commit b88825de8545ad252c31543fef13cadf4de7a2bc upstream.
Fix possible replacement of the per-cpu chain counters by null
pointer when updating an existing chain in the commit path.
Reported-by: Matteo Croce <technoboy85@gmail.com>
commit eb90b0c734ad793d5f5bf230a9e9a4dcc48df8aa upstream.
commit fc604767613b6d2036cdc35b660bc39451040a47
("ipvs: changes for local real server") from 2.6.37
introduced DNAT support to local real server but the
IPv6 LOCAL_OUT handler ip_vs_local_reply6() is
registered incorrectly as IPv4 hook causing any outgoing
IPv4 traffic to be dropped depending on the IP header values.
Chris tracked down the problem to CONFIG_IP_VS_IPV6=y
Bug report: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1349768
Reported-by: Chris J Arges <chris.j.arges@canonical.com>
Tested-by: Chris J Arges <chris.j.arges@canonical.com>
Signed-off-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Simon Horman <horms@verge.net.au>
commit caa8ad94edf686d02b555c65a6162c0d1b434958 upstream.
There's actually no good reason why we cannot use cgroup id 0,
so lets just remove this artificial barrier.
Reported-by: Alexey Perevalov <a.perevalov@samsung.com>
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Tested-by: Alexey Perevalov <a.perevalov@samsung.com>
commit 76f084bc10004b3050b2cff9cfac29148f1f6088 upstream.
Previously, only the four high bits of the tclass were maintained in the
ipv6 case. This matches the behavior of ipv4, though whether or not we
should reflect ECN bits may be up for debate.
Signed-off-by: Alex Gartrell <agartrell@fb.com>
Acked-by: Julian Anastasov <ja@ssi.bg>
commit 7bd8490eef9776ced7632345df5133384b6be0fe upstream.
xt_hashlimit cannot be used with large hash tables, because garbage
collector is run from a timer. If table is really big, its possible
to hold cpu for more than 500 msec, which is unacceptable.
Switch to a work queue, and use proper scheduling points to remove
latencies spikes.
Later, we also could switch to a smoother garbage collection done
at lookup time, one bucket at a time...
Cc: Florian Westphal <fw@strlen.de>
Cc: Patrick McHardy <kaber@trash.net>
Reviewed-by: Florian Westphal <fw@strlen.de>
commit bd8c78e78d5011d8111bc2533ee73b13a3bd6c42 upstream.
In testmode and vendor command reply/event SKBs we use the
skb cb data to store nl80211 parameters between allocation
and sending. This causes the code for CONFIG_NETLINK_MMAP
to get confused, because it takes ownership of the skb cb
data when the SKB is handed off to netlink, and it doesn't
explicitly clear it.
Clear the skb cb explicitly when we're done and before it
gets passed to netlink to avoid this issue.
Reported-by: Assaf Azulay <assaf.azulay@intel.com>
Reported-by: David Spinadel <david.spinadel@intel.com>
commit bb512ad0732232f1d2693bb68f31a76bed8f22ae upstream.
This reverts commit 24aa11ab8ae03292d38ec0dbd9bc2ac49fe8a6dd.
That commit was wrong since it uses data that hasn't even been set
up yet, but might be a hold-over from a previous connection.
Additionally, it seems like a driver-specific workaround that
shouldn't have been in mac80211 to start with.
Fixes: 24aa11ab8ae0 ("mac80211: disable uAPSD if all ACs are under ACM")
Reviewed-by: Luciano Coelho <luciano.coelho@intel.com>
commit c27a3e4d667fdcad3db7b104f75659478e0c68d8 upstream.
We hard code cephx auth ticket buffer size to 256 bytes. This isn't
enough for any moderate setups and, in case tickets themselves are not
encrypted, leads to buffer overflows (ceph_x_decrypt() errors out, but
ceph_decode_copy() doesn't - it's just a memcpy() wrapper). Since the
buffer is allocated dynamically anyway, allocated it a bit later, at
the point where we know how much is going to be needed.
Fixes: http://tracker.ceph.com/issues/8979
Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com>
Reviewed-by: Sage Weil <sage@redhat.com>
commit 597cda357716a3cf8d994cb11927af917c8d71fa upstream.
Add a helper for processing individual cephx auth tickets. Needed for
the next commit, which deals with allocating ticket buffers. (Most of
the diff here is whitespace - view with git diff -b).
commit 73c3d4812b4c755efeca0140f606f83772a39ce4 upstream.
We preallocate a few of the message types we get back from the mon. If we
get a larger message than we are expecting, fall back to trying to allocate
a new one instead of blindly using the one we have.
Signed-off-by: Sage Weil <sage@redhat.com>
Reviewed-by: Ilya Dryomov <ilya.dryomov@inktank.com>
commit 5f740d7e1531099b888410e6bab13f68da9b1a4d upstream.
Determining ->last_piece based on the value of ->page_offset + length
is incorrect because length here is the length of the entire message.
->last_piece set to false even if page array data item length is <=
PAGE_SIZE, which results in invalid length passed to
ceph_tcp_{send,recv}page() and causes various asserts to fire.
# cat pages-cursor-init.sh
#!/bin/bash
rbd create --size 10 --image-format 2 foo
FOO_DEV=$(rbd map foo)
dd if=/dev/urandom of=$FOO_DEV bs=1M &>/dev/null
rbd snap create foo@snap
rbd snap protect foo@snap
rbd clone foo@snap bar
# rbd_resize calls librbd rbd_resize(), size is in bytes
./rbd_resize bar $(((4 << 20) + 512))
rbd resize --size 10 bar
BAR_DEV=$(rbd map bar)
# trigger a 512-byte copyup -- 512-byte page array data item
dd if=/dev/urandom of=$BAR_DEV bs=1M count=1 seek=5
The problem exists only in ceph_msg_data_pages_cursor_init(),
ceph_msg_data_pages_advance() does the right thing. The size_t cast is
unnecessary.
Reviewed-by: Alex Elder <elder@linaro.org>
commit 32333edb82fb2009980eefc5518100068147ab82 upstream.
The commits 08c30aca9e698faddebd34f81e1196295f9dc063 "Bluetooth: Remove
RFCOMM session refcnt" and 8ff52f7d04d9cc31f1e81dcf9a2ba6335ed34905
"Bluetooth: Return RFCOMM session ptrs to avoid freed session"
allow rfcomm_recv_ua and rfcomm_session_close to delete the session
(and free the corresponding socket) and propagate NULL session pointer
to the upper callers.
