path: root/net/x25
2011-11-06Merge branch 'modsplit-Oct31_2011' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux * 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits) Revert "tracing: Include module.h in define_trace.h" irq: don't put module.h into irq.h for tracking irqgen modules. bluetooth: macroize two small inlines to avoid module.h ip_vs.h: fix implicit use of module_get/module_put from module.h nf_conntrack.h: fix up fallout from implicit moduleparam.h presence include: replace linux/module.h with "struct module" wherever possible include: convert various register fcns to macros to avoid include chaining crypto.h: remove unused crypto_tfm_alg_modname() inline uwb.h: fix implicit use of asm/page.h for PAGE_SIZE pm_runtime.h: explicitly requires notifier.h linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h miscdevice.h: fix up implicit use of lists and types stop_machine.h: fix implicit use of smp.h for smp_processor_id of: fix implicit use of errno.h in include/linux/of.h of_platform.h: delete needless include <linux/module.h> acpi: remove module.h include from platform/aclinux.h miscdevice.h: delete unnecessary inclusion of module.h device_cgroup.h: delete needless include <linux/module.h> net: sch_generic remove redundant use of <linux/module.h> net: inet_timewait_sock doesnt need <linux/module.h> ... Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in - drivers/media/dvb/frontends/dibx000_common.c - drivers/media/video/{mt9m111.c,ov6650.c} - drivers/mfd/ab3550-core.c - include/linux/dmaengine.h
2011-11-02x25: Fix NULL dereference in x25_recvmsgDave Jones
commit cb101ed2 in 3.0 introduced a bug in x25_recvmsg() When passed bogus junk from userspace, x25->neighbour can be NULL, as shown in this oops.. BUG: unable to handle kernel NULL pointer dereference at 000000000000001c IP: [<ffffffffa05482bd>] x25_recvmsg+0x4d/0x280 [x25] PGD 1015f3067 PUD 105072067 PMD 0 Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC CPU 0 Pid: 27928, comm: iknowthis Not tainted 3.1.0+ #2 Gigabyte Technology Co., Ltd. GA-MA78GM-S2H/GA-MA78GM-S2H RIP: 0010:[<ffffffffa05482bd>] [<ffffffffa05482bd>] x25_recvmsg+0x4d/0x280 [x25] RSP: 0018:ffff88010c0b7cc8 EFLAGS: 00010282 RAX: 0000000000000000 RBX: ffff88010c0b7d78 RCX: 0000000000000c02 RDX: ffff88010c0b7d78 RSI: ffff88011c93dc00 RDI: ffff880103f667b0 RBP: ffff88010c0b7d18 R08: 0000000000000000 R09: 0000000000000000 R10: 0000000000000000 R11: 0000000000000000 R12: ffff880103f667b0 R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000 FS: 00007f479ce7f700(0000) GS:ffff88012a600000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 000000000000001c CR3: 000000010529e000 CR4: 00000000000006f0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process iknowthis (pid: 27928, threadinfo ffff88010c0b6000, task ffff880103faa4f0) Stack: 0000000000000c02 0000000000000c02 ffff88010c0b7d18 ffffff958153cb37 ffffffff8153cb60 0000000000000c02 ffff88011c93dc00 0000000000000000 0000000000000c02 ffff88010c0b7e10 ffff88010c0b7de8 ffffffff815372c2 Call Trace: [<ffffffff8153cb60>] ? sock_update_classid+0xb0/0x180 [<ffffffff815372c2>] sock_aio_read.part.10+0x142/0x150 [<ffffffff812d6752>] ? inode_has_perm+0x62/0xa0 [<ffffffff815372fd>] sock_aio_read+0x2d/0x40 [<ffffffff811b05e2>] do_sync_read+0xd2/0x110 [<ffffffff812d3796>] ? security_file_permission+0x96/0xb0 [<ffffffff811b0a91>] ? rw_verify_area+0x61/0x100 [<ffffffff811b103d>] vfs_read+0x16d/0x180 [<ffffffff811b109d>] sys_read+0x4d/0x90 [<ffffffff81657282>] system_call_fastpath+0x16/0x1b Code: 8b 66 20 4c 8b 32 48 89 d3 48 89 4d b8 45 89 c7 c7 45 cc 95 ff ff ff 4d 85 e4 0f 84 ed 01 00 00 49 8b 84 24 18 05 00 00 4c 89 e7 78 1c 01 45 19 ed 31 f6 e8 d5 37 ff e0 41 0f b6 44 24 0e 41 Signed-off-by: Dave Jones <davej@redhat.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-31net: Add export.h for EXPORT_SYMBOL/THIS_MODULE to non-modulesPaul Gortmaker
These files are non modular, but need to export symbols using the macros now living in export.h -- call out the include so that things won't break when we remove the implicit presence of module.h from everywhere. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-17x25: Prevent skb overreads when checking call user dataMatthew Daley
