path: root/net/wireless
2010-01-14cfg80211: fix channel setting for wextAbhijeet Kolekar
Patch fixes the bug at http://bugzilla.intellinuxwireless.org/show_bug.cgi?id=2139 Currently we cannot set the channel using wext extension if we have already associated and disconnected. As cfg80211_mgd_wext_siwfreq will not switch the channel if ssid is set. This fixes it by clearing the ssid. Following is the sequence which it tries to fix. modprobe iwlagn iwconfig wlan0 essid "" ifconfig wlan0 down iwconfig wlan0 chan X wext is marked as deprecate.If we use nl80211 we can easily play with setting the channel. Signed-off-by: Abhijeet Kolekar <abhijeet.kolekar@intel.com> Acked-by: Samuel Ortiz <sameo@linux.intel.com> cc: stable@kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-11cfg80211: fix refcount imbalance when wext is disabledJohannes Berg
When CONFIG_CFG80211_WEXT is not set, there is a refcount imbalance with rdev->opencount, fix that by moving it out of the ifdef. Reported-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-04cfg80211: fix syntax error on user regulatory hintsLuis R. Rodriguez
This fixes a syntax error when setting up the user regulatory hint. This change yields the same exact binary object though so it ends up just being a syntax typo fix, fortunately. Cc: stable@kernel.org Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-28cfg80211: fix error path in cfg80211_wext_siwscanJohannes Berg
If there's an invalid channel or SSID, the code leaks the scan request. Always free the scan request, unless it was successfully given to the driver. Reported-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Dan Carpenter <error27@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-28cfg80211: fix race between deauth and assoc responseJohannes Berg
Joseph Nahmias reported, in http://bugs.debian.org/562016, that he was getting the following warning (with some log around the issue): ath0: direct probe to AP 00:11:95:77:e0:b0 (try 1) ath0: direct probe responded ath0: authenticate with AP 00:11:95:77:e0:b0 (try 1) ath0: authenticated ath0: associate with AP 00:11:95:77:e0:b0 (try 1) ath0: deauthenticating from 00:11:95:77:e0:b0 by local choice (reason=3) ath0: direct probe to AP 00:11:95:77:e0:b0 (try 1) ath0: RX AssocResp from 00:11:95:77:e0:b0 (capab=0x421 status=0 aid=2) ath0: associated ------------[ cut here ]------------ WARNING: at net/wireless/mlme.c:97 cfg80211_send_rx_assoc+0x14d/0x152 [cfg80211]() Hardware name: 7658CTO ... Pid: 761, comm: phy0 Not tainted 2.6.32-trunk-686 #1 Call Trace: [<c1030a5d>] ? warn_slowpath_common+0x5e/0x8a [<c1030a93>] ? warn_slowpath_null+0xa/0xc [<f86cafc7>] ? cfg80211_send_rx_assoc+0x14d/0x152 ... ath0: link becomes ready ath0: deauthenticating from 00:11:95:77:e0:b0 by local choice (reason=3) ath0: no IPv6 routers present ath0: link is not ready ath0: direct probe to AP 00:11:95:77:e0:b0 (try 1) ath0: direct probe responded ath0: authenticate with AP 00:11:95:77:e0:b0 (try 1) ath0: authenticated ath0: associate with AP 00:11:95:77:e0:b0 (try 1) ath0: RX ReassocResp from 00:11:95:77:e0:b0 (capab=0x421 status=0 aid=2) ath0: associated It is not clear to me how the first "direct probe" here happens, but this seems to be a race condition, if the user requests to deauth after requesting assoc, but before the assoc response is received. In that case, it may happen that mac80211 tries to report the assoc success to cfg80211, but gets blocked on the wdev lock that is held because the user is requesting the deauth. The result is that we run into a warning. This is mostly harmless, but maybe cause an unexpected event to be sent to userspace; we'd send an assoc success event although userspace was no longer expecting that. To fix this, remove the warning and check whether the race happened and in that case abort processing. Reported-by: Joseph Nahmias <joe@nahmias.net> Cc: stable@kernel.org Cc: 562016-quiet@bugs.debian.org Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-10wireless: update old static regulatory domain rulesJohn W. Linville
Update "US" and "JP" for current rules, and replace "EU" rules with the world roaming domain (since it was only a pseudo-domain anyway). Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-09cfg80211: Clear encryption privacy when key off is done.Vivek Natarajan
When the current_bss is not set, 'iwconfig <iface> key off' does not clear the private flag. Hence after we connect with WEP to an AP and then try to connect with another non-WEP AP, it does not work. This issue will not be seen if supplicant is used. Signed-off-by: Vivek Natarajan <vnatarajan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-04Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
2009-12-04cfg80211: indent regulatory messages with spacesKalle Valo
