path: root/net/sunrpc/auth.c
2011-06-05net: Remove unnecessary semicolonsJoe Perches
Semicolons are not necessary after switch/while/for/if braces so remove them. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-25vmscan: change shrinker API by passing shrink_control structYing Han
Change each shrinker's API by consolidating the existing parameters into shrink_control struct. This will simplify any further features added w/o touching each file of shrinker. [akpm@linux-foundation.org: fix build] [akpm@linux-foundation.org: fix warning] [kosaki.motohiro@jp.fujitsu.com: fix up new shrinker API] [akpm@linux-foundation.org: fix xfs warning] [akpm@linux-foundation.org: update gfs2] Signed-off-by: Ying Han <yinghan@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Minchan Kim <minchan.kim@gmail.com> Acked-by: Pavel Emelyanov <xemul@openvz.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Acked-by: Rik van Riel <riel@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-16SUNRPC: New xdr_streams XDR decoder APIChuck Lever
Now that all client-side XDR decoder routines use xdr_streams, there should be no need to support the legacy calling sequence [rpc_rqst *, __be32 *, RPC res *] anywhere. We can construct an xdr_stream in the generic RPC code, instead of in each decoder function. This is a refactoring change. It should not cause different behavior. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16SUNRPC: New xdr_streams XDR encoder APIChuck Lever
Now that all client-side XDR encoder routines use xdr_streams, there should be no need to support the legacy calling sequence [rpc_rqst *, __be32 *, RPC arg *] anywhere. We can construct an xdr_stream in the generic RPC code, instead of in each encoder function. Also, all the client-side encoder functions return 0 now, making a return value superfluous. Take this opportunity to convert them to return void instead. This is a refactoring change. It should not cause different behavior. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-10-26Merge branch 'for-2.6.37' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.37' of git://linux-nfs.org/~bfields/linux: (99 commits) svcrpc: svc_tcp_sendto XPT_DEAD check is redundant svcrpc: no need for XPT_DEAD check in svc_xprt_enqueue svcrpc: assume svc_delete_xprt() called only once svcrpc: never clear XPT_BUSY on dead xprt nfsd4: fix connection allocation in sequence() nfsd4: only require krb5 principal for NFSv4.0 callbacks nfsd4: move minorversion to client nfsd4: delay session removal till free_client nfsd4: separate callback change and callback probe nfsd4: callback program number is per-session nfsd4: track backchannel connections nfsd4: confirm only on succesful create_session nfsd4: make backchannel sequence number per-session nfsd4: use client pointer to backchannel session nfsd4: move callback setup into session init code nfsd4: don't cache seq_misordered replies SUNRPC: Properly initialize sock_xprt.srcaddr in all cases SUNRPC: Use conventional switch statement when reclassifying sockets sunrpc/xprtrdma: clean up workqueue usage sunrpc: Turn list_for_each-s into the ..._entry-s ... Fix up trivial conflicts (two different deprecation notices added in separate branches) in Documentation/feature-removal-schedule.txt
2010-10-25Merge branch 'nfs-for-2.6.37' of ↵Linus Torvalds
git://git.linux-nfs.org/projects/trondmy/nfs-2.6 * 'nfs-for-2.6.37' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: (67 commits) SUNRPC: Cleanup duplicate assignment in rpcauth_refreshcred nfs: fix unchecked value Ask for time_delta during fsinfo probe Revalidate caches on lock SUNRPC: After calling xprt_release(), we must restart from call_reserve NFSv4: Fix up the 'dircount' hint in encode_readdir NFSv4: Clean up nfs4_decode_dirent NFSv4: nfs4_decode_dirent must clear entry->fattr->valid NFSv4: Fix a regression in decode_getfattr NFSv4: Fix up decode_attr_filehandle() to handle the case of empty fh pointer NFS: Ensure we check all allocation return values in new readdir code NFS: Readdir plus in v4 NFS: introduce generic decode_getattr function NFS: check xdr_decode for errors NFS: nfs_readdir_filler catch all errors NFS: readdir with vmapped pages NFS: remove page size checking code NFS: decode_dirent should use an xdr_stream SUNRPC: Add a helper function xdr_inline_peek NFS: remove readdir plus limit ...
