path: root/net
2012-09-21net: change return values from -EACCES to -EPERMZhao Hongjiang
Change return value from -EACCES to -EPERM when the permission check fails. Signed-off-by: Zhao Hongjiang <zhaohongjiang@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-21ipv6: fix return value check in fib6_add()Wei Yongjun
In case of error, the function fib6_add_1() returns ERR_PTR() or NULL pointer. The ERR_PTR() case check is missing in fib6_add(). dpatch engine is used to generated this patch. (https://github.com/weiyj/dpatch) Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-20net: do not disable sg for packets requiring no checksumEd Cashin
A change in a series of VLAN-related changes appears to have inadvertently disabled the use of the scatter gather feature of network cards for transmission of non-IP ethernet protocols like ATA over Ethernet (AoE). Below is a reference to the commit that introduces a "harmonize_features" function that turns off scatter gather when the NIC does not support hardware checksumming for the ethernet protocol of an sk buff. commit f01a5236bd4b140198fbcc550f085e8361fd73fa Author: Jesse Gross <jesse@nicira.com> Date: Sun Jan 9 06:23:31 2011 +0000 net offloading: Generalize netif_get_vlan_features(). The can_checksum_protocol function is not equipped to consider a protocol that does not require checksumming. Calling it for a protocol that requires no checksum is inappropriate. The patch below has harmonize_features call can_checksum_protocol when the protocol needs a checksum, so that the network layer is not forced to perform unnecessary skb linearization on the transmission of AoE packets. Unnecessary linearization results in decreased performance and increased memory pressure, as reported here: http://www.spinics.net/lists/linux-mm/msg15184.html The problem has probably not been widely experienced yet, because only recently has the kernel.org-distributed aoe driver acquired the ability to use payloads of over a page in size, with the patchset recently included in the mm tree: https://lkml.org/lkml/2012/8/28/140 The coraid.com-distributed aoe driver already could use payloads of greater than a page in size, but its users generally do not use the newest kernels. Signed-off-by: Ed Cashin <ecashin@coraid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-20xfrm_user: don't copy esn replay window twice for new statesMathias Krause
The ESN replay window was already fully initialized in xfrm_alloc_replay_state_esn(). No need to copy it again. Cc: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Mathias Krause <minipli@googlemail.com> Acked-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-20xfrm_user: ensure user supplied esn replay window is validMathias Krause
The current code fails to ensure that the netlink message actually contains as many bytes as the header indicates. If a user creates a new state or updates an existing one but does not supply the bytes for the whole ESN replay window, the kernel copies random heap bytes into the replay bitmap, the ones happen to follow the XFRMA_REPLAY_ESN_VAL netlink attribute. This leads to following issues: 1. The replay window has random bits set confusing the replay handling code later on. 2. A malicious user could use this flaw to leak up to ~3.5kB of heap memory when she has access to the XFRM netlink interface (requires CAP_NET_ADMIN). Known users of the ESN replay window are strongSwan and Steffen's iproute2 patch (<http://patchwork.ozlabs.org/patch/85962/>). The latter uses the interface with a bitmap supplied while the former does not. strongSwan is therefore prone to run into issue 1. To fix both issues without breaking existing userland allow using the XFRMA_REPLAY_ESN_VAL netlink attribute with either an empty bitmap or a fully specified one. For the former case we initialize the in-kernel bitmap with zero, for the latter we copy the user supplied bitmap. For state updates the full bitmap must be supplied. To prevent overflows in the bitmap length calculation the maximum size of bmp_len is limited to 128 by this patch -- resulting in a maximum replay window of 4096 packets. This should be sufficient for all real life scenarios (RFC 4303 recommends a default replay window size of 64). Cc: Steffen Klassert <steffen.klassert@secunet.com> Cc: Martin Willi <martin@revosec.ch> Cc: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-20xfrm_user: fix info leak in copy_to_user_tmpl()Mathias Krause
