[ Upstream commit e95584a889e1902fdf1ded9712e2c3c3083baf96 ]
We have identified a problem with the "oversubscription" policy in the
link transmission code.
When small messages are transmitted, and the sending link has reached
the transmit window limit, those messages will be bundled and put into
the link backlog queue. However, bundles of data messages are counted
at the 'CRITICAL' level, so that the counter for that level, instead of
the counter for the real, bundled message's level is the one being
increased.
Subsequent, to-be-bundled data messages at non-CRITICAL levels continue
to be tested against the unchanged counter for their own level, while
contributing to an unrestrained increase at the CRITICAL backlog level.
This leaves a gap in congestion control algorithm for small messages
that can result in starvation for other users or a "real" CRITICAL
user. Even that eventually can lead to buffer exhaustion & link reset.
We fix this by keeping a 'target_bskb' buffer pointer at each levels,
then when bundling, we only bundle messages at the same importance
level only. This way, we know exactly how many slots a certain level
have occupied in the queue, so can manage level congestion accurately.
By bundling messages at the same level, we even have more benefits. Let
consider this:
- One socket sends 64-byte messages at the 'CRITICAL' level;
- Another sends 4096-byte messages at the 'LOW' level;
When a 64-byte message comes and is bundled the first time, we put the
overhead of message bundle to it (+ 40-byte header, data copy, etc.)
for later use, but the next message can be a 4096-byte one that cannot
be bundled to the previous one. This means the last bundle carries only
one payload message which is totally inefficient, as for the receiver
also! Later on, another 64-byte message comes, now we make a new bundle
and the same story repeats...
With the new bundling algorithm, this will not happen, the 64-byte
messages will be bundled together even when the 4096-byte message(s)
comes in between. However, if the 4096-byte messages are sent at the
same level i.e. 'CRITICAL', the bundling algorithm will again cause the
same overhead.
Also, the same will happen even with only one socket sending small
messages at a rate close to the link transmit's one, so that, when one
message is bundled, it's transmitted shortly. Then, another message
comes, a new bundle is created and so on...
We will solve this issue radically by another patch.
Fixes: 365ad353c256 ("tipc: reduce risk of user starvation during link congestion")
Reported-by: Hoang Le <hoang.h.le@dektech.com.au>
Acked-by: Jon Maloy <jon.maloy@ericsson.com>
Signed-off-by: Tuong Lien <tuong.t.lien@dektech.com.au>
[ Upstream commit d64bf89a75b65f83f06be9fb8f978e60d53752db ]
rds_ibdev:ipaddr_list and rds_ibdev:conn_list are initialized
after allocation some resources such as protection domain.
If allocation of such resources fail, then these uninitialized
variables are accessed in rds_ib_dev_free() in failure path. This
can potentially crash the system. The code has been updated to
initialize these variables very early in the function.
Signed-off-by: Dotan Barak <dotanb@dev.mellanox.co.il>
Signed-off-by: Sudhakar Dindukurti <sudhakar.dindukurti@oracle.com>
Acked-by: Santosh Shilimkar <santosh.shilimkar@oracle.com>
[ Upstream commit 0d9138ffac24cf8b75366ede3a68c951e6dcc575 ]
Lockdep is unhappy if two locks from the same class are held.
