[ Upstream commit 4bcd4ec1017205644a2697bccbc3b5143f522f5f ]
We find that sysctl_tipc_rmem and named_timeout do not have the right minimum
setting. sysctl_tipc_rmem should be larger than zero, like sysctl_tcp_rmem.
And named_timeout as a timeout setting should be not less than zero.
Fixes: cc79dd1ba9c10 ("tipc: change socket buffer overflow control to respect sk_rcvbuf")
Fixes: a5325ae5b8bff ("tipc: add name distributor resiliency queue")
Signed-off-by: Jie Liu <liujie165@huawei.com>
Reported-by: Qiang Ning <ningqiang1@huawei.com>
Reviewed-by: Zhiqiang Liu <liuzhiqiang26@huawei.com>
Reviewed-by: Miaohe Lin <linmiaohe@huawei.com>
[ Upstream commit 9cf1cd8ee3ee09ef2859017df2058e2f53c5347f ]
In order to set/get/dump, the tipc uses the generic netlink
infrastructure. So, when tipc module is inserted, init function
calls genl_register_family().
After genl_register_family(), set/get/dump commands are immediately
allowed and these callbacks internally use the net_generic.
net_generic is allocated by register_pernet_device() but this
is called after genl_register_family() in the __init function.
So, these callbacks would use un-initialized net_generic.
Test commands:
#SHELL1
while :
do
modprobe tipc
modprobe -rv tipc
done
#SHELL2
while :
do
tipc link list
done
Splat looks like:
[ 59.616322][ T2788] kasan: CONFIG_KASAN_INLINE enabled
[ 59.617234][ T2788] kasan: GPF could be caused by NULL-ptr deref or user memory access
[ 59.618398][ T2788] general protection fault: 0000 [#1] SMP DEBUG_PAGEALLOC KASAN PTI
[ 59.619389][ T2788] CPU: 3 PID: 2788 Comm: tipc Not tainted 5.4.0+ #194
[ 59.620231][ T2788] Hardware name: innotek GmbH VirtualBox/VirtualBox, BIOS VirtualBox 12/01/2006
[ 59.621428][ T2788] RIP: 0010:tipc_bcast_get_broadcast_mode+0x131/0x310 [tipc]
[ 59.622379][ T2788] Code: c7 c6 ef 8b 38 c0 65 ff 0d 84 83 c9 3f e8 d7 a5 f2 e3 48 8d bb 38 11 00 00 48 b8 00 00 00 00
[ 59.622550][ T2780] NET: Registered protocol family 30
[ 59.624627][ T2788] RSP: 0018:ffff88804b09f578 EFLAGS: 00010202
[ 59.624630][ T2788] RAX: dffffc0000000000 RBX: 0000000000000011 RCX: 000000008bc66907
[ 59.624631][ T2788] RDX: 0000000000000229 RSI: 000000004b3cf4cc RDI: 0000000000001149
[ 59.624633][ T2788] RBP: ffff88804b09f588 R08: 0000000000000003 R09: fffffbfff4fb3df1
[ 59.624635][ T2788] R10: fffffbfff50318f8 R11: ffff888066cadc18 R12: ffffffffa6cc2f40
[ 59.624637][ T2788] R13: 1ffff11009613eba R14: ffff8880662e9328 R15: ffff8880662e9328
[ 59.624639][ T2788] FS: 00007f57d8f7b740(0000) GS:ffff88806cc00000(0000) knlGS:0000000000000000
[ 59.624645][ T2788] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 59.625875][ T2780] tipc: Started in single node mode
[ 59.626128][ T2788] CR2: 00007f57d887a8c0 CR3: 000000004b140002 CR4: 00000000000606e0
[ 59.633991][ T2788] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 59.635195][ T2788] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
[ 59.636478][ T2788] Call Trace:
[ 59.637025][ T2788] tipc_nl_add_bc_link+0x179/0x1470 [tipc]
[ 59.638219][ T2788] ? lock_downgrade+0x6e0/0x6e0
[ 59.638923][ T2788] ? __tipc_nl_add_link+0xf90/0xf90 [tipc]
[ 59.639533][ T2788] ? tipc_nl_node_dump_link+0x318/0xa50 [tipc]
[ 59.640160][ T2788] ? mutex_lock_io_nested+0x1380/0x1380
[ 59.640746][ T2788] tipc_nl_node_dump_link+0x4fd/0xa50 [tipc]
[ 59.641356][ T2788] ? tipc_nl_node_reset_link_stats+0x340/0x340 [tipc]
[ 59.642088][ T2788] ? __skb_ext_del+0x270/0x270
[ 59.642594][ T2788] genl_lock_dumpit+0x85/0xb0
[ 59.643050][ T2788] netlink_dump+0x49c/0xed0
[ 59.643529][ T2788] ? __netlink_sendskb+0xc0/0xc0
[ 59.644044][ T2788] ? __netlink_dump_start+0x190/0x800
[ 59.644617][ T2788] ? __mutex_unlock_slowpath+0xd0/0x670
[ 59.645177][ T2788] __netlink_dump_start+0x5a0/0x800
[ 59.645692][ T2788] genl_rcv_msg+0xa75/0xe90
[ 59.646144][ T2788] ? __lock_acquire+0xdfe/0x3de0
[ 59.646692][ T2788] ? genl_family_rcv_msg_attrs_parse+0x320/0x320
[ 59.647340][ T2788] ? genl_lock_dumpit+0xb0/0xb0
[ 59.647821][ T2788] ? genl_unlock+0x20/0x20
[ 59.648290][ T2788] ? genl_parallel_done+0xe0/0xe0
[ 59.648787][ T2788] ? find_held_lock+0x39/0x1d0
[ 59.649276][ T2788] ? genl_rcv+0x15/0x40
[ 59.649722][ T2788] ? lock_contended+0xcd0/0xcd0
[ 59.650296][ T2788] netlink_rcv_skb+0x121/0x350
[ 59.650828][ T2788] ? genl_family_rcv_msg_attrs_parse+0x320/0x320
[ 59.651491][ T2788] ? netlink_ack+0x940/0x940
[ 59.651953][ T2788] ? lock_acquire+0x164/0x3b0
[ 59.652449][ T2788] genl_rcv+0x24/0x40
[ 59.652841][ T2788] netlink_unicast+0x421/0x600
Fixes: 7e4369057806 ("tipc: fix a slab object leak")
Fixes: a62fbccecd62 ("tipc: make subscriber server support net namespace")
Signed-off-by: Taehee Yoo <ap420073@gmail.com>
Acked-by: Jon Maloy <jon.maloy@ericsson.com>
[ Upstream commit fd567ac20cb0377ff466d3337e6e9ac5d0cb15e4 ]
In commit 4f07b80c9733 ("tipc: check msg->req data len in
tipc_nl_compat_bearer_disable") the same patch code was copied into
routines: tipc_nl_compat_bearer_disable(),
tipc_nl_compat_link_stat_dump() and tipc_nl_compat_link_reset_stats().
The two link routine occurrences should have been modified to check
the maximum link name length and not bearer name length.
Fixes: 4f07b80c9733 ("tipc: check msg->reg data len in tipc_nl_compat_bearer_disable")
Signed-off-by: John Rutherford <john.rutherford@dektech.com.au>
[ Upstream commit 7384b538d3aed2ed49d3575483d17aeee790fb06 ]
When we free skb at tipc_data_input, we return a 'false' boolean.
Then, skb passed to subcalling tipc_link_input in tipc_link_rcv,
<snip>
1303 int tipc_link_rcv:
1354 if (!tipc_data_input(l, skb, l->inputq))
1355 rc |= tipc_link_input(l, skb, l->inputq);
</snip>
Fix it by simple changing to a 'true' boolean when skb is being free-ed.
Then, tipc_link_rcv will bypassed to subcalling tipc_link_input as above
condition.
Acked-by: Ying Xue <ying.xue@windriver.com>
Acked-by: Jon Maloy <maloy@donjonn.com>
Signed-off-by: Hoang Le <hoang.h.le@dektech.com.au>
[ Upstream commit f87d8ad9233f115db92c6c087d58403b0009ed36 ]
There is a memory leak in case genlmsg_put fails.
Fix this by freeing *args* before return.
Addresses-Coverity-ID: 1476406 ("Resource leak")
Fixes: 46273cf7e009 ("tipc: fix a missing check of genlmsg_put")
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
[ Upstream commit 46273cf7e009231d2b6bc10a926e82b8928a9fb2 ]
genlmsg_put could fail. The fix inserts a check of its return value, and
if it fails, returns -EMSGSIZE.
