[ Upstream commit db31c55a6fb245fdbb752a2ca4aefec89afabb06 ]
If kmsg->msg_namelen > sizeof(struct sockaddr_storage) then in the
original code that would lead to memory corruption in the kernel if you
had audit configured. If you didn't have audit configured it was
harmless.
There are some programs such as beta versions of Ruby which use too
large of a buffer and returning an error code breaks them. We should
clamp the ->msg_namelen value instead.
Fixes: 1661bf364ae9 ("net: heap overflow in __audit_sockaddr()")
Reported-by: Eric Wong <normalperson@yhbt.net>
Tested-by: Eric Wong <normalperson@yhbt.net>
sockaddr_storage)
[ Upstream commit 68c6beb373955da0886d8f4f5995b3922ceda4be ]
In that case it is probable that kernel code overwrote part of the
stack. So we should bail out loudly here.
The BUG_ON may be removed in future if we are sure all protocols are
conformant.
Suggested-by: Eric Dumazet <eric.dumazet@gmail.com>
[ Upstream commit f3d3342602f8bcbf37d7c46641cb9bca7618eb1c ]
This patch now always passes msg->msg_namelen as 0. recvmsg handlers must
set msg_namelen to the proper size <= sizeof(struct sockaddr_storage)
to return msg_name to the user.
This prevents numerous uninitialized memory leaks we had in the
recvmsg handlers and makes it harder for new code to accidentally leak
uninitialized memory.
Optimize for the case recvfrom is called with NULL as address. We don't
need to copy the address at all, so set it to NULL before invoking the
recvmsg handler. We can do so, because all the recvmsg handlers must
cope with the case a plain read() is called on them. read() also sets
msg_name to NULL.
Also document these changes in include/linux/net.h as suggested by David
Miller.
Changes since RFC:
Set msg->msg_name = NULL if user specified a NULL in msg_name but had a
non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't
affect sendto as it would bail out earlier while trying to copy-in the
address. It also more naturally reflects the logic by the callers of
verify_iovec.
With this change in place I could remove "
if (!uaddr || msg_sys->msg_namelen == 0)
This change does not alter the user visible error logic as we ignore
msg_namelen as long as msg_name is NULL.
Also remove two unnecessary curly brackets in ___sys_recvmsg and change
comments to netdev style.
[ Upstream commit 1661bf364ae9c506bc8795fef70d1532931be1e8 ]
We need to cap ->msg_namelen or it leads to a buffer overflow when we
to the memcpy() in __audit_sockaddr(). It requires CAP_AUDIT_CONTROL to
exploit this bug.
The call tree is:
___sys_recvmsg()
move_addr_to_user()
audit_sockaddr()
__audit_sockaddr()
Reported-by: Jüri Aedla <juri.aedla@gmail.com>
[ Upstream commits 1be374a0518a288147c6a7398792583200a67261 and
a7526eb5d06b0084ef12d7b168d008fcf516caab ]
MSG_CMSG_COMPAT is (AFAIK) not intended to be part of the API --
it's a hack that steals a bit to indicate to other networking code
that a compat entry was used. So don't allow it from a non-compat
syscall.
This prevents an oops when running this code:
int main()
int s;
struct sockaddr_in addr;
struct msghdr *hdr;
char *highpage = mmap((void*)(TASK_SIZE_MAX - 4096), 4096,
PROT_READ | PROT_WRITE,
MAP_PRIVATE | MAP_ANONYMOUS | MAP_FIXED, -1, 0);
if (highpage == MAP_FAILED)
err(1, "mmap");
s = socket(AF_INET, SOCK_DGRAM, IPPROTO_UDP);
if (s == -1)
err(1, "socket");
addr.sin_family = AF_INET;
addr.sin_port = htons(1);
addr.sin_addr.s_addr = htonl(INADDR_LOOPBACK);
if (connect(s, (struct sockaddr*)&addr, sizeof(addr)) != 0)
err(1, "connect");
void *evil = highpage + 4096 - COMPAT_MSGHDR_SIZE;
printf("Evil address is %p\n", evil);
if (syscall(__NR_sendmmsg, s, evil, 1, MSG_CMSG_COMPAT) < 0)
err(1, "sendmmsg");
return 0;
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
[ Upstream commit 43da5f2e0d0c69ded3d51907d9552310a6b545e8 ]
The implementation of dev_ifconf() for the compat ioctl interface uses
an intermediate ifc structure allocated in userland for the duration of
the syscall. Though, it fails to initialize the padding bytes inserted
for alignment and that for leaks four bytes of kernel stack. Add an
explicit memset(0) before filling the structure to avoid the info leak.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
commit ed6fe9d614fc1bca95eb8c0ccd0e92db00ef9d5d upstream.
