path: root/net/xfrm/xfrm_algo.c
2011-07-28xfrm: Fix key lengths for rfc3686(ctr(aes))Tushar Gohad
Fix the min and max bit lengths for AES-CTR (RFC3686) keys. The number of bits in key spec is the key length (128/256) plus 32 bits of nonce. This change takes care of the "Invalid key length" errors reported by setkey when specifying 288 bit keys for aes-ctr. Signed-off-by: Tushar Gohad <tgohad@mvista.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-27xfrm: Pass name as const to xfrm_*_get_byname().David S. Miller
2010-01-17crypto: gcm - Add RFC4543 wrapper for GCMTobias Brunner
This patch adds the RFC4543 (GMAC) wrapper for GCM similar to the existing RFC4106 wrapper. The main differences between GCM and GMAC are the contents of the AAD and that the plaintext is empty for the latter. Signed-off-by: Tobias Brunner <tobias@strongswan.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-12-01Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/mac80211/ht.c
2009-12-01ipsec: can not add camellia cipher algorithm when using "ip xfrm state" commandLi Yewang
can not add camellia cipher algorithm when using "ip xfrm state" command. Signed-off-by: Li Yewang <lyw@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-25xfrm: Add SHA384 and SHA512 HMAC authentication algorithms to XFRMMartin Willi
These algorithms use a truncation of 192/256 bits, as specified in RFC4868. Signed-off-by: Martin Willi <martin@strongswan.org> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-18xfrm: remove skb_icv_walkSteffen Klassert
The last users of skb_icv_walk are converted to ahash now, so skb_icv_walk is unused and can be removed. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-24ipsec: Fix name of CAST algorithmHerbert Xu
Our CAST algorithm is called cast5, not cast128. Clearly nobody has ever used it :) Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-09xfrm: Use frag list abstraction interfaces.David S. Miller
2008-07-25net: convert BUG_TRAP to generic WARN_ONIlpo Järvinen
Removes legacy reinvent-the-wheel type thing. The generic machinery integrates much better to automated debugging aids such as kerneloops.org (and others), and is unambiguous due to better naming. Non-intuively BUG_TRAP() is actually equal to WARN_ON() rather than BUG_ON() though some might actually be promoted to BUG_ON() but I left that to future. I could make at least one BUILD_BUG_ON conversion. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-04xfrm: xfrm_algo: correct usage of RIPEMD-160Adrian-Ken Rueegsegger
This patch fixes the usage of RIPEMD-160 in xfrm_algo which in turn allows hmac(rmd160) to be used as authentication mechanism in IPsec ESP and AH (see RFC 2857). Signed-off-by: Adrian-Ken Rueegsegger <rueegsegger@swiss-it.ch> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-27[IPSEC]: Use digest_null directly for authHerbert Xu
Previously digest_null had no setkey function which meant that we used hmac(digest_null) for IPsec since IPsec always calls setkey. Now that digest_null has a setkey we no longer need to do that. In fact when only confidentiality is specified for ESP we already use digest_null directly. However, when the null algorithm is explicitly specified by the user we still opt for hmac(digest_null). This patch removes this discrepancy. I have not added a new compat name for it because by chance it wasn't actualy possible for the user to specify the name hmac(digest_null) due to a key length check in xfrm_user (which I found out when testing that compat name :) Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-07[IPSEC]: Add support for aes-ctr.Joy Latten
The below patch allows IPsec to use CTR mode with AES encryption algorithm. Tested this using setkey in ipsec-tools. Signed-off-by: Joy Latten <latten@austin.ibm.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[IPSEC]: Add support for combined mode algorithmsHerbert Xu
This patch adds support for combined mode algorithms with GCM being the first algorithm supported. Combined mode algorithms can be added through the xfrm_user interface using the new algorithm payload type XFRMA_ALG_AEAD. Each algorithms is identified by its name and the ICV length. For the purposes of matching algorithms in xfrm_tmpl structures, combined mode algorithms occupy the same name space as encryption algorithms. This is in line with how they are negotiated using IKE. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[IPSEC]: Allow async algorithmsHerbert Xu
Now that ESP uses authenc we can turn on the support for async algorithms in IPsec. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[XFRM]: Remove ifdef crypto.Sebastian Siewior
and select the crypto subsystem if neccessary Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-02cleanup asm/scatterlist.h includesAdrian Bunk
Not architecture specific code should not #include <asm/scatterlist.h>. This patch therefore either replaces them with #include <linux/scatterlist.h> or simply removes them if they were unused. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-26[IPSEC]: Fix scatterlist handling in skb_icv_walk().David S. Miller
Use sg_init_one() and sg_init_table() as needed. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-24SG: Change sg_set_page() to take length and offset argumentJens Axboe
Most drivers need to set length and offset as well, so may as well fold those three lines into one. Add sg_assign_page() for those two locations that only needed to set the page, where the offset/length is set outside of the function context. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-23net: fix xfrm build - missing scatterlist.h includeHeiko Carstens
net/xfrm/xfrm_algo.c: In function 'skb_icv_walk': net/xfrm/xfrm_algo.c:555: error: implicit declaration of function 'sg_set_page' make[2]: *** [net/xfrm/xfrm_algo.o] Error 1 Cc: David Miller <davem@davemloft.net> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-22Update net/ to use sg helpersJens Axboe
