The ip/udp bearer can be configured in a point-to-point
mode by specifying both local and remote ip/hostname,
or it can be enabled in multicast mode, where links are
established to all tipc nodes that have joined the same
multicast group. The multicast IP address is generated
based on the TIPC network ID, but can be overridden by
using another multicast address as remote ip.
Signed-off-by: Erik Hugne <erik.hugne@ericsson.com>
Reviewed-by: Jon Maloy <jon.maloy@ericsson.com>
Reviewed-by: Ying Xue <ying.xue@windriver.com>
The payload area following the TIPC discovery message header is an
opaque area defined by the media. INT_H_SIZE was enough for
Ethernet/IB/IPv4 but needs to be expanded to carry IPv6 addressing
information.
drivers/net/ethernet/rocker/rocker.c
The rocker commit was two overlapping changes, one to rename
the ->vport member to ->pport, and another making the bitmask
expression use '1ULL' instead of plain '1'.
After TIPC doesn't depend on iocb argument in its internal
implementations of sendmsg() and recvmsg() hooks defined in proto
structure, no any user is using iocb argument in them at all now.
Then we can drop the redundant iocb argument completely from kinds of
implementations of both sendmsg() and recvmsg() in the entire
networking stack.
Suggested-by: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: Ying Xue <ying.xue@windriver.com>
Currently the iocb argument is used to idenfiy whether or not socket
lock is hold before tipc_sendmsg()/tipc_send_stream() is called. But
this usage prevents iocb argument from being dropped through sendmsg()
at socket common layer. Therefore, in the commit we introduce two new
functions called __tipc_sendmsg() and __tipc_send_stream(). When they
are invoked, it assumes that their callers have taken socket lock,
thereby avoiding the weird usage of iocb argument.
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Reviewed-by: Erik Hugne <erik.hugne@ericsson.com>
With the exception of infiniband media which does not use media
offsets, the media address is always located at offset 4 in the
media info field as defined by the protocol, so we move the
definition to the generic bearer.h
The TIPC_MEDIA_ADDR_SIZE and TIPC_MEDIA_ADDR_OFFSET names
are misleading, as they actually define the size and offset of
the whole media info field and not the address part. This patch
does not have any functional changes.
If a bearer is disabled by manual intervention, all links over that
bearer should be purged, indicated with the 'shutting_down' flag.
Otherwise tipc will get confused if a new bearer is enabled using
a different media type.
If a subscription request is sent to a topology server
connection, and any error occurs (malformed request, oom
or limit reached) while processing this request, TIPC should
terminate the subscriber connection. While doing so, it tries
to access fields in an already freed (or never allocated)
subscription element leading to a nullpointer exception.
We fix this by removing the subscr_terminate function and
terminate the connection immediately upon any subscription
failure.
The TIPC name distributor pushes topology updates to the cluster
neighbors. Currently this is done in a unicast manner, and the
skb holding the update is cloned for each cluster member. This
is unnecessary, as we only modify the destnode field in the header
so we change it to do pskb_copy instead.
Currently, all real users of rhashtable default their grow and shrink
decision functions to rht_grow_above_75() and rht_shrink_below_30(),
so that there's currently no need to have this explicitly selectable.
It can/should be generic and private inside rhashtable until a real
use case pops up. Since we can make this private, we'll save us this
additional indirection layer and can improve insertion/deletion time
as well.
Reference: http://patchwork.ozlabs.org/patch/443040/
Suggested-by: David S. Miller <davem@davemloft.net>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Thomas Graf <tgraf@suug.ch>
tipc_snprintf() was heavily utilized by the old netlink API which no
longer exists (now netlink compat).
In this patch we swap tipc_snprintf() to the identical scnprintf() in
the only remaining occurrence.
Signed-off-by: Richard Alpe <richard.alpe@ericsson.com>
Add TIPC_CMD_NOOP to compat layer and remove the old framework.
All legacy nl commands are now converted to the compat layer in
netlink_compat.c.
Convert TIPC_CMD_SHOW_STATS to compat layer. This command does not
have any counterpart in the new API, meaning it now solely exists as a
function in the compat layer.
Convert TIPC_CMD_GET_NETID to compat dumpit.
Convert TIPC_CMD_SET_NETID to compat doit.
Convert TIPC_CMD_SET_NODE_ADDR to compat doit.
