path: root/net/sctp
2010-04-28sctp: Fix oops when sending queued ASCONF chunksVlad Yasevich
When we finish processing ASCONF_ACK chunk, we try to send the next queued ASCONF. This action runs the sctp state machine recursively and it's not prepared to do so. kernel BUG at kernel/timer.c:790! invalid opcode: 0000 [#1] SMP last sysfs file: /sys/module/ipv6/initstate Modules linked in: sha256_generic sctp libcrc32c ipv6 dm_multipath uinput 8139too i2c_piix4 8139cp mii i2c_core pcspkr virtio_net joydev floppy virtio_blk virtio_pci [last unloaded: scsi_wait_scan] Pid: 0, comm: swapper Not tainted 2.6.34-rc4 #15 /Bochs EIP: 0060:[<c044a2ef>] EFLAGS: 00010286 CPU: 0 EIP is at add_timer+0xd/0x1b EAX: cecbab14 EBX: 000000f0 ECX: c0957b1c EDX: 03595cf4 ESI: cecba800 EDI: cf276f00 EBP: c0957aa0 ESP: c0957aa0 DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068 Process swapper (pid: 0, ti=c0956000 task=c0988ba0 task.ti=c0956000) Stack: c0957ae0 d1851214 c0ab62e4 c0ab5f26 0500ffff 00000004 00000005 00000004 <0> 00000000 d18694fd 00000004 1666b892 cecba800 cecba800 c0957b14 00000004 <0> c0957b94 d1851b11 ceda8b00 cecba800 cf276f00 00000001 c0957b14 000000d0 Call Trace: [<d1851214>] ? sctp_side_effects+0x607/0xdfc [sctp] [<d1851b11>] ? sctp_do_sm+0x108/0x159 [sctp] [<d1863386>] ? sctp_pname+0x0/0x1d [sctp] [<d1861a56>] ? sctp_primitive_ASCONF+0x36/0x3b [sctp] [<d185657c>] ? sctp_process_asconf_ack+0x2a4/0x2d3 [sctp] [<d184e35c>] ? sctp_sf_do_asconf_ack+0x1dd/0x2b4 [sctp] [<d1851ac1>] ? sctp_do_sm+0xb8/0x159 [sctp] [<d1863334>] ? sctp_cname+0x0/0x52 [sctp] [<d1854377>] ? sctp_assoc_bh_rcv+0xac/0xe1 [sctp] [<d1858f0f>] ? sctp_inq_push+0x2d/0x30 [sctp] [<d186329d>] ? sctp_rcv+0x797/0x82e [sctp] Tested-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Yuansong Qiao <ysqiao@research.ait.ie> Signed-off-by: Shuaijun Zhang <szhang@research.ait.ie> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-28sctp: fix to calc the INIT/INIT-ACK chunk length correctly is setWei Yongjun
When calculating the INIT/INIT-ACK chunk length, we should not only account the length of parameters, but also the parameters zero padding length, such as AUTH HMACS parameter and CHUNKS parameter. Without the parameters zero padding length we may get following oops. skb_over_panic: text:ce2068d2 len:130 put:6 head:cac3fe00 data:cac3fe00 tail:0xcac3fe82 end:0xcac3fe80 dev:<NULL> ------------[ cut here ]------------ kernel BUG at net/core/skbuff.c:127! invalid opcode: 0000 [#2] SMP last sysfs file: /sys/module/aes_generic/initstate Modules linked in: authenc ...... Pid: 4102, comm: sctp_darn Tainted: G D 2.6.34-rc2 #6 EIP: 0060:[<c0607630>] EFLAGS: 00010282 CPU: 0 EIP is at skb_over_panic+0x37/0x3e EAX: 00000078 EBX: c07c024b ECX: c07c02b9 EDX: cb607b78 ESI: 00000000 EDI: cac3fe7a EBP: 00000002 ESP: cb607b74 DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 Process sctp_darn (pid: 4102, ti=cb607000 task=cabdc990 task.ti=cb607000) Stack: c07c02b9 ce2068d2 00000082 00000006 cac3fe00 cac3fe00 cac3fe82 cac3fe80 <0> c07c024b cac3fe7c cac3fe7a c0608dec ca986e80 ce2068d2 00000006 0000007a <0> cb8120ca ca986e80 cb812000 00000003 cb8120c4 ce208a25 cb8120ca cadd9400 Call Trace: [<ce2068d2>] ? sctp_addto_chunk+0x45/0x85 [sctp] [<c0608dec>] ? skb_put+0x2e/0x32 [<ce2068d2>] ? sctp_addto_chunk+0x45/0x85 [sctp] [<ce208a25>] ? sctp_make_init+0x279/0x28c [sctp] [<c0686a92>] ? apic_timer_interrupt+0x2a/0x30 [<ce1fdc0b>] ? sctp_sf_do_prm_asoc+0x2b/0x7b [sctp] [<ce202823>] ? sctp_do_sm+0xa0/0x14a [sctp] [<ce2133b9>] ? sctp_pname+0x0/0x14 [sctp] [<ce211d72>] ? sctp_primitive_ASSOCIATE+0x2b/0x31 [sctp] [<ce20f3cf>] ? sctp_sendmsg+0x7a0/0x9eb [sctp] [<c064eb1e>] ? inet_sendmsg+0x3b/0x43 [<c04244b7>] ? task_tick_fair+0x2d/0xd9 [<c06031e1>] ? sock_sendmsg+0xa7/0xc1 [<c0416afe>] ? smp_apic_timer_interrupt+0x6b/0x75 [<c0425123>] ? dequeue_task_fair+0x34/0x19b [<c0446abb>] ? sched_clock_local+0x17/0x11e [<c052ea87>] ? _copy_from_user+0x2b/0x10c [<c060ab3a>] ? verify_iovec+0x3c/0x6a [<c06035ca>] ? sys_sendmsg+0x186/0x1e2 [<c042176b>] ? __wake_up_common+0x34/0x5b [<c04240c2>] ? __wake_up+0x2c/0x3b [<c057e35c>] ? tty_wakeup+0x43/0x47 [<c04430f2>] ? remove_wait_queue+0x16/0x24 [<c0580c94>] ? n_tty_read+0x5b8/0x65e [<c042be02>] ? default_wake_function+0x0/0x8 [<c0604e0e>] ? sys_socketcall+0x17f/0x1cd [<c040264c>] ? sysenter_do_call+0x12/0x22 Code: 0f 45 de 53 ff b0 98 00 00 00 ff b0 94 ...... EIP: [<c0607630>] skb_over_panic+0x37/0x3e SS:ESP 0068:cb607b74 To reproduce: # modprobe sctp # echo 1 > /proc/sys/net/sctp/addip_enable # echo 1 > /proc/sys/net/sctp/auth_enable # sctp_test -H 3ffe:501:ffff:100:20c:29ff:fe4d:f37e -P 800 -l # sctp_darn -H 3ffe:501:ffff:100:20c:29ff:fe4d:f37e -P 900 -h 192.168.0.21 -p 800 -I -s -t sctp_darn ready to send... 3ffe:501:ffff:100:20c:29ff:fe4d:f37e:900-192.168.0.21:800 Interactive mode> bindx-add=192.168.0.21 3ffe:501:ffff:100:20c:29ff:fe4d:f37e:900-192.168.0.21:800 Interactive mode> bindx-add=192.168.1.21 3ffe:501:ffff:100:20c:29ff:fe4d:f37e:900-192.168.0.21:800 Interactive mode> snd=10 ------------------------------------------------------------------ eth0 has addresses: 3ffe:501:ffff:100:20c:29ff:fe4d:f37e and 192.168.0.21 eth1 has addresses: 192.168.1.21 ------------------------------------------------------------------ Reported-by: George Cheimonidis <gchimon@gmail.com> Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-28sctp: per_cpu variables should be in bh_disabled sectionVlad Yasevich
Since the change of the atomics to percpu variables, we now have to disable BH in process context when touching percpu variables. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-28sctp: fix potential reference of a freed pointerVlad Yasevich
When sctp attempts to update an assocition, it removes any addresses that were not in the updated INITs. However, the loop may attempt to refrence a transport with address after removing it. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-28sctp: avoid irq lock inversion while call sk->sk_data_ready()Wei Yongjun
sk->sk_data_ready() of sctp socket can be called from both BH and non-BH contexts, but the default sk->sk_data_ready(), sock_def_readable(), can not be used in this case. Therefore, we have to make a new function sctp_data_ready() to grab sk->sk_data_ready() with BH disabling. ========================================================= [ INFO: possible irq lock inversion dependency detected ] 2.6.33-rc6 #129 --------------------------------------------------------- sctp_darn/1517 just changed the state of lock: (clock-AF_INET){++.?..}, at: [<c06aab60>] sock_def_readable+0x20/0x80 but this lock took another, SOFTIRQ-unsafe lock in the past: (slock-AF_INET){+.-...} and interrupts could create inverse lock ordering between them. other info that might help us debug this: 1 lock held by sctp_darn/1517: #0: (sk_lock-AF_INET){+.+.+.}, at: [<cdfe363d>] sctp_sendmsg+0x23d/0xc00 [sctp] Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (108 commits) bridge: ensure to unlock in error path in br_multicast_query(). drivers/net/tulip/eeprom.c: fix bogus "(null)" in tulip init messages sky2: Avoid rtnl_unlock without rtnl_lock ipv6: Send netlink notification when DAD fails drivers/net/tg3.c: change the field used with the TG3_FLAG_10_100_ONLY constant ipconfig: Handle devices which take some time to come up. mac80211: Fix memory leak in ieee80211_if_write() mac80211: Fix (dynamic) power save entry ipw2200: use kmalloc for large local variables ath5k: read eeprom IQ calibration values correctly for G mode ath5k: fix I/Q calibration (for real) ath5k: fix TSF reset ath5k: use fixed antenna for tx descriptors libipw: split ieee->networks into small pieces mac80211: Fix sta_mtx unlocking on insert STA failure path rt2x00: remove KSEG1ADDR define from rt2x00soc.h net: add ColdFire support to the smc91x driver asix: fix setting mac address for AX88772 ipv6 ip6_tunnel: eliminate unused recursion field from ip6_tnl{}. net: Fix dev_mc_add() ...