Commit 644595f89620 ("compat: Handle COMPAT_USE_64BIT_TIME in
net/socket.c") introduced a bug where the helper functions to take
either a 64-bit or compat time[spec|val] got the arguments in the wrong
order, passing the kernel stack pointer off as a user pointer (and vice
versa).
Because of the user address range check, that in turn then causes an
EFAULT due to the user pointer range checking failing for the kernel
address. Incorrectly resuling in a failed system call for 32-bit
processes with a 64-bit kernel.
On odder architectures like HP-PA (with separate user/kernel address
spaces), it can be used read kernel memory.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
commit b09e786bd1dd66418b69348cb110f3a64764626a upstream.
This patch fixes a crash
tun_chr_close -> netdev_run_todo -> tun_free_netdev -> sk_release_kernel ->
sock_release -> iput(SOCK_INODE(sock))
introduced by commit 1ab5ecb90cb6a3df1476e052f76a6e8f6511cb3d
The problem is that this socket is embedded in struct tun_struct, it has
no inode, iput is called on invalid inode, which modifies invalid memory
and optionally causes a crash.
sock_release also decrements sockets_in_use, this causes a bug that
"sockets: used" field in /proc/*/net/sockstat keeps on decreasing when
creating and closing tun devices.
This patch introduces a flag SOCK_EXTERNALLY_ALLOCATED that instructs
sock_release to not free the inode and not decrement sockets_in_use,
fixing both memory corruption and sockets_in_use underflow.
It should be backported to 3.3 an 3.4 stabke.
Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz>
commit 2f533844242 (tcp: allow splice() to build full TSO packets) added
a regression for splice() calls using SPLICE_F_MORE.
We need to call tcp_flush() at the end of the last page processed in
tcp_sendpages(), or else transmits can be deferred and future sends
stall.
Add a new internal flag, MSG_SENDPAGE_NOTLAST, acting like MSG_MORE, but
with different semantic.
For all sendpage() providers, its a transparent change. Only
sock_sendpage() and tcp_sendpages() can differentiate the two different
flags provided by pipe_to_sendpage()
Reported-by: Tom Herbert <therbert@google.com>
Cc: Nandita Dukkipati <nanditad@google.com>
Cc: Neal Cardwell <ncardwell@google.com>
Cc: Tom Herbert <therbert@google.com>
Cc: Yuchung Cheng <ycheng@google.com>
Cc: H.K. Jerry Chu <hkchu@google.com>
Cc: Maciej Żenczykowski <maze@google.com>
Cc: Mahesh Bandewar <maheshb@google.com>
Cc: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
Signed-off-by: Eric Dumazet <eric.dumazet@gmail>com>
Pull x32 support for x86-64 from Ingo Molnar:
"This tree introduces the X32 binary format and execution mode for x86:
32-bit data space binaries using 64-bit instructions and 64-bit kernel
syscalls.
This allows applications whose working set fits into a 32 bits address
space to make use of 64-bit instructions while using a 32-bit address
space with shorter pointers, more compressed data structures, etc."
