path: root/net/sctp/sysctl.c
2006-01-17[SCTP]: Fix bad sysctl formatting of SCTP timeout values on 64-bit m/cs.Vlad Yasevich
Change all the structure members that hold jiffies to be of type unsigned long. This also corrects bad sysctl formating on 64 bit architectures. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com>
2005-11-11[SCTP]: Include ulpevents in socket receive buffer accounting.Neil Horman
Also introduces a sysctl option to configure the receive buffer accounting policy to be either at socket or association level. Default is all the associations on the same socket share the receive buffer. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-05[SCTP]: net/sctp/sysctl.c should #include <net/sctp/sctp.h>Adrian Bunk
Every file should #include the header files containing the prototypes of it's global functions. sctp.h contains the prototypes of sctp_sysctl_{,un}register(). Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-28[SCTP] Make init & delayed sack timeouts configurable by user.Vlad Yasevich
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-04-28[SCTP] Fix SCTP sendbuffer accouting.Neil Horman
- Include chunk and skb sizes in sendbuffer accounting. - 2 policies are supported. 0: per socket accouting, 1: per association accounting DaveM: I've made the default per-socket. Signed-off-by: Neil Horman <nhorman@redhat.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
