path: root/net/sunrpc/svcsock.c
2011-07-27Merge branch 'nfs-for-3.1' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
* 'nfs-for-3.1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (44 commits) NFSv4: Don't use the delegation->inode in nfs_mark_return_delegation() nfs: don't use d_move in nfs_async_rename_done RDMA: Increasing RPCRDMA_MAX_DATA_SEGS SUNRPC: Replace xprt->resend and xprt->sending with a priority queue SUNRPC: Allow caller of rpc_sleep_on() to select priority levels SUNRPC: Support dynamic slot allocation for TCP connections SUNRPC: Clean up the slot table allocation SUNRPC: Initalise the struct xprt upon allocation SUNRPC: Ensure that we grab the XPRT_LOCK before calling xprt_alloc_slot pnfs: simplify pnfs files module autoloading nfs: document nfsv4 sillyrename issues NFS: Convert nfs4_set_ds_client to EXPORT_SYMBOL_GPL SUNRPC: Convert the backchannel exports to EXPORT_SYMBOL_GPL SUNRPC: sunrpc should not explicitly depend on NFS config options NFS: Clean up - simplify the switch to read/write-through-MDS NFS: Move the pnfs write code into pnfs.c NFS: Move the pnfs read code into pnfs.c NFS: Allow the nfs_pageio_descriptor to signal that a re-coalesce is needed NFS: Use the nfs_pageio_descriptor->pg_bsize in the read/write request NFS: Cache rpc_ops in struct nfs_pageio_descriptor ...
2011-07-15svcsock.c: include sunrpc.h to quiet sparse noiseH Hartley Sweeten
Include the private header sunrpc.h to pickup the declaration of the function svc_send_common to quiet the following sparse noise: warning: symbol 'svc_send_common' was not declared. Should it be static? Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-07-15SUNRPC: sunrpc should not explicitly depend on NFS config optionsTrond Myklebust
Change explicit references to CONFIG_NFS_V4_1 to implicit ones Get rid of the unnecessary defines in backchannel_rqst.c and bc_svc.c: the Makefile takes care of those dependency. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-04-10svcrpc: complete svsk processing on cb receive failureJ. Bruce Fields
Currently when there's some failure to receive a callback (because we couldn't find a matching xid, for example), we exit svc_recv with sk_tcplen still set but without any pages saved with the socket. This will cause a crash later in svc_tcp_restore_pages. Instead, make sure we reset that tcp information whether the callback received failed or succeeded. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-04-07svcrpc: take advantage of tcp autotuningOlga Kornievskaia
Allow the NFSv4 server to make use of TCP autotuning behaviour, which was previously disabled by setting the sk_userlocks variable. Set the receive buffers to be big enough to receive the whole RPC request, and set this for the listening socket, not the accept socket. Remove the code that readjusts the receive/send buffer sizes for the accepted socket. Previously this code was used to influence the TCP window management behaviour, which is no longer needed when autotuning is enabled. This can improve IO bandwidth on networks with high bandwidth-delay products, where a large tcp window is required. It also simplifies performance tuning, since getting adequate tcp buffers previously required increasing the number of nfsd threads. Signed-off-by: Olga Kornievskaia <aglo@citi.umich.edu> Cc: Jim Rees <rees@umich.edu> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2011-04-07SUNRPC: Don't wait for full record to receive tcp dataJ. Bruce Fields
Ensure that we immediately read and buffer data from the incoming TCP stream so that we grow the receive window quickly, and don't deadlock on large READ or WRITE requests. Also do some minor exit cleanup. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-04-07svcrpc: copy cb reply instead of pagesTrond Myklebust
It's much simpler just to copy the cb reply data than to play tricks with pages. Callback replies will typically be very small (at least until we implement cb_getattr, in which case files with very long ACLs could pose a problem), so there's no loss in efficiency. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-04-07svcrpc: close connection if client sends short packetJ. Bruce Fields
