path: root/net/sctp/ulpqueue.c
2011-03-07sctp: several declared/set but unused fixesHagen Paul Pfeifer
Signed-off-by: Hagen Paul Pfeifer <hagen@jauu.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17net: Remove unnecessary returns from void function()sJoe Perches
This patch removes from net/ (but not any netfilter files) all the unnecessary return; statements that precede the last closing brace of void functions. It does not remove the returns that are immediately preceded by a label as gcc doesn't like that. Done via: $ grep -rP --include=*.[ch] -l "return;\n}" net/ | \ xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }' Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2008-09-21net: Remove __skb_insert() calls outside of skbuff internals.David S. Miller
This minor cleanup simplifies later changes which will convert struct sk_buff and friends over to using struct list_head. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-06[SCTP]: Correctly reap SSNs when processing FORWARD_TSN chunkVlad Yasevich
When we recieve a FORWARD_TSN chunk, we need to reap all the queued fast-forwarded chunks from the ordering queue However, if we don't have them queued, we need to see if the next expected one is there as well. If it is, start deliver from that point instead of waiting for the next chunk to arrive. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2008-02-05[SCTP]: Kill silly inlines in ulpqueue.cVlad Yasevich
2008-02-05[SCTP]: Stop claiming that this is a "reference implementation"Vlad Yasevich
I was notified by Randy Stewart that lksctp claims to be "the reference implementation". First of all, "the refrence implementation" was the original implementation of SCTP in usersapce written ty Randy and a few others. Second, after looking at the definiton of 'reference implementation', we don't really meet the requirements. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2008-01-28[NET] CORE: Introducing new memory accounting interface.Hideo Aoki
This patch introduces new memory accounting functions for each network protocol. Most of them are renamed from memory accounting functions for stream protocols. At the same time, some stream memory accounting functions are removed since other functions do same thing. Renaming: sk_stream_free_skb() -> sk_wmem_free_skb() __sk_stream_mem_reclaim() -> __sk_mem_reclaim() sk_stream_mem_reclaim() -> sk_mem_reclaim() sk_stream_mem_schedule -> __sk_mem_schedule() sk_stream_pages() -> sk_mem_pages() sk_stream_rmem_schedule() -> sk_rmem_schedule() sk_stream_wmem_schedule() -> sk_wmem_schedule() sk_charge_skb() -> sk_mem_charge() Removeing sk_stream_rfree(): consolidates into sock_rfree() sk_stream_set_owner_r(): consolidates into skb_set_owner_r() sk_stream_mem_schedule() The following functions are added. sk_has_account(): check if the protocol supports accounting sk_mem_uncharge(): do the opposite of sk_mem_charge() In addition, to achieve consolidation, updating sk_wmem_queued is removed from sk_mem_charge(). Next, to consolidate memory accounting functions, this patch adds memory accounting calls to network core functions. Moreover, present memory accounting call is renamed to new accounting call. Finally we replace present memory accounting calls with new interface in TCP and SCTP. Signed-off-by: Takahiro Yasui <tyasui@redhat.com> Signed-off-by: Hideo Aoki <haoki@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-16[SCTP]: Flush fragment queue when exiting partial delivery.Vlad Yasevich
At the end of partial delivery, we may have complete messages sitting on the fragment queue. These messages are stuck there until a new fragment arrives. This can comletely stall a given association. When clearing partial delivery state, flush any complete messages from the fragment queue and send them on their way up. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-09SCTP: Fix PR-SCTP to deliver all the accumulated ordered chunksVlad Yasevich
There is a small bug when we process a FWD-TSN. We'll deliver anything upto the current next expected SSN. However, if the next expected is already in the queue, it will take another chunk to trigger its delivery. The fix is to simply check the current queued SSN is the next expected one. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2007-10-23[SCTP]: Consolidate sctp_ulpq_renege_xxx functionsPavel Emelyanov
Both are equal, except for the list to be traversed. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[SCTP]: Rewrite of sctp buffer management codeNeil Horman
This patch introduces autotuning to the sctp buffer management code similar to the TCP. The buffer space can be grown if the advertised receive window still has room. This might happen if small message sizes are used, which is common in telecom environmens. New tunables are introduced that provide limits to buffer growth and memory pressure is entered if to much buffer spaces is used. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-08-29SCTP: properly clean up fragment and ordering queues during FWD-TSN.Vlad Yasevich
