path: root/net/wireless/radiotap.c
2010-10-15radiotap: fix vendor namespace parsingJohannes Berg
There's a bug with radiotap vendor namespace parsing if you don't register for the given namespace extensions. Fix this by passing only the unknown vendor namespaces and the registered data to frontends, but not both. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-09-14net/wireless: use ARRAY_SIZE macro in radiotap.cNikitas Angelinas
Replace sizeof(rtap_namespace_sizes) / sizeof(rtap_namespace_sizes[0]) with ARRAY_SIZE(rtap_namespace_sizes) in net/wireless/radiotap.c Signed-off-by: Nikitas Angelinas <nikitasangelinas@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-02-08wireless: update radiotap parserJohannes Berg
Upstream radiotap has adopted the namespace proposal David Young made and I then took care of, for which I had adapted the radiotap parser as a library outside the kernel. This brings the in-kernel parser up to speed. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-14wireless: use get/put_unaligned_* helpersHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[WIRELESS] radiotap parser: accept all other fieldsJohannes Berg
This makes the radiotap parser accept all other fields that are currently defined. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-07-12[PATCH] cfg80211: Radiotap parserAndy Green
Generic code to walk through the fields in a radiotap header, accounting for nasties like extended "field present" bitfields and alignment rules Signed-off-by: Andy Green <andy@warmcat.com> Signed-off-by: Jiri Benc <jbenc@suse.cz> Signed-off-by: John W. Linville <linville@tuxdriver.com>
