path: root/net
2014-02-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking updates from David Miller: 1) Fix flexcan build on big endian, from Arnd Bergmann 2) Correctly attach cpsw to GPIO bitbang MDIO drive, from Stefan Roese 3) udp_add_offload has to use GFP_ATOMIC since it can be invoked from non-sleepable contexts. From Or Gerlitz 4) vxlan_gro_receive() does not iterate over all possible flows properly, fix also from Or Gerlitz 5) CAN core doesn't use a proper SKB destructor when it hooks up sockets to SKBs. Fix from Oliver Hartkopp 6) ip_tunnel_xmit() can use an uninitialized route pointer, fix from Eric Dumazet 7) Fix address family assignment in IPVS, from Michal Kubecek 8) Fix ath9k build on ARM, from Sujith Manoharan 9) Make sure fail_over_mac only applies for the correct bonding modes, from Ding Tianhong 10) The udp offload code doesn't use RCU correctly, from Shlomo Pongratz 11) Handle gigabit features properly in generic PHY code, from Florian Fainelli 12) Don't blindly invoke link operations in rtnl_link_get_slave_info_data_size, they are optional. Fix from Fernando Luis Vazquez Cao 13) Add USB IDs for Netgear Aircard 340U, from Bjørn Mork 14) Handle netlink packet padding properly in openvswitch, from Thomas Graf 15) Fix oops when deleting chains in nf_tables, from Patrick McHardy 16) Fix RX stalls in xen-netback driver, from Zoltan Kiss 17) Fix deadlock in mac80211 stack, from Emmanuel Grumbach 18) inet_nlmsg_size() forgets to consider ifa_cacheinfo, fix from Geert Uytterhoeven 19) tg3_change_mtu() can deadlock, fix from Nithin Sujir 20) Fix regression in setting SCTP local source addresses on accepted sockets, caused by some generic ipv6 socket changes. Fix from Matija Glavinic Pecotic 21) IPPROTO_* must be pure defines, otherwise module aliases don't get constructed properly. Fix from Jan Moskyto 22) IPV6 netconsole setup doesn't work properly unless an explicit source address is specified, fix from Sabrina Dubroca 23) Use __GFP_NORETRY for high order skb page allocations in sock_alloc_send_pskb and skb_page_frag_refill. From Eric Dumazet 24) Fix a regression added in netconsole over bridging, from Cong Wang 25) TCP uses an artificial offset of 1ms for SRTT, but this doesn't jive well with TCP pacing which needs the SRTT to be accurate. Fix from Eric Dumazet 26) Several cases of missing header file includes from Rashika Kheria 27) Add ZTE MF667 device ID to qmi_wwan driver, from Raymond Wanyoike 28) TCP Small Queues doesn't handle nonagle properly in some corner cases, fix from Eric Dumazet 29) Remove extraneous read_unlock in bond_enslave, whoops. From Ding Tianhong 30) Fix 9p trans_virtio handling of vmalloc buffers, from Richard Yao * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (136 commits) 6lowpan: fix lockdep splats alx: add missing stats_lock spinlock init 9p/trans_virtio.c: Fix broken zero-copy on vmalloc() buffers bonding: remove unwanted bond lock for enslave processing USB2NET : SR9800 : One chip USB2.0 USB2NET SR9800 Device Driver Support tcp: tsq: fix nonagle handling bridge: Prevent possible race condition in br_fdb_change_mac_address bridge: Properly check if local fdb entry can be deleted when deleting vlan bridge: Properly check if local fdb entry can be deleted in br_fdb_delete_by_port bridge: Properly check if local fdb entry can be deleted in br_fdb_change_mac_address bridge: Fix the way to check if a local fdb entry can be deleted bridge: Change local fdb entries whenever mac address of bridge device changes bridge: Fix the way to find old local fdb entries in br_fdb_change_mac_address bridge: Fix the way to insert new local fdb entries in br_fdb_changeaddr bridge: Fix the way to find old local fdb entries in br_fdb_changeaddr tcp: correct code comment stating 3 min timeout for FIN_WAIT2, we only do 1 min net: vxge: Remove unused device pointer net: qmi_wwan: add ZTE MF667 3c59x: Remove unused pointer in vortex_eisa_cleanup() net: fix 'ip rule' iif/oif device rename ...
