[ Upstream commit e95584a889e1902fdf1ded9712e2c3c3083baf96 ]
We have identified a problem with the "oversubscription" policy in the
link transmission code.
When small messages are transmitted, and the sending link has reached
the transmit window limit, those messages will be bundled and put into
the link backlog queue. However, bundles of data messages are counted
at the 'CRITICAL' level, so that the counter for that level, instead of
the counter for the real, bundled message's level is the one being
increased.
Subsequent, to-be-bundled data messages at non-CRITICAL levels continue
to be tested against the unchanged counter for their own level, while
contributing to an unrestrained increase at the CRITICAL backlog level.
This leaves a gap in congestion control algorithm for small messages
that can result in starvation for other users or a "real" CRITICAL
user. Even that eventually can lead to buffer exhaustion & link reset.
We fix this by keeping a 'target_bskb' buffer pointer at each levels,
then when bundling, we only bundle messages at the same importance
level only. This way, we know exactly how many slots a certain level
have occupied in the queue, so can manage level congestion accurately.
By bundling messages at the same level, we even have more benefits. Let
consider this:
- One socket sends 64-byte messages at the 'CRITICAL' level;
- Another sends 4096-byte messages at the 'LOW' level;
When a 64-byte message comes and is bundled the first time, we put the
overhead of message bundle to it (+ 40-byte header, data copy, etc.)
for later use, but the next message can be a 4096-byte one that cannot
be bundled to the previous one. This means the last bundle carries only
one payload message which is totally inefficient, as for the receiver
also! Later on, another 64-byte message comes, now we make a new bundle
and the same story repeats...
With the new bundling algorithm, this will not happen, the 64-byte
messages will be bundled together even when the 4096-byte message(s)
comes in between. However, if the 4096-byte messages are sent at the
same level i.e. 'CRITICAL', the bundling algorithm will again cause the
same overhead.
Also, the same will happen even with only one socket sending small
messages at a rate close to the link transmit's one, so that, when one
message is bundled, it's transmitted shortly. Then, another message
comes, a new bundle is created and so on...
We will solve this issue radically by another patch.
Fixes: 365ad353c256 ("tipc: reduce risk of user starvation during link congestion")
Reported-by: Hoang Le <hoang.h.le@dektech.com.au>
Acked-by: Jon Maloy <jon.maloy@ericsson.com>
Signed-off-by: Tuong Lien <tuong.t.lien@dektech.com.au>
When a bundling message is received, the function tipc_link_input()
calls function tipc_msg_extract() to unbundle all inner messages of
the bundling message before adding them to input queue.
The function tipc_msg_extract() just clones all inner skb for all
inner messagges from the bundling skb. This means that the skb
headroom of an inner message overlaps with the data part of the
preceding message in the bundle.
If the message in question is a name addressed message, it may be
subject to a secondary destination lookup, and eventually be sent out
on one of the interfaces again. But, since what is perceived as headroom
by the device driver in reality is the last bytes of the preceding
message in the bundle, the latter will be overwritten by the MAC
addresses of the L2 header. If the preceding message has not yet been
consumed by the user, it will evenually be delivered with corrupted
contents.
This commit fixes this by uncloning all messages passing through the
function tipc_msg_lookup_dest(), hence ensuring that the headroom
is always valid when the message is passed on.
Signed-off-by: Tung Nguyen <tung.q.nguyen@dektech.com.au>
Signed-off-by: Jon Maloy <jon.maloy@ericsson.com>
In commit e3a77561e7d32 ("tipc: split up function tipc_msg_eval()"),
we have updated the function tipc_msg_lookup_dest() to set the error
codes to negative values at destination lookup failures. Thus when
the function sets the error code to -TIPC_ERR_NO_NAME, its inserted
into the 4 bit error field of the message header as 0xf instead of
TIPC_ERR_NO_NAME (1). The value 0xf is an unknown error code.
In this commit, we set only positive error code.
