commit e21dba7a4df4d93da237da65a096084b4f2e87b4 upstream.
This patch fixes 2 issues in x25_connect():
1. It makes absolutely no sense to reset the neighbour and the
connection state after a (successful) nonblocking call of x25_connect.
This prevents any connection from being established, since the response
(call accept) cannot be processed.
2. Any further calls to x25_connect() while a call is pending should
simply return, instead of creating new Call Request (on different
logical channels).
This patch should also fix the "KASAN: null-ptr-deref Write in
x25_connect" and "BUG: unable to handle kernel NULL pointer dereference
in x25_connect" bugs reported by syzbot.
Signed-off-by: Martin Schiller <ms@dev.tdt.de>
Reported-by: syzbot+429c200ffc8772bfe070@syzkaller.appspotmail.com
Reported-by: syzbot+eec0c87f31a7c3b66f7b@syzkaller.appspotmail.com
[ Upstream commit 06137619f061f498c2924f6543fa45b7d39f0501 ]
o x25_find_listener(): the compare for the null_x25_address was wrong.
We have to check the x25_addr of the listener socket instead of the
x25_addr of the incomming call.
o x25_bind(): it was not possible to bind a socket to null_x25_address
[ Upstream commit d449ba3d581ed29f751a59792fdc775572c66904 ]
The length of the called and calling address was not calculated
correctly (BCD encoding).
[ Upstream commit 797a22bd5298c2674d927893f46cadf619dad11d ]
syzbot was able to trigger another soft lockup [1]
I first thought it was the O(N^2) issue I mentioned in my
prior fix (f657d22ee1f "net/x25: do not hold the cpu
too long in x25_new_lci()"), but I eventually found
that x25_bind() was not checking SOCK_ZAPPED state under
socket lock protection.
This means that multiple threads can end up calling
x25_insert_socket() for the same socket, and corrupt x25_list
[1]
watchdog: BUG: soft lockup - CPU#0 stuck for 123s! [syz-executor.2:10492]
Modules linked in:
irq event stamp: 27515
hardirqs last enabled at (27514): [<ffffffff81006673>] trace_hardirqs_on_thunk+0x1a/0x1c
hardirqs last disabled at (27515): [<ffffffff8100668f>] trace_hardirqs_off_thunk+0x1a/0x1c
softirqs last enabled at (32): [<ffffffff8632ee73>] x25_get_neigh+0xa3/0xd0 net/x25/x25_link.c:336
softirqs last disabled at (34): [<ffffffff86324bc3>] x25_find_socket+0x23/0x140 net/x25/af_x25.c:341
CPU: 0 PID: 10492 Comm: syz-executor.2 Not tainted 5.0.0-rc7+ #88
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
RIP: 0010:__sanitizer_cov_trace_pc+0x4/0x50 kernel/kcov.c:97
Code: f4 ff ff ff e8 11 9f ea ff 48 c7 05 12 fb e5 08 00 00 00 00 e9 c8 e9 ff ff 90 90 90 90 90 90 90 90 90 90 90 90 90 55 48 89 e5 <48> 8b 75 08 65 48 8b 04 25 40 ee 01 00 65 8b 15 38 0c 92 7e 81 e2
RSP: 0018:ffff88806e94fc48 EFLAGS: 00000286 ORIG_RAX: ffffffffffffff13
RAX: 1ffff1100d84dac5 RBX: 0000000000000001 RCX: ffffc90006197000
RDX: 0000000000040000 RSI: ffffffff86324bf3 RDI: ffff88806c26d628
RBP: ffff88806e94fc48 R08: ffff88806c1c6500 R09: fffffbfff1282561
R10: fffffbfff1282560 R11: ffffffff89412b03 R12: ffff88806c26d628
R13: ffff888090455200 R14: dffffc0000000000 R15: 0000000000000000
FS: 00007f3a107e4700(0000) GS:ffff8880ae800000(0000) knlGS:0000000000000000
CR2: 00007f3a107e3db8 CR3: 00000000a5544000 CR4: 00000000001406f0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Call Trace:
__x25_find_socket net/x25/af_x25.c:327 [inline]
x25_find_socket+0x7d/0x140 net/x25/af_x25.c:342
x25_new_lci net/x25/af_x25.c:355 [inline]
x25_connect+0x380/0xde0 net/x25/af_x25.c:784
__sys_connect+0x266/0x330 net/socket.c:1662
__do_sys_connect net/socket.c:1673 [inline]
__se_sys_connect net/socket.c:1670 [inline]
__x64_sys_connect+0x73/0xb0 net/socket.c:1670
do_syscall_64+0x103/0x610 arch/x86/entry/common.c:290
entry_SYSCALL_64_after_hwframe+0x49/0xbe
RIP: 0033:0x457e29
Code: ad b8 fb ff c3 66 2e 0f 1f 84 00 00 00 00 00 66 90 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 0f 83 7b b8 fb ff c3 66 2e 0f 1f 84 00 00 00 00
RSP: 002b:00007f3a107e3c78 EFLAGS: 00000246 ORIG_RAX: 000000000000002a
RAX: ffffffffffffffda RBX: 0000000000000003 RCX: 0000000000457e29
RDX: 0000000000000012 RSI: 0000000020000200 RDI: 0000000000000005
RBP: 000000000073c040 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000246 R12: 00007f3a107e46d4
R13: 00000000004be362 R14: 00000000004ceb98 R15: 00000000ffffffff
Sending NMI from CPU 0 to CPUs 1:
NMI backtrace for cpu 1
