path: root/net/wireless
2013-11-04wireless: radiotap: fix parsing buffer overrunJohannes Berg
commit f5563318ff1bde15b10e736e97ffce13be08bc1a upstream. When parsing an invalid radiotap header, the parser can overrun the buffer that is passed in because it doesn't correctly check 1) the minimum radiotap header size 2) the space for extended bitmaps The first issue doesn't affect any in-kernel user as they all check the minimum size before calling the radiotap function. The second issue could potentially affect the kernel if an skb is passed in that consists only of the radiotap header with a lot of extended bitmaps that extend past the SKB. In that case a read-only buffer overrun by at most 4 bytes is possible. Fix this by adding the appropriate checks to the parser. Reported-by: Evan Huus <eapache@gmail.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-11nl80211: fix mgmt tx status and testmode reporting for netnsMichal Kazior
commit a0ec570f4f69c4cb700d743a915096c2c8f56a99 upstream. These two events were sent to the default network namespace. This caused AP mode in a non-default netns to not work correctly. Mgmt tx status was multicasted to a different (default) netns instead of the one the AP was in. Signed-off-by: Michal Kazior <michal.kazior@tieto.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07wireless: regulatory: fix channel disabling race conditionJohannes Berg
commit 990de49f74e772b6db5208457b7aa712a5f4db86 upstream. When a full scan 2.4 and 5 GHz scan is scheduled, but then the 2.4 GHz part of the scan disables a 5.2 GHz channel due to, e.g. receiving country or frequency information, that 5.2 GHz channel might already be in the list of channels to scan next. Then, when the driver checks if it should do a passive scan, that will return false and attempt an active scan. This is not only wrong but can also lead to the iwlwifi device firmware crashing since it checks regulatory as well. Fix this by not setting the channel flags to just disabled but rather OR'ing in the disabled flag. That way, even if the race happens, the channel will be scanned passively which is still (mostly) correct. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-26wireless: allow 40 MHz on world roaming channels 12/13Johannes Berg
commit 43c771a1963ab461a2f194e3c97fded1d5fe262f upstream. When in world roaming mode, allow 40 MHz to be used on channels 12 and 13 so that an AP that is, e.g., using HT40+ on channel 9 (in the UK) can be used. Reported-by: Eddie Chapman <eddie@ehuk.net> Tested-by: Eddie Chapman <eddie@ehuk.net> Acked-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-17mac80211: verify that skb data is presentJohannes Berg
commit 9b395bc3be1cebf0144a127c7e67d56dbdac0930 upstream. A number of places in the mesh code don't check that the frame data is present and in the skb header when trying to access. Add those checks and the necessary pskb_may_pull() calls. This prevents accessing data that doesn't actually exist. To do this, export ieee80211_get_mesh_hdrlen() to be able to use it in mac80211. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-17wireless: drop invalid mesh address extension framesJohannes Berg
commit 7dd111e8ee10cc6816669eabcad3334447673236 upstream. The mesh header can have address extension by a 4th or a 5th and 6th address, but never both. Drop such frames in 802.11 -> 802.3 conversion along with any frames that have the wrong extension. Reviewed-by: Javier Cardona <javier@cozybit.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-17cfg80211: fix antenna gain handlingFelix Fietkau
commit c4a9fafc77a5318f5ed26c509bbcddf03e18c201 upstream. No driver initializes chan->max_antenna_gain to something sensible, and the only place where it is being used right now is inside ath9k. This leads to ath9k potentially using less tx power than it can use, which can decrease performance/range in some rare cases. Rather than going through every single driver, this patch initializes chan->orig_mag in wiphy_register(), ignoring whatever value the driver left in there. If a driver for some reason wishes to limit it independent from regulatory rulesets, it can do so internally. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02cfg80211: fix possible circular lock on reg_regdb_search()Luis R. Rodriguez