2014-02-106lowpan: fix lockdep splatsEric Dumazet
When a device ndo_start_xmit() calls again dev_queue_xmit(), lockdep can complain because dev_queue_xmit() is re-entered and the spinlocks protecting tx queues share a common lockdep class. Same issue was fixed for bonding/l2tp/ppp in commits 0daa2303028a6 ("[PATCH] bonding: lockdep annotation") 49ee49202b4ac ("bonding: set qdisc_tx_busylock to avoid LOCKDEP splat") 23d3b8bfb8eb2 ("net: qdisc busylock needs lockdep annotations ") 303c07db487be ("ppp: set qdisc_tx_busylock to avoid LOCKDEP splat ") Reported-by: Alexander Aring <alex.aring@gmail.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Tested-by: Alexander Aring <alex.aring@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-109p/trans_virtio.c: Fix broken zero-copy on vmalloc() buffersRichard Yao
The 9p-virtio transport does zero copy on things larger than 1024 bytes in size. It accomplishes this by returning the physical addresses of pages to the virtio-pci device. At present, the translation is usually a bit shift. That approach produces an invalid page address when we read/write to vmalloc buffers, such as those used for Linux kernel modules. Any attempt to load a Linux kernel module from 9p-virtio produces the following stack. [<ffffffff814878ce>] p9_virtio_zc_request+0x45e/0x510 [<ffffffff814814ed>] p9_client_zc_rpc.constprop.16+0xfd/0x4f0 [<ffffffff814839dd>] p9_client_read+0x15d/0x240 [<ffffffff811c8440>] v9fs_fid_readn+0x50/0xa0 [<ffffffff811c84a0>] v9fs_file_readn+0x10/0x20 [<ffffffff811c84e7>] v9fs_file_read+0x37/0x70 [<ffffffff8114e3fb>] vfs_read+0x9b/0x160 [<ffffffff81153571>] kernel_read+0x41/0x60 [<ffffffff810c83ab>] copy_module_from_fd.isra.34+0xfb/0x180 Subsequently, QEMU will die printing: qemu-system-x86_64: virtio: trying to map MMIO memory This patch enables 9p-virtio to correctly handle this case. This not only enables us to load Linux kernel modules off virtfs, but also enables ZFS file-based vdevs on virtfs to be used without killing QEMU. Special thanks to both Avi Kivity and Alexander Graf for their interpretation of QEMU backtraces. Without their guidence, tracking down this bug would have taken much longer. Also, special thanks to Linus Torvalds for his insightful explanation of why this should use is_vmalloc_addr() instead of is_vmalloc_or_module_addr(): https://lkml.org/lkml/2014/2/8/272 Signed-off-by: Richard Yao <ryao@gentoo.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-10tcp: tsq: fix nonagle handlingJohn Ogness
Commit 46d3ceabd8d9 ("tcp: TCP Small Queues") introduced a possible regression for applications using TCP_NODELAY. If TCP session is throttled because of tsq, we should consult tp->nonagle when TX completion is done and allow us to send additional segment, especially if this segment is not a full MSS. Otherwise this segment is sent after an RTO. [edumazet] : Cooked the changelog, added another fix about testing sk_wmem_alloc twice because TX completion can happen right before setting TSQ_THROTTLED bit. This problem is particularly visible with recent auto corking, but might also be triggered with low tcp_limit_output_bytes values or NIC drivers delaying TX completion by hundred of usec, and very low rtt. Thomas Glanzmann for example reported an iscsi regression, caused by tcp auto corking making this bug quite visible. Fixes: 46d3ceabd8d9 ("tcp: TCP Small Queues") Signed-off-by: John Ogness <john.ogness@linutronix.de> Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Thomas Glanzmann <thomas@glanzmann.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-10bridge: Prevent possible race condition in br_fdb_change_mac_addressToshiaki Makita
br_fdb_change_mac_address() calls fdb_insert()/fdb_delete() without br->hash_lock. These hash list updates are racy with br_fdb_update()/br_fdb_cleanup(). Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Acked-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-10bridge: Properly check if local fdb entry can be deleted when deleting vlanToshiaki Makita
Vlan codes unconditionally delete local fdb entries. We should consider the possibility that other ports have the same address and vlan. Example of problematic case: ip link set eth0 address 12:34:56:78:90:ab ip link set eth1 address aa:bb:cc:dd:ee:ff brctl addif br0 eth0 brctl addif br0 eth1 # br0 will have mac address 12:34:56:78:90:ab bridge vlan add dev eth0 vid 10 bridge vlan add dev eth1 vid 10 bridge vlan add dev br0 vid 10 self We will have fdb entry such that f->dst == eth0, f->vlan_id == 10 and f->addr == 12:34:56:78:90:ab at this time. Next, delete eth0 vlan 10. bridge vlan del dev eth0 vid 10 In this case, we still need the entry for br0, but it will be deleted. Note that br0 needs the entry even though its mac address is not set manually. To delete the entry with proper condition checking, fdb_delete_local() is suitable to use. Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Acked-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-10bridge: Properly check if local fdb entry can be deleted in ↵Toshiaki Makita
br_fdb_delete_by_port br_fdb_delete_by_port() doesn't care about vlan and mac address of the bridge device. As the check is almost the same as mac address changing, slightly modify fdb_delete_local() and use it. Note that we can always set added_by_user to 0 in fdb_delete_local() because - br_fdb_delete_by_port() calls fdb_delete_local() for local entries regardless of its added_by_user. In this case, we have to check if another port has the same address and vlan, and if found, we have to create the entry (by changing dst). This is kernel-added entry, not user-added. - br_fdb_changeaddr() doesn't call fdb_delete_local() for user-added entry. Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Acked-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