Signed-off-by: Kangjie Lu <kjlu@umn.edu>
[ Upstream commit 42dec1dbe38239cf91cc1f4df7830c66276ced37 ]
Unlike kfree(p), kfree_rcu(p, rcu) won't do NULL pointer check. When
tipc_nametbl_remove_publ returns NULL, the panic below happens:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000068
RIP: 0010:__call_rcu+0x1d/0x290
Call Trace:
<IRQ>
tipc_publ_notify+0xa9/0x170 [tipc]
tipc_node_write_unlock+0x8d/0x100 [tipc]
tipc_node_link_down+0xae/0x1d0 [tipc]
tipc_node_check_dest+0x3ea/0x8f0 [tipc]
? tipc_disc_rcv+0x2c7/0x430 [tipc]
? tipc_rcv+0x6bb/0xf20 [tipc]
? ip_route_input_slow+0x9cf/0xb10
tipc_udp_recv+0x195/0x1e0 [tipc]
? tipc_udp_is_known_peer+0x80/0x80 [tipc]
udp_queue_rcv_skb+0x180/0x460
udp_unicast_rcv_skb.isra.56+0x75/0x90
__udp4_lib_rcv+0x4ce/0xb90
ip_local_deliver_finish+0x11c/0x210
ip_local_deliver+0x6b/0xe0
? ip_rcv_finish+0xa9/0x410
ip_rcv+0x273/0x362
Fixes: 97ede29e80ee ("tipc: convert name table read-write lock to RCU")
Reported-by: Li Shuang <shuali@redhat.com>
Signed-off-by: Xin Long <lucien.xin@gmail.com>
[ Upstream commit 4da5f0018eef4c0de31675b670c80e82e13e99d1 ]
Commit 2753ca5d9009 ("tipc: fix uninit-value in tipc_nl_compat_doit")
broke older tipc tools that use compat interface (e.g. tipc-config from
tipcutils package):
% tipc-config -p
operation not supported
The commit started to reject TIPC netlink compat messages that do not
have attributes. It is too restrictive because some of such messages are
valid (they don't need any arguments):
% grep 'tx none' include/uapi/linux/tipc_config.h
#define TIPC_CMD_NOOP 0x0000 /* tx none, rx none */
#define TIPC_CMD_GET_MEDIA_NAMES 0x0002 /* tx none, rx media_name(s) */
#define TIPC_CMD_GET_BEARER_NAMES 0x0003 /* tx none, rx bearer_name(s) */
#define TIPC_CMD_SHOW_PORTS 0x0006 /* tx none, rx ultra_string */
#define TIPC_CMD_GET_REMOTE_MNG 0x4003 /* tx none, rx unsigned */
#define TIPC_CMD_GET_MAX_PORTS 0x4004 /* tx none, rx unsigned */
#define TIPC_CMD_GET_NETID 0x400B /* tx none, rx unsigned */
#define TIPC_CMD_NOT_NET_ADMIN 0xC001 /* tx none, rx none */
This patch relaxes the original fix and rejects messages without
arguments only if such arguments are expected by a command (reg_type is
non zero).
Fixes: 2753ca5d9009 ("tipc: fix uninit-value in tipc_nl_compat_doit")
Cc: stable@vger.kernel.org
Signed-off-by: Taras Kondratiuk <takondra@cisco.com>
[ Upstream commit 4f07b80c973348a99b5d2a32476a2e7877e94a05 ]
This patch is to fix an uninit-value issue, reported by syzbot:
BUG: KMSAN: uninit-value in memchr+0xce/0x110 lib/string.c:981
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x191/0x1f0 lib/dump_stack.c:113
kmsan_report+0x130/0x2a0 mm/kmsan/kmsan.c:622
__msan_warning+0x75/0xe0 mm/kmsan/kmsan_instr.c:310
string_is_valid net/tipc/netlink_compat.c:176 [inline]
tipc_nl_compat_bearer_disable+0x2a1/0x480 net/tipc/netlink_compat.c:449
__tipc_nl_compat_doit net/tipc/netlink_compat.c:327 [inline]
tipc_nl_compat_doit+0x3ac/0xb00 net/tipc/netlink_compat.c:360
tipc_nl_compat_handle net/tipc/netlink_compat.c:1178 [inline]
tipc_nl_compat_recv+0x1b1b/0x27b0 net/tipc/netlink_compat.c:1281
TLV_GET_DATA_LEN() may return a negtive int value, which will be
used as size_t (becoming a big unsigned long) passed into memchr,
cause this issue.
Similar to what it does in tipc_nl_compat_bearer_enable(), this
fix is to return -EINVAL when TLV_GET_DATA_LEN() is negtive in
tipc_nl_compat_bearer_disable(), as well as in
v1->v2:
- add the missing Fixes tags per Eric's request.
Fixes: 0762216c0ad2 ("tipc: fix uninit-value in tipc_nl_compat_bearer_enable")
Fixes: 8b66fee7f8ee ("tipc: fix uninit-value in tipc_nl_compat_link_reset_stats")
Reported-by: syzbot+30eaa8bf392f7fafffaf@syzkaller.appspotmail.com
[ Upstream commit c492d4c74dd3f87559883ffa0f94a8f1ae3fe5f5 ]
This patch is to fix a dst defcnt leak, which can be reproduced by doing:
# ip net a c; ip net a s; modprobe tipc
# ip net e s ip l a n eth1 type veth peer n eth1 netns c
# ip net e c ip l s lo up; ip net e c ip l s eth1 up
# ip net e s ip l s lo up; ip net e s ip l s eth1 up
# ip net e c ip a a 1.1.1.2/8 dev eth1
# ip net e s ip a a 1.1.1.1/8 dev eth1
# ip net e c tipc b e m udp n u1 localip 1.1.1.2
# ip net e s tipc b e m udp n u1 localip 1.1.1.1
# ip net d c; ip net d s; rmmod tipc
and it will get stuck and keep logging the error:
unregister_netdevice: waiting for lo to become free. Usage count = 1
The cause is that a dst is held by the udp sock's sk_rx_dst set on udp rx
path with udp_early_demux == 1, and this dst (eventually holding lo dev)
can't be released as bearer's removal in tipc pernet .exit happens after
lo dev's removal, default_device pernet .exit.
"There are two distinct types of pernet_operations recognized: subsys and
device. At creation all subsys init functions are called before device
init functions, and at destruction all device exit functions are called
before subsys exit function."
So by calling register_pernet_device instead to register tipc_net_ops, the
pernet .exit() will be invoked earlier than loopback dev's removal when a
netns is being destroyed, as fou/gue does.
Note that vxlan and geneve udp tunnels don't have this issue, as the udp
sock is released in their device ndo_stop().
This fix is also necessary for tipc dst_cache, which will hold dsts on tx
path and I will introduce in my next patch.
commit 526f5b851a96566803ee4bee60d0a34df56c77f8 upstream.
Error message printed:
modprobe: ERROR: could not insert 'tipc': Address family not
supported by protocol.
when modprobe tipc after the following patch: switch order of
device registration, commit 7e27e8d6130c
("tipc: switch order of device registration to fix a crash")
Because sock_create_kern(net, AF_TIPC, ...) called by
tipc_topsrv_create_listener() in the initialization process
of tipc_init_net(), so tipc_socket_init() must be execute before that.
Meanwhile, tipc_net_id need to be initialized when sock_create()
called, and tipc_socket_init() is no need to be called for each namespace.
I add a variable tipc_topsrv_net_ops, and split the
register_pernet_subsys() of tipc into two parts, and split
tipc_socket_init() with initialization of pernet params.
By the way, I fixed resources rollback error when tipc_bcast_init()
failed in tipc_init_net().
Fixes: 7e27e8d6130c ("tipc: switch order of device registration to fix a crash")
Signed-off-by: Junwei Hu <hujunwei4@huawei.com>
Reported-by: Wang Wang <wangwang2@huawei.com>
Reported-by: syzbot+1e8114b61079bfe9cbc5@syzkaller.appspotmail.com
Reviewed-by: Kang Zhou <zhoukang7@huawei.com>
Reviewed-by: Suanming Mou <mousuanming@huawei.com>
registration"
commit 5593530e56943182ebb6d81eca8a3be6db6dbba4 upstream.
This reverts commit 532b0f7ece4cb2ffd24dc723ddf55242d1188e5e.
More revisions coming up.
[ Upstream commit 532b0f7ece4cb2ffd24dc723ddf55242d1188e5e ]
Because sock_create_kern(net, AF_TIPC, ...) is called by
of tipc_net_ops, tipc_socket_init() must be execute before that.