Convert TIPC_CMD_GET_NODES to compat dumpit and remove global node
counter solely used by the legacy API.
Convert TIPC_CMD_GET_MEDIA_NAMES to compat dumpit.
Convert socket (port) listing to compat dumpit call. If a socket
(port) has publications a second dumpit call is issued to collect them
and format then into the legacy buffer before continuing to process
the sockets (ports).
Command converted in this patch:
TIPC_CMD_SHOW_PORTS
Add functionality for printing a dump header and convert
TIPC_CMD_SHOW_NAME_TABLE to compat dumpit.
Convert TIPC_CMD_RESET_LINK_STATS to compat doit.
Convert setting of link proprieties to compat doit calls.
Commands converted in this patch:
TIPC_CMD_SET_LINK_TOL
TIPC_CMD_SET_LINK_PRI
TIPC_CMD_SET_LINK_WINDOW
Convert TIPC_CMD_GET_LINKS to compat dumpit and remove global link
Add functionality for safely appending string data to a TLV without
keeping write count in the caller.
Convert TIPC_CMD_SHOW_LINK_STATS to compat dumpit.
Introduce a framework for transcoding legacy nl action into actions
(.doit) calls from the new nl API. This is done by converting the
incoming TLV data into netlink data with nested netlink attributes.
Unfortunately due to the randomness of the legacy API we can't do this
generically so each legacy netlink command requires a specific
transcoding recipe. In this case for bearer enable and bearer disable.
Convert TIPC_CMD_ENABLE_BEARER and TIPC_CMD_DISABLE_BEARER into doit
compat calls.
Introduce a framework for dumping netlink data from the new netlink
API and formatting it to the old legacy API format. This is done by
looping the dump data and calling a format handler for each entity, in
this case a bearer.
We dump until either all data is dumped or we reach the limited buffer
size of the legacy API. Remember, the legacy API doesn't scale.
In this commit we convert TIPC_CMD_GET_BEARER_NAMES to use the compat
layer.
The new netlink API is no longer "v2" but rather the standard API and
the legacy API is now "nl compat". We split them into separate
start/stop and put them in different files in order to further
distinguish them.
In commit c637c1035534867b85b78b453c38c495b58e2c5a ("tipc: resolve race
problem at unicast message reception") we introduced a time limit
for how long the function tipc_sk_eneque() would be allowed to execute
its loop. Unfortunately, the test for when this limit is passed was put
in the wrong place, resulting in a lost message when the test is true.
We fix this by moving the test to before we dequeue the next buffer
from the input queue.
Signed-off-by: Jon Maloy <jon.maloy@ericsson.com>
In a previous commit in this series we resolved a race problem during
unicast message reception.
Here, we resolve the same problem at multicast reception. We apply the
same technique: an input queue serializing the delivery of arriving
buffers. The main difference is that here we do it in two steps.
First, the broadcast link feeds arriving buffers into the tail of an
arrival queue, which head is consumed at the socket level, and where
destination lookup is performed. Second, if the lookup is successful,
the resulting buffer clones are fed into a second queue, the input
queue. This queue is consumed at reception in the socket just like
in the unicast case. Both queues are protected by the same lock, -the
one of the input queue.
The structure 'tipc_port_list' is used to collect port numbers
representing multicast destination socket on a receiving node.
The list is not based on a standard linked list, and is in reality
optimized for the uncommon case that there are more than one
multicast destinations per node. This makes the list handling
unecessarily complex, and as a consequence, even the socket
multicast reception becomes more complex.
In this commit, we replace 'tipc_port_list' with a new 'struct
tipc_plist', which is based on a standard list. We give the new
list stack (push/pop) semantics, someting that simplifies
the implementation of the function tipc_sk_mcast_rcv().
The new input message queue in struct tipc_link can be used for
delivering connection abort messages to subscribing sockets. This
makes it possible to simplify the code for such cases.
This commit removes the temporary list in tipc_node_unlock()
used for transforming abort subscriptions to messages. Instead, the
abort messages are now created at the moment of lost contact, and
then added to the last failed link's generic input queue for delivery
to the sockets concerned.