The regulatory messages in syslog look weird: kernel: cfg80211: Regulatory domain: US kernel: ^I(start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp) kernel: ^I(2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2700 mBm) kernel: ^I(5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi, 2300 mBm) kernel: ^I(5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi, 2300 mBm) kernel: ^I(5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi, 2300 mBm) kernel: ^I(5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi, 2300 mBm) kernel: ^I(5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 3000 mBm) Indent them with four spaces instead of the tab character to get prettier output. Signed-off-by: Kalle Valo <kalle.valo@nokia.com> Acked: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-04WE: Fix set events not propagatedJean Tourrilhes
I've just noticed that some events are no longer propagated for some wireless drivers. Basically, SET request with a extra payload for driver without commit handler. The fix is pretty simple, see attached. Actually, a few lines below this line, you will see that the event generation for simple SET (iwpoint-less ?) is done properly, and this other event generation does not need fixing. Signed-off-by: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-29net: Move && and || to end of previous lineJoe Perches
Not including net/atm/ Compiled tested x86 allyesconfig only Added a > 80 column line or two, which I ignored. Existing checkpatch plaints willfully, cheerfully ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-28cfg80211: Add PMKSA wext compatibility handlerSamuel Ortiz
With the addition of the *_pmksa cfg80211 ops, we can now add the corresponding wireless extensions compatibility handler. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-28nl80211: PMKSA caching supportSamuel Ortiz
This is an interface to set, delete and flush PMKIDs through nl80211. Main users would be fullmac devices which firmwares are capable of generating the RSN IEs for the re-association requests, e.g. iwmc3200wifi. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-28wireless : use a dedicated workqueue for cfg80211.Alban Browaeys
This patch moves the works cleanup, scan and events to a cfg80211 dedicated workqueue. Platform driver like eeepc-laptop ought to use works to rfkill (as new rfkill does lock in rfkill_unregister and the platform driver is called from rfkill_switch_all which also lock the same mutex). This raise a new issue in itself that the work scheduled by the platform driver to the global worqueue calls wiphy_unregister which flush_work scan and event works (which thus flush works on the global workqueue inside a work on the global workqueue) and also put on hold the wdev_cleanup_work (which prevents the dev_put on netdev thus indefinite Usage count error on wifi device). Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Alban Browaeys <prahal@yahoo.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-24Merge branch 'master' of ↵David S. Miller
2009-11-19mac80211: avoid spurious deauth frames/messagesJohannes Berg
With WEXT, it happens frequently that the SME requests an authentication but then deauthenticates right away because some new parameters came along. Every time this happens we print a deauth message and send a deauth frame, but both of that is rather confusing. Avoid it by aborting the authentication process silently, and telling cfg80211 about that. The patch looks larger than it really is: __cfg80211_auth_remove() is split out from cfg80211_send_auth_timeout(), there's no new code except __cfg80211_auth_canceled() (a one-liner) and the mac80211 bits (7 new lines of code). Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-19cfg80211: disallow bridging managed/adhoc interfacesJohannes Berg
A number of people have tried to add a wireless interface (in managed mode) to a bridge and then complained that it doesn't work. It cannot work, however, because in 802.11 networks all packets need to be acknowledged and as such need to be sent to the right address. Promiscuous doesn't help here. The wireless address format used for these links has only space for three addresses, the * transmitter, which must be equal to the sender (origin) * receiver (on the wireless medium), which is the AP in the case of managed mode * the recipient (destination), which is on the APs local network segment In an IBSS, it is similar, but the receiver and recipient must match and the third address is used as the BSSID. To avoid such mistakes in the future, disallow adding a wireless interface to a bridge. Felix has recently added a four-address mode to the AP and client side that can be used (after negotiating that it is possible, which must happen out-of-band by setting up both sides) for bridging, so allow that case. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-19cfg80211: introduce capability for 4addr modeJohannes Berg