I move tipc_socket_init() into function tipc_init_net().
Fixes: 7e27e8d6130c
[ Upstream commit 7e27e8d6130c5e88fac9ddec4249f7f2337fe7f8 ]
When tipc is loaded while many processes try to create a TIPC socket,
a crash occurs:
PANIC: Unable to handle kernel paging request at virtual
address "dfff20000000021d"
pc : tipc_sk_create+0x374/0x1180 [tipc]
lr : tipc_sk_create+0x374/0x1180 [tipc]
Exception class = DABT (current EL), IL = 32 bits
Call trace:
__sock_create+0x1cc/0x408
__sys_socket+0xec/0x1f0
__arm64_sys_socket+0x74/0xa8
This is due to race between sock_create and unfinished
register_pernet_device. tipc_sk_insert tries to do
"net_generic(net, tipc_net_id)".
but tipc_net_id is not initialized yet.
So switch the order of the two to close the race.
This can be reproduced with multiple processes doing socket(AF_TIPC, ...)
and one process doing module removal.
Reviewed-by: Xiaogang Wang <wangxiaogang3@huawei.com>
commit 8c63bf9ab4be8b83bd8c34aacfd2f1d2c8901c8a upstream.
A similar issue as fixed by Patch "tipc: check bearer name with right
length in tipc_nl_compat_bearer_enable" was also found by syzbot in
tipc_nl_compat_link_set().
The length to check with should be 'TLV_GET_DATA_LEN(msg->req) -
offsetof(struct tipc_link_config, name)'.
Reported-by: syzbot+de00a87b8644a582ae79@syzkaller.appspotmail.com
commit 6f07e5f06c8712acc423485f657799fc8e11e56c upstream.
Syzbot reported the following crash:
BUG: KMSAN: uninit-value in memchr+0xce/0x110 lib/string.c:961
tipc_nl_compat_bearer_enable+0x2c4/0x910 net/tipc/netlink_compat.c:401
__tipc_nl_compat_doit net/tipc/netlink_compat.c:321 [inline]
tipc_nl_compat_doit+0x3aa/0xaf0 net/tipc/netlink_compat.c:354
tipc_nl_compat_handle net/tipc/netlink_compat.c:1162 [inline]
tipc_nl_compat_recv+0x1ae7/0x2750 net/tipc/netlink_compat.c:1265
genl_family_rcv_msg net/netlink/genetlink.c:601 [inline]
genl_rcv_msg+0x185f/0x1a60 net/netlink/genetlink.c:626
netlink_rcv_skb+0x431/0x620 net/netlink/af_netlink.c:2477
genl_rcv+0x63/0x80 net/netlink/genetlink.c:637
netlink_unicast_kernel net/netlink/af_netlink.c:1310 [inline]
netlink_unicast+0xf3e/0x1020 net/netlink/af_netlink.c:1336
netlink_sendmsg+0x127f/0x1300 net/netlink/af_netlink.c:1917
sock_sendmsg_nosec net/socket.c:622 [inline]
sock_sendmsg net/socket.c:632 [inline]
Uninit was created at:
__alloc_skb+0x309/0xa20 net/core/skbuff.c:208
alloc_skb include/linux/skbuff.h:1012 [inline]
netlink_alloc_large_skb net/netlink/af_netlink.c:1182 [inline]
netlink_sendmsg+0xb82/0x1300 net/netlink/af_netlink.c:1892
It was triggered when the bearer name size < TIPC_MAX_BEARER_NAME,
it would check with a wrong len/TLV_GET_DATA_LEN(msg->req), which
also includes priority and disc_domain length.
This patch is to fix it by checking it with a right length:
'TLV_GET_DATA_LEN(msg->req) - offsetof(struct tipc_bearer_config, name)'.
Reported-by: syzbot+8b707430713eb46e1e45@syzkaller.appspotmail.com
commit 2ac695d1d602ce00b12170242f58c3d3a8e36d04 upstream.
Syzbot found a crash:
BUG: KMSAN: uninit-value in tipc_nl_compat_name_table_dump+0x54f/0xcd0 net/tipc/netlink_compat.c:872
Call Trace:
__tipc_nl_compat_dumpit+0x59e/0xda0 net/tipc/netlink_compat.c:215
tipc_nl_compat_dumpit+0x63a/0x820 net/tipc/netlink_compat.c:280
tipc_nl_compat_handle net/tipc/netlink_compat.c:1226 [inline]
tipc_nl_compat_recv+0x1b5f/0x2750 net/tipc/netlink_compat.c:1265
It was supposed to be fixed on commit 974cb0e3e7c9 ("tipc: fix uninit-value
in tipc_nl_compat_name_table_dump") by checking TLV_GET_DATA_LEN(msg->req)
in cmd->header()/tipc_nl_compat_name_table_dump_header(), which is called
ahead of tipc_nl_compat_name_table_dump().
However, tipc_nl_compat_dumpit() doesn't handle the error returned from cmd
header function. It means even when the check added in that fix fails, it
won't stop calling tipc_nl_compat_name_table_dump(), and the issue will be
triggered again.
So this patch is to add the process for the err returned from cmd header
function in tipc_nl_compat_dumpit().
Reported-by: syzbot+3ce8520484b0d4e260a5@syzkaller.appspotmail.com
commit 29e270fc32192e7729057963ae7120663856c93e upstream.
Got below warning with gcc 8.2 compiler.
net/tipc/topsrv.c: In function ‘tipc_topsrv_start’:
net/tipc/topsrv.c:660:2: warning: ‘strncpy’ specified bound depends on the length of the source argument [-Wstringop-overflow=]
strncpy(srv->name, name, strlen(name) + 1);
net/tipc/topsrv.c:660:27: note: length computed here
So change it to correct length and use strscpy.
Signed-off-by: Guoqing Jiang <gqjiang@suse.com>
commit 2753ca5d9009c180dbfd4c802c80983b4b6108d1 upstream.
BUG: KMSAN: uninit-value in tipc_nl_compat_doit+0x404/0xa10 net/tipc/netlink_compat.c:335
CPU: 0 PID: 4514 Comm: syz-executor485 Not tainted 4.16.0+ #87
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:17 [inline]
dump_stack+0x185/0x1d0 lib/dump_stack.c:53
kmsan_report+0x142/0x240 mm/kmsan/kmsan.c:1067
__msan_warning_32+0x6c/0xb0 mm/kmsan/kmsan_instr.c:683
tipc_nl_compat_recv+0x164b/0x2700 net/tipc/netlink_compat.c:1153
genl_family_rcv_msg net/netlink/genetlink.c:599 [inline]
genl_rcv_msg+0x1686/0x1810 net/netlink/genetlink.c:624
netlink_rcv_skb+0x378/0x600 net/netlink/af_netlink.c:2447
genl_rcv+0x63/0x80 net/netlink/genetlink.c:635
netlink_unicast_kernel net/netlink/af_netlink.c:1311 [inline]
netlink_unicast+0x166b/0x1740 net/netlink/af_netlink.c:1337
netlink_sendmsg+0x1048/0x1310 net/netlink/af_netlink.c:1900
sock_sendmsg_nosec net/socket.c:630 [inline]
sock_sendmsg net/socket.c:640 [inline]
___sys_sendmsg+0xec0/0x1310 net/socket.c:2046
__sys_sendmsg net/socket.c:2080 [inline]
SYSC_sendmsg+0x2a3/0x3d0 net/socket.c:2091
SyS_sendmsg+0x54/0x80 net/socket.c:2087
do_syscall_64+0x309/0x430 arch/x86/entry/common.c:287
entry_SYSCALL_64_after_hwframe+0x3d/0xa2
RIP: 0033:0x43fda9
RSP: 002b:00007ffd0c184ba8 EFLAGS: 00000213 ORIG_RAX: 000000000000002e
RAX: ffffffffffffffda RBX: 00000000004002c8 RCX: 000000000043fda9
RDX: 0000000000000000 RSI: 0000000020023000 RDI: 0000000000000003
RBP: 00000000006ca018 R08: 00000000004002c8 R09: 00000000004002c8
R10: 00000000004002c8 R11: 0000000000000213 R12: 00000000004016d0
R13: 0000000000401760 R14: 0000000000000000 R15: 0000000000000000
kmsan_save_stack_with_flags mm/kmsan/kmsan.c:278 [inline]
kmsan_internal_poison_shadow+0xb8/0x1b0 mm/kmsan/kmsan.c:188
kmsan_kmalloc+0x94/0x100 mm/kmsan/kmsan.c:314
kmsan_slab_alloc+0x11/0x20 mm/kmsan/kmsan.c:321
slab_post_alloc_hook mm/slab.h:445 [inline]
slab_alloc_node mm/slub.c:2737 [inline]
__kmalloc_node_track_caller+0xaed/0x11c0 mm/slub.c:4369
__kmalloc_reserve net/core/skbuff.c:138 [inline]
__alloc_skb+0x2cf/0x9f0 net/core/skbuff.c:206
alloc_skb include/linux/skbuff.h:984 [inline]
netlink_alloc_large_skb net/netlink/af_netlink.c:1183 [inline]
netlink_sendmsg+0x9a6/0x1310 net/netlink/af_netlink.c:1875
In tipc_nl_compat_recv(), when the len variable returned by
nlmsg_attrlen() is 0, the message is still treated as a valid one,
which is obviously unresonable. When len is zero, it means the
message not only doesn't contain any valid TLV payload, but also
TLV header is not included. Under this stituation, tlv_type field
in TLV header is still accessed in tipc_nl_compat_dumpit() or
tipc_nl_compat_doit(), but the field space is obviously illegal.
