path: root/net
2006-09-08PKTGEN: Fix oops when used with balance-tlb bondingChen-Li Tien
Signed-off-by: Chen-Li Tien <cltien@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-08PKTGEN: Make sure skb->{nh,h} are initialized in fill_packet_ipv6() too.David S. Miller
[PKTGEN]: Make sure skb->{nh,h} are initialized in fill_packet_ipv6() too. Mirror the bug fix from fill_packet_ipv4() Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-08IPV6 OOPS'er triggerable by any userYOSHIFUJI Hideaki
[IPV6]: Fix kernel OOPs when setting sticky socket options. Bug noticed by Remi Denis-Courmont <rdenis@simphalempin.com>. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-08SCTP: Fix sctp_primitive_ABORT() call in sctp_close().Sridhar Samudrala
With the recent fix, the callers of sctp_primitive_ABORT() need to create an ABORT chunk and pass it as an argument rather than msghdr that was passed earlier. Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-08Allow per-route window scale limitingStephen Hemminger
There are black box devices out there, routers and firewalls and whatnot, that simply cannot grok the TCP window scaling option correctly. People should and do bark at the site running the device causing the problems, but in the mean time folks do want a way to deal with the problem. We don't want them to turn off window scaling completely as that hurts performance of connections that would run just fine with window scaling enabled. So give a way to do this on a per-route basis by limiting the window scaling by the per-connection window clamp. Stephen's changelog message explains how to do this using a route metric. [TCP]: Limit window scaling if window is clamped. This small change allows for easy per-route workarounds for broken hosts or middleboxes that are not compliant with TCP standards for window scaling. Rather than having to turn off window scaling globally. This patch allows reducing or disabling window scaling if window clamp is present. Example: Mark Lord reported a problem with 2.6.17 kernel being unable to access http://www.everymac.com # ip route add 216.145.246.23/32 via 10.8.0.1 window 65535 Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-08bridge-netfilter: don't overwrite memory outside of skbStephen Hemminger
The bridge netfilter code needs to check for space at the front of the skb before overwriting; otherwise if skb from device doesn't have headroom, then it will cause random memory corruption. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-08Fix output framentation of paged-skbsHerbert Xu
[INET]: Use pskb_trim_unique when trimming paged unique skbs The IPv4/IPv6 datagram output path was using skb_trim to trim paged packets because they know that the packet has not been cloned yet (since the packet hasn't been given to anything else in the system). This broke because skb_trim no longer allows paged packets to be trimmed. Paged packets must be given to one of the pskb_trim functions instead. This patch adds a new pskb_trim_unique function to cover the IPv4/IPv6 datagram output path scenario and replaces the corresponding skb_trim calls with it. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-08-23Fix ipv4 routing locking bugAlexey Kuznetsov
[IPV4]: severe locking bug in fib_semantics.c Found in 2.4 by Yixin Pan <yxpan@hotmail.com>. > When I read fib_semantics.c of Linux-2.4.32, write_lock(&fib_info_lock) = > is used in fib_release_info() instead of write_lock_bh(&fib_info_lock). = > Is the following case possible: a BH interrupts fib_release_info() while = > holding the write lock, and calls ip_check_fib_default() which calls = > read_lock(&fib_info_lock), and spin forever. Signed-off-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-08-23ip_tables: fix table locking in ipt_do_tablePatrick McHardy
[NETFILTER]: ip_tables: fix table locking in ipt_do_table table->private might change because of ruleset changes, don't use it without holding the lock. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-08-23ulog: fix panic on SMP kernelsMark Huang
[NETFILTER]: ulog: fix panic on SMP kernels Fix kernel panic on various SMP machines. The culprit is a null ub->skb in ulog_send(). If ulog_timer() has already been scheduled on one CPU and is spinning on the lock, and ipt_ulog_packet() flushes the queue on another CPU by calling ulog_send() right before it exits, there will be no skbuff when ulog_timer() acquires the lock and calls ulog_send(). Cancelling the timer in ulog_send() doesn't help because it has already been scheduled and is running on the first CPU. Similar problem exists in ebt_ulog.c and nfnetlink_log.c. Signed-off-by: Mark Huang <mlhuang@cs.princeton.edu> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-08-23ipx: header length validation neededStephen Hemminger
