[ Upstream commit 3e38df136e453aa69eb4472108ebce2fb00b1ba6 ]
BUG: KASAN: slab-out-of-bounds in nf_tables_rule_destroy+0xf1/0x130 at addr ffff88006a4c35c8
Read of size 8 by task nft/1607
When we've destroyed last valid expr, nft_expr_next() returns an invalid expr.
We must not dereference it unless it passes != nft_expr_last() check.
[ Upstream commit c2e756ff9e699865d294cdc112acfc36419cf5cc ]
Using smp_processor_id() causes splats with PREEMPT_RCU:
[19379.552780] BUG: using smp_processor_id() in preemptible [00000000] code: ping/32389
[19379.552793] caller is debug_smp_processor_id+0x17/0x19
[19379.552823] Call Trace:
[19379.552832] [<ffffffff81274e9e>] dump_stack+0x67/0x90
[19379.552837] [<ffffffff8129a4d4>] check_preemption_disabled+0xe5/0xf5
[19379.552842] [<ffffffff8129a4fb>] debug_smp_processor_id+0x17/0x19
[19379.552849] [<ffffffffa07c42dd>] nft_queue_eval+0x35/0x20c [nft_queue]
No need to disable preemption since we only fetch the numeric value, so
let's use raw_smp_processor_id() instead.
[ Upstream commit 11197d006bcfabf0173a7820a163fcaac420d10e ]
Previously, kernel sends NEW_PEER_CANDIDATE event to user land even if
the found peer does not have any room to accept other peer. This causes
continuous connection trials.
Signed-off-by: Masashi Honma <masashi.honma@gmail.com>
[ Upstream commit 76f43b4c0a9337af22827d78de4f2b8fd5328489 ]
mesh_sync_offset_adjust_tbtt() implements Extensible synchronization
framework ([1] 13.13.2 Extensible synchronization framework). It shall
not operate the flag "TBTT Adjusting subfield" ([1] 8.4.2.100.8 Mesh
Capability), since it is used only for MBCA ([1] 13.13.4 Mesh beacon
collision avoidance, see 13.13.4.4.3 TBTT scanning and adjustment
procedures for detail). So this patch remove the flag operations.
[1] IEEE Std 802.11 2012
[remove adjusting_tbtt entirely, since it's now unused]
[ Upstream commit 7bb387c5ab12aeac3d5eea28686489ff46b53ca9 ]
IP_MULTICAST_IF fails if sk_bound_dev_if is already set and the new index
does not match it. e.g.,
ntpd[15381]: setsockopt IP_MULTICAST_IF 192.168.1.23 fails: Invalid argument
Relax the check in setsockopt to allow setting mc_index to an L3 slave if
sk_bound_dev_if points to an L3 master.
Make a similar change for IPv6. In this case change the device lookup to
take the rcu_read_lock avoiding a refcnt. The rcu lock is also needed for
the lookup of a potential L3 master device.
This really only silences a setsockopt failure since uses of mc_index are
secondary to sk_bound_dev_if if it is set. In both cases, if either index
is an L3 slave or master, lookups are directed to the same FIB table so
relaxing the check at setsockopt time causes no harm.
Patch is based on a suggested change by Darwin for a problem noted in
their code base.
Suggested-by: Darwin Dingel <darwin.dingel@alliedtelesis.co.nz>
Signed-off-by: David Ahern <dsa@cumulusnetworks.com>
[ Upstream commit 3e56c2f856d7aba6a03feea834d68f9c05f7d0b6 ]
Fixes warning: Using plain integer as NULL pointer
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@oracle.com>
[ Upstream commit 584a8279a44a800dea5a5c1e9d53a002e03016b4 ]
The first message to a remote node should prompt a new
connection even if it is RDMA operation. For RDMA operation
the MR mapping can fail because connections is not yet up.
Since the connection establishment is asynchronous,
we make sure the map failure because of unavailable
connection reach to the user by appropriate error code.
Before returning to the user, lets trigger the connection
so that its ready for the next retry.
[ Upstream commit f9fb69adb6c7acca60977a4db5a5f95b8e66c041 ]
RDS support max message size as 1M but the code doesn't check this
in all cases. Patch fixes it for RDMA & non-RDMA and RDS MR size
and its enforced irrespective of underlying transport.
Signed-off-by: Avinash Repaka <avinash.repaka@oracle.com>
commit 9523feac272ccad2ad8186ba4fcc89103754de52 upstream.
Because userspace gets Very Unhappy when calls like stat() and execve()
return -EINTR on 9p filesystem mounts. For instance, when bash is
looking in PATH for things to execute and some SIGCHLD interrupts
stat(), bash can throw a spurious 'command not found' since it doesn't
retry the stat().
In practice, hitting the problem is rare and needs a really
slow/bogged down 9p server.
commit c45e3e4c5b134b081e8af362109905427967eb19 upstream.
A recent change fixing NFC device allocation itself introduced an
error-handling bug by returning an error pointer in case device-id
allocation failed. This is clearly broken as the callers still expected
NULL to be returned on errors as detected by Dan's static checker.
Fix this up by returning NULL in the event that we've run out of memory
when allocating a new device id.
Note that the offending commit is marked for stable (3.8) so this fix
needs to be backported along with it.
Fixes: 20777bc57c34 ("NFC: fix broken device allocation")
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Johan Hovold <johan@kernel.org>
commit b11270853fa3654f08d4a6a03b23ddb220512d8d upstream.
The WARN_ON(!key->len) in set_secret() in net/ceph/crypto.c is hit if a
user tries to add a key of type "ceph" with an invalid payload as
follows (assuming CONFIG_CEPH_LIB=y):
echo -e -n '\x01\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00' \
| keyctl padd ceph desc @s
This can be hit by fuzzers. As this is merely bad input and not a
kernel bug, replace the WARN_ON() with return -EINVAL.
Fixes: 7af3ea189a9a ("libceph: stop allocating a new cipher on every crypto request")
Reviewed-by: Ilya Dryomov <idryomov@gmail.com>
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
commit 499fde662f1957e3cb8d192a94a099ebe19c714b upstream.
As reported by Michal, vsock_stream_sendmsg() could still
sleep at vsock_stream_has_space() after prepare_to_wait():
vmci_transport_stream_has_space
vmci_qpair_produce_free_space
qp_lock
qp_acquire_queue_mutex
mutex_lock
Just switch to the new wait API like we did for commit
d9dc8b0f8b4e ("net: fix sleeping for sk_wait_event()").