Of course, it is not initialized.
Reported-by: syzbot+bca0dc46634781f08b38@syzkaller.appspotmail.com
Reported-by: syzbot+6bdb590321a7ae40c1a6@syzkaller.appspotmail.com
Signed-off-by: Ying Xue <ying.xue@windriver.com>
commit 974cb0e3e7c963ced06c4e32c5b2884173fa5e01 upstream.
syzbot reported:
BUG: KMSAN: uninit-value in __arch_swab32 arch/x86/include/uapi/asm/swab.h:10 [inline]
BUG: KMSAN: uninit-value in __fswab32 include/uapi/linux/swab.h:59 [inline]
BUG: KMSAN: uninit-value in tipc_nl_compat_name_table_dump+0x4a8/0xba0 net/tipc/netlink_compat.c:826
CPU: 0 PID: 6290 Comm: syz-executor848 Not tainted 4.19.0-rc8+ #70
Call Trace:
dump_stack+0x306/0x460 lib/dump_stack.c:113
kmsan_report+0x1a2/0x2e0 mm/kmsan/kmsan.c:917
__msan_warning+0x7c/0xe0 mm/kmsan/kmsan_instr.c:500
__tipc_nl_compat_dumpit+0x59e/0xdb0 net/tipc/netlink_compat.c:205
tipc_nl_compat_dumpit+0x63a/0x820 net/tipc/netlink_compat.c:270
tipc_nl_compat_handle net/tipc/netlink_compat.c:1151 [inline]
tipc_nl_compat_recv+0x1402/0x2760 net/tipc/netlink_compat.c:1210
genl_rcv_msg+0x185c/0x1a20 net/netlink/genetlink.c:626
netlink_rcv_skb+0x394/0x640 net/netlink/af_netlink.c:2454
netlink_unicast_kernel net/netlink/af_netlink.c:1317 [inline]
netlink_unicast+0x166d/0x1720 net/netlink/af_netlink.c:1343
netlink_sendmsg+0x1391/0x1420 net/netlink/af_netlink.c:1908
sock_sendmsg_nosec net/socket.c:621 [inline]
sock_sendmsg net/socket.c:631 [inline]
___sys_sendmsg+0xe47/0x1200 net/socket.c:2116
__sys_sendmsg net/socket.c:2154 [inline]
__do_sys_sendmsg net/socket.c:2163 [inline]
__se_sys_sendmsg+0x307/0x460 net/socket.c:2161
__x64_sys_sendmsg+0x4a/0x70 net/socket.c:2161
do_syscall_64+0xbe/0x100 arch/x86/entry/common.c:291
entry_SYSCALL_64_after_hwframe+0x63/0xe7
RIP: 0033:0x440179
Code: 18 89 d0 c3 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 00 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 0f 83 fb 13 fc ff c3 66 2e 0f 1f 84 00 00 00 00
RSP: 002b:00007ffecec49318 EFLAGS: 00000213 ORIG_RAX: 000000000000002e
RAX: ffffffffffffffda RBX: 00000000004002c8 RCX: 0000000000440179
RDX: 0000000000000000 RSI: 0000000020000100 RDI: 0000000000000003
RBP: 00000000006ca018 R08: 0000000000000000 R09: 00000000004002c8
R10: 0000000000000000 R11: 0000000000000213 R12: 0000000000401a00
R13: 0000000000401a90 R14: 0000000000000000 R15: 0000000000000000
kmsan_save_stack_with_flags mm/kmsan/kmsan.c:255 [inline]
kmsan_internal_poison_shadow+0xc8/0x1d0 mm/kmsan/kmsan.c:180
kmsan_kmalloc+0xa4/0x120 mm/kmsan/kmsan_hooks.c:104
kmsan_slab_alloc+0x10/0x20 mm/kmsan/kmsan_hooks.c:113
slab_post_alloc_hook mm/slab.h:446 [inline]
slab_alloc_node mm/slub.c:2727 [inline]
__kmalloc_node_track_caller+0xb43/0x1400 mm/slub.c:4360
__alloc_skb+0x422/0xe90 net/core/skbuff.c:206
alloc_skb include/linux/skbuff.h:996 [inline]
netlink_alloc_large_skb net/netlink/af_netlink.c:1189 [inline]
netlink_sendmsg+0xcaf/0x1420 net/netlink/af_netlink.c:1883
We cannot take for granted the thing that the length of data contained
in TLV is longer than the size of struct tipc_name_table_query in
Reported-by: syzbot+06e771a754829716a327@syzkaller.appspotmail.com
commit edf5ff04a45750ac8ce2435974f001dc9cfbf055 upstream.
syzbot reports following splat:
BUG: KMSAN: uninit-value in strlen+0x3b/0xa0 lib/string.c:486
CPU: 1 PID: 9306 Comm: syz-executor172 Not tainted 4.20.0-rc7+ #2
Google 01/01/2011
Call Trace:
dump_stack+0x173/0x1d0 lib/dump_stack.c:113
kmsan_report+0x12e/0x2a0 mm/kmsan/kmsan.c:613
__msan_warning+0x82/0xf0 mm/kmsan/kmsan_instr.c:313
nla_put_string include/net/netlink.h:1154 [inline]
__tipc_nl_compat_link_set net/tipc/netlink_compat.c:708 [inline]
tipc_nl_compat_link_set+0x929/0x1220 net/tipc/netlink_compat.c:744
__tipc_nl_compat_doit net/tipc/netlink_compat.c:311 [inline]
tipc_nl_compat_doit+0x3aa/0xaf0 net/tipc/netlink_compat.c:344
tipc_nl_compat_handle net/tipc/netlink_compat.c:1107 [inline]
tipc_nl_compat_recv+0x14d7/0x2760 net/tipc/netlink_compat.c:1210
netlink_rcv_skb+0x444/0x640 net/netlink/af_netlink.c:2477
netlink_unicast+0xf40/0x1020 net/netlink/af_netlink.c:1336
___sys_sendmsg+0xdb9/0x11b0 net/socket.c:2116
__se_sys_sendmsg+0x305/0x460 net/socket.c:2161
do_syscall_64+0xbc/0xf0 arch/x86/entry/common.c:291
The uninitialised access happened in
nla_put_string(skb, TIPC_NLA_LINK_NAME, lc->name)
This is because lc->name string is not validated before it's used.
Reported-by: syzbot+d78b8a29241a195aefb8@syzkaller.appspotmail.com
commit 0762216c0ad2a2fccd63890648eca491f2c83d9a upstream.
syzbot reported:
BUG: KMSAN: uninit-value in strlen+0x3b/0xa0 lib/string.c:484
CPU: 1 PID: 6371 Comm: syz-executor652 Not tainted 4.19.0-rc8+ #70
Call Trace:
nla_put_string include/net/netlink.h:1011 [inline]
tipc_nl_compat_bearer_enable+0x238/0x7b0 net/tipc/netlink_compat.c:389
tipc_nl_compat_doit+0x39f/0xae0 net/tipc/netlink_compat.c:344
tipc_nl_compat_recv+0x147c/0x2760 net/tipc/netlink_compat.c:1107
RIP: 0033:0x440179
RSP: 002b:00007fffef7beee8 EFLAGS: 00000213 ORIG_RAX: 000000000000002e
The root cause is that we don't validate whether bear name is a valid
string in tipc_nl_compat_bearer_enable().
Meanwhile, we also fix the same issue in the following functions:
tipc_nl_compat_media_set()
tipc_nl_compat_bearer_set()
Reported-by: syzbot+b33d5cae0efd35dbfe77@syzkaller.appspotmail.com
commit 8b66fee7f8ee18f9c51260e7a43ab37db5177a05 upstream.
