path: root/net
2020-05-21Merge remote-tracking branch 'remotes/fslc/4.9-2.3.x-imx' into ↵Marcel Ziswiler
toradex_4.9-2.3.x-imx-next Conflicts: sound/soc/codecs/sgtl5000.c sound/soc/fsl/imx-sgtl5000.c
2020-05-19Merge tag 'v4.9.220' into 4.9-2.3.x-imxMarcel Ziswiler
This is the 4.9.220 stable release Conflicts: arch/arm/Kconfig.debug arch/arm/boot/dts/imx7s.dtsi arch/arm/mach-imx/common.h arch/arm/mach-imx/cpuidle-imx6q.c arch/arm/mach-imx/cpuidle-imx6sx.c arch/arm/mach-imx/suspend-imx6.S block/blk-core.c drivers/crypto/caam/caamalg.c drivers/crypto/mxs-dcp.c drivers/dma/imx-sdma.c drivers/gpu/drm/bridge/adv7511/adv7511_drv.c drivers/input/keyboard/imx_keypad.c drivers/input/keyboard/snvs_pwrkey.c drivers/mmc/host/sdhci.c drivers/net/can/flexcan.c drivers/net/ethernet/freescale/fec_main.c drivers/net/phy/phy_device.c drivers/net/wireless/ath/ath10k/pci.c drivers/tty/serial/imx.c drivers/usb/dwc3/gadget.c drivers/usb/host/xhci.c include/linux/blkdev.h include/linux/cpu.h include/linux/platform_data/dma-imx-sdma.h kernel/cpu.c net/wireless/util.c sound/soc/fsl/Kconfig sound/soc/fsl/fsl_esai.c sound/soc/fsl/fsl_sai.c sound/soc/fsl/imx-sgtl5000.c
2020-05-14wireless: make wireless_ext and wext_priv storableOleksandr Suvorov
The config option WIRELESS_EXT and WEXT_PRIV use to build external drivers, such as backports. Make these options storable in config file to be able to set them independently. Related-to: ELB-2388 Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2020-04-24net: qrtr: send msgs from local of same id as broadcastWang Wenhu
[ Upstream commit 6dbf02acef69b0742c238574583b3068afbd227c ] If the local node id(qrtr_local_nid) is not modified after its initialization, it equals to the broadcast node id(QRTR_NODE_BCAST). So the messages from local node should not be taken as broadcast and keep the process going to send them out anyway. The definitions are as follow: static unsigned int qrtr_local_nid = NUMA_NO_NODE; Fixes: fdf5fd397566 ("net: qrtr: Broadcast messages only from control port") Signed-off-by: Wang Wenhu <wenhu.wang@vivo.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-04-24net: ipv4: devinet: Fix crash when add/del multicast IP with autojoinTaras Chornyi
[ Upstream commit 690cc86321eb9bcee371710252742fb16fe96824 ] When CONFIG_IP_MULTICAST is not set and multicast ip is added to the device with autojoin flag or when multicast ip is deleted kernel will crash. steps to reproduce: ip addr add 224.0.0.0/32 dev eth0 ip addr del 224.0.0.0/32 dev eth0 or ip addr add 224.0.0.0/32 dev eth0 autojoin Unable to handle kernel NULL pointer dereference at virtual address 0000000000000088 pc : _raw_write_lock_irqsave+0x1e0/0x2ac lr : lock_sock_nested+0x1c/0x60 Call trace: _raw_write_lock_irqsave+0x1e0/0x2ac lock_sock_nested+0x1c/0x60 ip_mc_config.isra.28+0x50/0xe0 inet_rtm_deladdr+0x1a8/0x1f0 rtnetlink_rcv_msg+0x120/0x350 netlink_rcv_skb+0x58/0x120 rtnetlink_rcv+0x14/0x20 netlink_unicast+0x1b8/0x270 netlink_sendmsg+0x1a0/0x3b0 ____sys_sendmsg+0x248/0x290 ___sys_sendmsg+0x80/0xc0 __sys_sendmsg+0x68/0xc0 __arm64_sys_sendmsg+0x20/0x30 el0_svc_common.constprop.2+0x88/0x150 do_el0_svc+0x20/0x80 el0_sync_handler+0x118/0x190 el0_sync+0x140/0x180 Fixes: 93a714d6b53d ("multicast: Extend ip address command to enable multicast group join/leave on") Signed-off-by: Taras Chornyi <taras.chornyi@plvision.eu> Signed-off-by: Vadym Kochan <vadym.kochan@plvision.eu> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-04-24hsr: check protocol version in hsr_newlink()Taehee Yoo
[ Upstream commit 4faab8c446def7667adf1f722456c2f4c304069c ] In the current hsr code, only 0 and 1 protocol versions are valid. But current hsr code doesn't check the version, which is received by userspace. Test commands: ip link add dummy0 type dummy ip link add dummy1 type dummy ip link add hsr0 type hsr slave1 dummy0 slave2 dummy1 version 4 In the test commands, version 4 is invalid. So, the command should be failed. After this patch, following error will occur. "Error: hsr: Only versions 0..1 are supported." Fixes: ee1c27977284 ("net/hsr: Added support for HSR v1") Signed-off-by: Taehee Yoo <ap420073@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-04-13Bluetooth: RFCOMM: fix ODEBUG bug in rfcomm_dev_ioctlQiujun Huang
commit 71811cac8532b2387b3414f7cd8fe9e497482864 upstream. Needn't call 'rfcomm_dlc_put' here, because 'rfcomm_dlc_exists' didn't increase dlc->refcnt. Reported-by: syzbot+4496e82090657320efc6@syzkaller.appspotmail.com Signed-off-by: Qiujun Huang <hqjagain@gmail.com> Suggested-by: Hillf Danton <hdanton@sina.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-04-13net: dsa: tag_brcm: Fix skb->fwd_offload_mark locationFlorian Fainelli
When the backport of upstream commit 0e62f543bed03a64495bd2651d4fe1aa4bcb7fe5 ("net: dsa: Fix duplicate frames flooded by learning") was done the assignment of skb->fwd_offload_mark would land in brcm_tag_xmit() which is incorrect, it should have been in brcm_tag_rcv(). Fixes: 5e845dc62f38 ("net: dsa: Fix duplicate frames flooded by learning") Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-04-13sctp: fix possibly using a bad saddr with a given dstMarcelo Ricardo Leitner
