path: root/net/wireless/nl80211.h
2011-07-06cfg80211/nl80211: support GTK rekey offloadJohannes Berg
In certain circumstances, like WoWLAN scenarios, devices may implement (partial) GTK rekeying on the device to avoid waking up the host for it. In order to successfully go through GTK rekeying, the KEK, KCK and the replay counter are required. Add API to let the supplicant hand the parameters to the driver which may store it for future GTK rekey operations. Note that, of course, if GTK rekeying is done by the device, the EAP frame must not be passed up to userspace, instead a rekey event needs to be sent to let userspace update its replay counter. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-11cfg80211/nl80211: add support for scheduled scansLuciano Coelho
Implement new functionality for scheduled scan offload. With this feature we can scan automatically at certain intervals. The idea is that the hardware can perform scan automatically and filter on desired results without waking up the host unnecessarily. Add NL80211_CMD_START_SCHED_SCAN and NL80211_CMD_STOP_SCHED_SCAN commands to the nl80211 interface. When results are available they are reported by NL80211_CMD_SCHED_SCAN_RESULTS events. The userspace is informed when the scheduled scan has stopped with a NL80211_CMD_SCHED_SCAN_STOPPED event, which can be triggered either by the driver or by a call to NL80211_CMD_STOP_SCHED_SCAN. Signed-off-by: Luciano Coelho <coelho@ti.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-04-12nl80211: New notification to discover mesh peer candidates.Javier Cardona
Notify userspace when a beacon/presp is received from a suitable mesh peer candidate for whom no sta information exists. Userspace can then decide to create a sta info for the candidate. If userspace is not ready to authenticate the peer right away, it can create the sta info with the authenticated flag unset and set it later. Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30cfg80211: Add nl80211 event for deletion of a station entryJouni Malinen
Indicate an NL80211_CMD_DEL_STATION event when a station entry in mac80211 is deleted to match with the NL80211_CMD_NEW_STATION event that is used when the entry was added. This is needed, e.g., to allow user space to remove a peer from RSN IBSS Authenticator state machine to avoid re-authentication and re-keying delays when the peer is not reachable anymore. Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-16nl80211: Add notification for dropped Deauth/DisassocJouni Malinen
Add a new notification to indicate that a received, unprotected Deauthentication or Disassociation frame was dropped due to management frame protection being in use. This notification is needed to allow user space (e.g., wpa_supplicant) to implement SA Query procedure to recover from association state mismatch between an AP and STA. This is needed to avoid getting stuck in non-working state when MFP (IEEE 802.11w) is used and a protected Deauthentication or Disassociation frame is dropped for any reason. After that, the station would silently discard any unprotected Deauthentication or Disassociation frame that could be indicating that the AP does not have association for the STA (when the Reason Code would be 6 or 7). IEEE Std 802.11w-2009, 11.13 describes this recovery mechanism. Signed-off-by: Jouni Malinen <j@w1.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-24cfg80211: allow using CQM event to notify packet lossJohannes Berg
This adds the ability for drivers to use CQM events to notify about packet loss for specific stations (which could be the AP for the managed mode case). Since the threshold might be determined by the driver (it isn't passed in right now) it will be passed out of the driver to userspace in the event. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-08-24cfg80211/mac80211: extensible frame processingJohannes Berg
Allow userspace to register for more than just action frames by giving the frame subtype, and make it possible to use this in various modes as well. With some tweaks and some added functionality this will, in the future, also be usable in AP mode and be able to replace the cooked monitor interface currently used in that case. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-03-24cfg80211: Add connection quality monitoring support to nl80211Juuso Oikarinen
Add support for basic configuration of a connection quality monitoring to the nl80211 interface, and basic support for notifying about triggered monitoring events. Via this interface a user-space connection manager may configure and receive pre-warning events of deteriorating WLAN connection quality, and start preparing for roaming in advance, before the connection is already lost. An example usage of such a trigger is starting scanning for nearby AP's in an attempt to find one with better connection quality, and associate to it before the connection characteristics of the existing connection become too bad or the association is even lost, leading in a prolonged delay in connectivity. The interface currently supports only RSSI, but it could be later extended to include other parameters, such as signal-to-noise ratio, if need for that arises. Signed-off-by: Juuso Oikarinen <juuso.oikarinen@nokia.com> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-02-15cfg80211/mac80211: allow registering for and sending action framesJouni Malinen
