path: root/net/tipc/node.c
2010-10-16tipc: cleanup function namespacestephen hemminger
Do some cleanups of TIPC based on make namespacecheck 1. Don't export unused symbols 2. Eliminate dead code 3. Make functions and variables local 4. Rename buf_acquire to tipc_buf_acquire since it is used in several files Compile tested only. This make break out of tree kernel modules that depend on TIPC routines. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Jon Maloy <jon.maloy@ericsson.com> Acked-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-13tipc: clean out all instances of #if 0'd unused codePaul Gortmaker
Remove all instances of legacy, or as yet to be implemented code that is currently living within an #if 0 ... #endif block. In the rare instance that some of it be needed in the future, it can still be dragged out of history, but there is no need for it to sit in mainline. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-23net: return operator cleanupEric Dumazet
Change "return (EXPR);" to "return EXPR;" return is not a function, parentheses are not required. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-17tipc: Prevent missing name table entries when link flip-flops rapidlyAllan Stephens
Ensure that TIPC does not re-establish communication with a neighboring node until it has finished updating all data structures containing information about that node to reflect the earlier loss of contact. Previously, it was possible for TIPC to perform its purge of name table entries relating to the node once contact had already been re-established, resulting in the unwanted removal of valid name table entries. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-17tipc: Optimize tipc_node_has_active_links()Allan Stephens
Eliminate unnecessary checking for null node pointer and redundant check of second active link array entry. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-12tipc: add tipc_ prefix to fcns targeted for un-inliningAllan Stephens
These functions have enough code in them such that they seem like sensible targets for un-inlining. Prior to doing that, this adds the tipc_ prefix to the functions, so that in the event of a panic dump or similar, the subsystem from which the functions come from is immediately clear. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-24tipc: remove trailing space in messagesFrans Pop
Signed-off-by: Frans Pop <elendil@planet.nl> Cc: Per Liden <per.liden@ericsson.com> Cc: Jon Maloy <jon.maloy@ericsson.com> Cc: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-18tipc: fix non-const printf format argumentsStephen Hemminger
Fix warnings from current gcc about using non-const strings as printf args in TIPC. Compile tested only (not a TIPC user). Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-02tipc: Don't use structure names which easily globally conflict.David S. Miller
Andrew Morton reported a build failure on sparc32, because TIPC uses names like "struct node" and there is a like named data structure defined in linux/node.h This just regexp replaces "struct node*" to "struct tipc_node*" to avoid this and any future similar problems. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-14tipc: Add missing locks when inspecting node list & link listAllan Stephens
This patch ensures that TIPC configuration commands that display info about neighboring nodes and their links take the spinlocks that protect the node list and link lists from changing while the lists are being traversed. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-21tipc: Prevent node object duplication due to simultaneous discoveryAllan Stephens
This patch ensures that the simultaneous discovery of the same neighboring node by multiple interfaces does not cause TIPC to add the node into its internal data structures more than once. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-08-02[TIPC]: Fix two minor sparse warnings.Florian Westphal
fix two warnings generated by sparse: link.c:2386 symbol 'msgcount' shadows an earlier one node.c:244 symbol 'addr_string' shadows an earlier one Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] TIPC: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[TIPC]: Use kzalloc where appropriateArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-02[TIPC]: endianness annotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-18[TIPC]: Can now list multicast link on an isolated network nodeAllan Stephens
This patch fixes a minor bug that prevents "tipc-config -l" from displaying the multicast link if a TIPC node has never successfully established at least one unicast link. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Per Liden <per.liden@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-29[TIPC]: Improve response to requests for node/link informationAllan Stephens
Now allocates reply space for "get links" request based on number of actual links, not number of potential links. Also, limits reply to "get links" and "get nodes" requests to 32KB to match capabilities of tipc-config utility that issued request. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Per Liden <per.liden@ericsson.com>
2006-06-27[PATCH] spin/rwlock init cleanupsIngo Molnar
locking init cleanups: - convert " = SPIN_LOCK_UNLOCKED" to spin_lock_init() or DEFINE_SPINLOCK() - convert rwlocks in a similar manner this patch was generated automatically. Motivation: - cleanliness - lockdep needs control of lock initialization, which the open-coded variants do not give - it's also useful for -rt and for lock debugging in general Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[TIPC]: Fixed link switchover bugsAllan Stephens
Incorporates several related fixes: - switchover now occurs when switching from an active link to a standby link - failure of a standby link no longer initiates switchover - links now display correct # of received packtes following reactivation Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Per Liden <per.liden@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-25[TIPC]: Enhanced & cleaned up system messages; fixed 2 obscure memory leaks.Allan Stephens
2006-06-25[TIPC]: First phase of assert() cleanupAllan Stephens
This also contains enhancements to simplify comparisons in name table publication removal algorithm and to simplify name table sanity checking when shutting down TIPC. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Per Liden <per.liden@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[TIPC]: CleanupsAdrian Bunk
This patch contains the following possible cleanups: - make needlessly global code static - #if 0 the following unused global functions: - name_table.c: tipc_nametbl_print() - name_table.c: tipc_nametbl_dump() - net.c: tipc_net_next_node() Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Per Liden <per.liden@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[TIPC]: Fix simple sparse warningsSam Ravnborg
Tried to run the new tipc stack through sparse. Following patch fixes all cases where 0 was used as replacement of NULL. Use NULL to document this is a pointer and to silence sparse. This brough sparse warning count down with 127 to 24 warnings. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Per Liden <per.liden@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-18[TIPC] Avoid polluting the global namespacePer Liden
This patch adds a tipc_ prefix to all externally visible symbols. Signed-off-by: Per Liden <per.liden@ericsson.com>
2006-01-12[TIPC] More updates of file headersPer Liden
Updated copyright notice to include the year the file was actually created. Information about file creation dates was extracted from the files in the old CVS repository at tipc.sourceforge.net. Signed-off-by: Per Liden <per.liden@nospam.ericsson.com>
2006-01-12[TIPC] Update of file headersPer Liden
The copyright statements from different parts of Ericsson have been merged into one. Signed-off-by: Per Liden <per.liden@nospam.ericsson.com>
2006-01-12[TIPC] License header updatePer Liden
The license header in each file now more clearly state that this code is licensed under a dual BSD/GPL. Before this was only evident if you looked at the MODULE_LICENSE line in core.c. Signed-off-by: Per Liden <per.liden@nospam.ericsson.com>
2006-01-12[TIPC] Initial mergePer Liden
TIPC (Transparent Inter Process Communication) is a protocol designed for intra cluster communication. For more information see http://tipc.sourceforge.net Signed-off-by: Per Liden <per.liden@nospam.ericsson.com>