[ Upstream commit 582eea230536a6f104097dd46205822005d5fe3a ] Under certain circumstances, depending on the order of addresses on the interfaces, it could be that sctp_v[46]_get_dst() would return a dst with a mismatched struct flowi. For example, if when walking through the bind addresses and the first one is not a match, it saves the dst as a fallback (added in 410f03831c07), but not the flowi. Then if the next one is also not a match, the previous dst will be returned but with the flowi information for the 2nd address, which is wrong. The fix is to use a locally stored flowi that can be used for such attempts, and copy it to the parameter only in case it is a possible match, together with the corresponding dst entry. The patch updates IPv6 code mostly just to be in sync. Even though the issue is also present there, it fallback is not expected to work with IPv6. Fixes: 410f03831c07 ("sctp: add routing output fallback") Reported-by: Jin Meng <meng.a.jin@nokia-sbell.com> Signed-off-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com> Tested-by: Xin Long <lucien.xin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-04-13sctp: fix refcount bug in sctp_wfreeQiujun Huang
[ Upstream commit 5c3e82fe159622e46e91458c1a6509c321a62820 ] We should iterate over the datamsgs to move all chunks(skbs) to newsk. The following case cause the bug: for the trouble SKB, it was in outq->transmitted list sctp_outq_sack sctp_check_transmitted SKB was moved to outq->sacked list then throw away the sack queue SKB was deleted from outq->sacked (but it was held by datamsg at sctp_datamsg_to_asoc So, sctp_wfree was not called here) then migrate happened sctp_for_each_tx_datachunk( sctp_clear_owner_w); sctp_assoc_migrate(); sctp_for_each_tx_datachunk( sctp_set_owner_w); SKB was not in the outq, and was not changed to newsk finally __sctp_outq_teardown sctp_chunk_put (for another skb) sctp_datamsg_put __kfree_skb(msg->frag_list) sctp_wfree (for SKB) SKB->sk was still oldsk (skb->sk != asoc->base.sk). Reported-and-tested-by: syzbot+cea71eec5d6de256d54d@syzkaller.appspotmail.com Signed-off-by: Qiujun Huang <hqjagain@gmail.com> Acked-by: Marcelo Ricardo Leitner <mleitner@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-04-13net, ip_tunnel: fix interface lookup with no keyWilliam Dauchy
[ Upstream commit 25629fdaff2ff509dd0b3f5ff93d70a75e79e0a1 ] when creating a new ipip interface with no local/remote configuration, the lookup is done with TUNNEL_NO_KEY flag, making it impossible to match the new interface (only possible match being fallback or metada case interface); e.g: `ip link add tunl1 type ipip dev eth0` To fix this case, adding a flag check before the key comparison so we permit to match an interface with no local/remote config; it also avoids breaking possible userland tools relying on TUNNEL_NO_KEY flag and uninitialised key. context being on my side, I'm creating an extra ipip interface attached to the physical one, and moving it to a dedicated namespace. Fixes: c54419321455 ("GRE: Refactor GRE tunneling code.") Signed-off-by: William Dauchy <w.dauchy@criteo.com> Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-04-13ipv4: fix a RCU-list lock in fib_triestat_seq_showQian Cai
[ Upstream commit fbe4e0c1b298b4665ee6915266c9d6c5b934ef4a ] fib_triestat_seq_show() calls hlist_for_each_entry_rcu(tb, head, tb_hlist) without rcu_read_lock() will trigger a warning, net/ipv4/fib_trie.c:2579 RCU-list traversed in non-reader section!! other info that might help us debug this: rcu_scheduler_active = 2, debug_locks = 1 1 lock held by proc01/115277: #0: c0000014507acf00 (&p->lock){+.+.}-{3:3}, at: seq_read+0x58/0x670 Call Trace: dump_stack+0xf4/0x164 (unreliable) lockdep_rcu_suspicious+0x140/0x164 fib_triestat_seq_show+0x750/0x880 seq_read+0x1a0/0x670 proc_reg_read+0x10c/0x1b0 __vfs_read+0x3c/0x70 vfs_read+0xac/0x170 ksys_read+0x7c/0x140 system_call+0x5c/0x68 Fix it by adding a pair of rcu_read_lock/unlock() and use cond_resched_rcu() to avoid the situation where walking of a large number of items may prevent scheduling for a long time. Signed-off-by: Qian Cai <cai@lca.pw> Reviewed-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-04-13l2tp: fix race between l2tp_session_delete() and l2tp_tunnel_closeall()Guillaume Nault
commit b228a94066406b6c456321d69643b0d7ce11cfa6 upstream. There are several ways to remove L2TP sessions: * deleting a session explicitly using the netlink interface (with L2TP_CMD_SESSION_DELETE), * deleting the session's parent tunnel (either by closing the tunnel's file descriptor or using the netlink interface), * closing the PPPOL2TP file descriptor of a PPP pseudo-wire. In some cases, when these methods are used concurrently on the same session, the session can be removed twice, leading to use-after-free bugs. This patch adds a 'dead' flag, used by l2tp_session_delete() and l2tp_tunnel_closeall() to prevent them from stepping on each other's toes. The session deletion path used when closing a PPPOL2TP file descriptor doesn't need to be adapted. It already has to ensure that a session remains valid for the lifetime of its PPPOL2TP file descriptor. So it takes an extra reference on the session in the ->session_close() callback (pppol2tp_session_close()), which is eventually dropped in the ->sk_destruct() callback of the PPPOL2TP socket (pppol2tp_session_destruct()). Still, __l2tp_session_unhash() and l2tp_session_queue_purge() can be called twice and even concurrently for a given session, but thanks to proper locking and re-initialisation of list fields, this is not an issue. Signed-off-by: Guillaume Nault <g.nault@alphalink.fr> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Will Deacon <will@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-04-13l2tp: ensure sessions are freed after their PPPOL2TP socketGuillaume Nault