CPU: 1 PID: 10493 Comm: syz-executor.3 Not tainted 5.0.0-rc7+ #88
RIP: 0010:__read_once_size include/linux/compiler.h:193 [inline]
RIP: 0010:queued_write_lock_slowpath+0x143/0x290 kernel/locking/qrwlock.c:86
Code: 4c 8d 2c 01 41 83 c7 03 41 0f b6 45 00 41 38 c7 7c 08 84 c0 0f 85 0c 01 00 00 8b 03 3d 00 01 00 00 74 1a f3 90 41 0f b6 55 00 <41> 38 d7 7c eb 84 d2 74 e7 48 89 df e8 cc aa 4e 00 eb dd be 04 00
RSP: 0018:ffff888085c47bd8 EFLAGS: 00000206
RAX: 0000000000000300 RBX: ffffffff89412b00 RCX: 1ffffffff1282560
RDX: 0000000000000000 RSI: 0000000000000004 RDI: ffffffff89412b00
RBP: ffff888085c47c70 R08: 1ffffffff1282560 R09: fffffbfff1282561
R10: fffffbfff1282560 R11: ffffffff89412b03 R12: 00000000000000ff
R13: fffffbfff1282560 R14: 1ffff11010b88f7d R15: 0000000000000003
FS: 00007fdd04086700(0000) GS:ffff8880ae900000(0000) knlGS:0000000000000000
CR2: 00007fdd04064db8 CR3: 0000000090be0000 CR4: 00000000001406e0
Call Trace:
queued_write_lock include/asm-generic/qrwlock.h:104 [inline]
do_raw_write_lock+0x1d6/0x290 kernel/locking/spinlock_debug.c:203
__raw_write_lock_bh include/linux/rwlock_api_smp.h:204 [inline]
_raw_write_lock_bh+0x3b/0x50 kernel/locking/spinlock.c:312
x25_insert_socket+0x21/0xe0 net/x25/af_x25.c:267
x25_bind+0x273/0x340 net/x25/af_x25.c:703
__sys_bind+0x23f/0x290 net/socket.c:1481
__do_sys_bind net/socket.c:1492 [inline]
__se_sys_bind net/socket.c:1490 [inline]
__x64_sys_bind+0x73/0xb0 net/socket.c:1490
RIP: 0033:0x457e29
Fixes: 90c27297a9bf ("X.25 remove bkl in bind")
Cc: andrew hendry <andrew.hendry@gmail.com>
[ Upstream commit ee74d0bd4325efb41e38affe5955f920ed973f23 ]
In case x25_connect() fails and frees the socket neighbour,
we also need to undo the change done to x25->state.
Before my last bug fix, we had use-after-free so this
patch fixes a latent bug.
syzbot report :
kasan: CONFIG_KASAN_INLINE enabled
kasan: GPF could be caused by NULL-ptr deref or user memory access
general protection fault: 0000 [#1] PREEMPT SMP KASAN
CPU: 1 PID: 16137 Comm: syz-executor.1 Not tainted 5.0.0+ #117
RIP: 0010:x25_write_internal+0x1e8/0xdf0 net/x25/x25_subr.c:173
Code: 00 40 88 b5 e0 fe ff ff 0f 85 01 0b 00 00 48 8b 8b 80 04 00 00 48 ba 00 00 00 00 00 fc ff df 48 8d 79 1c 48 89 fe 48 c1 ee 03 <0f> b6 34 16 48 89 fa 83 e2 07 83 c2 03 40 38 f2 7c 09 40 84 f6 0f
RSP: 0018:ffff888076717a08 EFLAGS: 00010207
RAX: ffff88805f2f2292 RBX: ffff8880a0ae6000 RCX: 0000000000000000
kobject: 'loop5' (0000000018d0d0ee): kobject_uevent_env
RDX: dffffc0000000000 RSI: 0000000000000003 RDI: 000000000000001c
RBP: ffff888076717b40 R08: ffff8880950e0580 R09: ffffed100be5e46d
R10: ffffed100be5e46c R11: ffff88805f2f2363 R12: ffff888065579840
kobject: 'loop5' (0000000018d0d0ee): fill_kobj_path: path = '/devices/virtual/block/loop5'
R13: 1ffff1100ece2f47 R14: 0000000000000013 R15: 0000000000000013
FS: 00007fb88cf43700(0000) GS:ffff8880ae900000(0000) knlGS:0000000000000000
CR2: 00007f9a42a41028 CR3: 0000000087a67000 CR4: 00000000001406e0
Call Trace:
x25_release+0xd0/0x340 net/x25/af_x25.c:658
__sock_release+0xd3/0x2b0 net/socket.c:579
sock_close+0x1b/0x30 net/socket.c:1162
__fput+0x2df/0x8d0 fs/file_table.c:278
____fput+0x16/0x20 fs/file_table.c:309
task_work_run+0x14a/0x1c0 kernel/task_work.c:113
get_signal+0x1961/0x1d50 kernel/signal.c:2388
do_signal+0x87/0x1940 arch/x86/kernel/signal.c:816
exit_to_usermode_loop+0x244/0x2c0 arch/x86/entry/common.c:162
prepare_exit_to_usermode arch/x86/entry/common.c:197 [inline]
syscall_return_slowpath arch/x86/entry/common.c:268 [inline]
do_syscall_64+0x52d/0x610 arch/x86/entry/common.c:293
RIP: 0033:0x457f29
RSP: 002b:00007fb88cf42c78 EFLAGS: 00000246 ORIG_RAX: 000000000000002a
RAX: fffffffffffffe00 RBX: 0000000000000003 RCX: 0000000000457f29
RDX: 0000000000000012 RSI: 0000000020000080 RDI: 0000000000000004
RBP: 000000000073bf00 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000246 R12: 00007fb88cf436d4
R13: 00000000004be462 R14: 00000000004cec98 R15: 00000000ffffffff
Modules linked in:
Fixes: 95d6ebd53c79 ("net/x25: fix use-after-free in x25_device_event()")
Reported-by: syzbot <syzkaller@googlegroups.com>
[ Upstream commit 95d6ebd53c79522bf9502dbc7e89e0d63f94dae4 ]
In case of failure x25_connect() does a x25_neigh_put(x25->neighbour)
but forgets to clear x25->neighbour pointer, thus triggering use-after-free.