If the client sents a record too short to contain even the beginning of the rpc header, then just close the connection. The current code drops the record data and continues. I don't see the point. It's a hopeless situation and simpler just to cut off the connection completely. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-04-07svcrpc: note network-order types in svc_process_calldirJ. Bruce Fields
2011-04-07SUNRPC: svc_tcp_recvfrom cleanupTrond Myklebust
Minor cleanup in preparation for later patches. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-04-07SUNRPC: requeue tcp socket less frequentlyTrond Myklebust
Don't requeue the socket in some cases where we know it's unnecessary. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-02-22net: add __rcu annotations to sk_wq and wqEric Dumazet
Add proper RCU annotations/verbs to sk_wq and wq members Fix __sctp_write_space() sk_sleep() abuse (and sock->wq access) Fix sunrpc sk_sleep() abuse too Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-25NFS do not find client in NFSv4 pg_authenticateAndy Adamson
The information required to find the nfs_client cooresponding to the incoming back channel request is contained in the NFS layer. Perform minimal checking in the RPC layer pg_authenticate method, and push more detailed checking into the NFS layer where the nfs_client can be found. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-01-14Merge branch 'for-2.6.38' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.38' of git://linux-nfs.org/~bfields/linux: (62 commits) nfsd4: fix callback restarting nfsd: break lease on unlink, link, and rename nfsd4: break lease on nfsd setattr nfsd: don't support msnfs export option nfsd4: initialize cb_per_client nfsd4: allow restarting callbacks nfsd4: simplify nfsd4_cb_prepare nfsd4: give out delegations more quickly in 4.1 case nfsd4: add helper function to run callbacks nfsd4: make sure sequence flags are set after destroy_session nfsd4: re-probe callback on connection loss nfsd4: set sequence flag when backchannel is down nfsd4: keep finer-grained callback status rpc: allow xprt_class->setup to return a preexisting xprt rpc: keep backchannel xprt as long as server connection rpc: move sk_bc_xprt to svc_xprt nfsd4: allow backchannel recovery nfsd4: support BIND_CONN_TO_SESSION nfsd4: modify session list under cl_lock Documentation: fl_mylease no longer exists ... Fix up conflicts in fs/nfsd/vfs.c with the vfs-scale work. The vfs-scale work touched some msnfs cases, and this merge removes support for that entirely, so the conflict was trivial to resolve.
2011-01-11rpc: move sk_bc_xprt to svc_xprtJ. Bruce Fields
This seems obviously transport-level information even if it's currently used only by the server socket code. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-01-06NFS rename client back channel transport fieldAndy Adamson
Differentiate from server backchannel Signed-off-by: Andy Adamson <andros@netapp.com> Acked-by: Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-01-06NFS associate sessionid with callback connectionAndy Adamson
The sessions based callback service is started prior to the CREATE_SESSION call so that it can handle CB_NULL requests which can be sent before the CREATE_SESSION call returns and the session ID is known. Set the callback sessionid after a sucessful CREATE_SESSION. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-01-06SUNRPC register and unregister the back channel transportAndy Adamson
2011-01-06SUNRPC new transport for the NFSv4.1 shared back channelAndy Adamson
Move the current sock create and destroy routines into the new transport ops. Back channel socket will be destroyed by the svc_closs_all call in svc_destroy. Added check: only TCP supported on shared back channel. Signed-off-by: Andy Adamson <andros@netapp.com> Acked-by: Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-17sunrpc: svc_sock_names should hold ref to socket being closed.NeilBrown
Currently svc_sock_names calls svc_close_xprt on a svc_sock to which it does not own a reference. As soon as svc_close_xprt sets XPT_CLOSE, the socket could be freed by a separate thread (though this is a very unlikely race). It is safer to hold a reference while calling svc_close_xprt. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-10-25svcrpc: svc_tcp_sendto XPT_DEAD check is redundantJ. Bruce Fields