commit cdd10c9627496ad25c87ce6394e29752253c69d3 upstream. If l2tp_tunnel_delete() or l2tp_tunnel_closeall() deletes a session right after pppol2tp_release() orphaned its socket, then the 'sock' variable of the pppol2tp_session_close() callback is NULL. Yet the session is still used by pppol2tp_release(). Therefore we need to take an extra reference in any case, to prevent l2tp_tunnel_delete() or l2tp_tunnel_closeall() from freeing the session. Since the pppol2tp_session_close() callback is only set if the session is associated to a PPPOL2TP socket and that both l2tp_tunnel_delete() and l2tp_tunnel_closeall() hold the PPPOL2TP socket before calling pppol2tp_session_close(), we're sure that pppol2tp_session_close() and pppol2tp_session_destruct() are paired and called in the right order. So the reference taken by the former will be released by the later. Signed-off-by: Guillaume Nault <g.nault@alphalink.fr> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Will Deacon <will@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-04-02mac80211: fix authentication with iwlwifi/mvmJohannes Berg
commit be8c827f50a0bcd56361b31ada11dc0a3c2fd240 upstream. The original patch didn't copy the ieee80211_is_data() condition because on most drivers the management frames don't go through this path. However, they do on iwlwifi/mvm, so we do need to keep the condition here. Cc: stable@vger.kernel.org Fixes: ce2e1ca70307 ("mac80211: Check port authorization in the ieee80211_tx_dequeue() case") Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Woody Suwalski <terraluna977@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-04-02mac80211: Check port authorization in the ieee80211_tx_dequeue() caseJouni Malinen
commit ce2e1ca703071723ca2dd94d492a5ab6d15050da upstream. mac80211 used to check port authorization in the Data frame enqueue case when going through start_xmit(). However, that authorization status may change while the frame is waiting in a queue. Add a similar check in the dequeue case to avoid sending previously accepted frames after authorization change. This provides additional protection against potential leaking of frames after a station has been disconnected and the keys for it are being removed. Cc: stable@vger.kernel.org Signed-off-by: Jouni Malinen <jouni@codeaurora.org> Link: https://lore.kernel.org/r/20200326155133.ced84317ea29.I34d4c47cd8cc8a4042b38a76f16a601fbcbfd9b3@changeid Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-04-02vti6: Fix memory leak of skb if input policy check failsTorsten Hilbrich
commit 2a9de3af21aa8c31cd68b0b39330d69f8c1e59df upstream. The vti6_rcv function performs some tests on the retrieved tunnel including checking the IP protocol, the XFRM input policy, the source and destination address. In all but one places the skb is released in the error case. When the input policy check fails the network packet is leaked. Using the same goto-label discard in this case to fix this problem. Fixes: ed1efb2aefbb ("ipv6: Add support for IPsec virtual tunnel interfaces") Signed-off-by: Torsten Hilbrich <torsten.hilbrich@secunet.com> Reviewed-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-04-02netfilter: nft_fwd_netdev: validate family and chain typePablo Neira Ayuso
commit 76a109fac206e158eb3c967af98c178cff738e6a upstream. Make sure the forward action is only used from ingress. Fixes: 39e6dea28adc ("netfilter: nf_tables: add forward expression to the netdev family") Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-04-02xfrm: policy: Fix doulbe free in xfrm_policy_timerYueHaibing
commit 4c59406ed00379c8663f8663d82b2537467ce9d7 upstream. After xfrm_add_policy add a policy, its ref is 2, then xfrm_policy_timer read_lock xp->walk.dead is 0 .... mod_timer() xfrm_policy_kill policy->walk.dead = 1 .... del_timer(&policy->timer) xfrm_pol_put //ref is 1 xfrm_pol_put //ref is 0 xfrm_policy_destroy call_rcu xfrm_pol_hold //ref is 1 read_unlock xfrm_pol_put //ref is 0 xfrm_policy_destroy call_rcu xfrm_policy_destroy is called twice, which may leads to double free. Call Trace: RIP: 0010:refcount_warn_saturate+0x161/0x210 ... xfrm_policy_timer+0x522/0x600 call_timer_fn+0x1b3/0x5e0 ? __xfrm_decode_session+0x2990/0x2990 ? msleep+0xb0/0xb0 ? _raw_spin_unlock_irq+0x24/0x40 ? __xfrm_decode_session+0x2990/0x2990 ? __xfrm_decode_session+0x2990/0x2990 run_timer_softirq+0x5c5/0x10e0 Fix this by use write_lock_bh in xfrm_policy_kill. Fixes: ea2dea9dacc2 ("xfrm: remove policy lock when accessing policy->walk.dead") Signed-off-by: YueHaibing <yuehaibing@huawei.com> Acked-by: Timo Teräs <timo.teras@iki.fi> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-04-02xfrm: add the missing verify_sec_ctx_len check in xfrm_add_acquireXin Long
commit a1a7e3a36e01ca6e67014f8cf673cb8e47be5550 upstream. Without doing verify_sec_ctx_len() check in xfrm_add_acquire(), it may be out-of-bounds to access uctx->ctx_str with uctx->ctx_len, as noticed by syz: BUG: KASAN: slab-out-of-bounds in selinux_xfrm_alloc_user+0x237/0x430 Read of size 768 at addr ffff8880123be9b4 by task syz-executor.1/11650 Call Trace: dump_stack+0xe8/0x16e print_address_description.cold.3+0x9/0x23b kasan_report.cold.4+0x64/0x95 memcpy+0x1f/0x50 selinux_xfrm_alloc_user+0x237/0x430 security_xfrm_policy_alloc+0x5c/0xb0 xfrm_policy_construct+0x2b1/0x650 xfrm_add_acquire+0x21d/0xa10 xfrm_user_rcv_msg+0x431/0x6f0 netlink_rcv_skb+0x15a/0x410 xfrm_netlink_rcv+0x6d/0x90 netlink_unicast+0x50e/0x6a0 netlink_sendmsg+0x8ae/0xd40 sock_sendmsg+0x133/0x170 ___sys_sendmsg+0x834/0x9a0 __sys_sendmsg+0x100/0x1e0 do_syscall_64+0xe5/0x660 entry_SYSCALL_64_after_hwframe+0x6a/0xdf So fix it by adding the missing verify_sec_ctx_len check there. Fixes: 980ebd25794f ("[IPSEC]: Sync series - acquire insert") Reported-by: Hangbin Liu <liuhangbin@gmail.com> Signed-off-by: Xin Long <lucien.xin@gmail.com> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-04-02xfrm: fix uctx len check in verify_sec_ctx_lenXin Long
