There is a race condition for an established connection that is being closed
by the guest: the refcnt is 4 at the end of hvs_release() (Note: here the
'remove_sock' is false):
1 for the initial value;
1 for the sk being in the bound list;
1 for the sk being in the connected list;
1 for the delayed close_work.
After hvs_release() finishes, __vsock_release() -> sock_put(sk) *may*
decrease the refcnt to 3.
Concurrently, hvs_close_connection() runs in another thread:
calls vsock_remove_sock() to decrease the refcnt by 2;
call sock_put() to decrease the refcnt to 0, and free the sk;
next, the "release_sock(sk)" may hang due to use-after-free.
In the above, after hvs_release() finishes, if hvs_close_connection() runs
faster than "__vsock_release() -> sock_put(sk)", then there is not any issue,
because at the beginning of hvs_close_connection(), the refcnt is still 4.
The issue can be resolved if an extra reference is taken when the
connection is established.
Fixes: a9eeb998c28d ("hv_sock: Add support for delayed close")
Signed-off-by: Dexuan Cui <decui@microsoft.com>
Reviewed-by: Sunil Muthuswamy <sunilmut@microsoft.com>
This patch moves the flush of works after vdev->config->del_vqs(vdev),
because we need to be sure that no workers run before to free the
'vsock' object.
Since we stopped the workers using the [tx|rx|event]_run flags,
we are sure no one is accessing the device while we are calling
vdev->config->reset(vdev), so we can safely move the workers' flush.
Before the vdev->config->del_vqs(vdev), workers can be scheduled
by VQ callbacks, so we must flush them after del_vqs(), to avoid
use-after-free of 'vsock' object.
Suggested-by: Michael S. Tsirkin <mst@redhat.com>
Signed-off-by: Stefano Garzarella <sgarzare@redhat.com>
Before to call vdev->config->reset(vdev) we need to be sure that
no one is accessing the device, for this reason, we add new variables
in the struct virtio_vsock to stop the workers during the .remove().
This patch also add few comments before vdev->config->reset(vdev)
and vdev->config->del_vqs(vdev).
Suggested-by: Stefan Hajnoczi <stefanha@redhat.com>
Some callbacks used by the upper layers can run while we are in the
.remove(). A potential use-after-free can happen, because we free
the_virtio_vsock without knowing if the callbacks are over or not.
To solve this issue we move the assignment of the_virtio_vsock at the
end of .probe(), when we finished all the initialization, and at the
beginning of .remove(), before to release resources.
For the same reason, we do the same also for the vdev->priv.
We use RCU to be sure that all callbacks that use the_virtio_vsock
ended before freeing it. This is not required for callbacks that
use vdev->priv, because after the vdev->config->del_vqs() we are sure
that they are ended and will no longer be invoked.
We also take the mutex during the .remove() to avoid that .probe() can
run while we are resetting the device.
Minor SPDX change conflict.
Pull networking fixes from David Miller:
1) Fix leak of unqueued fragments in ipv6 nf_defrag, from Guillaume
Nault.
2) Don't access the DDM interface unless the transceiver implements it
in bnx2x, from Mauro S. M. Rodrigues.
3) Don't double fetch 'len' from userspace in sock_getsockopt(), from
JingYi Hou.
4) Sign extension overflow in lio_core, from Colin Ian King.
5) Various netem bug fixes wrt. corrupted packets from Jakub Kicinski.
6) Fix epollout hang in hvsock, from Sunil Muthuswamy.
7) Fix regression in default fib6_type, from David Ahern.
8) Handle memory limits in tcp_fragment more appropriately, from Eric
Dumazet.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (24 commits)
tcp: refine memory limit test in tcp_fragment()
inet: clear num_timeout reqsk_alloc()
net: mvpp2: debugfs: Add pmap to fs dump
ipv6: Default fib6_type to RTN_UNICAST when not set
net: hns3: Fix inconsistent indenting
net/af_iucv: always register net_device notifier
net/af_iucv: build proper skbs for HiperTransport
net/af_iucv: remove GFP_DMA restriction for HiperTransport
net: dsa: mv88e6xxx: fix shift of FID bits in mv88e6185_g1_vtu_loadpurge()
hvsock: fix epollout hang from race condition
net/udp_gso: Allow TX timestamp with UDP GSO
net: netem: fix use after free and double free with packet corruption
net: netem: fix backlog accounting for corrupted GSO frames
net: lio_core: fix potential sign-extension overflow on large shift
tipc: pass tunnel dev as NULL to udp_tunnel(6)_xmit_skb
ip6_tunnel: allow not to count pkts on tstats by passing dev as NULL
ip_tunnel: allow not to count pkts on tstats by setting skb's dev to NULL
tun: wake up waitqueues after IFF_UP is set
net: remove duplicate fetch in sock_getsockopt
tipc: fix issues with early FAILOVER_MSG from peer
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/spdx
Pull still more SPDX updates from Greg KH:
"Another round of SPDX updates for 5.2-rc6
Here is what I am guessing is going to be the last "big" SPDX update
for 5.2. It contains all of the remaining GPLv2 and GPLv2+ updates
that were "easy" to determine by pattern matching. The ones after this
are going to be a bit more difficult and the people on the spdx list
will be discussing them on a case-by-case basis now.
