commit bf118a342f10dafe44b14451a1392c3254629a1f upstream.
The NFSv4 bitmap size is unbounded: a server can return an arbitrary
sized bitmap in an FATTR4_WORD0_ACL request. Replace using the
nfs4_fattr_bitmap_maxsz as a guess to the maximum bitmask returned by a server
with the inclusion of the bitmap (xdr length plus bitmasks) and the acl data
xdr length to the (cached) acl page data.
This is a general solution to commit e5012d1f "NFSv4.1: update
nfs4_fattr_bitmap_maxsz" and fixes hitting a BUG_ON in xdr_shrink_bufhead
when getting ACLs.
Fix a bug in decode_getacl that returned -EINVAL on ACLs > page when getxattr
was called with a NULL buffer, preventing ACL > PAGE_SIZE from being retrieved.
Signed-off-by: Andy Adamson <andros@netapp.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Ensure that the backchannel exports conform to the existing sunrpc
practice.
Initialize xdr_stream and xdr_buf using an array of page pointers
and length of buffer.
Signed-off-by: Benny Halevy <bhalevy@panasas.com>
vm_map_ram() is not available on NOMMU platforms, and causes trouble
on incoherrent architectures such as ARM when we access the page data
through both the direct and the virtual mapping.
The alternative is to use the direct mapping to access page data
for the case when we are not crossing a page boundary, but to copy
the data into a linear scratch buffer when we are accessing data
that spans page boundaries.
Tested-by: Marc Kleine-Budde <mkl@pengutronix.de>
Cc: stable@kernel.org [2.6.37]
We sometimes need to be able to read ahead in an xdr_stream without
incrementing the current pointer position.
Clean up: Introduce a helper to '\0'-terminate XDR strings
that are placed in a page in the page cache.
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
If we have unused buffer space, then we should make use of that rather
than unnecessarily truncating the message.
The "copy" variable value can be computed using the existing
logic rather than repeating it.
to clean up the code "copy" will be set prior to the block
hence it mustn't be used there.
char *p is used only as a shorthand for tail->iov_base + len in a nested
block. Move it there.
On Jan. 14, 2009, 2:50 +0200, andros@netapp.com wrote:
> From: Andy Adamson <andros@netapp.com>
> The buflen is reset for all cases at the end of xdr_shrink_pagelen.
> The data left in the tail after xdr_read_pages is not processed when the
> buflen is incorrectly set.
Note that in this case we also lose (len - tail->iov_len)
bytes from the buffered data in pages.
Reported-by: Andy Adamson <andros@netapp.com>
Signed-off-by: Kevin Coffman <kwc@citi.umich.edu>
Signed-off-by: Steve Dickson <steved@redhat.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
ntohl is already defined as be32_to_cpu.
be64_to_cpu has architecture specific optimized implementations.
htonl is already defined as cpu_to_be32.
cpu_to_be64 has architecture specific optimized implementations.
We've never considered the sunrpc code as part of any ABI to be used by
out-of-tree modules.
Fix a problem in _copy_to_pages(), whereby it may call flush_dcache_page()
with an invalid pointer due to the fact that 'pgto' gets incremented
beyond the end of the page array. Fix is to exit the loop without this
unnecessary increment of pgto.
XDR strings, opaques, and net objects should all use unsigned lengths.
To wit, RFC 4506 says:
4.2. Unsigned Integer
An XDR unsigned integer is a 32-bit datum that encodes a non-negative
integer in the range [0,4294967295].
4.11. String
The standard defines a string of n (numbered 0 through n-1) ASCII
bytes to be the number n encoded as an unsigned integer (as described
above), and followed by the n bytes of the string.
After this patch, xdr_decode_string_inplace now matches the other XDR
string and array helpers that take a string length argument. See:
xdr_encode_opaque_fixed, xdr_encode_opaque, xdr_encode_array
Acked-By: NeilBrown <neilb@suse.de>
Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
Do this for all RPC client related functions and XDR functions.
This patch fixes the errors made in the users of the crypto layer during
the sg_init_table conversion. It also adds a few conversions that were
missing altogether.
Most drivers need to set length and offset as well, so may as well fold
those three lines into one.
Add sg_assign_page() for those two locations that only needed to set
the page, where the offset/length is set outside of the function context.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Since process_xdr_buf() is useful outside of the kerberos-specific code, we
move it to net/sunrpc/xdr.c, export it, and rename it in keeping with xdr_*
naming convention of xdr.c.
Also clean up the code...
Converts various integer buffer offsets and sizes to unsigned integer.
pure s/u32/__be32/
[AV: large part based on Alexey's patches]
* the client is ia64 or any platform that actually implements
flush_dcache_page(), and
* the server returns fsinfo.dtpref >= client's PAGE_SIZE, and
* the server does *not* return post-op attributes for the directory
in the READDIR reply.
Problem diagnosed by Greg Banks <gnb@melbourne.sgi.com>
This patch removes ths unused function xdr_decode_string().
Acked-by: Neil Brown <neilb@suse.de>
Acked-by: Charles Lever <Charles.Lever@netapp.com>
This is the net/ part of the big kfree cleanup patch.
Remove pointless checks for NULL prior to calling kfree() in net/.
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
Cc: Arnaldo Carvalho de Melo <acme@conectiva.com.br>
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Move the bulk of client-side socket-specific code into a separate source
file, net/sunrpc/xprtsock.c.
Test-plan:
Millions of fsx operations. Performance characterization such as "sio" or
"iozone". Destructive testing (unplugging the network temporarily, server
reboots). Connectathon with v2, v3, and v4.
Version: Thu, 11 Aug 2005 16:03:38 -0400
Signed-off-by: Chuck Lever <cel@netapp.com>
Clean-up: Move some code that is common to both RPC client- and server-side
socket transports into its own source file, net/sunrpc/socklib.c.
Test-plan:
Compile kernel with CONFIG_NFS enabled. Millions of fsx operations over
UDP, client and server. Connectathon over UDP.
Version: Thu, 11 Aug 2005 16:03:09 -0400
Signed-off-by: Andreas Gruenbacher <agruen@suse.de>
Acked-by: Olaf Kirch <okir@suse.de>
Signed-off-by: Olaf Kirch <okir@suse.de>
Fix up call_header() so that it calls xdr_adjust_iovec().
Fix calculation of the scratch buffer length in xdr_init_encode().
I have recompiled Linux kernel 2.6.11.5 documentation for me and our
university students again. The documentation could be extended for more
sources which are equipped by structured comments for recent 2.6 kernels. I
have tried to proceed with that task. I have done that more times from 2.6.0
time and it gets boring to do same changes again and again. Linux kernel
compiles after changes for i386 and ARM targets. I have added references to
some more files into kernel-api book, I have added some section names as well.
So please, check that changes do not break something and that categories are
not too much skewed.
I have changed kernel-doc to accept "fastcall" and "asmlinkage" words reserved
by kernel convention. Most of the other changes are modifications in the
comments to make kernel-doc happy, accept some parameters description and do
not bail out on errors. Changed <pid> to @pid in the description, moved some
#ifdef before comments to correct function to comments bindings, etc.
You can see result of the modified documentation build at
http://cmp.felk.cvut.cz/~pisa/linux/lkdb-2.6.11.tar.gz
Some more sources are ready to be included into kernel-doc generated
documentation. Sources has been added into kernel-api for now. Some more
section names added and probably some more chaos introduced as result of quick
cleanup work.
Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz>
Signed-off-by: Martin Waitz <tali@admingilde.org>
infrastructure for it.
Let it rip!