br_fdb_change_mac_address br_fdb_change_mac_address() doesn't check if the local entry has the same address as any of bridge ports. Although I'm not sure when it is beneficial, current implementation allow the bridge device to receive any mac address of its ports. To preserve this behavior, we have to check if the mac address of the entry being deleted is identical to that of any port. As this check is almost the same as that in br_fdb_changeaddr(), create a common function fdb_delete_local() and call it from br_fdb_changeadddr() and br_fdb_change_mac_address(). Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Acked-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-10bridge: Fix the way to check if a local fdb entry can be deletedToshiaki Makita
We should take into account the followings when deleting a local fdb entry. - nbp_vlan_find() can be used only when vid != 0 to check if an entry is deletable, because a fdb entry with vid 0 can exist at any time while nbp_vlan_find() always return false with vid 0. Example of problematic case: ip link set eth0 address 12:34:56:78:90:ab ip link set eth1 address 12:34:56:78:90:ab brctl addif br0 eth0 brctl addif br0 eth1 ip link set eth0 address aa:bb:cc:dd:ee:ff Then, the fdb entry 12:34:56:78:90:ab will be deleted even though the bridge port eth1 still has that address. - The port to which the bridge device is attached might needs a local entry if its mac address is set manually. Example of problematic case: ip link set eth0 address 12:34:56:78:90:ab brctl addif br0 eth0 ip link set br0 address 12:34:56:78:90:ab ip link set eth0 address aa:bb:cc:dd:ee:ff Then, the fdb still must have the entry 12:34:56:78:90:ab, but it will be deleted. We can use br->dev->addr_assign_type to check if the address is manually set or not, but I propose another approach. Since we delete and insert local entries whenever changing mac address of the bridge device, we can change dst of the entry to NULL regardless of addr_assign_type when deleting an entry associated with a certain port, and if it is found to be unnecessary later, then delete it. That is, if changing mac address of a port, the entry might be changed to its dst being NULL first, but is eventually deleted when recalculating and changing bridge id. This approach is especially useful when we want to share the code with deleting vlan in which the bridge device might want such an entry regardless of addr_assign_type, and makes things easy because we don't have to consider if mac address of the bridge device will be changed or not at the time we delete a local entry of a port, which means fdb code will not be bothered even if the bridge id calculating logic is changed in the future. Also, this change reduces inconsistent state, where frames whose dst is the mac address of the bridge, can't reach the bridge because of premature fdb entry deletion. This change reduces the possibility that the bridge device replies unreachable mac address to arp requests, which could occur during the short window between calling del_nbp() and br_stp_recalculate_bridge_id() in br_del_if(). This will effective after br_fdb_delete_by_port() starts to use the same code by following patch. Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Acked-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-10bridge: Change local fdb entries whenever mac address of bridge device changesToshiaki Makita
Vlan code may need fdb change when changing mac address of bridge device even if it is caused by the mac address changing of a bridge port. Example configuration: ip link set eth0 address 12:34:56:78:90:ab ip link set eth1 address aa:bb:cc:dd:ee:ff brctl addif br0 eth0 brctl addif br0 eth1 # br0 will have mac address 12:34:56:78:90:ab bridge vlan add dev br0 vid 10 self bridge vlan add dev eth0 vid 10 We will have fdb entry such that f->dst == NULL, f->vlan_id == 10 and f->addr == 12:34:56:78:90:ab at this time. Next, change the mac address of eth0 to greater value. ip link set eth0 address ee:ff:12:34:56:78 Then, mac address of br0 will be recalculated and set to aa:bb:cc:dd:ee:ff. However, an entry aa:bb:cc:dd:ee:ff will not be created and we will be not able to communicate using br0 on vlan 10. Address this issue by deleting and adding local entries whenever changing the mac address of the bridge device. If there already exists an entry that has the same address, for example, in case that br_fdb_changeaddr() has already inserted it, br_fdb_change_mac_address() will simply fail to insert it and no duplicated entry will be made, as it was. This approach also needs br_add_if() to call br_fdb_insert() before br_stp_recalculate_bridge_id() so that we don't create an entry whose dst == NULL in this function to preserve previous behavior. Note that this is a slight change in behavior where the bridge device can receive the traffic to the new address before calling br_stp_recalculate_bridge_id() in br_add_if(). However, it is not a problem because we have already the address on the new port and such a way to insert new one before recalculating bridge id is taken in br_device_event() as well. Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Acked-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-10bridge: Fix the way to find old local fdb entries in br_fdb_change_mac_addressToshiaki Makita