The only caller (svc_send) has already checked XPT_DEAD. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-10-19sunrpc: Turn list_for_each-s into the ..._entry-sPavel Emelyanov
Saves some lines of code and some branticks when reading one. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-10-01sunrpc: Create sockets in net namespacesPavel Emelyanov
The context is already known in all the sock_create callers. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-10-01sunrpc: Pull net argument downto svc_create_socketPavel Emelyanov
After this the socket creation in it knows the context. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1674 commits) qlcnic: adding co maintainer ixgbe: add support for active DA cables ixgbe: dcb, do not tag tc_prio_control frames ixgbe: fix ixgbe_tx_is_paused logic ixgbe: always enable vlan strip/insert when DCB is enabled ixgbe: remove some redundant code in setting FCoE FIP filter ixgbe: fix wrong offset to fc_frame_header in ixgbe_fcoe_ddp ixgbe: fix header len when unsplit packet overflows to data buffer ipv6: Never schedule DAD timer on dead address ipv6: Use POSTDAD state ipv6: Use state_lock to protect ifa state ipv6: Replace inet6_ifaddr->dead with state cxgb4: notify upper drivers if the device is already up when they load cxgb4: keep interrupts available when the ports are brought down cxgb4: fix initial addition of MAC address cnic: Return SPQ credit to bnx2x after ring setup and shutdown. cnic: Convert cnic_local_flags to atomic ops. can: Fix SJA1000 command register writes on SMP systems bridge: fix build for CONFIG_SYSFS disabled ARCNET: Limit com20020 PCI ID matches for SOHARD cards ... Fix up various conflicts with pcmcia tree drivers/net/ {pcmcia/3c589_cs.c, wireless/orinoco/orinoco_cs.c and wireless/orinoco/spectrum_cs.c} and feature removal (Documentation/feature-removal-schedule.txt). Also fix a non-content conflict due to pm_qos_requirement getting renamed in the PM tree (now pm_qos_request) in net/mac80211/scan.c
2010-05-17net: Remove unnecessary returns from void function()sJoe Perches
This patch removes from net/ (but not any netfilter files) all the unnecessary return; statements that precede the last closing brace of void functions. It does not remove the returns that are immediately preceded by a label as gcc doesn't like that. Done via: $ grep -rP --include=*.[ch] -l "return;\n}" net/ | \ xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }' Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-03sunrpc: centralise most calls to svc_xprt_receivedNeil Brown
svc_xprt_received must be called when ->xpo_recvfrom has finished receiving a message, so that the XPT_BUSY flag will be cleared and if necessary, requeued for further work. This call is currently made in each ->xpo_recvfrom function, often from multiple different points. In each case it is the earliest point on a particular path where it is known that the protection provided by XPT_BUSY is no longer needed. However there are (still) some error paths which do not call svc_xprt_received, and requiring each ->xpo_recvfrom to make the call does not encourage robustness. So: move the svc_xprt_received call to be made just after the call to ->xpo_recvfrom(), and move it of the various ->xpo_recvfrom methods. This means that it may not be called at the earliest possible instant, but this is unlikely to be a measurable performance issue. Note that there are still other calls to svc_xprt_received as it is also needed when an xprt is newly created. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2010-04-20net: sk_sleep() helperEric Dumazet
Define a new function to return the waitqueue of a "struct sock". static inline wait_queue_head_t *sk_sleep(struct sock *sk) { return sk->sk_sleep; } Change all read occurrences of sk_sleep by a call to this function. Needed for a future RCU conversion. sk_sleep wont be a field directly available. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-28nfsd: ensure sockets are closed on errorNeil Brown
