The L2 Switch have 4 ports,
and the port0 can be used as ethernet port
when Switch is configured to operate
as a 3-Port Switch (Switch Mode).
Signed-off-by: Niu Xule <b23300@freescale.com>
fix connman can not detect wlan device dynamically.
Signed-off-by: Richard Zhao <richard.zhao@freescale.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
tc: Fix unitialized kernel memory leak
pkt_sched: Revert tasklet_hrtimer changes.
net: sk_free() should be allowed right after sk_alloc()
gianfar: gfar_remove needs to call unregister_netdev()
ipw2200: firmware DMA loading rework
Three bytes of uninitialized kernel memory are currently leaked to user
Reviewed-by: Jiri Pirko <jpirko@redhat.com>
These are full of unresolved problems, mainly that conversions don't
work 1-1 from hrtimers to tasklet_hrtimers because unlike hrtimers
tasklets can't be killed from softirq context.
And when a qdisc gets reset, that's exactly what we need to do here.
We'll work this out in the net-next-2.6 tree and if warranted we'll
backport that work to -stable.
This reverts the following 3 changesets:
a2cb6a4dd470d7a64255a10b843b0d188416b78f
("pkt_sched: Fix bogon in tasklet_hrtimer changes.")
38acce2d7983632100a9ff3fd20295f6e34074a8
("pkt_sched: Convert CBQ to tasklet_hrtimer.")
ee5f9757ea17759e1ce5503bdae2b07e48e32af9
("pkt_sched: Convert qdisc_watchdog to tasklet_hrtimer")
After commit 2b85a34e911bf483c27cfdd124aeb1605145dc80
(net: No more expensive sock_hold()/sock_put() on each tx)
sk_free() frees socks conditionally and depends
on sk_wmem_alloc being set e.g. in sock_init_data(). But in some
cases sk_free() is called earlier, usually after other alloc errors.
Fix is to move sk_wmem_alloc initialization from sock_init_data()
to sk_alloc() itself.
Signed-off-by: Jarek Poplawski <jarkao2@gmail.com>
This patch fixes the bug that was reported in
http://bugzilla.kernel.org/show_bug.cgi?id=14053
If we're in the case where we need to force a reencode and then resend of
the RPC request, due to xprt_transmit failing with a networking error, then
we _must_ retransmit the entire request.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Cc: stable@kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs:
9p: update documentation pointers
9p: remove unnecessary v9fses->options which duplicates the mount string
net/9p: insulate the client against an invalid error code sent by a 9p server
9p: Add missing cast for the error return value in v9fs_get_inode
9p: Remove redundant inode uid/gid assignment
9p: Fix possible regressions when ->get_sb fails.
9p: Fix v9fs show_options
9p: Fix possible memleak in v9fs_inode_from fid.
9p: minor comment fixes
9p: Fix possible inode leak in v9fs_get_inode.
9p: Check for error in return value of v9fs_fid_add
Add a check in ip_append_data() for NULL *rtp to prevent future bugs in
callers from being exploitable.
Signed-off-by: Julien Tinnes <julien@cr0.org>
Signed-off-by: Tavis Ormandy <taviso@sdf.lonestar.org>
irda/sa1100_ir: fix broken netdev_ops conversion
irda/au1k_ir: fix broken netdev_ops conversion
Reported by Stephen Rothwell, luckily it's harmless:
net/sched/sch_api.c: In function 'qdisc_watchdog':
net/sched/sch_api.c:460: warning: initialization from incompatible pointer type
net/sched/sch_cbq.c: In function 'cbq_undelay':
net/sched/sch_cbq.c:595: warning: initialization from incompatible pointer type
smc91x: let smc91x work well under netpoll
pxaficp-ir: remove incorrect net_device_ops
NET: llc, zero sockaddr_llc struct
drivers/net: fixed drivers that support netpoll use ndo_start_xmit()
netpoll: warning for ndo_start_xmit returns with interrupts enabled
net: Fix Micrel KSZ8842 Kconfig description
netfilter: xt_quota: fix wrong return value (error case)
ipv6: Fix commit 63d9950b08184e6531adceb65f64b429909cc101 (ipv6: Make v4-mapped bindings consistent with IPv4)
E100: fix interaction with swiotlb on X86.