Since the socket is visible in x25_list, we need to hold x25_list_lock
to protect the operation.
syzbot report :
BUG: KASAN: use-after-free in x25_kill_by_device net/x25/af_x25.c:217 [inline]
BUG: KASAN: use-after-free in x25_device_event+0x296/0x2b0 net/x25/af_x25.c:252
Read of size 8 at addr ffff8880a030edd0 by task syz-executor003/7854
CPU: 0 PID: 7854 Comm: syz-executor003 Not tainted 5.0.0+ #97
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x172/0x1f0 lib/dump_stack.c:113
print_address_description.cold+0x7c/0x20d mm/kasan/report.c:187
kasan_report.cold+0x1b/0x40 mm/kasan/report.c:317
__asan_report_load8_noabort+0x14/0x20 mm/kasan/generic_report.c:135
notifier_call_chain+0xc7/0x240 kernel/notifier.c:93
__raw_notifier_call_chain kernel/notifier.c:394 [inline]
raw_notifier_call_chain+0x2e/0x40 kernel/notifier.c:401
call_netdevice_notifiers_info+0x3f/0x90 net/core/dev.c:1739
call_netdevice_notifiers_extack net/core/dev.c:1751 [inline]
call_netdevice_notifiers net/core/dev.c:1765 [inline]
__dev_notify_flags+0x1e9/0x2c0 net/core/dev.c:7607
dev_change_flags+0x10d/0x170 net/core/dev.c:7643
dev_ifsioc+0x2b0/0x940 net/core/dev_ioctl.c:237
dev_ioctl+0x1b8/0xc70 net/core/dev_ioctl.c:488
sock_do_ioctl+0x1bd/0x300 net/socket.c:995
sock_ioctl+0x32b/0x610 net/socket.c:1096
vfs_ioctl fs/ioctl.c:46 [inline]
file_ioctl fs/ioctl.c:509 [inline]
do_vfs_ioctl+0xd6e/0x1390 fs/ioctl.c:696
ksys_ioctl+0xab/0xd0 fs/ioctl.c:713
__do_sys_ioctl fs/ioctl.c:720 [inline]
__se_sys_ioctl fs/ioctl.c:718 [inline]
__x64_sys_ioctl+0x73/0xb0 fs/ioctl.c:718
RIP: 0033:0x4467c9
Code: e8 0c e8 ff ff 48 83 c4 18 c3 0f 1f 80 00 00 00 00 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 0f 83 5b 07 fc ff c3 66 2e 0f 1f 84 00 00 00 00
RSP: 002b:00007fdbea222d98 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
RAX: ffffffffffffffda RBX: 00000000006dbc58 RCX: 00000000004467c9
RDX: 0000000020000340 RSI: 0000000000008914 RDI: 0000000000000003
RBP: 00000000006dbc50 R08: 00007fdbea223700 R09: 0000000000000000
R10: 00007fdbea223700 R11: 0000000000000246 R12: 00000000006dbc5c
R13: 6000030030626669 R14: 0000000000000000 R15: 0000000030626669
Allocated by task 7843:
save_stack+0x45/0xd0 mm/kasan/common.c:73
set_track mm/kasan/common.c:85 [inline]
__kasan_kmalloc mm/kasan/common.c:495 [inline]
__kasan_kmalloc.constprop.0+0xcf/0xe0 mm/kasan/common.c:468
kasan_kmalloc+0x9/0x10 mm/kasan/common.c:509
kmem_cache_alloc_trace+0x151/0x760 mm/slab.c:3615
kmalloc include/linux/slab.h:545 [inline]
x25_link_device_up+0x46/0x3f0 net/x25/x25_link.c:249
x25_device_event+0x116/0x2b0 net/x25/af_x25.c:242
__dev_notify_flags+0x121/0x2c0 net/core/dev.c:7605
Freed by task 7865:
__kasan_slab_free+0x102/0x150 mm/kasan/common.c:457
kasan_slab_free+0xe/0x10 mm/kasan/common.c:465
__cache_free mm/slab.c:3494 [inline]
kfree+0xcf/0x230 mm/slab.c:3811
x25_neigh_put include/net/x25.h:253 [inline]
x25_connect+0x8d8/0xde0 net/x25/af_x25.c:824
__sys_connect+0x266/0x330 net/socket.c:1685
__do_sys_connect net/socket.c:1696 [inline]
__se_sys_connect net/socket.c:1693 [inline]
__x64_sys_connect+0x73/0xb0 net/socket.c:1693
The buggy address belongs to the object at ffff8880a030edc0
which belongs to the cache kmalloc-256 of size 256
The buggy address is located 16 bytes inside of
256-byte region [ffff8880a030edc0, ffff8880a030eec0)
The buggy address belongs to the page:
page:ffffea000280c380 count:1 mapcount:0 mapping:ffff88812c3f07c0 index:0x0
flags: 0x1fffc0000000200(slab)
raw: 01fffc0000000200 ffffea0002806788 ffffea00027f0188 ffff88812c3f07c0
raw: 0000000000000000 ffff8880a030e000 000000010000000c 0000000000000000
page dumped because: kasan: bad access detected
Reported-by: syzbot+04babcefcd396fabec37@syzkaller.appspotmail.com
commit cf657d22ee1f0e887326a92169f2e28dc932fd10 upstream.