Reported-by: Michal Kubecek <mkubecek@suse.cz>
Cc: Stefan Hajnoczi <stefanha@redhat.com>
Cc: Jorgen Hansen <jhansen@vmware.com>
Cc: "Michael S. Tsirkin" <mst@redhat.com>
Cc: Claudio Imbrenda <imbrenda@linux.vnet.ibm.com>
Reviewed-by: Stefan Hajnoczi <stefanha@redhat.com>
Cc: "Jorgen S. Hansen" <jhansen@vmware.com>
commit 76da0704507bbc51875013f6557877ab308cfd0a upstream.
In commit 242d3a49a2a1 ("ipv6: reorder ip6_route_dev_notifier after ipv6_dev_notf")
I assumed NETDEV_REGISTER and NETDEV_UNREGISTER are paired,
unfortunately, as reported by jeffy, netdev_wait_allrefs()
could rebroadcast NETDEV_UNREGISTER event until all refs are
gone.
We have to add an additional check to avoid this corner case.
For netdev_wait_allrefs() dev->reg_state is NETREG_UNREGISTERED,
for dev_change_net_namespace(), dev->reg_state is
NETREG_REGISTERED. So check for dev->reg_state != NETREG_UNREGISTERED.
Fixes: 242d3a49a2a1 ("ipv6: reorder ip6_route_dev_notifier after ipv6_dev_notf")
Reported-by: jeffy <jeffy.chen@rock-chips.com>
Cc: David Ahern <dsahern@gmail.com>
Acked-by: David Ahern <dsahern@gmail.com>
Cc: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
[ Upstream commit 7c8a61d9ee1df0fb4747879fa67a99614eb62fec ]
Alexandar Potapenko while testing the kernel with KMSAN and syzkaller
discovered that in some configurations sctp would leak 4 bytes of
kernel stack.
Working with his reproducer I discovered that those 4 bytes that
are leaked is the scope id of an ipv6 address returned by recvmsg.
With a little code inspection and a shrewd guess I discovered that
sctp_inet6_skb_msgname only initializes the scope_id field for link
local ipv6 addresses to the interface index the link local address
pertains to instead of initializing the scope_id field for all ipv6
addresses.
That is almost reasonable as scope_id's are meaniningful only for link
local addresses. Set the scope_id in all other cases to 0 which is
not a valid interface index to make it clear there is nothing useful
in the scope_id field.
There should be no danger of breaking userspace as the stack leak
guaranteed that previously meaningless random data was being returned.
Fixes: 372f525b495c ("SCTP: Resync with LKSCTP tree.")
History-tree: https://git.kernel.org/pub/scm/linux/kernel/git/tglx/history.git
Reported-by: Alexander Potapenko <glider@google.com>
Tested-by: Alexander Potapenko <glider@google.com>
[ Upstream commit df80cd9b28b9ebaa284a41df611dbf3a2d05ca74 ]
Now when peeling off an association to the sock in another netns, all
transports in this assoc are not to be rehashed and keep use the old
key in hashtable.
As a transport uses sk->net as the hash key to insert into hashtable,
it would miss removing these transports from hashtable due to the new
netns when closing the sock and all transports are being freeed, then
later an use-after-free issue could be caused when looking up an asoc
and dereferencing those transports.
This is a very old issue since very beginning, ChunYu found it with
syzkaller fuzz testing with this series:
socket$inet6_sctp()
bind$inet6()
sendto$inet6()
unshare(0x40000000)
getsockopt$inet_sctp6_SCTP_GET_ASSOC_ID_LIST()
getsockopt$inet_sctp6_SCTP_SOCKOPT_PEELOFF()
This patch is to block this call when peeling one assoc off from one
netns to another one, so that the netns of all transport would not
go out-sync with the key in hashtable.
Note that this patch didn't fix it by rehashing transports, as it's
difficult to handle the situation when the tuple is already in use
in the new netns. Besides, no one would like to peel off one assoc
to another netns, considering ipaddrs, ifaces, etc. are usually
different.
Reported-by: ChunYu Wang <chunwang@redhat.com>
Signed-off-by: Xin Long <lucien.xin@gmail.com>
Acked-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
[ Upstream commit 0642840b8bb008528dbdf929cec9f65ac4231ad0 ]
The way people generally use netlink_dump is that they fill in the skb
as much as possible, breaking when nla_put returns an error. Then, they
get called again and start filling out the next skb, and again, and so
forth. The mechanism at work here is the ability for the iterative
dumping function to detect when the skb is filled up and not fill it
past the brim, waiting for a fresh skb for the rest of the data.
However, if the attributes are small and nicely packed, it is possible
that a dump callback function successfully fills in attributes until the
skb is of size 4080 (libmnl's default page-sized receive buffer size).
The dump function completes, satisfied, and then, if it happens to be
that this is actually the last skb, and no further ones are to be sent,
then netlink_dump will add on the NLMSG_DONE part:
nlh = nlmsg_put_answer(skb, cb, NLMSG_DONE, sizeof(len), NLM_F_MULTI);
It is very important that netlink_dump does this, of course. However, in
this example, that call to nlmsg_put_answer will fail, because the
previous filling by the dump function did not leave it enough room. And
how could it possibly have done so? All of the nla_put variety of
functions simply check to see if the skb has enough tailroom,
independent of the context it is in.
In order to keep the important assumptions of all netlink dump users, it
is therefore important to give them an skb that has this end part of the
tail already reserved, so that the call to nlmsg_put_answer does not
fail. Otherwise, library authors are forced to find some bizarre sized
receive buffer that has a large modulo relative to the common sizes of
messages received, which is ugly and buggy.
This patch thus saves the NLMSG_DONE for an additional message, for the
case that things are dangerously close to the brim. This requires
keeping track of the errno from ->dump() across calls.
Signed-off-by: Jason A. Donenfeld <Jason@zx2c4.com>
[ Upstream commit 052d41c01b3a2e3371d66de569717353af489d63 ]
After refcnt reaches zero, vlan_vid_del() could free
dev->vlan_info via RCU:
RCU_INIT_POINTER(dev->vlan_info, NULL);
call_rcu(&vlan_info->rcu, vlan_info_rcu_free);
However, the pointer 'grp' still points to that memory
since it is set before vlan_vid_del():
vlan_info = rtnl_dereference(dev->vlan_info);
if (!vlan_info)
goto out;
grp = &vlan_info->grp;
Depends on when that RCU callback is scheduled, we could
trigger a use-after-free in vlan_group_for_each_dev()
right following this vlan_vid_del().
Fix it by moving vlan_vid_del() before setting grp. This
is also symmetric to the vlan_vid_add() we call in
vlan_device_event().