rtl8187: always set MSR_LINK_ENEDCA flag with RTL8187B
ibm_newemac: emac_close() needs to call netif_carrier_off()
net: fix ks8851 build errors
net: Rename MAC platform driver for w90p910 platform
yellowfin: Fix buffer underrun after dev_alloc_skb() failure
orinoco: correct key bounds check in orinoco_hw_get_tkip_iv
mac80211: fix todo lock
sllc_arphrd member of sockaddr_llc might not be changed. Zero sllc
before copying to the above layer's structure.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
WARN_ONCE for ndo_start_xmit() enable interrupts in netpoll_send_skb(),
because the NETPOLL API requires that interrupts remain disabled in
netpoll_send_skb().
Signed-off-by: Dongdong Deng <dongdong.deng@windriver.com>
Acked-by: Matt Mackall <mpm@selenic.com>
Success was indicated on a memory allocation failure, thereby causing
a crash due to a later NULL deref.
(Affects v2.6.30-rc1 up to here.)
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
Commit 63d9950b08184e6531adceb65f64b429909cc101
changes behavior of inet6_bind() for v4-mapped addresses so it should
behave the same way as inet_bind().
During this change setting of err to -EADDRNOTAVAIL got lost:
af_inet.c:469 inet_bind()
err = -EADDRNOTAVAIL;
if (!sysctl_ip_nonlocal_bind &&
!(inet->freebind || inet->transparent) &&
addr->sin_addr.s_addr != htonl(INADDR_ANY) &&
chk_addr_ret != RTN_LOCAL &&
chk_addr_ret != RTN_MULTICAST &&
chk_addr_ret != RTN_BROADCAST)
goto out;
af_inet6.c:463 inet6_bind()
if (addr_type == IPV6_ADDR_MAPPED) {
int chk_addr_ret;
/* Binding to v4-mapped address on a v6-only socket
* makes no sense
if (np->ipv6only) {
err = -EINVAL;
goto out;
/* Reproduce AF_INET checks to make the bindings consitant */
v4addr = addr->sin6_addr.s6_addr32[3];
chk_addr_ret = inet_addr_type(net, v4addr);
v4addr != htonl(INADDR_ANY) &&
goto out;
} else {
Signed-off-by Bruno Prémont <bonbons@linux-vserver.org>
This code expects to run in softirq context, and bare hrtimers
run in hw IRQ context.
None of this stuff should execute in hw IRQ context, therefore
use a tasklet_hrtimer so that it runs in softirq context.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (60 commits)
net: restore gnet_stats_basic to previous definition
NETROM: Fix use of static buffer
e1000e: fix use of pci_enable_pcie_error_reporting
e1000e: WoL does not work on 82577/82578 with manageability enabled
cnic: Fix locking in init/exit calls.
cnic: Fix locking in start/stop calls.
bnx2: Use mutex on slow path cnic calls.
cnic: Refine registration with bnx2.
cnic: Fix symbol_put_addr() panic on ia64.
gre: Fix MTU calculation for bound GRE tunnels
pegasus: Add new device ID.
via-velocity: Fix test of mii_status bit VELOCITY_DUPLEX_FULL
rt2x00: fix memory corruption in rf cache, add a sanity check
ixgbe: Fix receive on real device when VLANs are configured
ixgbe: Do not return 0 in ixgbe_fcoe_ddp() upon FCP_RSP in DDP completion
netxen: free napi resources during detach
netxen: remove netxen workqueue
ixgbe: fix issues setting rx-usecs with legacy interrupts
can: fix oops caused by wrong rtnl newlink usage
In 5e140dfc1fe87eae27846f193086724806b33c7d "net: reorder struct Qdisc
for better SMP performance" the definition of struct gnet_stats_basic
changed incompatibly, as copies of this struct are shipped to
userland via netlink.
Restoring old behavior is not welcome, for performance reason.