Due to quadratic behavior of x25_new_lci(), syzbot was able
to trigger an rcu stall.
Fix this by not blocking BH for the whole duration of
the function, and inserting a reschedule point when possible.
If we care enough, using a bitmap could get rid of the quadratic
behavior.
syzbot report :
rcu: INFO: rcu_preempt self-detected stall on CPU
rcu: 0-...!: (10500 ticks this GP) idle=4fa/1/0x4000000000000002 softirq=283376/283376 fqs=0
rcu: (t=10501 jiffies g=383105 q=136)
rcu: rcu_preempt kthread starved for 10502 jiffies! g383105 f0x0 RCU_GP_WAIT_FQS(5) ->state=0x402 ->cpu=0
rcu: RCU grace-period kthread stack dump:
rcu_preempt I28928 10 2 0x80000000
Call Trace:
context_switch kernel/sched/core.c:2844 [inline]
__schedule+0x817/0x1cc0 kernel/sched/core.c:3485
schedule+0x92/0x180 kernel/sched/core.c:3529
schedule_timeout+0x4db/0xfd0 kernel/time/timer.c:1803
rcu_gp_fqs_loop kernel/rcu/tree.c:1948 [inline]
rcu_gp_kthread+0x956/0x17a0 kernel/rcu/tree.c:2105
kthread+0x357/0x430 kernel/kthread.c:246
ret_from_fork+0x3a/0x50 arch/x86/entry/entry_64.S:352
NMI backtrace for cpu 0
CPU: 0 PID: 8759 Comm: syz-executor2 Not tainted 5.0.0-rc4+ #51
Call Trace:
<IRQ>
nmi_cpu_backtrace.cold+0x63/0xa4 lib/nmi_backtrace.c:101
nmi_trigger_cpumask_backtrace+0x1be/0x236 lib/nmi_backtrace.c:62
arch_trigger_cpumask_backtrace+0x14/0x20 arch/x86/kernel/apic/hw_nmi.c:38
trigger_single_cpu_backtrace include/linux/nmi.h:164 [inline]
rcu_dump_cpu_stacks+0x183/0x1cf kernel/rcu/tree.c:1211
print_cpu_stall kernel/rcu/tree.c:1348 [inline]
check_cpu_stall kernel/rcu/tree.c:1422 [inline]
rcu_pending kernel/rcu/tree.c:3018 [inline]
rcu_check_callbacks.cold+0x500/0xa4a kernel/rcu/tree.c:2521
update_process_times+0x32/0x80 kernel/time/timer.c:1635
tick_sched_handle+0xa2/0x190 kernel/time/tick-sched.c:161
tick_sched_timer+0x47/0x130 kernel/time/tick-sched.c:1271
__run_hrtimer kernel/time/hrtimer.c:1389 [inline]
__hrtimer_run_queues+0x33e/0xde0 kernel/time/hrtimer.c:1451
hrtimer_interrupt+0x314/0x770 kernel/time/hrtimer.c:1509
local_apic_timer_interrupt arch/x86/kernel/apic/apic.c:1035 [inline]
smp_apic_timer_interrupt+0x120/0x570 arch/x86/kernel/apic/apic.c:1060
apic_timer_interrupt+0xf/0x20 arch/x86/entry/entry_64.S:807
</IRQ>
RIP: 0010:queued_write_lock_slowpath+0x13e/0x290 kernel/locking/qrwlock.c:86
Code: 00 00 fc ff df 4c 8d 2c 01 41 83 c7 03 41 0f b6 45 00 41 38 c7 7c 08 84 c0 0f 85 0c 01 00 00 8b 03 3d 00 01 00 00 74 1a f3 90 <41> 0f b6 55 00 41 38 d7 7c eb 84 d2 74 e7 48 89 df e8 6c 0f 4f 00
RSP: 0018:ffff88805f117bd8 EFLAGS: 00000206 ORIG_RAX: ffffffffffffff13
RAX: 0000000000000300 RBX: ffffffff89413ba0 RCX: 1ffffffff1282774
RDX: 0000000000000000 RSI: 0000000000000004 RDI: ffffffff89413ba0
RBP: ffff88805f117c70 R08: 1ffffffff1282774 R09: fffffbfff1282775
R10: fffffbfff1282774 R11: ffffffff89413ba3 R12: 00000000000000ff
R13: fffffbfff1282774 R14: 1ffff1100be22f7d R15: 0000000000000003
x25_bind+0x273/0x340 net/x25/af_x25.c:705
__sys_bind+0x23f/0x290 net/socket.c:1505
__do_sys_bind net/socket.c:1516 [inline]
__se_sys_bind net/socket.c:1514 [inline]
__x64_sys_bind+0x73/0xb0 net/socket.c:1514
RIP: 0033:0x457e39
RSP: 002b:00007fafccd0dc78 EFLAGS: 00000246 ORIG_RAX: 0000000000000031
RAX: ffffffffffffffda RBX: 0000000000000003 RCX: 0000000000457e39
RDX: 0000000000000012 RSI: 0000000020000240 RDI: 0000000000000004
R10: 0000000000000000 R11: 0000000000000246 R12: 00007fafccd0e6d4
R13: 00000000004bdf8b R14: 00000000004ce4b8 R15: 00000000ffffffff