The memory used for the template copy is a local stack variable. As struct xfrm_user_tmpl contains multiple holes added by the compiler for alignment, not initializing the memory will lead to leaking stack bytes to userland. Add an explicit memset(0) to avoid the info leak. Initial version of the patch by Brad Spengler. Cc: Brad Spengler <spender@grsecurity.net> Signed-off-by: Mathias Krause <minipli@googlemail.com> Acked-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-20xfrm_user: fix info leak in copy_to_user_policy()Mathias Krause
The memory reserved to dump the xfrm policy includes multiple padding bytes added by the compiler for alignment (padding bytes in struct xfrm_selector and struct xfrm_userpolicy_info). Add an explicit memset(0) before filling the buffer to avoid the heap info leak. Signed-off-by: Mathias Krause <minipli@googlemail.com> Acked-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-20xfrm_user: fix info leak in copy_to_user_state()Mathias Krause
The memory reserved to dump the xfrm state includes the padding bytes of struct xfrm_usersa_info added by the compiler for alignment (7 for amd64, 3 for i386). Add an explicit memset(0) before filling the buffer to avoid the info leak. Signed-off-by: Mathias Krause <minipli@googlemail.com> Acked-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-20xfrm_user: fix info leak in copy_to_user_auth()Mathias Krause
copy_to_user_auth() fails to initialize the remainder of alg_name and therefore discloses up to 54 bytes of heap memory via netlink to userland. Use strncpy() instead of strcpy() to fill the trailing bytes of alg_name with null bytes. Signed-off-by: Mathias Krause <minipli@googlemail.com> Acked-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-20tcp: restore rcv_wscale in a repair mode (v2)Andrey Vagin
rcv_wscale is a symetric parameter with snd_wscale. Both this parameters are set on a connection handshake. Without this value a remote window size can not be interpreted correctly, because a value from a packet should be shifted on rcv_wscale. And one more thing is that wscale_ok should be set too. This patch doesn't break a backward compatibility. If someone uses it in a old scheme, a rcv window will be restored with the same bug (rcv_wscale = 0). v2: Save backward compatibility on big-endian system. Before the first two bytes were snd_wscale and the second two bytes were rcv_wscale. Now snd_wscale is opt_val & 0xFFFF and rcv_wscale >> 16. This approach is independent on byte ordering. Cc: David S. Miller <davem@davemloft.net> Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Cc: James Morris <jmorris@namei.org> Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Cc: Patrick McHardy <kaber@trash.net> CC: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: Andrew Vagin <avagin@openvz.org> Acked-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-19net/core: fix comment in skb_try_coalesceLi RongQing
It should be the skb which is not cloned Signed-off-by: Li RongQing <roy.qing.li@gmail.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-19pkt_sched: fix virtual-start-time update in QFQPaolo Valente
If the old timestamps of a class, say cl, are stale when the class becomes active, then QFQ may assign to cl a much higher start time than the maximum value allowed. This may happen when QFQ assigns to the start time of cl the finish time of a group whose classes are characterized by a higher value of the ratio max_class_pkt/weight_of_the_class with respect to that of cl. Inserting a class with a too high start time into the bucket list corrupts the data structure and may eventually lead to crashes. This patch limits the maximum start time assigned to a class. Signed-off-by: Paolo Valente <paolo.valente@unimore.it> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-19tcp: flush DMA queue before sk_wait_data if rcv_wnd is zeroMichal Kubeček