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Fixes: efc73f4bbc23 ("net: Fix memory leak - vlan_info struct")
Cc: Alexander Duyck <alexander.duyck@gmail.com>
Cc: Girish Moodalbail <girish.moodalbail@oracle.com>
Reviewed-by: Girish Moodalbail <girish.moodalbail@oracle.com>
Tested-by: Fengguang Wu <fengguang.wu@intel.com>
[ Upstream commit 2b5ec1a5f9738ee7bf8f5ec0526e75e00362c48f ]
When run ipvs in two different network namespace at the same host, and one
ipvs transport network traffic to the other network namespace ipvs.
'ipvs_property' flag will make the second ipvs take no effect. So we should
clear 'ipvs_property' when SKB network namespace changed.
Fixes: 621e84d6f373 ("dev: introduce skb_scrub_packet()")
Signed-off-by: Ye Yin <hustcat@gmail.com>
Signed-off-by: Wei Zhou <chouryzhou@gmail.com>
Signed-off-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Simon Horman <horms@verge.net.au>
[ Upstream commit 3b11775033dc87c3d161996c54507b15ba26414a ]
Christoph Paasch sent a patch to address the following issue :
tcp_make_synack() is leaving some TCP private info in skb->cb[],
then send the packet by other means than tcp_transmit_skb()
tcp_transmit_skb() makes sure to clear skb->cb[] to not confuse
IPv4/IPV6 stacks, but we have no such cleanup for SYNACK.
tcp_make_synack() should not use tcp_init_nondata_skb() :
tcp_init_nondata_skb() really should be limited to skbs put in write/rtx
queues (the ones that are only sent via tcp_transmit_skb())
This patch fixes the issue and should even save few cpu cycles ;)
Fixes: 971f10eca186 ("tcp: better TCP_SKB_CB layout to reduce cache line misses")
Reported-by: Christoph Paasch <cpaasch@apple.com>
Reviewed-by: Christoph Paasch <cpaasch@apple.com>
[ Upstream commit 4eebff27ca4182bbf5f039dd60d79e2d7c0a707e ]
Average RTT could become zero. This happened in real life at least twice.
This patch treats zero as 1us.
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Acked-by: Lawrence Brakmo <Brakmo@fb.com>
[ Upstream commit ad02c4f547826167a709dab8a89a1caefd2c1f50 ]
For TCP sockets, TX timestamps are only captured when the user data
is successfully and fully written to the socket. In many cases,
however, TCP writes can be partial for which no timestamp is
collected.
Collect timestamps whenever any user data is (fully or partially)
copied into the socket. Pass tcp_write_queue_tail to tcp_tx_timestamp
instead of the local skb pointer since it can be set to NULL on
the error path.
Note that tcp_write_queue_tail can be NULL, even if bytes have been
copied to the socket. This is because acknowledgements are being
processed in tcp_sendmsg(), and by the time tcp_tx_timestamp is
called tcp_write_queue_tail can be NULL. For such cases, this patch
does not collect any timestamps (i.e., it is best-effort).
This patch is written with suggestions from Willem de Bruijn and
Eric Dumazet.
Change-log V1 -> V2:
- Use sockc.tsflags instead of sk->sk_tsflags.
- Use the same code path for normal writes and errors.
Signed-off-by: Soheil Hassas Yeganeh <soheil@google.com>
Acked-by: Yuchung Cheng <ycheng@google.com>
Cc: Willem de Bruijn <willemb@google.com>
Cc: Eric Dumazet <edumazet@google.com>
Cc: Neal Cardwell <ncardwell@google.com>
Cc: Martin KaFai Lau <kafai@fb.com>
Acked-by: Willem de Bruijn <willemb@google.com>
commit e1bf1687740ce1a3598a1c5e452b852ff2190682 upstream.
This reverts commit 870190a9ec9075205c0fa795a09fa931694a3ff1.
It was not a good idea. The custom hash table was a much better
fit for this purpose.
A fast lookup is not essential, in fact for most cases there is no lookup
at all because original tuple is not taken and can be used as-is.
What needs to be fast is insertion and deletion.
rhlist removal however requires a rhlist walk.
We can have thousands of entries in such a list if source port/addresses
are reused for multiple flows, if this happens removal requests are so
expensive that deletions of a few thousand flows can take several
seconds(!).
The advantages that we got from rhashtable are:
1) table auto-sizing
2) multiple locks
1) would be nice to have, but it is not essential as we have at
most one lookup per new flow, so even a million flows in the bysource
table are not a problem compared to current deletion cost.
2) is easy to add to custom hash table.
I tried to add hlist_node to rhlist to speed up rhltable_remove but this
isn't doable without changing semantics. rhltable_remove_fast will
check that the to-be-deleted object is part of the table and that
requires a list walk that we want to avoid.
Furthermore, using hlist_node increases size of struct rhlist_head, which
in turn increases nf_conn size.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=196821
Reported-by: Ivan Babrou <ibobrik@gmail.com>
commit 6e699867f84c0f358fed233fe6162173aca28e04 upstream.
successful insert into the bysource hash sets IPS_SRC_NAT_DONE status bit
so we can check that instead of presence of nat extension which requires
extra deref.
commit cfbb0d90a7abb289edc91833d0905931f8805f12 upstream.
For the reinstall prevention, the code I had added compares the
whole key. It turns out though that iwlwifi firmware doesn't
provide the TKIP TX MIC key as it's not needed in client mode,
and thus the comparison will always return false.
For client mode, thus always zero out the TX MIC key part before
doing the comparison in order to avoid accepting the reinstall
of the key with identical encryption and RX MIC key, but not the
same TX MIC key (since the supplicant provides the real one.)
Fixes: fdf7cb4185b6 ("mac80211: accept key reinstall without changing anything")
Cc: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit 2bdd713b92a9cade239d3c7d15205a09f556624d upstream.
Otherwise we risk leaking information via timing side channel.
commit fdf7cb4185b60c68e1a75e61691c4afdc15dea0e upstream.
When a key is reinstalled we can reset the replay counters
etc. which can lead to nonce reuse and/or replay detection
being impossible, breaking security properties, as described
in the "KRACK attacks".
In particular, CVE-2017-13080 applies to GTK rekeying that
happened in firmware while the host is in D3, with the second
part of the attack being done after the host wakes up. In
this case, the wpa_supplicant mitigation isn't sufficient
since wpa_supplicant doesn't know the GTK material.
In case this happens, simply silently accept the new key
coming from userspace but don't take any action on it since
it's the same key; this keeps the PN replay counters intact.