Fix is to use a private structure for kernel, and
teach gnet_stats_copy_basic() to convert from kernel to user land,
using legacy structure (struct gnet_stats_basic)
Based on a report and initial patch from Michael Spang.
Reported-by: Michael Spang <mspang@csclub.uwaterloo.ca>
The static variable used by nr_call_to_digi might result in corruption if
multiple threads are trying to usee a node or neighbour via ioctl. Fixed
by having the caller pass a structure in. This is safe because nr_add_node
rsp. nr_add_neigh will allocate a permanent structure, if needed.
A looney tunes server sending an invalid error code (which is !IS_ERR_VALUE)
can result in a client oops. So fix it by adding a check and converting unknown
or invalid error codes to -ESERVERFAULT.
Signed-off-by: Abhishek Kulkarni <adkulkar@umail.iu.edu>
Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
Fix the comments -- mostly the improper and/or missing descriptions
of function parameters.
The key todo lock can be taken from different locks
that require it to be _bh to avoid lock inversion
due to (soft)irqs.
This should fix the two problems reported by Bob and
Gabor:
http://mid.gmane.org/20090619113049.GB18956@hash.localnet
http://mid.gmane.org/4A3FA376.8020307@openwrt.org
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Cc: Bob Copeland <me@bobcopeland.com>
Cc: Gabor Juhos <juhosg@openwrt.org>
The GRE header length should be subtracted when the tunnel MTU is
calculated. This just corrects for the associativity change
introduced by commit 42aa916265d740d66ac1f17290366e9494c884c2
("gre: Move MTU setting out of ipgre_tunnel_bind_dev").
Signed-off-by: Tom Goff <thomas.goff@boeing.com>
We splice skbs from the pending queue for a TID
onto the local pending queue when tearing down a
block ack request. This is not necessary unless we
actually have received a request to start a block ack
request (rate control, for example). If we never received
that request we should not be splicing the tid pending
queue as it would be null, causing a panic.
Not sure yet how exactly we allowed through a call when the
tid state does not have at least HT_ADDBA_REQUESTED_MSK set,
that will require some further review as it is not quite
obvious.
For more information see the bug report:
http://bugzilla.kernel.org/show_bug.cgi?id=13922
This fixes this oops:
BUG: unable to handle kernel NULL pointer dereference at 00000030
IP: [<f8806c70>] ieee80211_agg_splice_packets+0x40/0xc0 [mac80211]
*pdpt = 0000000002d1e001 *pde = 0000000000000000
Thread overran stack, or stack corrupted
Oops: 0000 [#1] SMP
last sysfs file: /sys/module/aes_generic/initstate
Modules linked in: <bleh>
Pid: 0, comm: swapper Not tainted (2.6.31-rc5-wl #2) Dell DV051
EIP: 0060:[<f8806c70>] EFLAGS: 00010292 CPU: 0
EIP is at ieee80211_agg_splice_packets+0x40/0xc0 [mac80211]
EAX: 00000030 EBX: 0000004c ECX: 00000003 EDX: 00000000
ESI: c1c98000 EDI: f745a1c0 EBP: c076be58 ESP: c076be38
DS: 007b ES: 007b FS: 00d8 GS: 0000 SS: 0068
Process swapper (pid: 0, ti=c076a000 task=c0709160 task.ti=c076a000)
Stack: <bleh2>
Call Trace:
[<f8806edb>] ? ieee80211_stop_tx_ba_cb+0xab/0x150 [mac80211]
[<f8802f1e>] ? ieee80211_tasklet_handler+0xce/0x110 [mac80211]
[<c04862ff>] ? net_rx_action+0xef/0x1d0
[<c0149378>] ? tasklet_action+0x58/0xc0
[<c014a0f2>] ? __do_softirq+0xc2/0x190
[<c018eb48>] ? handle_IRQ_event+0x58/0x140
[<c01205fe>] ? ack_apic_level+0x7e/0x270
[<c014a1fd>] ? do_softirq+0x3d/0x40
[<c014a345>] ? irq_exit+0x65/0x90
[<c010a6af>] ? do_IRQ+0x4f/0xc0
[<c014a35d>] ? irq_exit+0x7d/0x90
[<c011d547>] ? smp_apic_timer_interrupt+0x57/0x90
[<c01094a9>] ? common_interrupt+0x29/0x30
[<c010fd9e>] ? mwait_idle+0xbe/0x100
[<c0107e42>] ? cpu_idle+0x52/0x90
[<c054b1a5>] ? rest_init+0x55/0x60
[<c077492d>] ? start_kernel+0x315/0x37d
[<c07743ce>] ? unknown_bootoption+0x0/0x1f9
[<c0774099>] ? i386_start_kernel+0x79/0x81
Code: <bleh3>
EIP: [<f8806c70>] ieee80211_agg_splice_packets+0x40/0xc0 [mac80211] SS:ESP 0068:c076be38
CR2: 0000000000000030
Testedy-by: Jack Lau <jackelectronics@hotmail.com>
Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com>
kernel_sendpage() does the proper default case handling for when the
socket doesn't have a native sendpage implementation.