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-03-05net: backlog functions renameZhu Yi
sk_add_backlog -> __sk_add_backlog sk_add_backlog_limited -> sk_add_backlog Signed-off-by: Zhu Yi <yi.zhu@intel.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-05sctp: use limited socket backlogZhu Yi
Make sctp adapt to the limited socket backlog change. Cc: Vlad Yasevich <vladislav.yasevich@hp.com> Cc: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-17net: remove INIT_RCU_HEAD() usageAlexey Dobriyan
call_rcu() will unconditionally reinitialize RCU head anyway. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16percpu: add __percpu sparse annotations to netTejun Heo
Add __percpu sparse annotations to net. These annotations are to make sparse consider percpu variables to be in a different address space and warn if accessed without going through percpu accessors. This patch doesn't affect normal builds. The macro and type tricks around snmp stats make things a bit interesting. DEFINE/DECLARE_SNMP_STAT() macros mark the target field as __percpu and SNMP_UPD_PO_STATS() macro is updated accordingly. All snmp_mib_*() users which used to cast the argument to (void **) are updated to cast it to (void __percpu **). Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David S. Miller <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Cc: Vlad Yasevich <vladislav.yasevich@hp.com> Cc: netdev@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-09tree-wide: Assorted spelling fixesDaniel Mack
In particular, several occurances of funny versions of 'success', 'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address', 'beginning', 'desirable', 'separate' and 'necessary' are fixed. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Joe Perches <joe@perches.com> Cc: Junio C Hamano <gitster@pobox.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-01-23net: constify MIB name tablesAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-21net/sctp: Eliminate useless codeJulia Lawall
The variable newinet is initialized twice to the same (side effect-free) expression. Drop one initialization. A simplified version of the semantic match that finds this problem is: (http://coccinelle.lip6.fr/) // <smpl> @forall@ idexpression *x; identifier f!=ERR_PTR; @@ x = f(...) ... when != x ( x = f(...,<+...x...+>,...) | * x = f(...) ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-03net/sctp/socket.c: squish warningAndrew Morton
net/sctp/socket.c: In function 'sctp_setsockopt_autoclose': net/sctp/socket.c:2090: warning: comparison is always false due to limited range of data type Cc: Andrei Pelinescu-Onciul <andrei@iptel.org> Cc: Vlad Yasevich <vladislav.yasevich@hp.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits) tree-wide: fix misspelling of "definition" in comments reiserfs: fix misspelling of "journaled" doc: Fix a typo in slub.txt. inotify: remove superfluous return code check hdlc: spelling fix in find_pvc() comment doc: fix regulator docs cut-and-pasteism mtd: Fix comment in Kconfig doc: Fix IRQ chip docs tree-wide: fix assorted typos all over the place drivers/ata/libata-sff.c: comment spelling fixes fix typos/grammos in Documentation/edac.txt sysctl: add missing comments fs/debugfs/inode.c: fix comment typos sgivwfb: Make use of ARRAY_SIZE. sky2: fix sky2_link_down copy/paste comment error tree-wide: fix typos "couter" -> "counter" tree-wide: fix typos "offest" -> "offset" fix kerneldoc for set_irq_msi() spidev: fix double "of of" in comment comment typo fix: sybsystem -> subsystem ...