[ Upstream commit 50317fce2cc70a2bbbc4b42c31bbad510382a53c ]
Davide found the following script triggers a NULL pointer
dereference:
ip l a name eth0 type dummy
tc q a dev eth0 parent :1 handle 1: htb
This is because for a freshly created netdevice noop_qdisc
is attached and when passing 'parent :1', kernel actually
tries to match the major handle which is 0 and noop_qdisc
has handle 0 so is matched by mistake. Commit 69012ae425d7
tries to fix a similar bug but still misses this case.
Handle 0 is not a valid one, should be just skipped. In
fact, kernel uses it as TC_H_UNSPEC.
Fixes: 69012ae425d7 ("net: sched: fix handling of singleton qdiscs with qdisc_hash")
Fixes: 59cc1f61f09c ("net: sched:convert qdisc linked list to hashtable")
Reported-by: Davide Caratti <dcaratti@redhat.com>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Jamal Hadi Salim <jhs@mojatatu.com>
[ Upstream commit d04adf1b355181e737b6b1e23d801b07f0b7c4c0 ]
Now when migrating sock to another one in sctp_sock_migrate(), it only
resets owner sk for the data in receive queues, not the chunks on out
queues.
It would cause that data chunks length on the sock is not consistent
with sk sk_wmem_alloc. When closing the sock or freeing these chunks,
the old sk would never be freed, and the new sock may crash due to
the overflow sk_wmem_alloc.
syzbot found this issue with this series:
r0 = socket$inet_sctp()
sendto$inet(r0)
listen(r0)
accept4(r0)
close(r0)
Although listen() should have returned error when one TCP-style socket
is in connecting (I may fix this one in another patch), it could also
be reproduced by peeling off an assoc.
This issue is there since very beginning.
This patch is to reset owner sk for the chunks on out queues so that
sk sk_wmem_alloc has correct value after accept one sock or peeloff
an assoc to one sock.
Note that when resetting owner sk for chunks on outqueue, it has to
sctp_clear_owner_w/skb_orphan chunks before changing assoc->base.sk
first and then sctp_set_owner_w them after changing assoc->base.sk,
due to that sctp_wfree and it's callees are using assoc->base.sk.
[ Upstream commit 8aec4959d832bae0889a8e2f348973b5e4abffef ]
When receiving a Toobig icmpv6 packet, ip6gre_err would just set
tunnel dev's mtu, that's not enough. For skb_dst(skb)'s pmtu may
still be using the old value, it has no chance to be updated with
tunnel dev's mtu.
Jianlin found this issue by reducing route's mtu while running
netperf, the performance went to 0.
ip6ip6 and ip4ip6 tunnel can work well with this, as they lookup
the upper dst and update_pmtu it's pmtu or icmpv6_send a Toobig
to upper socket after setting tunnel dev's mtu.
We couldn't do that for ip6_gre, as gre's inner packet could be
any protocol, it's difficult to handle them (like lookup upper
dst) in a good way.
So this patch is to fix it by updating skb_dst(skb)'s pmtu when
dev->mtu < skb_dst(skb)'s pmtu in tx path. It's safe to do this
update there, as usually dev->mtu <= skb_dst(skb)'s pmtu and no
performance regression can be caused by this.
Fixes: c12b395a4664 ("gre: Support GRE over IPv6")
Reported-by: Jianlin Shi <jishi@redhat.com>
[ Upstream commit f8d20b46ce55cf40afb30dcef6d9288f7ef46d9b ]
The similar fix in patch 'ipip: only increase err_count for some
certain type icmp in ipip_err' is needed for ip6gre_err.
In Jianlin's case, udp netperf broke even when receiving a TooBig
icmpv6 packet.
[ Upstream commit f3594f0a7ea36661d7fd942facd7f31a64245f1a ]
t->err_count is used to count the link failure on tunnel and an err
will be reported to user socket in tx path if t->err_count is not 0.
udp socket could even return EHOSTUNREACH to users.
Since commit fd58156e456d ("IPIP: Use ip-tunneling code.") removed
the 'switch check' for icmp type in ipip_err(), err_count would be
increased by the icmp packet with ICMP_EXC_FRAGTIME code. an link
failure would be reported out due to this.
In Jianlin's case, when receiving ICMP_EXC_FRAGTIME a icmp packet,
udp netperf failed with the err:
send_data: data send error: No route to host (errno 113)
We expect this error reported from tunnel to socket when receiving
some certain type icmp, but not ICMP_EXC_FRAGTIME, ICMP_SR_FAILED
or ICMP_PARAMETERPROB ones.
This patch is to bring 'switch check' for icmp type back to ipip_err
so that it only reports link failure for the right type icmp, just as
in ipgre_err() and ipip6_err().
Fixes: fd58156e456d ("IPIP: Use ip-tunneling code.")
[ Upstream commit 0f5da659d8f1810f44de14acf2c80cd6499623a0 ]
socket_diag shows information only about sockets from a namespace where
a diag socket lives.
But if we request information about one unix socket, the kernel don't
check that its netns is matched with a diag socket namespace, so any
user can get information about any unix socket in a system. This looks
like a bug.
v2: add a Fixes tag
Fixes: 51d7cccf0723 ("net: make sock diag per-namespace")
Signed-off-by: Andrei Vagin <avagin@openvz.org>
[ Upstream commit 06f877d613be3621604c2520ec0351d9fbdca15f ]
In my first attempt to fix the lockdep splat, I forgot we could
enter inet_csk_route_req() with a freshly allocated request socket,
for which refcount has not yet been elevated, due to complex
SLAB_TYPESAFE_BY_RCU rules.
We either are in rcu_read_lock() section _or_ we own a refcount on the
request.
Correct RCU verb to use here is rcu_dereference_check(), although it is
not possible to prove we actually own a reference on a shared
refcount :/
In v2, I added ireq_opt_deref() helper and use in three places, to fix other
possible splats.