Fix the below warning for hyperv and virtio sockets (vmci socket code
doesn't have the issue) by using lock_sock_nested() when __vsock_release()
is called recursively:
WARNING: possible recursive locking detected
5.3.0+ #1 Not tainted
server/1795 is trying to acquire lock:
ffff8880c5158990 (sk_lock-AF_VSOCK){+.+.}, at: hvs_release+0x10/0x120 [hv_sock]
but task is already holding lock:
ffff8880c5158150 (sk_lock-AF_VSOCK){+.+.}, at: __vsock_release+0x2e/0xf0 [vsock]
Possible unsafe locking scenario:
CPU0
lock(sk_lock-AF_VSOCK);
*** DEADLOCK ***
May be due to missing lock nesting notation
2 locks held by server/1795:
#0: ffff8880c5d05ff8 (&sb->s_type->i_mutex_key#10){+.+.}, at: __sock_release+0x2d/0xa0
#1: ffff8880c5158150 (sk_lock-AF_VSOCK){+.+.}, at: __vsock_release+0x2e/0xf0 [vsock]
stack backtrace:
CPU: 5 PID: 1795 Comm: server Not tainted 5.3.0+ #1
Call Trace:
dump_stack+0x67/0x90
__lock_acquire.cold.67+0xd2/0x20b
lock_acquire+0xb5/0x1c0
lock_sock_nested+0x6d/0x90
__vsock_release+0x24/0xf0 [vsock]
__vsock_release+0xa0/0xf0 [vsock]
vsock_release+0x12/0x30 [vsock]
__sock_release+0x37/0xa0
sock_close+0x14/0x20
__fput+0xc1/0x250
task_work_run+0x98/0xc0
do_exit+0x344/0xc60
do_group_exit+0x47/0xb0
get_signal+0x15c/0xc50
do_signal+0x30/0x720
exit_to_usermode_loop+0x50/0xa0
do_syscall_64+0x24e/0x270
entry_SYSCALL_64_after_hwframe+0x49/0xbe
RIP: 0033:0x7f4184e85f31
Tested-by: Stefano Garzarella <sgarzare@redhat.com>
Signed-off-by: Dexuan Cui <decui@microsoft.com>
Reviewed-by: Stefano Garzarella <sgarzare@redhat.com>
[ Upstream commit 474f0813a3002cb299bb73a5a93aa1f537a80ca8 ]
Make sure TCA_DSMARK_INDICES was provided by the user.
syzbot reported :
kasan: CONFIG_KASAN_INLINE enabled
kasan: GPF could be caused by NULL-ptr deref or user memory access
general protection fault: 0000 [#1] PREEMPT SMP KASAN
CPU: 1 PID: 8799 Comm: syz-executor235 Not tainted 5.3.0+ #0
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
RIP: 0010:nla_get_u16 include/net/netlink.h:1501 [inline]
RIP: 0010:dsmark_init net/sched/sch_dsmark.c:364 [inline]
RIP: 0010:dsmark_init+0x193/0x640 net/sched/sch_dsmark.c:339
Code: 85 db 58 0f 88 7d 03 00 00 e8 e9 1a ac fb 48 8b 9d 70 ff ff ff 48 b8 00 00 00 00 00 fc ff df 48 8d 7b 04 48 89 fa 48 c1 ea 03 <0f> b6 14 02 48 89 f8 83 e0 07 83 c0 01 38 d0 7c 08 84 d2 0f 85 ca
RSP: 0018:ffff88809426f3b8 EFLAGS: 00010247
RAX: dffffc0000000000 RBX: 0000000000000000 RCX: ffffffff85c6eb09
RDX: 0000000000000000 RSI: ffffffff85c6eb17 RDI: 0000000000000004
RBP: ffff88809426f4b0 R08: ffff88808c4085c0 R09: ffffed1015d26159
R10: ffffed1015d26158 R11: ffff8880ae930ac7 R12: ffff8880a7e96940
R13: dffffc0000000000 R14: ffff88809426f8c0 R15: 0000000000000000
FS: 0000000001292880(0000) GS:ffff8880ae900000(0000) knlGS:0000000000000000
CR2: 0000000020000080 CR3: 000000008ca1b000 CR4: 00000000001406e0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Call Trace:
qdisc_create+0x4ee/0x1210 net/sched/sch_api.c:1237
tc_modify_qdisc+0x524/0x1c50 net/sched/sch_api.c:1653