If recv() syscall is called for a TCP socket so that - IOAT DMA is used - MSG_WAITALL flag is used - requested length is bigger than sk_rcvbuf - enough data has already arrived to bring rcv_wnd to zero then when tcp_recvmsg() gets to calling sk_wait_data(), receive window can be still zero while sk_async_wait_queue exhausts enough space to keep it zero. As this queue isn't cleaned until the tcp_service_net_dma() call, sk_wait_data() cannot receive any data and blocks forever. If zero receive window and non-empty sk_async_wait_queue is detected before calling sk_wait_data(), process the queue first. Signed-off-by: Michal Kubecek <mkubecek@suse.cz> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-19batman-adv: make batadv_test_bit() return 0 or 1 onlyLinus Lüssing
On some architectures test_bit() can return other values than 0 or 1: With a generic x86 OpenWrt image in a kvm setup (batadv_)test_bit() frequently returns -1 for me, leading to batadv_iv_ogm_update_seqnos() wrongly signaling a protected seqno window. This patch tries to fix this issue by making batadv_test_bit() return 0 or 1 only. Signed-off-by: Linus Lüssing <linus.luessing@web.de> Acked-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Antonio Quartulli <ordex@autistici.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-18xfrm: fix a read lock imbalance in make_blackholeLi RongQing
if xfrm_policy_get_afinfo returns 0, it has already released the read lock, xfrm_policy_put_afinfo should not be called again. Signed-off-by: Li RongQing <roy.qing.li@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-18tcp: fix regression in urgent data handlingEric Dumazet
Stephan Springl found that commit 1402d366019fed "tcp: introduce tcp_try_coalesce" introduced a regression for rlogin It turns out problem comes from TCP urgent data handling and a change in behavior in input path. rlogin sends two one-byte packets with URG ptr set, and when next data frame is coalesced, we lack sk_data_ready() calls to wakeup consumer. Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Stephan Springl <springl-k@lar.bfw.de> Cc: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-18net: fix memory leak on oom with zerocopyMichael S. Tsirkin
If orphan flags fails, we don't free the skb on receive, which leaks the skb memory. Return value was also wrong: netif_receive_skb is supposed to return NET_RX_DROP, not ENOMEM. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-18xfrm_user: return error pointer instead of NULL #2Mathias Krause
When dump_one_policy() returns an error, e.g. because of a too small buffer to dump the whole xfrm policy, xfrm_policy_netlink() returns NULL instead of an error pointer. But its caller expects an error pointer and therefore continues to operate on a NULL skbuff. Signed-off-by: Mathias Krause <minipli@googlemail.com> Acked-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-18xfrm_user: return error pointer instead of NULLMathias Krause
When dump_one_state() returns an error, e.g. because of a too small buffer to dump the whole xfrm state, xfrm_state_netlink() returns NULL instead of an error pointer. But its callers expect an error pointer and therefore continue to operate on a NULL skbuff. This could lead to a privilege escalation (execution of user code in kernel context) if the attacker has CAP_NET_ADMIN and is able to map address 0. Signed-off-by: Mathias Krause <minipli@googlemail.com> Acked-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-18ipv6: use DST_* macro to set obselete fieldNicolas Dichtel
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-18ipv6: use net->rt_genid to check dst validityNicolas Dichtel
IPv6 dst should take care of rt_genid too. When a xfrm policy is inserted or deleted, all dst should be invalidated. To force the validation, dst entries should be created with ->obsolete set to DST_OBSOLETE_FORCE_CHK. This was already the case for all functions calling ip6_dst_alloc(), except for ip6_rt_copy(). As a consequence, we can remove the specific code in inet6_connection_sock. Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-18xfrm: invalidate dst on policy insertion/deletionNicolas Dichtel
When a policy is inserted or deleted, all dst should be recalculated. Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-18netns: move net->ipv4.rt_genid to net->rt_genidNicolas Dichtel
This commit prepares the use of rt_genid by both IPv4 and IPv6. Initialization is left in IPv4 part. Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-18net: rt_cache_flush() cleanupEric Dumazet