We have been always failed to delete the old entry at br_fdb_change_mac_address() because br_set_mac_address() updates dev->dev_addr before calling br_fdb_change_mac_address() and br_fdb_change_mac_address() uses dev->dev_addr to find the old entry. That update of dev_addr is completely unnecessary because the same work is done in br_stp_change_bridge_id() which is called right away after calling br_fdb_change_mac_address(). Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Acked-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-10bridge: Fix the way to insert new local fdb entries in br_fdb_changeaddrToshiaki Makita
Since commit bc9a25d21ef8 ("bridge: Add vlan support for local fdb entries"), br_fdb_changeaddr() has inserted a new local fdb entry only if it can find old one. But if we have two ports where they have the same address or user has deleted a local entry, there will be no entry for one of the ports. Example of problematic case: ip link set eth0 address aa:bb:cc:dd:ee:ff ip link set eth1 address aa:bb:cc:dd:ee:ff brctl addif br0 eth0 brctl addif br0 eth1 # eth1 will not have a local entry due to dup. ip link set eth1 address 12:34:56:78:90:ab Then, the new entry for the address 12:34:56:78:90:ab will not be created, and the bridge device will not be able to communicate. Insert new entries regardless of whether we can find old entries or not. Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Acked-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-10bridge: Fix the way to find old local fdb entries in br_fdb_changeaddrToshiaki Makita
br_fdb_changeaddr() assumes that there is at most one local entry per port per vlan. It used to be true, but since commit 36fd2b63e3b4 ("bridge: allow creating/deleting fdb entries via netlink"), it has not been so. Therefore, the function might fail to search a correct previous address to be deleted and delete an arbitrary local entry if user has added local entries manually. Example of problematic case: ip link set eth0 address ee:ff:12:34:56:78 brctl addif br0 eth0 bridge fdb add 12:34:56:78:90:ab dev eth0 master ip link set eth0 address aa:bb:cc:dd:ee:ff Then, the address 12:34:56:78:90:ab might be deleted instead of ee:ff:12:34:56:78, the original mac address of eth0. Address this issue by introducing a new flag, added_by_user, to struct net_bridge_fdb_entry. Note that br_fdb_delete_by_port() has to set added_by_user to 0 in cases like: ip link set eth0 address 12:34:56:78:90:ab ip link set eth1 address aa:bb:cc:dd:ee:ff brctl addif br0 eth0 bridge fdb add aa:bb:cc:dd:ee:ff dev eth0 master brctl addif br0 eth1 brctl delif br0 eth0 In this case, kernel should delete the user-added entry aa:bb:cc:dd:ee:ff, but it also should have been added by "brctl addif br0 eth1" originally, so we don't delete it and treat it a new kernel-created entry. Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-09tcp: correct code comment stating 3 min timeout for FIN_WAIT2, we only do 1 minJesper Juhl
As far as I can tell we have used a default of 60 seconds for FIN_WAIT2 timeout for ages (since 2.x times??). In any case, the timeout these days is 60 seconds, so the 3 min comment is wrong (and cost me a few minutes of my life when I was debugging a FIN_WAIT2 related problem in a userspace application and checked the kernel source for details). Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-09net: fix 'ip rule' iif/oif device renameMaciej Żenczykowski
ip rules with iif/oif references do not update: (detach/attach) across interface renames. Signed-off-by: Maciej Żenczykowski <maze@google.com> CC: Willem de Bruijn <willemb@google.com> CC: Eric Dumazet <edumazet@google.com> CC: Chris Davis <chrismd@google.com> CC: Carlo Contavalli <ccontavalli@google.com> Google-Bug-Id: 12936021 Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-096lowpan: Remove unused pointer in lowpan_header_create()Christian Engelmayer
Commit 8df8c56a (6lowpan: Moving generic compression code into 6lowpan_iphc.c) left pointer 'hdr' unused - remove it. Detected by Coverity: CID 1164868. Signed-off-by: Christian Engelmayer <cengelma@gmx.at> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-09ipv6: icmp6_send: fix Oops when pinging a not set up IPv6 peer on a sit tunnelFX Le Bail
The patch 446fab59333dea91e54688f033dd8d788d0486fb ("ipv6: enable anycast addresses as source addresses in ICMPv6 error messages") causes an Oops when pinging a not set up IPv6 peer on a sit tunnel. The problem is that ipv6_anycast_destination() uses unconditionally skb_dst(skb), which is NULL in this case. The solution is to use instead the ipv6_chk_acast_addr_src() function. Here are the steps to reproduce it: modprobe sit ip link add sit1 type sit remote 10.16.0.121 local 10.16.0.249 ip l s sit1 up ip -6 a a dev sit1 2001:1234::123 remote 2001:1234::121 ping6 2001:1234::121 Reported-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Tested-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: Francois-Xavier Le Bail <fx.lebail@yahoo.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-09net: Mark functions as static in net/sunrpc/svc_xprt.cRashika Kheria
Mark functions as static in net/sunrpc/svc_xprt.c because they are not used outside this file. This eliminates the following warning in net/sunrpc/svc_xprt.c: net/sunrpc/svc_xprt.c:574:5: warning: no previous prototype for ‘svc_alloc_arg’ [-Wmissing-prototypes] net/sunrpc/svc_xprt.c:615:18: warning: no previous prototype for ‘svc_get_next_xprt’ [-Wmissing-prototypes] net/sunrpc/svc_xprt.c:694:6: warning: no previous prototype for ‘svc_add_new_temp_xprt’ [-Wmissing-prototypes] Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-09net: Include appropriate header file in netfilter/nft_lookup.cRashika Kheria