It's very likely that not many devices will support four-address mode in station or AP mode so introduce capability bits for both modes, set them in mac80211 and check them when userspace tries to use the mode. Also, keep track of 4addr in cfg80211 (wireless_dev) and not in mac80211 any more. mac80211 can also be improved for the VLAN case by not looking at the 4addr flag but maintaining the station pointer for it correctly. However, keep track of use_4addr for station mode in mac80211 to avoid all the derefs. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-19cfg80211: convert bools into flagsJohannes Berg
We've accumulated a number of options for wiphys which make more sense as flags as we keep adding more. Convert the existing ones. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-18Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/sfc/sfe4001.c drivers/net/wireless/libertas/cmd.c drivers/staging/Kconfig drivers/staging/Makefile drivers/staging/rtl8187se/Kconfig drivers/staging/rtl8192e/Kconfig
2009-11-18mac80211: update cfg80211 scan result code for the updated mesh conf IERui Paulo
Signed-off-by: Rui Paulo <rpaulo@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-18mac80211: use a structure to hold the mesh config information elementRui Paulo
2009-11-18cfg80211: re-join IBSS when privacy changesJohannes Berg
When going from/to a WEP protected IBSS, we need to leave this one and join a new one to take care of the changed capability. Cc: Hong Zhang <henryzhang62@yahoo.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-18cfg80211: Allow reassociation in associated stateJouni Malinen
cfg80211 rejects all association requests when in associated state. This prevents clean roaming within an ESS since one would first need to disassociate before being able to request reassociation. Accept the reassociation request and let the old association to be dropped when the new one is completed. This fixes nl80211-based roaming with the current snapshot version of wpa_supplicant (that has code for requesting reassociation explicitly withthe previous BSSID attribute). Signed-off-by: Jouni Malinen <j@w1.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-13nl80211: only allow adding stations to running vlan interfacesFelix Fietkau
Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-13cfg80211: return channel noise via survey APIHolger Schurig
This patch implements the NL80211_CMD_GET_SURVEY command and an get_survey() ops that a driver can implement. The goal of this command is to allow a drivers to report channel survey data (e.g. channel noise, channel occupation). For now, only the mechanism to report back channel noise has been implemented. In future, there will either be a survey-trigger command --- or the existing scan-trigger command will be enhanced. This will allow user-space to request survey for arbitrary channels. Note: any driver that cannot report channel noise should not report any value at all, e.g. made-up -92 dBm. Signed-off-by: Holger Schurig <holgerschurig@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-13cfg80211: introduce nl80211_get_ifidx()Holger Schurig
... which get's rid of three indentical cut-n-paste sections. Signed-off-by: Holger Schurig <holgerschurig@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-13mac80211: add nl80211/cfg80211 handling of the new mesh root mode option.Rui Paulo
Signed-off-by: Rui Paulo <rpaulo@gmail.com> Signed-off-by: Javier Cardona <javier@cozybit.com> Reviewed-by: Andrey Yurovsky <andrey@cozybit.com> Tested-by: Brian Cavagnolo <brian@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-13mac80211: replace "destination" with "target" to follow the specRui Paulo
Resulting object files have the same MD5 as before. Signed-off-by: Rui Paulo <rpaulo@gmail.com> Signed-off-by: Javier Cardona <javier@cozybit.com> Reviewed-by: Andrey Yurovsky <andrey@cozybit.com> Tested-by: Brian Cavagnolo <brian@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-11mac80211: implement support for 4-address frames for AP and client modeFelix Fietkau
In some situations it might be useful to run a network with an Access Point and multiple clients, but with each client bridged to a network behind it. For this to work, both the client and the AP need to transmit 4-address frames, containing both source and destination MAC addresses. With this patch, you can configure a client to communicate using only 4-address frames for data traffic. On the AP side you can enable 4-address frames for individual clients by isolating them in separate AP VLANs which are configured in 4-address mode. Such an AP VLAN will be limited to one client only, and this client will be used as the destination for all traffic on its interface, regardless of the destination MAC address in the packet headers. The advantage of this mode compared to regular WDS mode is that it's easier to configure and does not require a static list of peer MAC addresses on any side. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-11nl80211: add a parameter for using 4-address frames on virtual interfacesFelix Fietkau
2009-11-09Merge branch 'master' of ↵David S. Miller
2009-11-06Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/usb/cdc_ether.c All CDC ethernet devices of type USB_CLASS_COMM need to use '&mbm_info'. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-04cfg80211: remove dead variableJohannes Berg
