[ Upstream commit ec518f21cb1a1b1f8a516499ea05c60299e04963 ]
Before syzbot/KMSAN bites, add the missing policy for TIPC_NLA_NET_ADDR
Fixes: 27c21416727a ("tipc: add net set to new netlink api")
Cc: Jon Maloy <jon.maloy@ericsson.com>
Cc: Ying Xue <ying.xue@windriver.com>
Pass the new extended ACK reporting struct to all of the generic
netlink parsing functions. For now, pass NULL in almost all callers
(except for some in the core.)
Now genl_register_family() is the only thing (other than the
users themselves, perhaps, but I didn't find any doing that)
writing to the family struct.
In all families that I found, genl_register_family() is only
called from __init functions (some indirectly, in which case
I've add __init annotations to clarifly things), so all can
actually be marked __ro_after_init.
This protects the data structure from accidental corruption.
Instead of providing macros/inline functions to initialize
the families, make all users initialize them statically and
get rid of the macros.
This reduces the kernel code size by about 1.6k on x86-64
(with allyesconfig).
Static family IDs have never really been used, the only
use case was the workaround I introduced for those users
that assumed their family ID was also their multicast
group ID.
Additionally, because static family IDs would never be
reserved by the generic netlink code, using a relatively
low ID would only work for built-in families that can be
registered immediately after generic netlink is started,
which is basically only the control family (apart from
the workaround code, which I also had to add code for so
it would reserve those IDs)
Thus, anything other than GENL_ID_GENERATE is flawed and
luckily not used except in the cases I mentioned. Move
those workarounds into a few lines of code, and then get
rid of GENL_ID_GENERATE entirely, making it more robust.
This helper function allows family implementations to access
their family's attrbuf. This gets rid of the attrbuf usage
in families, and also adds locking validation, since it's not
valid to use the attrbuf with parallel_ops or outside of the
dumpit callback.
When using replicast a UDP bearer can have an arbitrary amount of
remote ip addresses associated with it. This means we cannot simply
add all remote ip addresses to an existing bearer data message as it
might fill the message, leaving us with a truncated message that we
can't safely resume. To handle this we introduce the new netlink
command TIPC_NL_UDP_GET_REMOTEIP. This command is intended to be
called when the bearer data message has the
TIPC_NLA_UDP_MULTI_REMOTEIP flag set, indicating there are more than
one remote ip (replicast).
Signed-off-by: Richard Alpe <richard.alpe@ericsson.com>
Reviewed-by: Jon Maloy <jon.maloy@ericsson.com>
This patch introduces UDP replicast. A concept where we emulate
multicast by sending multiple unicast messages to configured peers.
The purpose of replicast is mainly to be able to use TIPC in cloud
environments where IP multicast is disabled. Using replicas to unicast
multicast messages is costly as we have to copy each skb and send the
copies individually.
Add TIPC_NL_PEER_REMOVE netlink command. This command can remove
an offline peer node from the internal data structures.
This will be supported by the tipc user space tool in iproute2.
Acked-by: Ying Xue <ying.xue@windriver.com>
In this commit, we dump the monitor attributes when queried.
The link monitor attributes are separated into two kinds:
1. general attributes per bearer
2. specific attributes per node/peer
This style resembles the socket attributes and the nametable
publications per socket.
Signed-off-by: Parthasarathy Bhuvaragan <parthasarathy.bhuvaragan@ericsson.com>
In this commit, we add support to fetch the configured
cluster monitoring threshold.
In this commit, we introduce support to configure the minimum
threshold to activate the new link monitoring algorithm.
Make the c files less cluttered and enable netlink attributes to be
shared between files.
Acked-by: Parthasarathy Bhuvaragan <parthasarathy.bhuvaragan@ericsson.com>
We move the definition of struct tipc_link from link.h to link.c in
order to minimize its exposure to the rest of the code.
When needed, we define new functions to make it possible for external
entities to access and set data in the link.
Apart from the above, there are no functional changes.