Now, arguably this might be something that we could instead solve by
just specifying that all protocols should do it themselves at the
protocol level, but we really only care about the common protocols.
Does anybody really care about sendpage on something like Appletalk? Not
likely.
Acked-by: Julien TINNES <julien@cr0.org>
Acked-by: Tavis Ormandy <taviso@sdf.lonestar.org>
Commit 1748376b6626acf59c24e9592ac67b3fe2a0e026,
net: Use a percpu_counter for sockets_allocated
added percpu_counter function calls to sctp_proc_init code path, but
forgot to add them to sctp_proc_exit(). This resulted in a following
Ooops when performing this test
# modprobe sctp
# rmmod -f sctp
# modprobe sctp
[ 573.862512] BUG: unable to handle kernel paging request at f8214a24
[ 573.862518] IP: [<c0308b8f>] __percpu_counter_init+0x3f/0x70
[ 573.862530] *pde = 37010067 *pte = 00000000
[ 573.862534] Oops: 0002 [#1] SMP
[ 573.862537] last sysfs file: /sys/module/libcrc32c/initstate
[ 573.862540] Modules linked in: sctp(+) crc32c libcrc32c binfmt_misc bridge
stp bnep lp snd_hda_codec_analog snd_hda_intel snd_hda_codec snd_hwdep
snd_pcm_oss snd_mixer_oss arc4 joydev snd_pcm ecb pcmcia snd_seq_dummy
snd_seq_oss iwlagn iwlcore snd_seq_midi snd_rawmidi snd_seq_midi_event
yenta_socket rsrc_nonstatic thinkpad_acpi snd_seq snd_timer snd_seq_device
mac80211 psmouse sdhci_pci sdhci nvidia(P) ppdev video snd soundcore serio_raw
pcspkr iTCO_wdt iTCO_vendor_support led_class ricoh_mmc pcmcia_core intel_agp
nvram agpgart usbhid parport_pc parport output snd_page_alloc cfg80211 btusb
ohci1394 ieee1394 e1000e [last unloaded: sctp]
[ 573.862589]
[ 573.862593] Pid: 5373, comm: modprobe Tainted: P R (2.6.31-rc3 #6)
7663B15
[ 573.862596] EIP: 0060:[<c0308b8f>] EFLAGS: 00010286 CPU: 1
[ 573.862599] EIP is at __percpu_counter_init+0x3f/0x70
[ 573.862602] EAX: f8214a20 EBX: f80faa14 ECX: c48c0000 EDX: f80faa20
[ 573.862604] ESI: f80a7000 EDI: 00000000 EBP: f69d5ef0 ESP: f69d5eec
[ 573.862606] DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068
[ 573.862610] Process modprobe (pid: 5373, ti=f69d4000 task=c2130c70
task.ti=f69d4000)
[ 573.862612] Stack:
[ 573.862613] 00000000 f69d5f18 f80a70a8 f80fa9fc 00000000 fffffffc f69d5f30
c018e2d4
[ 573.862619] <0> 00000000 f80a7000 00000000 f69d5f88 c010112b 00000000
c07029c0 fffffffb
[ 573.862626] <0> 00000000 f69d5f38 c018f83f f69d5f54 c0557cad f80fa860
00000001 c07010c0
[ 573.862634] Call Trace:
[ 573.862644] [<f80a70a8>] ? sctp_init+0xa8/0x7d4 [sctp]
[ 573.862650] [<c018e2d4>] ? marker_update_probe_range+0x184/0x260
[ 573.862659] [<f80a7000>] ? sctp_init+0x0/0x7d4 [sctp]
[ 573.862662] [<c010112b>] ? do_one_initcall+0x2b/0x160