commit a85d0d7f3460b1a123b78e7f7e39bf72c37dfb78 upstream. When call_crda() is called we kick off a witch hunt search for the same regulatory domain on our internal regulatory database and that work gets kicked off on a workqueue, this is done while the cfg80211_mutex is held. If that workqueue kicks off it will first lock reg_regdb_search_mutex and later cfg80211_mutex but to ensure two CPUs will not contend against cfg80211_mutex the right thing to do is to have the reg_regdb_search() wait until the cfg80211_mutex is let go. The lockdep report is pasted below. cfg80211: Calling CRDA to update world regulatory domain ====================================================== [ INFO: possible circular locking dependency detected ] 3.3.8 #3 Tainted: G O ------------------------------------------------------- kworker/0:1/235 is trying to acquire lock: (cfg80211_mutex){+.+...}, at: [<816468a4>] set_regdom+0x78c/0x808 [cfg80211] but task is already holding lock: (reg_regdb_search_mutex){+.+...}, at: [<81646828>] set_regdom+0x710/0x808 [cfg80211] which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #2 (reg_regdb_search_mutex){+.+...}: [<800a8384>] lock_acquire+0x60/0x88 [<802950a8>] mutex_lock_nested+0x54/0x31c [<81645778>] is_world_regdom+0x9f8/0xc74 [cfg80211] -> #1 (reg_mutex#2){+.+...}: [<800a8384>] lock_acquire+0x60/0x88 [<802950a8>] mutex_lock_nested+0x54/0x31c [<8164539c>] is_world_regdom+0x61c/0xc74 [cfg80211] -> #0 (cfg80211_mutex){+.+...}: [<800a77b8>] __lock_acquire+0x10d4/0x17bc [<800a8384>] lock_acquire+0x60/0x88 [<802950a8>] mutex_lock_nested+0x54/0x31c [<816468a4>] set_regdom+0x78c/0x808 [cfg80211] other info that might help us debug this: Chain exists of: cfg80211_mutex --> reg_mutex#2 --> reg_regdb_search_mutex Possible unsafe locking scenario: CPU0 CPU1 ---- ---- lock(reg_regdb_search_mutex); lock(reg_mutex#2); lock(reg_regdb_search_mutex); lock(cfg80211_mutex); *** DEADLOCK *** 3 locks held by kworker/0:1/235: #0: (events){.+.+..}, at: [<80089a00>] process_one_work+0x230/0x460 #1: (reg_regdb_work){+.+...}, at: [<80089a00>] process_one_work+0x230/0x460 #2: (reg_regdb_search_mutex){+.+...}, at: [<81646828>] set_regdom+0x710/0x808 [cfg80211] stack backtrace: Call Trace: [<80290fd4>] dump_stack+0x8/0x34 [<80291bc4>] print_circular_bug+0x2ac/0x2d8 [<800a77b8>] __lock_acquire+0x10d4/0x17bc [<800a8384>] lock_acquire+0x60/0x88 [<802950a8>] mutex_lock_nested+0x54/0x31c [<816468a4>] set_regdom+0x78c/0x808 [cfg80211] Reported-by: Felix Fietkau <nbd@openwrt.org> Tested-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15cfg80211: fix interface combinations check for ADHOC(IBSS)Liang Li
partial of commit 8e8b41f9d8c8e63fc92f899ace8da91a490ac573 upstream. As part of commit 463454b5dbd8 ("cfg80211: fix interface combinations check"), this extra check was introduced: if ((all_iftypes & used_iftypes) != used_iftypes) goto cont; However, most wireless NIC drivers did not advertise ADHOC in wiphy.iface_combinations[i].limits[] and hence we'll get -EBUSY when we bring up a ADHOC wlan with commands similar to: # iwconfig wlan0 mode ad-hoc && ifconfig wlan0 up In commit 8e8b41f9d8c8e ("cfg80211: enforce lack of interface combinations"), the change below fixes the issue: if (total == 1) return 0; But it also introduces other dependencies for stable. For example, a full cherry pick of 8e8b41f9d8c8e would introduce additional regressions unless we also start cherry picking driver specific fixes like the following: 9b4760e ath5k: add possible wiphy interface combinations 1ae2fc2 mac80211_hwsim: advertise interface combinations 20c8e8d ath9k: add possible wiphy interface combinations And the purpose of the 'if (total == 1)' is to cover the specific use case (IBSS, adhoc) that was mentioned above. So we just pick the specific part out from 8e8b41f9d8c8e here. Doing so gives stable kernels a way to fix the change introduced by 463454b5dbd8, without having to make cherry picks specific to various NIC drivers. Signed-off-by: Liang Li <liang.li@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15cfg80211: process pending events when unregistering net deviceDaniel Drake
commit 1f6fc43e621167492ed4b7f3b4269c584c3d6ccc upstream. libertas currently calls cfg80211_disconnected() when it is being brought down. This causes an event to be allocated, but since the wdev is already removed from the rdev by the time that the event processing work executes, the event is never processed or freed. http://article.gmane.org/gmane.linux.kernel.wireless.general/95666 Fix this leak, and other possible situations, by processing the event queue when a device is being unregistered. Thanks to Johannes Berg for the suggestion. Signed-off-by: Daniel Drake <dsd@laptop.org> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15wireless: reg: restore previous behaviour of chan->max_power calculationsStanislaw Gruszka