CPU: 1 PID: 8752 Comm: syz-executor4 Not tainted 5.0.0-rc4+ #51
RIP: 0010:__x25_find_socket+0x78/0x120 net/x25/af_x25.c:328
Code: 89 f8 48 c1 e8 03 80 3c 18 00 0f 85 a6 00 00 00 4d 8b 64 24 68 4d 85 e4 74 7f e8 03 97 3d fb 49 83 ec 68 74 74 e8 f8 96 3d fb <49> 8d bc 24 88 04 00 00 48 89 f8 48 c1 e8 03 0f b6 04 18 84 c0 74
RSP: 0018:ffff8880639efc58 EFLAGS: 00000246
RAX: 0000000000040000 RBX: dffffc0000000000 RCX: ffffc9000e677000
RDX: 0000000000040000 RSI: ffffffff863244b8 RDI: ffff88806a764628
RBP: ffff8880639efc80 R08: ffff8880a80d05c0 R09: fffffbfff1282775
R10: fffffbfff1282774 R11: ffffffff89413ba3 R12: ffff88806a7645c0
R13: 0000000000000001 R14: ffff88809f29ac00 R15: 0000000000000000
FS: 00007fe8d0c58700(0000) GS:ffff8880ae900000(0000) knlGS:0000000000000000
CR2: 0000001b32823000 CR3: 00000000672eb000 CR4: 00000000001406e0
Call Trace:
x25_new_lci net/x25/af_x25.c:357 [inline]
x25_connect+0x374/0xdf0 net/x25/af_x25.c:786
__sys_connect+0x266/0x330 net/socket.c:1686
__do_sys_connect net/socket.c:1697 [inline]
__se_sys_connect net/socket.c:1694 [inline]
__x64_sys_connect+0x73/0xb0 net/socket.c:1694
RIP: 0033:0x457e39
RSP: 002b:00007fe8d0c57c78 EFLAGS: 00000246 ORIG_RAX: 000000000000002a
RDX: 0000000000000012 RSI: 0000000020000200 RDI: 0000000000000004
R10: 0000000000000000 R11: 0000000000000246 R12: 00007fe8d0c586d4
R13: 00000000004be378 R14: 00000000004ceb00 R15: 00000000ffffffff
Cc: Andrew Hendry <andrew.hendry@gmail.com>
Cc: linux-x25@vger.kernel.org
[ Upstream commit 64df6d525fcff1630098db9238bfd2b3e092d5c1 ]
The function x25_init is not properly unregister related resources
on error handler.It is will result in kernel oops if x25_init init
failed, so add properly unregister call on error handler.
Also, i adjust the coding style and make x25_register_sysctl properly
return failure.
Signed-off-by: linzhang <xiaolou4617@gmail.com>
[ Upstream commit 79e48650320e6fba48369fccf13fd045315b19b8 ]
Stack object "dte_facilities" is allocated in x25_rx_call_request(),
which is supposed to be initialized in x25_negotiate_facilities.
However, 5 fields (8 bytes in total) are not initialized. This
object is then copied to userland via copy_to_user, thus infoleak
occurs.
Signed-off-by: Kangjie Lu <kjlu@gatech.edu>
In preparation for changing how struct net is refcounted
on kernel sockets pass the knowledge that we are creating
a kernel socket from sock_create_kern through to sk_alloc.
After TIPC doesn't depend on iocb argument in its internal
implementations of sendmsg() and recvmsg() hooks defined in proto
structure, no any user is using iocb argument in them at all now.
Then we can drop the redundant iocb argument completely from kinds of
implementations of both sendmsg() and recvmsg() in the entire
networking stack.
Suggested-by: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: Ying Xue <ying.xue@windriver.com>
This encapsulates all of the skb_copy_datagram_iovec() callers
with call argument signature "skb, offset, msghdr->msg_iov, length".
When we move to iov_iters in the networking, the iov_iter object will
sit in the msghdr.
Having a helper like this means there will be less places to touch
during that transformation.
Based upon descriptions and patch from Al Viro.
Several spots in the kernel perform a sequence like:
skb_queue_tail(&sk->s_receive_queue, skb);
sk->sk_data_ready(sk, skb->len);
But at the moment we place the SKB onto the socket receive queue it
can be consumed and freed up. So this skb->len access is potentially
to freed up memory.