[ 573.862666] [<c018f83f>] ? tracepoint_module_notify+0x2f/0x40
[ 573.862671] [<c0557cad>] ? notifier_call_chain+0x2d/0x70
[ 573.862678] [<c01588fd>] ? __blocking_notifier_call_chain+0x4d/0x60
[ 573.862682] [<c016b2f1>] ? sys_init_module+0xb1/0x1f0
[ 573.862686] [<c0102ffc>] ? sysenter_do_call+0x12/0x28
[ 573.862688] Code: 89 48 08 b8 04 00 00 00 e8 df aa ec ff ba f4 ff ff ff 85
c0 89 43 14 74 31 b8 b0 18 71 c0 e8 19 b9 24 00 a1 c4 18 71 c0 8d 53 0c <89> 50
04 89 43 0c b8 b0 18 71 c0 c7 43 10 c4 18 71 c0 89 15 c4
[ 573.862725] EIP: [<c0308b8f>] __percpu_counter_init+0x3f/0x70 SS:ESP
0068:f69d5eec
[ 573.862730] CR2: 00000000f8214a24
[ 573.862734] ---[ end trace 39c4e0b55e7cf54d ]---
Signed-off-by: Rafael Laufer <rlaufer@cisco.com>
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
raw_getname() can leak 10 bytes of kernel memory to user
(two bytes hole between can_family and can_ifindex,
8 bytes at the end of sockaddr_can structure)
Acked-by: Oliver Hartkopp <oliver@hartkopp.net>
addresses with addition
This patch fixes hash collisions in cases where number
of entries have incrementing IP source and destination addresses
from single respective subnets (i.e. 192.168.0.1-172.16.0.1,
192.168.0.2-172.16.0.2, and so on.).
Signed-off-by: Jussi Maki <joamaki@gmail.com>
net: Fix spinlock use in alloc_netdev_mq()
git://git.kernel.org/pub/scm/linux/kernel/git/lowpan/lowpan
irda_getname() can leak kernel memory to user.
atalk_getname() can leak 8 bytes of kernel memory to user
nr_getname() can leak kernel memory to user.
econet_getname() can leak kernel memory to user.
rose_getname() can leak kernel memory to user.
Provide dummt get/setsockopt implementations to stop these
syscalls from oopsing on our sockets.
Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
fix two errors in ioctl processing:
1) if the ioctl isn't supported one should return -ENOIOCTLCMD
2) don't call ndo_do_ioctl if the device doesn't provide it
net/phonet/pn_dev.c: In function `phonet_device_get':
net/phonet/pn_dev.c:99: warning: 'dev' might be used uninitialized in this function
Acked-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com>
percpu counter dccp_orphan_count is init in dccp_init() by
percpu_counter_init() while dccp module is loaded, but the
destroy of it is missing while dccp module is unloaded. We
can get the kernel WARNING about this. Reproduct by the
following commands:
$ modprobe dccp
$ rmmod dccp
$ modprobe dccp
WARNING: at lib/list_debug.c:26 __list_add+0x27/0x5c()
Hardware name: VMware Virtual Platform
list_add corruption. next->prev should be prev (c080c0c4), but was (null). (next
=ca7188cc).