Fixes: e3a77561e7d32 ("tipc: split up function tipc_msg_eval()")
Signed-off-by: Parthasarathy Bhuvaragan <parthasarathy.bhuvaragan@ericsson.com>
In tipc_msg_reverse(), we assign skb attributes to local pointers
in stack at startup. This is followed by skb_linearize() and for
cloned buffers we perform skb relocation using pskb_expand_head().
Both these methods may update the skb attributes and thus making
the pointers incorrect.
In this commit, we fix this error by ensuring that the pointers
are re-assigned after any of these skb operations.
Fixes: 29042e19f2c60 ("tipc: let function tipc_msg_reverse() expand header
when needed")
Reviewed-by: Jon Maloy <jon.maloy@ericsson.com>
In the function msg_reverse(), we reverse the header while trying to
reuse the original buffer whenever possible. Those rejected/returned
messages are always transmitted as unicast, but the msg_non_seq field
is not explicitly set to zero as it should be.
We have seen cases where multicast senders set the message type to
"NOT dest_droppable", meaning that a multicast message shorter than
one MTU will be returned, e.g., during receive buffer overflow, by
reusing the original buffer. This has the effect that even the
'msg_non_seq' field is inadvertently inherited by the rejected message,
although it is now sent as a unicast message. This again leads the
receiving unicast link endpoint to steer the packet toward the broadcast
link receive function, where it is dropped. The affected unicast link is
thereafter (after 100 failed retransmissions) declared 'stale' and
reset.
We fix this by unconditionally setting the 'msg_non_seq' flag to zero
for all rejected/returned messages.
Reported-by: Canh Duc Luu <canh.d.luu@dektech.com.au>
The kernel may sleep under a rcu read lock in tipc_msg_reverse, and the
function call path is:
tipc_l2_rcv_msg (acquire the lock by rcu_read_lock)
tipc_rcv
tipc_sk_rcv
tipc_msg_reverse
pskb_expand_head(GFP_KERNEL) --> may sleep
tipc_node_broadcast
tipc_node_xmit_skb
tipc_node_xmit
tipc_sk_rcv
tipc_msg_reverse
To fix it, "GFP_KERNEL" is replaced with "GFP_ATOMIC".
Signed-off-by: Jia-Ju Bai <baijiaju1990@163.com>
TIPC multicast messages are currently carried over a reliable
'broadcast link', making use of the underlying media's ability to
transport packets as L2 broadcast or IP multicast to all nodes in
the cluster.
When the used bearer is lacking that ability, we can instead emulate
the broadcast service by replicating and sending the packets over as
many unicast links as needed to reach all identified destinations.
We now introduce a new TIPC link-level 'replicast' service that does
this.
Reviewed-by: Parthasarathy Bhuvaragan <parthasarathy.bhuvaragan@ericsson.com>
Acked-by: Ying Xue <ying.xue@windriver.com>
Until now, we allocate memory always with GFP_ATOMIC flag.
When the system is under memory pressure and a user tries to send,
the send fails due to low memory. However, the user application
can wait for free memory if we allocate it using GFP_KERNEL flag.
In this commit, we use allocate memory with GFP_KERNEL for all user
allocation.
Reported-by: Rune Torgersen <runet@innovsys.com>
copy_from_iter_full(), copy_from_iter_full_nocache() and
csum_and_copy_from_iter_full() - counterparts of copy_from_iter()
et.al., advancing iterator only in case of successful full copy
and returning whether it had been successful or not.
Convert some obvious users. *NOTE* - do not blindly assume that
something is a good candidate for those unless you are sure that
not advancing iov_iter in failure case is the right thing in
this case. Anything that does short read/short write kind of
stuff (or is in a loop, etc.) is unlikely to be a good one.
When extracting an individual message from a received "bundle" buffer,
we just create a clone of the base buffer, and adjust it to point into
the right position of the linearized data area of the latter. This works
well for regular message reception, but during periods of extremely high
load it may happen that an extracted buffer, e.g, a connection probe, is
reversed and forwarded through an external interface while the preceding
extracted message is still unhandled. When this happens, the header or
data area of the preceding message will be partially overwritten by a
MAC header, leading to unpredicatable consequences, such as a link
reset.
