless break;s removed after returns
and a comment added to an unnecessary default: break;
because of a dubious gcc warning.
Unnecessary casts of void * clutter the code.
These are the remainder casts after several specific
patches to remove netdev_priv and dev_priv.
Done via coccinelle script:
$ cat cast_void_pointer.cocci
type T;
T *pt;
void *pv;
- pt = (T *)pv;
+ pt = pv;
Acked-by: Paul Moore <paul.moore@hp.com>
Signed-off-by: David S. Miller <davem@conan.davemloft.net>
Signed-off-by: Michio Honda <micchie@sfc.wide.ad.jp>
Acked-by: Wei Yongjun <yjwei@cn.fujitsu.com>
In this case, the SCTP association transmits an ASCONF packet
including addition of the new IP address and deletion of the old
address. This patch implements this functionality.
In this case, the ASCONF chunk is added to the beginning of the
queue, because the other chunks cannot be transmitted in this state.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
This patch allows the application to operate Auto-ASCONF on/off
behavior via setsockopt() and getsockopt().
SCTP reconfigure the IP addresses in the association by using
ASCONF chunks as mentioned in RFC5061. For example, we can
start to use the newly configured IP address in the existing
association. This patch implements automatic ASCONF operation
in the SCTP stack with address events in the host computer,
which is called auto_asconf.
It's already known non-null above.
This variable only needs initialization when cmsgs.info
is NULL.
Use memset to ensure padding is also zeroed so
kernel doesn't leak any data.
The ipv6 routing lookup does give us a source address,
but instead of filling it into the dst, it's stored in
the flowi. We can use that instead of going through the
entire source address selection again.
Also the useless ->dst_saddr member of sctp_pf is removed.
And sctp_v6_dst_saddr() is removed, instead by introduce
sctp_v6_to_addr(), which can be reused to cleanup some dup
code.
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