2010-10-24SUNRPC: Cleanup duplicate assignment in rpcauth_refreshcredTrond Myklebust
2010-09-29sunrpc: fix up rpcauth_remove_module section mismatchStephen Rothwell
On Wed, 29 Sep 2010 14:02:38 +1000 Stephen Rothwell <sfr@canb.auug.org.au> wrote: > > After merging the final tree, today's linux-next build (powerpc > ppc44x_defconfig) produced tis warning: > > WARNING: net/sunrpc/sunrpc.o(.init.text+0x110): Section mismatch in reference from the function init_sunrpc() to the function .exit.text:rpcauth_remove_module() > The function __init init_sunrpc() references > a function __exit rpcauth_remove_module(). > This is often seen when error handling in the init function > uses functionality in the exit path. > The fix is often to remove the __exit annotation of > rpcauth_remove_module() so it may be used outside an exit section. > > Probably caused by commit 2f72c9b73730c335381b13e2bd221abe1acea394 > ("sunrpc: The per-net skeleton"). This actually causes a build failure on a sparc32 defconfig build: `rpcauth_remove_module' referenced in section `.init.text' of net/built-in.o: defined in discarded section `.exit.text' of net/built-in.o I applied the following patch for today: Fixes: `rpcauth_remove_module' referenced in section `.init.text' of net/built-in.o: defined in discarded section `.exit.text' of net/built-in.o Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-09-12sunrpc: increase MAX_HASHTABLE_BITS to 14Miquel van Smoorenburg
The maximum size of the authcache is now set to 1024 (10 bits), but on our server we need at least 4096 (12 bits). Increase MAX_HASHTABLE_BITS to 14. This is a maximum of 16384 entries, each containing a pointer (8 bytes on x86_64). This is exactly the limit of kmalloc() (128K). Signed-off-by: Miquel van Smoorenburg <mikevs@xs4all.net> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-08-11nfs: update for module_param_named API changeStephen Rothwell
After merging the rr tree, today's linux-next build (powerpc ppc64_defconfig) failed like this: net/sunrpc/auth.c:74: error: 'param_ops_hashtbl_sz' undeclared here (not in a function) Caused by commit 0685652df0929cec7d78efa85127f6eb34962132 ("param:param_ops") interacting with commit f8f853ab19fcc415b6eadd273373edc424916212 ("SUNRPC: Make the credential cache hashtable size configurable") from the nfs tree. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-08-07Merge branch 'nfs-for-2.6.36' of ↵Linus Torvalds
git://git.linux-nfs.org/projects/trondmy/nfs-2.6 * 'nfs-for-2.6.36' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: (42 commits) NFS: NFSv4.1 is no longer a "developer only" feature NFS: NFS_V4 is no longer an EXPERIMENTAL feature NFS: Fix /proc/mount for legacy binary interface NFS: Fix the locking in nfs4_callback_getattr SUNRPC: Defer deleting the security context until gss_do_free_ctx() SUNRPC: prevent task_cleanup running on freed xprt SUNRPC: Reduce asynchronous RPC task stack usage SUNRPC: Move the bound cred to struct rpc_rqst SUNRPC: Clean up of rpc_bindcred() SUNRPC: Move remaining RPC client related task initialisation into clnt.c SUNRPC: Ensure that rpc_exit() always wakes up a sleeping task SUNRPC: Make the credential cache hashtable size configurable SUNRPC: Store the hashtable size in struct rpc_cred_cache NFS: Ensure the AUTH_UNIX credcache is allocated dynamically NFS: Fix the NFS users of rpc_restart_call() SUNRPC: The function rpc_restart_call() should return success/failure NFSv4: Get rid of the bogus RPC_ASSASSINATED(task) checks NFSv4: Clean up the process of renewing the NFSv4 lease NFSv4.1: Handle NFS4ERR_DELAY on SEQUENCE correctly NFS: nfs_rename() should not have to flush out writebacks ...
2010-08-04SUNRPC: Move the bound cred to struct rpc_rqstTrond Myklebust
This will allow us to save the original generic cred in rpc_message, so that if we migrate from one server to another, we can generate a new bound cred without having to punt back to the NFS layer. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-08-04SUNRPC: Clean up of rpc_bindcred()Trond Myklebust
2010-08-04SUNRPC: Make the credential cache hashtable size configurableTrond Myklebust
This patch allows the user to configure the credential cache hashtable size using a new module parameter: auth_hashtable_size When set, this parameter will be rounded up to the nearest power of two, with a maximum allowed value of 1024 elements. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-08-04SUNRPC: Store the hashtable size in struct rpc_cred_cacheTrond Myklebust
Cleanup in preparation for allowing the user to determine the maximum hash table size. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-08-04NFS: Ensure the AUTH_UNIX credcache is allocated dynamicallyTrond Myklebust
2010-07-21mm: add context argument to shrinker callback to remaining shrinkersDave Chinner
Add the shrinkers missed in the first conversion of the API in commit 7f8275d0d660c146de6ee3017e1e2e594c49e820 ("mm: add context argument to shrinker callback"). Signed-off-by: Dave Chinner <dchinner@redhat.com>
2010-05-14SUNRPC: Ensure rpcauth_prune_expired() respects the nr_to_scan parameterTrond Myklebust
2010-05-14SUNRPC: Ensure memory shrinker doesn't waste time in rpcauth_prune_expired()Trond Myklebust
The 'cred_unused' list, that is traversed by rpcauth_cache_shrinker is ordered by time. If we hit a credential that is under the 60 second garbage collection moratorium, we should exit because we know at that point that all successive credentials are subject to the same moratorium... Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-05-14SUNRPC: Dont run rpcauth_cache_shrinker() when gfp_mask is GFP_NOFSTrond Myklebust