Another 5000+ files are fixed up, so our overall totals are:
Files checked: 64545
Files with SPDX: 45529
Compared to the 5.1 kernel which was:
Files checked: 63848
Files with SPDX: 22576
This is a huge improvement.
Also, we deleted another 20000 lines of boilerplate license crud,
always nice to see in a diffstat"
* tag 'spdx-5.2-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/spdx: (65 commits)
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 507
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 506
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 505
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 504
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 503
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 502
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 501
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 500
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 499
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 498
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 497
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 496
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 495
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 491
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 490
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 489
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 488
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 487
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 486
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 485
Based on 1 normalized pattern(s):
this work is licensed under the terms of the gnu gpl version 2
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 48 file(s).
Reviewed-by: Allison Randal <allison@lohutok.net>
Reviewed-by: Enrico Weigelt <info@metux.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190604081204.624030236@linutronix.de
Currently, hvsock can enter into a state where epoll_wait on EPOLLOUT will
not return even when the hvsock socket is writable, under some race
condition. This can happen under the following sequence:
- fd = socket(hvsocket)
- fd_out = dup(fd)
- fd_in = dup(fd)
- start a writer thread that writes data to fd_out with a combination of
epoll_wait(fd_out, EPOLLOUT) and
- start a reader thread that reads data from fd_in with a combination of
epoll_wait(fd_in, EPOLLIN)
- On the host, there are two threads that are reading/writing data to the
hvsocket
stack:
hvs_stream_has_space
hvs_notify_poll_out
vsock_poll
sock_poll
ep_poll
Race condition:
check for epollout from ep_poll():
assume no writable space in the socket
hvs_stream_has_space() returns 0
check for epollin from ep_poll():
assume socket has some free space < HVS_PKT_LEN(HVS_SEND_BUF_SIZE)
hvs_stream_has_space() will clear the channel pending send size
host will not notify the guest because the pending send size has
been cleared and so the hvsocket will never mark the
socket writable
Now, the EPOLLOUT will never return even if the socket write buffer is
empty.
The fix is to set the pending size to the default size and never change it.
This way the host will always notify the guest whenever the writable space
is bigger than the pending size. The host is already optimized to *only*
notify the guest when the pending size threshold boundary is crossed and
not everytime.
This change also reduces the cpu usage somewhat since hv_stream_has_space()
is in the hotpath of send:
vsock_stream_sendmsg()->hv_stream_has_space()
Earlier hv_stream_has_space was setting/clearing the pending size on every
call.
Signed-off-by: Sunil Muthuswamy <sunilmut@microsoft.com>
Reviewed-by: Dexuan Cui <decui@microsoft.com>
Honestly all the conflicts were simple overlapping changes,
nothing really interesting to report.
"Lots of bug fixes here:
1) Out of bounds access in __bpf_skc_lookup, from Lorenz Bauer.
2) Fix rate reporting in cfg80211_calculate_bitrate_he(), from John
Crispin.
3) Use after free in psock backlog workqueue, from John Fastabend.
4) Fix source port matching in fdb peer flow rule of mlx5, from Raed
Salem.
5) Use atomic_inc_not_zero() in fl6_sock_lookup(), from Eric Dumazet.
6) Network header needs to be set for packet redirect in nfp, from
John Hurley.
7) Fix udp zerocopy refcnt, from Willem de Bruijn.
8) Don't assume linear buffers in vxlan and geneve error handlers,
from Stefano Brivio.
9) Fix TOS matching in mlxsw, from Jiri Pirko.
10) More SCTP cookie memory leak fixes, from Neil Horman.
11) Fix VLAN filtering in rtl8366, from Linus Walluij.
12) Various TCP SACK payload size and fragmentation memory limit fixes
from Eric Dumazet.
13) Use after free in pneigh_get_next(), also from Eric Dumazet.
14) LAPB control block leak fix from Jeremy Sowden"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (145 commits)
lapb: fixed leak of control-blocks.
tipc: purge deferredq list for each grp member in tipc_group_delete
ax25: fix inconsistent lock state in ax25_destroy_timer
neigh: fix use-after-free read in pneigh_get_next
tcp: fix compile error if !CONFIG_SYSCTL
hv_sock: Suppress bogus "may be used uninitialized" warnings
be2net: Fix number of Rx queues used for flow hashing
net: handle 802.1P vlan 0 packets properly
tcp: enforce tcp_min_snd_mss in tcp_mtu_probing()
tcp: add tcp_min_snd_mss sysctl
tcp: tcp_fragment() should apply sane memory limits
tcp: limit payload size of sacked skbs
Revert "net: phylink: set the autoneg state in phylink_phy_change"
bpf: fix nested bpf tracepoints with per-cpu data
bpf: Fix out of bounds memory access in bpf_sk_storage
vsock/virtio: set SOCK_DONE on peer shutdown
net: dsa: rtl8366: Fix up VLAN filtering
net: add high_order_alloc_disable sysctl/static key
tcp: add tcp_tx_skb_cache sysctl
gcc 8.2.0 may report these bogus warnings under some condition:
warning: ‘vnew’ may be used uninitialized in this function
warning: ‘hvs_new’ may be used uninitialized in this function
Actually, the 2 pointers are only initialized and used if the variable
"conn_from_host" is true. The code is not buggy here.