Additional fix is required to terminate the loop in rfcomm_process_rx
function to avoid use of freed 'sk' memory.
The issue is only reproducible with kernel option CONFIG_PAGE_POISONING
enabled making freed memory being changed and filled up with fixed char
value used to unmask use-after-free issues.
Signed-off-by: Vignesh Raman <Vignesh_Raman@mentor.com>
Signed-off-by: Vitaly Kuzmichev <Vitaly_Kuzmichev@mentor.com>
Acked-by: Dean Jenkins <Dean_Jenkins@mentor.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
commit 9f743d7499bc2c4dc8c35af33bdb2a29bea663b9 upstream.
Commit 6c53823ae0e10e723131055e1e65dd6a328a228e reshuffled the way the
authentication requirement gets set in the hci_io_capa_request_evt()
function, but at the same time it failed to update an if-statement where
cp.authentication is used before it has been initialized. The correct
value the code should be looking for in this if-statement is
conn->auth_type.
Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
commit 093facf3634da1b0c2cc7ed106f1983da901bbab upstream.
If the current process is exiting, lingering on socket close will make
it unkillable, so we should avoid it.
Reproducer:
#include <sys/types.h>
#include <sys/socket.h>
#define BTPROTO_L2CAP 0
#define BTPROTO_SCO 2
#define BTPROTO_RFCOMM 3
int main()
int fd;
struct linger ling;
fd = socket(PF_BLUETOOTH, SOCK_STREAM, BTPROTO_RFCOMM);
//or: fd = socket(PF_BLUETOOTH, SOCK_DGRAM, BTPROTO_L2CAP);
//or: fd = socket(PF_BLUETOOTH, SOCK_SEQPACKET, BTPROTO_SCO);
ling.l_onoff = 1;
ling.l_linger = 1000000000;
setsockopt(fd, SOL_SOCKET, SO_LINGER, &ling, sizeof(ling));
return 0;
Signed-off-by: Vladimir Davydov <vdavydov@parallels.com>
commit 6c53823ae0e10e723131055e1e65dd6a328a228e upstream.
When we need to make the decision whether to perform just-works or real
user confirmation we need to know the exact local authentication
requirement that was passed to the controller. So far conn->auth_type
(the local requirement) wasn't in one case updated appropriately in fear
of the user confirmation being rejected later.
The real problem however was not really that conn->auth_type couldn't
represent the true value but that we were checking the local MITM
requirement in an incorrect way. It's perfectly fine to let auth_type
follow what we tell the controller since we're still tracking the target
security level with conn->pending_sec_level.
This patch updates the check for local MITM requirement in the
hci_user_confirm_request_evt function to use the locally requested
security level and ensures that auth_type always represents what we tell
the controller. All other code in hci_user_confirm_request_evt still
uses the auth_type instead of pending_sec_level for determining whether
to do just-works or not, since that's the only value that's in sync with
what the remote device knows.
Tested-by: Szymon Janc <szymon.janc@tieto.com>
commit 42bd6a56ed1ab4b2cb50f4d4e674874da9b47f46 upstream.
The advertising data and scan response data are merged in the wrong
order. It should be advertsing data first and then scan response data
and not the other way around.
commit 3c45ddf823d679a820adddd53b52c6699c9a05ac upstream.
The current code always selects XPRT_TRANSPORT_BC_TCP for the back
channel, even when the forward channel was not TCP (eg, RDMA). When
a 4.1 mount is attempted with RDMA, the server panics in the TCP BC
code when trying to send CB_NULL.
Instead, construct the transport protocol number from the forward
channel transport or'd with XPRT_TRANSPORT_BC. Transports that do
not support bi-directional RPC will not have registered a "BC"
transport, causing create_backchannel_client() to fail immediately.
Fixes: https://bugzilla.linux-nfs.org/show_bug.cgi?id=265
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
[ Upstream commit 757efd32d5ce31f67193cc0e6a56e4dffcc42fb1 ]
Dave reported following splat, caused by improper use of
IP_INC_STATS_BH() in process context.
BUG: using __this_cpu_add() in preemptible [00000000] code: trinity-c117/14551
caller is __this_cpu_preempt_check+0x13/0x20
CPU: 3 PID: 14551 Comm: trinity-c117 Not tainted 3.16.0+ #33
ffffffff9ec898f0 0000000047ea7e23 ffff88022d32f7f0 ffffffff9e7ee207
0000000000000003 ffff88022d32f818 ffffffff9e397eaa ffff88023ee70b40
ffff88022d32f970 ffff8801c026d580 ffff88022d32f828 ffffffff9e397ee3
Call Trace:
[<ffffffff9e7ee207>] dump_stack+0x4e/0x7a
[<ffffffff9e397eaa>] check_preemption_disabled+0xfa/0x100
[<ffffffff9e397ee3>] __this_cpu_preempt_check+0x13/0x20
[<ffffffffc0839872>] sctp_packet_transmit+0x692/0x710 [sctp]
[<ffffffffc082a7f2>] sctp_outq_flush+0x2a2/0xc30 [sctp]
[<ffffffff9e0d985c>] ? mark_held_locks+0x7c/0xb0
[<ffffffff9e7f8c6d>] ? _raw_spin_unlock_irqrestore+0x5d/0x80
[<ffffffffc082b99a>] sctp_outq_uncork+0x1a/0x20 [sctp]
[<ffffffffc081e112>] sctp_cmd_interpreter.isra.23+0x1142/0x13f0 [sctp]
[<ffffffffc081c86b>] sctp_do_sm+0xdb/0x330 [sctp]
[<ffffffff9e0b8f1b>] ? preempt_count_sub+0xab/0x100
[<ffffffffc083b350>] ? sctp_cname+0x70/0x70 [sctp]
[<ffffffffc08389ca>] sctp_primitive_ASSOCIATE+0x3a/0x50 [sctp]
[<ffffffffc083358f>] sctp_sendmsg+0x88f/0xe30 [sctp]
[<ffffffff9e0d673a>] ? lock_release_holdtime.part.28+0x9a/0x160
[<ffffffff9e0d62ce>] ? put_lock_stats.isra.27+0xe/0x30
[<ffffffff9e73b624>] inet_sendmsg+0x104/0x220
[<ffffffff9e73b525>] ? inet_sendmsg+0x5/0x220
[<ffffffff9e68ac4e>] sock_sendmsg+0x9e/0xe0
[<ffffffff9e1c0c09>] ? might_fault+0xb9/0xc0
[<ffffffff9e1c0bae>] ? might_fault+0x5e/0xc0
[<ffffffff9e68b234>] SYSC_sendto+0x124/0x1c0
[<ffffffff9e0136b0>] ? syscall_trace_enter+0x250/0x330
[<ffffffff9e68c3ce>] SyS_sendto+0xe/0x10
[<ffffffff9e7f9be4>] tracesys+0xdd/0xe2
This is a followup of commits f1d8cba61c3c4b ("inet: fix possible
seqlock deadlocks") and 7f88c6b23afbd315 ("ipv6: fix possible seqlock
deadlock in ip6_finish_output2")
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
Reported-by: Dave Jones <davej@redhat.com>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
[ Upstream commit d9124268d84a836f14a6ead54ff9d8eee4c43be5 ]
batadv_frag_insert_packet was unable to handle out-of-order packets because it
dropped them directly. This is caused by the way the fragmentation lists is
checked for the correct place to insert a fragmentation entry.