When we recieve a FWD-TSN (meaning the peer has abandoned the data), we need to clean up any partially received messages that may be hanging out on the re-assembly or re-ordering queues. This is a MUST requirement that was not properly done before. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com.>
2007-04-25[NET]: cleanup extra semicolonsStephen Hemminger
Spring cleaning time... There seems to be a lot of places in the network code that have extra bogus semicolons after conditionals. Most commonly is a bogus semicolon after: switch() { } Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SCTP]: Implement SCTP_PARTIAL_DELIVERY_POINT option.Vlad Yasevich
This option induces partial delivery to run as soon as the specified amount of data has been accumulated on the association. However, we give preference to fully reassembled messages over PD messages. In any case, window and buffer is freed up. Signed-off-by: Vlad Yasevich <vladislav.yasevich@.hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SCTP]: Implement SCTP_FRAGMENT_INTERLEAVE socket optionVlad Yasevich
This option was introduced in draft-ietf-tsvwg-sctpsocket-13. It prevents head-of-line blocking in the case of one-to-many endpoint. Applications enabling this option really must enable SCTP_SNDRCV event so that they would know where the data belongs. Based on an earlier patch by Ivan Skytte Jørgensen. Additionally, this functionality now permits multiple associations on the same endpoint to enter Partial Delivery. Applications should be extra careful, when using this functionality, to track EOR indicators. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-18[SCTP]: Do not interleave non-fragments when in partial deliveryVlad Yasevich
The way partial delivery is currently implemnted, it is possible to intereleave a message (either from another steram, or unordered) that is not part of partial delivery process. The only way to this is for a message to not be a fragment and be 'in order' or unorderd for a given stream. This will result in bypassing the reassembly/ordering queues where things live duing partial delivery, and the message will be delivered to the socket in the middle of partial delivery. This is a two-fold problem, in that: 1. the app now must check the stream-id and flags which it may not be doing. 2. this clearing partial delivery state from the association and results in ulp hanging. This patch is a band-aid over a much bigger problem in that we don't do stream interleave. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-20[SCTP]: Clean up stale data during association restartVlad Yasevich
During association restart we may have stale data sitting on the ULP queue waiting for ordering or reassembly. This data may cause severe problems if not cleaned up. In particular stale data pending ordering may cause problems with receive window exhaustion if our peer has decided to restart the association. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] SCTP: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-11[SCTP]: Fix receive buffer accounting.Vlad Yasevich
When doing receiver buffer accounting, we always used skb->truesize. This is problematic when processing bundled DATA chunks because for every DATA chunk that could be small part of one large skb, we would charge the size of the entire skb. The new approach is to store the size of the DATA chunk we are accounting for in the sctp_ulpevent structure and use that stored value for accounting. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-05[SCTP]: Prevent possible infinite recursion with multiple bundled DATA.Vladislav Yasevich
There is a rare situation that causes lksctp to go into infinite recursion and crash the system. The trigger is a packet that contains at least the first two DATA fragments of a message bundled together. The recursion is triggered when the user data buffer is smaller that the full data message. The problem is that we clone the skb for every fragment in the message. When reassembling the full message, we try to link skbs from the "first fragment" clone using the frag_list. However, since the frag_list is shared between two clones in this rare situation, we end up setting the frag_list pointer of the second fragment to point to itself. This causes sctp_skb_pull() to potentially recurse indefinitely. Proposed solution is to make a copy of the skb when attempting to link things using frag_list. Signed-off-by: Vladislav Yasevich <vladsilav.yasevich@hp.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-29[NET]: Kill skb->listDavid S. Miller
Remove the "list" member of struct sk_buff, as it is entirely redundant. All SKB list removal callers know which list the SKB is on, so storing this in sk_buff does nothing other than taking up some space. Two tricky bits were SCTP, which I took care of, and two ATM drivers which Francois Romieu <romieu@fr.zoreil.com> fixed up. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2005-07-11[SCTP]: __nocast annotationsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