One the changes in commit d7979ae4a "svc: Move close processing to a single place" is: err_delete: - svc_delete_socket(svsk); + set_bit(SK_CLOSE, &svsk->sk_flags); return -EAGAIN; This is insufficient. The recvfrom methods must always call svc_xprt_received on completion so that the socket gets re-queued if there is any more work to do. This particular path did not make that call because it actually destroyed the svsk, making requeue pointless. When the svc_delete_socket was change to just set a bit, we should have added a call to svc_xprt_received, This is the problem that b0401d7253 attempted to fix, incorrectly. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2010-01-26NFSD: Support AF_INET6 in svc_addsock() functionAime Le Rouzic
Relax the address family check at the top of svc_addsock() to allow AF_INET6 listener sockets to be specified via /proc/fs/nfsd/portlist. Signed-off-by: Aime Le Rouzic <aime.le-rouzic@bull.net> Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-11-06Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/usb/cdc_ether.c All CDC ethernet devices of type USB_CLASS_COMM need to use '&mbm_info'. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-30net: fix sk_forward_alloc corruptionEric Dumazet
On UDP sockets, we must call skb_free_datagram() with socket locked, or risk sk_forward_alloc corruption. This requirement is not respected in SUNRPC. Add a convenient helper, skb_free_datagram_locked() and use it in SUNRPC Reported-by: Francis Moreau <francis.moro@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-18inet: rename some inet_sock fieldsEric Dumazet
In order to have better cache layouts of struct sock (separate zones for rx/tx paths), we need this preliminary patch. Goal is to transfert fields used at lookup time in the first read-mostly cache line (inside struct sock_common) and move sk_refcnt to a separate cache line (only written by rx path) This patch adds inet_ prefix to daddr, rcv_saddr, dport, num, saddr, sport and id fields. This allows a future patch to define these fields as macros, like sk_refcnt, without name clashes. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-11nfsd41: sunrpc: Added rpc server-side backchannel handlingRahul Iyer
When the call direction is a reply, copy the xid and call direction into the req->rq_private_buf.head[0].iov_base otherwise rpc_verify_header returns rpc_garbage. Signed-off-by: Rahul Iyer <iyer@netapp.com> Signed-off-by: Mike Sager <sager@netapp.com> Signed-off-by: Marc Eshel <eshel@almaden.ibm.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [get rid of CONFIG_NFSD_V4_1] [sunrpc: refactoring of svc_tcp_recvfrom] [nfsd41: sunrpc: create common send routine for the fore and the back channels] [nfsd41: sunrpc: Use free_page() to free server backchannel pages] [nfsd41: sunrpc: Document server backchannel locking] [nfsd41: sunrpc: remove bc_connect_worker()] [nfsd41: sunrpc: Define xprt_server_backchannel()[ [nfsd41: sunrpc: remove bc_close and bc_init_auto_disconnect dummy functions] [nfsd41: sunrpc: eliminate unneeded switch statement in xs_setup_tcp()] [nfsd41: sunrpc: Don't auto close the server backchannel connection] [nfsd41: sunrpc: Remove unused functions] Signed-off-by: Alexandros Batsakis <batsakis@netapp.com> Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfsd41: change bc_sock to bc_xprt] [nfsd41: sunrpc: move struct rpc_buffer def into a common header file] [nfsd41: sunrpc: use rpc_sleep in bc_send_request so not to block on mutex] [removed cosmetic changes] Signed-off-by: Benny Halevy <bhalevy@panasas.com> [sunrpc: add new xprt class for nfsv4.1 backchannel] [sunrpc: v2.1 change handling of auto_close and init_auto_disconnect operations for the nfsv4.1 backchannel] Signed-off-by: Alexandros Batsakis <batsakis@netapp.com> [reverted more cosmetic leftovers] [got rid of xprt_server_backchannel] [separated "nfsd41: sunrpc: add new xprt class for nfsv4.1 backchannel"] Signed-off-by: Benny Halevy <bhalevy@panasas.com> Cc: Trond Myklebust <trond.myklebust@netapp.com> [sunrpc: change idle timeout value for the backchannel] Signed-off-by: Alexandros Batsakis <batsakis@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Acked-by: Trond Myklebust <trond.myklebust@netapp.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-08-24nfsd41: sunrpc: svc_tcp_recv_record()Alexandros Batsakis