rtnetlink_rcv_msg+0x463/0xb00 net/core/rtnetlink.c:5223
netlink_rcv_skb+0x177/0x450 net/netlink/af_netlink.c:2477
rtnetlink_rcv+0x1d/0x30 net/core/rtnetlink.c:5241
netlink_unicast_kernel net/netlink/af_netlink.c:1302 [inline]
netlink_unicast+0x531/0x710 net/netlink/af_netlink.c:1328
netlink_sendmsg+0x8a5/0xd60 net/netlink/af_netlink.c:1917
sock_sendmsg_nosec net/socket.c:637 [inline]
sock_sendmsg+0xd7/0x130 net/socket.c:657
___sys_sendmsg+0x803/0x920 net/socket.c:2311
__sys_sendmsg+0x105/0x1d0 net/socket.c:2356
__do_sys_sendmsg net/socket.c:2365 [inline]
__se_sys_sendmsg net/socket.c:2363 [inline]
__x64_sys_sendmsg+0x78/0xb0 net/socket.c:2363
do_syscall_64+0xfa/0x760 arch/x86/entry/common.c:290
RIP: 0033:0x440369
Fixes: 758cc43c6d73 ("[PKT_SCHED]: Fix dsmark to apply changes consistent")
Reported-by: syzbot <syzkaller@googlegroups.com>
[ Upstream commit a0c2dc1fe63e2869b74c1c7f6a81d1745c8a695d ]
sysbot reported a memory leak after a bind() has failed.
While we are at it, abort the operation if kmemdup() has failed.
BUG: memory leak
unreferenced object 0xffff888105d83ec0 (size 32):
comm "syz-executor067", pid 7207, jiffies 4294956228 (age 19.430s)
hex dump (first 32 bytes):
00 69 6c 65 20 72 65 61 64 00 6e 65 74 3a 5b 34 .ile read.net:[4
30 32 36 35 33 33 30 39 37 5d 00 00 00 00 00 00 026533097]......
backtrace:
[<0000000036bac473>] kmemleak_alloc_recursive /./include/linux/kmemleak.h:43 [inline]
[<0000000036bac473>] slab_post_alloc_hook /mm/slab.h:522 [inline]
[<0000000036bac473>] slab_alloc /mm/slab.c:3319 [inline]
[<0000000036bac473>] __do_kmalloc /mm/slab.c:3653 [inline]
[<0000000036bac473>] __kmalloc_track_caller+0x169/0x2d0 /mm/slab.c:3670
[<000000000cd39d07>] kmemdup+0x27/0x60 /mm/util.c:120
[<000000008e57e5fc>] kmemdup /./include/linux/string.h:432 [inline]
[<000000008e57e5fc>] llcp_sock_bind+0x1b3/0x230 /net/nfc/llcp_sock.c:107
[<000000009cb0b5d3>] __sys_bind+0x11c/0x140 /net/socket.c:1647
[<00000000492c3bbc>] __do_sys_bind /net/socket.c:1658 [inline]
[<00000000492c3bbc>] __se_sys_bind /net/socket.c:1656 [inline]
[<00000000492c3bbc>] __x64_sys_bind+0x1e/0x30 /net/socket.c:1656
[<0000000008704b2a>] do_syscall_64+0x76/0x1a0 /arch/x86/entry/common.c:296
[<000000009f4c57a4>] entry_SYSCALL_64_after_hwframe+0x44/0xa9
Fixes: 30cc4587659e ("NFC: Move LLCP code to the NFC top level diirectory")
[ Upstream commit 8c7138b33e5c690c308b2a7085f6313fdcb3f616 ]
The "reuse->sock[]" array is shared by multiple sockets. The going away
sk must unpublish itself from "reuse->sock[]" before making call_rcu()
call. However, this unpublish-action is currently done after a grace
period and it may cause use-after-free.
The fix is to move reuseport_detach_sock() to sk_destruct().
Due to the above reason, any socket with sk_reuseport_cb has
to go through the rcu grace period before freeing it.
It is a rather old bug (~3 yrs). The Fixes tag is not necessary
the right commit but it is the one that introduced the SOCK_RCU_FREE
logic and this fix is depending on it.