We dont use jhash anymore since route cache removal, so we can get rid of get_random_bytes() calls for rt_genid changes. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-18ipv4/route: arg delay is useless in rt_cache_flush()Nicolas Dichtel
Since route cache deletion (89aef8921bfbac22f), delay is no more used. Remove it. Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Use after free and new device IDs in bluetooth from Andre Guedes, Yevgeniy Melnichuk, Gustavo Padovan, and Henrik Rydberg. 2) Fix crashes with short packet lengths and VLAN in pktgen, from Nishank Trivedi. 3) mISDN calls flush_work_sync() with locks held, fix from Karsten Keil. 4) Packet scheduler gred parameters are reported to userspace improperly scaled, and WRED idling is not performed correctly. All from David Ward. 5) Fix TCP socket refcount problem in ipv6, from Julian Anastasov. 6) ibmveth device has RX queue alignment requirements which are not being explicitly met resulting in sporadic failures, fix from Santiago Leon. 7) Netfilter needs to take care when interpreting sockets attached to socket buffers, they could be time-wait minisockets. Fix from Eric Dumazet. 8) sock_edemux() has the same issue as netfilter did in #7 above, fix from Eric Dumazet. 9) Avoid infinite loops in CBQ scheduler with some configurations, from Eric Dumazet. 10) Deal with "Reflection scan: an Off-Path Attack on TCP", from Jozsef Kadlecsik. 11) SCTP overcharges socket for TX packets, fix from Thomas Graf. 12) CODEL packet scheduler should not reset it's state every time it builds a new flow, fix from Eric Dumazet. 13) Fix memory leak in nl80211, from Wei Yongjun. 14) NETROM doesn't check skb_copy_datagram_iovec() return values, from Alan Cox. 15) l2tp ethernet was using sizeof(ETH_HLEN) instead of plain ETH_HLEN, oops. From Eric Dumazet. 16) Fix selection of ath9k chips on which PA linearization and AM2PM predistoration are used, from Felix Fietkau. 17) Flow steering settings in mlx4 driver need to be validated properly, from Hadar Hen Zion. 18) bnx2x doesn't show the correct link duplex setting, from Yaniv Rosner. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (75 commits) pktgen: fix crash with vlan and packet size less than 46 bnx2x: Add missing afex code bnx2x: fix registers dumped bnx2x: correct advertisement of pause capabilities bnx2x: display the correct duplex value bnx2x: prevent timeouts when using PFC bnx2x: fix stats copying logic bnx2x: Avoid sending multiple statistics queries net: qmi_wwan: call subdriver with control intf only net_sched: gred: actually perform idling in WRED mode net_sched: gred: fix qave reporting via netlink net_sched: gred: eliminate redundant DP prio comparisons net_sched: gred: correct comment about qavg calculation in RIO mode mISDN: Fix wrong usage of flush_work_sync while holding locks netfilter: log: Fix log-level processing net-sched: sch_cbq: avoid infinite loop net: qmi_wwan: fix Gobi device probing for un2430 net: fix net/core/sock.c build error ixp4xx_hss: fix build failure due to missing linux/module.h inclusion caif: move the dereference below the NULL test ...
2012-09-13pktgen: fix crash with vlan and packet size less than 46Nishank Trivedi
If vlan option is being specified in the pktgen and packet size being requested is less than 46 bytes, despite being illogical request, pktgen should not crash the kernel. BUG: unable to handle kernel paging request at ffff88021fb82000 Process kpktgend_0 (pid: 1184, threadinfo ffff880215f1a000, task ffff880218544530) Call Trace: [<ffffffffa0637cd2>] ? pktgen_finalize_skb+0x222/0x300 [pktgen] [<ffffffff814f0084>] ? build_skb+0x34/0x1c0 [<ffffffffa0639b11>] pktgen_thread_worker+0x5d1/0x1790 [pktgen] [<ffffffffa03ffb10>] ? igb_xmit_frame_ring+0xa30/0xa30 [igb] [<ffffffff8107ba20>] ? wake_up_bit+0x40/0x40 [<ffffffff8107ba20>] ? wake_up_bit+0x40/0x40 [<ffffffffa0639540>] ? spin+0x240/0x240 [pktgen] [<ffffffff8107b4e3>] kthread+0x93/0xa0 [<ffffffff81615de4>] kernel_thread_helper+0x4/0x10 [<ffffffff8107b450>] ? flush_kthread_worker+0x80/0x80 [<ffffffff81615de0>] ? gs_change+0x13/0x13 The root cause of why pktgen is not able to handle this case is due to comparison of signed (datalen) and unsigned data (sizeof), which eventually passes a huge number to skb_put(). Signed-off-by: Nishank Trivedi <nistrive@cisco.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-13net_sched: gred: actually perform idling in WRED modeDavid Ward