[ 49.844590] lockdep_rcu_suspicious+0xea/0xf3
[ 49.846487] inet_csk_route_req+0x53/0x14d
[ 49.848334] tcp_v4_route_req+0xe/0x10
[ 49.850174] tcp_conn_request+0x31c/0x6a0
[ 49.851992] ? __lock_acquire+0x614/0x822
[ 49.854015] tcp_v4_conn_request+0x5a/0x79
[ 49.855957] ? tcp_v4_conn_request+0x5a/0x79
[ 49.858052] tcp_rcv_state_process+0x98/0xdcc
[ 49.859990] ? sk_filter_trim_cap+0x2f6/0x307
[ 49.862085] tcp_v4_do_rcv+0xfc/0x145
[ 49.864055] ? tcp_v4_do_rcv+0xfc/0x145
[ 49.866173] tcp_v4_rcv+0x5ab/0xaf9
[ 49.868029] ip_local_deliver_finish+0x1af/0x2e7
[ 49.870064] ip_local_deliver+0x1b2/0x1c5
[ 49.871775] ? inet_del_offload+0x45/0x45
[ 49.873916] ip_rcv_finish+0x3f7/0x471
[ 49.875476] ip_rcv+0x3f1/0x42f
[ 49.876991] ? ip_local_deliver_finish+0x2e7/0x2e7
[ 49.878791] __netif_receive_skb_core+0x6d3/0x950
[ 49.880701] ? process_backlog+0x7e/0x216
[ 49.882589] __netif_receive_skb+0x1d/0x5e
[ 49.884122] process_backlog+0x10c/0x216
[ 49.885812] net_rx_action+0x147/0x3df
Fixes: a6ca7abe53633 ("tcp/dccp: fix lockdep splat in inet_csk_route_req()")
Fixes: c92e8c02fe66 ("tcp/dccp: fix ireq->opt races")
Reported-by: kernel test robot <fengguang.wu@intel.com>
Reported-by: Maciej Żenczykowski <maze@google.com>
[ Upstream commit a6ca7abe53633d08eea1c6756cb49c9b2d4c90bf ]
This patch fixes the following lockdep splat in inet_csk_route_req()
inet_csk_route_req
tcp_v4_send_synack
tcp_rtx_synack
inet_rtx_syn_ack
tcp_fastopen_synack_time
tcp_retransmit_timer
tcp_write_timer_handler
tcp_write_timer
call_timer_fn
Thread running inet_csk_route_req() owns a reference on the request
socket, so we have the guarantee ireq->ireq_opt wont be changed or
freed.
lockdep can enforce this invariant for us.
[ Upstream commit b71d21c274eff20a9db8158882b545b141b73ab8 ]
Commit 9b9742022888 ("sctp: support ipv6 nonlocal bind")
introduced support for the above options as v4 sctp did,
so patched sctp_v6_available().
In the v4 implementation it's enough, because
sctp_inet_bind_verify() just returns with sctp_v4_available().
However sctp_inet6_bind_verify() has an extra check before that
for link-local scope_id, which won't respect the above options.
Added the checks before calling ipv6_chk_addr(), but
not before the validation of scope_id.
before (w/ both options):
./v6test fe80::10 sctp
bind failed, errno: 99 (Cannot assign requested address)
./v6test fe80::10 tcp
bind success, errno: 0 (Success)
after (w/ both options):
Signed-off-by: Laszlo Toth <laszlth@gmail.com>
Reviewed-by: Xin Long <lucien.xin@gmail.com>
[ Upstream commit 864e2a1f8aac05effac6063ce316b480facb46ff ]
When syzkaller team brought us a C repro for the crash [1] that
had been reported many times in the past, I finally could find
the root cause.
If FlowLabel info is merged by fl6_merge_options(), we leave
part of the opt_space storage provided by udp/raw/l2tp with random value
in opt_space.tot_len, unless a control message was provided at sendmsg()
time.
Then ip6_setup_cork() would use this random value to perform a kzalloc()
call. Undefined behavior and crashes.
Fix is to properly set tot_len in fl6_merge_options()
At the same time, we can also avoid consuming memory and cpu cycles
to clear it, if every option is copied via a kmemdup(). This is the
change in ip6_setup_cork().
[1]
kasan: CONFIG_KASAN_INLINE enabled
kasan: GPF could be caused by NULL-ptr deref or user memory access
general protection fault: 0000 [#1] SMP KASAN
Dumping ftrace buffer:
(ftrace buffer empty)
Modules linked in:
CPU: 0 PID: 6613 Comm: syz-executor0 Not tainted 4.14.0-rc4+ #127
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
task: ffff8801cb64a100 task.stack: ffff8801cc350000
RIP: 0010:ip6_setup_cork+0x274/0x15c0 net/ipv6/ip6_output.c:1168
RSP: 0018:ffff8801cc357550 EFLAGS: 00010203
RAX: dffffc0000000000 RBX: ffff8801cc357748 RCX: 0000000000000010
RDX: 0000000000000002 RSI: ffffffff842bd1d9 RDI: 0000000000000014
RBP: ffff8801cc357620 R08: ffff8801cb17f380 R09: ffff8801cc357b10
R10: ffff8801cb64a100 R11: 0000000000000000 R12: ffff8801cc357ab0
R13: ffff8801cc357b10 R14: 0000000000000000 R15: ffff8801c3bbf0c0
FS: 00007f9c5c459700(0000) GS:ffff8801db200000(0000) knlGS:0000000000000000
CR2: 0000000020324000 CR3: 00000001d1cf2000 CR4: 00000000001406f0
DR0: 0000000020001010 DR1: 0000000000000000 DR2: 0000000000000000
DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000600
Call Trace:
ip6_make_skb+0x282/0x530 net/ipv6/ip6_output.c:1729
udpv6_sendmsg+0x2769/0x3380 net/ipv6/udp.c:1340
inet_sendmsg+0x11f/0x5e0 net/ipv4/af_inet.c:762
sock_sendmsg_nosec net/socket.c:633 [inline]
sock_sendmsg+0xca/0x110 net/socket.c:643
SYSC_sendto+0x358/0x5a0 net/socket.c:1750
SyS_sendto+0x40/0x50 net/socket.c:1718
entry_SYSCALL_64_fastpath+0x1f/0xbe
RIP: 0033:0x4520a9
RSP: 002b:00007f9c5c458c08 EFLAGS: 00000216 ORIG_RAX: 000000000000002c
RAX: ffffffffffffffda RBX: 0000000000718000 RCX: 00000000004520a9
RDX: 0000000000000001 RSI: 0000000020fd1000 RDI: 0000000000000016
RBP: 0000000000000086 R08: 0000000020e0afe4 R09: 000000000000001c
R10: 0000000000000000 R11: 0000000000000216 R12: 00000000004bb1ee
R13: 00000000ffffffff R14: 0000000000000016 R15: 0000000000000029
Code: e0 07 83 c0 03 38 d0 7c 08 84 d2 0f 85 ea 0f 00 00 48 8d 79 04 48 b8 00 00 00 00 00 fc ff df 45 8b 74 24 04 48 89 fa 48 c1 ea 03 <0f> b6 14 02 48 89 f8 83 e0 07 83 c0 03 38 d0 7c 08 84 d2 0f 85
RIP: ip6_setup_cork+0x274/0x15c0 net/ipv6/ip6_output.c:1168 RSP: ffff8801cc357550
[ Upstream commit 1b5f962e71bfad6284574655c406597535c3ea7a ]
Syzkaller stumbled upon a way to trigger
WARNING: CPU: 1 PID: 13881 at net/core/sock_reuseport.c:41
reuseport_alloc+0x306/0x3b0 net/core/sock_reuseport.c:39
There are two initialization paths for the sock_reuseport structure in a
socket: Through the udp/tcp bind paths of SO_REUSEPORT sockets or through
SO_ATTACH_REUSEPORT_[CE]BPF before bind. The existing implementation
assumedthat the socket lock protected both of these paths when it actually
only protects the SO_ATTACH_REUSEPORT path. Syzkaller triggered this
double allocation by running these paths concurrently.