This implements a new command to register for action frames that userspace wants to handle instead of the in-kernel rejection. It is then responsible for rejecting ones that it decided not to handle. There is no unregistration, but the socket can be closed for that. Frames that are not registered for will not be forwarded to userspace and will be rejected by the kernel, the cfg80211 API helps implementing that. Additionally, this patch adds a new command that allows doing action frame transmission from userspace. It can be used either to exchange action frames on the current operational channel (e.g., with the AP with which we are currently associated) or to exchange off-channel Public Action frames with the remain-on-channel command. Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-28mac80211/cfg80211: add station eventsJohannes Berg
When, for instance, a new IBSS peer is found, userspace wants to be notified. Add events for all new stations that mac80211 learns about. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-28cfg80211: add remain-on-channel commandJouni Malinen
Add new commands for requesting the driver to remain awake on a specified channel for the specified amount of time (and another command to cancel such an operation). This can be used to implement userspace-controlled off-channel operations, like Public Action frame exchange on another channel than the operation channel. The off-channel operation should behave similarly to scan, i.e. the local station (if associated) moves into power save mode to request the AP to buffer frames for it and then moves to the other channel to allow the off-channel operation to be completed. The duration parameter can be used to request enough time to receive a response from the target station. Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10cfg80211: fix lockingJohannes Berg
Over time, a lot of locking issues have crept into the smarts of cfg80211, so e.g. scan completion can race against a new scan, IBSS join can race against leaving an IBSS, etc. Introduce a new per-interface lock that protects most of the per-interface data that we need to keep track of, and sprinkle assertions about that lock everywhere. Some things now need to be offloaded to work structs so that we don't require being able to sleep in functions the drivers call. The exception to that are the MLME callbacks (rx_auth etc.) that currently only mac80211 calls because it was easier to do that there instead of in cfg80211, and future drivers implementing those calls will, if they ever exist, probably need to use a similar scheme like mac80211 anyway... In order to be able to handle _deauth and _disassoc properly, introduce a cookie passed to it that will determine locking requirements. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10cfg80211: connect/disconnect APISamuel Ortiz
This patch introduces the cfg80211 connect/disconnect API. The goal here is to run the AUTH and ASSOC steps in one call. This is needed for some fullmac cards that run both steps directly from the target, after the host driver sends a connect command. Additionally, all the new crypto parameters for connect() are now also valid for associate() -- although associate requires the IEs to be used, the information can be useful for drivers and should be given. Signed-off-by: Samuel Ortiz <samuel.ortiz@intel.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10cfg80211: use proper allocation flagsJohannes Berg
Instead of hardcoding GFP_ATOMIC everywhere, add a new function parameter that gets the flags from the caller. Obviously then I need to update all callers (all of them in mac80211), and it turns out that now it's ok to use GFP_KERNEL in almost all places. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10nl80211: clean up function definitionsJohannes Berg
I don't like the 'extern' keyword much when it's not necessary, it makes lines rather long. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10cfg80211: issue netlink notification when scan startsJohannes Berg
To ease multiple apps working together smoothly, send a notification when a scan is started. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-04-22nl80211: Add event for authentication/association timeoutJouni Malinen
SME needs to be notified when the authentication or association attempt times out and MLME has stopped processing in order to allow the SME to decide what to do next. Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-04-22cfg80211/nl80211: add IBSS APIJohannes Berg