commit 5e31fc0815a4e2c72b1b495fe7a0d8f9bfb9e4b4 upstream. commit eccc068e8e84c8fe997115629925e0422a98e4de Author: Hong Wu <Hong.Wu@dspg.com> Date: Wed Jan 11 20:33:39 2012 +0200 wireless: Save original maximum regulatory transmission power for the calucation of the local maximum transmit pow changed the way we calculate chan->max_power as min(chan->max_power, chan->max_reg_power). That broke rt2x00 (and perhaps some other drivers) that do not set chan->max_power. It is not so easy to fix this problem correctly in rt2x00. According to commit eccc068e8 changelog, change claim only to save maximum regulatory power - changing setting of chan->max_power was side effect. This patch restore previous calculations of chan->max_power and do not touch chan->max_reg_power. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Acked-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-19cfg80211: check iface combinations only when iface is runningMichal Kazior
commit f8cdddb8d61d16a156229f0910f7ecfc7a82c003 upstream. Don't validate interface combinations on a stopped interface. Otherwise we might end up being able to create a new interface with a certain type, but won't be able to change an existing interface into that type. This also skips some other functions when interface is stopped and changing interface type. Signed-off-by: Michal Kazior <michal.kazior@tieto.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> [Fixes regression introduced by cherry pick of 463454b5dbd8] Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-07-16cfg80211: fix potential deadlock in regulatoryEliad Peller
commit fe20b39ec32e975f1054c0b7866c873a954adf05 upstream. reg_timeout_work() calls restore_regulatory_settings() which takes cfg80211_mutex. reg_set_request_processed() already holds cfg80211_mutex before calling cancel_delayed_work_sync(reg_timeout), so it might deadlock. Call the async cancel_delayed_work instead, in order to avoid the potential deadlock. This is the relevant lockdep warning: cfg80211: Calling CRDA for country: XX ====================================================== [ INFO: possible circular locking dependency detected ] 3.4.0-rc5-wl+ #26 Not tainted ------------------------------------------------------- kworker/0:2/1391 is trying to acquire lock: (cfg80211_mutex){+.+.+.}, at: [<bf28ae00>] restore_regulatory_settings+0x34/0x418 [cfg80211] but task is already holding lock: ((reg_timeout).work){+.+...}, at: [<c0059e94>] process_one_work+0x1f0/0x480 which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #2 ((reg_timeout).work){+.+...}: [<c008fd44>] validate_chain+0xb94/0x10f0 [<c0090b68>] __lock_acquire+0x8c8/0x9b0 [<c0090d40>] lock_acquire+0xf0/0x114 [<c005b600>] wait_on_work+0x4c/0x154 [<c005c000>] __cancel_work_timer+0xd4/0x11c [<c005c064>] cancel_delayed_work_sync+0x1c/0x20 [<bf28b274>] reg_set_request_processed+0x50/0x78 [cfg80211] [<bf28bd84>] set_regdom+0x550/0x600 [cfg80211] [<bf294cd8>] nl80211_set_reg+0x218/0x258 [cfg80211] [<c03c7738>] genl_rcv_msg+0x1a8/0x1e8 [<c03c6a00>] netlink_rcv_skb+0x5c/0xc0 [<c03c7584>] genl_rcv+0x28/0x34 [<c03c6720>] netlink_unicast+0x15c/0x228 [<c03c6c7c>] netlink_sendmsg+0x218/0x298 [<c03933c8>] sock_sendmsg+0xa4/0xc0 [<c039406c>] __sys_sendmsg+0x1e4/0x268 [<c0394228>] sys_sendmsg+0x4c/0x70 [<c0013840>] ret_fast_syscall+0x0/0x3c -> #1 (reg_mutex){+.+.+.}: [<c008fd44>] validate_chain+0xb94/0x10f0 [<c0090b68>] __lock_acquire+0x8c8/0x9b0 [<c0090d40>] lock_acquire+0xf0/0x114 [<c04734dc>] mutex_lock_nested+0x48/0x320 [<bf28b2cc>] reg_todo+0x30/0x538 [cfg80211] [<c0059f44>] process_one_work+0x2a0/0x480 [<c005a4b4>] worker_thread+0x1bc/0x2bc [<c0061148>] kthread+0x98/0xa4 [<c0014af4>] kernel_thread_exit+0x0/0x8 -> #0 (cfg80211_mutex){+.+.+.}: [<c008ed58>] print_circular_bug+0x68/0x2cc [<c008fb28>] validate_chain+0x978/0x10f0 [<c0090b68>] __lock_acquire+0x8c8/0x9b0 [<c0090d40>] lock_acquire+0xf0/0x114 [<c04734dc>] mutex_lock_nested+0x48/0x320 [<bf28ae00>] restore_regulatory_settings+0x34/0x418 [cfg80211] [<bf28b200>] reg_timeout_work+0x1c/0x20 [cfg80211] [<c0059f44>] process_one_work+0x2a0/0x480 [<c005a4b4>] worker_thread+0x1bc/0x2bc [<c0061148>] kthread+0x98/0xa4 [<c0014af4>] kernel_thread_exit+0x0/0x8 other info that might help us debug this: Chain exists of: cfg80211_mutex --> reg_mutex --> (reg_timeout).work Possible unsafe locking scenario: CPU0 CPU1 ---- ---- lock((reg_timeout).work); lock(reg_mutex); lock((reg_timeout).work); lock(cfg80211_mutex); *** DEADLOCK *** 2 locks held by kworker/0:2/1391: #0: (events){.+.+.+}, at: [<c0059e94>] process_one_work+0x1f0/0x480 #1: ((reg_timeout).work){+.+...