CPU: 1 PID: 11057 Comm: syz-executor0 Not tainted 4.20.0-rc7+ #2
Call Trace:
__msan_warning+0x82/0xf0 mm/kmsan/kmsan_instr.c:295
tipc_nl_compat_link_reset_stats+0x1f0/0x360 net/tipc/netlink_compat.c:760
RIP: 0033:0x457ec9
Code: 6d b7 fb ff c3 66 2e 0f 1f 84 00 00 00 00 00 66 90 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 0f 83 3b b7 fb ff c3 66 2e 0f 1f 84 00 00 00 00
RSP: 002b:00007f2557338c78 EFLAGS: 00000246 ORIG_RAX: 000000000000002e
RAX: ffffffffffffffda RBX: 0000000000000003 RCX: 0000000000457ec9
RDX: 0000000000000000 RSI: 00000000200001c0 RDI: 0000000000000003
RBP: 000000000073bf00 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000246 R12: 00007f25573396d4
R13: 00000000004cb478 R14: 00000000004d86c8 R15: 00000000ffffffff
kmsan_save_stack_with_flags mm/kmsan/kmsan.c:204 [inline]
kmsan_internal_poison_shadow+0x92/0x150 mm/kmsan/kmsan.c:158
kmsan_kmalloc+0xa6/0x130 mm/kmsan/kmsan_hooks.c:176
kmsan_slab_alloc+0xe/0x10 mm/kmsan/kmsan_hooks.c:185
slab_alloc_node mm/slub.c:2759 [inline]
__kmalloc_node_track_caller+0xe18/0x1030 mm/slub.c:4383
__kmalloc_reserve net/core/skbuff.c:137 [inline]
__alloc_skb+0x309/0xa20 net/core/skbuff.c:205
alloc_skb include/linux/skbuff.h:998 [inline]
The uninitialised access happened in tipc_nl_compat_link_reset_stats:
nla_put_string(skb, TIPC_NLA_LINK_NAME, name)
This is because name string is not validated before it's used.
Reported-by: syzbot+e01d94b5a4c266be6e4c@syzkaller.appspotmail.com
[ Upstream commit ec518f21cb1a1b1f8a516499ea05c60299e04963 ]
Before syzbot/KMSAN bites, add the missing policy for TIPC_NLA_NET_ADDR
Fixes: 27c21416727a ("tipc: add net set to new netlink api")
Cc: Jon Maloy <jon.maloy@ericsson.com>
Cc: Ying Xue <ying.xue@windriver.com>
[ Upstream commit a7d5f107b4978e08eeab599ee7449af34d034053 ]
When the function tipc_accept_from_sock() fails to create an instance of
struct tipc_subscriber it omits to free the already created instance of
struct tipc_conn instance before it returns.
We fix that with this commit.
Reported-by: David S. Miller <davem@davemloft.net>
Signed-off-by: Jon Maloy <jon.maloy@ericsson.com>
[ Upstream commit 35e22e49a5d6a741ebe7f2dd280b2052c3003ef7 ]
In tipc_server_stop(), we iterate over the connections with limiting
factor as server's idr_in_use. We ignore the fact that this variable
is decremented in tipc_close_conn(), leading to premature exit.
In this commit, we iterate until the we have no connections left.
Tested-by: John Thompson <thompa.atl@gmail.com>
Signed-off-by: Parthasarathy Bhuvaragan <parthasarathy.bhuvaragan@ericsson.com>
commit d01332f1acacc0cb43a61f4244dd2b846d4cd585 upstream.
Changing certain link attributes (link tolerance and link priority)
from the TIPC management tool is supposed to automatically take
effect at both endpoints of the affected link.
Currently the media address is not instantiated for the link and is
used uninstantiated when crafting protocol messages designated for the
peer endpoint. This means that changing a link property currently
results in the property being changed on the local machine but the
protocol message designated for the peer gets lost. Resulting in
property discrepancy between the endpoints.
In this patch we resolve this by using the media address from the
link entry and using the bearer transmit function to send it. Hence,
we can now eliminate the redundant function tipc_link_prot_xmit() and
the redundant field tipc_link::media_addr.
Fixes: 2af5ae372a4b (tipc: clean up unused code and structures)
Reviewed-by: Jon Maloy <jon.maloy@ericsson.com>
Reported-by: Jason Hu <huzhijiang@gmail.com>
Signed-off-by: Richard Alpe <richard.alpe@ericsson.com>
[backported to 4.4 by Tommi Rantala]
Signed-off-by: Tommi Rantala <tommi.t.rantala@nokia.com>
[ Upstream commit aad06212d36cf34859428a0a279e5c14ee5c9e26 ]
In commit e3a77561e7d32 ("tipc: split up function tipc_msg_eval()"),
we have updated the function tipc_msg_lookup_dest() to set the error
codes to negative values at destination lookup failures. Thus when
the function sets the error code to -TIPC_ERR_NO_NAME, its inserted
into the 4 bit error field of the message header as 0xf instead of
TIPC_ERR_NO_NAME (1). The value 0xf is an unknown error code.
In this commit, we set only positive error code.
Fixes: e3a77561e7d32 ("tipc: split up function tipc_msg_eval()")
[ Upstream commit 5bfd37b4de5c98e86b12bd13be5aa46c7484a125 ]
syszkaller reported use-after-free in tipc [1]
When msg->rep skb is freed, set the pointer to NULL,
so that caller does not free it again.
[1]
BUG: KASAN: use-after-free in skb_push+0xd4/0xe0 net/core/skbuff.c:1466
Read of size 8 at addr ffff8801c6e71e90 by task syz-executor5/4115
CPU: 1 PID: 4115 Comm: syz-executor5 Not tainted 4.13.0-rc4+ #32
Call Trace:
__dump_stack lib/dump_stack.c:16 [inline]
dump_stack+0x194/0x257 lib/dump_stack.c:52
print_address_description+0x73/0x250 mm/kasan/report.c:252
kasan_report_error mm/kasan/report.c:351 [inline]
kasan_report+0x24e/0x340 mm/kasan/report.c:409
__asan_report_load8_noabort+0x14/0x20 mm/kasan/report.c:430
tipc_nl_compat_recv+0x833/0x18f0 net/tipc/netlink_compat.c:1209
genl_family_rcv_msg+0x7b7/0xfb0 net/netlink/genetlink.c:598
genl_rcv_msg+0xb2/0x140 net/netlink/genetlink.c:623
netlink_rcv_skb+0x216/0x440 net/netlink/af_netlink.c:2397
genl_rcv+0x28/0x40 net/netlink/genetlink.c:634
netlink_unicast_kernel net/netlink/af_netlink.c:1265 [inline]
netlink_unicast+0x4e8/0x6f0 net/netlink/af_netlink.c:1291
netlink_sendmsg+0xa4a/0xe60 net/netlink/af_netlink.c:1854
sock_sendmsg_nosec net/socket.c:633 [inline]
sock_sendmsg+0xca/0x110 net/socket.c:643
sock_write_iter+0x31a/0x5d0 net/socket.c:898
call_write_iter include/linux/fs.h:1743 [inline]
new_sync_write fs/read_write.c:457 [inline]
__vfs_write+0x684/0x970 fs/read_write.c:470
vfs_write+0x189/0x510 fs/read_write.c:518
SYSC_write fs/read_write.c:565 [inline]
SyS_write+0xef/0x220 fs/read_write.c:557
entry_SYSCALL_64_fastpath+0x1f/0xbe
RIP: 0033:0x4512e9
RSP: 002b:00007f3bc8184c08 EFLAGS: 00000216 ORIG_RAX: 0000000000000001
RAX: ffffffffffffffda RBX: 0000000000718000 RCX: 00000000004512e9
RDX: 0000000000000020 RSI: 0000000020fdb000 RDI: 0000000000000006
RBP: 0000000000000086 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000216 R12: 00000000004b5e76
R13: 00007f3bc8184b48 R14: 00000000004b5e86 R15: 0000000000000000
Allocated by task 4115:
save_stack_trace+0x16/0x20 arch/x86/kernel/stacktrace.c:59
save_stack+0x43/0xd0 mm/kasan/kasan.c:447
set_track mm/kasan/kasan.c:459 [inline]
kasan_kmalloc+0xad/0xe0 mm/kasan/kasan.c:551
kasan_slab_alloc+0x12/0x20 mm/kasan/kasan.c:489
kmem_cache_alloc_node+0x13d/0x750 mm/slab.c:3651
__alloc_skb+0xf1/0x740 net/core/skbuff.c:219
alloc_skb include/linux/skbuff.h:903 [inline]
tipc_tlv_alloc+0x26/0xb0 net/tipc/netlink_compat.c:148
tipc_nl_compat_dumpit+0xf2/0x3c0 net/tipc/netlink_compat.c:248
tipc_nl_compat_handle net/tipc/netlink_compat.c:1130 [inline]
tipc_nl_compat_recv+0x756/0x18f0 net/tipc/netlink_compat.c:1199
Freed by task 4115:
kasan_slab_free+0x71/0xc0 mm/kasan/kasan.c:524
__cache_free mm/slab.c:3503 [inline]
kmem_cache_free+0x77/0x280 mm/slab.c:3763
kfree_skbmem+0x1a1/0x1d0 net/core/skbuff.c:622
__kfree_skb net/core/skbuff.c:682 [inline]
kfree_skb+0x165/0x4c0 net/core/skbuff.c:699
tipc_nl_compat_dumpit+0x36a/0x3c0 net/tipc/netlink_compat.c:260
The buggy address belongs to the object at ffff8801c6e71dc0
which belongs to the cache skbuff_head_cache of size 224
The buggy address is located 208 bytes inside of
224-byte region [ffff8801c6e71dc0, ffff8801c6e71ea0)
The buggy address belongs to the page:
page:ffffea00071b9c40 count:1 mapcount:0 mapping:ffff8801c6e71000 index:0x0
flags: 0x200000000000100(slab)
raw: 0200000000000100 ffff8801c6e71000 0000000000000000 000000010000000c
raw: ffffea0007224a20 ffff8801d98caf48 ffff8801d9e79040 0000000000000000
page dumped because: kasan: bad access detected
Memory state around the buggy address:
ffff8801c6e71d80: fc fc fc fc fc fc fc fc fb fb fb fb fb fb fb fb
ffff8801c6e71e00: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
>ffff8801c6e71e80: fb fb fb fb fc fc fc fc fc fc fc fc fc fc fc fc
ffff8801c6e71f00: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
ffff8801c6e71f80: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
[ Upstream commit 4c887aa65d38633885010277f3482400681be719 ]
In tipc_conn_sendmsg(), we first queue the request to the outqueue
followed by the connection state check. If the connection is not
connected, we should not queue this message.