The fragmentation code keeps the fragments in lists. The fragmentation entries
are kept in descending order of sequence number. The list is traversed and each
entry is compared with the new fragment. If the current entry has a smaller
sequence number than the new fragment then the new one has to be inserted
before the current entry. This ensures that the list is still in descending
order.
An out-of-order packet with a smaller sequence number than all entries in the
list still has to be added to the end of the list. The used hlist has no
information about the last entry in the list inside hlist_head and thus the
last entry has to be calculated differently. Currently the code assumes that
the iterator variable of hlist_for_each_entry can be used for this purpose
after the hlist_for_each_entry finished. This is obviously wrong because the
iterator variable is always NULL when the list was completely traversed.
Instead the information about the last entry has to be stored in a different
variable.
This problem was introduced in 610bfc6bc99bc83680d190ebc69359a05fc7f605
("batman-adv: Receive fragmented packets and merge").
Signed-off-by: Sven Eckelmann <sven@narfation.org>
Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch>
Signed-off-by: Antonio Quartulli <antonio@meshcoding.com>
[ Upstream commit fcdfe3a7fa4cb74391d42b6a26dc07c20dab1d82 ]
When performing segmentation, the mac_len value is copied right
out of the original skb. However, this value is not always set correctly
(like when the packet is VLAN-tagged) and we'll end up copying a bad
value.
One way to demonstrate this is to configure a VM which tags
packets internally and turn off VLAN acceleration on the forwarding
bridge port. The packets show up corrupt like this:
16:18:24.985548 52:54:00:ab:be:25 > 52:54:00:26:ce:a3, ethertype 802.1Q
(0x8100), length 1518: vlan 100, p 0, ethertype 0x05e0,
0x0000: 8cdb 1c7c 8cdb 0064 4006 b59d 0a00 6402 ...|...d@.....d.
0x0010: 0a00 6401 9e0d b441 0a5e 64ec 0330 14fa ..d....A.^d..0..
0x0020: 29e3 01c9 f871 0000 0101 080a 000a e833)....q.........3
0x0030: 000f 8c75 6e65 7470 6572 6600 6e65 7470 ...unetperf.netp
0x0040: 6572 6600 6e65 7470 6572 6600 6e65 7470 erf.netperf.netp
0x0050: 6572 6600 6e65 7470 6572 6600 6e65 7470 erf.netperf.netp
0x0060: 6572 6600 6e65 7470 6572 6600 6e65 7470 erf.netperf.netp
This also leads to awful throughput as GSO packets are dropped and
cause retransmissions.
The solution is to set the mac_len using the values already available
in then new skb. We've already adjusted all of the header offset, so we
might as well correctly figure out the mac_len using skb_reset_mac_len().
After this change, packets are segmented correctly and performance
is restored.
CC: Eric Dumazet <edumazet@google.com>
Signed-off-by: Vlad Yasevich <vyasevic@redhat.com>
[ Upstream commit 1f74e613ded11517db90b2bd57e9464d9e0fb161 ]
In vegas we do a multiplication of the cwnd and the rtt. This
may overflow and thus their result is stored in a u64. However, we first
need to cast the cwnd so that actually 64-bit arithmetic is done.
Then, we need to do do_div to allow this to be used on 32-bit arches.
Cc: Stephen Hemminger <stephen@networkplumber.org>
Cc: Neal Cardwell <ncardwell@google.com>
Cc: David Laight <David.Laight@ACULAB.COM>
Cc: Doug Leith <doug.leith@nuim.ie>
Fixes: 8d3a564da34e (tcp: tcp_vegas cong avoid fix)
Signed-off-by: Christoph Paasch <christoph.paasch@uclouvain.be>
[ Upstream commit 45a07695bc64b3ab5d6d2215f9677e5b8c05a7d0 ]
In veno we do a multiplication of the cwnd and the rtt. This
A first attempt at fixing 76f1017757aa0 ([TCP]: TCP Veno congestion
control) was made by 159131149c2 (tcp: Overflow bug in Vegas), but it
failed to add the required cast in tcp_veno_cong_avoid().
Fixes: 76f1017757aa0 ([TCP]: TCP Veno congestion control)
[ Upstream commit 95cb5745983c222867cc9ac593aebb2ad67d72c0 ]
Ipv4 tunnels created with "local any remote $ip" didn't work properly since
7d442fab0 (ipv4: Cache dst in tunnels). 99% of packets sent via those tunnels
had src addr = 0.0.0.0. That was because only dst_entry was cached, although
fl4.saddr has to be cached too. Every time ip_tunnel_xmit used cached dst_entry
(tunnel_rtable_get returned non-NULL), fl4.saddr was initialized with
tnl_params->saddr (= 0 in our case), and wasn't changed until iptunnel_xmit().
This patch adds saddr to ip_tunnel->dst_cache, fixing this issue.