Set the SOCK_DONE flag to match the TCP_CLOSING state when a peer has
shut down and there is nothing left to read.
This fixes the following bug:
1) Peer sends SHUTDOWN(RDWR).
2) Socket enters TCP_CLOSING but SOCK_DONE is not set.
3) read() returns -ENOTCONN until close() is called, then returns 0.
Signed-off-by: Stephen Barber <smbarber@chromium.org>
The current vsock code for removal of socket from the list is both
subject to race and inefficient. It takes the lock, checks whether
the socket is in the list, drops the lock and if the socket was on the
list, deletes it from the list. This is subject to race because as soon
as the lock is dropped once it is checked for presence, that condition
cannot be relied upon for any decision. It is also inefficient because
if the socket is present in the list, it takes the lock twice.
Some ISDN files that got removed in net-next had some changes
done in mainline, take the removals.
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license as published by
the free software foundation version 2 and no later version this
program is distributed in the hope that it will be useful but
without any warranty without even the implied warranty of
merchantability or fitness for a particular purpose see the gnu
general public license for more details
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 33 file(s).
Reviewed-by: Alexios Zavras <alexios.zavras@intel.com>
Link: https://lkml.kernel.org/r/20190530000435.345978407@linutronix.de
it under the terms and conditions of the gnu general public license
version 2 as published by the free software foundation this program
is distributed in the hope it will be useful but without any
warranty without even the implied warranty of merchantability or
fitness for a particular purpose see the gnu general public license
for more details
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 263 file(s).
Link: https://lkml.kernel.org/r/20190529141901.208660670@linutronix.de
the free software foundation either version 2 of the license or at
your option any later version
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 3029 file(s).
Link: https://lkml.kernel.org/r/20190527070032.746973796@linutronix.de
Currently, the hv_sock send() iterates once over the buffer, puts data into
the VMBUS channel and returns. It doesn't maximize on the case when there
is a simultaneous reader draining data from the channel. In such a case,
the send() can maximize the bandwidth (and consequently minimize the cpu
cycles) by iterating until the channel is found to be full.
Perf data:
Total Data Transfer: 10GB/iteration
Single threaded reader/writer, Linux hvsocket writer with Windows hvsocket
reader
Packet size: 64KB
CPU sys time was captured using the 'time' command for the writer to send
10GB of data.
'Send Buffer Loop' is with the patch applied.
The values below are over 10 iterations.
| | Current | Send Buffer Loop |
| | Throughput | CPU sys | Throughput | CPU sys |
| | (MB/s) | time (s) | (MB/s) | time (s) |
| Min | 407 | 7.048 | 401 | 5.958 |
| Max | 455 | 7.563 | 542 | 6.993 |
| Avg | 440 | 7.411 | 451 | 6.639 |
| Median | 446 | 7.417 | 447 | 6.761 |
Observation:
1. The avg throughput doesn't really change much with this change for this
scenario. This is most probably because the bottleneck on throughput is
somewhere else.
2. The average system (or kernel) cpu time goes down by 10%+ with this
change, for the same amount of data transfer.
socket buffers
Currently, the hv_sock buffer size is static and can't scale to the
bandwidth requirements of the application. This change allows the
applications to influence the socket buffer sizes using the SO_SNDBUF and
the SO_RCVBUF socket options.
Few interesting points to note:
1. Since the VMBUS does not allow a resize operation of the ring size, the
socket buffer size option should be set prior to establishing the
connection for it to take effect.
2. Setting the socket option comes with the cost of that much memory being
reserved/allocated by the kernel, for the lifetime of the connection.
Perf data:
Total Data Transfer: 1GB
Results below are summarized over 10 iterations.
Linux hvsocket writer + Windows hvsocket reader:
|Packet size -> | 128B | 1KB | 4KB | 64KB |
|SO_SNDBUF size | | Throughput in MB/s (min/max/avg/median): |
| v | |
| Default | 109/118/114/116 | 636/774/701/700 | 435/507/480/476 | 410/491/462/470 |
| 16KB | 110/116/112/111 | 575/705/662/671 | 749/900/854/869 | 592/824/692/676 |
| 32KB | 108/120/115/115 | 703/823/767/772 | 718/878/850/866 | 1593/2124/2000/2085 |
| 64KB | 108/119/114/114 | 592/732/683/688 | 805/934/903/911 | 1784/1943/1862/1843 |
Windows hvsocket writer + Linux hvsocket reader:
|SO_RCVBUF size | | Throughput in MB/s (min/max/avg/median): |
| v | |
| Default | 69/82/75/73 | 313/343/333/336 | 418/477/446/445 | 659/701/676/678 |
| 16KB | 69/83/76/77 | 350/401/375/382 | 506/548/517/516 | 602/624/615/615 |
| 32KB | 62/83/73/73 | 471/529/496/494 | 830/1046/935/939 | 944/1180/1070/1100 |
| 64KB | 64/70/68/69 | 467/533/501/497 | 1260/1590/1430/1431 | 1605/1819/1670/1660 |
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull SPDX update from Greg KH:
"Here is a series of patches that add SPDX tags to different kernel
files, based on two different things:
- SPDX entries are added to a bunch of files that we missed a year
ago that do not have any license information at all.