This patch will linearize and check there is enough data. It handles the pprop case as well as avoiding a whole audit of the routing code. Signed-off-by: Stephen Hemminger <shemminger@osdl.org>
2006-08-23Fix IFLA_ADDRESS handlingDavid Miller
[RTNETLINK]: Fix IFLA_ADDRESS handling. The ->set_mac_address handlers expect a pointer to a sockaddr which contains the MAC address, whereas IFLA_ADDRESS provides just the MAC address itself. So whip up a sockaddr to wrap around the netlink attribute for the ->set_mac_address call. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-08-23Fix timer race in dst GC codeDmitry Mishin
[NET]: add_timer -> mod_timer() in dst_run_gc() Patch from Dmitry Mishin <dim@openvz.org>: Replace add_timer() by mod_timer() in dst_run_gc in order to avoid BUG message. CPU1 CPU2 dst_run_gc() entered dst_run_gc() entered spin_lock(&dst_lock) ..... del_timer(&dst_gc_timer) fail to get lock .... mod_timer() <--- puts timer back to the list add_timer(&dst_gc_timer) <--- BUG because timer is in list already. Found during OpenVZ internal testing. At first we thought that it is OpenVZ specific as we added dst_run_gc(0) call in dst_dev_event(), but as Alexey pointed to me it is possible to trigger this condition in mainstream kernel. F.e. timer has fired on CPU2, but the handler was preeempted by an irq before dst_lock is tried. Meanwhile, someone on CPU1 adds an entry to gc list and starts the timer. If CPU2 was preempted long enough, this timer can expire simultaneously with resuming timer handler on CPU1, arriving exactly to the situation described. Signed-off-by: Dmitry Mishin <dim@openvz.org> Signed-off-by: Kirill Korotaev <dev@openvz.org> Signed-off-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-08-23Kill HASH_HIGHMEM from route cache hash sizingKirill Korotaev
[IPV4]: Limit rt cache size properly. During OpenVZ stress testing we found that UDP traffic with random src can generate too much excessive rt hash growing leading finally to OOM and kernel panics. It was found that for 4GB i686 system (having 1048576 total pages and 225280 normal zone pages) kernel allocates the following route hash: syslog: IP route cache hash table entries: 262144 (order: 8, 1048576 bytes) => ip_rt_max_size = 4194304 entries, i.e. max rt size is 4194304 * 256b = 1Gb of RAM > normal_zone Attached the patch which removes HASH_HIGHMEM flag from alloc_large_system_hash() call. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-08-22Fix sctp privilege elevation (CVE-2006-3745)Sridhar Samudrala
sctp_make_abort_user() now takes the msg_len along with the msg so that we don't have to recalculate the bytes in iovec. It also uses memcpy_fromiovec() so that we don't go beyond the length allocated. It is good to have this fix even if verify_iovec() is fixed to return error on overflow. Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-08-06Fix race related problem when adding items to and svcrpc auth cache.Neil Brown
Fix race related problem when adding items to and svcrpc auth cache. If we don't find the item we are lookng for, we allocate a new one, and then grab the lock again and search to see if it has been added while we did the alloc. If it had been added we need to 'cache_put' the newly created item that we are never going to use. But as it hasn't been initialised properly, putting it can cause an oops. So move the ->init call earlier to that it will always be fully initilised if we have to put it. Thanks to Philipp Matthias Hahn <pmhahn@svs.Informatik.Uni-Oldenburg.de> for reporting the problem. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-08-06VLAN state handling fixStefan Rompf
[VLAN]: Fix link state propagation When the queue of the underlying device is stopped at initialization time or the device is marked "not present", the state will be propagated to the vlan device and never change. Based on an analysis by Patrick McHardy. Signed-off-by: Stefan Rompf <stefan@loplof.de> ACKed-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-08-06Update frag_list in pskb_trimHerbert Xu