}, at: [<c0059e94>] process_one_work+0x1f0/0x480 stack backtrace: [<c001b928>] (unwind_backtrace+0x0/0x12c) from [<c0471d3c>] (dump_stack+0x20/0x24) [<c0471d3c>] (dump_stack+0x20/0x24) from [<c008ef70>] (print_circular_bug+0x280/0x2cc) [<c008ef70>] (print_circular_bug+0x280/0x2cc) from [<c008fb28>] (validate_chain+0x978/0x10f0) [<c008fb28>] (validate_chain+0x978/0x10f0) from [<c0090b68>] (__lock_acquire+0x8c8/0x9b0) [<c0090b68>] (__lock_acquire+0x8c8/0x9b0) from [<c0090d40>] (lock_acquire+0xf0/0x114) [<c0090d40>] (lock_acquire+0xf0/0x114) from [<c04734dc>] (mutex_lock_nested+0x48/0x320) [<c04734dc>] (mutex_lock_nested+0x48/0x320) from [<bf28ae00>] (restore_regulatory_settings+0x34/0x418 [cfg80211]) [<bf28ae00>] (restore_regulatory_settings+0x34/0x418 [cfg80211]) from [<bf28b200>] (reg_timeout_work+0x1c/0x20 [cfg80211]) [<bf28b200>] (reg_timeout_work+0x1c/0x20 [cfg80211]) from [<c0059f44>] (process_one_work+0x2a0/0x480) [<c0059f44>] (process_one_work+0x2a0/0x480) from [<c005a4b4>] (worker_thread+0x1bc/0x2bc) [<c005a4b4>] (worker_thread+0x1bc/0x2bc) from [<c0061148>] (kthread+0x98/0xa4) [<c0061148>] (kthread+0x98/0xa4) from [<c0014af4>] (kernel_thread_exit+0x0/0x8) cfg80211: Calling CRDA to update world regulatory domain cfg80211: World regulatory domain updated: cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp) cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm) cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm) cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm) cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm) cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm) Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-17cfg80211: fix interface combinations checkJohannes Berg
commit 463454b5dbd8dbab6e2fc6c557329e5b811b9c32 upstream. If a given interface combination doesn't contain a required interface type then we missed checking that and erroneously allowed it even though iface type wasn't there at all. Add a check that makes sure that all interface types are accounted for. Reported-by: Mohammed Shafi Shajakhan <mohammed@qca.qualcomm.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-01cfg80211: warn if db.txt is empty with CONFIG_CFG80211_INTERNAL_REGDBLuis R. Rodriguez
commit 80007efeff0568375b08faf93c7aad65602cb97e upstream. It has happened twice now where elaborate troubleshooting has undergone on systems where CONFIG_CFG80211_INTERNAL_REGDB [0] has been set but yet net/wireless/db.txt was not updated. Despite the documentation on this it seems system integrators could use some more help with this, so throw out a kernel warning at boot time when their database is empty. This does mean that the error-prone system integrator won't likely realize the issue until they boot the machine but -- it does not seem to make sense to enable a build bug breaking random build testing. [0] http://wireless.kernel.org/en/developers/Regulatory/CRDA#CONFIG_CFG80211_INTERNAL_REGDB Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Youngsin Lee <youngsin@qualcomm.com> Cc: Raja Mani <rmani@qca.qualcomm.com> Cc: Senthil Kumar Balasubramanian <senthilb@qca.qualcomm.com> Cc: Vipin Mehta <vipimeht@qca.qualcomm.com> Cc: yahuan@qca.qualcomm.com Cc: jjan@qca.qualcomm.com Cc: vthiagar@qca.qualcomm.com Cc: henrykim@qualcomm.com Cc: jouni@qca.qualcomm.com Cc: athiruve@qca.qualcomm.com Cc: cjkim@qualcomm.com Cc: philipk@qca.qualcomm.com Cc: sunnykim@qualcomm.com Cc: sskwak@qualcomm.com Cc: kkim@qualcomm.com Cc: mattbyun@qualcomm.com Cc: ryanlee@qualcomm.com Cc: simbap@qualcomm.com Cc: krislee@qualcomm.com Cc: conner@qualcomm.com Cc: hojinkim@qualcomm.com Cc: honglee@qualcomm.com Cc: johnwkim@qualcomm.com Cc: jinyong@qca.qualcomm.com Signed-off-by: Luis R. Rodriguez <mcgrof@frijolero.org> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13cfg80211: fix interface combinations check.Lukasz Kucharczyk
Signed-off-by: Lukasz Kucharczyk <lukasz.kucharczyk@tieto.com> Cc: stable@vger.kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-04-09net/wireless/wext-core.c: add missing kfreeJulia Lawall
Free extra as done in the error-handling code just above. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-04-09nl80211: ensure interface is up in various APIsJohannes Berg
The nl80211 handling code should ensure as much as it can that the interface is in a valid state, it can certainly ensure the interface is running. Not doing so can cause calls through mac80211 into the driver that result in warnings and unspecified behaviour in the driver. Cc: stable@vger.kernel.org Reported-by: Ben Greear <greearb@candelatech.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-04-05Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge batch of fixes from Andrew Morton: "The simple_open() cleanup was held back while I wanted for laggards to merge things. I still need to send a few checkpoint/restore patches. I've been wobbly about merging them because I'm wobbly about the overall prospects for success of the project. But after speaking with Pavel at the LSF conference, it sounds like they're further toward completion than I feared - apparently davem is at the "has stopped complaining" stage regarding the net changes. So I need to go back and re-review those patchs and their (lengthy) discussion." * emailed from Andrew Morton <akpm@linux-foundation.org>: (16 