In this commit, we reject the messages if the connection state is
not CF_CONNECTED.
commit 3de81b758853f0b29c61e246679d20b513c4cfec upstream.
Qian Zhang (张谦) reported a potential socket buffer overflow in
tipc_msg_build() which is also known as CVE-2016-8632: due to
insufficient checks, a buffer overflow can occur if MTU is too short for
even tipc headers. As anyone can set device MTU in a user/net namespace,
this issue can be abused by a regular user.
As agreed in the discussion on Ben Hutchings' original patch, we should
check the MTU at the moment a bearer is attached rather than for each
processed packet. We also need to repeat the check when bearer MTU is
adjusted to new device MTU. UDP case also needs a check to avoid
overflow when calculating bearer MTU.
Fixes: b97bf3fd8f6a ("[TIPC] Initial merge")
Signed-off-by: Michal Kubecek <mkubecek@suse.cz>
Reported-by: Qian Zhang (张谦) <zhangqian-c@360.cn>
[bwh: Backported to 4.4:
- Adjust context
- NETDEV_GOING_DOWN and NETDEV_CHANGEMTU cases in net notifier were combined]
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit f1d048f24e66ba85d3dabf3d076cefa5f2b546b0 upstream.
We sometimes observe a 'deadly embrace' type deadlock occurring
between mutually connected sockets on the same node. This happens
when the one-hour peer supervision timers happen to expire
simultaneously in both sockets.
The scenario is as follows:
CPU 1: CPU 2:
tipc_sk_timeout(sk1) tipc_sk_timeout(sk2)
lock(sk1.slock) lock(sk2.slock)
msg_create(probe) msg_create(probe)
unlock(sk1.slock) unlock(sk2.slock)
tipc_node_xmit_skb() tipc_node_xmit_skb()
tipc_node_xmit() tipc_node_xmit()
tipc_sk_rcv(sk2) tipc_sk_rcv(sk1)
lock(sk2.slock) lock((sk1.slock)
filter_rcv() filter_rcv()
tipc_sk_proto_rcv() tipc_sk_proto_rcv()
msg_create(probe_rsp) msg_create(probe_rsp)
tipc_sk_respond() tipc_sk_respond()
tipc_sk_rcv(sk1) tipc_sk_rcv(sk2)
lock((sk1.slock) lock((sk2.slock)
===> DEADLOCK ===> DEADLOCK
Further analysis reveals that there are three different locations in the
socket code where tipc_sk_respond() is called within the context of the
socket lock, with ensuing risk of similar deadlocks.
We now solve this by passing a buffer queue along with all upcalls where
sk_lock.slock may potentially be held. Response or rejected message
buffers are accumulated into this queue instead of being sent out
directly, and only sent once we know we are safely outside the slock
context.
Reported-by: GUNA <gbalasun@gmail.com>
commit d2f394dc4816b7bd1b44981d83509f18f19c53f0 upstream.
In a dual bearer configuration, if the second tipc link becomes
active while the first link still has pending nametable "bulk"
updates, it randomly leads to reset of the second link.
When a link is established, the function named_distribute(),
fills the skb based on node mtu (allows room for TUNNEL_PROTOCOL)
with NAME_DISTRIBUTOR message for each PUBLICATION.
However, the function named_distribute() allocates the buffer by
increasing the node mtu by INT_H_SIZE (to insert NAME_DISTRIBUTOR).
This consumes the space allocated for TUNNEL_PROTOCOL.
When establishing the second link, the link shall tunnel all the
messages in the first link queue including the "bulk" update.
As size of the NAME_DISTRIBUTOR messages while tunnelling, exceeds
the link mtu the transmission fails (-EMSGSIZE).
Thus, the synch point based on the message count of the tunnel
packets is never reached leading to link timeout.
In this commit, we adjust the size of name distributor message so that
they can be tunnelled.
commit c4282ca76c5b81ed73ef4c5eb5c07ee397e51642 upstream.
commit 88e8ac7000dc ("tipc: reduce transmission rate of reset messages
when link is down") revealed a flaw in the node FSM, as defined in
the log of commit 66996b6c47ed ("tipc: extend node FSM").
We see the following scenario:
1: Node B receives a RESET message from node A before its link endpoint
is fully up, i.e., the node FSM is in state SELF_UP_PEER_COMING. This
event will not change the node FSM state, but the (distinct) link FSM
will move to state RESETTING.
2: As an effect of the previous event, the local endpoint on B will
declare node A lost, and post the event SELF_DOWN to the its node
FSM. This moves the FSM state to SELF_DOWN_PEER_LEAVING, meaning
that no messages will be accepted from A until it receives another
RESET message that confirms that A's endpoint has been reset. This
is wasteful, since we know this as a fact already from the first
received RESET, but worse is that the link instance's FSM has not
wasted this information, but instead moved on to state ESTABLISHING,
meaning that it repeatedly sends out ACTIVATE messages to the reset
peer A.
3: Node A will receive one of the ACTIVATE messages, move its link FSM
to state ESTABLISHED, and start repeatedly sending out STATE messages
to node B.
4: Node B will consistently drop these messages, since it can only accept
accept a RESET according to its node FSM.
5: After four lost STATE messages node A will reset its link and start
repeatedly sending out RESET messages to B.
6: Because of the reduced send rate for RESET messages, it is very
likely that A will receive an ACTIVATE (which is sent out at a much
higher frequency) before it gets the chance to send a RESET, and A
may hence quickly move back to state ESTABLISHED and continue sending
out STATE messages, which will again be dropped by B.
7: GOTO 5.
8: After having repeated the cycle 5-7 a number of times, node A will
by chance get in between with sending a RESET, and the situation is
resolved.
Unfortunately, we have seen that it may take a substantial amount of
time before this vicious loop is broken, sometimes in the order of
minutes.
We correct this by making a small correction to the node FSM: When a
node in state SELF_UP_PEER_COMING receives a SELF_DOWN event, it now
moves directly back to state SELF_DOWN_PEER_DOWN, instead of as now
SELF_DOWN_PEER_LEAVING. This is logically consistent, since we don't
need to wait for RESET confirmation from of an endpoint that we alread
know has been reset. It also means that node B in the scenario above
will not be dropping incoming STATE messages, and the link can come up
immediately.
Finally, a symmetry comparison reveals that the FSM has a similar
error when receiving the event PEER_DOWN in state PEER_UP_SELF_COMING.