commit 171d449a028573b2f0acdc7f31ecbb045391b320 upstream. It's not sufficient to do 'uctx->len != (sizeof(struct xfrm_user_sec_ctx) + uctx->ctx_len)' check only, as uctx->len may be greater than nla_len(rt), in which case it will cause slab-out-of-bounds when accessing uctx->ctx_str later. This patch is to fix it by return -EINVAL when uctx->len > nla_len(rt). Fixes: df71837d5024 ("[LSM-IPSec]: Security association restriction.") Signed-off-by: Xin Long <lucien.xin@gmail.com> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-04-02vti[6]: fix packet tx through bpf_redirect() in XinY casesNicolas Dichtel
commit f1ed10264ed6b66b9cd5e8461cffce69be482356 upstream. I forgot the 4in6/6in4 cases in my previous patch. Let's fix them. Fixes: 95224166a903 ("vti[6]: fix packet tx through bpf_redirect()") Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-04-02mac80211: mark station unauthorized before key removalJohannes Berg
commit b16798f5b907733966fd1a558fca823b3c67e4a1 upstream. If a station is still marked as authorized, mark it as no longer so before removing its keys. This allows frames transmitted to it to be rejected, providing additional protection against leaking plain text data during the disconnection flow. Cc: stable@vger.kernel.org Link: https://lore.kernel.org/r/20200326155133.ccb4fb0bb356.If48f0f0504efdcf16b8921f48c6d3bb2cb763c99@changeid Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-04-02mac80211: Do not send mesh HWMP PREQ if HWMP is disabledNicolas Cavallari
[ Upstream commit ba32679cac50c38fdf488296f96b1f3175532b8e ] When trying to transmit to an unknown destination, the mesh code would unconditionally transmit a HWMP PREQ even if HWMP is not the current path selection algorithm. Signed-off-by: Nicolas Cavallari <nicolas.cavallari@green-communications.fr> Link: https://lore.kernel.org/r/20200305140409.12204-1-cavallar@lri.fr Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2020-04-02net: ipv4: don't let PMTU updates increase route MTUSabrina Dubroca
[ Upstream commit 28d35bcdd3925e7293408cdb8aa5f2aac5f0d6e3 ] When an MTU update with PMTU smaller than net.ipv4.route.min_pmtu is received, we must clamp its value. However, we can receive a PMTU exception with PMTU < old_mtu < ip_rt_min_pmtu, which would lead to an increase in PMTU. To fix this, take the smallest of the old MTU and ip_rt_min_pmtu. Before this patch, in case of an update, the exception's MTU would always change. Now, an exception can have only its lock flag updated, but not the MTU, so we need to add a check on locking to the following "is this exception getting updated, or close to expiring?" test. Fixes: d52e5a7e7ca4 ("ipv4: lock mtu in fnhe when received PMTU < net.ipv4.route.min_pmtu") Signed-off-by: Sabrina Dubroca <sd@queasysnail.net> Reviewed-by: Stefano Brivio <sbrivio@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sashal@kernel.org>
2020-04-02hsr: set .netnsok flagTaehee Yoo
[ Upstream commit 09e91dbea0aa32be02d8877bd50490813de56b9a ] The hsr module has been supporting the list and status command. (HSR_C_GET_NODE_LIST and HSR_C_GET_NODE_STATUS) These commands send node information to the user-space via generic netlink. But, in the non-init_net namespace, these commands are not allowed because .netnsok flag is false. So, there is no way to get node information in the non-init_net namespace. Fixes: f421436a591d ("net/hsr: Add support for the High-availability Seamless Redundancy protocol (HSRv0)") Signed-off-by: Taehee Yoo <ap420073@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-04-02hsr: add restart routine into hsr_get_node_list()Taehee Yoo
[ Upstream commit ca19c70f5225771c05bcdcb832b4eb84d7271c5e ] The hsr_get_node_list() is to send node addresses to the userspace. If there are so many nodes, it could fail because of buffer size. In order to avoid this failure, the restart routine is added. Fixes: f421436a591d ("net/hsr: Add support for the High-availability Seamless Redundancy protocol (HSRv0)") Signed-off-by: Taehee Yoo <ap420073@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-04-02hsr: use rcu_read_lock() in hsr_get_node_{list/status}()Taehee Yoo
[ Upstream commit 173756b86803655d70af7732079b3aa935e6ab68 ] hsr_get_node_{list/status}() are not under rtnl_lock() because they are callback functions of generic netlink. But they use __dev_get_by_index() without rtnl_lock(). So, it would use unsafe data. In order to fix it, rcu_read_lock() and dev_get_by_index_rcu() are used instead of __dev_get_by_index(). Fixes: f421436a591d ("net/hsr: Add support for the High-availability Seamless Redundancy protocol (HSRv0)") Signed-off-by: Taehee Yoo <ap420073@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-04-02net_sched: keep alloc_hash updated after hash allocationCong Wang
[ Upstream commit 0d1c3530e1bd38382edef72591b78e877e0edcd3 ] In commit 599be01ee567 ("net_sched: fix an OOB access in cls_tcindex") I moved cp->hash calculation before the first tcindex_alloc_perfect_hash(), but cp->alloc_hash is left untouched. This difference could lead to another out of bound access. cp->alloc_hash should always be the size allocated, we should update it after this tcindex_alloc_perfect_hash(). Reported-and-tested-by: syzbot+dcc34d54d68ef7d2d53d@syzkaller.appspotmail.com Reported-and-tested-by: syzbot+c72da7b9ed57cde6fca2@syzkaller.appspotmail.com Fixes: 599be01ee567 ("net_sched: fix an OOB access in cls_tcindex") Cc: Jamal Hadi Salim <jhs@mojatatu.com> Cc: Jiri Pirko <jiri@resnulli.us> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-04-02net_sched: cls_route: remove the right filter from hashtableCong Wang