Furthermore, the skb->len can be modified by the consumer so it is
possible that the value isn't accurate.
And finally, no actual implementation of this callback actually uses
the length argument. And since nobody actually cared about it's
value, lots of call sites pass arbitrary values in such as '0' and
even '1'.
So just remove the length argument from the callback, that way there
is no confusion whatsoever and all of these use-after-free cases get
fixed as a side effect.
Based upon a patch by Eric Dumazet and his suggestion to audit this
issue tree-wide.
This is a follow-up patch to f3d3342602f8bc ("net: rework recvmsg
handler msg_name and msg_namelen logic").
DECLARE_SOCKADDR validates that the structure we use for writing the
name information to is not larger than the buffer which is reserved
for msg->msg_name (which is 128 bytes). Also use DECLARE_SOCKADDR
consistently in sendmsg code paths.
Signed-off-by: Steffen Hurrle <steffen@hurrle.net>
Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
use pr_<level> instead of printk(LEVEL)
Suggested-by: Joe Perches <joe@perches.com>
Signed-off-by: Wang Weidong <wangweidong1@huawei.com>
This patch now always passes msg->msg_namelen as 0. recvmsg handlers must
set msg_namelen to the proper size <= sizeof(struct sockaddr_storage)
to return msg_name to the user.
This prevents numerous uninitialized memory leaks we had in the
recvmsg handlers and makes it harder for new code to accidentally leak
uninitialized memory.
Optimize for the case recvfrom is called with NULL as address. We don't
need to copy the address at all, so set it to NULL before invoking the
recvmsg handler. We can do so, because all the recvmsg handlers must
cope with the case a plain read() is called on them. read() also sets
msg_name to NULL.
Also document these changes in include/linux/net.h as suggested by David
Miller.
Changes since RFC:
Set msg->msg_name = NULL if user specified a NULL in msg_name but had a
non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't
affect sendto as it would bail out earlier while trying to copy-in the
address. It also more naturally reflects the logic by the callers of
verify_iovec.
With this change in place I could remove "
if (!uaddr || msg_sys->msg_namelen == 0)
This change does not alter the user visible error logic as we ignore
msg_namelen as long as msg_name is NULL.
Also remove two unnecessary curly brackets in ___sys_recvmsg and change
comments to netdev style.
Suggested-by: Eric Dumazet <eric.dumazet@gmail.com>
Update the URLs in the Kconfig file to the new pages at sangoma.com and cisco.com
Signed-off-by: Michael Drüing <michael@drueing.de>
This was found with a manual audit and I don't have a reproducer. We
limit ->calling_len and ->called_len when we get them from
copy_from_user() in x25_ioctl() so when they come from skb->data then
we should cap them there as well.
Two of the x25 ioctl cases have error paths that break out of the function without
unlocking the socket, leading to this warning:
[ BUG: lock held when returning to user space! ]
3.10.0-rc7+ #36 Not tainted
trinity-child2/31407 is leaving the kernel with locks still held!
1 lock held by trinity-child2/31407:
#0: (sk_lock-AF_X25){+.+.+.}, at: [<ffffffffa024b6da>] x25_ioctl+0x8a/0x740 [x25]
Signed-off-by: Dave Jones <davej@redhat.com>
So far, only net_device * could be passed along with netdevice notifier
event. This patch provides a possibility to pass custom structure
able to provide info that event listener needs to know.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
v2->v3: fix typo on simeth
shortened dev_getter
shortened notifier_info struct name
v1->v2: fix notifier_call parameter in call_netdevice_notifier()
... and don't bother with ->owner, while we are at it - procfs fops
do not need it.
I'm not sure why, but the hlist for each entry iterators were conceived
list_for_each_entry(pos, head, member)
The hlist ones were greedy and wanted an extra parameter:
hlist_for_each_entry(tpos, pos, head, member)
Why did they need an extra pos parameter? I'm not quite sure. Not only
they don't really need it, it also prevents the iterator from looking
exactly like the list iterator, which is unfortunate.
Besides the semantic patch, there was some manual work required:
- Fix up the actual hlist iterators in linux/list.h
- Fix up the declaration of other iterators based on the hlist ones.
- A very small amount of places were using the 'node' parameter, this
was modified to use 'obj->member' instead.
- Coccinelle didn't handle the hlist_for_each_entry_safe iterator
properly, so those had to be fixed up manually.
