path: root/net/sunrpc/backchannel_rqst.c
2011-07-15SUNRPC: Convert the backchannel exports to EXPORT_SYMBOL_GPLTrond Myklebust
Ensure that the backchannel exports conform to the existing sunrpc practice. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-07-15SUNRPC: sunrpc should not explicitly depend on NFS config optionsTrond Myklebust
Change explicit references to CONFIG_NFS_V4_1 to implicit ones Get rid of the unnecessary defines in backchannel_rqst.c and bc_svc.c: the Makefile takes care of those dependency. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-06-20nfs41: sunrpc: xprt_alloc_bc_request() should not use spin_lock_bh()Ricardo Labiaga
xprt_alloc_bc_request() is always called in soft interrupt context. Grab the spin_lock instead of the bottom half spin_lock. Softirqs do not preempt other softirqs running on the same processor, so there is no need to disable bottom halves. Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17nfs41: Rename rq_received to rq_reply_bytes_recvdRicardo Labiaga
The 'rq_received' member of 'struct rpc_rqst' is used to track when we have received a reply to our request. With v4.1, the backchannel can now accept callback requests over the existing connection. Rename this field to make it clear that it is only used for tracking reply bytes and not all bytes received on the connection. Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2009-06-17nfs41: New backchannel helper routinesRicardo Labiaga
This patch introduces support to setup the callback xprt on the client side. It allocates/ destroys the preallocated memory structures used to process backchannel requests. At setup time, xprt_setup_backchannel() is invoked to allocate one or more rpc_rqst structures and substructures. This ensures that they are available when an RPC callback arrives. The rpc_rqst structures are maintained in a linked list attached to the rpc_xprt structure. We keep track of the number of allocations so that they can be correctly removed when the channel is destroyed. When an RPC callback arrives, xprt_alloc_bc_request() is invoked to obtain a preallocated rpc_rqst structure. An rpc_xprt structure is returned, and its RPC_BC_PREALLOC_IN_USE bit is set in rpc_xprt->bc_flags. The structure is removed from the the list since it is now in use, and it will be later added back when its user is done with it. After the RPC callback replies, the rpc_rqst structure is returned by invoking xprt_free_bc_request(). This clears the RPC_BC_PREALLOC_IN_USE bit and adds it back to the list, allowing it to be reused by a subsequent RPC callback request. To be consistent with the reception of RPC messages, the backchannel requests should be placed into the 'struct rpc_rqst' rq_rcv_buf, which is then in turn copied to the 'struct rpc_rqst' rq_private_buf. [nfs41: Preallocate rpc_rqst receive buffer for handling callbacks] Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [Update copyright notice and explain page allocation] Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com>