This patch moves the check for double allocation into the reuseport_alloc
function which is protected by a global spin lock.
Fixes: e32ea7e74727 ("soreuseport: fast reuseport UDP socket selection")
Fixes: c125e80b8868 ("soreuseport: fast reuseport TCP socket selection")
Signed-off-by: Craig Gallek <kraig@google.com>
[ Upstream commit 509c7a1ecc8601f94ffba8a00889fefb239c00c6 ]
syzkaller got crashes in packet_getsockopt() processing
PACKET_ROLLOVER_STATS command while another thread was managing
to change po->rollover
Using RCU will fix this bug. We might later add proper RCU annotations
for sparse sake.
In v2: I replaced kfree(rollover) in fanout_add() to kfree_rcu()
variant, as spotted by John.
Fixes: a9b6391814d5 ("packet: rollover statistics")
Cc: John Sperbeck <jsperbeck@google.com>
[ Upstream commit c92e8c02fe664155ac4234516e32544bec0f113d ]
syzkaller found another bug in DCCP/TCP stacks [1]
For the reasons explained in commit ce1050089c96 ("tcp/dccp: fix
ireq->pktopts race"), we need to make sure we do not access
ireq->opt unless we own the request sock.
Note the opt field is renamed to ireq_opt to ease grep games.
[1]
BUG: KASAN: use-after-free in ip_queue_xmit+0x1687/0x18e0 net/ipv4/ip_output.c:474
Read of size 1 at addr ffff8801c951039c by task syz-executor5/3295
CPU: 1 PID: 3295 Comm: syz-executor5 Not tainted 4.14.0-rc4+ #80
Call Trace:
__dump_stack lib/dump_stack.c:16 [inline]
dump_stack+0x194/0x257 lib/dump_stack.c:52
print_address_description+0x73/0x250 mm/kasan/report.c:252
kasan_report_error mm/kasan/report.c:351 [inline]
kasan_report+0x25b/0x340 mm/kasan/report.c:409
__asan_report_load1_noabort+0x14/0x20 mm/kasan/report.c:427
tcp_transmit_skb+0x1ab7/0x3840 net/ipv4/tcp_output.c:1135
tcp_send_ack.part.37+0x3bb/0x650 net/ipv4/tcp_output.c:3587
tcp_send_ack+0x49/0x60 net/ipv4/tcp_output.c:3557
__tcp_ack_snd_check+0x2c6/0x4b0 net/ipv4/tcp_input.c:5072
tcp_ack_snd_check net/ipv4/tcp_input.c:5085 [inline]
tcp_rcv_state_process+0x2eff/0x4850 net/ipv4/tcp_input.c:6071
tcp_child_process+0x342/0x990 net/ipv4/tcp_minisocks.c:816
tcp_v4_rcv+0x1827/0x2f80 net/ipv4/tcp_ipv4.c:1682
ip_local_deliver_finish+0x2e2/0xba0 net/ipv4/ip_input.c:216
NF_HOOK include/linux/netfilter.h:249 [inline]
ip_local_deliver+0x1ce/0x6e0 net/ipv4/ip_input.c:257
dst_input include/net/dst.h:464 [inline]
ip_rcv_finish+0x887/0x19a0 net/ipv4/ip_input.c:397
ip_rcv+0xc3f/0x1820 net/ipv4/ip_input.c:493
__netif_receive_skb_core+0x1a3e/0x34b0 net/core/dev.c:4476
__netif_receive_skb+0x2c/0x1b0 net/core/dev.c:4514
netif_receive_skb_internal+0x10b/0x670 net/core/dev.c:4587
netif_receive_skb+0xae/0x390 net/core/dev.c:4611
tun_rx_batched.isra.50+0x5ed/0x860 drivers/net/tun.c:1372
tun_get_user+0x249c/0x36d0 drivers/net/tun.c:1766
tun_chr_write_iter+0xbf/0x160 drivers/net/tun.c:1792
call_write_iter include/linux/fs.h:1770 [inline]
new_sync_write fs/read_write.c:468 [inline]
__vfs_write+0x68a/0x970 fs/read_write.c:481
vfs_write+0x18f/0x510 fs/read_write.c:543
SYSC_write fs/read_write.c:588 [inline]
SyS_write+0xef/0x220 fs/read_write.c:580
RIP: 0033:0x40c341
RSP: 002b:00007f469523ec10 EFLAGS: 00000293 ORIG_RAX: 0000000000000001
RAX: ffffffffffffffda RBX: 0000000000718000 RCX: 000000000040c341
RDX: 0000000000000037 RSI: 0000000020004000 RDI: 0000000000000015
RBP: 0000000000000086 R08: 0000000000000000 R09: 0000000000000000
R10: 00000000000f4240 R11: 0000000000000293 R12: 00000000004b7fd1
R13: 00000000ffffffff R14: 0000000020000000 R15: 0000000000025000
Allocated by task 3295:
save_stack_trace+0x16/0x20 arch/x86/kernel/stacktrace.c:59
save_stack+0x43/0xd0 mm/kasan/kasan.c:447
set_track mm/kasan/kasan.c:459 [inline]
kasan_kmalloc+0xad/0xe0 mm/kasan/kasan.c:551
__do_kmalloc mm/slab.c:3725 [inline]
__kmalloc+0x162/0x760 mm/slab.c:3734
kmalloc include/linux/slab.h:498 [inline]
tcp_v4_save_options include/net/tcp.h:1962 [inline]
tcp_v4_init_req+0x2d3/0x3e0 net/ipv4/tcp_ipv4.c:1271
tcp_conn_request+0xf6d/0x3410 net/ipv4/tcp_input.c:6283
tcp_v4_conn_request+0x157/0x210 net/ipv4/tcp_ipv4.c:1313
tcp_rcv_state_process+0x8ea/0x4850 net/ipv4/tcp_input.c:5857
tcp_v4_do_rcv+0x55c/0x7d0 net/ipv4/tcp_ipv4.c:1482
tcp_v4_rcv+0x2d10/0x2f80 net/ipv4/tcp_ipv4.c:1711
Freed by task 3306:
kasan_slab_free+0x71/0xc0 mm/kasan/kasan.c:524
__cache_free mm/slab.c:3503 [inline]
kfree+0xca/0x250 mm/slab.c:3820
inet_sock_destruct+0x59d/0x950 net/ipv4/af_inet.c:157
__sk_destruct+0xfd/0x910 net/core/sock.c:1560
sk_destruct+0x47/0x80 net/core/sock.c:1595
__sk_free+0x57/0x230 net/core/sock.c:1603
sk_free+0x2a/0x40 net/core/sock.c:1614
sock_put include/net/sock.h:1652 [inline]
inet_csk_complete_hashdance+0xd5/0xf0 net/ipv4/inet_connection_sock.c:959
tcp_check_req+0xf4d/0x1620 net/ipv4/tcp_minisocks.c:765
tcp_v4_rcv+0x17f6/0x2f80 net/ipv4/tcp_ipv4.c:1675
Fixes: e994b2f0fb92 ("tcp: do not lock listener to process SYN packets")
Fixes: 079096f103fa ("tcp/dccp: install syn_recv requests into ehash table")
[ Upstream commit 1cc276cec9ec574d41cf47dfc0f51406b6f26ab4 ]
Now sctp processes icmp redirect packet in sctp_icmp_redirect where
it calls sctp_transport_dst_check in which tp->dst can be released.