Reported-by: Sergey Popov <pinkbyte@gentoo.org>
Signed-off-by: Dmitry Popov <ixaphire@qrator.net>
Sasha's report:
> While fuzzing with trinity inside a KVM tools guest running the latest -next
> kernel with the KASAN patchset, I've stumbled on the following spew:
> [ 4448.949424] ==================================================================
> [ 4448.951737] AddressSanitizer: user-memory-access on address 0
> [ 4448.952988] Read of size 2 by thread T19638:
> [ 4448.954510] CPU: 28 PID: 19638 Comm: trinity-c76 Not tainted 3.16.0-rc4-next-20140711-sasha-00046-g07d3099-dirty #813
> [ 4448.956823] ffff88046d86ca40 0000000000000000 ffff880082f37e78 ffff880082f37a40
> [ 4448.958233] ffffffffb6e47068 ffff880082f37a68 ffff880082f37a58 ffffffffb242708d
> [ 4448.959552] 0000000000000000 ffff880082f37a88 ffffffffb24255b1 0000000000000000
> [ 4448.961266] Call Trace:
> [ 4448.963158] dump_stack (lib/dump_stack.c:52)
> [ 4448.964244] kasan_report_user_access (mm/kasan/report.c:184)
> [ 4448.965507] __asan_load2 (mm/kasan/kasan.c:352)
> [ 4448.966482] ? netlink_sendmsg (net/netlink/af_netlink.c:2339)
> [ 4448.967541] netlink_sendmsg (net/netlink/af_netlink.c:2339)
> [ 4448.968537] ? get_parent_ip (kernel/sched/core.c:2555)
> [ 4448.970103] sock_sendmsg (net/socket.c:654)
> [ 4448.971584] ? might_fault (mm/memory.c:3741)
> [ 4448.972526] ? might_fault (./arch/x86/include/asm/current.h:14 mm/memory.c:3740)
> [ 4448.973596] ? verify_iovec (net/core/iovec.c:64)
> [ 4448.974522] ___sys_sendmsg (net/socket.c:2096)
> [ 4448.975797] ? put_lock_stats.isra.13 (./arch/x86/include/asm/preempt.h:98 kernel/locking/lockdep.c:254)
> [ 4448.977030] ? lock_release_holdtime (kernel/locking/lockdep.c:273)
> [ 4448.978197] ? lock_release_non_nested (kernel/locking/lockdep.c:3434 (discriminator 1))
> [ 4448.979346] ? check_chain_key (kernel/locking/lockdep.c:2188)
> [ 4448.980535] __sys_sendmmsg (net/socket.c:2181)
> [ 4448.981592] ? trace_hardirqs_on_caller (kernel/locking/lockdep.c:2600)
> [ 4448.982773] ? trace_hardirqs_on (kernel/locking/lockdep.c:2607)
> [ 4448.984458] ? syscall_trace_enter (arch/x86/kernel/ptrace.c:1500 (discriminator 2))
> [ 4448.985621] ? trace_hardirqs_on_caller (kernel/locking/lockdep.c:2600)
> [ 4448.986754] SyS_sendmmsg (net/socket.c:2201)
> [ 4448.987708] tracesys (arch/x86/kernel/entry_64.S:542)
> [ 4448.988929] ==================================================================
This reports means that we've come to netlink_sendmsg() with msg->msg_name == NULL and msg->msg_namelen > 0.
After this report there was no usual "Unable to handle kernel NULL pointer dereference"
and this gave me a clue that address 0 is mapped and contains valid socket address structure in it.
This bug was introduced in f3d3342602f8bcbf37d7c46641cb9bca7618eb1c
(net: rework recvmsg handler msg_name and msg_namelen logic).
Commit message states that:
"Set msg->msg_name = NULL if user specified a NULL in msg_name but had a
non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't
affect sendto as it would bail out earlier while trying to copy-in the
address."
But in fact this affects sendto when address 0 is mapped and contains
socket address structure in it. In such case copy-in address will succeed,
verify_iovec() function will successfully exit with msg->msg_namelen > 0
and msg->msg_name == NULL.
This patch fixes it by setting msg_namelen to 0 if msg_name == NULL.
Cc: Eric Dumazet <edumazet@google.com>
Cc: <stable@vger.kernel.org>
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com>
In "Counting Packets Sent Between Arbitrary Internet Hosts", Jeffrey and
Jedidiah describe ways exploiting linux IP identifier generation to
infer whether two machines are exchanging packets.
With commit 73f156a6e8c1 ("inetpeer: get rid of ip_id_count"), we
changed IP id generation, but this does not really prevent this
side-channel technique.
This patch adds a random amount of perturbation so that IP identifiers
for a given destination [1] are no longer monotonically increasing after
an idle period.
Note that prandom_u32_max(1) returns 0, so if generator is used at most
once per jiffy, this patch inserts no hole in the ID suite and do not
increase collision probability.
This is jiffies based, so in the worst case (HZ=1000), the id can
rollover after ~65 seconds of idle time, which should be fine.
We also change the hash used in __ip_select_ident() to not only hash
on daddr, but also saddr and protocol, so that ICMP probes can not be
used to infer information for other protocols.
For IPv6, adds saddr into the hash as well, but not nexthdr.
If I ping the patched target, we can see ID are now hard to predict.
21:57:11.008086 IP (...)
A > target: ICMP echo request, seq 1, length 64
21:57:11.010752 IP (... id 2081 ...)
target > A: ICMP echo reply, seq 1, length 64
21:57:12.013133 IP (...)
A > target: ICMP echo request, seq 2, length 64
21:57:12.015737 IP (... id 3039 ...)
target > A: ICMP echo reply, seq 2, length 64
21:57:13.016580 IP (...)
A > target: ICMP echo request, seq 3, length 64
21:57:13.019251 IP (... id 3437 ...)
target > A: ICMP echo reply, seq 3, length 64
[1] TCP sessions uses a per flow ID generator not changed by this patch.
Reported-by: Jeffrey Knockel <jeffk@cs.unm.edu>
Reported-by: Jedidiah R. Crandall <crandall@cs.unm.edu>
Cc: Willy Tarreau <w@1wt.eu>
Cc: Hannes Frederic Sowa <hannes@redhat.com>
ndm_type means L3 address type, in neighbour proxy and vxlan, it's RTN_UNICAST.
NDA_DST is for netlink TLV type, hence it's not right value in this context.
Signed-off-by: Jun Zhao <mypopydev@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless
John W. Linville says:
pull request: wireless 2014-07-24
Please pull this batch of fixes intended for the 3.16 stream...