The semantic patch which is mostly the work of Peter Senna Tschudin is here:
iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host;
type T;
expression a,c,d,e;
identifier b;
statement S;
-T b;
<+... when != b
hlist_for_each_entry(a,
- b,
c, d) S
hlist_for_each_entry_continue(a,
- b,
c) S
hlist_for_each_entry_from(a,
- b,
c) S
hlist_for_each_entry_rcu(a,
- b,
c, d) S
hlist_for_each_entry_rcu_bh(a,
- b,
c, d) S
hlist_for_each_entry_continue_rcu_bh(a,
- b,
c) S
for_each_busy_worker(a, c,
- b,
d) S
ax25_uid_for_each(a,
- b,
c) S
ax25_for_each(a,
- b,
c) S
inet_bind_bucket_for_each(a,
- b,
c) S
sctp_for_each_hentry(a,
- b,
c) S
sk_for_each(a,
- b,
c) S
sk_for_each_rcu(a,
- b,
c) S
sk_for_each_from
-(a, b)
+(a)
S
+ sk_for_each_from(a) S
sk_for_each_safe(a,
- b,
c, d) S
sk_for_each_bound(a,
- b,
c) S
hlist_for_each_entry_safe(a,
- b,
c, d, e) S
hlist_for_each_entry_continue_rcu(a,
- b,
c) S
nr_neigh_for_each(a,
- b,
c) S
nr_neigh_for_each_safe(a,
- b,
c, d) S
nr_node_for_each(a,
- b,
c) S
nr_node_for_each_safe(a,
- b,
c, d) S
- for_each_gfn_sp(a, c, d, b) S
+ for_each_gfn_sp(a, c, d) S
- for_each_gfn_indirect_valid_sp(a, c, d, b) S
+ for_each_gfn_indirect_valid_sp(a, c, d) S
for_each_host(a,
- b,
c) S
for_each_host_safe(a,
- b,
c, d) S
for_each_mesh_entry(a,
- b,
c, d) S
[akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c]
[akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c]
[akpm@linux-foundation.org: checkpatch fixes]
[akpm@linux-foundation.org: fix warnings]
[akpm@linux-foudnation.org: redo intrusive kvm changes]
Tested-by: Peter Senna Tschudin <peter.senna@gmail.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Gleb Natapov <gleb@redhat.com>
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a
while now and is almost always enabled by default. As agreed during the
Linux kernel summit, remove it from any "depends on" lines in Kconfigs.
CC: Andrew Hendry <andrew.hendry@gmail.com>
CC: "David S. Miller" <davem@davemloft.net>
Fix incorrect start markers, wrapped summary lines, missing section
breaks, incorrect separators, and some name mismatches.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
sk_add_backlog() & sk_rcvqueues_full() hard coded sk_rcvbuf as the
memory limit. We need to make this limit a parameter for TCP use.
No functional change expected in this patch, all callers still using the
old sk_rcvbuf limit.
Cc: Neal Cardwell <ncardwell@google.com>
Cc: Tom Herbert <therbert@google.com>
Cc: Maciej Żenczykowski <maze@google.com>
Cc: Yuchung Cheng <ycheng@google.com>
Cc: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
Cc: Rick Jones <rick.jones2@hp.com>
This results in code with less boiler plate that is a bit easier
to read.
Additionally stops us from using compatibility code in the sysctl
core, hastening the day when the compatibility code can be removed.
Acked-by: Pavel Emelyanov <xemul@parallels.com>
This makes it clearer which sysctls are relative to your current network
namespace.
This makes it a little less error prone by not exposing sysctls for the
initial network namespace in other namespaces.
This is the same way we handle all of our other network interfaces to
userspace and I can't honestly remember why we didn't do this for
sysctls right from the start.
Use of "unsigned int" is preferred to bare "unsigned" in net tree.
Use IS_ENABLED(CONFIG_FOO)
instead of defined(CONFIG_FOO) || defined (CONFIG_FOO_MODULE)
Signed-off-by: Igor Maravić <igorm@etf.rs>
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
* 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits)
Revert "tracing: Include module.h in define_trace.h"
irq: don't put module.h into irq.h for tracking irqgen modules.
bluetooth: macroize two small inlines to avoid module.h
ip_vs.h: fix implicit use of module_get/module_put from module.h
nf_conntrack.h: fix up fallout from implicit moduleparam.h presence
include: replace linux/module.h with "struct module" wherever possible
include: convert various register fcns to macros to avoid include chaining
crypto.h: remove unused crypto_tfm_alg_modname() inline
uwb.h: fix implicit use of asm/page.h for PAGE_SIZE
pm_runtime.h: explicitly requires notifier.h
linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h
miscdevice.h: fix up implicit use of lists and types
stop_machine.h: fix implicit use of smp.h for smp_processor_id
of: fix implicit use of errno.h in include/linux/of.h
of_platform.h: delete needless include <linux/module.h>
acpi: remove module.h include from platform/aclinux.h
miscdevice.h: delete unnecessary inclusion of module.h
device_cgroup.h: delete needless include <linux/module.h>
net: sch_generic remove redundant use of <linux/module.h>
net: inet_timewait_sock doesnt need <linux/module.h>
Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in
- drivers/media/dvb/frontends/dibx000_common.c
- drivers/media/video/{mt9m111.c,ov6650.c}
- drivers/mfd/ab3550-core.c
- include/linux/dmaengine.h
commit cb101ed2 in 3.0 introduced a bug in x25_recvmsg()
When passed bogus junk from userspace, x25->neighbour can be NULL,
as shown in this oops..