Modules linked in: dccp(+) nfsd lockd nfs_acl auth_rpcgss exportfs sunrpc
Pid: 1956, comm: modprobe Not tainted 2.6.31-rc5 #55
Call Trace:
[<c042f8fa>] warn_slowpath_common+0x6a/0x81
[<c053a6cb>] ? __list_add+0x27/0x5c
[<c042f94f>] warn_slowpath_fmt+0x29/0x2c
[<c053a6cb>] __list_add+0x27/0x5c
[<c053c9b3>] __percpu_counter_init+0x4d/0x5d
[<ca9c90c7>] dccp_init+0x19/0x2ed [dccp]
[<c0401141>] do_one_initcall+0x4f/0x111
[<ca9c90ae>] ? dccp_init+0x0/0x2ed [dccp]
[<c06971b5>] ? notifier_call_chain+0x26/0x48
[<c0444943>] ? __blocking_notifier_call_chain+0x45/0x51
[<c04516f7>] sys_init_module+0xac/0x1bd
[<c04028e4>] sysenter_do_call+0x12/0x22
Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com>
-tip testing found this lockdep warning:
[ 2.272010] calling net_dev_init+0x0/0x164 @ 1
[ 2.276033] device class 'net': registering
[ 2.280191] INFO: trying to register non-static key.
[ 2.284005] the code is fine but needs lockdep annotation.
[ 2.284005] turning off the locking correctness validator.
[ 2.284005] Pid: 1, comm: swapper Not tainted 2.6.31-rc5-tip #1145
[ 2.284005] Call Trace:
[ 2.284005] [<7958eb4e>] ? printk+0xf/0x11
[ 2.284005] [<7904f83c>] __lock_acquire+0x11b/0x622
[ 2.284005] [<7908c9b7>] ? alloc_debug_processing+0xf9/0x144
[ 2.284005] [<7904e2be>] ? mark_held_locks+0x3a/0x52
[ 2.284005] [<7908dbc4>] ? kmem_cache_alloc+0xa8/0x13f
[ 2.284005] [<7904e475>] ? trace_hardirqs_on_caller+0xa2/0xc3
[ 2.284005] [<7904fdf6>] lock_acquire+0xb3/0xd0
[ 2.284005] [<79489678>] ? alloc_netdev_mq+0xf5/0x1ad
[ 2.284005] [<79591514>] _spin_lock_bh+0x2d/0x5d
[ 2.284005] [<79489678>] alloc_netdev_mq+0xf5/0x1ad
[ 2.284005] [<793a38f2>] ? loopback_setup+0x0/0x74
[ 2.284005] [<798eecd0>] loopback_net_init+0x20/0x5d
[ 2.284005] [<79483efb>] register_pernet_device+0x23/0x4b
[ 2.284005] [<798f5c9f>] net_dev_init+0x115/0x164
[ 2.284005] [<7900104f>] do_one_initcall+0x4a/0x11a
[ 2.284005] [<798f5b8a>] ? net_dev_init+0x0/0x164
[ 2.284005] [<79066f6d>] ? register_irq_proc+0x8c/0xa8
[ 2.284005] [<798cc29a>] do_basic_setup+0x42/0x52
[ 2.284005] [<798cc30a>] kernel_init+0x60/0xa1
[ 2.284005] [<798cc2aa>] ? kernel_init+0x0/0xa1
[ 2.284005] [<79003e03>] kernel_thread_helper+0x7/0x10
[ 2.284078] device: 'lo': device_add
[ 2.288248] initcall net_dev_init+0x0/0x164 returned 0 after 11718 usecs
[ 2.292010] calling neigh_init+0x0/0x66 @ 1
[ 2.296010] initcall neigh_init+0x0/0x66 returned 0 after 0 usecs
it's using an zero-initialized spinlock. This is a side-effect of:
dev_unicast_init(dev);
in alloc_netdev_mq() making use of dev->addr_list_lock.
The device has just been allocated freshly, it's not accessible
anywhere yet so no locking is needed at all - in fact it's wrong
to lock it here (the lock isnt initialized yet).