[ Upstream commit ef299cc3fa1a9e1288665a9fdc8bff55629fd359 ] route4_change() allocates a new filter and copies values from the old one. After the new filter is inserted into the hash table, the old filter should be removed and freed, as the final step of the update. However, the current code mistakenly removes the new one. This looks apparently wrong to me, and it causes double "free" and use-after-free too, as reported by syzbot. Reported-and-tested-by: syzbot+f9b32aaacd60305d9687@syzkaller.appspotmail.com Reported-and-tested-by: syzbot+2f8c233f131943d6056d@syzkaller.appspotmail.com Reported-and-tested-by: syzbot+9c2df9fd5e9445b74e01@syzkaller.appspotmail.com Fixes: 1109c00547fc ("net: sched: RCU cls_route") Cc: Jamal Hadi Salim <jhs@mojatatu.com> Cc: Jiri Pirko <jiri@resnulli.us> Cc: John Fastabend <john.fastabend@gmail.com> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-04-02net: dsa: Fix duplicate frames flooded by learningFlorian Fainelli
[ Upstream commit 0e62f543bed03a64495bd2651d4fe1aa4bcb7fe5 ] When both the switch and the bridge are learning about new addresses, switch ports attached to the bridge would see duplicate ARP frames because both entities would attempt to send them. Fixes: 5037d532b83d ("net: dsa: add Broadcom tag RX/TX handler") Reported-by: Maxime Bizon <mbizon@freebox.fr> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Reviewed-by: Vivien Didelot <vivien.didelot@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-04-02hsr: fix general protection fault in hsr_addr_is_self()Taehee Yoo
[ Upstream commit 3a303cfdd28d5f930a307c82e8a9d996394d5ebd ] The port->hsr is used in the hsr_handle_frame(), which is a callback of rx_handler. hsr master and slaves are initialized in hsr_add_port(). This function initializes several pointers, which includes port->hsr after registering rx_handler. So, in the rx_handler routine, un-initialized pointer would be used. In order to fix this, pointers should be initialized before registering rx_handler. Test commands: ip netns del left ip netns del right modprobe -rv veth modprobe -rv hsr killall ping modprobe hsr ip netns add left ip netns add right ip link add veth0 type veth peer name veth1 ip link add veth2 type veth peer name veth3 ip link add veth4 type veth peer name veth5 ip link set veth1 netns left ip link set veth3 netns right ip link set veth4 netns left ip link set veth5 netns right ip link set veth0 up ip link set veth2 up ip link set veth0 address fc:00:00:00:00:01 ip link set veth2 address fc:00:00:00:00:02 ip netns exec left ip link set veth1 up ip netns exec left ip link set veth4 up ip netns exec right ip link set veth3 up ip netns exec right ip link set veth5 up ip link add hsr0 type hsr slave1 veth0 slave2 veth2 ip a a 192.168.100.1/24 dev hsr0 ip link set hsr0 up ip netns exec left ip link add hsr1 type hsr slave1 veth1 slave2 veth4 ip netns exec left ip a a 192.168.100.2/24 dev hsr1 ip netns exec left ip link set hsr1 up ip netns exec left ip n a 192.168.100.1 dev hsr1 lladdr \ fc:00:00:00:00:01 nud permanent ip netns exec left ip n r 192.168.100.1 dev hsr1 lladdr \ fc:00:00:00:00:01 nud permanent for i in {1..100} do ip netns exec left ping 192.168.100.1 & done ip netns exec left hping3 192.168.100.1 -2 --flood & ip netns exec right ip link add hsr2 type hsr slave1 veth3 slave2 veth5 ip netns exec right ip a a 192.168.100.3/24 dev hsr2 ip netns exec right ip link set hsr2 up ip netns exec right ip n a 192.168.100.1 dev hsr2 lladdr \ fc:00:00:00:00:02 nud permanent ip netns exec right ip n r 192.168.100.1 dev hsr2 lladdr \ fc:00:00:00:00:02 nud permanent for i in {1..100} do ip netns exec right ping 192.168.100.1 & done ip netns exec right hping3 192.168.100.1 -2 --flood & while : do ip link add hsr0 type hsr slave1 veth0 slave2 veth2 ip a a 192.168.100.1/24 dev hsr0 ip link set hsr0 up ip link del hsr0 done Splat looks like: [ 120.954938][ C0] general protection fault, probably for non-canonical address 0xdffffc0000000006: 0000 [#1]I [ 120.957761][ C0] KASAN: null-ptr-deref in range [0x0000000000000030-0x0000000000000037] [ 120.959064][ C0] CPU: 0 PID: 1511 Comm: hping3 Not tainted 5.6.0-rc5+ #460 [ 120.960054][ C0] Hardware name: innotek GmbH VirtualBox/VirtualBox, BIOS VirtualBox 12/01/2006 [ 120.962261][ C0] RIP: 0010:hsr_addr_is_self+0x65/0x2a0 [hsr] [ 120.963149][ C0] Code: 44 24 18 70 73 2f c0 48 c1 eb 03 48 8d 04 13 c7 00 f1 f1 f1 f1 c7 40 04 00 f2 f2 f2 4 [ 120.966277][ C0] RSP: 0018:ffff8880d9c09af0 EFLAGS: 00010206 [ 120.967293][ C0] RAX: 0000000000000006 RBX: 1ffff1101b38135f RCX: 0000000000000000 [ 120.968516][ C0] RDX: dffffc0000000000 RSI: ffff8880d17cb208 RDI: 0000000000000000 [ 120.969718][ C0] RBP: 0000000000000030 R08: ffffed101b3c0e3c R09: 0000000000000001 [ 120.972203][ C0] R10: 0000000000000001 R11: ffffed101b3c0e3b R12: 0000000000000000 [ 120.973379][ C0] R13: ffff8880aaf80100 R14: ffff8880aaf800f2 R15: ffff8880aaf80040 [ 120.974410][ C0] FS: 00007f58e693f740(0000) GS:ffff8880d9c00000(0000) knlGS:0000000000000000 [ 120.979794][ C0] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 120.980773][ C0] CR2: 00007ffcb8b38f29 CR3: 00000000afe8e001 CR4: 00000000000606f0 [ 120.981945][ C0] Call Trace: [ 120.982411][ C0] <IRQ> [ 120.982848][ C0] ? hsr_add_node+0x8c0/0x8c0 [hsr] [ 120.983522][ C0] ? rcu_read_lock_held+0x90/0xa0 [ 120.984159][ C0] ? rcu_read_lock_sched_held+0xc0/0xc0 [ 120.984944][ C0] hsr_handle_frame+0x1db/0x4e0 [hsr] [ 120.985597][ C0] ? hsr_nl_nodedown+0x2b0/0x2b0 [hsr] [ 120.986289][ C0] __netif_receive_skb_core+0x6bf/0x3170 [ 120.992513][ C0] ? check_chain_key+0x236/0x5d0 [ 120.993223][ C0] ? do_xdp_generic+0x1460/0x1460 [ 120.993875][ C0] ? register_lock_class+0x14d0/0x14d0 [ 120.994609][ C0] ? __netif_receive_skb_one_core+0x8d/0x160 [ 120.995377][ C0] __netif_receive_skb_one_core+0x8d/0x160 [ 120.996204][ C0] ? __netif_receive_skb_core+0x3170/0x3170 [ ... ] Reported-by: syzbot+fcf5dd39282ceb27108d@syzkaller.appspotmail.com Fixes: c5a759117210 ("net/hsr: Use list_head (and rcu) instead of array for slave devices.") Signed-off-by: Taehee Yoo <ap420073@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-03-20ipv4: ensure rcu_read_lock() in cipso_v4_error()Matteo Croce