We now fix this by ensuring that the msg_reverse() function never
returns a cloned buffer, and that the returned buffer always contains
sufficient valid head and tail room to be forwarded.
Reported-by: Erik Hugne <erik.hugne@gmail.com>
The code path for receiving broadcast packets is currently distinct
from the unicast path. This leads to unnecessary code and data
duplication, something that can be avoided with some effort.
We now introduce separate per-peer tipc_link instances for handling
broadcast packet reception. Each receive link keeps a pointer to the
common, single, broadcast link instance, and can hence handle release
and retransmission of send buffers as if they belonged to the own
instance.
Furthermore, we let each unicast link instance keep a reference to both
the pertaining broadcast receive link, and to the common send link.
This makes it possible for the unicast links to easily access data for
broadcast link synchronization, as well as for carrying acknowledges for
received broadcast packets.
Reviewed-by: Ying Xue <ying.xue@windriver.com>
This commit simplifies the broadcast link transmission function, by
leveraging previous changes to the link transmission function and the
broadcast transmission link life cycle.
net/ipv6/xfrm6_output.c
net/openvswitch/flow_netlink.c
net/openvswitch/vport-gre.c
net/openvswitch/vport-vxlan.c
net/openvswitch/vport.c
net/openvswitch/vport.h
The openvswitch conflicts were overlapping changes. One was
the egress tunnel info fix in 'net' and the other was the
vport ->send() op simplification in 'net-next'.
The xfrm6_output.c conflicts was also a simplification
overlapping a bug fix.
The current code for message reassembly is erroneously assuming that
the the first arriving fragment buffer always is linear, and then goes
ahead resetting the fragment list of that buffer in anticipation of
more arriving fragments.
However, if the buffer already happens to be non-linear, we will
inadvertently drop the already attached fragment list, and later
on trig a BUG() in __pskb_pull_tail().
We see this happen when running fragmented TIPC multicast across UDP,
something made possible since
commit d0f91938bede ("tipc: add ip/udp media type")
We fix this by not resetting the fragment list when the buffer is non-
linear, and by initiatlizing our private fragment list tail pointer to
the tail of the existing fragment list.
Fixes: commit d0f91938bede ("tipc: add ip/udp media type")
After the previous commits, we are guaranteed that no packets
of type LINK_PROTOCOL or with illegal sequence numbers will be
attempted added to the link deferred queue. This makes it possible to
make some simplifications to the sorting algorithm in the function
tipc_skb_queue_sorted().
We also alter the function so that it will drop packets if one with
the same seqeunce number is already present in the queue. This is
necessary because we have identified weird packet sequences, involving
duplicate packets, where a legitimate in-sequence packet may advance to
the head of the queue without being detected and de-queued.
Finally, we make this function outline, since it will now be called only
in exceptional cases.
The msg pointer into header may change after skb linearization.
We must reinitialize it after calling skb_linearize to prevent
operating on a freed or invalid pointer.
Signed-off-by: Erik Hugne <erik.hugne@ericsson.com>
Reported-by: Tamás Végh <tamas.vegh@ericsson.com>
When a message is received in a socket, one of the call chains
tipc_sk_rcv()->tipc_sk_enqueue()->filter_rcv()(->tipc_sk_proto_rcv())
or
tipc_sk_backlog_rcv()->filter_rcv()(->tipc_sk_proto_rcv())
are followed. At each of these levels we may encounter situations
where the message may need to be rejected, or a new message
produced for transfer back to the sender. Despite recent
improvements, the current code for doing this is perceived
as awkward and hard to follow.
Leveraging the two previous commits in this series, we now
introduce a more uniform handling of such situations. We
let each of the functions in the chain itself produce/reverse
the message to be returned to the sender, but also perform the
actual forwarding. This simplifies the necessary logics within
each function.
Currently, we use the code sequence
if (msg_reverse())
tipc_link_xmit_skb()
at numerous locations in socket.c. The preparation of arguments
for these calls, as well as the sequence itself, makes the code
unecessarily complex.