These were either missed because the tool saw the MODULE_LICENSE()
tag, or some EXPORT_SYMBOL tags, and got confused and thought the
file had a real license, or the files have been added since the
last big sweep, or they were Makefile/Kconfig files, which we
didn't touch last time.
- Add GPL-2.0-only or GPL-2.0-or-later tags to files where our scan
tools can determine the license text in the file itself. Where this
happens, the license text is removed, in order to cut down on the
700+ different ways we have in the kernel today, in a quest to get
rid of all of these.
These patches have been out for review on the linux-spdx@vger mailing
list, and while they were created by automatic tools, they were
hand-verified by a bunch of different people, all whom names are on
the patches are reviewers.
The reason for these "large" patches is if we were to continue to
progress at the current rate of change in the kernel, adding license
tags to individual files in different subsystems, we would be finished
in about 10 years at the earliest.
There will be more series of these types of patches coming over the
next few weeks as the tools and reviewers crunch through the more
"odd" variants of how to say "GPLv2" that developers have come up with
over the years, combined with other fun oddities (GPL + a BSD
disclaimer?) that are being unearthed, with the goal for the whole
kernel to be cleaned up.
These diffstats are not small, 3840 files are touched, over 10k lines
removed in just 24 patches"
* tag 'spdx-5.2-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (24 commits)
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 25
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 24
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 23
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 22
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 21
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 20
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 19
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 18
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 17
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 15
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 14
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 13
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 12
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 11
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 10
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 9
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 7
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 3
Add SPDX license identifiers to all Make/Kconfig files which:
- Have no license information of any form
These files fall under the project license, GPL v2 only. The resulting SPDX
license identifier is:
GPL-2.0-only
Avoid a race in which static variables in net/vmw_vsock/af_vsock.c are
accessed (while handling interrupts) before they are initialized.
[ 4.201410] BUG: unable to handle kernel paging request at ffffffffffffffe8
[ 4.207829] IP: vsock_addr_equals_addr+0x3/0x20
[ 4.211379] PGD 28210067 P4D 28210067 PUD 28212067 PMD 0
[ 4.211379] Oops: 0000 [#1] PREEMPT SMP PTI
[ 4.211379] Modules linked in:
[ 4.211379] CPU: 1 PID: 30 Comm: kworker/1:1 Not tainted 4.14.106-419297-gd7e28cc1f241 #1
[ 4.211379] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-1 04/01/2014
[ 4.211379] Workqueue: virtio_vsock virtio_transport_rx_work
[ 4.211379] task: ffffa3273d175280 task.stack: ffffaea1800e8000
[ 4.211379] RIP: 0010:vsock_addr_equals_addr+0x3/0x20
[ 4.211379] RSP: 0000:ffffaea1800ebd28 EFLAGS: 00010286
[ 4.211379] RAX: 0000000000000002 RBX: 0000000000000000 RCX: ffffffffb94e42f0
[ 4.211379] RDX: 0000000000000400 RSI: ffffffffffffffe0 RDI: ffffaea1800ebdd0
[ 4.211379] RBP: ffffaea1800ebd58 R08: 0000000000000001 R09: 0000000000000001
[ 4.211379] R10: 0000000000000000 R11: ffffffffb89d5d60 R12: ffffaea1800ebdd0
[ 4.211379] R13: 00000000828cbfbf R14: 0000000000000000 R15: ffffaea1800ebdc0
[ 4.211379] FS: 0000000000000000(0000) GS:ffffa3273fd00000(0000) knlGS:0000000000000000
[ 4.211379] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 4.211379] CR2: ffffffffffffffe8 CR3: 000000002820e001 CR4: 00000000001606e0
[ 4.211379] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 4.211379] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
[ 4.211379] Call Trace:
[ 4.211379] ? vsock_find_connected_socket+0x6c/0xe0
[ 4.211379] virtio_transport_recv_pkt+0x15f/0x740
[ 4.211379] ? detach_buf+0x1b5/0x210
[ 4.211379] virtio_transport_rx_work+0xb7/0x140
[ 4.211379] process_one_work+0x1ef/0x480
[ 4.211379] worker_thread+0x312/0x460
[ 4.211379] kthread+0x132/0x140
[ 4.211379] ? process_one_work+0x480/0x480
[ 4.211379] ? kthread_destroy_worker+0xd0/0xd0
[ 4.211379] ret_from_fork+0x35/0x40
[ 4.211379] Code: c7 47 08 00 00 00 00 66 c7 07 28 00 c7 47 08 ff ff ff ff c7 47 04 ff ff ff ff c3 0f 1f 00 66 2e 0f 1f 84 00 00 00 00 00 8b 47 08 <3b> 46 08 75 0a 8b 47 04 3b 46 04 0f 94 c0 c3 31 c0 c3 90 66 2e
[ 4.211379] RIP: vsock_addr_equals_addr+0x3/0x20 RSP: ffffaea1800ebd28
[ 4.211379] ---[ end trace f31cc4a2e6df3689 ]---
[ 4.211379] Kernel panic - not syncing: Fatal exception in interrupt
[ 4.211379] Kernel Offset: 0x37000000 from 0xffffffff81000000 (relocation range: 0xffffffff80000000-0xffffffffbfffffff)
[ 4.211379] Rebooting in 5 seconds..