Include appropriate header file net/netfilter/nf_tables_core.h in net/netfilter/nft_lookup.c because it has prototype declaration of functions defined in net/netfilter/nft_lookup.c. This eliminates the following warning in net/netfilter/nft_lookup.c: net/netfilter/nft_lookup.c:133:12: warning: no previous prototype for ‘nft_lookup_module_init’ [-Wmissing-prototypes] net/netfilter/nft_lookup.c:138:6: warning: no previous prototype for ‘nft_lookup_module_exit’ [-Wmissing-prototypes] Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-09net: Move prototype declaration to header file include/net/net_namespace.h ↵Rashika Kheria
from net/ipx/af_ipx.c Move prototype declaration of function to header file include/net/net_namespace.h from net/ipx/af_ipx.c because they are used by more than one file. This eliminates the following warning in net/ipx/sysctl_net_ipx.c: net/ipx/sysctl_net_ipx.c:33:6: warning: no previous prototype for ‘ipx_register_sysctl’ [-Wmissing-prototypes] net/ipx/sysctl_net_ipx.c:38:6: warning: no previous prototype for ‘ipx_unregister_sysctl’ [-Wmissing-prototypes] Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-09net: Move prototype declaration to header file include/net/datalink.h from ↵Rashika Kheria
net/ipx/af_ipx.c Move prototype declarations of function to header file include/net/datalink.h from net/ipx/af_ipx.c because they are used by more than one file. This eliminates the following warning in net/ipx/pe2.c: net/ipx/pe2.c:20:24: warning: no previous prototype for ‘make_EII_client’ [-Wmissing-prototypes] net/ipx/pe2.c:32:6: warning: no previous prototype for ‘destroy_EII_client’ [-Wmissing-prototypes] Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-09net: Move prototype declaration to header file include/net/ipx.h from ↵Rashika Kheria
net/ipx/af_ipx.c Move prototype declaration of functions to header file include/net/ipx.h from net/ipx/af_ipx.c because they are used by more than one file. This eliminates the following warning in net/ipx/ipx_route.c:33:19: warning: no previous prototype for ‘ipxrtr_lookup’ [-Wmissing-prototypes] net/ipx/ipx_route.c:52:5: warning: no previous prototype for ‘ipxrtr_add_route’ [-Wmissing-prototypes] net/ipx/ipx_route.c:94:6: warning: no previous prototype for ‘ipxrtr_del_routes’ [-Wmissing-prototypes] net/ipx/ipx_route.c:149:5: warning: no previous prototype for ‘ipxrtr_route_skb’ [-Wmissing-prototypes] net/ipx/ipx_route.c:171:5: warning: no previous prototype for ‘ipxrtr_route_packet’ [-Wmissing-prototypes] net/ipx/ipx_route.c:261:5: warning: no previous prototype for ‘ipxrtr_ioctl’ [-Wmissing-prototypes] Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-09net: Move prototype declaration to include/net/ipx.h from net/ipx/ipx_route.cRashika Kheria
Move prototype definition of function to header file include/net/ipx.h from net/ipx/ipx_route.c because they are used by more than one file. This eliminates the following warning from net/ipx/af_ipx.c: net/ipx/af_ipx.c:193:23: warning: no previous prototype for ‘ipxitf_find_using_net’ [-Wmissing-prototypes] net/ipx/af_ipx.c:577:5: warning: no previous prototype for ‘ipxitf_send’ [-Wmissing-prototypes] net/ipx/af_ipx.c:1219:8: warning: no previous prototype for ‘ipx_cksum’ [-Wmissing-prototypes] Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-09net: Move prototype declaration to header file include/net/dn.h from ↵Rashika Kheria
net/decnet/af_decnet.c Move prototype declaration of functions to header file include/net/dn.h from net/decnet/af_decnet.c because they are used by more than one file. This eliminates the following warning in net/decnet/af_decnet.c: net/decnet/sysctl_net_decnet.c:354:6: warning: no previous prototype for ‘dn_register_sysctl’ [-Wmissing-prototypes] net/decnet/sysctl_net_decnet.c:359:6: warning: no previous prototype for ‘dn_unregister_sysctl’ [-Wmissing-prototypes] Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-09net: Move prototype declaration to appropriate header file from ↵Rashika Kheria
decnet/af_decnet.c Move prototype declaration of functions to header file include/net/dn_route.h from net/decnet/af_decnet.c because it is used by more than one file. This eliminates the following warning in net/decnet/dn_route.c: net/decnet/dn_route.c:629:5: warning: no previous prototype for ‘dn_route_rcv’ [-Wmissing-prototypes] Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-09net: Mark functions as static in core/dev.cRashika Kheria
Mark functions as static in core/dev.c because they are not used outside this file. This eliminates the following warning in core/dev.c: net/core/dev.c:2806:5: warning: no previous prototype for ‘__dev_queue_xmit’ [-Wmissing-prototypes] net/core/dev.c:4640:5: warning: no previous prototype for ‘netdev_adjacent_sysfs_add’ [-Wmissing-prototypes] net/core/dev.c:4650:6: warning: no previous prototype for ‘netdev_adjacent_sysfs_del’ [-Wmissing-prototypes] Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Reviewed-by: Veaceslav Falico <vfalico@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-09net: Include appropriate header file in caif/cfsrvl.cRashika Kheria
Include appropriate header file net/caif/caif_dev.h in caif/cfsrvl.c because it has prototype declaration of functions defined in caif/cfsrvl.c. This eliminates the following warning in caif/cfsrvl.c: net/caif/cfsrvl.c:198:6: warning: no previous prototype for ‘caif_free_client’ [-Wmissing-prototypes] net/caif/cfsrvl.c:208:6: warning: no previous prototype for ‘caif_client_register_refcnt’ [-Wmissing-prototypes] Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-09net: Include appropriate header file in caif/caif_dev.cRashika Kheria