2009-12-08sctp: fix compile error due to sysctl mismergeLinus Torvalds
I messed up the merge in d7fc02c7bae7b1cf69269992cf880a43a350cdaa, where the conflict in question wasn't just about CTL_UNNUMBERED being removed, but the 'strategy' field is too (sysctl handling is now done through the /proc interface, with no duplicate protocols for reading the data). Reported-by: Larry Finger <Larry.Finger@lwfinger.net> Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1815 commits) mac80211: fix reorder buffer release iwmc3200wifi: Enable wimax core through module parameter iwmc3200wifi: Add wifi-wimax coexistence mode as a module parameter iwmc3200wifi: Coex table command does not expect a response iwmc3200wifi: Update wiwi priority table iwlwifi: driver version track kernel version iwlwifi: indicate uCode type when fail dump error/event log iwl3945: remove duplicated event logging code b43: fix two warnings ipw2100: fix rebooting hang with driver loaded cfg80211: indent regulatory messages with spaces iwmc3200wifi: fix NULL pointer dereference in pmkid update mac80211: Fix TX status reporting for injected data frames ath9k: enable 2GHz band only if the device supports it airo: Fix integer overflow warning rt2x00: Fix padding bug on L2PAD devices. WE: Fix set events not propagated b43legacy: avoid PPC fault during resume b43: avoid PPC fault during resume tcp: fix a timewait refcnt race ... Fix up conflicts due to sysctl cleanups (dead sysctl_check code and CTL_UNNUMBERED removed) in kernel/sysctl_check.c net/ipv4/sysctl_net_ipv4.c net/ipv6/addrconf.c net/sctp/sysctl.c
2009-12-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/sysctl-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/sysctl-2.6: (43 commits) security/tomoyo: Remove now unnecessary handling of security_sysctl. security/tomoyo: Add a special case to handle accesses through the internal proc mount. sysctl: Drop & in front of every proc_handler. sysctl: Remove CTL_NONE and CTL_UNNUMBERED sysctl: kill dead ctl_handler definitions. sysctl: Remove the last of the generic binary sysctl support sysctl net: Remove unused binary sysctl code sysctl security/tomoyo: Don't look at ctl_name sysctl arm: Remove binary sysctl support sysctl x86: Remove dead binary sysctl support sysctl sh: Remove dead binary sysctl support sysctl powerpc: Remove dead binary sysctl support sysctl ia64: Remove dead binary sysctl support sysctl s390: Remove dead sysctl binary support sysctl frv: Remove dead binary sysctl support sysctl mips/lasat: Remove dead binary sysctl support sysctl drivers: Remove dead binary sysctl support sysctl crypto: Remove dead binary sysctl support sysctl security/keys: Remove dead binary sysctl support sysctl kernel: Remove binary sysctl logic ...