For the mac80211 fixes, Johannes says:
"I have two fixes: one for tracing that fixes a long-standing NULL
pointer dereference, and one for a mac80211 issue that causes iwlmvm to
send invalid frames during authentication/association."
and,
"One more fix - for a bug in the newly introduced code that obtains rate
control information for stations."
For the iwlwifi fixes, Emmanuel says:
"It includes a merge damage fix. This region has been changed in -next
and -fixes quite a few times and apparently, I failed to handle it
properly, so here the fix. Along with that I have a fix from Eliad
to properly handle overlapping BSS in AP mode."
On top of that, Felix provides and ath9k fix for Tx stalls that happen
after an aggregation session failure.
Please let me know if there are problems! There are some changes
here that will cause merge conflicts in -next. Once you merge this
I can pull it into wireless-next and resolve those issues.
Pablo Neira Ayuso says:
Via Simon Horman, I received the following one-liner for your net tree:
1) Fix crash when exiting from netns that uses IPVS and conntrack,
from Julian Anastasov via Simon Horman.
git://git.kernel.org/pub/scm/linux/kernel/git/klassert/ipsec
Steffen Klassert says:
pull request (net): ipsec 2014-07-23
Just two fixes this time, both are stable candidates.
1) Fix the dst_entry refcount on socket policy usage.
2) Fix a wrong SPI check that prevents AH SAs from getting
installed, dependent on the SPI. From Tobias Brunner.
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211
Jason reported an oops caused by SCTP on his ARM machine with
SCTP authentication enabled:
Internal error: Oops: 17 [#1] ARM
CPU: 0 PID: 104 Comm: sctp-test Not tainted 3.13.0-68744-g3632f30c9b20-dirty #1
task: c6eefa40 ti: c6f52000 task.ti: c6f52000
PC is at sctp_auth_calculate_hmac+0xc4/0x10c
LR is at sg_init_table+0x20/0x38
pc : [<c024bb80>] lr : [<c00f32dc>] psr: 40000013
sp : c6f538e8 ip : 00000000 fp : c6f53924
r10: c6f50d80 r9 : 00000000 r8 : 00010000
r7 : 00000000 r6 : c7be4000 r5 : 00000000 r4 : c6f56254
r3 : c00c8170 r2 : 00000001 r1 : 00000008 r0 : c6f1e660
Flags: nZcv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
Control: 0005397f Table: 06f28000 DAC: 00000015
Process sctp-test (pid: 104, stack limit = 0xc6f521c0)
Stack: (0xc6f538e8 to 0xc6f54000)
Backtrace:
[<c024babc>] (sctp_auth_calculate_hmac+0x0/0x10c) from [<c0249af8>] (sctp_packet_transmit+0x33c/0x5c8)
[<c02497bc>] (sctp_packet_transmit+0x0/0x5c8) from [<c023e96c>] (sctp_outq_flush+0x7fc/0x844)
[<c023e170>] (sctp_outq_flush+0x0/0x844) from [<c023ef78>] (sctp_outq_uncork+0x24/0x28)
[<c023ef54>] (sctp_outq_uncork+0x0/0x28) from [<c0234364>] (sctp_side_effects+0x1134/0x1220)
[<c0233230>] (sctp_side_effects+0x0/0x1220) from [<c02330b0>] (sctp_do_sm+0xac/0xd4)
[<c0233004>] (sctp_do_sm+0x0/0xd4) from [<c023675c>] (sctp_assoc_bh_rcv+0x118/0x160)
[<c0236644>] (sctp_assoc_bh_rcv+0x0/0x160) from [<c023d5bc>] (sctp_inq_push+0x6c/0x74)
[<c023d550>] (sctp_inq_push+0x0/0x74) from [<c024a6b0>] (sctp_rcv+0x7d8/0x888)
While we already had various kind of bugs in that area
ec0223ec48a9 ("net: sctp: fix sctp_sf_do_5_1D_ce to verify if
we/peer is AUTH capable") and b14878ccb7fa ("net: sctp: cache
auth_enable per endpoint"), this one is a bit of a different
kind.
Giving a bit more background on why SCTP authentication is
needed can be found in RFC4895:
SCTP uses 32-bit verification tags to protect itself against
blind attackers. These values are not changed during the
lifetime of an SCTP association.
Looking at new SCTP extensions, there is the need to have a
method of proving that an SCTP chunk(s) was really sent by
the original peer that started the association and not by a
malicious attacker.
To cause this bug, we're triggering an INIT collision between
peers; normal SCTP handshake where both sides intent to
authenticate packets contains RANDOM; CHUNKS; HMAC-ALGO
parameters that are being negotiated among peers:
---------- INIT[RANDOM; CHUNKS; HMAC-ALGO] ---------->
<------- INIT-ACK[RANDOM; CHUNKS; HMAC-ALGO] ---------
-------------------- COOKIE-ECHO -------------------->
<-------------------- COOKIE-ACK ---------------------
RFC4895 says that each endpoint therefore knows its own random
number and the peer's random number *after* the association
has been established. The local and peer's random number along
with the shared key are then part of the secret used for
calculating the HMAC in the AUTH chunk.
Now, in our scenario, we have 2 threads with 1 non-blocking
SEQ_PACKET socket each, setting up common shared SCTP_AUTH_KEY
and SCTP_AUTH_ACTIVE_KEY properly, and each of them calling
sctp_bindx(3), listen(2) and connect(2) against each other,
thus the handshake looks similar to this, e.g.:
<--------- INIT[RANDOM; CHUNKS; HMAC-ALGO] -----------
-------- INIT-ACK[RANDOM; CHUNKS; HMAC-ALGO] -------->
Since such collisions can also happen with verification tags,
the RFC4895 for AUTH rather vaguely says under section 6.1:
In case of INIT collision, the rules governing the handling
of this Random Number follow the same pattern as those for
the Verification Tag, as explained in Section 5.2.4 of
RFC 2960 [5]. Therefore, each endpoint knows its own Random
Number and the peer's Random Number after the association
In RFC2960, section 5.2.4, we're eventually hitting Action B:
B) In this case, both sides may be attempting to start an
association at about the same time but the peer endpoint
started its INIT after responding to the local endpoint's
INIT. Thus it may have picked a new Verification Tag not
being aware of the previous Tag it had sent this endpoint.