Include appropriate header file net/caif/caif_dev.h in caif/caif_dev.c because it has prototype declarations of function defined in caif/caif_dev.c. This eliminates the following file in caif/caif_dev.c: net/caif/caif_dev.c:303:6: warning: no previous prototype for ‘caif_enroll_dev’ [-Wmissing-prototypes] Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-09net: Mark function as static in 9p/client.cRashika Kheria
Mark function as static in net/9p/client.c because it is not used outside this file. This eliminates the following warning in net/9p/client.c: net/9p/client.c:207:18: warning: no previous prototype for ‘p9_fcall_alloc’ [-Wmissing-prototypes] Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-09Merge branch 'for-davem' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless John W. Linville says: ==================== Please pull this batch of fixes intended for the 3.14 stream! For the mac80211 bits, Johannes says: "This is just a collection of small fixes, the commit logs explain the details. The only thing that isn't strictly a fix is the 5/10 MHz enabling, I had forgotten this and there's little point in waiting longer. The patch simply removes the force-disable code that I put in when there was a problem with the userspace API (that has long been fixed.)" For the iwlwifi bits, Emmanuel says: "I have an important fix that disables A band in case the driver thought it was enabled, and the firmware disagreed. We ended up making the firmware unhappy. I also fix the station table in AP mode and fix the scan while we have BT working. Johannes removes a static variable that could potentially lead to to issues on multi-device setups and disables scheduled scan to avoid issues with old versions of wpa_supplicant. A small fix from David on scan and a few new device IDs for 7265." On top of that... Oleksij Rempel adds a USB ID to the ar5523 driver and changes the default powersave setting for ath9k_htc to "off", due to observed stability issues (based on an equivalent ath9k patch). Stanislaw Gruszka similarly disables powersave for a couple of rt2x00 drivers. He also fixes a couple of scheduling while atomic issues in ath9k_htc. Sujith Manoharan rounds-out the powersave disables with one for ath9k. He also fixes a build prolem with ath9k on ARM and fixes an ath9k Tx power calculation. Finally, Andrea Merello fixes a couple of lingering DMA mapping problems in the rtl8180 driver. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-09Merge branch 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/pablo/nfDavid S. Miller
Pablo Neira Ayuso says: ==================== Netfilter/nftables/IPVS fixes for net The following patchset contains Netfilter/IPVS fixes, mostly nftables fixes, most relevantly they are: * Fix a crash in the h323 conntrack NAT helper due to expectation list corruption, from Alexey Dobriyan. * A couple of RCU race fixes for conntrack, one manifests by hitting BUG_ON in nf_nat_setup_info() and the destroy path, patches from Andrey Vagin and me. * Dump direction attribute in nft_ct only if it is set, from Arturo Borrero. * Fix IPVS bug in its own connection tracking system that may lead to copying only 4 bytes of the IPv6 address when initializing the ip_vs_conn object, from Michal Kubecek. * Fix -EBUSY errors in nftables when deleting the rules, chain and tables in a row due mixture of asynchronous and synchronous object releasing, from me. * Three fixes for the nf_tables set infrastructure when using intervals and mappings, from me. * Four patches to fixing the nf_tables log, reject and ct expressions from the new inet table, from Patrick McHardy. * Fix memory overrun in the map that is used to dynamically allocate names from anonymous sets, also from Patrick. * Fix a potential oops if you dump a set with NFPROTO_UNSPEC and a table name, from Patrick McHardy. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-07libceph: do not dereference a NULL bio pointerIlya Dryomov
Commit f38a5181d9f3 ("ceph: Convert to immutable biovecs") introduced a NULL pointer dereference, which broke rbd in -rc1. Fix it. Cc: Kent Overstreet <kmo@daterainc.com> Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com> Reviewed-by: Sage Weil <sage@inktank.com>
2014-02-07libceph: take map_sem for read in handle_reply()Ilya Dryomov
Handling redirect replies requires both map_sem and request_mutex. Taking map_sem unconditionally near the top of handle_reply() avoids possible race conditions that arise from releasing request_mutex to be able to acquire map_sem in redirect reply case. (Lock ordering is: map_sem, request_mutex, crush_mutex.) Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com> Reviewed-by: Sage Weil <sage@inktank.com>
2014-02-07libceph: factor out logic from ceph_osdc_start_request()Ilya Dryomov
Factor out logic from ceph_osdc_start_request() into a new helper, __ceph_osdc_start_request(). ceph_osdc_start_request() now amounts to taking locks and calling __ceph_osdc_start_request(). Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com> Reviewed-by: Sage Weil <sage@inktank.com>
2014-02-07Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
2014-02-07netfilter: nf_tables: unininline nft_trace_packet()Patrick McHardy
It makes no sense to inline a rarely used function meant for debugging only that is called a total of five times in the main evaluation loop. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2014-02-07netfilter: nf_tables: fix loop checking with end interval elementsPablo Neira Ayuso
Fix access to uninitialized data for end interval elements. The element data part is uninitialized in interval end elements. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2014-02-07netfilter: nft_rbtree: fix data handling of end interval elementsPablo Neira Ayuso