The problem is before calling sctp_transport_dst_check, it doesn't
check sock_owned_by_user, which means tp->dst could be freed while
a process is accessing it with owning the socket.
An use-after-free issue could be triggered by this.
This patch is to fix it by checking sock_owned_by_user before calling
sctp_transport_dst_check in sctp_icmp_redirect, so that it would not
release tp->dst if users still hold sock lock.
Besides, the same issue fixed in commit 45caeaa5ac0b ("dccp/tcp: fix
routing redirect race") on sctp also needs this check.
Fixes: 55be7a9c6074 ("ipv4: Add redirect support to all protocol icmp error handlers")
Reported-by: Eric Dumazet <edumazet@google.com>
[ Upstream commit 0ad646c81b2182f7fa67ec0c8c825e0ee165696d ]
register_netdevice() could fail early when we have an invalid
dev name, in which case ->ndo_uninit() is not called. For tun
device, this is a problem because a timer etc. are already
initialized and it expects ->ndo_uninit() to clean them up.
We could move these initializations into a ->ndo_init() so
that register_netdevice() knows better, however this is still
complicated due to the logic in tun_detach().
Therefore, I choose to just call dev_get_valid_name() before
register_netdevice(), which is quicker and much easier to audit.
And for this specific case, it is already enough.
Fixes: 96442e42429e ("tuntap: choose the txq based on rxq")
Reported-by: Dmitry Alexeev <avekceeb@gmail.com>
Cc: Jason Wang <jasowang@redhat.com>
[ Upstream commit 5903f594935a3841137c86b9d5b75143a5b7121c ]
When pppol2tp_session_ioctl() is called by pppol2tp_tunnel_ioctl(),
the session may be unconnected. That is, it was created by
pppol2tp_session_create() and hasn't been connected with
pppol2tp_connect(). In this case, ps->sock is NULL, so we need to check
for this case in order to avoid dereferencing a NULL pointer.
Fixes: 309795f4bec2 ("l2tp: Add netlink control API for L2TP")
Signed-off-by: Guillaume Nault <g.nault@alphalink.fr>
[ Upstream commit 2b7cda9c35d3b940eb9ce74b30bbd5eb30db493d ]
Based on SNMP values provided by Roman, Yuchung made the observation
that some crashes in tcp_sacktag_walk() might be caused by MTU probing.
Looking at tcp_mtu_probe(), I found that when a new skb was placed
in front of the write queue, we were not updating tcp highest sack.
If one skb is freed because all its content was copied to the new skb
(for MTU probing), then tp->highest_sack could point to a now freed skb.
Bad things would then happen, including infinite loops.
This patch renames tcp_highest_sack_combine() and uses it
from tcp_mtu_probe() to fix the bug.
Note that I also removed one test against tp->sacked_out,
since we want to replace tp->highest_sack regardless of whatever
condition, since keeping a stale pointer to freed skb is a recipe
for disaster.
Fixes: a47e5a988a57 ("[TCP]: Convert highest_sack to sk_buff to allow direct access")
Reported-by: Alexei Starovoitov <alexei.starovoitov@gmail.com>
Reported-by: Roman Gushchin <guro@fb.com>
Reported-by: Oleksandr Natalenko <oleksandr@natalenko.name>
Acked-by: Alexei Starovoitov <ast@kernel.org>
Acked-by: Neal Cardwell <ncardwell@google.com>
[ Upstream commit c0576e3975084d4699b7bfef578613fb8e1144f6 ]
If for some reason, the newly allocated child need to be freed,
we will call cgroup_put() (via sk_free_unlock_clone()) while the
corresponding cgroup_get() was not yet done, and we will free memory
too soon.
Fixes: d979a39d7242 ("cgroup: duplicate cgroup reference when cloning sockets")
Cc: Tejun Heo <tj@kernel.org>
[ Upstream commit 41c87425a1ac9b633e0fcc78eb1f19640c8fb5a0 ]
It turns out that multiple places can call netlink_dump(), which means
it's still possible to dereference partially initialized values in
dump() that were the result of a faulty returned start().
This fixes the issue by calling start() _before_ setting cb_running to
true, so that there's no chance at all of hitting the dump() function
through any indirect paths.
It also moves the call to start() to be when the mutex is held. This has
the nice side effect of serializing invocations to start(), which is
likely desirable anyway. It also prevents any possible other races that
might come out of this logic.
In testing this with several different pieces of tricky code to trigger
these issues, this commit fixes all avenues that I'm aware of.
Cc: Johannes Berg <johannes@sipsolutions.net>
Reviewed-by: Johannes Berg <johannes@sipsolutions.net>
[ Upstream commit e669b86945478b3d90d2d87e3793a6eed06d332f ]
In the (unlikely) event fixup_permanent_addr() returns a failure,
addrconf_permanent_addr() calls ipv6_del_addr() without the
mandatory call to in6_ifa_hold(), leading to a refcount error,
spotted by syzkaller :
WARNING: CPU: 1 PID: 3142 at lib/refcount.c:227 refcount_dec+0x4c/0x50
lib/refcount.c:227
Kernel panic - not syncing: panic_on_warn set ...