Fixes: 22b5c0b63f32 ("vsock/virtio: fix kernel panic after device hot-unplug")
Cc: Stefan Hajnoczi <stefanha@redhat.com>
Cc: Stefano Garzarella <sgarzare@redhat.com>
Cc: kvm@vger.kernel.org
Cc: virtualization@lists.linux-foundation.org
Cc: netdev@vger.kernel.org
Cc: kernel-team@android.com
Cc: stable@vger.kernel.org [4.9+]
Signed-off-by: Jorge E. Moreira <jemoreira@google.com>
Reviewed-by: Stefano Garzarella <sgarzare@redhat.com>
Reviewed-by: Stefan Hajnoczi <stefanha@redhat.com>
Acked-by: Stefan Hajnoczi <stefanha@redhat.com>
When the socket is released, we should free all packets
queued in the per-socket list in order to avoid a memory
leak.
Currently, hvsock does not implement any delayed or background close
logic. Whenever the hvsock socket is closed, a FIN is sent to the peer, and
the last reference to the socket is dropped, which leads to a call to
.destruct where the socket can hang indefinitely waiting for the peer to
close it's side. The can cause the user application to hang in the close()
call.
This change implements proper STREAM(TCP) closing handshake mechanism by
sending the FIN to the peer and the waiting for the peer's FIN to arrive
for a given timeout. On timeout, it will try to terminate the connection
(i.e. a RST). This is in-line with other socket providers such as virtio.
This change does not address the hang in the vmbus_hvsock_device_unregister
where it waits indefinitely for the host to rescind the channel. That
should be taken up as a separate fix.
Previous to commit 22b5c0b63f32 ("vsock/virtio: fix kernel panic
after device hot-unplug"), vsock_core_init() was called from
virtio_vsock_probe(). Now, virtio_transport_reset_no_sock() can be called
before vsock_core_init() has the chance to run.
[Wed Feb 27 14:17:09 2019] BUG: unable to handle kernel NULL pointer dereference at 0000000000000110
[Wed Feb 27 14:17:09 2019] #PF error: [normal kernel read fault]
[Wed Feb 27 14:17:09 2019] PGD 0 P4D 0
[Wed Feb 27 14:17:09 2019] Oops: 0000 [#1] SMP PTI
[Wed Feb 27 14:17:09 2019] CPU: 3 PID: 59 Comm: kworker/3:1 Not tainted 5.0.0-rc7-390-generic-hvi #390
[Wed Feb 27 14:17:09 2019] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
[Wed Feb 27 14:17:09 2019] Workqueue: virtio_vsock virtio_transport_rx_work [vmw_vsock_virtio_transport]
[Wed Feb 27 14:17:09 2019] RIP: 0010:virtio_transport_reset_no_sock+0x8c/0xc0 [vmw_vsock_virtio_transport_common]
[Wed Feb 27 14:17:09 2019] Code: 35 8b 4f 14 48 8b 57 08 31 f6 44 8b 4f 10 44 8b 07 48 8d 7d c8 e8 84 f8 ff ff 48 85 c0 48 89 c3 74 2a e8 f7 31 03 00 48 89 df <48> 8b 80 10 01 00 00 e8 68 fb 69 ed 48 8b 75 f0 65 48 33 34 25 28
[Wed Feb 27 14:17:09 2019] RSP: 0018:ffffb42701ab7d40 EFLAGS: 00010282
[Wed Feb 27 14:17:09 2019] RAX: 0000000000000000 RBX: ffff9d79637ee080 RCX: 0000000000000003
[Wed Feb 27 14:17:09 2019] RDX: 0000000000000001 RSI: 0000000000000002 RDI: ffff9d79637ee080
[Wed Feb 27 14:17:09 2019] RBP: ffffb42701ab7d78 R08: ffff9d796fae70e0 R09: ffff9d796f403500
[Wed Feb 27 14:17:09 2019] R10: ffffb42701ab7d90 R11: 0000000000000000 R12: ffff9d7969d09240
[Wed Feb 27 14:17:09 2019] R13: ffff9d79624e6840 R14: ffff9d7969d09318 R15: ffff9d796d48ff80
[Wed Feb 27 14:17:09 2019] FS: 0000000000000000(0000) GS:ffff9d796fac0000(0000) knlGS:0000000000000000
[Wed Feb 27 14:17:09 2019] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[Wed Feb 27 14:17:09 2019] CR2: 0000000000000110 CR3: 0000000427f22000 CR4: 00000000000006e0
[Wed Feb 27 14:17:09 2019] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[Wed Feb 27 14:17:09 2019] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
[Wed Feb 27 14:17:09 2019] Call Trace:
[Wed Feb 27 14:17:09 2019] virtio_transport_recv_pkt+0x63/0x820 [vmw_vsock_virtio_transport_common]
[Wed Feb 27 14:17:09 2019] ? kfree+0x17e/0x190
[Wed Feb 27 14:17:09 2019] ? detach_buf_split+0x145/0x160
[Wed Feb 27 14:17:09 2019] ? __switch_to_asm+0x40/0x70
[Wed Feb 27 14:17:09 2019] virtio_transport_rx_work+0xa0/0x106 [vmw_vsock_virtio_transport]
[Wed Feb 27 14:17:09 2019] NET: Registered protocol family 40
[Wed Feb 27 14:17:09 2019] process_one_work+0x167/0x410
[Wed Feb 27 14:17:09 2019] worker_thread+0x4d/0x460
[Wed Feb 27 14:17:09 2019] kthread+0x105/0x140