In this commit, we introduce a new function, tipc_sk_respond(),
that performs this call combination. We also replace some, but not
yet all, of these explicit call sequences with calls to the new
function. Notably, we let the function tipc_sk_proto_rcv() use
the new function to directly send out PROBE_REPLY messages,
instead of deferring this to the calling tipc_sk_rcv() function,
as we do now.
The shortest TIPC message header, for cluster local CONNECTED messages,
is 24 bytes long. With this format, the fields "dest_node" and
"orig_node" are optimized away, since they in reality are redundant
in this particular case.
However, the absence of these fields leads to code inconsistencies
that are difficult to handle in some cases, especially when we need
to reverse or reject messages at the socket layer.
In this commit, we concentrate the handling of the absent fields
to one place, by letting the function tipc_msg_reverse() reallocate
the buffer and expand the header to 32 bytes when necessary. This
means that the socket code now can assume that the two previously
absent fields are present in the header when a message needs to be
rejected. This opens up for some further simplifications of the
socket code.
Currently, the packet sequence number is updated and added to each
packet at the moment a packet is added to the link backlog queue.
This is wasteful, since it forces the code to traverse the send
packet list packet by packet when adding them to the backlog queue.
It would be better to just splice the whole packet list into the
backlog queue when that is the right action to do.
In this commit, we do this change. Also, since the sequence numbers
cannot now be assigned to the packets at the moment they are added
the backlog queue, we do instead calculate and add them at the moment
of transmission, when the backlog queue has to be traversed anyway.
We do this in the function tipc_link_push_packet().
Reviewed-by: Erik Hugne <erik.hugne@ericsson.com>
The link congestion algorithm used until now implies two problems.
- It is too generous towards lower-level messages in situations of high
load by giving "absolute" bandwidth guarantees to the different
priority levels. LOW traffic is guaranteed 10%, MEDIUM is guaranted
20%, HIGH is guaranteed 30%, and CRITICAL is guaranteed 40% of the
available bandwidth. But, in the absence of higher level traffic, the
ratio between two distinct levels becomes unreasonable. E.g. if there
is only LOW and MEDIUM traffic on a system, the former is guaranteed
1/3 of the bandwidth, and the latter 2/3. This again means that if
there is e.g. one LOW user and 10 MEDIUM users, the former will have
33.3% of the bandwidth, and the others will have to compete for the
remainder, i.e. each will end up with 6.7% of the capacity.
- Packets of type MSG_BUNDLER are created at SYSTEM importance level,
but only after the packets bundled into it have passed the congestion
test for their own respective levels. Since bundled packets don't
result in incrementing the level counter for their own importance,
only occasionally for the SYSTEM level counter, they do in practice
obtain SYSTEM level importance. Hence, the current implementation
provides a gap in the congestion algorithm that in the worst case
may lead to a link reset.
We now refine the congestion algorithm as follows:
- A message is accepted to the link backlog only if its own level
counter, and all superior level counters, permit it.
- The importance of a created bundle packet is set according to its
contents. A bundle packet created from messges at levels LOW to
CRITICAL is given importance level CRITICAL, while a bundle created
from a SYSTEM level message is given importance SYSTEM. In the latter
case only subsequent SYSTEM level messages are allowed to be bundled
into it.
This solves the first problem described above, by making the bandwidth
guarantee relative to the total number of users at all levels; only
the upper limit for each level remains absolute. In the example
described above, the single LOW user would use 1/11th of the bandwidth,
the same as each of the ten MEDIUM users, but he still has the same
guarantee against starvation as the latter ones.
The fix also solves the second problem. If the CRITICAL level is filled
up by bundle packets of that level, no lower level packets will be
accepted any more.
Suggested-by: Gergely Kiss <gergely.kiss@ericsson.com>
When a bearer is disabled manually, all its links have to be reset
and deleted. However, if there is a remaining, parallel link ready
to take over a deleted link's traffic, we currently delay the delete
of the removed link until the failover procedure is finished. This
is because the remaining link needs to access state from the reset
link, such as the last received packet number, and any partially
reassembled buffer, in order to perform a successful failover.