TIPC handles message cardinality and sequencing at the link layer,
before passing messages upwards to the destination sockets. During the
upcall from link to socket no locks are held. It is therefore possible,
and we see it happen occasionally, that messages arriving in different
threads and delivered in sequence still bypass each other before they
reach the destination socket. This must not happen, since it violates
the sequentiality guarantee.
We solve this by adding a new input buffer queue to the link structure.
Arriving messages are added safely to the tail of that queue by the
link, while the head of the queue is consumed, also safely, by the
receiving socket. Sequentiality is secured per socket by only allowing
buffers to be dequeued inside the socket lock. Since there may be multiple
simultaneous readers of the queue, we use a 'filter' parameter to reduce
the risk that they peek the same buffer from the queue, hence also
reducing the risk of contention on the receiving socket locks.
This solves the sequentiality problem, and seems to cause no measurable
performance degradation.
A nice side effect of this change is that lock handling in the functions
tipc_rcv() and tipc_bcast_rcv() now becomes uniform, something that
will enable future simplifications of those functions.
The list for outgoing traffic buffers from a socket is currently
allocated on the stack. This forces us to initialize the queue for
each sent message, something costing extra CPU cycles in the most
critical data path. Later in this series we will introduce a new
safe input buffer queue, something that would force us to initialize
even the spinlock of the outgoing queue. A closer analysis reveals
that the queue always is filled and emptied within the same lock_sock()
session. It is therefore safe to use a queue aggregated in the socket
itself for this purpose. Since there already exists a queue for this
in struct sock, sk_write_queue, we introduce use of that queue in
this commit.
The function tipc_msg_eval() is in reality doing two related, but
different tasks. First it tries to find a new destination for named
messages, in case there was no first lookup, or if the first lookup
failed. Second, it does what its name suggests, evaluating the validity
of the message and its destination, and returning an appropriate error
code depending on the result.
This is confusing, and in this commit we choose to break it up into two
functions. A new function, tipc_msg_lookup_dest(), first attempts to find
a new destination, if the message is of the right type. If this lookup
fails, or if the message should not be subject to a second lookup, the
already existing tipc_msg_reverse() is called. This function performs
prepares the message for rejection, if applicable.
The code for enqueuing arriving buffers in the function tipc_sk_rcv()
contains long code lines and currently goes to two indentation levels.
As a cosmetic preparaton for the next commits, we break it out into
a separate function.
Despite recent improvements, the handling of error codes and return
values at reception of messages in the socket layer is still confusing.
In this commit, we try to make it more comprehensible. First, we
separate between the return values coming from the functions called
by tipc_sk_rcv(), -those are TIPC specific error codes, and the
return values returned by tipc_sk_rcv() itself. Second, we don't
use the returned TIPC error code as indication for whether a buffer
should be forwarded/rejected or not; instead we use the buffer pointer
passed along with filter_msg(). This separation is necessary because
we sometimes want to forward messages even when there is no error
(i.e., protocol messages and successfully secondary looked up data
messages).
The most common usage of namespace information is when we fetch the
own node addess from the net structure. This leads to a lot of
passing around of a parameter of type 'struct net *' between
functions just to make them able to obtain this address.
However, in many cases this is unnecessary. The own node address
is readily available as a member of both struct tipc_sock and
tipc_link, and can be fetched from there instead.
The fact that the vast majority of functions in socket.c and link.c
anyway are maintaining a pointer to their respective base structures
makes this option even more compelling.
In this commit, we introduce the inline functions tsk_own_node()
and link_own_node() to make it easy for functions to fetch the node
address from those structs instead of having to pass along and
dereference the namespace struct.
In particular, we make calls to the msg_xx() functions in msg.{h,c}
context independent by directly passing them the own node address
as parameter when needed. Those functions should be regarded as
leaves in the code dependency tree, and it is hence desirable to
keep them namspace unaware.
Apart from a potential positive effect on cache behavior, these
changes make it easier to introduce the changes that will follow
later in this series.
More iov_iter work from Al Viro.
When a new link instance is created, it is trigged to start by
sending it a TIPC_STARTING_EVT, whereafter a regular link
reset is applied to it.
The starting event is codewise treated as a timeout event, and prompts
a link RESET message to be sent to the peer node, carrying a link
session identifier. The later link_reset() call nudges this session
identifier, whereafter all subsequent RESET messages will be sent out
with the new identifier. The latter session number overrides the former,
causing the peer to unconditionally accept it irrespective of its
current working state.