x25_find_listener does not check that the amount of call user data given in the skb is big enough in per-socket comparisons, hence buffer overreads may occur. Fix this by adding a check. Signed-off-by: Matthew Daley <mattjd@gmail.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Andrew Hendry <andrew.hendry@gmail.com> Cc: stable <stable@kernel.org> Acked-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-17x25: Handle undersized/fragmented skbsMatthew Daley
There are multiple locations in the X.25 packet layer where a skb is assumed to be of at least a certain size and that all its data is currently available at skb->data. These assumptions are not checked, hence buffer overreads may occur. Use pskb_may_pull to check these minimal size assumptions and ensure that data is available at skb->data when necessary, as well as use skb_copy_bits where needed. Signed-off-by: Matthew Daley <mattjd@gmail.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Andrew Hendry <andrew.hendry@gmail.com> Cc: stable <stable@kernel.org> Acked-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-17x25: Validate incoming call user data lengthsMatthew Daley
X.25 call user data is being copied in its entirety from incoming messages without consideration to the size of the destination buffers, leading to possible buffer overflows. Validate incoming call user data lengths before these copies are performed. It appears this issue was noticed some time ago, however nothing seemed to come of it: see http://www.spinics.net/lists/linux-x25/msg00043.html and commit 8db09f26f912f7c90c764806e804b558da520d4f. Signed-off-by: Matthew Daley <mattjd@gmail.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Tested-by: Andrew Hendry <andrew.hendry@gmail.com> Cc: stable <stable@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-01x25: Reduce switch/case indentJoe Perches
Make the case labels the same indent as the switch. git diff -w shows 80 column line reflowing. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-05x25: remove the BKLArnd Bergmann
This replaces all instances of lock_kernel in x25 with lock_sock, taking care to release the socket lock around sleeping functions (sock_alloc_send_skb and skb_recv_datagram). It is not clear whether this is a correct solution, but it seem to be what other protocols do in the same situation. Includes a fix suggested by Eric Dumazet. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: David S. Miller <davem@davemloft.net> Tested-by: Andrew Hendry <andrew.hendry@gmail.com> Cc: linux-x25@vger.kernel.org Cc: netdev@vger.kernel.org Cc: Eric Dumazet <eric.dumazet@gmail.com>
2011-02-09x25: Do not reference freed memory.David S. Miller
In x25_link_free(), we destroy 'nb' before dereferencing 'nb->dev'. Don't do this, because 'nb' might be freed by then. Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Tested-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-07x25: possible skb leak on bad facilitiesandrew hendry
Originally x25_parse_facilities returned -1 for an error 0 meaning 0 length facilities >0 the length of the facilities parsed. 5ef41308f94dc ("x25: Prevent crashing when parsing bad X.25 facilities") introduced more error checking in x25_parse_facilities however used 0 to indicate bad parsing a6331d6f9a429 ("memory corruption in X.25 facilities parsing") followed this further for DTE facilities, again using 0 for bad parsing. The meaning of 0 got confused in the callers. If the facilities are messed up we can't determine where the data starts. So patch makes all parsing errors return -1 and ensures callers close and don't use the skb further. Reported-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-08Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/ath/ath9k/ar9003_eeprom.c net/llc/af_llc.c
2010-12-08x25: decrement netdev reference counts on unloadApollon Oikonomopoulos
x25 does not decrement the network device reference counts on module unload. Thus unregistering any pre-existing interface after unloading the x25 module hangs and results in unregister_netdevice: waiting for tap0 to become free. Usage count = 1 This patch decrements the reference counts of all interfaces in x25_link_free, the way it is already done in x25_link_device_down for NETDEV_DOWN events. Signed-off-by: Apollon Oikonomopoulos <apollon@noc.grnet.gr> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-28X25 remove bkl in call user data length ioctlandrew hendry
2010-11-28X25 remove bkl from causediag ioctlsandrew hendry
2010-11-28X25 remove bkl from calluserdata ioctlsandrew hendry
2010-11-28X25 remove bkl in facility ioctlsandrew hendry