In this commit, we do instead move the state data over to the new
link, so that it can fulfill the procedure autonomously, without
accessing any data on the old link. This means that we can now
proceed and delete all pertaining links immediately when a bearer
is disabled. This saves us from some unnecessary complexity in such
situations.
We also choose to change the confusing definitions CHANGEOVER_PROTOCOL,
ORIGINAL_MSG and DUPLICATE_MSG to the more descriptive TUNNEL_PROTOCOL,
FAILOVER_MSG and SYNCH_MSG respectively.
A message sent to a node after a successful name table lookup may still
find that the destination socket has disappeared, because distribution
of name table updates is non-atomic. If so, the message will be rejected
back to the sender with error code TIPC_ERR_NO_PORT. If the source
socket of the message has disappeared in the meantime, the message
should be dropped.
However, in the currrent code, the message will instead be subject to an
unwanted tertiary lookup, because the function tipc_msg_lookup_dest()
doesn't check if there is an error code present in the message before
performing the lookup. In the worst case, the message may now find the
old destination again, and be redirected once more, instead of being
dropped directly as it should be.
A second bug in this function is that the "prev_node" field in the message
is not updated after successful lookup, something that may have
unpredictable consequences.
The problems arising from those bugs occur very infrequently.
The third change in this function; the test on msg_reroute_msg_cnt() is
purely cosmetic, reflecting that the returned value never can be negative.
This commit corrects the two bugs described above.
Messages transferred by TIPC are assigned an "importance priority", -an
integer value indicating how to treat the message when there is link or
destination socket congestion.
There is no separate header field for this value. Instead, the message
user values have been chosen in ascending order according to perceived
importance, so that the message user field can be used for this.
This is not a good solution. First, we have many more users than the
needed priority levels, so we end up with treating more priority
levels than necessary. Second, the user field cannot always
accurately reflect the priority of the message. E.g., a message
fragment packet should really have the priority of the enveloped
user data message, and not the priority of the MSG_FRAGMENTER user.
Until now, we have been working around this problem in different ways,
but it is now time to implement a consistent way of handling such
priorities, although still within the constraint that we cannot
allocate any more bits in the regular data message header for this.
In this commit, we define a new priority level, TIPC_SYSTEM_IMPORTANCE,
that will be the only one used apart from the four (lower) user data
levels. All non-data messages map down to this priority. Furthermore,
we take some free bits from the MSG_FRAGMENTER header and allocate
them to store the priority of the enveloped message. We then adjust
the functions msg_importance()/msg_set_importance() so that they
read/set the correct header fields depending on user type.
This small protocol change is fully compatible, because the code at
the receiving end of a link currently reads the importance level
only from user data messages, where there is no change.
struct tipc_link contains one single queue for outgoing packets,
where both transmitted and waiting packets are queued.
This infrastructure is hard to maintain, because we need
to keep a number of fields to keep track of which packets are
sent or unsent, and the number of packets in each category.
A lot of code becomes simpler if we split this queue into a transmission
queue, where sent/unacknowledged packets are kept, and a backlog queue,
where we keep the not yet sent packets.
In this commit we do this separation.
When we currently extract a bundled buffer from a message bundle in
the function tipc_msg_extract(), we allocate a new buffer and explicitly
copy the linear data area.
This is unnecessary, since we can just clone the buffer and do
skb_pull() on the clone to move the data pointer to the correct
position.
This is what we do in this commit.
Currently, TIPC linearizes all incoming buffers directly at reception
before passing them upwards in the stack. This is clearly a waste of
CPU resources, and must be avoided.
In this commit, we eliminate this unnecessary linearization. We still
ensure that at least the message header is linear, and that the buffer
is linearized where this is still needed, i.e. when unbundling and when
reversing messages.
In addition, we ensure that fragmented messages are validated after
reassembly before delivering them upwards in the stack.
The function link_buf_validate() is in reality re-entrant and context
independent, and will in later commits be called from several locations.
Therefore, we move it to msg.c, make it outline and rename the it to
tipc_msg_validate().