2009-12-07Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: kernel/irq/chip.c
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-12-04tree-wide: fix some typos and punctuation in commentsThadeu Lima de Souza Cascardo
fix some typos and punctuation in comments Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-12-02sctp: fix sctp_setsockopt_autoclose compile warningAndrei Pelinescu-Onciul
Fix the following warning, when building on 64 bits: net/sctp/socket.c:2091: warning: large integer implicitly truncated to unsigned type Signed-off-by: Andrei Pelinescu-Onciul <andrei@iptel.org> Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29net: Move && and || to end of previous lineJoe Perches
Not including net/atm/ Compiled tested x86 allyesconfig only Added a > 80 column line or two, which I ignored. Existing checkpatch plaints willfully, cheerfully ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/ieee802154/fakehard.c drivers/net/e1000e/ich8lan.c drivers/net/e1000e/phy.c drivers/net/netxen/netxen_nic_init.c drivers/net/wireless/ath/ath9k/main.c
2009-11-29sctp: on T3_RTX retransmit all the in-flight chunksAndrei Pelinescu-Onciul
When retransmitting due to T3 timeout, retransmit all the in-flight chunks for the corresponding transport/path, including chunks sent less then 1 rto ago. This is the correct behaviour according to rfc4960 section 6.3.3 E3 and "Note: Any DATA chunks that were sent to the address for which the T3-rtx timer expired but did not fit in one MTU (rule E3 above) should be marked for retransmission and sent as soon as cwnd allows (normally, when a SACK arrives). ". This fixes problems when more then one path is present and the T3 retransmission of the first chunk that timeouts stops the T3 timer for the initial active path, leaving all the other in-flight chunks waiting forever or until a new chunk is transmitted on the same path and timeouts (and this will happen only if the cwnd allows sending new chunks, but since cwnd was dropped to MTU by the timeout => it will wait until the first heartbeat). Example: 10 packets in flight, sent at 0.1 s intervals on the primary path. The primary path is down and the first packet timeouts. The first packet is retransmitted on another path, the T3 timer for the primary path is stopped and cwnd is set to MTU. All the other 9 in-flight packets will not be retransmitted (unless more new packets are sent on the primary path which depend on cwnd allowing it, and even in this case the 9 packets will be retransmitted only after a new packet timeouts which even in the best case would be more then RTO). This commit reverts d0ce92910bc04e107b2f3f2048f07e94f570035d and also removes the now unused transport->last_rto, introduced in b6157d8e03e1e780660a328f7183bcbfa4a93a19. p.s The problem is not only when multiple paths are there. It can happen in a single homed environment. If the application stops sending data, it possible to have a hung association. Signed-off-by: Andrei Pelinescu-Onciul <andrei@iptel.org> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-23sctp: prevent too-fast association id reuseVlad Yasevich
We use the idr subsystem and always ask for an id at or above 1. This results in a id reuse when one association is terminated while another is created. To prevent re-use, we keep track of the last id returned and ask for that id + 1 as a base for each query. We let the idr spin lock protect this base id as well. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2009-11-23sctp: fix integer overflow when setting the autoclose timerAndrei Pelinescu-Onciul
When setting the autoclose timeout in jiffies there is a possible integer overflow if the value in seconds is very large (e.g. for 2^22 s with HZ=1024). The problem appears even on 64-bit due to the integer promotion rules. The fix is just a cast to unsigned long. Signed-off-by: Andrei Pelinescu-Onciul <andrei@iptel.org> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2009-11-23sctp: limit maximum autoclose setsockopt valueAndrei Pelinescu-Onciul
To avoid overflowing the maximum timer interval when transforming the autoclose interval from seconds to jiffies, limit the maximum autoclose value to MAX_SCHEDULE_TIMEOUT/HZ. Signed-off-by: Andrei Pelinescu-Onciul <andrei@iptel.org> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2009-11-23sctp: Fix mis-ordering of user space data when multihoming in useNeil Horman