Fix up trivial context conflicts in arch/x86/{Kconfig,vdso/vma.c}
* 'x86-x32-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (71 commits)
x32: Fix alignment fail in struct compat_siginfo
x32: Fix stupid ia32/x32 inversion in the siginfo format
x32: Add ptrace for x32
x32: Switch to a 64-bit clock_t
x32: Provide separate is_ia32_task() and is_x32_task() predicates
x86, mtrr: Use explicit sizing and padding for the 64-bit ioctls
x86/x32: Fix the binutils auto-detect
x32: Warn and disable rather than error if binutils too old
x32: Only clear TIF_X32 flag once
x32: Make sure TS_COMPAT is cleared for x32 tasks
fs: Remove missed ->fds_bits from cessation use of fd_set structs internally
fs: Fix close_on_exec pointer in alloc_fdtable
x32: Drop non-__vdso weak symbols from the x32 VDSO
x32: Fix coding style violations in the x32 VDSO code
x32: Add x32 VDSO support
x32: Allow x32 to be configured
x32: If configured, add x32 system calls to system call tables
x32: Handle process creation
x32: Signal-related system calls
x86: Add #ifdef CONFIG_COMPAT to <asm/sys_ia32.h>
The following 4 functions:
move_addr_to_kernel
move_addr_to_user
verify_iovec
verify_compat_iovec
are always effectively called with a sockaddr_storage.
Make this explicit by changing their signature.
This removes a large number of casts from sockaddr_storage to sockaddr.
Signed-off-by: Maciej Żenczykowski <maze@google.com>
Use helper functions aware of COMPAT_USE_64BIT_TIME to write struct
timeval and struct timespec to userspace in net/socket.c.
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
commit a9b3cd7f32 (rcu: convert uses of rcu_assign_pointer(x, NULL) to
RCU_INIT_POINTER) did a lot of incorrect changes, since it did a
complete conversion of rcu_assign_pointer(x, y) to RCU_INIT_POINTER(x,
y).
We miss needed barriers, even on x86, when y is not NULL.
CC: Stephen Hemminger <shemminger@vyatta.com>
CC: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1958 commits)
net: pack skb_shared_info more efficiently
net_sched: red: split red_parms into parms and vars
net_sched: sfq: extend limits
cnic: Improve error recovery on bnx2x devices
cnic: Re-init dev->stats_addr after chip reset
net_sched: Bug in netem reordering
bna: fix sparse warnings/errors
bna: make ethtool_ops and strings const
xgmac: cleanups
net: make ethtool_ops const
vmxnet3" make ethtool ops const
xen-netback: make ops structs const
virtio_net: Pass gfp flags when allocating rx buffers.
ixgbe: FCoE: Add support for ndo_get_fcoe_hbainfo() call
netdev: FCoE: Add new ndo_get_fcoe_hbainfo() call
igb: reset PHY after recovering from PHY power down
igb: add basic runtime PM support
igb: Add support for byte queue limits.
e1000: cleanup CE4100 MDIO registers access
e1000: unmap ce4100_gbe_mdio_base_virt in e1000_remove
We're doing some odd things there, which already messes up various users
(see the net/socket.c code that this removes), and it was going to add
yet more crud to the block layer because of the incorrect error code
translation.
ENOIOCTLCMD is not an error return that should be returned to user mode
from the "ioctl()" system call, but it should *not* be translated as
EINVAL ("Invalid argument"). It should be translated as ENOTTY
("Inappropriate ioctl for device").
That EINVAL confusion has apparently so permeated some code that the
block layer actually checks for it, which is sad. We continue to do so
for now, but add a big comment about how wrong that is, and we should
remove it entirely eventually. In the meantime, this tries to keep the
changes localized to just the EINVAL -> ENOTTY fix, and removing code
that makes it harder to do the right thing.
Define special location values for RX NFC that request the driver to
select the actual rule location. This allows for implementation on
devices that use hash-based filter lookup, whereas currently the API is
more suited to devices with TCAM lookup or linear search.
In ethtool_set_rxnfc() and the compat wrapper ethtool_ioctl(), copy
the structure back to user-space after insertion so that the actual
location is returned.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
This patch adds in the infrastructure code to create the network priority
cgroup. The cgroup, in addition to the standard processes file creates two
control files:
1) prioidx - This is a read-only file that exports the index of this cgroup.