[NET]: Update frag_list in pskb_trim When pskb_trim has to defer to ___pksb_trim to trim the frag_list part of the packet, the frag_list is not updated to reflect the trimming. This will usually work fine until you hit something that uses the packet length or tail from the frag_list. Examples include esp_output and ip_fragment. Another problem caused by this is that you can end up with a linear packet with a frag_list attached. It is possible to get away with this if we audit everything to make sure that they always consult skb->len before going down onto frag_list. In fact we can do the samething for the paged part as well to avoid copying the data area of the skb. For now though, let's do the conservative fix and update frag_list. Many thanks to Marco Berizzi for helping me to track down this bug. This 4-year old bug took 3 months to track down. Marco was very patient indeed :) Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-08-06H.323 helper: fix possible NULL-ptr dereferencePatrick McHardy
[NETFILTER]: H.323 helper: fix possible NULL-ptr dereference An RCF message containing a timeout results in a NULL-ptr dereference if no RRQ has been seen before. Noticed by the "SATURN tool", reported by Thomas Dillig <tdillig@stanford.edu> and Isil Dillig <isil@stanford.edu>. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-07-24ieee80211: TKIP requires CRC32Chuck Ebbert
ieee80211_crypt_tkip will not work without CRC32. LD .tmp_vmlinux1 net/built-in.o: In function `ieee80211_tkip_encrypt': net/ieee80211/ieee80211_crypt_tkip.c:349: undefined reference to `crc32_le' Reported by Toralf Foerster <toralf.foerster@gmx.de> Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-07-24Fix IPv4/DECnet routing rule dumpingPatrick McHardy
When more rules are present than fit in a single skb, the remaining rules are incorrectly skipped. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-07-24Add missing UFO initialisationsHerbert Xu
This bug was unknowingly fixed the GSO patches (or rather, its effect was unknown at the time). Thanks to Marco Berizzi's persistence which is documented in the thread "ipsec tunnel asymmetrical mtu", we now know that it can have highly non-obvious symptoms. What happens is that uninitialised uso_size fields can cause packets to be incorrectly identified as UFO, which means that it does not get fragmented even if it's over the MTU. The fix is simple enough. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-07-24PKT_SCHED: Fix error handling while dumping actionsThomas Graf
"return -err" and blindly inheriting the error code in the netlink failure exception handler causes errors codes to be returned as positive value therefore making them being ignored by the caller. May lead to sending out incomplete netlink messages. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-07-24PKT_SCHED: Return ENOENT if action module is unavailableThomas Graf
Return ENOENT if action module is unavailable Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-07-24PKT_SCHED: Fix illegal memory dereferences when dumping actionsThomas Graf
The TCA_ACT_KIND attribute is used without checking its availability when dumping actions therefore leading to a value of 0x4 being dereferenced. The use of strcmp() in tc_lookup_action_n() isn't safe when fed with string from an attribute without enforcing proper NUL termination. Both bugs can be triggered with malformed netlink message and don't require any privileges. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-07-24ethtool: oops in ethtool_set_pauseparam()Willy Tarreau
The function pointers which were checked were for their get_* counterparts. Typically a copy-paste typo. Signed-off-by: Willy Tarreau <w@1wt.eu> Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-30[PATCH] NETFILTER: SCTP conntrack: fix crash triggered by packet without ↵Patrick McHardy
chunks [CVE-2006-2934] When a packet without any chunks is received, the newconntrack variable in sctp_packet contains an out of bounds value that is used to look up an pointer from the array of timeouts, which is then dereferenced, resulting in a crash. Make sure at least a single chunk is present. Problem noticed by George A. Theall <theall@tenablesecurity.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-29[PATCH] IPV6 ADDRCONF: Fix default source address selection without ↵YOSHIFUJI Hideaki