Recently had a bug reported to me, in which the user was sending packets with a payload containing a sequence number. The packets were getting delivered in order according the chunk TSN values, but the sequence values in the payload were arriving out of order. At first I thought it must be an application error, but we eventually found it to be a problem on the transmit side in the sctp stack. The conditions for the error are that multihoming must be in use, and it helps if each transport has a different pmtu. The problem occurs in sctp_outq_flush. Basically we dequeue packets from the data queue, and attempt to append them to the orrered packet for a given transport. After we append a data chunk we add the trasport to the end of a list of transports to have their packets sent at the end of sctp_outq_flush. The problem occurs when a data chunks fills up a offered packet on a transport. The function that does the appending (sctp_packet_transmit_chunk), will try to call sctp_packet_transmit on the full packet, and then append the chunk to a new packet. This call to sctp_packet_transmit, sends that packet ahead of the others that may be queued in the transport_list in sctp_outq_flush. The result is that frames that were sent in one order from the user space sending application get re-ordered prior to tsn assignment in sctp_packet_transmit, resulting in mis-sequencing of data payloads, even though tsn ordering is correct. The fix is to change where we assign a tsn. By doing this earlier, we are then free to place chunks in packets, whatever way we see fit and the protocol will make sure to do all the appropriate re-ordering on receive as is needed. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Reported-by: William Reich <reich@ulticom.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2009-11-23sctp: Update max.burst implementationVlad Yasevich
Current implementation of max.burst ends up limiting new data during cwnd decay period. The decay is happening becuase the connection is idle and we are allowed to fill the congestion window. The point of max.burst is to limit micro-bursts in response to large acks. This still happens, as max.burst is still applied to each transmit opportunity. It will also apply if a very large send is made (greater then allowed by burst). Tested-by: Florian Niederbacher <florian.niederbacher@student.uibk.ac.at> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2009-11-23sctp: Remove useless last_time_used variableVlad Yasevich
The transport last_time_used variable is rather useless. It was only used when determining if CWND needs to be updated due to idle transport. However, idle transport detection was based on a Heartbeat timer and last_time_used was not incremented when sending Heartbeats. As a result the check for cwnd reduction was always true. We can get rid of the variable and just base our cwnd manipulation on the HB timer (like the code comment sais). We also have to call into the cwnd manipulation function regardless of whether HBs are enabled or not. That way we will detect idle transports if the user has disabled Heartbeats. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2009-11-23sctp: remove deprecated SCTP_GET_*_OLD stuffsAmerigo Wang
SCTP_GET_*_OLD stuffs are schedlued to be removed. Cc: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: WANG Cong <amwang@redhat.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2009-11-23sctp: allow setting path_maxrxt independent of SPP_PMTUD_ENABLEAndrei Pelinescu-Onciul
Since draft-ietf-tsvwg-sctpsocket-15.txt, setting the SPP_MTUD_ENABLE flag when changing pathmaxrxt via the SCTP_PEER_ADDR_PARAMS setsockopt is not required any longer. Signed-off-by: Andrei Pelinescu-Onciul <andrei@iptel.org> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2009-11-23sctp: Update SWS avaoidance receiver side algorithmVlad Yasevich
We currently send window update SACKs every time we free up 1 PMTU worth of data. That a lot more SACKs then necessary. Instead, we'll now send back the actuall window every time we send a sack, and do window-update SACKs when a fraction of the receive buffer has been opened. The fraction is controlled with a sysctl. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2009-11-23sctp: Select a working primary during sctp_connectx()Vlad Yasevich
When sctp_connectx() is used, we pick the first address as primary, even though it may not have worked. This results in excessive retransmits and poor performance. We should select the address that the association was established with. Reported-by: Thomas Dreibholz <dreibh@iem.uni-due.de> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2009-11-23sctp: Fix malformed "Invalid Stream Identifier" errorVlad Yasevich
The "Invalid Stream Identifier" error has a 16 bit reserved field at the end, thus making the parameter length be 8 bytes. We've never supplied that reserved field making wireshark tag the packet as malformed. Reported-by: Chris Dischino <cdischino@sonusnet.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2009-11-23sctp: implement the sender side for SACK-IMMEDIATELY extensionWei Yongjun
This patch implement the sender side for SACK-IMMEDIATELY extension. Section 4.1. Sender Side Considerations Whenever the sender of a DATA chunk can benefit from the corresponding SACK chunk being sent back without delay, the sender MAY set the I-bit in the DATA chunk header. Reasons for setting the I-bit include o The sender is in the SHUTDOWN-PENDING state. o The application requests to set the I-bit of the last DATA chunk of a user message when providing the user message to the SCTP implementation. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2009-11-23sctp: implement the receiver side for SACK-IMMEDIATELY extensionWei Yongjun