Reviewed-by: Ying Xue <ying.xue@windriver.com>
Signed-off-by: Jon Maloy <jon.maloy@ericsson.com>
In our effort to have less code and include dependencies between
entities such as node, link and bearer, we try to narrow down
the exposed interface towards the node as much as possible.
In this commit, we move the definition of struct tipc_node, along
with many of its associated function declarations, from node.h to
node.c. We also move some function definitions from link.c and
name_distr.c to node.c, since they access fields in struct tipc_node
that should not be externally visible. The moved functions are renamed
according to new location, and made static whenever possible.
There are no functional changes in this commit.
The new netlink API is no longer "v2" but rather the standard API and
the legacy API is now "nl compat". We split them into separate
start/stop and put them in different files in order to further
distinguish them.
Reviewed-by: Erik Hugne <erik.hugne@ericsson.com>
Currently tipc module only allows users sitting on "init_net" namespace
to configure it through netlink interface. But now almost each tipc
component is able to be aware of net namespace, so it's time to open
the permission for users residing in other namespaces, allowing them
to configure their own tipc stack instance through netlink interface.
Signed-off-by: Ying Xue <ying.xue@windriver.com>
Tested-by: Tero Aho <Tero.Aho@coriant.com>
Involve namespace infrastructure, make the "tipc_net_id" global
variable aware of per namespace, and rename it to "net_id". In
order that the conversion can be successfully done, an instance
of networking namespace must be passed to relevant functions,
allowing them to access the "net_id" variable of per namespace.
Add TIPC_NL_NAME_TABLE_GET command to the new tipc netlink API.
This command supports dumping the name table of all nodes.
Netlink logical layout of name table response message:
-> name table
-> publication
-> type
-> lower
-> upper
-> scope
-> node
-> ref
-> key
Add TIPC_NL_NET_SET command to the new tipc netlink API.
This command can set the network id and network (tipc) address.
Netlink logical layout of network set message:
-> net
[ -> id ]
[ -> address ]
Add TIPC_NL_NET_GET command to the new tipc netlink API.
This command dumps the network id of the node.
Netlink logical layout of returned network data:
-> net
-> id
Add TIPC_NL_NODE_GET to the new tipc netlink API.
This command can dump the address and node status of all nodes in the
tipc cluster.
Netlink logical layout of returned node/address data:
-> node
-> address
-> up flag
Add TIPC_NL_MEDIA_SET command to the new tipc netlink API.
This command can set one or more link properties for a particular
media.
Netlink logical layout of bearer set message:
-> media
-> name
-> link properties
[ -> tolerance ]
[ -> priority ]
[ -> window ]
Add TIPC_NL_MEDIA_GET command to the new tipc netlink API.
This command supports dumping all information about all defined
media as well as getting all information about a specific media.
The information about a media includes name and link properties.
Netlink logical layout of media get response message:
-> media
-> name
-> link properties
-> tolerance
-> priority
-> window
Add TIPC_NL_LINK_RESET_STATS command to the new netlink API.
This command resets the link statistics for a particular link.
Netlink logical layout of link reset message:
-> link
-> name
Add TIPC_NL_LINK_SET to the new tipc netlink API.
link.
Netlink logical layout of link set message:
-> link
-> name
-> properties
[ -> tolerance ]
[ -> priority ]
[ -> window ]
Add TIPC_NL_LINK_GET command to the new tipc netlink API.
This command supports dumping all information about all links
(including the broadcast link) or getting all information about a
specific link (not the broadcast link).
The information about a link includes name, transmission info,
properties and link statistics.
As the tipc broadcast link is special we unfortunately have to treat
it specially. It is a deliberate decision not to abstract the
broadcast link on this (API) level.