Factor functionality out of svc_tcp_recvfrom() to simplify routine Signed-off-by: Alexandros Batsakis <batsakis@netapp.com> Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-07-14SUNRPC: handle IPv6 PKTINFO when extracting destination addressChuck Lever
PKTINFO is needed to scrape the caller's IP address off the socket so RPC datagram replies are routed correctly. Fill in missing pieces in the kernel RPC server's UDP receive path to request IPv6 PKTINFO and correctly parse the IPv6 cmsg header. Without this patch, kernel RPC services drop all incoming requests on UDP on IPv6. Related commit: 7a37f5787e76bf1765c1add3a9a7163f841a28bb Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Cc: Neil Brown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-06-22Merge branch 'for-2.6.31' of git://fieldses.org/git/linux-nfsdLinus Torvalds
* 'for-2.6.31' of git://fieldses.org/git/linux-nfsd: (60 commits) SUNRPC: Fix the TCP server's send buffer accounting nfsd41: Backchannel: minorversion support for the back channel nfsd41: Backchannel: cleanup nfs4.0 callback encode routines nfsd41: Remove ip address collision detection case nfsd: optimise the starting of zero threads when none are running. nfsd: don't take nfsd_mutex twice when setting number of threads. nfsd41: sanity check client drc maxreqs nfsd41: move channel attributes from nfsd4_session to a nfsd4_channel_attr struct NFS: kill off complicated macro 'PROC' sunrpc: potential memory leak in function rdma_read_xdr nfsd: minor nfsd_vfs_write cleanup nfsd: Pull write-gathering code out of nfsd_vfs_write nfsd: track last inode only in use_wgather case sunrpc: align cache_clean work's timer nfsd: Use write gathering only with NFSv2 NFSv4: kill off complicated macro 'PROC' NFSv4: do exact check about attribute specified knfsd: remove unreported filehandle stats counters knfsd: fix reply cache memory corruption knfsd: reply cache cleanups ...
2009-06-18SUNRPC: Fix the TCP server's send buffer accountingTrond Myklebust
Currently, the sunrpc server is refusing to allow us to process new RPC calls if the TCP send buffer is 2/3 full, even if we do actually have enough free space to guarantee that we can send another request. The following patch fixes svc_tcp_has_wspace() so that we only stop processing requests if we know that the socket buffer cannot possibly fit another reply. It also fixes the tcp write_space() callback so that we only clear the SOCK_NOSPACE flag when the TCP send buffer is less than 2/3 full. This should ensure that the send window will grow as per the standard TCP socket code. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-06-17nfs41: sunrpc: provide functions to create and destroy a svc_xprt for ↵Benny Halevy
backchannel use For nfs41 callbacks we need an svc_xprt to process requests coming up the backchannel socket as rpc_rqst's that are transformed into svc_rqst's that need a rq_xprt to be processed. The svc_{udp,tcp}_create methods are too heavy for this job as svc_create_socket creates an actual socket to listen on while for nfs41 we're "reusing" the fore channel's socket. Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2009-06-15Merge commit 'v2.6.30' into for-2.6.31J. Bruce Fields
2009-05-27nfsd: Revert "svcrpc: take advantage of tcp autotuning"J. Bruce Fields
This reverts commit 47a14ef1af48c696b214ac168f056ddc79793d0e "svcrpc: take advantage of tcp autotuning", which uncovered some further problems in the server rpc code, causing significant performance regressions in common cases. We will likely reinstate this patch after releasing 2.6.30 and applying some work on the underlying fixes to the problem (developed by Trond). Reported-by: Jeff Moyer <jmoyer@redhat.com> Cc: Olga Kornievskaia <aglo@citi.umich.edu> Cc: Jim Rees <rees@umich.edu> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-04-28SUNRPC: Clean up one_sock_name()Chuck Lever