Under some circumstances, put_rpccred() can end up allocating memory, so check the gfp_mask to prevent deadlocks. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-04-22SUNRPC: Fix a bug in rpcauth_prune_expiredTrond Myklebust
Don't want to evict a credential if cred->cr_expire == jiffies, since that means that it was just placed on the cred_unused list. We therefore need to use time_in_range() rather than time_in_range_open(). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-12-13Merge branch 'nfs-for-2.6.33'Trond Myklebust
2009-12-03RPC: Fix two potential races in put_rpccredTrond Myklebust
It is possible for rpcauth_destroy_credcache() to cause the rpc credentials to be unhashed while put_rpccred is waiting for the rpc_credcache_lock on another cpu. Should this happen, then we can end up calling hlist_del_rcu(&cred->cr_hash) a second time in put_rpccred, thus causing list corruption. Should the credential actually be hashed, it is also possible for rpcauth_lookup_credcache to find and reference it before we get round to unhashing it. In this case, the call to rpcauth_unhash_cred will fail, and so we should just exit without destroying the cred. Reported-by: Neil Brown <neilb@suse.de> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-11-29net: Move && and || to end of previous lineJoe Perches
Not including net/atm/ Compiled tested x86 allyesconfig only Added a > 80 column line or two, which I ignored. Existing checkpatch plaints willfully, cheerfully ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-15SUNRPC: Defer the auth_gss upcall when the RPC call is asynchronousTrond Myklebust
Otherwise, the upcall is going to be synchronous, which may not be what the caller wants... Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-12-30Merge branch 'devel' into nextTrond Myklebust
2008-12-23optimize attribute timeouts for "noac" and "actimeo=0"Peter Staubach
Hi. I've been looking at a bugzilla which describes a problem where a customer was advised to use either the "noac" or "actimeo=0" mount options to solve a consistency problem that they were seeing in the file attributes. It turned out that this solution did not work reliably for them because sometimes, the local attribute cache was believed to be valid and not timed out. (With an attribute cache timeout of 0, the cache should always appear to be timed out.) In looking at this situation, it appears to me that the problem is that the attribute cache timeout code has an off-by-one error in it. It is assuming that the cache is valid in the region, [read_cache_jiffies, read_cache_jiffies + attrtimeo]. The cache should be considered valid only in the region, [read_cache_jiffies, read_cache_jiffies + attrtimeo). With this change, the options, "noac" and "actimeo=0", work as originally expected. This problem was previously addressed by special casing the attrtimeo == 0 case. However, since the problem is only an off- by-one error, the cleaner solution is address the off-by-one error and thus, not require the special case. Thanx... ps Signed-off-by: Peter Staubach <staubach@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-12-23SUNRPC: Remove the last remnant of the BKL...Trond Myklebust
Somehow, this escaped the previous purge. There should be no need to keep any extra locks in the XDR callbacks. The NFS client XDR code only writes into private objects, whereas all reads of shared objects are confined to fields that do not change, such as filehandles... Ditto for lockd, the NFSv2/v3 client mount code, and rpcbind. The nfsd XDR code may require the BKL, but since it does a synchronous RPC call from a thread that already holds the lock, that issue is moot. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-11-14CRED: Wrap current->cred and a few other accessorsDavid Howells
Wrap current->cred and a few other accessors to hide their actual implementation. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Separate task security context from task_structDavid Howells
Separate the task security context from task_struct. At this point, the security data is temporarily embedded in the task_struct with two pointers pointing to it. Note that the Alpha arch is altered as it refers to (E)UID and (E)GID in entry.S via asm-offsets. With comment fixes Signed-off-by: Marc Dionne <marc.c.dionne@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Wrap task credential accesses in the SunRPC protocolDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: J. Bruce Fields <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Cc: linux-nfs@vger.kernel.org Signed-off-by: James Morris <jmorris@namei.org>
2008-10-28SUNRPC: Fix potential race in put_rpccred()Trond Myklebust
We have to be careful when we try to unhash the credential in put_rpccred(), because we're not holding the credcache lock, so the call to rpcauth_unhash_cred() may fail if someone else has looked the cred up, and obtained a reference to it. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-10-28SUNRPC: Fix rpcauth_prune_expiredTrond Myklebust
We need to make sure that we don't remove creds from the cred_unused list if they are still under the moratorium, or else they will never get garbage collected. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-10-16net: Remove CONFIG_KMOD from net/ (towards removing CONFIG_KMOD entirely)Johannes Berg