We also redesign the function to make proper use of pskb_may_pull()
TIPC handles message cardinality and sequencing at the link layer,
before passing messages upwards to the destination sockets. During the
upcall from link to socket no locks are held. It is therefore possible,
and we see it happen occasionally, that messages arriving in different
threads and delivered in sequence still bypass each other before they
reach the destination socket. This must not happen, since it violates
the sequentiality guarantee.
We solve this by adding a new input buffer queue to the link structure.
Arriving messages are added safely to the tail of that queue by the
link, while the head of the queue is consumed, also safely, by the
receiving socket. Sequentiality is secured per socket by only allowing
buffers to be dequeued inside the socket lock. Since there may be multiple
simultaneous readers of the queue, we use a 'filter' parameter to reduce
the risk that they peek the same buffer from the queue, hence also
reducing the risk of contention on the receiving socket locks.
This solves the sequentiality problem, and seems to cause no measurable
performance degradation.
A nice side effect of this change is that lock handling in the functions
tipc_rcv() and tipc_bcast_rcv() now becomes uniform, something that
will enable future simplifications of those functions.
The function tipc_msg_eval() is in reality doing two related, but
different tasks. First it tries to find a new destination for named
messages, in case there was no first lookup, or if the first lookup
failed. Second, it does what its name suggests, evaluating the validity
of the message and its destination, and returning an appropriate error
code depending on the result.
This is confusing, and in this commit we choose to break it up into two
functions. A new function, tipc_msg_lookup_dest(), first attempts to find
a new destination, if the message is of the right type. If this lookup
fails, or if the message should not be subject to a second lookup, the
already existing tipc_msg_reverse() is called. This function performs
prepares the message for rejection, if applicable.
The most common usage of namespace information is when we fetch the
own node addess from the net structure. This leads to a lot of
passing around of a parameter of type 'struct net *' between
functions just to make them able to obtain this address.
However, in many cases this is unnecessary. The own node address
is readily available as a member of both struct tipc_sock and
tipc_link, and can be fetched from there instead.
The fact that the vast majority of functions in socket.c and link.c
anyway are maintaining a pointer to their respective base structures
makes this option even more compelling.
In this commit, we introduce the inline functions tsk_own_node()
and link_own_node() to make it easy for functions to fetch the node
address from those structs instead of having to pass along and
dereference the namespace struct.
In particular, we make calls to the msg_xx() functions in msg.{h,c}
context independent by directly passing them the own node address
as parameter when needed. Those functions should be regarded as
leaves in the code dependency tree, and it is hence desirable to
keep them namspace unaware.
Apart from a potential positive effect on cache behavior, these
changes make it easier to introduce the changes that will follow
later in this series.
This one needs to copy the same data from user potentially more than
once. Sadly, MTU changes can trigger that ;-/
Cc: Jon Maloy <jon.maloy@ericsson.com>
If net namespace is supported in tipc, each namespace will be treated
as a separate tipc node. Therefore, every namespace must own its
private tipc node address. This means the "tipc_own_addr" global
variable of node address must be moved to tipc_net structure to
satisfy the requirement. It's turned out that users also can assign
node address for every namespace.
Signed-off-by: Ying Xue <ying.xue@windriver.com>
Tested-by: Tero Aho <Tero.Aho@coriant.com>
TIPC name table is used to store the mapping relationship between
TIPC service name and socket port ID. When tipc supports namespace,
it allows users to publish service names only owned by a certain
namespace. Therefore, every namespace must have its private name
table to prevent service names published to one namespace from being
contaminated by other service names in another namespace. Therefore,
The name table global variable (ie, nametbl) and its lock must be
moved to tipc_net structure, and a parameter of namespace must be
added for necessary functions so that they can obtain name table
variable defined in tipc_net structure.
Involve namespace infrastructure, make the "tipc_net_id" global
variable aware of per namespace, and rename it to "net_id". In
order that the conversion can be successfully done, an instance
of networking namespace must be passed to relevant functions,
allowing them to access the "net_id" variable of per namespace.