commit 211a4d12abf86fe0df4cd68fc6327cbb58f56f81 Author: Johannes Berg <johannes@sipsolutions.net> Date: Tue Oct 20 15:08:53 2009 +0900 cfg80211: sme: deauthenticate on assoc failure accidentally introduced a dead variable, I had changed the code to not need it while creating the patch and it looks like I forgot to remove the variable (and nobody else noticed either). Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (21 commits) mac80211: check interface is down before type change cfg80211: fix NULL ptr deref libertas if_usb: Fix crash on 64-bit machines mac80211: fix reason code output endianness mac80211: fix addba timer ath9k: fix misplaced semicolon on rate control b43: Fix DMA TX bounce buffer copying mac80211: fix BSS leak rt73usb.c : more ids ipw2200: fix oops on missing firmware gre: Fix dev_addr clobbering for gretap sky2: set carrier off in probe net: fix sk_forward_alloc corruption pcnet_cs: add cis of PreMax PE-200 ethernet pcmcia card r8169: Fix card drop incoming VLAN tagged MTU byte large jumbo frames ibmtr: possible Read buffer overflow? net: Fix RPF to work with policy routing net: fix kmemcheck annotations e1000e: rework disable K1 at 1000Mbps for 82577/82578 e1000e: config PHY via software after resets ...
2009-11-02cfg80211: validate scan channelsJohannes Berg
Currently it is possible to request a scan on only disabled channels, which could be problematic for some drivers. Reject such scans, and also ignore disabled channels that are given. This resuls in the scan begin/end event only including channels that are actually used. This makes the mac80211 check for disabled channels superfluous. At the same time, remove the no-IBSS check from mac80211 -- nothing says that we should not find any networks on channels that cannot be used for an IBSS, even when operating in IBSS mode. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-02cfg80211: Fix WEXT compat siwauth wpa and group cipherJouni Malinen
Neither of these commands should clear the current configuration value if they return error. Furthermore, cfg80211_set_cipher_group() should be able to handle IW_AUTH_CIPHER_NONE without reporting error. Signed-off-by: Jouni Malinen <j@w1.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-02cfg80211: fix NULL ptr derefJohannes Berg
commit 211a4d12abf86fe0df4cd68fc6327cbb58f56f81 Author: Johannes Berg <johannes@sipsolutions.net> Date: Tue Oct 20 15:08:53 2009 +0900 cfg80211: sme: deauthenticate on assoc failure introduced a potential NULL pointer dereference that some people have been hitting for some reason -- the params.bssid pointer is not guaranteed to be non-NULL for what seems to be a race between various ways of reaching the same thing. While I'm trying to analyse the problem more let's first fix the crash. I think the real fix may be to avoid doing _anything_ if it ended up being NULL, but right now I'm not sure yet. I think http://bugzilla.kernel.org/show_bug.cgi?id=14342 might also be this issue. Reported-by: Parag Warudkar <parag.lkml@gmail.com> Tested-by: Parag Warudkar <parag.lkml@gmail.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-10-30cfg80211/mac80211: use debugfs_remove_recursiveJohannes Berg
We can save a lot of code and pointers in the structs by using debugfs_remove_recursive(). First, change cfg80211 to use debugfs_remove_recursive() so that drivers do not need to clean up any files they added to the per-wiphy debugfs (if and only if they are ok to be accessed until after wiphy_unregister!). Then also make mac80211 use debugfs_remove_recursive() where necessary -- it need not remove per-wiphy files as cfg80211 now removes those, but netdev etc. files still need to be handled but can now be removed without needing struct dentry pointers to all of them. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-10-29Merge branch 'master' of ↵David S. Miller
2009-10-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (43 commits) net: Fix 'Re: PACKET_TX_RING: packet size is too long' netdev: usb: dm9601.c can drive a device not supported yet, add support for it qlge: Fix firmware mailbox command timeout. qlge: Fix EEH handling. AF_RAW: Augment raw_send_hdrinc to expand skb to fit iphdr->ihl (v2) bonding: fix a race condition in calls to slave MII ioctls virtio-net: fix data corruption with OOM sfc: Set ip_summed correctly for page buffers passed to GRO cnic: Fix L2CTX_STATUSB_NUM offset in context memory. MAINTAINERS: rt2x00 list is moderated airo: Reorder tests, check bounds before element mac80211: fix for incorrect sequence number on hostapd injected frames libertas spi: fix sparse errors mac80211: trivial: fix spelling in mesh_hwmp cfg80211: sme: deauthenticate on assoc failure mac80211: keep auth state when assoc fails mac80211: fix ibss joining b43: add 'struct b43_wl' missing declaration b43: Fix Bugzilla #14181 and the bug from the previous 'fix' rt2x00: Fix crypto in TX frame for rt2800usb ...