The endpoint should stay in or enter the ESTABLISHED
state but it MUST update its peer's Verification Tag from
the State Cookie, stop any init or cookie timers that may
running and send a COOKIE ACK.
In other words, the handling of the Random parameter is the
same as behavior for the Verification Tag as described in
Action B of section 5.2.4.
Looking at the code, we exactly hit the sctp_sf_do_dupcook_b()
case which triggers an SCTP_CMD_UPDATE_ASSOC command to the
side effect interpreter, and in fact it properly copies over
peer_{random, hmacs, chunks} parameters from the newly created
association to update the existing one.
Also, the old asoc_shared_key is being released and based on
the new params, sctp_auth_asoc_init_active_key() updated.
However, the issue observed in this case is that the previous
asoc->peer.auth_capable was 0, and has *not* been updated, so
that instead of creating a new secret, we're doing an early
return from the function sctp_auth_asoc_init_active_key()
leaving asoc->asoc_shared_key as NULL. However, we now have to
authenticate chunks from the updated chunk list (e.g. COOKIE-ACK).
That in fact causes the server side when responding with ...
<------------------ AUTH; COOKIE-ACK -----------------
... to trigger a NULL pointer dereference, since in
sctp_packet_transmit(), it discovers that an AUTH chunk is
being queued for xmit, and thus it calls sctp_auth_calculate_hmac().
Since the asoc->active_key_id is still inherited from the
endpoint, and the same as encoded into the chunk, it uses
asoc->asoc_shared_key, which is still NULL, as an asoc_key
and dereferences it in ...
crypto_hash_setkey(desc.tfm, &asoc_key->data[0], asoc_key->len)
... causing an oops. All this happens because sctp_make_cookie_ack()
called with the *new* association has the peer.auth_capable=1
and therefore marks the chunk with auth=1 after checking
sctp_auth_send_cid(), but it is *actually* sent later on over
the then *updated* association's transport that didn't initialize
its shared key due to peer.auth_capable=0. Since control chunks
in that case are not sent by the temporary association which
are scheduled for deletion, they are issued for xmit via
SCTP_CMD_REPLY in the interpreter with the context of the
*updated* association. peer.auth_capable was 0 in the updated
association (which went from COOKIE_WAIT into ESTABLISHED state),
since all previous processing that performed sctp_process_init()
was being done on temporary associations, that we eventually
throw away each time.
The correct fix is to update to the new peer.auth_capable
value as well in the collision case via sctp_assoc_update(),
so that in case the collision migrated from 0 -> 1,
sctp_auth_asoc_init_active_key() can properly recalculate
the secret. This therefore fixes the observed server panic.
Fixes: 730fc3d05cd4 ("[SCTP]: Implete SCTP-AUTH parameter processing")
Reported-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Tested-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Cc: Vlad Yasevich <vyasevich@gmail.com>
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
If the expected throughput is queried before rate control has been
initialized, the minstrel op for it will crash while trying to access
the rate table.
Check for WLAN_STA_RATE_CONTROL before attempting to use the rate
control op.
Reported-by: Jean-Pierre Tosoni <jp.tosoni@acksys.fr>
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
Antonio Quartulli says:
pull request [net]: batman-adv 20140721
here you have two fixes that we have been testing for quite some time
(this is why they arrived a bit late in the rc cycle).
Patch 1) ensures that BLA packets get dropped and not forwarded to the
mesh even if they reach batman-adv within QinQ frames. Forwarding them
into the mesh means messing up with the TT database of other nodes which
can generate all kind of unexpected behaviours during route computation.
Patch 2) avoids a couple of race conditions triggered upon fast VLAN
deletion-addition. Such race conditions are pretty dangerous because
they not only create inconsistencies in the TT database of the nodes
in the network, but such scenario is also unrecoverable (unless
nodes are rebooted).
There is a benign buffer overflow in ip_options_compile spotted by
AddressSanitizer[1] :
Its benign because we always can access one extra byte in skb->head
(because header is followed by struct skb_shared_info), and in this case
this byte is not even used.
[28504.910798] ==================================================================
[28504.912046] AddressSanitizer: heap-buffer-overflow in ip_options_compile
[28504.913170] Read of size 1 by thread T15843:
[28504.914026] [<ffffffff81802f91>] ip_options_compile+0x121/0x9c0
[28504.915394] [<ffffffff81804a0d>] ip_options_get_from_user+0xad/0x120
[28504.916843] [<ffffffff8180dedf>] do_ip_setsockopt.isra.15+0x8df/0x1630
[28504.918175] [<ffffffff8180ec60>] ip_setsockopt+0x30/0xa0
[28504.919490] [<ffffffff8181e59b>] tcp_setsockopt+0x5b/0x90
[28504.920835] [<ffffffff8177462f>] sock_common_setsockopt+0x5f/0x70
[28504.922208] [<ffffffff817729c2>] SyS_setsockopt+0xa2/0x140
[28504.923459] [<ffffffff818cfb69>] system_call_fastpath+0x16/0x1b
[28504.924722]
[28504.925106] Allocated by thread T15843:
[28504.925815] [<ffffffff81804995>] ip_options_get_from_user+0x35/0x120
[28504.926884] [<ffffffff8180dedf>] do_ip_setsockopt.isra.15+0x8df/0x1630
[28504.927975] [<ffffffff8180ec60>] ip_setsockopt+0x30/0xa0
[28504.929175] [<ffffffff8181e59b>] tcp_setsockopt+0x5b/0x90
[28504.930400] [<ffffffff8177462f>] sock_common_setsockopt+0x5f/0x70
[28504.931677] [<ffffffff817729c2>] SyS_setsockopt+0xa2/0x140
[28504.932851] [<ffffffff818cfb69>] system_call_fastpath+0x16/0x1b
[28504.934018]
[28504.934377] The buggy address ffff880026382828 is located 0 bytes to the right
[28504.934377] of 40-byte region [ffff880026382800, ffff880026382828)
[28504.937144]
[28504.937474] Memory state around the buggy address:
[28504.938430] ffff880026382300: ........ rrrrrrrr rrrrrrrr rrrrrrrr
[28504.939884] ffff880026382400: ffffffff rrrrrrrr rrrrrrrr rrrrrrrr
[28504.941294] ffff880026382500: .....rrr rrrrrrrr rrrrrrrr rrrrrrrr
[28504.942504] ffff880026382600: ffffffff rrrrrrrr rrrrrrrr rrrrrrrr
[28504.943483] ffff880026382700: ffffffff rrrrrrrr rrrrrrrr rrrrrrrr
[28504.944511] >ffff880026382800: .....rrr rrrrrrrr rrrrrrrr rrrrrrrr
[28504.945573] ^
[28504.946277] ffff880026382900: ffffffff rrrrrrrr rrrrrrrr rrrrrrrr
[28505.094949] ffff880026382a00: ffffffff rrrrrrrr rrrrrrrr rrrrrrrr
[28505.096114] ffff880026382b00: ffffffff rrrrrrrr rrrrrrrr rrrrrrrr
[28505.097116] ffff880026382c00: ffffffff rrrrrrrr rrrrrrrr rrrrrrrr
[28505.098472] ffff880026382d00: ffffffff rrrrrrrr rrrrrrrr rrrrrrrr
[28505.099804] Legend:
[28505.100269] f - 8 freed bytes
[28505.100884] r - 8 redzone bytes
[28505.101649] . - 8 allocated bytes
[28505.102406] x=1..7 - x allocated bytes + (8-x) redzone bytes
[28505.103637] ==================================================================
[1] https://code.google.com/p/address-sanitizer/wiki/AddressSanitizerForKernel
When a VLAN interface (on top of batX) is removed and
re-added within a short timeframe TT does not have enough
time to properly cleanup. This creates an internal TT state
mismatch as the newly created softif_vlan will be
initialized from scratch with a TT client count of zero
(even if TT entries for this VLAN still exist). The
resulting TT messages are bogus due to the counter / tt
client listing mismatch, thus creating inconsistencies on
every node in the network
To fix this issue destroy_vlan() has to not free the VLAN
object immediately but it has to be kept alive until all the
TT entries for this VLAN have been removed. destroy_vlan()
still removes the sysfs folder so that the user has the
feeling that everything went fine.
If the same VLAN is re-added before the old object is free'd,
then the latter is resurrected and re-used.
Implement such behaviour by increasing the reference counter
of a softif_vlan object every time a new local TT entry for
such VLAN is created and remove the object from the list
only when all the TT entries have been destroyed.
Signed-off-by: Antonio Quartulli <antonio@open-mesh.com>
Since bridge loop avoidance only supports untagged or simple 802.1q
tagged VLAN claim frames, claim frames with stacked VLAN headers (QinQ)
should be detected and dropped. Transporting the over the mesh may cause
problems on the receivers, or create bogus entries in the local tt
tables.
Reported-by: Antonio Quartulli <antonio@open-mesh.com>
Signed-off-by: Simon Wunderlich <simon@open-mesh.com>
*_result[len] is parsed as *(_result[len]) which is not at all what we
want to touch here.
Fixes: 84a7c0b1db1c ("dns_resolver: assure that dns_query() result is null-terminated")
When kernel generates a handle for a u32 filter, it tries to start
from the max in the bucket. So when we have a filter with the max (fff)
handle, it will cause kernel always generates the same handle for new
filters. This can be shown by the following command:
tc qdisc add dev eth0 ingress
tc filter add dev eth0 parent ffff: protocol ip pref 770 handle 800::fff u32 match ip protocol 1 0xff
tc filter add dev eth0 parent ffff: protocol ip pref 770 u32 match ip protocol 1 0xff
we will get some u32 filters with same handle:
# tc filter show dev eth0 parent ffff:
filter protocol ip pref 770 u32
filter protocol ip pref 770 u32 fh 800: ht divisor 1
filter protocol ip pref 770 u32 fh 800::fff order 4095 key ht 800 bkt 0
match 00010000/00ff0000 at 8
handles should be unique. This patch fixes it by looking up a bitmap,
so that can guarantee the handle is as unique as possible. For compatibility,
we still start from 0x800.
Signed-off-by: Cong Wang <cwang@twopensource.com>
Signed-off-by: Jamal Hadi Salim <jhs@mojatatu.com>
tsc can be NULL (mac80211 currently always passes NULL),
resulting in NULL-dereference. check before copying it.
Cc: stable@vger.kernel.org
Signed-off-by: Eliad Peller <eliadx.peller@intel.com>
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
Netfilter/nf_tables fixes
The following patchset contains nf_tables fixes, they are:
1) Fix wrong transaction handling when the table flags are not
modified.
2) Fix missing rcu read_lock section in the netlink dump path, which
is not protected by the nfnl_lock.
3) Set NLM_F_DUMP_INTR in the netlink dump path to indicate
interferences with updates.
4) Fix 64 bits chain counters when they are retrieved from a 32 bits
arch, from Eric Dumazet.
Fixed a bug that was introduced by my GRE-GRO patch
(bf5a755f5e9186406bbf50f4087100af5bd68e40 net-gre-gro: Add GRE
support to the GRO stack) that breaks the forwarding path
because various GSO related fields were not set. The bug will
cause on the egress path either the GSO code to fail, or a
GRE-TSO capable (NETIF_F_GSO_GRE) NICs to choke. The following
fix has been tested for both cases.
Signed-off-by: H.K. Jerry Chu <hkchu@google.com>
commit 8f4e0a18682d91 ("IPVS netns exit causes crash in conntrack")
added second ip_vs_conn_drop_conntrack call instead of just adding
the needed check. As result, the first call still can cause
crash on netns exit. Remove it.
Signed-off-by: Hans Schillstrom <hans@schillstrom.com>
Pull networking fixes from David Miller:
1) Bluetooth pairing fixes from Johan Hedberg.
2) ieee80211_send_auth() doesn't allocate enough tail room for the SKB,
from Max Stepanov.
3) New iwlwifi chip IDs, from Oren Givon.
4) bnx2x driver reads wrong PCI config space MSI register, from Yijing
Wang.
5) IPV6 MLD Query validation isn't strong enough, from Hangbin Liu.
6) Fix double SKB free in openvswitch, from Andy Zhou.
7) Fix sk_dst_set() being racey with UDP sockets, leading to strange
crashes, from Eric Dumazet.
8) Interpret the NAPI budget correctly in the new systemport driver,
from Florian Fainelli.
9) VLAN code frees percpu stats in the wrong place, leading to crashes
in the get stats handler. From Eric Dumazet.