gred_dequeue() and gred_drop() do not seem to get called when the queue is empty, meaning that we never start idling while in WRED mode. And since qidlestart is not stored by gred_store_wred_set(), we would never stop idling while in WRED mode if we ever started. This messes up the average queue size calculation that influences packet marking/dropping behavior. Now, we start WRED mode idling as we are removing the last packet from the queue. Also we now actually stop WRED mode idling when we are enqueuing a packet. Cc: Bruce Osler <brosler@cisco.com> Signed-off-by: David Ward <david.ward@ll.mit.edu> Acked-by: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-13net_sched: gred: fix qave reporting via netlinkDavid Ward
q->vars.qavg is a Wlog scaled value, but q->backlog is not. In order to pass q->vars.qavg as the backlog value, we need to un-scale it. Additionally, the qave value returned via netlink should not be Wlog scaled, so we need to un-scale the result of red_calc_qavg(). This caused artificially high values for "Average Queue" to be shown by 'tc -s -d qdisc', but did not affect the actual operation of GRED. Signed-off-by: David Ward <david.ward@ll.mit.edu> Acked-by: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-13net_sched: gred: eliminate redundant DP prio comparisonsDavid Ward
Each pair of DPs only needs to be compared once when searching for a non-unique prio value. Signed-off-by: David Ward <david.ward@ll.mit.edu> Acked-by: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-13net_sched: gred: correct comment about qavg calculation in RIO modeDavid Ward
2012-09-13Merge branch 'master' of git://1984.lsi.us.es/nfDavid S. Miller
Pablo Neira Ayuso say: ==================== The following patchset contains four updates for your net tree, they are: * Fix crash on timewait sockets, since the TCP early demux was added, in nfnetlink_log, from Eric Dumazet. * Fix broken syslog log-level for xt_LOG and ebt_log since printk format was converted from <.> to a 2 bytes pattern using ASCII SOH, from Joe Perches. * Two security fixes for the TCP connection tracking targeting off-path attacks, from Jozsef Kadlecsik. The problem was discovered by Jan Wrobel and it is documented in: http://mixedbit.org/reflection_scan/reflection_scan.pdf. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-13Merge tag 'nfs-for-3.6-4' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client bugfixes from Trond Myklebust: - Final (hopefully) fix for the range checking code in NFSv4 getacl. This should fix the Oopses being seen when the acl size is close to PAGE_SIZE. - Fix a regression with the legacy binary mount code - Fix a regression in the readdir cookieverf initialisation - Fix an RPC over UDP regression - Ensure that we report all errors in the NFSv4 open code - Ensure that fsync() reports all relevant synchronisation errors. * tag 'nfs-for-3.6-4' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: NFS: fsync() must exit with an error if page writeback failed SUNRPC: Fix a UDP transport regression NFS: return error from decode_getfh in decode open NFSv4: Fix buffer overflow checking in __nfs4_get_acl_uncached NFSv4: Fix range checking in __nfs4_get_acl_uncached and __nfs4_proc_set_acl NFS: Fix a problem with the legacy binary mount code NFS: Fix the initialisation of the readdir 'cookieverf' array
2012-09-12netfilter: log: Fix log-level processingJoe Perches
auto75914331@hushmail.com reports that iptables does not correctly output the KERN_<level>. $IPTABLES -A RULE_0_in -j LOG --log-level notice --log-prefix "DENY in: " result with linux 3.6-rc5 Sep 12 06:37:29 xxxxx kernel: <5>DENY in: IN=eth0 OUT= MAC=....... result with linux 3.5.3 and older: Sep 9 10:43:01 xxxxx kernel: DENY in: IN=eth0 OUT= MAC...... commit 04d2c8c83d0 ("printk: convert the format for KERN_<LEVEL> to a 2 byte pattern") updated the syslog header style but did not update netfilter uses. Do so. Use KERN_SOH and string concatenation instead of "%c" KERN_SOH_ASCII as suggested by Eric Dumazet. Signed-off-by: Joe Perches <joe@perches.com> cc: auto75914331@hushmail.com Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2012-09-11net-sched: sch_cbq: avoid infinite loopEric Dumazet