CONFIG_IPV6_PRIVACY We need to update hiscore.rule even if we don't enable CONFIG_IPV6_PRIVACY, because we have more less significant rule; longest match. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-29[PATCH] IPV6: Fix source address selection.Łukasz Stelmach
Two additional labels (RFC 3484, sec. 10.3) for IPv6 addreses are defined to make a distinction between global unicast addresses and Unique Local Addresses (fc00::/7, RFC 4193) and Teredo (2001::/32, RFC 4380). It is necessary to avoid attempts of connection that would either fail (eg. fec0:: to 2001:feed::) or be sub-optimal (2001:0:: to 2001:feed::). Signed-off-by: Łukasz Stelmach <stlman@poczta.fm> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-29[PATCH] ETHTOOL: Fix UFO typoHerbert Xu
The function ethtool_get_ufo was referring to ETHTOOL_GTSO instead of ETHTOOL_GUFO. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-29[PATCH] SCTP: Fix persistent slowdown in sctp when a gap ack consumes rx buffer.Neil Horman
In the event that our entire receive buffer is full with a series of chunks that represent a single gap-ack, and then we accept a chunk (or chunks) that fill in the gap between the ctsn and the first gap, we renege chunks from the end of the buffer, which effectively does nothing but move our gap to the end of our received tsn stream. This does little but move our missing tsns down stream a little, and, if the sender is sending sufficiently large retransmit frames, the result is a perpetual slowdown which can never be recovered from, since the only chunk that can be accepted to allow progress in the tsn stream necessitates that a new gap be created to make room for it. This leads to a constant need for retransmits, and subsequent receiver stalls. The fix I've come up with is to deliver the frame without reneging if we have a full receive buffer and the receiving sockets sk_receive_queue is empty(indicating that the receive buffer is being blocked by a missing tsn). Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-29[PATCH] SCTP: Send only 1 window update SACK per message.Tsutomu Fujii
Right now, every time we increase our rwnd by more then MTU bytes, we trigger a SACK. When processing large messages, this will generate a SACK for almost every other SCTP fragment. However since we are freeing the entire message at the same time, we might as well collapse the SACK generation to 1. Signed-off-by: Tsutomu Fujii <t-fujii@nb.jp.nec.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-29[PATCH] SCTP: Reset rtt_in_progress for the chunk when processing its sack.David Miller
2006-06-29[PATCH] SCTP: Reject sctp packets with broadcast addresses.Vlad Yasevich
Make SCTP handle broadcast properly Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-29[PATCH] SCTP: Limit association max_retrans setting in setsockopt.Vlad Yasevich
When using ASSOCINFO socket option, we need to limit the number of maximum association retransmissions to be no greater than the sum of all the path retransmissions. This is specified in Section 7.1.2 of the SCTP socket API draft. However, we only do this if the association has multiple paths. If there is only one path, the protocol stack will use the assoc_max_retrans setting when trying to retransmit packets. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-29[PATCH] IPV6: Sum real space for RTAs.YOSHIFUJI Hideaki
This patch fixes RTNLGRP_IPV6_IFINFO netlink notifications. Issue pointed out by Patrick McHardy <kaber@trash.net>. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-20[PATCH] xt_sctp: fix endless loop caused by 0 chunk length (CVE-2006-3085)Patrick McHardy
Fix endless loop in the SCTP match similar to those already fixed in the SCTP conntrack helper (was CVE-2006-1527). Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-12[IPV4]: Increment ipInHdrErrors when TTL expires.Weidong
Signed-off-by: Weidong <weid@nanjing-fnst.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-11[TCP]: continued: reno sacked_out count fixAki M Nyrhinen