[Wed Feb 27 14:17:09 2019] ? rescuer_thread+0x360/0x360
[Wed Feb 27 14:17:09 2019] ? kthread_destroy_worker+0x50/0x50
[Wed Feb 27 14:17:09 2019] ret_from_fork+0x35/0x40
[Wed Feb 27 14:17:09 2019] Modules linked in: vmw_vsock_virtio_transport vmw_vsock_virtio_transport_common input_leds vsock serio_raw i2c_piix4 mac_hid qemu_fw_cfg autofs4 cirrus ttm drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops virtio_net psmouse drm net_failover pata_acpi virtio_blk failover floppy
Reported-by: Alexandru Herghelegiu <aherghelegiu@bitdefender.com>
Signed-off-by: Adalbert Lazăr <alazar@bitdefender.com>
Co-developed-by: Stefan Hajnoczi <stefanha@redhat.com>
The netfilter conflicts were rather simple overlapping
changes.
However, the cls_tcindex.c stuff was a bit more complex.
On the 'net' side, Cong is fixing several races and memory
leaks. Whilst on the 'net-next' side we have Vlad adding
the rtnl-ness support.
What I've decided to do, in order to resolve this, is revert the
conversion over to using a workqueue that Cong did, bringing us back
to pure RCU. I did it this way because I believe that either Cong's
races don't apply with have Vlad did things, or Cong will have to
implement the race fix slightly differently.
In the unlikely event that the kmalloc call in vmci_transport_socket_init()
fails, we end-up calling vmci_transport_destruct() with a NULL vmci_trans()
and oopsing.
This change addresses the above explicitly checking for zero vmci_trans()
at destruction time.
Reported-by: Xiumei Mu <xmu@redhat.com>
Fixes: d021c344051a ("VSOCK: Introduce VM Sockets")
Signed-off-by: Paolo Abeni <pabeni@redhat.com>
Reviewed-by: Jorgen Hansen <jhansen@vmware.com>
An ipvlan bug fix in 'net' conflicted with the abstraction away
of the IPV6 specific support in 'net-next'.
Similarly, a bug fix for mlx5 in 'net' conflicted with the flow
action conversion in 'net-next'.
This is a cleanup to prepare for the addition of 64-bit time_t
in O_SNDTIMEO/O_RCVTIMEO. The existing compat handler seems
unnecessarily complex and error-prone, moving it all into the
main setsockopt()/getsockopt() implementation requires half
as much code and is easier to extend.
32-bit user space can now use old_timeval32 on both 32-bit
and 64-bit machines, while 64-bit code can use
__old_kernel_timeval.
Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com>
Acked-by: Willem de Bruijn <willemb@google.com>
When the virtio transport device disappear, we should reset all
connected sockets in order to inform the users.
virtio_vsock_remove() invokes the vsock_core_exit() also if there
are opened sockets for the AF_VSOCK protocol family. In this way
the vsock "transport" pointer is set to NULL, triggering the
kernel panic at the first socket activity.
This patch move the vsock_core_init()/vsock_core_exit() in the
virtio_vsock respectively in module_init and module_exit functions,
that cannot be invoked until there are open sockets.
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=1609699
Reported-by: Yan Fu <yafu@redhat.com>
Found by scripts/checkpatch.pl
If a server side socket is bound to an address, but not in the listening
state yet, incoming connection requests should receive a reset control
packet in response. However, the function used to send the reset
silently drops the reset packet if the sending socket isn't bound
to a remote address (as is the case for a bound socket not yet in
the listening state). This change fixes this by using the src
of the incoming packet as destination for the reset packet in
this case.
Reviewed-by: Adit Ranadive <aditr@vmware.com>
Reviewed-by: Vishnu Dasa <vdasa@vmware.com>
Signed-off-by: Jorgen Hansen <jhansen@vmware.com>
The old code always starts from fixed port for VMADDR_PORT_ANY. Sometimes
when VMM crashed, there is still orphaned vsock which is waiting for
close timer, then it could cause connection time out for new started VM
if they are trying to connect to same port with same guest cid since the
new packets could hit that orphaned vsock. We could also fix this by doing
more in vhost_vsock_reset_orphans, but any way, it should be better to start
from a random local port instead of a fixed one.