BUG: unable to handle kernel NULL pointer dereference at 000000000000001c
IP: [<ffffffffa05482bd>] x25_recvmsg+0x4d/0x280 [x25]
PGD 1015f3067 PUD 105072067 PMD 0
Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC
CPU 0
Pid: 27928, comm: iknowthis Not tainted 3.1.0+ #2 Gigabyte Technology Co., Ltd. GA-MA78GM-S2H/GA-MA78GM-S2H
RIP: 0010:[<ffffffffa05482bd>] [<ffffffffa05482bd>] x25_recvmsg+0x4d/0x280 [x25]
RSP: 0018:ffff88010c0b7cc8 EFLAGS: 00010282
RAX: 0000000000000000 RBX: ffff88010c0b7d78 RCX: 0000000000000c02
RDX: ffff88010c0b7d78 RSI: ffff88011c93dc00 RDI: ffff880103f667b0
RBP: ffff88010c0b7d18 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: ffff880103f667b0
R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
FS: 00007f479ce7f700(0000) GS:ffff88012a600000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 000000000000001c CR3: 000000010529e000 CR4: 00000000000006f0
Process iknowthis (pid: 27928, threadinfo ffff88010c0b6000, task ffff880103faa4f0)
Stack:
0000000000000c02 0000000000000c02 ffff88010c0b7d18 ffffff958153cb37
ffffffff8153cb60 0000000000000c02 ffff88011c93dc00 0000000000000000
0000000000000c02 ffff88010c0b7e10 ffff88010c0b7de8 ffffffff815372c2
Call Trace:
[<ffffffff8153cb60>] ? sock_update_classid+0xb0/0x180
[<ffffffff815372c2>] sock_aio_read.part.10+0x142/0x150
[<ffffffff812d6752>] ? inode_has_perm+0x62/0xa0
[<ffffffff815372fd>] sock_aio_read+0x2d/0x40
[<ffffffff811b05e2>] do_sync_read+0xd2/0x110
[<ffffffff812d3796>] ? security_file_permission+0x96/0xb0
[<ffffffff811b0a91>] ? rw_verify_area+0x61/0x100
[<ffffffff811b103d>] vfs_read+0x16d/0x180
[<ffffffff811b109d>] sys_read+0x4d/0x90
[<ffffffff81657282>] system_call_fastpath+0x16/0x1b
Code: 8b 66 20 4c 8b 32 48 89 d3 48 89 4d b8 45 89 c7 c7 45 cc 95 ff ff ff 4d 85 e4 0f 84 ed 01 00 00 49 8b 84 24 18 05 00 00 4c 89 e7
78 1c 01 45 19 ed 31 f6 e8 d5 37 ff e0 41 0f b6 44 24 0e 41
These files are non modular, but need to export symbols using
the macros now living in export.h -- call out the include so
that things won't break when we remove the implicit presence
of module.h from everywhere.
x25_find_listener does not check that the amount of call user data given
in the skb is big enough in per-socket comparisons, hence buffer
overreads may occur. Fix this by adding a check.
Signed-off-by: Matthew Daley <mattjd@gmail.com>
Cc: stable <stable@kernel.org>
Acked-by: Andrew Hendry <andrew.hendry@gmail.com>
There are multiple locations in the X.25 packet layer where a skb is
assumed to be of at least a certain size and that all its data is
currently available at skb->data. These assumptions are not checked,
hence buffer overreads may occur. Use pskb_may_pull to check these
minimal size assumptions and ensure that data is available at skb->data
when necessary, as well as use skb_copy_bits where needed.
X.25 call user data is being copied in its entirety from incoming messages
without consideration to the size of the destination buffers, leading to
possible buffer overflows. Validate incoming call user data lengths before
these copies are performed.
It appears this issue was noticed some time ago, however nothing seemed to
come of it: see http://www.spinics.net/lists/linux-x25/msg00043.html and
commit 8db09f26f912f7c90c764806e804b558da520d4f.
Tested-by: Andrew Hendry <andrew.hendry@gmail.com>
Make the case labels the same indent as the switch.
git diff -w shows 80 column line reflowing.
This replaces all instances of lock_kernel in x25
with lock_sock, taking care to release the socket
lock around sleeping functions (sock_alloc_send_skb
and skb_recv_datagram). It is not clear whether
this is a correct solution, but it seem to be what
other protocols do in the same situation.
Includes a fix suggested by Eric Dumazet.
Cc: netdev@vger.kernel.org
In x25_link_free(), we destroy 'nb' before dereferencing
'nb->dev'. Don't do this, because 'nb' might be freed
by then.
Reported-by: Randy Dunlap <randy.dunlap@oracle.com>
Tested-by: Randy Dunlap <randy.dunlap@oracle.com>
Originally x25_parse_facilities returned
-1 for an error
0 meaning 0 length facilities
>0 the length of the facilities parsed.
5ef41308f94dc ("x25: Prevent crashing when parsing bad X.25 facilities") introduced more
error checking in x25_parse_facilities however used 0 to indicate bad parsing
a6331d6f9a429 ("memory corruption in X.25 facilities parsing") followed this further for
DTE facilities, again using 0 for bad parsing.
The meaning of 0 got confused in the callers.
If the facilities are messed up we can't determine where the data starts.
So patch makes all parsing errors return -1 and ensures callers close and don't use the skb further.
Reported-by: Andy Whitcroft <apw@canonical.com>
Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com>
drivers/net/wireless/ath/ath9k/ar9003_eeprom.c
net/llc/af_llc.c
x25 does not decrement the network device reference counts on module unload.
Thus unregistering any pre-existing interface after unloading the x25 module
hangs and results in
unregister_netdevice: waiting for tap0 to become free. Usage count = 1
This patch decrements the reference counts of all interfaces in x25_link_free,
the way it is already done in x25_link_device_down for NETDEV_DOWN events.
Signed-off-by: Apollon Oikonomopoulos <apollon@noc.grnet.gr>
Routing doesn't use the socket data and is protected by x25_route_list_lock