Some code here depends on CONFIG_KMOD to not try to load protocol modules or similar, replace by CONFIG_MODULES where more than just request_module depends on CONFIG_KMOD and and also use try_then_request_module in ebtables. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-19SUNRPC: Protect creds against early garbage collectionTrond Myklebust
2008-03-14SUNRPC: Add a helper rpcauth_lookup_generic_cred()Trond Myklebust
The NFSv4 protocol allows clients to negotiate security protocols on the fly in the case where an administrator on the server changes the export settings and/or in the case where we may have a filesystem migration event. Instead of having the NFS client code cache credentials that are tied to a particular AUTH method it is therefore preferable to have a generic credential that can be converted into whatever AUTH is in use by the RPC client when the read/write/sillyrename/... is put on the wire. We do this by means of the new "generic" credential, which basically just caches the minimal information that is needed to look up an RPCSEC_GSS, AUTH_SYS, or AUTH_NULL credential. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-03-14SUNRPC: Add an rpc_credop callback for binding a credential to an rpc_taskTrond Myklebust
We need the ability to treat 'generic' creds specially, since they want to bind instances of the auth cred instead of binding themselves. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-03-14SUNRPC: Add a generic RPC credentialTrond Myklebust
Add an rpc credential that is not tied to any particular auth mechanism, but that can be cached by NFS, and later used to look up a cred for whichever auth mechanism that turns out to be valid when the RPC call is being made. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-03-14SUNRPC: Clean up rpcauth_bindcred()Trond Myklebust
2008-03-14SUNRPC: Fix RPCAUTH_LOOKUP_ROOTCREDSTrond Myklebust
The current RPCAUTH_LOOKUP_ROOTCREDS flag only works for AUTH_SYS authentication, and then only as a special case in the code. This patch removes the auth_sys special casing, and replaces it with generic code. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-03-14SUNRPC: Fix a bug in rpcauth_lookup_credcache()Trond Myklebust
The hash bucket is for some reason always being set to zero. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-02-01Merge branch 'task_killable' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc * 'task_killable' of git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc: (22 commits) Remove commented-out code copied from NFS NFS: Switch from intr mount option to TASK_KILLABLE Add wait_for_completion_killable Add wait_event_killable Add schedule_timeout_killable Use mutex_lock_killable in vfs_readdir Add mutex_lock_killable Use lock_page_killable Add lock_page_killable Add fatal_signal_pending Add TASK_WAKEKILL exit: Use task_is_* signal: Use task_is_* sched: Use task_contributes_to_load, TASK_ALL and TASK_NORMAL ptrace: Use task_is_* power: Use task_is_* wait: Use TASK_NORMAL proc/base.c: Use task_is_* proc/array.c: Use TASK_REPORT perfmon: Use task_is_* ... Fixed up conflicts in NFS/sunrpc manually..
2008-01-30SUNRPC: Mask signals across the call to rpc_call_setup() in rpc_run_taskTrond Myklebust
To ensure that the RPCSEC_GSS upcall is performed with the correct sigmask. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30SUNRPC: Restrict sunrpc client exportsTrond Myklebust
The sunrpc client exports are not meant to be part of any official kernel API: they can change at the drop of a hat. Mark them as internal functions using EXPORT_SYMBOL_GPL. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30SUNRPC: Move exported declarations to the function declarationsTrond Myklebust
Do this for all RPC client related functions and XDR functions. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-19SUNRPC: move bkl locking and xdr proc invocation into a common helperJ. Bruce Fields
Since every invocation of xdr encode or decode functions takes the BKL now, there's a lot of redundant lock_kernel/unlock_kernel pairs that we can pull out into a common function. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-17mm: clean up and kernelify shrinker registrationRusty Russell
I can never remember what the function to register to receive VM pressure is called. I have to trace down from __alloc_pages() to find it. It's called "set_shrinker()", and it needs Your Help. 1) Don't hide struct shrinker. It contains no magic. 2) Don't allocate "struct shrinker". It's not helpful. 3) Call them "register_shrinker" and "unregister_shrinker". 4) Call the function "shrink" not "shrinker". 5) Reduce the 17 lines of waffly comments to 13, but document it properly. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: David Chinner <dgc@sgi.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10sunrpc: drop BKL around wrap and unwrapJ. Bruce Fields
We don't need the BKL when wrapping and unwrapping; and experiments by Avishay Traeger have found that permitting multiple encryption and decryption operations to proceed in parallel can provide significant performance improvements. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Cc: Avishay Traeger <atraeger@cs.sunysb.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC: Remove the tk_auth macro...Trond Myklebust
We should almost always be deferencing the rpc_auth struct by means of the credential's cr_auth field instead of the rpc_clnt->cl_auth anyway. Fix up that historical mistake, and remove the macro that propagated it. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC: Convert the credential garbage collector into a shrinker callbackTrond Myklebust