Fixes: a4298e4522d6 ("net: add SOCK_RCU_FREE socket flag")
Suggested-by: Eric Dumazet <eric.dumazet@gmail.com>
Signed-off-by: Martin KaFai Lau <kafai@fb.com>
[ Upstream commit b406472b5ad79ede8d10077f0c8f05505ace8b6d ]
Since commit c09551c6ff7f ("net: ipv4: use a dedicated counter
for icmp_v4 redirect packets") we use 'n_redirects' to account
for redirect packets, but we still use 'rate_tokens' to compute
the redirect packets exponential backoff.
If the device sent to the relevant peer any ICMP error packet
after sending a redirect, it will also update 'rate_token' according
to the leaking bucket schema; typically 'rate_token' will raise
above BITS_PER_LONG and the redirect packets backoff algorithm
will produce undefined behavior.
Fix the issue using 'n_redirects' to compute the exponential backoff
in ip_rt_send_redirect().
Note that we still clear rate_tokens after a redirect silence period,
to avoid changing an established behaviour.
The root cause predates git history; before the mentioned commit in
the critical scenario, the kernel stopped sending redirects, after
the mentioned commit the behavior more randomic.
Reported-by: Xiumei Mu <xmu@redhat.com>
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Fixes: c09551c6ff7f ("net: ipv4: use a dedicated counter for icmp_v4 redirect packets")
Signed-off-by: Paolo Abeni <pabeni@redhat.com>
Acked-by: Lorenzo Bianconi <lorenzo.bianconi@redhat.com>
[ Upstream commit 6af1799aaf3f1bc8defedddfa00df3192445bbf3 ]
This began with a syzbot report. syzkaller was injecting
IPv6 TCP SYN packets having a v4mapped source address.
After an unsuccessful 4-tuple lookup, TCP creates a request
socket (SYN_RECV) and calls reqsk_queue_hash_req()
reqsk_queue_hash_req() calls sk_ehashfn(sk)
At this point we have AF_INET6 sockets, and the heuristic
used by sk_ehashfn() to either hash the IPv4 or IPv6 addresses
is to use ipv6_addr_v4mapped(&sk->sk_v6_daddr)
For the particular spoofed packet, we end up hashing V4 addresses
which were not initialized by the TCP IPv6 stack, so KMSAN fired
a warning.
I first fixed sk_ehashfn() to test both source and destination addresses,
but then faced various problems, including user-space programs
like packetdrill that had similar assumptions.
Instead of trying to fix the whole ecosystem, it is better
to admit that we have a dual stack behavior, and that we
can not build linux kernels without V4 stack anyway.
The dual stack API automatically forces the traffic to be IPv4
if v4mapped addresses are used at bind() or connect(), so it makes
no sense to allow IPv6 traffic to use the same v4mapped class.
Cc: Florian Westphal <fw@strlen.de>
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
[ Upstream commit 0e141f757b2c78c983df893e9993313e2dc21e38 ]
erspan driver calls ether_setup(), after commit 61e84623ace3
("net: centralize net_device min/max MTU checking"), the range
of mtu is [min_mtu, max_mtu], which is [68, 1500] by default.
It causes the dev mtu of the erspan device to not be greater
than 1500, this limit value is not correct for ipgre tap device.
Tested:
Before patch:
# ip link set erspan0 mtu 1600
Error: mtu greater than device maximum.
After patch:
# ip -d link show erspan0
21: erspan0@NONE: <BROADCAST,MULTICAST> mtu 1600 qdisc noop state DOWN
mode DEFAULT group default qlen 1000
link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff promiscuity 0 minmtu 68 maxmtu 0
Fixes: 61e84623ace3 ("net: centralize net_device min/max MTU checking")
Signed-off-by: Haishuang Yan <yanhaishuang@cmss.chinamobile.com>
commit c1d3ad84eae35414b6b334790048406bd6301b12 upstream.