This is a value that is both arbitrary and unique to a cgroup in this subsystem,
and is used to index the per-device priority map
2) priomap - This is a writeable file. On read it reports a table of 2-tuples
<name:priority> where name is the name of a network interface and priority is
indicates the priority assigned to frames egresessing on the named interface and
originating from a pid in this cgroup
This cgroup allows for skb priority to be set prior to a root qdisc getting
selected. This is benenficial for DCB enabled systems, in that it allows for any
application to use dcb configured priorities so without application modification
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Signed-off-by: John Fastabend <john.r.fastabend@intel.com>
CC: Robert Love <robert.w.love@intel.com>
CC: "David S. Miller" <davem@davemloft.net>
The 802.1X EAPOL handshake hostapd does requires
knowing whether the frame was ack'ed by the peer.
Currently, we fudge this pretty badly by not even
transmitting the frame as a normal data frame but
injecting it with radiotap and getting the status
out of radiotap monitor as well. This is rather
complex, confuses users (mon.wlan0 presence) and
doesn't work with all hardware.
To get rid of that hack, introduce a real wifi TX
status option for data frame transmissions.
This works similar to the existing TX timestamping
in that it reflects the SKB back to the socket's
error queue with a SCM_WIFI_STATUS cmsg that has
an int indicating ACK status (0/1).
Since it is possible that at some point we will
want to have TX timestamping and wifi status in a
single errqueue SKB (there's little point in not
doing that), redefine SO_EE_ORIGIN_TIMESTAMPING
to SO_EE_ORIGIN_TXSTATUS which can collect more
than just the timestamp; keep the old constant
as an alias of course. Currently the internal APIs
don't make that possible, but it wouldn't be hard
to split them up in a way that makes it possible.
Thanks to Neil Horman for helping me figure out
the functions that add the control messages.
MAINTAINERS
drivers/net/Kconfig
drivers/net/ethernet/broadcom/bnx2x/bnx2x_link.c
drivers/net/ethernet/broadcom/tg3.c
drivers/net/wireless/iwlwifi/iwl-pci.c
drivers/net/wireless/iwlwifi/iwl-trans-tx-pcie.c
drivers/net/wireless/rt2x00/rt2800usb.c
drivers/net/wireless/wl12xx/main.c
Dereferencing a user pointer directly from kernel-space without going
through the copy_from_user family of functions is a bad idea. Two of
such usages can be found in the sendmsg code path called from sendmmsg,
added by
commit c71d8ebe7a4496fb7231151cb70a6baa0cb56f9a upstream.
commit 5b47b8038f183b44d2d8ff1c7d11a5c1be706b34 in the 3.0-stable tree.
Usages are performed through memcmp() and memcpy() directly. Fix those
by using the already copied msg_sys structure instead of the __user *msg
structure. Note that msg_sys can be set to NULL by verify_compat_iovec()
or verify_iovec(), which requires additional NULL pointer checks.
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Signed-off-by: David Goulet <dgoulet@ev0ke.net>
CC: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
CC: Anton Blanchard <anton@samba.org>
CC: David S. Miller <davem@davemloft.net>
CC: stable <stable@kernel.org>
The sendmmsg() introduced by commit 228e548e "net: Add sendmmsg socket system
call" is capable of sending to multiple different destination addresses.
SMACK is using destination's address for checking sendmsg() permission.
However, security_socket_sendmsg() is called for only once even if multiple
different destination addresses are passed to sendmmsg().
Therefore, we need to call security_socket_sendmsg() for each destination
address rather than only the first destination address.
Since calling security_socket_sendmsg() every time when only single destination
address was passed to sendmmsg() is a waste of time, omit calling
security_socket_sendmsg() unless destination address of previous datagram and
that of current datagram differs.
Acked-by: Anton Blanchard <anton@samba.org>
Cc: stable <stable@kernel.org> [3.0+]
To limit the amount of time we can spend in sendmmsg, cap the
number of elements to UIO_MAXIOV (currently 1024).
For error handling an application using sendmmsg needs to retry at
the first unsent message, so capping is simpler and requires less
application logic than returning EINVAL.
sendmmsg uses a similar error return strategy as recvmmsg but it
turns out to be a confusing way to communicate errors.
The current code stores the error code away and returns it on the next
sendmmsg call. This means a call with completely valid arguments could
get an error from a previous call.