Netlink logical layout of link response message:
-> port
-> name
-> MTU
-> RX
-> TX
-> up flag
-> active flag
-> properties
-> priority
-> tolerance
-> window
-> statistics
-> rx_info
-> rx_fragments
-> rx_fragmented
-> rx_bundles
-> rx_bundled
-> tx_info
-> tx_fragments
-> tx_fragmented
-> tx_bundles
-> tx_bundled
-> msg_prof_tot
-> msg_len_cnt
-> msg_len_tot
-> msg_len_p0
-> msg_len_p1
-> msg_len_p2
-> msg_len_p3
-> msg_len_p4
-> msg_len_p5
-> msg_len_p6
-> rx_states
-> rx_probes
-> rx_nacks
-> rx_deferred
-> tx_states
-> tx_probes
-> tx_nacks
-> tx_acks
-> retransmitted
-> duplicates
-> link_congs
-> max_queue
-> avg_queue
Add TIPC_NL_PUBL_GET command to the new tipc netlink API.
This command supports dumping of all publications for a specific
socket.
Netlink logical layout of request message:
-> socket
-> reference
Netlink logical layout of response message:
-> publication
-> type
-> lower
-> upper
Add TIPC_NL_SOCK_GET command to the new tipc netlink API.
This command supports dumping of all available sockets with their
associated connection or publication(s). It could be extended to reply
with a single socket if the NLM_F_DUMP isn't set.
The information about a socket includes reference, address, connection
information / publication information.
-> socket
-> reference
-> address
-> connection
-> node
-> socket
-> connected flag
-> type
-> instance
-> publication flag
Add TIPC_NL_BEARER_SET command to the new tipc netlink API.
bearer.
-> bearer
-> name
-> link properties
[ -> tolerance ]
[ -> priority ]
[ -> window ]
Add TIPC_NL_BEARER_GET command to the new tipc netlink API.
This command supports dumping all data about all bearers or getting
all information about a specific bearer.
The information about a bearer includes name, link priorities and
domain.
Netlink logical layout of bearer get message:
-> bearer
-> name
Netlink logical layout of returned bearer information:
-> bearer
-> name
-> link properties
-> priority
-> tolerance
-> window
-> domain
A new netlink API for tipc that can disable or enable a tipc bearer.
The new API is separated from the old API because of a bug in the
user space client (tipc-config). The problem is that older versions
of tipc-config has a very low receive limit and adding commands to
the legacy genl_opts struct causes the ctrl_getfamily() response
message to grow, subsequently breaking the tool.
The new API utilizes netlink policies for input validation. Where the
top-level netlink attributes are tipc-logical entities, like bearer.
The top level entities then contain nested attributes. In this case
a name, nested link properties and a domain.
Netlink commands implemented in this patch:
TIPC_NL_BEARER_ENABLE
TIPC_NL_BEARER_DISABLE
Netlink logical layout of bearer enable message:
-> bearer
-> name
[ -> domain ]
-> properties
-> priority
Netlink logical layout of bearer disable message:
-> bearer
-> name
It is possible by passing a netlink socket to a more privileged
executable and then to fool that executable into writing to the socket
data that happens to be valid netlink message to do something that
privileged executable did not intend to do.
To keep this from happening replace bare capable and ns_capable calls
with netlink_capable, netlink_net_calls and netlink_ns_capable calls.
Which act the same as the previous calls except they verify that the
opener of the socket had the desired permissions as well.
Reported-by: Andy Lutomirski <luto@amacapital.net>
When tipc module is inserted, many tipc components are initialized
one by one. During the initialization period, if one of them is
failed, tipc_core_stop() will be called to stop all components
whatever corresponding components are created or not. To avoid to
release uncreated ones, relevant components have to add necessary
enabled flags indicating whether they are created or not.
But in the initialization stage, if one component is unsuccessfully
created, we will just destroy successfully created components before
the failed component instead of all components. All enabled flags
defined in components, in turn, become redundant. Additionally it's
also unnecessary to identify whether table.types is NULL in
tipc_nametbl_stop() because name stable has been definitely created
successfully when tipc_nametbl_stop() is called.
Cc: Erik Hugne <erik.hugne@ericsson.com>
Reviewed-by: Paul Gortmaker <paul.gortmaker@windriver.com>
As suggested by David Miller, make genl_register_family_with_ops()
a macro and pass only the array, evaluating ARRAY_SIZE() in the
macro, this is a little safer.