This patch fixes several things which related to the handling of end interval elements: * Chain use underflow with intervals and map: If you add a rule using intervals+map that introduces a loop, the error path of the rbtree set decrements the chain refcount for each side of the interval, leading to a chain use counter underflow. * Don't copy the data part of the end interval element since, this area is uninitialized and this confuses the loop detection code. * Don't allocate room for the data part of end interval elements since this is unused. So, after this patch the idea is that end interval elements don't have a data part. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Acked-by: Patrick McHardy <kaber@trash.net>
2014-02-07netfilter: nf_tables: do not allow NFT_SET_ELEM_INTERVAL_END flag and dataPablo Neira Ayuso
This combination is not allowed since end interval elements cannot contain data. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Acked-by: Patrick McHardy <kaber@trash.net>
2014-02-06tcp: remove 1ms offset in srtt computationEric Dumazet
TCP pacing depends on an accurate srtt estimation. Current srtt estimation is using jiffie resolution, and has an artificial offset of at least 1 ms, which can produce slowdowns when FQ/pacing is used, especially in DC world, where typical rtt is below 1 ms. We are planning a switch to usec resolution for linux-3.15, but in the meantime, this patch removes the 1 ms offset. All we need is to have tp->srtt minimal value of 1 to differentiate the case of srtt being initialized or not, not 8. The problematic behavior was observed on a 40Gbit testbed, where 32 concurrent netperf were reaching 12Gbps of aggregate speed, instead of line speed. This patch also has the effect of reporting more accurate srtt and send rates to iproute2 ss command as in : $ ss -i dst cca2 Netid State Recv-Q Send-Q Local Address:Port Peer Address:Port tcp ESTAB 0 0 10.244.129.1:56984 10.244.129.2:12865 cubic wscale:6,6 rto:200 rtt:0.25/0.25 ato:40 mss:1448 cwnd:10 send 463.4Mbps rcv_rtt:1 rcv_space:29200 tcp ESTAB 0 390960 10.244.129.1:60247 10.244.129.2:50204 cubic wscale:6,6 rto:200 rtt:0.875/0.75 mss:1448 cwnd:73 ssthresh:51 send 966.4Mbps unacked:73 retrans:0/121 rcv_space:29200 Reported-by: Vytautas Valancius <valas@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Yuchung Cheng <ycheng@google.com> Cc: Neal Cardwell <ncardwell@google.com> Acked-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-06bridge: fix netconsole setup over bridgeCong Wang
Commit 93d8bf9fb8f3 ("bridge: cleanup netpoll code") introduced a check in br_netpoll_enable(), but this check is incorrect for br_netpoll_setup(). This patch moves the code after the check into __br_netpoll_enable() and calls it in br_netpoll_setup(). For br_add_if(), the check is still needed. Fixes: 93d8bf9fb8f3 ("bridge: cleanup netpoll code") Cc: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Cc: Stephen Hemminger <stephen@networkplumber.org> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <cwang@twopensource.com> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Acked-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Tested-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-06net: use __GFP_NORETRY for high order allocationsEric Dumazet
sock_alloc_send_pskb() & sk_page_frag_refill() have a loop trying high order allocations to prepare skb with low number of fragments as this increases performance. Problem is that under memory pressure/fragmentation, this can trigger OOM while the intent was only to try the high order allocations, then fallback to order-0 allocations. We had various reports from unexpected regressions. According to David, setting __GFP_NORETRY should be fine, as the asynchronous compaction is still enabled, and this will prevent OOM from kicking as in : CFSClientEventm invoked oom-killer: gfp_mask=0x42d0, order=3, oom_adj=0, oom_score_adj=0, oom_score_badness=2 (enabled),memcg_scoring=disabled CFSClientEventm Call Trace: [<ffffffff8043766c>] dump_header+0xe1/0x23e [<ffffffff80437a02>] oom_kill_process+0x6a/0x323 [<ffffffff80438443>] out_of_memory+0x4b3/0x50d [<ffffffff8043a4a6>] __alloc_pages_may_oom+0xa2/0xc7 [<ffffffff80236f42>] __alloc_pages_nodemask+0x1002/0x17f0 [<ffffffff8024bd23>] alloc_pages_current+0x103/0x2b0 [<ffffffff8028567f>] sk_page_frag_refill+0x8f/0x160 [<ffffffff80295fa0>] tcp_sendmsg+0x560/0xee0 [<ffffffff802a5037>] inet_sendmsg+0x67/0x100 [<ffffffff80283c9c>] __sock_sendmsg_nosec+0x6c/0x90 [<ffffffff80283e85>] sock_sendmsg+0xc5/0xf0 [<ffffffff802847b6>] __sys_sendmsg+0x136/0x430 [<ffffffff80284ec8>] sys_sendmsg+0x88/0x110 [<ffffffff80711472>] system_call_fastpath+0x16/0x1b Out of Memory: Kill process 2856 (bash) score 9999 or sacrifice child Signed-off-by: Eric Dumazet <edumazet@google.com> Acked-by: David Rientjes <rientjes@google.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-06netpoll: fix netconsole IPv6 setupSabrina Dubroca
Currently, to make netconsole start over IPv6, the source address needs to be specified. Without a source address, netpoll_parse_options assumes we're setting up over IPv4 and the destination IPv6 address is rejected. Check if the IP version has been forced by a source address before checking for a version mismatch when parsing the destination address. Signed-off-by: Sabrina Dubroca <sd@queasysnail.net> Acked-by: Cong Wang <cwang@twopensource.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-06net: sctp: fix initialization of local source address on accepted ipv6 socketsMatija Glavinic Pecotic