This bug was introduced via:
| commit a6ac65db2329e7685299666f5f7b6093c7b0f3a0
| Date: Thu Jul 30 01:06:12 2009 +0000
| net: restore the original spinlock to protect unicast list
Acked-by: Jiri Pirko <jpirko@redhat.com>
Tested-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (47 commits)
ehea: Fix napi list corruption on ifconfig down
igbvf: Allow VF driver to correctly recognize failure to set mac
3c59x: Fix build failure with gcc 3.2
sky2: Avoid transmits during sky2_down()
iwlagn: do not send key clear commands when rfkill enabled
libertas: Read buffer overflow
drivers/net/wireless: introduce missing kfree
drivers/net/wireless/iwlwifi: introduce missing kfree
zd1211rw: fix unaligned access in zd_mac_rx
cfg80211: fix regression on beacon world roaming feature
cfg80211: add two missing NULL pointer checks
ixgbe: Patch to modify 82598 PCIe completion timeout values
bluetooth: rfcomm_init bug fix
mlx4_en: Fix double pci unmapping.
mISDN: Fix handling of receive buffer size in L1oIP
pcnet32: VLB support fixes
pcnet32: remove superfluous NULL pointer check in pcnet32_probe1()
netxen: fix coherent dma mask setting
mISDN: Read buffer overflow
A regression was added through patch a4ed90d6:
"cfg80211: respect API on orig_flags on channel for beacon hint"
We did indeed respect _orig flags but the intention was not clearly
stated in the commit log. This patch fixes firmware issues picked
up by iwlwifi when we lift passive scan of beaconing restrictions
on channels its EEPROM has been configured to always enable.
By doing so though we also disallowed beacon hints on devices
registering their wiphy with custom world regulatory domains
enabled, this happens to be currently ath5k, ath9k and ar9170.
The passive scan and beacon restrictions on those devices would
never be lifted even if we did find a beacon and the hardware did
support such enhancements when world roaming.
Since Johannes indicates iwlwifi firmware cannot be changed to
allow beacon hinting we set up a flag now to specifically allow
drivers to disable beacon hints for devices which cannot use them.
We enable the flag on iwlwifi to disable beacon hints and by default
enable it for all other drivers. It should be noted beacon hints lift
passive scan flags and beacon restrictions when we receive a beacon from
an AP on any 5 GHz non-DFS channels, and channels 12-14 on the 2.4 GHz
band. We don't bother with channels 1-11 as those channels are allowed
world wide.
This should fix world roaming for ath5k, ath9k and ar9170, thereby
improving scan time when we receive the first beacon from any AP,
and also enabling beaconing operation (AP/IBSS/Mesh) on cards which
would otherwise not be allowed to do so. Drivers not using custom
regulatory stuff (wiphy_apply_custom_regulatory()) were not affected
by this as the orig_flags for the channels would have been cleared
upon wiphy registration.
I tested this with a world roaming ath5k card.
Cc: Jouni Malinen <jouni.malinen@atheros.com>
Reviewed-by: Johannes Berg <johannes@sipsolutions.net>
These pointers can be NULL, the is_mesh() case isn't
ever hit in the current kernel, but cmp_ies() can be
hit under certain conditions.
Cc: stable@kernel.org [2.6.29, 2.6.30]
rfcomm tty may be used before rfcomm_tty_driver initilized,
The problem is that now socket layer init before tty layer, if userspace
program do socket callback right here then oops will happen.
reporting in:
http://marc.info/?l=linux-bluetooth&m=124404919324542&w=2
make 3 changes:
1. remove #ifdef in rfcomm/core.c,
make it blank function when rfcomm tty not selected in rfcomm.h
2. tune the rfcomm_init error patch to ensure
tty driver initilized before rfcomm socket usage.
3. remove __exit for rfcomm_cleanup_sockets
because above change need call it in a __init function.
Reported-by: Oliver Hartkopp <oliver@hartkopp.net>
Tested-by: Oliver Hartkopp <oliver@hartkopp.net>
Signed-off-by: Dave Young <hidave.darkstar@gmail.com>
There is a path when an assetion in dev_unicast_sync() appears.
igmp6_group_added -> dev_mc_add -> __dev_set_rx_mode ->
-> vlan_dev_set_rx_mode -> dev_unicast_sync
Therefore we cannot protect this list with rtnl. This patch restores the
original protecting this list with spinlock.
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
Tested-by: Meelis Roos <mroos@linux.ee>