Change things so we only return an error if no datagrams could be sent.
If less than the requested number of messages were sent, the application
must retry starting at the first failed one and if the problem is
persistent the error will be returned.
This matches the behaviour of other syscalls like read/write - it
is not an error if less than the requested number of elements are sent.
When assigning a NULL value to an RCU protected pointer, no barrier
is needed. The rcu_assign_pointer, used to handle that but will soon
change to not handle the special case.
Convert all rcu_assign_pointer of NULL value.
//smpl
@@ expression P; @@
- rcu_assign_pointer(P, NULL)
+ RCU_INIT_POINTER(P, NULL)
// </smpl>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (32 commits)
tg3: Remove 5719 jumbo frames and TSO blocks
tg3: Break larger frags into 4k chunks for 5719
tg3: Add tx BD budgeting code
tg3: Consolidate code that calls tg3_tx_set_bd()
tg3: Add partial fragment unmapping code
tg3: Generalize tg3_skb_error_unmap()
tg3: Remove short DMA check for 1st fragment
tg3: Simplify tx bd assignments
tg3: Reintroduce tg3_tx_ring_info
ASIX: Use only 11 bits of header for data size
ASIX: Simplify condition in rx_fixup()
Fix cdc-phonet build
bonding: reduce noise during init
bonding: fix string comparison errors
net: Audit drivers to identify those needing IFF_TX_SKB_SHARING cleared
net: add IFF_SKB_TX_SHARED flag to priv_flags
net: sock_sendmsg_nosec() is static
forcedeth: fix vlans
gianfar: fix bug caused by 87c288c6e9aa31720b72e2bc2d665e24e1653c3e
gro: Only reset frag0 when skb can be pulled
Workloads using pipes and sockets hit inode_sb_list_lock contention.
superblock s_inodes list is needed for quota, dirty, pagecache and
fsnotify management. pipe/anon/socket fs are clearly not candidates for
these.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1446 commits)
macvlan: fix panic if lowerdev in a bond
tg3: Add braces around 5906 workaround.
tg3: Fix NETIF_F_LOOPBACK error
macvlan: remove one synchronize_rcu() call
networking: NET_CLS_ROUTE4 depends on INET
irda: Fix error propagation in ircomm_lmp_connect_response()
irda: Kill set but unused variable 'bytes' in irlan_check_command_param()
irda: Kill set but unused variable 'clen' in ircomm_connect_indication()
rxrpc: Fix set but unused variable 'usage' in rxrpc_get_transport()
be2net: Kill set but unused variable 'req' in lancer_fw_download()
irda: Kill set but unused vars 'saddr' and 'daddr' in irlan_provider_connect_indication()
atl1c: atl1c_resume() is only used when CONFIG_PM_SLEEP is defined.
rxrpc: Fix set but unused variable 'usage' in rxrpc_get_peer().
rxrpc: Kill set but unused variable 'local' in rxrpc_UDP_error_handler()
rxrpc: Kill set but unused variable 'sp' in rxrpc_process_connection()
rxrpc: Kill set but unused variable 'sp' in rxrpc_rotate_tx_window()
pkt_sched: Kill set but unused variable 'protocol' in tc_classify()
isdn: capi: Use pr_debug() instead of ifdefs.
tg3: Update version to 3.119
tg3: Apply rx_discards fix to 5719/5720
Fix up trivial conflicts in arch/x86/Kconfig and net/mac80211/agg-tx.c
as per Davem.
drivers/net/vmxnet3/vmxnet3_ethtool.c
net/core/dev.c
recvmmsg fails on a raw socket with EINVAL. The reason for this is
packet_recvmsg checks the incoming flags:
err = -EINVAL;
if (flags & ~(MSG_PEEK|MSG_DONTWAIT|MSG_TRUNC|MSG_CMSG_COMPAT|MSG_ERRQUEUE))
goto out;
This patch strips out MSG_WAITFORONE when calling recvmmsg which
fixes the issue.
Cc: stable@kernel.org [2.6.34+]
The rcu callback wq_free_rcu() just calls a kfree(),
so we use kfree_rcu() instead of the call_rcu(wq_free_rcu).