Signed-off-by: Lepton Wu <ytht.net@gmail.com>
syzbot reported that we reinitialize an active delayed
work in vsock_stream_connect():
ODEBUG: init active (active state 0) object type: timer_list hint:
delayed_work_timer_fn+0x0/0x90 kernel/workqueue.c:1414
WARNING: CPU: 1 PID: 11518 at lib/debugobjects.c:329
debug_print_object+0x16a/0x210 lib/debugobjects.c:326
The pattern is apparently wrong, we should only initialize
the dealyed work once and could repeatly schedule it. So we
have to move out the initializations to allocation side.
And to avoid confusion, we can split the shared dwork
into two, instead of re-using the same one.
Reported-by: <syzbot+8a9b1bd330476a4f3db6@syzkaller.appspotmail.com>
Cc: Andy king <acking@vmware.com>
Cc: Jorgen Hansen <jhansen@vmware.com>
The poll() changes were not well thought out, and completely
unexplained. They also caused a huge performance regression, because
"->poll()" was no longer a trivial file operation that just called down
to the underlying file operations, but instead did at least two indirect
calls.
Indirect calls are sadly slow now with the Spectre mitigation, but the
performance problem could at least be largely mitigated by changing the
"->get_poll_head()" operation to just have a per-file-descriptor pointer
to the poll head instead. That gets rid of one of the new indirections.
But that doesn't fix the new complexity that is completely unwarranted
for the regular case. The (undocumented) reason for the poll() changes
was some alleged AIO poll race fixing, but we don't make the common case
slower and more complex for some uncommon special case, so this all
really needs way more explanations and most likely a fundamental
redesign.
[ This revert is a revert of about 30 different commits, not reverted
individually because that would just be unnecessarily messy - Linus ]
The dst_cid and src_cid are 64 bits, therefore 64 bit accessors should be
used, and in fact in virtio_transport_common.c only 64 bit accessors are
used. Using 32 bit accessors for 64 bit values breaks big endian systems.
This patch fixes a wrong use of le32_to_cpu in virtio_transport_send_pkt.
Fixes: b9116823189e85ccf384 ("VSOCK: add loopback to virtio_transport")
Signed-off-by: Claudio Imbrenda <imbrenda@linux.vnet.ibm.com>
Commit c1eef220c1760762753b602c382127bfccee226d ("vsock: always call
vsock_init_tables()") introduced a module_init() function without a
corresponding module_exit() function.
Modules with an init function can only be removed if they also have an
exit function. Therefore the vsock module was considered "permanent"
and could not be removed.
This patch adds an empty module_exit() function so that "rmmod vsock"
works. No explicit cleanup is required because:
1. Transports call vsock_core_exit() upon exit and cannot be removed
while sockets are still alive.
2. vsock_diag.ko does not perform any action that requires cleanup by
vsock.ko.
Fixes: c1eef220c176 ("vsock: always call vsock_init_tables()")
Cc: Cong Wang <xiyou.wangcong@gmail.com>
Signed-off-by: Stefan Hajnoczi <stefanha@redhat.com>
Changes since v1:
Added changes in these files:
drivers/infiniband/hw/usnic/usnic_transport.c
drivers/staging/lustre/lnet/lnet/lib-socket.c
drivers/target/iscsi/iscsi_target_login.c
drivers/vhost/net.c
fs/dlm/lowcomms.c
fs/ocfs2/cluster/tcp.c
security/tomoyo/network.c
Before:
All these functions either return a negative error indicator,
or store length of sockaddr into "int *socklen" parameter
and return zero on success.
"int *socklen" parameter is awkward. For example, if caller does not
care, it still needs to provide on-stack storage for the value
it does not need.
None of the many FOO_getname() functions of various protocols
ever used old value of *socklen. They always just overwrite it.
This change drops this parameter, and makes all these functions, on success,
return length of sockaddr. It's always >= 0 and can be differentiated
from an error.
Tests in callers are changed from "if (err)" to "if (err < 0)", where needed.
rpc_sockname() lost "int buflen" parameter, since its only use was
to be passed to kernel_getsockname() as &buflen and subsequently
not used in any way.
Userspace API is not changed.
30108430 2633624 873672 33615726 200ef6e vmlinux.before.o
30108109 2633612 873672 33615393 200ee21 vmlinux.o
Signed-off-by: Denys Vlasenko <dvlasenk@redhat.com>
CC: David S. Miller <davem@davemloft.net>
CC: linux-kernel@vger.kernel.org
CC: netdev@vger.kernel.org
CC: linux-bluetooth@vger.kernel.org
CC: linux-decnet-user@lists.sourceforge.net
CC: linux-wireless@vger.kernel.org
CC: linux-rdma@vger.kernel.org
CC: linux-sctp@vger.kernel.org
CC: linux-nfs@vger.kernel.org
CC: linux-x25@vger.kernel.org
This is the mindless scripted replacement of kernel use of POLL*
variables as described by Al, done by this script:
for V in IN OUT PRI ERR RDNORM RDBAND WRNORM WRBAND HUP RDHUP NVAL MSG; do
L=`git grep -l -w POLL$V | grep -v '^t' | grep -v /um/ | grep -v '^sa' | grep -v '/poll.h$'|grep -v '^D'`
for f in $L; do sed -i "-es/^\([^\"]*\)\(\<POLL$V\>\)/\\1E\\2/" $f; done
done
with de-mangling cleanups yet to come.