Only the works of initializing and shutting down tipc module are done
in core.h and core.c files, so all stuffs which are not closely
associated with the two tasks should be moved to appropriate places.
Note that the code _using_ ->msg_iter at that point will be very
unhappy with anything other than unshifted iovec-backed iov_iter.
We still need to convert users to proper primitives.
Use standard SKB list APIs associated with struct sk_buff_head to
manage socket outgoing packet chain and name table outgoing packet
chain, having relevant code simpler and more readable.
manage link transmission queue, having relevant code more clean.
The pseudo message types of BUNDLE_CLOSED as well as BUNDLE_OPEN are
used to flag whether or not more messages can be bundled into a data
packet in the outgoing transmission queue. Obviously, no more messages
can be appended after the packet has been sent and is waiting to be
acknowledged and deleted. These message types do in reality represent
a send-side local implementation flag, and are not defined as part of
the protocol. It is therefore safe to move it to to where it belongs,
that is, the control area (TIPC_SKB_CB) of the buffer.
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
The current link implementation keeps a linked list of blocked ports/
sockets that is populated when there is link congestion. The purpose
of this is to let the link know which users to wake up when the
congestion abates.
This adds unnecessary complexity to the data structure and the code,
since it forces us to involve the link each time we want to delete
a socket. It also forces us to grab the spinlock port_lock within
the scope of node_lock. We want to get rid of this direct dependence,
as well as the deadlock hazard resulting from the usage of port_lock.
In this commit, we instead let the link keep list of a "wakeup" pseudo
messages for use in such situations. Those messages are sent to the
pending sockets via the ordinary message reception path, and wake up
the socket's owner when they are received.
This enables us to get rid of the 'waiting_ports' linked lists in struct
tipc_port that manifest this direct reference. As a consequence, we can
eliminate another BH entry into the socket, and hence the need to grab
port_lock. This is a further step in our effort to remove port_lock
altogether.
The function tipc_msg_init() has turned out to be of limited value
in many cases. It take too few parameters to be usable for creating
a complete message, it makes too many assumptions about what the
message should be used for, and it does not allocate any buffer to
be returned to the caller.
Therefore, we now introduce the new function tipc_msg_create(), which
takes all the parameters needed to create a full message, and returns
a buffer of the requested size. The new function will be very useful
for the changes we will be doing in later commits in this series.
As per comment from David Miller, we try to make the buffer reassembly
function more resilient to user errors than it is today.
- We check that the "*buf" parameter always is set, since this is
mandatory input.
- We ensure that *buf->next always is set to NULL before linking in
the buffer, instead of relying of the caller to have done this.
- We ensure that the "tail" pointer in the head buffer's control
block is initialized to NULL when the first fragment arrives.
After the previous commit, we can now give the functions with temporary
names, such as tipc_link_xmit2(), tipc_msg_build2() etc., their proper
names.
There are no functional changes in this commit.
We can now remove a number of functions which have become obsolete
and unreferenced through this commit series. There are no functional
We add a new broadcast link transmit function in bclink.c and a new
receive function in socket.c. The purpose is to move the branching
between external and internal destination down to the link layer,
just as we have done with unicast in earlier commits. We also make
use of the new link-independent fragmentation support that was
introduced in an earlier commit series.
This gives a shorter and simpler code path, and makes it possible
to obtain copy-free buffer delivery to all node local destination
sockets.
The new transmission code is added in parallel with the existing one,
and will be used by the socket multicast send function in the next
commit in this series.
Since commit 37e22164a8a3c39bdad45aa463b1e69a1fdf4110 ("tipc: rename and
move message reassembly function") reassembly of long broadcast messages
has been broken. This is because we test for a non-NULL return value
of the *buf parameter as criteria for succesful reassembly. However, this
parameter is left defined even after reception of the first fragment,
when reassebly is still incomplete. This leads to a kernel crash as soon
as a the first fragment of a long broadcast message is received.
We fix this with this commit, by implementing a stricter behavior of the
function and its return values.
This commit should be applied to both net and net-next.