10) TCP sockets doing a repair can crash with a divide by zero, because
we invoke tcp_push() with an MSS value of zero. Just skip that part
of the sendmsg paths in repair mode. From Christoph Paasch.
11) IRQ affinity bug fixes in mlx4 driver from Amir Vadai.
12) Don't ignore path MTU icmp messages with a zero mtu, machines out
there still spit them out, and all of our per-protocol handlers for
PMTU can cope with it just fine. From Edward Allcutt.
13) Some NETDEV_CHANGE notifier invocations were not passing in the
correct kind of cookie as the argument, from Loic Prylli.
14) Fix crashes in long multicast/broadcast reassembly, from Jon Paul
Maloy.
15) ip_tunnel_lookup() doesn't interpret wildcard keys correctly, fix
from Dmitry Popov.
16) Fix skb->sk assigned without taking a reference to 'sk' in
appletalk, from Andrey Utkin.
17) Fix some info leaks in ULP event signalling to userspace in SCTP,
from Daniel Borkmann.
18) Fix deadlocks in HSO driver, from Olivier Sobrie.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (93 commits)
hso: fix deadlock when receiving bursts of data
hso: remove unused workqueue
net: ppp: don't call sk_chk_filter twice
mlx4: mark napi id for gro_skb
bonding: fix ad_select module param check
net: pppoe: use correct channel MTU when using Multilink PPP
neigh: sysctl - simplify address calculation of gc_* variables
net: sctp: fix information leaks in ulpevent layer
MAINTAINERS: update r8169 maintainer
net: bcmgenet: fix RGMII_MODE_EN bit
tipc: clear 'next'-pointer of message fragments before reassembly
r8152: fix r8152_csum_workaround function
be2net: set EQ DB clear-intr bit in be_open()
GRE: enable offloads for GRE
farsync: fix invalid memory accesses in fst_add_one() and fst_init_card()
igb: do a reset on SR-IOV re-init if device is down
igb: Workaround for i210 Errata 25: Slow System Clock
usbnet: smsc95xx: add reset_resume function with reset operation
dp83640: Always decode received status frames
r8169: disable L23
The l2tp [get|set]sockopt() code has fallen back to the UDP functions
for socket option levels != SOL_PPPOL2TP since day one, but that has
never actually worked, since the l2tp socket isn't an inet socket.
As David Miller points out:
"If we wanted this to work, it'd have to look up the tunnel and then
use tunnel->sk, but I wonder how useful that would be"
Since this can never have worked so nobody could possibly have depended
on that functionality, just remove the broken code and return -EINVAL.
Acked-by: James Chapman <jchapman@katalix.com>
Acked-by: David Miller <davem@davemloft.net>
Cc: Phil Turnbull <phil.turnbull@oracle.com>
Cc: Vegard Nossum <vegard.nossum@oracle.com>
The code in neigh_sysctl_register() relies on a specific layout of
struct neigh_table, namely that the 'gc_*' variables are directly
following the 'parms' member in a specific order. The code, though,
expresses this in the most ugly way.
Get rid of the ugly casts and use the 'tbl' pointer to get a handle to
the table. This way we can refer to the 'gc_*' variables directly.
Similarly seen in the grsecurity patch, written by Brad Spengler.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Cc: Brad Spengler <spender@grsecurity.net>
While working on some other SCTP code, I noticed that some
structures shared with user space are leaking uninitialized
stack or heap buffer. In particular, struct sctp_sndrcvinfo
has a 2 bytes hole between .sinfo_flags and .sinfo_ppid that
remains unfilled by us in sctp_ulpevent_read_sndrcvinfo() when
putting this into cmsg. But also struct sctp_remote_error
contains a 2 bytes hole that we don't fill but place into a skb
through skb_copy_expand() via sctp_ulpevent_make_remote_error().
Both structures are defined by the IETF in RFC6458:
* Section 5.3.2. SCTP Header Information Structure:
The sctp_sndrcvinfo structure is defined below:
struct sctp_sndrcvinfo {
uint16_t sinfo_stream;
uint16_t sinfo_ssn;
uint16_t sinfo_flags;
<-- 2 bytes hole -->
uint32_t sinfo_ppid;
uint32_t sinfo_context;
uint32_t sinfo_timetolive;
uint32_t sinfo_tsn;
uint32_t sinfo_cumtsn;
sctp_assoc_t sinfo_assoc_id;
* 6.1.3. SCTP_REMOTE_ERROR:
A remote peer may send an Operation Error message to its peer.
This message indicates a variety of error conditions on an
association. The entire ERROR chunk as it appears on the wire
is included in an SCTP_REMOTE_ERROR event. Please refer to the
SCTP specification [RFC4960] and any extensions for a list of
possible error formats. An SCTP error notification has the
following format:
struct sctp_remote_error {
uint16_t sre_type;
uint16_t sre_flags;
uint32_t sre_length;
uint16_t sre_error;
sctp_assoc_t sre_assoc_id;
uint8_t sre_data[];
Fix this by setting both to 0 before filling them out. We also
have other structures shared between user and kernel space in
SCTP that contains holes (e.g. struct sctp_paddrthlds), but we
copy that buffer over from user space first and thus don't need
to care about it in that cases.
While at it, we can also remove lengthy comments copied from
the draft, instead, we update the comment with the correct RFC
number where one can look it up.
Use generic u64_stats_sync infrastructure to get proper 64bit stats,
even on 32bit arches, at no extra cost for 64bit arches.
Without this fix, 32bit arches can have some wrong counters at the time
the carry is propagated into upper word.
An updater may interfer with the dumping of any of the object lists.
Fix this by using a per-net generation counter and use the
nl_dump_check_consistent() interface so the NLM_F_DUMP_INTR flag is set
to notify userspace that it has to restart the dump since an updater
has interfered.
This patch also replaces the existing consistency checking code in the
rule dumping path since it is broken. Basically, the value that the
dump callback returns is not propagated to userspace via
netlink_dump_start().
The dump operation through netlink is not protected by the nfnl_lock.
Thus, a reader process can be dumping any of the existing object
lists while another process can be updating the list content.
This patch resolves this situation by protecting all the object
lists with RCU in the netlink dump path which is the reader side.
The updater path is already protected via nfnl_lock, so use list
manipulation RCU-safe operations.