This adds IBSS API along with (preliminary) wext handlers. The wext handlers can only do IBSS so you need to call them from your own wext handlers if the mode is IBSS. The nl80211 API requires * an SSID * a channel (frequency) for the case that a new IBSS has to be created It optionally supports * a flag to fix the channel * a fixed BSSID The cfg80211 code also takes care to leave the IBSS before the netdev is set down. If wireless extensions are used, it also caches values when the interface is down and instructs the driver to join when the interface is set up. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-04-22cfg80211: send regulatory beacon hint events to userspaceLuis R. Rodriguez
This informs userspace when a change has occured on a world roaming wiphy's channel which has lifted some restrictions due to a regulatory beacon hint. Because this is now sent to userspace through the regulatory multicast group we remove the debug prints we used to use as they are no longer necessary. Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-04-22nl80211: Add Michael MIC failure eventJouni Malinen
Define a new nl80211 event, NL80211_CMD_MICHAEL_MIC_FAILURE, to be used to notify user space about locally detected Michael MIC failures. This matches with the MLME-MICHAELMICFAILURE.indication() primitive. Since we do not actually have TSC in the skb anymore when mac80211_ev_michael_mic_failure() is called, that function is changed to take in the TSC as an optional parameter instead of as a requirement to include the TSC after the hdr field (which we did not really follow). For now, TSC is not included in the events from mac80211, but it could be added at some point. Signed-off-by: Jouni Malinen <j@w1.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-04-22nl80211: Generate deauth/disassoc event for locally generated framesJouni Malinen
Previously, nl80211 mlme events were generated only for received deauthentication and disassociation frames. We need to do the same for locally generated ones in order to let applications know that we disconnected (e.g., when AP does not reply to a probe). Rename the nl80211 and cfg80211 functions (s/rx_//) to make it clearer that they are used for both received and locally generated frames. Signed-off-by: Jouni Malinen <j@w1.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-27nl80211: Event notifications for MLME eventsJouni Malinen
Add new nl80211 event notifications (and a new multicast group, "mlme") for informing user space about received and processed Authentication, (Re)Association Response, Deauthentication, and Disassociation frames in station and IBSS modes (i.e., MLME SAP interface primitives MLME-AUTHENTICATE.confirm, MLME-ASSOCIATE.confirm, MLME-REASSOCIATE.confirm, MLME-DEAUTHENTICATE.indicate, and MLME-DISASSOCIATE.indication). The event data is encapsulated as the 802.11 management frame since we already have the frame in that format and it includes all the needed information. This is the initial step in providing MLME SAP interface for authentication and association with nl80211. In other words, kernel code will act as the MLME and a user space application can control it as the SME. Signed-off-by: Jouni Malinen <j@w1.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-27cfg80211/nl80211: remove usage of CONFIG_NL80211Reinette Chatre
The scan capability added to cfg80211/nl80211 introduced a dependency on nl80211 by cfg80211. We can thus no longer have just cfg80211 without nl80211. Specifically, cfg80211_scan_done() calls nl80211_send_scan_aborted() or nl80211_send_scan_done(). Now we remove the option for user to select nl80211. It will always be compiled if user selects cfg80211. Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-16cfg80211: add regulatory netlink multicast groupLuis R. Rodriguez
This allows us to send to userspace "regulatory" events. For now we just send an event when we change regulatory domains. We also notify userspace when devices are using their own custom world roaming regulatory domains. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-27wireless: fix for CONFIG_NL80211=nRandy Dunlap
Add empty function for case of CONFIG_NL80211=n: net/wireless/scan.c:35: error: implicit declaration of function 'nl80211_send_scan_aborted' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-13cfg80211/nl80211: scanning (and mac80211 update to use it)Johannes Berg
This patch adds basic scan capability to cfg80211/nl80211 and changes mac80211 to use it. The BSS list that cfg80211 maintains is made driver-accessible with a private area in each BSS struct, but mac80211 doesn't yet use it. That's another large project. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[NL80211]: add netlink interface to cfg80211Johannes Berg
Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