2010-11-28X25 remove bkl in subscription ioctlsandrew hendry
2010-11-19X25: remove bkl in routing ioctlsandrew hendry
Routing doesn't use the socket data and is protected by x25_route_list_lock Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-19X25: remove bkl in inq and outq ioctlsandrew hendry
2010-11-19X25: remove bkl in timestamp ioctlsandrew hendry
2010-11-19X25: pushdown bkl in ioctlsandrew hendry
Push down the bkl in the ioctls so they can be removed one at a time. Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-12x25: Prevent crashing when parsing bad X.25 facilitiesDan Rosenberg
Now with improved comma support. On parsing malformed X.25 facilities, decrementing the remaining length may cause it to underflow. Since the length is an unsigned integer, this will result in the loop continuing until the kernel crashes. This patch adds checks to ensure decrementing the remaining length does not cause it to wrap around. Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-03memory corruption in X.25 facilities parsingandrew hendry
Signed-of-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1699 commits) bnx2/bnx2x: Unsupported Ethtool operations should return -EINVAL. vlan: Calling vlan_hwaccel_do_receive() is always valid. tproxy: use the interface primary IP address as a default value for --on-ip tproxy: added IPv6 support to the socket match cxgb3: function namespace cleanup tproxy: added IPv6 support to the TPROXY target tproxy: added IPv6 socket lookup function to nf_tproxy_core be2net: Changes to use only priority codes allowed by f/w tproxy: allow non-local binds of IPv6 sockets if IP_TRANSPARENT is enabled tproxy: added tproxy sockopt interface in the IPV6 layer tproxy: added udp6_lib_lookup function tproxy: added const specifiers to udp lookup functions tproxy: split off ipv6 defragmentation to a separate module l2tp: small cleanup nf_nat: restrict ICMP translation for embedded header can: mcp251x: fix generation of error frames can: mcp251x: fix endless loop in interrupt handler if CANINTF_MERRF is set can-raw: add msg_flags to distinguish local traffic 9p: client code cleanup rds: make local functions/variables static ... Fix up conflicts in net/core/dev.c, drivers/net/pcmcia/smc91c92_cs.c and drivers/net/wireless/ath/ath9k/debug.c as per David
2010-10-21BKL: introduce CONFIG_BKL.Arnd Bergmann
With all the patches we have queued in the BKL removal tree, only a few dozen modules are left that actually rely on the BKL, and even there are lots of low-hanging fruit. We need to decide what to do about them, this patch illustrates one of the options: Every user of the BKL is marked as 'depends on BKL' in Kconfig, and the CONFIG_BKL becomes a user-visible option. If it gets disabled, no BKL using module can be built any more and the BKL code itself is compiled out. The one exception is file locking, which is practically always enabled and does a 'select BKL' instead. This effectively forces CONFIG_BKL to be enabled until we have solved the fs/lockd mess and can apply the patch that removes the BKL from fs/locks.c. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2010-09-22X.25 remove bkl in pollandrew hendry
The x25_datagram_poll didn't add anything, removed it. Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-22X.25 remove bkl in getsocknameandrew hendry
2010-09-14X.25 remove bkl in connectandrew hendry
Connect already has socket locking. Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-14X.25 remove bkl in acceptAndrew Hendry
Accept already has socket locking. [ Extend socket locking over TCP_LISTEN state test. -DaveM ] Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-14X.25 remove bkl in bindandrew hendry
Accept updates socket values in 3 lines so wrapped with lock_sock. Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-14X.25 remove bkl in listenandrew hendry
Listen updates socket values and needs lock_sock. Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17X25: Remove bkl in sockoptsandrew hendry
Removes the BKL in x25 setsock and getsockopts. Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17X25: Move accept approve flag to bitfieldandrew hendry
Moves the x25 accept approve flag from char into bitfield. Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17X25: Move interrupt flag to bitfieldandrew hendry
Moves the x25 interrupt flag from char into bitfield. Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17X25: Move qbit flag to bitfieldandrew hendry