CPU: 1 PID: 3142 Comm: ip Not tainted 4.14.0-rc4-next-20171009+ #33
Google 01/01/2011
Call Trace:
panic+0x1e4/0x41c kernel/panic.c:181
__warn+0x1c4/0x1e0 kernel/panic.c:544
report_bug+0x211/0x2d0 lib/bug.c:183
fixup_bug+0x40/0x90 arch/x86/kernel/traps.c:178
do_trap_no_signal arch/x86/kernel/traps.c:212 [inline]
do_trap+0x260/0x390 arch/x86/kernel/traps.c:261
do_error_trap+0x120/0x390 arch/x86/kernel/traps.c:298
do_invalid_op+0x1b/0x20 arch/x86/kernel/traps.c:311
invalid_op+0x18/0x20 arch/x86/entry/entry_64.S:905
RIP: 0010:refcount_dec+0x4c/0x50 lib/refcount.c:227
RSP: 0018:ffff8801ca49e680 EFLAGS: 00010286
RAX: 000000000000002c RBX: ffff8801d07cfcdc RCX: 0000000000000000
RDX: 000000000000002c RSI: 1ffff10039493c90 RDI: ffffed0039493cc4
RBP: ffff8801ca49e688 R08: ffff8801ca49dd70 R09: 0000000000000000
R10: ffff8801ca49df58 R11: 0000000000000000 R12: 1ffff10039493cd9
R13: ffff8801ca49e6e8 R14: ffff8801ca49e7e8 R15: ffff8801d07cfcdc
__in6_ifa_put include/net/addrconf.h:369 [inline]
ipv6_del_addr+0x42b/0xb60 net/ipv6/addrconf.c:1208
addrconf_permanent_addr net/ipv6/addrconf.c:3327 [inline]
addrconf_notify+0x1c66/0x2190 net/ipv6/addrconf.c:3393
notifier_call_chain+0x136/0x2c0 kernel/notifier.c:93
__raw_notifier_call_chain kernel/notifier.c:394 [inline]
raw_notifier_call_chain+0x2d/0x40 kernel/notifier.c:401
call_netdevice_notifiers_info+0x32/0x60 net/core/dev.c:1697
call_netdevice_notifiers net/core/dev.c:1715 [inline]
__dev_notify_flags+0x15d/0x430 net/core/dev.c:6843
dev_change_flags+0xf5/0x140 net/core/dev.c:6879
do_setlink+0xa1b/0x38e0 net/core/rtnetlink.c:2113
rtnl_newlink+0xf0d/0x1a40 net/core/rtnetlink.c:2661
rtnetlink_rcv_msg+0x733/0x1090 net/core/rtnetlink.c:4301
netlink_rcv_skb+0x216/0x440 net/netlink/af_netlink.c:2408
rtnetlink_rcv+0x1c/0x20 net/core/rtnetlink.c:4313
netlink_unicast_kernel net/netlink/af_netlink.c:1273 [inline]
netlink_unicast+0x4e8/0x6f0 net/netlink/af_netlink.c:1299
netlink_sendmsg+0xa4a/0xe70 net/netlink/af_netlink.c:1862
___sys_sendmsg+0x75b/0x8a0 net/socket.c:2049
__sys_sendmsg+0xe5/0x210 net/socket.c:2083
SYSC_sendmsg net/socket.c:2094 [inline]
SyS_sendmsg+0x2d/0x50 net/socket.c:2090
RIP: 0033:0x7fa9174d3320
RSP: 002b:00007ffe302ae9e8 EFLAGS: 00000246 ORIG_RAX: 000000000000002e
RAX: ffffffffffffffda RBX: 00007ffe302b2ae0 RCX: 00007fa9174d3320
RDX: 0000000000000000 RSI: 00007ffe302aea20 RDI: 0000000000000016
RBP: 0000000000000082 R08: 0000000000000000 R09: 000000000000000f
R10: 0000000000000000 R11: 0000000000000246 R12: 00007ffe302b32a0
R13: 0000000000000000 R14: 00007ffe302b2ab8 R15: 00007ffe302b32b8
Fixes: f1705ec197e7 ("net: ipv6: Make address flushing on ifdown optional")
[ Upstream commit 3d0241d57c7b25bb75ac9d7a62753642264fdbce ]
When gso_size reset to zero for the tail segment in skb_segment(), later
in ipv6_gso_segment(), __skb_udp_tunnel_segment() and gre_gso_segment()
we will get incorrect results (payload length, pcsum) for that segment.
inet_gso_segment() already has a check for gso_size before calculating
payload.
The issue was found with LTP vxlan & gre tests over ixgbe NIC.
Fixes: 07b26c9454a2 ("gso: Support partial splitting at the frag_list pointer")
Signed-off-by: Alexey Kodanev <alexey.kodanev@oracle.com>
Acked-by: Alexander Duyck <alexander.h.duyck@intel.com>
[ Upstream commit 3a89eaa65db68bf53bf92dedc60084f810e1779a ]
The support for DSA Ethernet switch chips depends on TCP/IP networking,
thus explicit that HAVE_NET_DSA depends on INET.
DSA uses SWITCHDEV, thus select it instead of depending on it.
Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
Tested-by: Randy Dunlap <rdunlap@infradead.org>
[ Upstream commit ebd89a2d0675f1325c2be5b7576fd8cb7e8defd0 ]
ah4 input processing uses the asynchronous hash crypto API which
supplies an error code as part of the operation completion but
the error code was being ignored.
Treat a crypto API error indication as a verification failure.
While a crypto API reported error would almost certainly result
in a memcpy of the digest failing anyway and thus the security
risk seems minor, performing a memory compare on what might be
uninitialized memory is wrong.
Signed-off-by: Gilad Ben-Yossef <gilad@benyossef.com>
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit f169fd695b192dd7b23aff8e69d25a1bc881bbfa ]
After adding the following nft rule, then ping 224.0.0.1:
# nft add rule netdev t c pkttype host counter
The warning complain message will be printed out again and again:
WARNING: CPU: 0 PID: 10182 at net/netfilter/nft_meta.c:163 \
nft_meta_get_eval+0x3fe/0x460 [nft_meta]
Call Trace:
<IRQ>
dump_stack+0x85/0xc2
__warn+0xcb/0xf0
warn_slowpath_null+0x1d/0x20
nft_do_chain+0xff/0x5e0 [nf_tables]
So we should deal with PACKET_LOOPBACK in netdev family too. For ipv4,
convert it to PACKET_BROADCAST/MULTICAST according to the destination
address's type; For ipv6, convert it to PACKET_MULTICAST directly.
Signed-off-by: Liping Zhang <zlpnobody@gmail.com>