2007-05-22[IPSEC]: Fix warnings with casting int to pointerHerbert Xu
This patch adds some casts to shut up the warnings introduced by my last patch that added a common interator function for xfrm algorightms. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-19[IPSEC] pfkey: Load specific algorithm in pfkey_add rather than allHerbert Xu
This is a natural extension of the changeset [XFRM]: Probe selected algorithm only. which only removed the probe call for xfrm_user. This patch does exactly the same thing for af_key. In other words, we load the algorithm requested by the user rather than everything when adding xfrm states in af_key. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-27[NET]: Revert sk_buff walker cleanups.David S. Miller
This reverts eefa3906283a2b60a6d02a2cda593a7d7d7946c5 The simplification made in that change works with the assumption that the 'offset' parameter to these functions is always positive or zero, which is not true. It can be and often is negative in order to access SKB header values in front of skb->data. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[NET]: Clean up sk_buff walkers.Jean Delvare
I noticed recently that, in skb_checksum(), "offset" and "start" are essentially the same thing and have the same value throughout the function, despite being computed differently. Using a single variable allows some cleanups and makes the skb_checksum() function smaller, more readable, and presumably marginally faster. We appear to have many other "sk_buff walker" functions built on the exact same model, so the cleanup applies to them, too. Here is a list of the functions I found to be affected: net/appletalk/ddp.c:atalk_sum_skb() net/core/datagram.c:skb_copy_datagram_iovec() net/core/datagram.c:skb_copy_and_csum_datagram() net/core/skbuff.c:skb_copy_bits() net/core/skbuff.c:skb_store_bits() net/core/skbuff.c:skb_checksum() net/core/skbuff.c:skb_copy_and_csum_bit() net/core/user_dma.c:dma_skb_copy_datagram_iovec() net/xfrm/xfrm_algo.c:skb_icv_walk() net/xfrm/xfrm_algo.c:skb_to_sgvec() OTOH, I admit I'm a bit surprised, the cleanup is rather obvious so I'm really wondering if I am missing something. Can anyone please comment on this? Signed-off-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET]: Move generic skbuff stuff from XFRM code to generic codeDavid Howells
Move generic skbuff stuff from XFRM code to generic code so that AF_RXRPC can use it too. The kdoc comments I've attached to the functions needs to be checked by whoever wrote them as I had to make some guesses about the workings of these functions. Signed-off-By: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] XFRM: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-07[IPSEC]: added the entry of Camellia cipher algorithm to ealg_list[]Noriaki TAKAMIYA
This patch adds the entry of Camellia cipher algorithm to ealg_list[]. Signed-off-by: Noriaki TAKAMIYA <takamiya@po.ntts.co.jp> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-12-31[XFRM]: Algorithm lookup using .compat nameMartin Willi
Installing an IPsec SA using old algorithm names (.compat) does not work if the algorithm is not already loaded. When not using the PF_KEY interface, algorithms are not preloaded in xfrm_probe_algs() and installing a IPsec SA fails. Signed-off-by: Martin Willi <martin@strongswan.org> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-06[IPSEC]: Add support for AES-XCBC-MACKazunori MIYAZAWA
The glue of xfrm. Signed-off-by: Kazunori MIYAZAWA <miyazawa@linux-ipv6.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-09-21[CRYPTO] users: Use crypto_comp and crypto_has_*Herbert Xu
This patch converts all users to use the new crypto_comp type and the crypto_has_* functions. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-09-21[IPSEC]: Use HMAC template and hash interfaceHerbert Xu
This patch converts IPsec to use the new HMAC template. The names of existing simple digest algorithms may still be used to refer to their HMAC composites. The same structure can be used by other MACs such as AES-XCBC-MAC. This patch also switches from the digest interface to hash. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-21[IPSEC] ESP: Use block ciphers where applicableHerbert Xu
This patch converts IPSec/ESP to use the new block cipher type where applicable. Similar to the HMAC conversion, existing algorithm names have been kept for compatibility. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-09-21[IPSEC]: Add compatibility algorithm name supportHerbert Xu
This patch adds a compatibility name field for each IPsec algorithm. This is needed when parameterised algorithms are used. For example, "md5" will become "hmac(md5)", and "aes" will become "cbc(aes)". Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-01-09[NET]: Change some "if (x) BUG();" to "BUG_ON(x);"Kris Katterjohn
This changes some simple "if (x) BUG();" statements to "BUG_ON(x);" Signed-off-by: Kris Katterjohn <kjak@users.sourceforge.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-18[XFRM]: skb_cow_data() does not set proper owner for new skbs.Evgeniy Polyakov
It looks like skb_cow_data() does not set proper owner for newly created skb. If we have several fragments for skb and some of them are shared(?) or cloned (like in async IPsec) there might be a situation when we require recreating skb and thus using skb_copy() for it. Newly created skb has neither a destructor nor a socket assotiated with it, which must be copied from the old skb. As far as I can see, current code sets destructor and socket for the first one skb only and uses truesize of the first skb only to increment sk_wmem_alloc value. If above "analysis" is correct then attached patch fixes that. Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