patches) memcg swap: use mem_cgroup_uncharge_swap fix backlight: add driver for DA9052/53 PMIC v1 C6X: use set_current_blocked() and block_sigmask() MAINTAINERS: add entry for sparse checker MAINTAINERS: fix REMOTEPROC F: typo alpha: use set_current_blocked() and block_sigmask() simple_open: automatically convert to simple_open() scripts/coccinelle/api/simple_open.cocci: semantic patch for simple_open() libfs: add simple_open() hugetlbfs: remove unregister_filesystem() when initializing module drivers/rtc/rtc-88pm860x.c: fix rtc irq enable callback fs/xattr.c:setxattr(): improve handling of allocation failures fs/xattr.c:listxattr(): fall back to vmalloc() if kmalloc() failed fs/xattr.c: suppress page allocation failure warnings from sys_listxattr() sysrq: use SEND_SIG_FORCED instead of force_sig() proc: fix mount -t proc -o AAA
2012-04-05simple_open: automatically convert to simple_open()Stephen Boyd
Many users of debugfs copy the implementation of default_open() when they want to support a custom read/write function op. This leads to a proliferation of the default_open() implementation across the entire tree. Now that the common implementation has been consolidated into libfs we can replace all the users of this function with simple_open(). This replacement was done with the following semantic patch: <smpl> @ open @ identifier open_f != simple_open; identifier i, f; @@ -int open_f(struct inode *i, struct file *f) -{ ( -if (i->i_private) -f->private_data = i->i_private; | -f->private_data = i->i_private; ) -return 0; -} @ has_open depends on open @ identifier fops; identifier open.open_f; @@ struct file_operations fops = { ... -.open = open_f, +.open = simple_open, ... }; </smpl> [akpm@linux-foundation.org: checkpatch fixes] Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Julia Lawall <Julia.Lawall@lip6.fr> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-26cfg80211: allow CFG80211_SIGNAL_TYPE_UNSPEC in station_infoJohn W. Linville
The station_info struct had demanded dBm signal values, but the cfg80211 wireless extensions implementation was also accepting "unspecified" (i.e. RSSI) unit values while the nl80211 code was completely unaware of them. Resolve this by formally allowing the "unspecified" units while making nl80211 ignore them. Signed-off-by: John W. Linville <linville@tuxdriver.com> Reviewed-by: Johannes Berg <johannes@sipsolutions.net>
2012-03-13cfg80211: clarify timestamp in cfg80211_inform_bssJohannes Berg
This is intended to be the timestamp sent by the peer in the beacon/probe response, not any form of host timestamp. Clarify the documentation and variable names. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-03-12cfg80211: Add background scan period attribute.Bala Shanmugam
Receive background scan period as part of connect command and pass the same to the driver. Signed-off-by: Bala Shanmugam <bkamatch@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-03-06cfg80211: expose cfg80211_calculate_bitrate()Thomas Pedersen
Signed-off-by: Thomas Pedersen <thomas@cozybit.com> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-03-06cfg80211/mac80211: report signal strength for mgmt framesJohannes Berg
Add the signal strength (in dBm only for now) to frames that are received via nl80211's various frame APIs. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Acked-by: Kalle Valo <kvalo@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-03-05cfg80211: Add an attribute to set inactivity timeout in AP modeVasanthakumar Thiagarajan
This patch adds an attribute, NL80211_ATTR_INACTIVITY_TIMEOUT, to set the inactivity timeout which can be used to remove the station in AP mode. This can be passed in NL80211_CMD_START_AP and used by the drivers which have AP MLME in firmware but don't support get_station() properly. To disable inactivity timer in userspace, wpa_s for example, there is a new flag, NL80211_FEATURE_INACTIVITY_TIMER, in nl80211_feature_flags through which drivers can register their capability to use the inactivity timeout to free the stations. Signed-off-by: Vasanthakumar Thiagarajan <vthiagar@qca.qualcomm.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-03-05{nl,cfg,mac}80211: Implement RSSI threshold for mesh peeringAshok Nagarajan
Mesh peer links are established only if average rssi of the peer candidate satisfies the threshold. This is not in 802.11s specification but was requested by David Fulgham, an open80211s user. This is a way to avoid marginal peer links with stations that are barely within range. This patch adds a new mesh configuration parameter, mesh_rssi_threshold. This feature is supported only for hardwares that report signal in dBm. Signed-off-by: Ashok Nagarajan <ashok@cozybit.com> Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-02-29cfg80211: remove cookies from callbacksJohannes Berg