commit 3e72dfdf8227b052393f71d820ec7599909dddc2 upstream. Similarly to commit c543cb4a5f07 ("ipv4: ensure rcu_read_lock() in ipv4_link_failure()"), __ip_options_compile() must be called under rcu protection. Fixes: 3da1ed7ac398 ("net: avoid use IPCB in cipso_v4_error") Suggested-by: Guillaume Nault <gnault@redhat.com> Signed-off-by: Matteo Croce <mcroce@redhat.com> Acked-by: Paul Moore <paul@paul-moore.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-03-20mac80211: rx: avoid RCU list traversal under mutexMadhuparna Bhowmik
[ Upstream commit 253216ffb2a002a682c6f68bd3adff5b98b71de8 ] local->sta_mtx is held in __ieee80211_check_fast_rx_iface(). No need to use list_for_each_entry_rcu() as it also requires a cond argument to avoid false lockdep warnings when not used in RCU read-side section (with CONFIG_PROVE_RCU_LIST). Therefore use list_for_each_entry(); Signed-off-by: Madhuparna Bhowmik <madhuparnabhowmik10@gmail.com> Link: https://lore.kernel.org/r/20200223143302.15390-1-madhuparnabhowmik10@gmail.com Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2020-03-20cfg80211: check reg_rule for NULL in handle_channel_custom()Johannes Berg
[ Upstream commit a7ee7d44b57c9ae174088e53a668852b7f4f452d ] We may end up with a NULL reg_rule after the loop in handle_channel_custom() if the bandwidth didn't fit, check if this is the case and bail out if so. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Link: https://lore.kernel.org/r/20200221104449.3b558a50201c.I4ad3725c4dacaefd2d18d3cc65ba6d18acd5dbfe@changeid Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2020-03-20batman-adv: Use explicit tvlv padding for ELP packetsSven Eckelmann
commit f4156f9656feac21f4de712fac94fae964c5d402 upstream. The announcement messages of batman-adv COMPAT_VERSION 15 have the possibility to announce additional information via a dynamic TVLV part. This part is optional for the ELP packets and currently not parsed by the Linux implementation. Still out-of-tree versions are using it to transport things like neighbor hashes to optimize the rebroadcast behavior. Since the ELP broadcast packets are smaller than the minimal ethernet packet, it often has to be padded. This is often done (as specified in RFC894) with octets of zero and thus work perfectly fine with the TVLV part (making it a zero length and thus empty). But not all ethernet compatible hardware seems to follow this advice. To avoid ambiguous situations when parsing the TVLV header, just force the 4 bytes (TVLV length + padding) after the required ELP header to zero. Fixes: d6f94d91f766 ("batman-adv: ELP - adding basic infrastructure") Reported-by: Linus Lüssing <linus.luessing@c0d3.blue> Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-03-20batman-adv: Avoid probe ELP information leakSven Eckelmann
commit 88d0895d0ea9d4431507d576c963f2ff9918144d upstream. The probe ELPs for WiFi interfaces are expanded to contain at least BATADV_ELP_MIN_PROBE_SIZE bytes. This is usually a lot more than the number of bytes which the template ELP packet requires. These extra padding bytes were not initialized and thus could contain data which were previously stored at the same location. It is therefore required to set it to some predefined or random values to avoid leaking private information from the system transmitting these kind of packets. Fixes: e4623c913508 ("batman-adv: Avoid probe ELP information leak") Signed-off-by: Sven Eckelmann <sven@narfation.org> Acked-by: Antonio Quartulli <a@unstable.cc> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-03-20batman-adv: update data pointers after skb_cow()Matthias Schiffer
commit bc44b78157f621ff2a2618fe287a827bcb094ac4 upstream. batadv_check_unicast_ttvn() calls skb_cow(), so pointers into the SKB data must be (re)set after calling it. The ethhdr variable is dropped altogether. Fixes: 78fc6bbe0aca ("batman-adv: add UNICAST_4ADDR packet type") Signed-off-by: Matthias Schiffer <mschiffer@universe-factory.net> Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-03-20batman-adv: Don't schedule OGM for disabled interfaceSven Eckelmann
A transmission scheduling for an interface which is currently dropped by batadv_iv_ogm_iface_disable could still be in progress. The B.A.T.M.A.N. V is simply cancelling the workqueue item in an synchronous way but this is not possible with B.A.T.M.A.N. IV because the OGM submissions are intertwined. Instead it has to stop submitting the OGM when it detect that the buffer pointer is set to NULL. Reported-by: syzbot+a98f2016f40b9cd3818a@syzkaller.appspotmail.com Reported-by: syzbot+ac36b6a33c28a491e929@syzkaller.appspotmail.com Fixes: c6c8fea29769 ("net: Add batman-adv meshing protocol") Signed-off-by: Sven Eckelmann <sven@narfation.org> Cc: Hillf Danton <hdanton@sina.com> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-03-20batman-adv: Avoid free/alloc race when handling OGM bufferSven Eckelmann