Moves the X25 q bit flag from char into a bitfield to allow BKL cleanup. Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/e100.c drivers/net/e1000e/netdev.c
2010-04-22X25: Add if_x25.h and x25 to device identifiersAndrew Hendry
V2 Feedback from John Hughes. - Add header for userspace implementations such as xot/xoe to use - Use explicit values for interface stability - No changes to driver patches V1 - Use identifiers instead of magic numbers for X25 layer 3 to device interface. - Also fixed checkpatch notes on updated code. [ Add new user header to include/linux/Kbuild -DaveM ] Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-21X25 fix dead unaccepted socketsandrew hendry
1, An X25 program binds and listens 2, calls arrive waiting to be accepted 3, Program exits without accepting 4, Sockets time out but don't get correctly cleaned up 5, cat /proc/net/x25/socket shows the dead sockets with bad inode fields. This line borrowed from AX25 sets the dying socket so the timers clean up later. Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-20net: sk_sleep() helperEric Dumazet
Define a new function to return the waitqueue of a "struct sock". static inline wait_queue_head_t *sk_sleep(struct sock *sk) { return sk->sk_sleep; } Change all read occurrences of sk_sleep by a call to this function. Needed for a future RCU conversion. sk_sleep wont be a field directly available. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
2010-04-07x.25 attempts to negotiate invalid throughputJohn Hughes
The current X.25 code has some bugs in throughput negotiation: 1. It does negotiation in all cases, usually there is no need 2. It incorrectly attempts to negotiate the throughput class in one direction only. There are separate throughput classes for input and output and if either is negotiated both mist be negotiates. This is bug https://bugzilla.kernel.org/show_bug.cgi?id=15681 This bug was first reported by Daniel Ferenci to the linux-x25 mailing list on 6/8/2004, but is still present. The current (2.6.34) x.25 code doesn't seem to know that the X.25 throughput facility includes two values, one for the required throughput outbound, one for inbound. This causes it to attempt to negotiate throughput 0x0A, which is throughput 9600 inbound and the illegal value "0" for inbound throughput. Because of this some X.25 devices (e.g. Cisco 1600) refuse to connect to Linux X.25. The following patch fixes this behaviour. Unless the user specifies a required throughput it does not attempt to negotiate. If the user does not specify a throughput it accepts the suggestion of the remote X.25 system. If the user requests a throughput then it validates both the input and output throughputs and correctly negotiates them with the remote end. Signed-off-by: John Hughes <john@calva.com> Tested-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-07x25: Patch to fix bug 15678 - x25 accesses fields beyond end of packet.John Hughes
Here is a patch to stop X.25 examining fields beyond the end of the packet. For example, when a simple CALL ACCEPTED was received: 10 10 0f x25_parse_facilities was attempting to decode the FACILITIES field, but this packet contains no facilities field. Signed-off-by: John Hughes <john@calva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-05net: backlog functions renameZhu Yi
sk_add_backlog -> __sk_add_backlog sk_add_backlog_limited -> sk_add_backlog Signed-off-by: Zhu Yi <yi.zhu@intel.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-05x25: use limited socket backlogZhu Yi
Make x25 adapt to the limited socket backlog change. Cc: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-15X25: Dont let x25_bind use addresses containing charactersandrew hendry
Addresses should be all digits. Stops x25_bind using addresses containing characters. Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-15X25: Fix x25_create errors for bad protocol and ENOBUFSandrew hendry
alloc_socket failures should return -ENOBUFS a bad protocol should return -EINVAL Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-10net: x25: use seq_list_foo() helpersLi Zefan
Simplify seq_file code. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-10net: x25: use seq_hlist_foo() helpersLi Zefan
Simplify seq_file code. Signed-off-by: Li Zefan <lizf@cn.fujtisu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