In "cfg80211: no cookies in cfg80211_send_XXX()" Holger Schurig removed the cookies in the calls from mac80211 to cfg80211, but the ones in the other direction were left in. Remove them now. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-02-22cfg80211: restructure AP/GO mode APIJohannes Berg
The AP/GO mode API isn't very clearly defined, it has "set beacon" and "new beacon" etc. Modify the API to the following: * start AP -- all settings * change beacon -- new beacon data * stop AP -- stop AP mode operation This also reflects in the nl80211 API, rename the commands there correspondingly (but keep the old names for compatibility.) Overall, this makes it much clearer what's going on in the API. Kalle developed the ath6kl changes, I created the rest of the patch. Signed-off-by: Kalle Valo <kvalo@qca.qualcomm.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-02-06mac80211: off by one in mcs mask handlingDan Carpenter
"ridx" is used as an index into the mcs_mask[] array which has IEEE80211_HT_MCS_MASK_LEN elements. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-02-06cfg80211/mac80211: userspace peer authorization in IBSSAntonio Quartulli
If the IBSS network is RSN-protected, let userspace authorize the stations instead of adding them as AUTHORIZED by default. Signed-off-by: Antonio Quartulli <ordex@autistici.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-02-06cfg80211: export cfg80211_ref_bssJohannes Berg
This is needed by mac80211 to keep a reference to a BSS alive for the auth process. Remove the old version of cfg80211_ref_bss() since it's not actually used. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-02-06cfg80211: stop tracking authenticated stateJohannes Berg
To track authenticated state seems to have been a design mistake in cfg80211. It is possible to have out of band authentication (FT), tracking multiple authentications caused more problems than it ever helped, and the implementation in mac80211 is too complex. Remove all this complexity, and let userspace do whatever it wants to, mac80211 can deal with that just fine. Association is still tracked of course, but authentication no longer is. Local auth state changes are thus no longer of value, so ignore them completely. This will also help implement SAE -- asking the driver to do an authentication is now almost equivalent to sending an authentication frame, with the exception of shared key authentication which is still handled completely. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-30nl80211: add support for mcs masksSimon Wunderlich
Allow to set mcs masks through nl80211. We also allow to set MCS rates but no legacy rates (and vice versa). Signed-off-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de> Signed-off-by: Mathias Kretschmer <mathias.kretschmer@fokus.fraunhofer.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-27{nl,cfg,mac}80211: Add support of setting non-forwarding entity in MeshChun-Yeow Yeoh
A mesh node that joins the mesh network is by default a forwarding entity. This patch allows the mesh node to set as non-forwarding entity. Whenever dot11MeshForwarding is set to 0, the mesh node can prevent itself from forwarding the traffic which is not destined to him. Signed-off-by: Chun-Yeow Yeoh <yeohchunyeow@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-27cfg80211: fix a few -Wshadow warningsJohannes Berg
It seems that -Wshadow is no longer default in sparse runs, but let's fix the warnings anyway. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-24wireless: Save original maximum regulatory transmission power for the ↵Hong Wu
calucation of the local maximum transmit power The local maximum transmit power is the maximum power a wireless device allowed to transmit. If Power Constraint is presented, the local maximum power equals to the maximum allowed power defined in regulatory domain minus power constraint. The maximum transmit power is maximum power a wireless device capable of transmitting, and should be used in Power Capability element (7.3.2.16 IEEE802.11 2007). The transmit power from a wireless device should not greater than the local maximum transmit power. The maximum transmit power was not calculated correctly in the current Linux wireless/mac80211 when Power Constraint is presented. Signed-off-by: Hong Wu <hong.wu@dspg.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-11nl80211: fix old station flags compatibilityJohannes Berg