The openvswitch has some indirection, assing ops/n_ops directly in
that code. This might ultimately just assign the pointers in the
family initializations, saving the struct genl_family_and_ops and
code (once mcast groups are handled differently.)
Signed-off-by: Hong Zhiguo <honkiko@gmail.com>
It is a frequent mistake to confuse the netlink port identifier with a
process identifier. Try to reduce this confusion by renaming fields
that hold port identifiers portid instead of pid.
I have carefully avoided changing the structures exported to
userspace to avoid changing the userspace API.
I have successfully built an allyesconfig kernel with this change.
Acked-by: Stephen Hemminger <shemminger@vyatta.com>
All messages should go directly to the kernel log. The TIPC
specific error, warning, info and debug trace macro's are
removed and all references replaced with pr_err, pr_warn,
pr_info and pr_debug.
Commonly used sub-strings are explicitly declared as a const
char to reduce .text size.
Note that this means the debug messages (changed to pr_debug),
are now enabled through dynamic debugging, instead of a TIPC
specific Kconfig option (TIPC_DEBUG). The latter will be
phased out completely
Signed-off-by: Erik Hugne <erik.hugne@ericsson.com>
[PG: use pr_fmt as suggested by Joe Perches <joe@perches.com>]
This makes generic netlink network namespace aware. No
generic netlink families except for the controller family
are made namespace aware, they need to be checked one by
one and then set the family->netnsok member to true.
A new function genlmsg_multicast_netns() is introduced to
allow sending a multicast message in a given namespace,
for example when it applies to an object that lives in
that namespace, a new function genlmsg_multicast_allns()
to send a message to all network namespaces (for objects
that do not have an associated netns).
The function genlmsg_multicast() is changed to multicast
the message in just init_net, which is currently correct
for all generic netlink families since they only work in
init_net right now. Some will later want to work in all
net namespaces because they do not care about the netns
at all -- those will have to be converted to use one of
the new functions genlmsg_multicast_allns() or
genlmsg_multicast_netns() whenever they are made netns
aware in some way.
After this patch families can easily decide whether or
not they should be available in all net namespaces. Many
genl families us it for objects not related to networking
and should therefore be available in all namespaces, but
that will have to be done on a per family basis.
Note that this doesn't touch on the checkpoint/restart
problem where network namespaces could be used, genl
families and multicast groups are numbered globally and
I see no easy way of changing that, especially since it
must be possible to multicast to all network namespaces
for those families that do not care about netns.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Use genl_register_family_with_ops() instead of a copy. This also changes
netlink related variable names to be kernel-wide unique for consistency
with other users.
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
This patch prevents a TIPC configuration command requiring network
administrator privileges from triggering an skbuff underrun if it
is issued by a process lacking those privileges. The revised error
handling code avoids the use of a potentially uninitialized global
variable by transforming the unauthorized command into a new command,
then following the standard command processing path to generate the
required error message.
Signed-off-by: Allan Stephens <allan.stephens@windriver.com>
The tipc netlink config handler uses the nlmsg_pid from the
request header as destination for its reply. If the application
initialized nlmsg_pid to 0, the reply is looped back to the kernel,
causing hangup. Fix: use nlmsg_pid of the skb that triggered the
request.
For the common "(struct nlmsghdr *)skb->data" sequence, so that we reduce the
number of direct accesses to skb->data and for consistency with all the other
cast skb member helpers.
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
This patch adds a tipc_ prefix to all externally visible symbols.
Signed-off-by: Per Liden <per.liden@ericsson.com>
Increasing the module ref count at registration will block the module from
ever being unloaded. In fact, genetlink should not care about the owner at
all. This patch removes the owner field from the struct registered with
genetlink.
Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca>
Updated copyright notice to include the year the file was
actually created. Information about file creation dates
was extracted from the files in the old CVS repository
at tipc.sourceforge.net.
Signed-off-by: Per Liden <per.liden@nospam.ericsson.com>
The copyright statements from different parts of Ericsson
have been merged into one.
The license header in each file now more clearly state that this
code is licensed under a dual BSD/GPL. Before this was only
evident if you looked at the MODULE_LICENSE line in core.c.