From: Aki M Nyrhinen <anyrhine@cs.helsinki.fi> IMHO the current fix to the problem (in_flight underflow in reno) is incorrect. it treats the symptons but ignores the problem. the problem is timing out packets other than the head packet when we don't have sack. i try to explain (sorry if explaining the obvious). with sack, scanning the retransmit queue for timed out packets is fine because we know which packets in our retransmit queue have been acked by the receiver. without sack, we know only how many packets in our retransmit queue the receiver has acknowledged, but no idea which packets. think of a "typical" slow-start overshoot case, where for example every third packet in a window get lost because a router buffer gets full. with sack, we check for timeouts on those every third packet (as the rest have been sacked). the packet counting works out and if there is no reordering, we'll retransmit exactly the packets that were lost. without sack, however, we check for timeout on every packet and end up retransmitting consecutive packets in the retransmit queue. in our slow-start example, 2/3 of those retransmissions are unnecessary. these unnecessary retransmissions eat the congestion window and evetually prevent fast recovery from continuing, if enough packets were lost. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-11[DCCP] Ackvec: fix soft lockup in ackvec handling codeAndrea Bittau
A soft lockup existed in the handling of ack vector records. Specifically, when a tail of the list of ack vector records was removed, it was possible to end up iterating infinitely on an element of the tail. Signed-off-by: Andrea Bittau <a.bittau@cs.ucl.ac.uk> Signed-off-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-05[BRIDGE]: fix locking and memory leak in br_add_bridgeJiri Benc
There are several bugs in error handling in br_add_bridge: - when dev_alloc_name fails, allocated net_device is not freed - unregister_netdev is called when rtnl lock is held - free_netdev is called before netdev_run_todo has a chance to be run after unregistering net_device Signed-off-by: Jiri Benc <jbenc@suse.cz> Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-05[IRDA]: Missing allocation result check in irlap_change_speed().Florin Malita
The skb allocation may fail, which can result in a NULL pointer dereference in irlap_queue_xmit(). Coverity CID: 434. Signed-off-by: Florin Malita <fmalita@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-05[NET]: Eliminate unused /proc/sys/net/ethernetJes Sorensen
The /proc/sys/net/ethernet directory has been sitting empty for more than 10 years! Time to eliminate it! Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-05[TCP]: Avoid skb_pull if possible when trimming headHerbert Xu ~{PmVHI~}
Trimming the head of an skb by calling skb_pull can cause the packet to become unaligned if the length pulled is odd. Since the length is entirely arbitrary for a FIN packet carrying data, this is actually quite common. Unaligned data is not the end of the world, but we should avoid it if it's easily done. In this case it is trivial. Since we're discarding all of the head data it doesn't matter whether we move skb->data forward or back. However, it is still possible to have unaligned skb->data in general. So network drivers should be prepared to handle it instead of crashing. This patch also adds an unlikely marking on len < headlen since partial ACKs on head data are extremely rare in the wild. As the return value of __pskb_trim_head is no longer ever NULL that has been removed. Signed-off-by: Herbert Xu ~{PmV>HI~} <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-02[TCP] tcp_highspeed: Fix problem observed by Xiaoliang (David) WeiStephen Hemminger
When snd_cwnd is smaller than 38 and the connection is in congestion avoidance phase (snd_cwnd > snd_ssthresh), the snd_cwnd seems to stop growing. The additive increase was confused because C array's are 0 based. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-28[NETFILTER]: PPTP helper: fix sstate/cstate typoAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-28[NETFILTER]: mark H.323 helper experimentalPatrick McHardy
2006-05-28[NETFILTER]: Fix small information leak in SO_ORIGINAL_DST (CVE-2006-1343)Marcel Holtmann
It appears that sockaddr_in.sin_zero is not zeroed during getsockopt(...SO_ORIGINAL_DST...) operation. This can lead to an information leak (CVE-2006-1343). Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-26[NET]: dev.c comment fixesStephen Hemminger
Noticed that dev_alloc_name() comment was incorrect, and more spellung errors. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-26[IPV6] ROUTE: Don't try less preferred routes for on-link routes.YOSHIFUJI Hideaki
In addition to the real on-link routes, NONEXTHOP routes should be considered on-link. Problem reported by Meelis Roos <mroos@linux.ee>. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Acked-by: Meelis Roos <mroos@linux.ee> Signed-off-by: David S. Miller <davem@davemloft.net>
