connkeys is malloced in nl80211_parse_connkeys() and should
be freed in the error handling case, otherwise it will cause
memory leak.
spatch with a semantic match is used to found this problem.
(http://coccinelle.lip6.fr/)
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem
Cellular base stations can provide hints to cfg80211 about
where they think we are. This can be done for example on
a cell phone. To enable these hints we simply allow them
through as user regulatory hints but we allow userspace
to clasify the hint as either coming directly from the
user or coming from a cellular base station. This option
is only available when you enable
CONFIG_CFG80211_CERTIFICATION_ONUS.
The base station hints themselves will not be processed
by the core unless at least one device on the system
supports this feature.
Signed-off-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com>
Let the user configure serveral TX error conection quality monitoring
parameters: % error rate, survey interval, and # of attempted packets.
On exceeding the TX failure rate over the given interval, the driver
will send a CQM notify event with the actual TX failure rate and
packets attempted.
Signed-off-by: Thomas Pedersen <c_tpeder@qca.qualcomm.com>
In one of my previous patches I erroneously
used nla_put_u32 for the wdev_id, fix that
to use nla_put_u64.
This essentially reverts commit 2e165b818456 but
introduces the get_channel operation with a new
wireless_dev argument so that you can retrieve
the channel per interface. This is necessary as
even though we can track all interface channels
(except monitor) we can't track the channel type
used.
It may be desirable to use WoWLAN without triggers to
keep the connection alive to the AP while suspended.
Allow this use by enabling WoWLAN without triggers if
no triggers were requested.
The new P2P Device will have to be able to scan for
P2P search, so move scanning to use struct wireless_dev
instead of struct net_device.
After a new virtual interface is created, reply
to userspace with a message detailing it so it
knows the new wdev identifier.
In order to be able to create P2P Device wdevs, move
the virtual interface management over to wireless_dev
structures.
The management frame and remain-on-channel APIs will be
needed in the P2P device abstraction, so move them over
to the new wdev-based APIs. Userspace can still use both
the interface index and wdev identifier for them so it's
backward compatible, but for the P2P Device wdev it will
be able to use the wdev identifier only.
Since soon there will be virtual interfaces that
don't have a netdev, use the wdev identifier for
the API to retrieve interface data.
Some nl80211 callbacks will soon need the wdev instead
of the netdev, so add NL80211_FLAG_NEED_WDEV to allow
them to request that. Add NL80211_FLAG_NEED_WDEV_UP as
well which checks the netdev is UP if one exists.
In order to support a P2P device abstraction and
Bluetooth high-speed AMPs, we need to have a way
to identify virtual interfaces that don't have a
netdev associated.
Do this by adding a NL80211_ATTR_WDEV attribute
to identify a wdev which may or may not also be
a netdev.
To simplify things, use a 64-bit value with the
high 32 bits being the wiphy index for this new
wdev identifier in the nl80211 API.
Until now, a u16 value was used to represent bitrate value.
With VHT bitrates this becomes too small.
Introduce a new 32-bit bitrate attribute. nl80211 will report
both the new and the old attribute, unless the bitrate doesn't
fit into the old u16 attribute in which case only the new one
will be reported.
User space tools encouraged to prefer the 32-bit attribute, if
available (since it won't be available on older kernels.)
Signed-off-by: Vladimir Kondratiev <qca_vkondrat@qca.qualcomm.com>
[reword commit message and comments a bit]
drivers/net/wireless/brcm80211/brcmfmac/dhd_sdio.c
devlist_mtx locking is changed to accomodate changes.
Signed-off-by: Michal Kazior <michal.kazior@tieto.com>
We do not need it anymore since cfg80211 tracks
monitor channel and monitor channel type.
We need to know which channel is used by a running
AP and mesh for channel context accounting and
finding matching/active interface combination.
STA/IBSS have current_bss already which allows us
to check which channel a vif is tuned to.
Non-fixed channel IBSS can be handled with
additional changes.
Monitor mode is going to be handled differently.
This functionality will be reused when interface
is going down. Avoids code duplication. Also adds
missing wdev locking.
Using NLMSG_GOODSIZE results in multiple pages being used as
nlmsg_new() will automatically add the size of the netlink
header to the payload thus exceeding the page limit.
NLMSG_DEFAULT_SIZE takes this into account.
Signed-off-by: Thomas Graf <tgraf@suug.ch>
Cc: Jiri Pirko <jpirko@redhat.com>
Cc: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
Cc: Sergey Lapin <slapin@ossfans.org>
Cc: Johannes Berg <johannes@sipsolutions.net>
Cc: Lauro Ramos Venancio <lauro.venancio@openbossa.org>
Cc: Aloisio Almeida Jr <aloisio.almeida@openbossa.org>
Cc: Samuel Ortiz <sameo@linux.intel.com>
Reviewed-by: Jiri Pirko <jpirko@redhat.com>
Allow drivers to advertise their VHT capabilities
and export them to userspace via nl80211.
Signed-off-by: Mahesh Palivela <maheshp@posedge.com>
When CONFIG_PM is disabled, no device can possibly
support WoWLAN since it can't go to sleep to start
with. Due to this, mac80211 had even rejected the
hardware registration. By making all the code and
data for WoWLAN depend on CONFIG_PM we can promote
this runtime error to a compile-time error.
Add #ifdef around all WoWLAN code to remove it in
systems that don't need it as they never suspend.