This patch implement the receiver side for SACK-IMMEDIATELY extension: Section 4.2. Receiver Side Considerations On reception of an SCTP packet containing a DATA chunk with the I-bit set, the receiver SHOULD NOT delay the sending of the corresponding SACK chunk and SHOULD send it back immediately. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2009-11-18sysctl: Drop & in front of every proc_handler.Eric W. Biederman
For consistency drop & in front of every proc_handler. Explicity taking the address is unnecessary and it prevents optimizations like stubbing the proc_handlers to NULL. Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Joe Perches <joe@perches.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-11-17Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/can/Kconfig
2009-11-13sctp: Set socket source address when additing first transportVlad Yasevich
Recent commits sctp: Get rid of an extra routing lookup when adding a transport and sctp: Set source addresses on the association before adding transports changed when routes are added to the sctp transports. As such, we didn't set the socket source address correctly when adding the first transport. The first transport is always the primary/active one, so when adding it, set the socket source address. This was causing regression failures in SCTP tests. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-13sctp: Fix regression introduced by new sctp_connectx apiVlad Yasevich
A new (unrealeased to the user) sctp_connectx api c6ba68a26645dbc5029a9faa5687ebe6fcfc53e4 sctp: support non-blocking version of the new sctp_connectx() API introduced a regression cought by the user regression test suite. In particular, the API requires the user library to re-allocate the buffer and could potentially trigger a SIGFAULT. This change corrects that regression by passing the original address buffer to the kernel unmodified, but still allows for a returned association id. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-13sctp: Set source addresses on the association before adding transportsVlad Yasevich
Recent commit 8da645e101a8c20c6073efda3c7cc74eec01b87f sctp: Get rid of an extra routing lookup when adding a transport introduced a regression in the connection setup. The behavior was different between IPv4 and IPv6. IPv4 case ended up working because the route lookup routing returned a NULL route, which triggered another route lookup later in the output patch that succeeded. In the IPv6 case, a valid route was returned for first call, but we could not find a valid source address at the time since the source addresses were not set on the association yet. Thus resulted in a hung connection. The solution is to set the source addresses on the association prior to adding peers. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-12sysctl net: Remove unused binary sysctl codeEric W. Biederman
Now that sys_sysctl is a compatiblity wrapper around /proc/sys all sysctl strategy routines, and all ctl_name and strategy entries in the sysctl tables are unused, and can be revmoed. In addition neigh_sysctl_register has been modified to no longer take a strategy argument and it's callers have been modified not to pass one. Cc: "David Miller" <davem@davemloft.net> Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Cc: netdev@vger.kernel.org Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-11-05sctp: ipv6: avoid touching device refcountEric Dumazet
Avoid touching device refcount in sctp/ipv6, thanks to RCU Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-05net: drop capability from protocol definitionsEric Paris
struct can_proto had a capability field which wasn't ever used. It is dropped entirely. struct inet_protosw had a capability field which can be more clearly expressed in the code by just checking if sock->type = SOCK_RAW. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-04net: Introduce for_each_netdev_rcu() iteratorEric Dumazet
Adds RCU management to the list of netdevices. Convert some for_each_netdev() users to RCU version, if it can avoid read_lock-ing dev_base_lock Ie: read_lock(&dev_base_loack); for_each_netdev(net, dev) some_action(); read_unlock(&dev_base_lock); becomes : rcu_read_lock(); for_each_netdev_rcu(net, dev) some_action(); rcu_read_unlock(); Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-18inet: rename some inet_sock fieldsEric Dumazet
In order to have better cache layouts of struct sock (separate zones for rx/tx paths), we need this preliminary patch. Goal is to transfert fields used at lookup time in the first read-mostly cache line (inside struct sock_common) and move sk_refcnt to a separate cache line (only written by rx path) This patch adds inet_ prefix to daddr, rcv_saddr, dport, num, saddr, sport and id fields. This allows a future patch to define these fields as macros, like sk_refcnt, without name clashes. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