Clean up svc_one_sock_name() by setting up automatic variables for frequently used expressions. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-04-28SUNRPC: Support PF_INET6 in one_sock_name()Chuck Lever
Add an arm to the switch statement in svc_one_sock_name() so it can construct the name of PF_INET6 sockets properly. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Cc: Aime Le Rouzic <aime.le-rouzic@bull.net> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-04-28SUNRPC: Switch one_sock_name() to use snprintf()Chuck Lever
Use snprintf() in one_sock_name() to prevent overflowing the output buffer. If the name doesn't fit in the buffer, the buffer is filled in with an empty string, and -ENAMETOOLONG is returned. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-04-28SUNRPC: pass buffer size to svc_sock_names()Chuck Lever
Adjust the synopsis of svc_sock_names() to pass in the size of the output buffer. Add a documenting comment. This is a cosmetic change for now. A subsequent patch will make sure the buffer length is passed to one_sock_name(), where the length will actually be useful. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-04-28SUNRPC: pass buffer size to svc_addsock()Chuck Lever
Adjust the synopsis of svc_addsock() to pass in the size of the output buffer. Add a documenting comment. This is a cosmetic change for now. A subsequent patch will make sure the buffer length is passed to one_sock_name(), where the length will actually be useful. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-04-28SUNRPC: Fix error return value of svc_addr_len()Chuck Lever
The svc_addr_len() helper function returns -EAFNOSUPPORT if it doesn't recognize the address family of the passed-in socket address. However, the return type of this function is size_t, which means -EAFNOSUPPORT is turned into a very large positive value in this case. The check in svc_udp_recvfrom() to see if the return value is less than zero therefore won't work at all. Additionally, handle_connect_req() passes this value directly to memset(). This could cause memset() to clobber a large chunk of memory if svc_addr_len() has returned an error. Currently the address family of these addresses, however, is known to be supported long before handle_connect_req() is called, so this isn't a real risk. Change the error return value of svc_addr_len() to zero, which fits in the range of size_t, and is safer to pass to memset() directly. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-04-06Merge branch 'for-2.6.30' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.30' of git://linux-nfs.org/~bfields/linux: (81 commits) nfsd41: define nfsd4_set_statp as noop for !CONFIG_NFSD_V4 nfsd41: define NFSD_DRC_SIZE_SHIFT in set_max_drc nfsd41: Documentation/filesystems/nfs41-server.txt nfsd41: CREATE_EXCLUSIVE4_1 nfsd41: SUPPATTR_EXCLCREAT attribute nfsd41: support for 3-word long attribute bitmask nfsd: dynamically skip encoded fattr bitmap in _nfsd4_verify nfsd41: pass writable attrs mask to nfsd4_decode_fattr nfsd41: provide support for minor version 1 at rpc level nfsd41: control nfsv4.1 svc via /proc/fs/nfsd/versions nfsd41: add OPEN4_SHARE_ACCESS_WANT nfs4_stateid bmap nfsd41: access_valid nfsd41: clientid handling nfsd41: check encode size for sessions maxresponse cached nfsd41: stateid handling nfsd: pass nfsd4_compound_state* to nfs4_preprocess_{state,seq}id_op nfsd41: destroy_session operation nfsd41: non-page DRC for solo sequence responses nfsd41: Add a create session replay cache nfsd41: create_session operation ...
2009-04-01SUNRPC: Ensure IPV6_V6ONLY is set on the socket before binding to a portTrond Myklebust
Also ensure that we use the protocol family instead of the address family when calling sock_create_kern(). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-28SUNRPC: Set IPV6ONLY flag on PF_INET6 RPC listener socketsChuck Lever
We are about to convert to using separate RPC listener sockets for PF_INET and PF_INET6. This echoes the way IPv6 is handled in user space by TI-RPC, and eliminates the need for ULPs to worry about mapped IPv4 AF_INET6 addresses when doing address comparisons. Start by setting the IPV6ONLY flag on PF_INET6 RPC listener sockets. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