Cc: Kalle Valo <kvalo@qca.qualcomm.com>
Acked-by: Luciano Coelho <coelho@ti.com>
Support configuring an RSSI threshold in dBm (s32) when requesting
scheduled scan, below which a BSS won't be reported by the cfg80211
driver.
Commit "cfg80211: provide channel to start_ap function" assumes that the
channel is always passed to the NL80211_CMD_START_AP command, however
in case of multi-BSSID, hostapd only passes the channel for the first vif.
This makes starting beaconing on secondary vifs fail with -EINVAL.
Fix this by storing the channel provided to .start_ap in wdev->preset_chan
and picking the first AP vif's channel for secondary vifs if not provided.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
To fix the testmode cross-namespace access problem,
use __cfg80211_rdev_from_attrs() to get the device
instead of open-coding similar functionality.
Change the function to __cfg80211_rdev_from_attrs
to take attributes instead of the info struct to
make it usable from dump callbacks for testmode.
There are currently a few ways to "escape"
the network namespace and access a wiphy
that belongs to another namespace. Add a
netns argument to the relevant functions
to fix this.
One remaining issue with testmode will be
fixed in a follow-up patch.
Refactor the function to make it easier to
extend.
Some of the functions to retrieve a device can
be static as they're used only in nl80211.
As defined in section 13.10.9.3 Case D (802.11-2012), this
control variable is used to limit the mesh STA to send only
one PREQ to a root mesh STA within this interval of time
(in TUs). The default value for this variable is set to
2000 TUs. However, for current implementation, the maximum
configurable of dot11MeshHWMPconfirmationInterval is
restricted by dot11MeshHWMPactivePathTimeout.
Signed-off-by: Chun-Yeow Yeoh <yeohchunyeow@gmail.com>
[line-break commit log]
dot11MeshHWMPactivePathToRootTimeout
Add the mesh configuration parameters dot11MeshHWMProotInterval
and dot11MeshHWMPactivePathToRootTimeout to be used by
proactive PREQ mechanism.
It should be NL80211_SCHED_SCAN_MATCH_ATTR_SSID as
documented, not NL80211_ATTR_SCHED_SCAN_MATCH_SSID.
fix the coding style related to mesh parameters, especially the indentation,
as pointed out by Johannes Berg.
The remain-on-channel time validation shouldn't
depend on the value of HZ, as it does now with
the check against jiffies, since then you might
use a value that works on one system but not on
another. Fix it by checking against a minimum
that's fixed.
Also add validation of the wait duration for a
management frame TX since this also translates
into remain-on-channel internally.
Now that we've removed all uses of the set_channel
API except for the monitor channel and in libertas,
clarify this. Split the libertas mesh use into a
new libertas_set_mesh_channel() operation, just to
keep backward compatibility, and rename the normal
set_channel() to set_monitor_channel().
Also describe the desired set_monitor_channel()
semantics more clearly.
Just like the AP mode patch, instead of setting
the channel and then joining the mesh network,
provide the channel to join the network on to
the join_mesh() function.
Like in AP mode, you can also give the channel
to the join-mesh nl80211 command now.
Unlike AP mode, it picks a default channel if
none was given.
As libertas uses mesh mode interfaces but has
no join_mesh callback and we can't simply break
it, keep some compatibility code for that case
and configure the channel directly for it.
In the non-libertas case, where we store the
channel until join, allow setting it while the
interface is down.
If it worked (Felix says it doesn't right now), the
typical use-case for WDS interfaces would be to be
slaved to AP mode interfaces. Therefore, it isn't
necessary to set the channel on WDS interfaces. As
they don't support powersave or anything like that,
they also couldn't use a different channel anyway.
Instead of setting the channel first and then
starting the AP, let cfg80211 store the channel
and provide it as one of the AP settings.
This means that now you have to set the channel
before you can start an AP interface, but since
hostapd/wpa_supplicant always do that we're OK
with this change.
Alternatively, it's now possible to give the
channel as an attribute to the start-ap nl80211
command, overriding any preset channel.
There are four instances in nl80211 of getting the
channel type from the attribute and validating it,
refactor those.
We don't really want/need to maintain the old
station flags API any more, so refuse changes
to new (not yet defined) flags from the old
flags API.
This patch introduces a new mesh configuration parameter "ht_opmode" and will
allow user to check the current HT protection mode selected. Users could
configure the protection mode by the command "iw mesh_iface set mesh_param
mesh_ht_protection_mode=2". The default protection mode of mesh is set to
non-HT mixed mode.
Signed-off-by: Ashok Nagarajan <ashok@cozybit.com>
Reviewed-by: Thomas Pedersen <thomas@cozybit.com>
drivers/net/wireless/iwlwifi/iwl-testmode.c
Legacy rates are not validated while configuring
tx rateset using iw. So below cmd is accepted by nl80211.
sudo iw wlan2 set bitrates legacy-2.4 1 2 3
Validate legacy rates and return
error if any rate in the rateset is not valid.
Signed-off-by: Bala Shanmugam <bkamatch@qca.qualcomm.com>
include/net/nfc/nfc.h
net/nfc/netlink.c
net/wireless/nl80211.c
If the current channel is known, add frequency and channel type to
NL80211_CMD_GET_INTERFACE.
Signed-off-by: Pontus Fuchs <pontus.fuchs@gmail.com>
The firmware may decide to switch channels while already beaconing, e.g.
in response to a cfg80211 connect request on a different vif. Add this
event to notify userspace when an AP or GO interface has successfully
migrated to a new channel, so it can update its configuration
accordingly.