My patch to validate station flags broke compatibility with the old station flags setting where all flags are always set at once since it always set the mask as all possible flags which ended up being rejected later in the station add/modify code. Fix by parsing only the current flags in the old flags attribute -- new applications and new flags should use (and will now require) the new flags attribute where the mask is given by the application. Reported-and-tested-by: Thomas Hilber <ath9k-dev@toh.cx> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-04wireless: Treat IPv6 diffserv the same as IPv4 for 802.11eDave Täht
Wireless will select a different hardware queue based on the top 3 bits of the diffserv field, for ipv4. Extend that queue selection mechanism to ipv6, and make the calls orthogonal. Signed-off-by: Dave Täht <dave.taht@bufferbloat.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-04cfg80211: relicense reg.c reg.h and genregdb.awk to ISCLuis R. Rodriguez
Following the tradition we have had with ath5k, ath9k, CRDA, wireless-regdb I'd like to license this code under the permissive ISC license for the code sharing purposes with other OSes, it'd sure be nice to help the landscape in this area. Although I am %82.89 owner of the regulatory code I have asked every contributor to the regulatory code and have receieved positive Acked-bys from everyone except two deceased entities: o Frans Pop RIP 2010 [0] - Frans Pop <elendil@planet.nl> - Frans Pop <fjp@debian.org> o Nokia RIP February, 11, 2011 [1], [2] - ext-yuri.ershov@nokia.com - kalle.valo@nokia.com Frans Pop's contribution was a simple patch 55f98938, titled, "wireless: remove trailing space in messages" which just add a \n to some printk lines. I'm going to treat these additions as uncopyrightable. As for the contributions made by employees on behalf of Nokia my contact point was Petri Karhula <petri.karhula@nokia.com> but after one month he noted he had not been able to get traction from the legal department on this request, as such it I proceeded by replacing their contributions in previous patches. The end goal is to help a clean rewrite that starts in userspace that is shared under ISC license which currently is taking place with the regulatory simulator [3]. [0] http://lists.debian.org/debian-devel/2011/12/msg00263.html [1] http://press.nokia.com/2011/02/11/nokia-outlines-new-strategy-introduces-new-leadership-operational-structure/ [2] http://NokiaPlanB.com [3] git://github.com/mcgrof/regsim.git Acked-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Acked-by: Dan Carpenter <error27@gmail.com> Acked-by: Mihai Moldovan <ionic@ionic.de> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Sven Neumann <s.neumann@raumfeld.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Tomas Winkler <tomas.winkler@intel.com> Acked-by: Tony Vroon <tony@linx.net> Acked-by: Pavel Roskin <proski@gnu.org> Acked-by: Bob Copeland <me@bobcopeland.com> Acked-by: Lucas De Marchi <lucas.demarchi@profusion.mobi> Acked-by: Pat Erley <pat-lkml@erley.org> Acked-by: Tejun Heo <tj@kernel.org> Acked-by: John W. Linville <linville@tuxdriver.com> Acked-by: Chris Wright <chrisw@sous-sol.org> Acked-by: Joe Perches <joe@perches.com> Acked-by: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: John Gordon <john@devicescape.com> Acked-by: Simon Barber <protocolmagic@gmail.com> Acked-by: Rajkumar Manoharan <rmanohar@qca.qualcomm.com> Acked-by: Jiri Benc <jbenc@upir.cz> Acked-by: Bruno Randolf <br1@einfach.org> Acked-by: Scott James Remnant <keybuk@google.com> Acked-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-04cfg80211: replace reg.c Nokia commit 269ac5Luis R. Rodriguez
Nokia hasn't gotten back to me in over 1 month for a relicense change request. There are only a few changes that they contributed, so just reverting their changes but replacing with another set. This change replaces this commit: commit 269ac5fd2d75b118d76a2291e28796527db2f3f8 Author: Kalle Valo <kalle.valo@nokia.com> Date: Tue Dec 1 10:47:15 2009 +0200 cfg80211: indent regulatory messages with spaces The regulatory messages in syslog look weird: kernel: cfg80211: Regulatory domain: US kernel: ^I(start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp) kernel: ^I(2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2700 mBm) kernel: ^I(5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi, 2300 mBm) kernel: ^I(5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi, 2300 mBm) kernel: ^I(5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi, 2300 mBm) kernel: ^I(5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi, 2300 mBm) kernel: ^I(5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 3000 mBm) Indent them with four spaces instead of the tab character to get prettier output. Signed-off-by: Kalle Valo <kalle.valo@nokia.com> Acked: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Cc: Petri Karhula <petri.karhula@nokia.com> Signed-off-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-04cfg80211: replace reg.c Nokia commit c4c32294Luis R. Rodriguez