Instead of moving to PERR_DOWN_SELF_LEAVING, it should move directly
to SELF_DOWN_PEER_DOWN. Although we have never seen any negative effect
of this logical error, we choose fix this one, too.
The node FSM looks as follows after those changes:
| PEER_DOWN_EVT|
|SELF_DOWN_EVT | | |
| |NODE_ | |NODE_ | |
| +----------|FAILINGOVER|<---------|SYNCHING |-----------+ |
| |SELF_ +-----------+ FAILOVER_+-----------+ PEER_ | |
| |DOWN_EVT | A BEGIN_EVT A | DOWN_EVT| |
| | |FAILOVER_ |FAILOVER_ |SYNCH_ |SYNCH_ | |
| | |END_EVT |BEGIN_EVT |BEGIN_EVT|END_EVT | |
| | +-------->| SELF_UP_ |<-------+ | |
| | +-----------------| PEER_UP |----------------+ | |
| | |SELF_DOWN_EVT +--------------+ PEER_DOWN_EVT| | |
| | | A A | | |
| | | PEER_UP_EVT| |SELF_UP_EVT | | |
V V V | | V V V
|SELF_DOWN_ | |SELF_UP_ | |PEER_UP_ | |PEER_DOWN |
|PEER_LEAVING| |PEER_COMING| |SELF_COMING| |SELF_LEAVING|
| | A A | |
| SELF_ | |SELF_ |PEER_ |PEER_ |
| DOWN_EVT| |UP_EVT |UP_EVT |DOWN_EVT |
|PEER_DOWN_EVT +--->| SELF_DOWN_ |<---+ SELF_DOWN_EVT|
+------------------->| PEER_DOWN |<--------------------+
commit 7c8bcfb1255fe9d929c227d67bdcd84430fd200b upstream.
In the refactoring commit d570d86497ee ("tipc: enqueue arrived buffers
in socket in separate function") we did by accident replace the test
if (sk->sk_backlog.len == 0)
atomic_set(&tsk->dupl_rcvcnt, 0);
with
if (sk->sk_backlog.len)
This effectively disables the compensation we have for the double
receive buffer accounting that occurs temporarily when buffers are
moved from the backlog to the socket receive queue. Until now, this
has gone unnoticed because of the large receive buffer limits we are
applying, but becomes indispensable when we reduce this buffer limit
later in this series.
We now fix this by inverting the mentioned condition.
commit 541726abe7daca64390c2ec34e6a203145f1686d upstream.
Nametable updates received from the network that cannot be applied
immediately are placed on a defer queue. This queue is global to the
TIPC module, which might cause problems when using TIPC in containers.
To prevent nametable updates from escaping into the wrong namespace,
we make the queue pernet instead.
Signed-off-by: Erik Hugne <erik.hugne@gmail.com>
commit 9bd160bfa27fa41927dbbce7ee0ea779700e09ef upstream.
Expand headroom further in order to be able to fit the larger IPv6
header. Prior to this patch this caused a skb under panic for certain
tipc packets when using IPv6 UDP bearer(s).
commit d25a01257e422a4bdeb426f69529d57c73b235fe upstream.
When the TIPC module is unloaded, we have identified a race condition
that allows a node reference counter to go to zero and the node instance
being freed before the node timer is finished with accessing it. This
leads to occasional crashes, especially in multi-namespace environments.
The scenario goes as follows:
CPU0:(node_stop) CPU1:(node_timeout) // ref == 2
1: if(!mod_timer())
2: if (del_timer())
3: tipc_node_put() // ref -> 1
4: tipc_node_put() // ref -> 0
5: kfree_rcu(node);
6: tipc_node_get(node)
7: // BOOM!
We now clean up this functionality as follows:
1) We remove the node pointer from the node lookup table before we
attempt deactivating the timer. This way, we reduce the risk that
tipc_node_find() may obtain a valid pointer to an instance marked
for deletion; a harmless but undesirable situation.
2) We use del_timer_sync() instead of del_timer() to safely deactivate
the node timer without any risk that it might be reactivated by the
timeout handler. There is no risk of deadlock here, since the two
functions never touch the same spinlocks.
3: We remove a pointless tipc_node_get() + tipc_node_put() from the
timeout handler.
Reported-by: Zhijiang Hu <huzhijiang@gmail.com>
[ Upstream commit d2fbdf76b85bcdfe57b8ef2ba09d20e8ada79abd ]
tipc_msg_create() can return a NULL skb and if so, we shouldn't try to
call tipc_node_xmit_skb() on it.
general protection fault: 0000 [#1] PREEMPT SMP KASAN
CPU: 3 PID: 30298 Comm: trinity-c0 Not tainted 4.7.0-rc7+ #19
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
task: ffff8800baf09980 ti: ffff8800595b8000 task.ti: ffff8800595b8000
RIP: 0010:[<ffffffff830bb46b>] [<ffffffff830bb46b>] tipc_node_xmit_skb+0x6b/0x140
RSP: 0018:ffff8800595bfce8 EFLAGS: 00010246
RAX: 0000000000000000 RBX: 0000000000000000 RCX: 000000003023b0e0
RDX: 0000000000000000 RSI: dffffc0000000000 RDI: ffffffff83d12580
RBP: ffff8800595bfd78 R08: ffffed000b2b7f32 R09: 0000000000000000
R10: fffffbfff0759725 R11: 0000000000000000 R12: 1ffff1000b2b7f9f
R13: ffff8800595bfd58 R14: ffffffff83d12580 R15: dffffc0000000000
FS: 00007fcdde242700(0000) GS:ffff88011af80000(0000) knlGS:0000000000000000
CR2: 00007fcddde1db10 CR3: 000000006874b000 CR4: 00000000000006e0
DR0: 00007fcdde248000 DR1: 00007fcddd73d000 DR2: 00007fcdde248000
DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000090602
Stack:
0000000000000018 0000000000000018 0000000041b58ab3 ffffffff83954208
ffffffff830bb400 ffff8800595bfd30 ffffffff8309d767 0000000000000018
0000000000000018 ffff8800595bfd78 ffffffff8309da1a 00000000810ee611
Call Trace:
[<ffffffff830c84a3>] tipc_shutdown+0x553/0x880
[<ffffffff825b4a3b>] SyS_shutdown+0x14b/0x170
[<ffffffff8100334c>] do_syscall_64+0x19c/0x410
[<ffffffff83295ca5>] entry_SYSCALL64_slow_path+0x25/0x25
Code: 90 00 b4 0b 83 c7 00 f1 f1 f1 f1 4c 8d 6d e0 c7 40 04 00 00 00 f4 c7 40 08 f3 f3 f3 f3 48 89 d8 48 c1 e8 03 c7 45 b4 00 00 00 00 <80> 3c 30 00 75 78 48 8d 7b 08 49 8d 75 c0 48 b8 00 00 00 00 00
RIP [<ffffffff830bb46b>] tipc_node_xmit_skb+0x6b/0x140
RSP <ffff8800595bfce8>
---[ end trace 57b0484e351e71f1 ]---
I feel like we should maybe return -ENOMEM or -ENOBUFS, but I'm not sure
userspace is equipped to handle that. Anyway, this is better than a GPF
and looks somewhat consistent with other tipc_msg_create() callers.
Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com>
commit c7cad0d6f70cd4ce8644ffe528a4df1cdc2e77f5 upstream.
In commit 5cbb28a4bf65c7e4 ("tipc: linearize arriving NAME_DISTR
and LINK_PROTO buffers") we added linearization of NAME_DISTRIBUTOR,
LINK_PROTOCOL/RESET and LINK_PROTOCOL/ACTIVATE to the function
tipc_udp_recv(). The location of the change was selected in order
to make the commit easily appliable to 'net' and 'stable'.
We now move this linearization to where it should be done, in the
functions tipc_named_rcv() and tipc_link_proto_rcv() respectively.
Reviewed-by: Ying Xue <ying.xue@windriver.com>
Signed-off-by: Juerg Haefliger <juerg.haefliger@hpe.com>
[ Upstream commit 55e77a3e8297581c919b45adcc4d0815b69afa84 ]
Fix incorrect use of nla_strlcpy() where the first NLA_HDRLEN bytes
of the link name where left out.
Making the output of tipc-config -ls look something like:
Link statistics:
dcast-link
1:data0-1.1.2:data0
1:data0-1.1.3:data0
Also, for the record, the patch that introduce this regression
claims "Sending the whole object out can cause a leak". Which isn't
very likely as this is a compat layer, where the data we are parsing
is generated by us and we know the string to be NULL terminated. But
you can of course never be to secure.