commit efe4208f47f907b86f528788da711e8ab9dea44d: 'ipv6: make lookups simpler and faster' broke initialization of local source address on accepted ipv6 sockets. Before the mentioned commit receive address was copied along with the contents of ipv6_pinfo in sctp_v6_create_accept_sk. Now when it is moved, it has to be copied separately. This also fixes lksctp's ipv6 regression in a sense that test_getname_v6, TC5 - 'getsockname on a connected server socket' now passes. Signed-off-by: Matija Glavinic Pecotic <matija.glavinic-pecotic.ext@nsn.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-06ipv4: Fix runtime WARNING in rtmsg_ifa()Geert Uytterhoeven
On m68k/ARAnyM: WARNING: CPU: 0 PID: 407 at net/ipv4/devinet.c:1599 0x316a99() Modules linked in: CPU: 0 PID: 407 Comm: ifconfig Not tainted 3.13.0-atari-09263-g0c71d68014d1 #1378 Stack from 10c4fdf0: 10c4fdf0 002ffabb 000243e8 00000000 008ced6c 00024416 00316a99 0000063f 00316a99 00000009 00000000 002501b4 00316a99 0000063f c0a86117 00000080 c0a86117 00ad0c90 00250a5a 00000014 00ad0c90 00000000 00000000 00000001 00b02dd0 00356594 00000000 00356594 c0a86117 eff6c9e4 008ced6c 00000002 008ced60 0024f9b4 00250b52 00ad0c90 00000000 00000000 00252390 00ad0c90 eff6c9e4 0000004f 00000000 00000000 eff6c9e4 8000e25c eff6c9e4 80001020 Call Trace: [<000243e8>] warn_slowpath_common+0x52/0x6c [<00024416>] warn_slowpath_null+0x14/0x1a [<002501b4>] rtmsg_ifa+0xdc/0xf0 [<00250a5a>] __inet_insert_ifa+0xd6/0x1c2 [<0024f9b4>] inet_abc_len+0x0/0x42 [<00250b52>] inet_insert_ifa+0xc/0x12 [<00252390>] devinet_ioctl+0x2ae/0x5d6 Adding some debugging code reveals that net_fill_ifaddr() fails in put_cacheinfo(skb, ifa->ifa_cstamp, ifa->ifa_tstamp, preferred, valid)) nla_put complains: lib/nlattr.c:454: skb_tailroom(skb) = 12, nla_total_size(attrlen) = 20 Apparently commit 5c766d642bcaffd0c2a5b354db2068515b3846cf ("ipv4: introduce address lifetime") forgot to take into account the addition of struct ifa_cacheinfo in inet_nlmsg_size(). Hence add it, like is already done for ipv6. Suggested-by: Cong Wang <cwang@twopensource.com> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Cong Wang <cwang@twopensource.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-06netfilter: nf_tables: fix racy rule deletionPablo Neira Ayuso
We may lost race if we flush the rule-set (which happens asynchronously via call_rcu) and we try to remove the table (that userspace assumes to be empty). Fix this by recovering synchronous rule and chain deletion. This was introduced time ago before we had no batch support, and synchronous rule deletion performance was not good. Now that we have the batch support, we can just postpone the purge of old rule in a second step in the commit phase. All object deletions are synchronous after this patch. As a side effect, we save memory as we don't need rcu_head per rule anymore. Cc: Patrick McHardy <kaber@trash.net> Reported-by: Arturo Borrero Gonzalez <arturo.borrero.glez@gmail.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2014-02-06netfilter: nf_tables: fix log/queue expressions for NFPROTO_INETPatrick McHardy
The log and queue expressions both store the family during ->init() and use it to deliver packets. This is wrong when used in NFPROTO_INET since they should both deliver to the actual AF of the packet, not the dummy NFPROTO_INET. Use the family from the hook ops to fix this. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2014-02-06mac80211: fix virtual monitor interface iterationJohannes Berg
During channel context assignment, the interface should be found by interface iteration, so we need to assign the pointer before the channel context. Reported-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Tested-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-02-06mac80211: fix fragmentation code, particularly for encryptionJohannes Berg
The "new" fragmentation code (since my rewrite almost 5 years ago) erroneously sets skb->len rather than using skb_trim() to adjust the length of the first fragment after copying out all the others. This leaves the skb tail pointer pointing to after where the data originally ended, and thus causes the encryption MIC to be written at that point, rather than where it belongs: immediately after the data. The impact of this is that if software encryption is done, then a) encryption doesn't work for the first fragment, the connection becomes unusable as the first fragment will never be properly verified at the receiver, the MIC is practically guaranteed to be wrong b) we leak up to 8 bytes of plaintext (!) of the packet out into the air This is only mitigated by the fact that many devices are capable of doing encryption in hardware, in which case this can't happen as the tail pointer is irrelevant in that case. Additionally, fragmentation is not used very frequently and would normally have to be configured manually. Fix this by using skb_trim() properly. Cc: stable@vger.kernel.org Fixes: 2de8e0d999b8 ("mac80211: rewrite fragmentation") Reported-by: Jouni Malinen <j@w1.fi> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-02-06mac80211: Fix IBSS disconnectSujith Manoharan
Currently, when a station leaves an IBSS network, the corresponding BSS is not dropped from cfg80211 if there are other active stations in the network. But, the small window that is present when trying to determine a station's status based on IEEE80211_IBSS_MERGE_INTERVAL introduces a race. Instead of trying to keep the BSS, always remove it when leaving an IBSS network. There is not much benefit to retain the BSS entry since it will be added with a subsequent join operation. This fixes an issue where a dangling BSS entry causes ath9k to wait for a beacon indefinitely. Cc: <stable@vger.kernel.org> Reported-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Sujith Manoharan <c_manoha@qca.qualcomm.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