Nokia hasn't gotten back to me in over 1 month for a relicense change request. There are only a few changes that they contributed, so just reverting their changes but replacing with another set. This change replaces this commit: commit c4c322941ce0d7e2b7b8794ad70683123d9cb26a Author: Yuri Ershov <ext-yuri.ershov@nokia.com> Date: Tue Jun 29 15:08:08 2010 +0400 cfg80211: Update of regulatory request initiator handling In some cases there could be possible dereferencing freed pointer. The update is intended to avoid this issue. Signed-off-by: Yuri Ershov <ext-yuri.ershov@nokia.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Cc: Petri Karhula <petri.karhula@nokia.com> Signed-off-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-04wireless: Protect regdomain change by mutexDmitry Shmidt
Signed-off-by: Dmitry Shmidt <dimitrysh@google.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-12-19cfg80211: Return beacon loss count in stationPaul Stewart
If station info contains a beacon loss count, return it to userspace. Signed-off-by: Paul Stewart <pstew@chromium.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-12-16cfg80211: Restore orig channel values upon disconnectRajkumar Manoharan
When we restore regulatory settings the world regulatory domain is properly reset on cfg80211 (or user prefered regulatory domain) but we were never setting back channel values for drivers that use WIPHY_FLAG_CUSTOM_REGULATORY. Set these values up again by using the orig_ channel parameters. This fixes restoring custom regulatory settings upon disconnect events. Cc: compat@orbit-lab.org Cc: Paul Stewart <pstew@google.com> Cc: Rajkumar Manoharan <rmanohar@qca.qualcomm.com> Cc: Senthilkumar Balasubramanian <senthilb@qca.qualcomm.com> Signed-off-by: Rajkumar Manoharan <rmanohar@qca.qualcomm.com> Signed-off-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-12-16cfg80211: allow following country IE power for custom regdom cardsLuis R. Rodriguez
By definition WIPHY_FLAG_STRICT_REGULATORY was intended to allow the wiphy to adjust itself to the country IE power information if the card had no regulatory data but we had no way to tell cfg80211 that if the card also had its own custom regulatory domain (these are typically custom world regulatory domains) that we want to follow the country IE's noted values for power for each channel. We add support for this and document it. This is not a critical fix but a performance optimization for cards with custom regulatory domains that associate to an AP with sends out country IEs with a higher EIRP than the one on the custom regulatory domain. In practice the only driver affected right now are the Atheros drivers as they are the only drivers using both WIPHY_FLAG_STRICT_REGULATORY and WIPHY_FLAG_CUSTOM_REGULATORY -- used on cards that have an Atheros world regulatory domain. Cards that have been programmed to follow a country specifically will not follow the country IE power. So although not a stable fix distributions should consider cherry picking this. Cc: compat@orbit-lab.org Cc: Paul Stewart <pstew@google.com> Cc: Rajkumar Manoharan <rmanohar@qca.qualcomm.com> Cc: Senthilkumar Balasubramanian <senthilb@qca.qualcomm.com> Reported-by: Rajkumar Manoharan <rmanohar@qca.qualcomm.com> Signed-off-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-12-15cfg80211: validate nl80211 station handling betterJohannes Berg
The nl80211 station handling code is a bit messy and doesn't do a lot of validation. It seems like this could be an issue for drivers that don't use mac80211 to validate everything. As cfg80211 doesn't keep station state, move the validation of allowing supported_rates to change for TDLS only in station mode to mac80211. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-12-15nl80211: add TDLS peer flag to policyJohannes Berg
This was evidently missed in the TDLS patch (07ba55d7). Cc: Arik Nemtsov <arik@wizery.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-12-14nl80211: accept testmode dump with netdevJohannes Berg
All nl80211 commands that need only the wiphy still allow identifying it by giving an interface index, except, as Kenny pointed out, the testmode dump support. Fix this by looking up the wiphy via the ifidx in this case as well. Tested-by: Kenny Hsu <kenny.hsu@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-12-13cfg80211: notify core hints that helps to restore regd settingsRajkumar Manoharan
Regulatory updates set by CORE are ignored for custom regulatory cards. Let us notify the changes to the driver, as some drivers uses core hint to restore its orig_* reg domain setting. Cc: Paul Stewart <pstew@google.com> Signed-off-by: Rajkumar Manoharan <rmanohar@qca.qualcomm.com> Acked-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