commit 40e220b4218bb3d278e5e8cc04ccdfd1c7ff8307 upstream. Each slave interface of an B.A.T.M.A.N. IV virtual interface has an OGM packet buffer which is initialized using data from netdevice notifier and other rtnetlink related hooks. It is sent regularly via various slave interfaces of the batadv virtual interface and in this process also modified (realloced) to integrate additional state information via TVLV containers. It must be avoided that the worker item is executed without a common lock with the netdevice notifier/rtnetlink helpers. Otherwise it can either happen that half modified/freed data is sent out or functions modifying the OGM buffer try to access already freed memory regions. Reported-by: syzbot+0cc629f19ccb8534935b@syzkaller.appspotmail.com Fixes: c6c8fea29769 ("net: Add batman-adv meshing protocol") Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-03-20batman-adv: Avoid free/alloc race when handling OGM2 bufferSven Eckelmann
commit a8d23cbbf6c9f515ed678204ad2962be7c336344 upstream. A B.A.T.M.A.N. V virtual interface has an OGM2 packet buffer which is initialized using data from the netdevice notifier and other rtnetlink related hooks. It is sent regularly via various slave interfaces of the batadv virtual interface and in this process also modified (realloced) to integrate additional state information via TVLV containers. It must be avoided that the worker item is executed without a common lock with the netdevice notifier/rtnetlink helpers. Otherwise it can either happen that half modified data is sent out or the functions modifying the OGM2 buffer try to access already freed memory regions. Fixes: 0da0035942d4 ("batman-adv: OGMv2 - add basic infrastructure") Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-03-20batman-adv: Fix duplicated OGMs on NETDEV_UPSven Eckelmann
commit 9e6b5648bbc4cd48fab62cecbb81e9cc3c6e7e88 upstream. The state of slave interfaces are handled differently depending on whether the interface is up or not. All active interfaces (IFF_UP) will transmit OGMs. But for B.A.T.M.A.N. IV, also non-active interfaces are scheduling (low TTL) OGMs on active interfaces. The code which setups and schedules the OGMs must therefore already be called when the interfaces gets added as slave interface and the transmit function must then check whether it has to send out the OGM or not on the specific slave interface. But the commit f0d97253fb5f ("batman-adv: remove ogm_emit and ogm_schedule API calls") moved the setup code from the enable function to the activate function. The latter is called either when the added slave was already up when batadv_hardif_enable_interface processed the new interface or when a NETDEV_UP event was received for this slave interfac. As result, each NETDEV_UP would schedule a new OGM worker for the interface and thus OGMs would be send a lot more than expected. Fixes: f0d97253fb5f ("batman-adv: remove ogm_emit and ogm_schedule API calls") Reported-by: Linus Lüssing <linus.luessing@c0d3.blue> Tested-by: Linus Lüssing <linus.luessing@c0d3.blue> Acked-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-03-20batman-adv: Prevent duplicated gateway_node entrySven Eckelmann
commit dff9bc42ab0b2d38c5e90ddd79b238fed5b4c7ad upstream. The function batadv_gw_node_add is responsible for adding new gw_node to the gateway_list. It is expecting that the caller already checked that there is not already an entry with the same key or not. But the lock for the list is only held when the list is really modified. This could lead to duplicated entries because another context could create an entry with the same key between the check and the list manipulation. The check and the manipulation of the list must therefore be in the same locked code section. Fixes: c6c8fea29769 ("net: Add batman-adv meshing protocol") Signed-off-by: Sven Eckelmann <sven@narfation.org> Acked-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-03-20batman-adv: Fix multicast TT issues with bogus ROAM flagsLinus Lüssing
commit a44ebeff6bbd6ef50db41b4195fca87b21aefd20 upstream. When a (broken) node wrongly sends multicast TT entries with a ROAM flag then this causes any receiving node to drop all entries for the same multicast MAC address announced by other nodes, leading to packet loss. Fix this DoS vector by only storing TT sync flags. For multicast TT non-sync'ing flag bits like ROAM are unused so far anyway. Fixes: 1d8ab8d3c176 ("batman-adv: Modified forwarding behaviour for multicast packets") Reported-by: Leonardo Mörlein <me@irrelefant.net> Signed-off-by: Linus Lüssing <linus.luessing@c0d3.blue> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-03-20batman-adv: Avoid storing non-TT-sync flags on singular entries tooLinus Lüssing
commit 4a519b83da16927fb98fd32b0f598e639d1f1859 upstream. Since commit 54e22f265e87 ("batman-adv: fix TT sync flag inconsistencies") TT sync flags and TT non-sync'd flags are supposed to be stored separately. The previous patch missed to apply this separation on a TT entry with only a single TT orig entry. This is a minor fix because with only a single TT orig entry the DDoS issue the former patch solves does not apply. Fixes: 54e22f265e87 ("batman-adv: fix TT sync flag inconsistencies") Signed-off-by: Linus Lüssing <linus.luessing@c0d3.blue> Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-03-20batman-adv: Fix debugfs path for renamed softifSven Eckelmann