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
This patch adds a multiple message send syscall and is the send
version of the existing recvmmsg syscall. This is heavily
based on the patch by Arnaldo that added recvmmsg.
I wrote a microbenchmark to test the performance gains of using
this new syscall:
http://ozlabs.org/~anton/junkcode/sendmmsg_test.c
The test was run on a ppc64 box with a 10 Gbit network card. The
benchmark can send both UDP and RAW ethernet packets.
64B UDP
batch pkts/sec
1 804570
2 872800 (+ 8 %)
4 916556 (+14 %)
8 939712 (+17 %)
16 952688 (+18 %)
32 956448 (+19 %)
64 964800 (+20 %)
64B raw socket
batch pkts/sec
1 1201449
2 1350028 (+12 %)
4 1461416 (+22 %)
8 1513080 (+26 %)
16 1541216 (+28 %)
32 1553440 (+29 %)
64 1557888 (+30 %)
We see a 20% improvement in throughput on UDP send and 30%
on raw socket send.
[ Add sparc syscall entries. -DaveM ]
drivers/net/smsc911x.c
This change is meant to add an ntuple data extensions to the rx network flow
classification specifiers. The idea is to allow ntuple to be displayed via
the network flow classification interface.
The first patch had some left over stuff from the original flow extension
flags I had added. That bit is removed in this patch.
The second had some left over comments that stated we ignored bits in the
masks when we actually match them.
This work is based on input from Ben Hutchings.
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
Reviewed-by: Ben Hutchings <bhutchings@solarflare.com>
This structure was accidentally defined such that its layout can
differ between 32-bit and 64-bit processes. Add compat structure
definitions and an ioctl wrapper function.
Acked-by: Alexander Duyck <alexander.h.duyck@intel.com>
Cc: stable@kernel.org [2.6.30+]
Use __force to quiet sparse warnings for cases where the code
is simulating user space pointers.
Add proper RCU annotations/verbs to sk_wq and wq members
Fix __sctp_write_space() sk_sleep() abuse (and sock->wq access)
Fix sunrpc sk_sleep() abuse too
git://git.kernel.org/pub/scm/linux/kernel/git/npiggin/linux-npiggin
* 'vfs-scale-working' of git://git.kernel.org/pub/scm/linux/kernel/git/npiggin/linux-npiggin: (57 commits)
fs: scale mntget/mntput
fs: rename vfsmount counter helpers
fs: implement faster dentry memcmp
fs: prefetch inode data in dcache lookup
fs: improve scalability of pseudo filesystems
fs: dcache per-inode inode alias locking
fs: dcache per-bucket dcache hash locking
bit_spinlock: add required includes
kernel: add bl_list
xfs: provide simple rcu-walk ACL implementation
btrfs: provide simple rcu-walk ACL implementation
ext2,3,4: provide simple rcu-walk ACL implementation
fs: provide simple rcu-walk generic_check_acl implementation
fs: provide rcu-walk aware permission i_ops
fs: rcu-walk aware d_revalidate method
fs: cache optimise dentry and inode for rcu-walk
fs: dcache reduce branches in lookup path
fs: dcache remove d_mounted
fs: fs_struct use seqlock
fs: rcu-walk for path lookup
The problem that this patch aims to fix is vfsmount refcounting scalability.
We need to take a reference on the vfsmount for every successful path lookup,
which often go to the same mount point.
The fundamental difficulty is that a "simple" reference count can never be made
scalable, because any time a reference is dropped, we must check whether that
was the last reference. To do that requires communication with all other CPUs
that may have taken a reference count.
We can make refcounts more scalable in a couple of ways, involving keeping
distributed counters, and checking for the global-zero condition less
frequently.
- check the global sum once every interval (this will delay zero detection
for some interval, so it's probably a showstopper for vfsmounts).
- keep a local count and only taking the global sum when local reaches 0 (this
is difficult for vfsmounts, because we can't hold preempt off for the life of
a reference, so a counter would need to be per-thread or tied strongly to a
particular CPU which requires more locking).