Its possible to setup a bad cbq configuration leading to an infinite loop in cbq_classify() DEV_OUT=eth0 ICMP="match ip protocol 1 0xff" U32="protocol ip u32" DST="match ip dst" tc qdisc add dev $DEV_OUT root handle 1: cbq avpkt 1000 \ bandwidth 100mbit tc class add dev $DEV_OUT parent 1: classid 1:1 cbq \ rate 512kbit allot 1500 prio 5 bounded isolated tc filter add dev $DEV_OUT parent 1: prio 3 $U32 \ $ICMP $DST 192.168.3.234 flowid 1: Reported-by: Denys Fedoryschenko <denys@visp.net.lb> Tested-by: Denys Fedoryschenko <denys@visp.net.lb> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-10net: fix net/core/sock.c build errorRandy Dunlap
Fix net/core/sock.c build error when CONFIG_INET is not enabled: net/built-in.o: In function `sock_edemux': (.text+0xd396): undefined reference to `inet_twsk_put' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-10caif: move the dereference below the NULL testWei Yongjun
The dereference should be moved below the NULL test. spatch with a semantic match is used to found this. (http://coccinelle.lip6.fr/) Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-09netfilter: Validate the sequence number of dataless ACK packets as wellJozsef Kadlecsik
We spare nothing by not validating the sequence number of dataless ACK packets and enabling it makes harder off-path attacks. See: "Reflection scan: an Off-Path Attack on TCP" by Jan Wrobel, http://arxiv.org/abs/1201.2074 Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2012-09-09netfilter: Mark SYN/ACK packets as invalid from original directionJozsef Kadlecsik
Clients should not send such packets. By accepting them, we open up a hole by wich ephemeral ports can be discovered in an off-path attack. See: "Reflection scan: an Off-Path Attack on TCP" by Jan Wrobel, http://arxiv.org/abs/1201.2074 Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2012-09-08net: small bug on rxhash calculationChema Gonzalez
In the current rxhash calculation function, while the sorting of the ports/addrs is coherent (you get the same rxhash for packets sharing the same 4-tuple, in both directions), ports and addrs are sorted independently. This implies packets from a connection between the same addresses but crossed ports hash to the same rxhash. For example, traffic between A=S:l and B=L:s is hashed (in both directions) from {L, S, {s, l}}. The same rxhash is obtained for packets between C=S:s and D=L:l. This patch ensures that you either swap both addrs and ports, or you swap none. Traffic between A and B, and traffic between C and D, get their rxhash from different sources ({L, S, {l, s}} for A<->B, and {L, S, {s, l}} for C<->D) The patch is co-written with Eric Dumazet <edumazet@google.com> Signed-off-by: Chema Gonzalez <chema@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-07Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem John W. Linville says: ==================== Please pull these fixes intended for 3.6. There are more commits here than I would like -- I got a bit behind while I was stalking Steven Rostedt in San Diego last week... I'll slow it down after this! There are a couple of pulls here. One is from Johannes: "Please pull (according to the below information) to get a few fixes. * a fix to properly disconnect in the driver when authentication or association fails * a fix to prevent invalid information about mesh paths being reported to userspace * a memory leak fix in an nl80211 error path" The other comes via Gustavo: "A few updates for the 3.6 kernel. There are two btusb patches to add more supported devices through the new USB_VENDOR_AND_INTEFACE_INFO() macro and another one that add a new device id for a Sony Vaio laptop, one fix for a user-after-free and, finally, two patches from Vinicius to fix a issue in SMP pairing." Along with those... Arend van Spriel provides a fix for a use-after-free bug in brcmfmac. Daniel Drake avoids a hang by not trying to touch the libertas hardware duing suspend if it is already powered-down. Felix Fietkau provides a batch of ath9k fixes that adress some potential problems with power settings, as well as a fix to avoid a potential interrupt storm. Gertjan van Wingerde provides a register-width fix for rt2x00, and a rt2x00 fix to prevent incorrectly detecting the rfkill status. He also provides a device ID patch. Hante Meuleman gives us three brcmfmac fixes, one that properly initializes a command