We don't think that this causes any problem, but it is not in accordance
with the protocol spec, and may cause confusion when debugging TIPC
sessions.
To avoid this, we make the starting event distinct from the
subsequent timeout events, by not allowing the former to send
out any RESET message. This eliminates the described problem.
Instances of struct node are created in the function tipc_disc_rcv()
under the assumption that there is no race between received discovery
messages arriving from the same node. This assumption is wrong.
When we use more than one bearer, it is possible that discovery
messages from the same node arrive at the same moment, resulting in
creation of two instances of struct tipc_node. This may later cause
confusion during link establishment, and may result in one of the links
never becoming activated.
We fix this by making lookup and potential creation of nodes atomic.
Instead of first looking up the node, and in case of failure, create it,
we now start with looking up the node inside node_link_create(), and
return a reference to that one if found. Otherwise, we go ahead and
create the node as we did before.
During link failover it may happen that the remaining link goes
down while it is still in the process of taking over traffic
from a previously failed link. When this happens, we currently
abort the failover procedure and reset the first failed link to
non-failover mode, so that it will be ready to re-establish
contact with its peer when it comes available.
However, if the first link goes down because its bearer was manually
disabled, it is not enough to reset it; it must also be deleted;
which is supposed to happen when the failover procedure is finished.
Otherwise it will remain a zombie link: attached to the owner node
structure, in mode LINK_STOPPED, and permanently blocking any re-
establishing of the link to the peer via the interface in question.
We fix this by amending the failover abort procedure. Apart from
resetting the link to non-failover state, we test if the link is
also in LINK_STOPPED mode. If so, we delete it, using the conditional
tipc_link_delete() function introduced in the previous commit.
When a bearer is disabled, all pertaining links will be reset and
deleted. However, if there is a second active link towards a killed
link's destination, the delete has to be postponed until the failover
is finished. During this interval, we currently put the link in zombie
mode, i.e., we take it out of traffic, delete its timer, but leave it
attached to the owner node structure until all missing packets have
been received. When this is done, we detach the link from its node
and delete it, assuming that the synchronous timer deletion that was
initiated earlier in a different thread has finished.
This is unsafe, as the failover may finish before del_timer_sync()
has returned in the other thread.
We fix this by adding an atomic reference counter of type kref in
struct tipc_link. The counter keeps track of the references kept
to the link by the owner node and the timer. We then do a conditional
delete, based on the reference counter, both after the failover has
been finished and when the timer expires, if applicable. Whoever
comes last, will actually delete the link. This approach also implies
that we can make the deletion of the timer asynchronous.
This one needs to copy the same data from user potentially more than
once. Sadly, MTU changes can trigger that ;-/
Cc: Jon Maloy <jon.maloy@ericsson.com>
If a large number of namespaces is spawned on a node and TIPC is
enabled in each of these, the excessive printk tracing of network
events will cause the system to grind down to a near halt.
The traces are still of debug value, so instead of removing them
completely we fix it by changing the link state and node availability
logging debug traces.
Commit 07f6c4bc (tipc: convert tipc reference table to use generic
rhashtable) introduced a problem with port listing in the new netlink
API. It broke the resume functionality resulting in a never ending
loop. This was caused by starting with the first hash table every time
subsequently never returning an empty skb (terminating).
This patch fixes the resume mechanism by keeping a logical reference
to the last hash table along with a logical reference to the socket
(port) that didn't fit in the previous message.
Commit f2f9800d4955 "tipc: make tipc node table aware of net
namespace" has added a dereference of sock->sk before making sure it's
not NULL, which makes releasing a tipc socket NULL pointer dereference
for sockets that are not fully initialized.
Remove the redundant timer defined in tipc_sock structure, instead we
can directly reuse the sk_timer defined in sock structure.
Acked-by: Erik Hugne <erik.hugne@ericsson.com>
Currently tipc module only allows users sitting on "init_net" namespace
to configure it through netlink interface. But now almost each tipc
component is able to be aware of net namespace, so it's time to open
the permission for users residing in other namespaces, allowing them
to configure their own tipc stack instance through netlink interface.
Tested-by: Tero Aho <Tero.Aho@coriant.com>
After namespace is supported, each namespace should own its private
random value. So the global variable representing the random value
must be moved to tipc_net structure.