2009-10-27cfg80211: remove warning in deauth caseHolger Schurig
It might be the case that __cfg80211_disconnected() has already cleaned up wdev->current_bss() for us. The old code didn't catch that situation and didn't warn needlessly. Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-10-27cfg80211: no cookies in cfg80211_send_XXX()Holger Schurig
Get rid of cookies in cfg80211_send_XXX() functions. Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-10-27cfg80211: sme: deauthenticate on assoc failureJohannes Berg
When the in-kernel SME gets an association failure from the AP we don't deauthenticate, and thus get into a very confused state which will lead to warnings later on. Fix this by actually deauthenticating when the AP indicates an association failure. (Brought to you by the hacking session at Kernel Summit 2009 in Tokyo, Japan. -- JWL) Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-10-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (53 commits) vmxnet: fix 2 build problems net: add support for STMicroelectronics Ethernet controllers. net: ks8851_mll uses mii interfaces net/fec_mpc52xx: Fix kernel panic on FEC error net: Fix OF platform drivers coldplug/hotplug when compiled as modules TI DaVinci EMAC: Clear statistics register properly. r8169: partial support and phy init for the 8168d irda/sa1100_ir: check return value of startup hook udp: Fix udp_poll() and ioctl() WAN: fix Cisco HDLC handshaking. tcp: fix tcp_defer_accept to consider the timeout 3c574_cs: spin_lock the set_multicast_list function net: Teach pegasus driver to ignore bluetoother adapters with clashing Vendor:Product IDs netxen: fix pci bar mapping ethoc: fix warning from 32bit build libertas: fix build net: VMware virtual Ethernet NIC driver: vmxnet3 net: Fix IXP 2000 network driver building. libertas: fix build mac80211: document ieee80211_rx() context requirement ...
2009-10-11Merge branch 'master' of ↵David S. Miller
2009-10-11headers: remove sched.h from interrupt.hAlexey Dobriyan
After m68k's task_thread_info() doesn't refer to current, it's possible to remove sched.h from interrupt.h and not break m68k! Many thanks to Heiko Carstens for allowing this. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-10-08cfg80211: fix netns error unwinding bugJohannes Berg
The error unwinding code in set_netns has a bug that will make it run into a BUG_ON if passed a bad wiphy index, fix by not trying to unlock a wiphy that doesn't exist. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-10-07net/wireless/ethtool.h: drop unnecessary include of linux/ethtool.hJohn W. Linville
Everything including this header includes net/cfg80211.h, which includes linux/netdevice.h, which includes linux/ethtool.h already. Why slow-down the build, even a little bit? Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-10-07cfg80211: add firmware and hardware version to wiphyKalle Valo
It's useful to provide firmware and hardware version to user space and have a generic interface to retrieve them. Users can provide the version information in bug reports etc. Add fields for firmware and hardware version to struct wiphy. (Dropped nl80211 bits for now and modified remaining bits in favor of ethtool. -- JWL) Cc: Kalle Valo <kalle.valo@nokia.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