Fixes: 5d2be1422e02 (tipc: fix an infoleak in tipc_nl_compat_link_dump)
[ Upstream commit 5d2be1422e02ccd697ccfcd45c85b4a26e6178e2 ]
link_info.str is a char array of size 60. Memory after the NULL
byte is not initialized. Sending the whole object out can cause
a leak.
Signed-off-by: Kangjie Lu <kjlu@gatech.edu>
[ Upstream commit 4de13d7ed6ffdcbb34317acaa9236f121176f5f8 ]
commit 4d5cfcba2f6e ('tipc: fix connection abort during subscription
cancel'), removes the check for a valid subscription before calling
tipc_nametbl_subscribe().
This will lead to a nullptr exception when we process a
subscription cancel request. For a cancel request, a null
subscription is passed to tipc_nametbl_subscribe() resulting
in exception.
In this commit, we call tipc_nametbl_subscribe() only for
a valid subscription.
Fixes: 4d5cfcba2f6e ('tipc: fix connection abort during subscription cancel')
Reported-by: Anders Widell <anders.widell@ericsson.com>
[ Upstream commit 03aaaa9b941e136757b55c4cf775aab6068dfd94 ]
The publication field of the old netlink API should contain the
publication key and not the publication reference.
Fixes: 44a8ae94fd55 (tipc: convert legacy nl name table dump to nl compat)
[ Upstream commit 45e093ae2830cd1264677d47ff9a95a71f5d9f9c ]
Make sure the socket for which the user is listing publication exists
before parsing the socket netlink attributes.
Prior to this patch a call without any socket caused a NULL pointer
dereference in tipc_nl_publ_dump().
Tested-and-reported-by: Baozeng Ding <sploving1@gmail.com>
Acked-by: Jon Maloy <jon.maloy@ericsson.cm>
[ Upstream commit f214fc402967e1bc94ad7f39faa03db5813d6849 ]
reverts commit 94153e36e709e ("tipc: use existing sk_write_queue for
outgoing packet chain")
In Commit 94153e36e709e, we assume that we fill & empty the socket's
sk_write_queue within the same lock_sock() session.
This is not true if the link is congested. During congestion, the
socket lock is released while we wait for the congestion to cease.
This implementation causes a nullptr exception, if the user space
program has several threads accessing the same socket descriptor.
Consider two threads of the same program performing the following:
Thread1 Thread2
Enter tipc_sendmsg() Enter tipc_sendmsg()
lock_sock() lock_sock()
Enter tipc_link_xmit(), ret=ELINKCONG spin on socket lock..
sk_wait_event() :
release_sock() grab socket lock
: Enter tipc_link_xmit(), ret=0
: release_sock()
Wakeup after congestion
lock_sock()
skb = skb_peek(pktchain);
!! TIPC_SKB_CB(skb)->wakeup_pending = tsk->link_cong;
In this case, the second thread transmits the buffers belonging to
both thread1 and thread2 successfully. When the first thread wakeup
after the congestion it assumes that the pktchain is intact and
operates on the skb's in it, which leads to the following exception:
[2102.439969] BUG: unable to handle kernel NULL pointer dereference at 00000000000000d0
[2102.440074] IP: [<ffffffffa005f330>] __tipc_link_xmit+0x2b0/0x4d0 [tipc]
[2102.440074] PGD 3fa3f067 PUD 3fa6b067 PMD 0
[2102.440074] Oops: 0000 [#1] SMP
[2102.440074] CPU: 2 PID: 244 Comm: sender Not tainted 3.12.28 #1
[2102.440074] RIP: 0010:[<ffffffffa005f330>] [<ffffffffa005f330>] __tipc_link_xmit+0x2b0/0x4d0 [tipc]
[2102.440074] Call Trace:
[2102.440074] [<ffffffff8163f0b9>] ? schedule+0x29/0x70
[2102.440074] [<ffffffffa006a756>] ? tipc_node_unlock+0x46/0x170 [tipc]
[2102.440074] [<ffffffffa005f761>] tipc_link_xmit+0x51/0xf0 [tipc]
[2102.440074] [<ffffffffa006d8ae>] tipc_send_stream+0x11e/0x4f0 [tipc]
[2102.440074] [<ffffffff8106b150>] ? __wake_up_sync+0x20/0x20
[2102.440074] [<ffffffffa006dc9c>] tipc_send_packet+0x1c/0x20 [tipc]
[2102.440074] [<ffffffff81502478>] sock_sendmsg+0xa8/0xd0
[2102.440074] [<ffffffff81507895>] ? release_sock+0x145/0x170
[2102.440074] [<ffffffff815030d8>] ___sys_sendmsg+0x3d8/0x3e0
[2102.440074] [<ffffffff816426ae>] ? _raw_spin_unlock+0xe/0x10
[2102.440074] [<ffffffff81115c2a>] ? handle_mm_fault+0x6ca/0x9d0
[2102.440074] [<ffffffff8107dd65>] ? set_next_entity+0x85/0xa0
[2102.440074] [<ffffffff816426de>] ? _raw_spin_unlock_irq+0xe/0x20
[2102.440074] [<ffffffff8107463c>] ? finish_task_switch+0x5c/0xc0
[2102.440074] [<ffffffff8163ea8c>] ? __schedule+0x34c/0x950
[2102.440074] [<ffffffff81504e12>] __sys_sendmsg+0x42/0x80
[2102.440074] [<ffffffff81504e62>] SyS_sendmsg+0x12/0x20
[2102.440074] [<ffffffff8164aed2>] system_call_fastpath+0x16/0x1b
In this commit, we maintain the skb list always in the stack.
[ Upstream commit b53ce3e7d407aa4196877a48b8601181162ab158 ]
tipc_bcast_unlock need to be unlocked in error path.
Signed-off-by: Insu Yun <wuninsu@gmail.com>
[ Upstream commit d5c91fb72f1652ea3026925240a0998a42ddb16b ]
In commit 5266698661401a ("tipc: let broadcast packet reception
use new link receive function") we introduced a new per-node
broadcast reception link instance. This link is created at the
moment the node itself is created. Unfortunately, the allocation
is done after the node instance has already been added to the node
lookup hash table. This creates a potential race condition, where
arriving broadcast packets are able to find and access the node
before it has been fully initialized, and before the above mentioned
link has been created. The result is occasional crashes in the function
tipc_bcast_rcv(), which is trying to access the not-yet existing link.
We fix this by deferring the addition of the node instance until after
it has been fully initialized in the function tipc_node_create().
[ Upstream commit 4d5cfcba2f6ec494d8810b9e3c0a7b06255c8067 ]
In 'commit 7fe8097cef5f ("tipc: fix nullpointer bug when subscribing
to events")', we terminate the connection if the subscription
creation fails.
In the same commit, the subscription creation result was based on
the value of the subscription pointer (set in the function) instead
of the return code.
Unfortunately, the same function tipc_subscrp_create() handles
subscription cancel request. For a subscription cancellation request,
the subscription pointer cannot be set. Thus if a subscriber has
several subscriptions and cancels any of them, the connection is
terminated.
In this commit, we terminate the connection based on the return value
of tipc_subscrp_create().
Fixes: commit 7fe8097cef5f ("tipc: fix nullpointer bug when subscribing to events")
Coverity says:
*** CID 1338065: Error handling issues (CHECKED_RETURN)
/net/tipc/udp_media.c: 162 in tipc_udp_send_msg()
156 struct udp_media_addr *dst = (struct udp_media_addr *)&dest->value;
157 struct udp_media_addr *src = (struct udp_media_addr *)&b->addr.value;
158 struct sk_buff *clone;
159 struct rtable *rt;
160
161 if (skb_headroom(skb) < UDP_MIN_HEADROOM)
>>> Calling "pskb_expand_head" without checking return value (as is done elsewhere 51 out of 56 times).
162 pskb_expand_head(skb, UDP_MIN_HEADROOM, 0, GFP_ATOMIC);
163
164 clone = skb_clone(skb, GFP_ATOMIC);
165 skb_set_inner_protocol(clone, htons(ETH_P_TIPC));
166 ub = rcu_dereference_rtnl(b->media_ptr);
167 if (!ub) {
When expanding buffer headroom over udp tunnel with pskb_expand_head(),
it's unfortunate that we don't check its return value. As a result, if
the function returns an error code due to the lack of memory, it may
cause unpredictable consequence as we unconditionally consider that
it's always successful.
Fixes: e53567948f82 ("tipc: conditionally expand buffer headroom over udp tunnel")
Reported-by: <scan-admin@coverity.com>
Cc: Stephen Hemminger <stephen@networkplumber.org>