NOTE! On almost all architectures, the EPOLL* constants have the same
values as the POLL* constants do. But they keyword here is "almost".
For various bad reasons they aren't the same, and epoll() doesn't
actually work quite correctly in some cases due to this on Sparc et al.
The next patch from Al will sort out the final differences, and we
should be all done.
Scripted-by: Al Viro <viro@zeniv.linux.org.uk>
Pull poll annotations from Al Viro:
"This introduces a __bitwise type for POLL### bitmap, and propagates
the annotations through the tree. Most of that stuff is as simple as
'make ->poll() instances return __poll_t and do the same to local
variables used to hold the future return value'.
Some of the obvious brainos found in process are fixed (e.g. POLLIN
misspelled as POLL_IN). At that point the amount of sparse warnings is
low and most of them are for genuine bugs - e.g. ->poll() instance
deciding to return -EINVAL instead of a bitmap. I hadn't touched those
in this series - it's large enough as it is.
Another problem it has caught was eventpoll() ABI mess; select.c and
eventpoll.c assumed that corresponding POLL### and EPOLL### were
equal. That's true for some, but not all of them - EPOLL### are
arch-independent, but POLL### are not.
The last commit in this series separates userland POLL### values from
the (now arch-independent) kernel-side ones, converting between them
in the few places where they are copied to/from userland. AFAICS, this
is the least disruptive fix preserving poll(2) ABI and making epoll()
work on all architectures.
As it is, it's simply broken on sparc - try to give it EPOLLWRNORM and
it will trigger only on what would've triggered EPOLLWRBAND on other
architectures. EPOLLWRBAND and EPOLLRDHUP, OTOH, are never triggered
at all on sparc. With this patch they should work consistently on all
architectures"
* 'misc.poll' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (37 commits)
make kernel-side POLL... arch-independent
eventpoll: no need to mask the result of epi_item_poll() again
eventpoll: constify struct epoll_event pointers
debugging printk in sg_poll() uses %x to print POLL... bitmap
annotate poll(2) guts
9p: untangle ->poll() mess
->si_band gets POLL... bitmap stored into a user-visible long field
ring_buffer_poll_wait() return value used as return value of ->poll()
the rest of drivers/*: annotate ->poll() instances
media: annotate ->poll() instances
fs: annotate ->poll() instances
ipc, kernel, mm: annotate ->poll() instances
net: annotate ->poll() instances
apparmor: annotate ->poll() instances
tomoyo: annotate ->poll() instances
sound: annotate ->poll() instances
acpi: annotate ->poll() instances
crypto: annotate ->poll() instances
block: annotate ->poll() instances
x86: annotate ->poll() instances
select(2) with wfds but no rfds must return when the socket is shut down
by the peer. This way userspace notices socket activity and gets -EPIPE
from the next write(2).
Currently select(2) does not return for virtio-vsock when a SEND+RCV
shutdown packet is received. This is because vsock_poll() only sets
POLLOUT | POLLWRNORM for TCP_CLOSE, not the TCP_CLOSING state that the
socket is in when the shutdown is received.
Since commit 3b4477d2dcf2709d0be89e2a8dced3d0f4a017f2 ("VSOCK: use TCP
state constants for sk_state") VSOCK has used TCP_* constants for
sk_state.
Commit b4562ca7925a3bedada87a3dd072dd5bad043288 ("hv_sock: add locking
in the open/close/release code paths") reintroduced the SS_DISCONNECTING
constant.
This patch replaces the old SS_DISCONNECTING with the new TCP_CLOSING
constant.
CC: Dexuan Cui <decui@microsoft.com>
CC: Cathy Avery <cavery@redhat.com>
A recent commit (3b4477d2dcf2) converted the sk_state to use
TCP constants. In that change, vmci_transport_handle_detach
was changed such that sk->sk_state was set to TCP_CLOSE before
we test whether it is TCP_SYN_SENT. This change moves the
sk_state change back to the original locations in that function.
When using the host personality, VMCI will grab a mutex for any
queue pair access. In the detach callback for the vmci vsock
transport, we call vsock_stream_has_data while holding a spinlock,
and vsock_stream_has_data will access a queue pair.
To avoid this, we can simply omit calling vsock_stream_has_data
for host side queue pairs, since the QPs are empty per default
when the guest has detached.
This bug affects users of VMware Workstation using kernel version
4.4 and later.
Testing: Ran vsock tests between guest and host, and verified that
with this change, the host isn't calling vsock_stream_has_data
during detach. Ran mixedTest between guest and host using both
guest and host as server.
v2: Rebased on top of recent change to sk_state values
Reviewed-by: Aditya Sarwade <asarwade@vmware.com>
Files removed in 'net-next' had their license header updated
in 'net'. We take the remove from 'net-next'.
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