Currently frame registrations are not purged, even when changing the
interface type. This can lead to potentially weird situations where
frames possibly not allowed on a given interface type remain registered
due to the type switching happening after registration.
The kernel currently relies on userspace apps to actually purge the
registrations themselves, this is not something that the kernel should
rely on.
Add a call to cfg80211_mlme_purge_registrations() to forcefully remove
any registrations left over prior to switching the iftype.
Cc: stable@vger.kernel.org
Signed-off-by: Denis Kenzior <denkenz@gmail.com>
Link: https://lore.kernel.org/r/20190828211110.15005-1-denkenz@gmail.com
[ Upstream commit 3a359798b176183ef09efb7a3dc59abad1cc7104 ]
When creating a raw AF_NFC socket, CAP_NET_RAW needs to be checked
first.
Signed-off-by: Ori Nimron <orinimron123@gmail.com>
[ Upstream commit e69dbd4619e7674c1679cba49afd9dd9ac347eef ]
When creating a raw AF_IEEE802154 socket, CAP_NET_RAW needs to be
checked first.
Acked-by: Stefan Schmidt <stefan@datenfreihafen.org>
[ Upstream commit 0614e2b73768b502fc32a75349823356d98aae2c ]
When creating a raw AF_AX25 socket, CAP_NET_RAW needs to be checked
first.
[ Upstream commit 6cc03e8aa36c51f3b26a0d21a3c4ce2809c842ac ]
When creating a raw AF_APPLETALK socket, CAP_NET_RAW needs to be checked
first.
[ Upstream commit b41d936b5ecfdb3a4abc525ce6402a6c49cffddc ]
syzbot managed to crash the kernel in tabledist() loading
an empty distribution table.
t = dist->table[rnd % dist->size];
Simply return an error when such load is attempted.
Signed-off-by: Jakub Kicinski <jakub.kicinski@netronome.com>
[ Upstream commit ea8564c865299815095bebeb4b25bef474218e4c ]
userspace openvswitch patch "(dpif-linux: Implement the API
functions to allow multiple handler threads read upcall)"
changes its type from U32 to UNSPEC, but leave the kernel
unchanged
and after kernel 6e237d099fac "(netlink: Relax attr validation
for fixed length types)", this bug is exposed by the below
warning
[ 57.215841] netlink: 'ovs-vswitchd': attribute type 5 has an invalid length.
Fixes: 5cd667b0a456 ("openvswitch: Allow each vport to have an array of 'port_id's")
Signed-off-by: Li RongQing <lirongqing@baidu.com>
Acked-by: Pravin B Shelar <pshelar@ovn.org>
[ Upstream commit 62794fc4fbf52f2209dc094ea255eaef760e7d01 ]
The TCA_KIND attribute is of NLA_STRING which does not check
the NUL char. KMSAN reported an uninit-value of TCA_KIND which
is likely caused by the lack of NUL.
Change it to NLA_NUL_STRING and add a max len too.
Fixes: 8b4c3cdd9dd8 ("net: sched: Add policy validation for tc attributes")
Reported-and-tested-by: syzbot+618aacd49e8c8b8486bd@syzkaller.appspotmail.com
Cc: Jamal Hadi Salim <jhs@mojatatu.com>
Reviewed-by: David Ahern <dsahern@gmail.com>
Acked-by: Jiri Pirko <jiri@mellanox.com>
[ Upstream commit 92974a1d006ad8b30d53047c70974c9e065eb7df ]
current 'sample' action doesn't push the mac header of ingress packets if
they are received by a layer 3 tunnel (like gre or sit); but it forgot to
check for gre over ipv6, so the following script:
# tc q a dev $d clsact
# tc f a dev $d ingress protocol ip flower ip_proto icmp action sample \
> group 100 rate 1
# psample -v -g 100
dumps everything, including outer header and mac, when $d is a gre tunnel
over ipv6. Fix this adding a missing label for ARPHRD_IP6GRE devices.