commit 6da7be7d24b2921f8215473ba7552796dff05fe1 upstream. batman-adv is creating special debugfs directories in the init net_namespace for each created soft-interface (batadv net_device). But it is possible to rename a net_device to a completely different name then the original one. It can therefore happen that a user registers a new batadv net_device with the name "bat0". batman-adv is then also adding a new directory under $debugfs/batman-adv/ with the name "wlan0". The user then decides to rename this device to "bat1" and registers a different batadv device with the name "bat0". batman-adv will then try to create a directory with the name "bat0" under $debugfs/batman-adv/ again. But there already exists one with this name under this path and thus this fails. batman-adv will detect a problem and rollback the registering of this device. batman-adv must therefore take care of renaming the debugfs directories for soft-interfaces whenever it detects such a net_device rename. Fixes: c6c8fea29769 ("net: Add batman-adv meshing protocol") Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-03-20batman-adv: Fix debugfs path for renamed hardifSven Eckelmann
commit 36dc621ceca1be3ec885aeade5fdafbbcc452a6d upstream. batman-adv is creating special debugfs directories in the init net_namespace for each valid hard-interface (net_device). But it is possible to rename a net_device to a completely different name then the original one. It can therefore happen that a user registers a new net_device which gets the name "wlan0" assigned by default. batman-adv is also adding a new directory under $debugfs/batman-adv/ with the name "wlan0". The user then decides to rename this device to "wl_pri" and registers a different device. The kernel may now decide to use the name "wlan0" again for this new device. batman-adv will detect it as a valid net_device and tries to create a directory with the name "wlan0" under $debugfs/batman-adv/. But there already exists one with this name under this path and thus this fails. batman-adv will detect a problem and rollback the registering of this device. batman-adv must therefore take care of renaming the debugfs directories for hard-interfaces whenever it detects such a net_device rename. Fixes: 5bc7c1eb44f2 ("batman-adv: add debugfs structure for information per interface") Reported-by: John Soros <sorosj@gmail.com> Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-03-20batman-adv: prevent TT request storms by not sending inconsistent TT TLVLsMarek Lindner
commit 16116dac23396e73c01eeee97b102e4833a4b205 upstream. A translation table TVLV changset sent with an OGM consists of a number of headers (one per VLAN) plus the changeset itself (addition and/or deletion of entries). The per-VLAN headers are used by OGM recipients for consistency checks. Said consistency check might determine that a full translation table request is needed to restore consistency. If the TT sender adds per-VLAN headers of empty VLANs into the OGM, recipients are led to believe to have reached an inconsistent state and thus request a full table update. The full table does not contain empty VLANs (due to missing entries) the cycle restarts when the next OGM is issued. Consequently, when the translation table TVLV headers are composed, empty VLANs are to be excluded. Fixes: 21a57f6e7a3b ("batman-adv: make the TT CRC logic VLAN specific") Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-03-20batman-adv: Fix TT sync flags for intermediate TT responsesLinus Lüssing
commit 7072337e52b3e9d5460500d8dc9cbc1ba2db084c upstream. The previous TT sync fix so far only fixed TT responses issued by the target node directly. So far, TT responses issued by intermediate nodes still lead to the wrong flags being added, leading to CRC mismatches. This behaviour was observed at Freifunk Hannover in a 800 nodes setup where a considerable amount of nodes were still infected with 'WI' TT flags even with (most) nodes having the previous TT sync fix applied. I was able to reproduce the issue with intermediate TT responses in a four node test setup and this patch fixes this issue by ensuring to use the per originator instead of the summarized, OR'd ones. Fixes: e9c00136a475 ("batman-adv: fix tt_global_entries flags update") Reported-by: Leonardo Mörlein <me@irrelefant.net> Signed-off-by: Linus Lüssing <linus.luessing@c0d3.blue> Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-03-20batman-adv: Avoid race in TT TVLV allocator helperSven Eckelmann
commit 8ba0f9bd3bdea1058c2b2676bec7905724418e40 upstream. The functions batadv_tt_prepare_tvlv_local_data and batadv_tt_prepare_tvlv_global_data are responsible for preparing a buffer which can be used to store the TVLV container for TT and add the VLAN information to it. This will be done in three phases: 1. count the number of VLANs and their entries 2. allocate the buffer using the counters from the previous step and limits from the caller (parameter tt_len) 3. insert the VLAN information to the buffer The step 1 and 3 operate on a list which contains the VLANs. The access to these lists must be protected with an appropriate lock or otherwise they might operate on on different entries. This could for example happen when another context is adding VLAN entries to this list. This could lead to a buffer overflow in these functions when enough entries were added between step 1 and 3 to the VLAN lists that the buffer room for the entries (*tt_change) is smaller then the now required extra buffer for new VLAN entries. Fixes: 7ea7b4a14275 ("batman-adv: make the TT CRC logic VLAN specific") Signed-off-by: Sven Eckelmann <sven@narfation.org> Acked-by: Antonio Quartulli <a@unstable.cc> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