structure, one that fixes a race condition that could lose usb requests, and one that removes some log spam. Marc Kleine-Budde offers an rt2x00 fix for a voltage setting on some specific devices. Mohammed Shafi Shajakhan sent an ath9k fix to avoid a crash related to using timers that aren't allocated when 2 wire bluetooth coexistence hardware is in use. Sergei Poselenov changes rt2800usb to do some validity checking for received packets, avoiding crashes on an ARM Soc. Stone Piao gives us an mwifiex fix for an incorrectly set skb length value for a command buffer. All of these are localized to their specific drivers, and relatively small. The power-related patches from Felix are bigger than I would like, but I merged them in consideration of their isolation to ath9k and the sensitive nature of power settings in wireless devices. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-07udp: increment UDP_MIB_INERRORS if copy failedEric Dumazet
In UDP recvmsg(), we miss an increase of UDP_MIB_INERRORS if the copy of skb to userspace failed for whatever reason. Reported-by: Shawn Bohrer <sbohrer@rgmadvisors.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-07SUNRPC: Fix a UDP transport regressionTrond Myklebust
Commit 43cedbf0e8dfb9c5610eb7985d5f21263e313802 (SUNRPC: Ensure that we grab the XPRT_LOCK before calling xprt_alloc_slot) is causing hangs in the case of NFS over UDP mounts. Since neither the UDP or the RDMA transport mechanism use dynamic slot allocation, we can skip grabbing the socket lock for those transports. Add a new rpc_xprt_op to allow switching between the TCP and UDP/RDMA case. Note that the NFSv4.1 back channel assigns the slot directly through rpc_run_bc_task, so we can ignore that case. Reported-by: Dick Streefland <dick.streefland@altium.nl> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: stable@vger.kernel.org [>= 3.1]
2012-09-06netfilter: take care of timewait socketsEric Dumazet
Sami Farin reported crashes in xt_LOG because it assumes skb->sk is a full blown socket. Since (41063e9 ipv4: Early TCP socket demux), we can have skb->sk pointing to a timewait socket. Same fix is needed in nfnetlink_log. Diagnosed-by: Florian Westphal <fw@strlen.de> Reported-by: Sami Farin <hvtaifwkbgefbaei@gmail.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2012-09-05Fix order of arguments to compat_put_time[spec|val]Mikulas Patocka
Commit 644595f89620 ("compat: Handle COMPAT_USE_64BIT_TIME in net/socket.c") introduced a bug where the helper functions to take either a 64-bit or compat time[spec|val] got the arguments in the wrong order, passing the kernel stack pointer off as a user pointer (and vice versa). Because of the user address range check, that in turn then causes an EFAULT due to the user pointer range checking failing for the kernel address. Incorrectly resuling in a failed system call for 32-bit processes with a 64-bit kernel. On odder architectures like HP-PA (with separate user/kernel address spaces), it can be used read kernel memory. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-09-05tcp: fix possible socket refcount problem for ipv6Julian Anastasov
commit 144d56e91044181ec0ef67aeca91e9a8b5718348 ("tcp: fix possible socket refcount problem") is missing the IPv6 part. As tcp_release_cb is shared by both protocols we should hold sock reference for the TCP_MTU_REDUCED_DEFERRED bit. Signed-off-by: Julian Anastasov <ja@ssi.bg> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-05Merge branch 'for-john' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211
2012-09-05Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/bluetooth/bluetooth
2012-09-05mac80211: Various small fixes for cfg.c: mpath_set_pinfo()LEO Airwarosu Yoichi Shinoda
Various small fixes for net/mac80211/cfg.c:mpath_set_pinfo(): Initialize *pinfo before filling members in, handle MESH_PATH_RESOLVED correctly, and remove bogus assignment; result in correct display of FLAGS values and meaningful EXPTIME for expired paths in iw utility. Signed-off-by: Yoichi Shinoda <shinoda@jaist.ac.jp> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-09-04l2tp: fix a typo in l2tp_eth_dev_recv()Eric Dumazet
While investigating l2tp bug, I hit a bug in eth_type_trans(), because not enough bytes were pulled in skb head. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