Fixes: 5c5670fae430 ("net/sched: Introduce sample tc action")
Signed-off-by: Davide Caratti <dcaratti@redhat.com>
Reviewed-by: Yotam Gigi <yotam.gi@gmail.com>
[ Upstream commit 73f0c11d11329a0d6d205d4312b6e5d2512af7c5 ]
As the endpoint is unregistered there might still be work pending to
handle incoming messages, which will result in a use after free
scenario. The plan is to remove the rx_worker, but until then (and for
stable@) ensure that the work is stopped before the node is freed.
Fixes: bdabad3e363d ("net: Add Qualcomm IPC router")
Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
[ Upstream commit 1e64d7cbfdce4887008314d5b367209582223f27 ]
If IPV6 was disabled, then ss command would cause a kernel warning
because the command was attempting to dump IPV6 socket information.
The fix is to just remove the warning.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=202249
Fixes: 432490f9d455 ("net: ip, diag -- Add diag interface for raw sockets")
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
[ Upstream commit 68d19d7d995759b96169da5aac313363f92a9075 ]
This reverts commit c49a8682fc5d298d44e8d911f4fa14690ea9485e.
There are devices which require low connection intervals for usable operation
including keyboards and mice. Forcing a static connection interval for
these types of devices has an impact in latency and causes a regression.
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
If a SYN/FIN-segment is on the write-queue, skb->len is 0, but the
segment actually has been transmitted. end_seq and seq of the tcp_skb_cb
in that case will indicate this difference.
We should not remove such segments from the write-queue as we might be
in SYN_SENT-state and a retransmission-timer is running. When that one
fires, packets_out will be 1, but the write-queue would be empty,
resulting in:
[ 61.280214] ------------[ cut here ]------------
[ 61.281307] WARNING: CPU: 0 PID: 0 at net/ipv4/tcp_timer.c:429 tcp_retransmit_timer+0x18f9/0x2660
[ 61.283498] Modules linked in:
[ 61.284084] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.14.142 #58
[ 61.285214] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 0.5.1 01/01/2011
[ 61.286644] task: ffffffff8401e1c0 task.stack: ffffffff84000000
[ 61.287758] RIP: 0010:tcp_retransmit_timer+0x18f9/0x2660
[ 61.288715] RSP: 0018:ffff88806ce07cb8 EFLAGS: 00010206
[ 61.289669] RAX: ffffffff8401e1c0 RBX: ffff88805c998b00 RCX: 0000000000000006
[ 61.290968] RDX: 0000000000000100 RSI: 0000000000000000 RDI: ffff88805c9994d8
[ 61.292314] RBP: ffff88805c99919a R08: ffff88807fff901c R09: ffff88807fff9008
[ 61.293547] R10: ffff88807fff9017 R11: ffff88807fff9010 R12: ffff88805c998b30
[ 61.294834] R13: ffffffff844b9380 R14: 0000000000000000 R15: ffff88805c99930c
[ 61.296086] FS: 0000000000000000(0000) GS:ffff88806ce00000(0000) knlGS:0000000000000000
[ 61.297523] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 61.298646] CR2: 00007f721da50ff8 CR3: 0000000004014002 CR4: 00000000001606f0
[ 61.299944] Call Trace:
[ 61.300403] <IRQ>
[ 61.300806] ? kvm_sched_clock_read+0x21/0x30
[ 61.301689] ? sched_clock+0x5/0x10
[ 61.302433] ? sched_clock_cpu+0x18/0x170
[ 61.303173] tcp_write_timer_handler+0x2c1/0x7a0
[ 61.304038] tcp_write_timer+0x13e/0x160
[ 61.304794] call_timer_fn+0x14a/0x5f0
[ 61.305480] ? tcp_write_timer_handler+0x7a0/0x7a0
[ 61.306364] ? __next_timer_interrupt+0x140/0x140
[ 61.307229] ? _raw_spin_unlock_irq+0x24/0x40
[ 61.308033] ? tcp_write_timer_handler+0x7a0/0x7a0
[ 61.308887] ? tcp_write_timer_handler+0x7a0/0x7a0
[ 61.309760] run_timer_softirq+0xc41/0x1080
[ 61.310539] ? trigger_dyntick_cpu.isra.33+0x180/0x180
[ 61.311506] ? ktime_get+0x13f/0x1c0
[ 61.312232] ? clockevents_program_event+0x10d/0x2f0
[ 61.313158] __do_softirq+0x20b/0x96b
[ 61.313889] irq_exit+0x1a7/0x1e0
[ 61.314513] smp_apic_timer_interrupt+0xfc/0x4d0
[ 61.315386] apic_timer_interrupt+0x8f/0xa0
[ 61.316129] </IRQ>
Followed by a panic.