- keep a local difference of increments and decrements, which allows us to sum
the total difference and hence find the refcount when summing all CPUs. Then,
keep a single integer "long" refcount for slow and long lasting references,
and only take the global sum of local counters when the long refcount is 0.
This last scheme is what I implemented here. Attached mounts and process root
and working directory references are "long" references, and everything else is
a short reference.
This allows scalable vfsmount references during path walking over mounted
subtrees and unattached (lazy umounted) mounts with processes still running
in them.
This results in one fewer atomic op in the fastpath: mntget is now just a
per-CPU inc, rather than an atomic inc; and mntput just requires a spinlock
and non-atomic decrement in the common case. However code is otherwise bigger
and heavier, so single threaded performance is basically a wash.
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
Regardless of how much we possibly try to scale dcache, there is likely
always going to be some fundamental contention when adding or removing children
under the same parent. Pseudo filesystems do not seem need to have connected
dentries because by definition they are disconnected.
Reduce some branches and memory accesses in dcache lookup by adding dentry
flags to indicate common d_ops are set, rather than having to check them.
This saves a pointer memory access (dentry->d_op) in common path lookup
situations, and saves another pointer load and branch in cases where we
have d_op but not the particular operation.
Patched with:
git grep -E '[.>]([[:space:]])*d_op([[:space:]])*=' | xargs sed -e 's/\([^\t ]*\)->d_op = \(.*\);/d_set_d_op(\1, \2);/' -e 's/\([^\t ]*\)\.d_op = \(.*\);/d_set_d_op(\&\1, \2);/' -i
Pseudo filesystems that don't put inode on RCU list or reachable by
rcu-walk dentries do not need to RCU free their inodes.
RCU free the struct inode. This will allow:
- Subsequent store-free path walking patch. The inode must be consulted for
permissions when walking, so an RCU inode reference is a must.
- sb_inode_list_lock to be moved inside i_lock because sb list walkers who want
to take i_lock no longer need to take sb_inode_list_lock to walk the list in
the first place. This will simplify and optimize locking.
- Could remove some nested trylock loops in dcache code
- Could potentially simplify things a bit in VM land. Do not need to take the
page lock to follow page->mapping.
The downsides of this is the performance cost of using RCU. In a simple
creat/unlink microbenchmark, performance drops by about 10% due to inability to
reuse cache-hot slab objects. As iterations increase and RCU freeing starts
kicking over, this increases to about 20%.
In cases where inode lifetimes are longer (ie. many inodes may be allocated
during the average life span of a single inode), a lot of this cache reuse is
not applicable, so the regression caused by this patch is smaller.
The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU,
however this adds some complexity to list walking and store-free path walking,
so I prefer to implement this at a later date, if it is shown to be a win in
real situations. I haven't found a regression in any non-micro benchmark so I
doubt it will be a problem.
drivers/net/bnx2x/bnx2x.h
drivers/net/wireless/iwlwifi/iwl-1000.c
drivers/net/wireless/iwlwifi/iwl-6000.c
drivers/net/wireless/iwlwifi/iwl-core.h
drivers/vhost/vhost.c
Signed-off-by: Martin Lucina <mato@kotelna.sk>
Use modern RCU API / annotations for net_families array.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
isdn: mISDN: socket: fix information leak to userland
netdev: can: Change mail address of Hans J. Koch
pcnet_cs: add new_id
net: Truncate recvfrom and sendto length to INT_MAX.
RDS: Let rds_message_alloc_sgs() return NULL
RDS: Copy rds_iovecs into kernel memory instead of rereading from userspace
RDS: Clean up error handling in rds_cmsg_rdma_args
RDS: Return -EINVAL if rds_rdma_pages returns an error
net: fix rds_iovec page count overflow
can: pch_can: fix section mismatch warning by using a whitelisted name
can: pch_can: fix sparse warning
netxen_nic: Fix the tx queue manipulation bug in netxen_nic_probe
ip_gre: fix fallback tunnel setup
vmxnet: trivial annotation of protocol constant
vmxnet3: remove unnecessary byteswapping in BAR writing macros
ipv6/udp: report SndbufErrors and RcvbufErrors
phy/marvell: rename 88ec048 to 88e1318s and fix mscr1 addr