So, before removing an skb with skb->len == 0, let's make sure that the
skb is really empty by checking the end_seq and seq.
This patch needs to be backported only to 4.14 and older (among those
that applied the backport of fdfc5c8594c2).
Fixes: fdfc5c8594c2 ("tcp: remove empty skb from write queue in error cases")
Cc: Eric Dumazet <edumazet@google.com>
Cc: Jason Baron <jbaron@akamai.com>
Cc: Vladimir Rutsky <rutsky@google.com>
Cc: Soheil Hassas Yeganeh <soheil@google.com>
Cc: Neal Cardwell <ncardwell@google.com>
Signed-off-by: Christoph Paasch <cpaasch@apple.com>
syzkaller is not happy since commit fdfc5c8594c2 ("tcp: remove empty skb
from write queue in error cases"):
CPU: 1 PID: 13814 Comm: syz-executor.4 Not tainted 4.14.143 #5
task: ffff888040105c00 task.stack: ffff8880649c0000
RIP: 0010:tcp_sendmsg_locked+0x6b4/0x4390 net/ipv4/tcp.c:1350
RSP: 0018:ffff8880649cf718 EFLAGS: 00010206
RAX: 0000000000000014 RBX: 000000000000001e RCX: ffffc90000717000
RDX: 0000000000000077 RSI: ffffffff82e760f7 RDI: 00000000000000a0
RBP: ffff8880649cfaa8 R08: 1ffff1100c939e7a R09: ffff8880401063c8
R10: 0000000000000003 R11: 0000000000000001 R12: dffffc0000000000
R13: ffff888043d74750 R14: ffff888043d74500 R15: 000000000000001e
FS: 00007f0afcb6d700(0000) GS:ffff88806cf00000(0000) knlGS:0000000000000000
CR2: 0000001b2ca22000 CR3: 0000000040496004 CR4: 00000000003606e0
Call Trace:
tcp_sendmsg+0x2a/0x40 net/ipv4/tcp.c:1533
inet_sendmsg+0x173/0x4e0 net/ipv4/af_inet.c:784
sock_sendmsg_nosec net/socket.c:646 [inline]
sock_sendmsg+0xc3/0x100 net/socket.c:656
SYSC_sendto+0x35d/0x5e0 net/socket.c:1766
do_syscall_64+0x241/0x680 arch/x86/entry/common.c:292
entry_SYSCALL_64_after_hwframe+0x42/0xb7
The problem is that we are removing an skb from the write-queue that
could have been referenced by the sk_send_head. Thus, we need to check
for the send_head's sanity after removing it.
[ Upstream commit 3a069024d371125227de3ac8fa74223fcf473520 ]
The find_pattern() debug output was printing the 'skip' character.
This can be a NULL-byte and messes up further pr_debug() output.
Output without the fix:
kernel: nf_conntrack_ftp: Pattern matches!
kernel: nf_conntrack_ftp: Skipped up to `<7>nf_conntrack_ftp: find_pattern `PORT': dlen = 8
kernel: nf_conntrack_ftp: find_pattern `EPRT': dlen = 8
Output with the fix:
kernel: nf_conntrack_ftp: Skipped up to 0x0 delimiter!
kernel: nf_conntrack_ftp: Match succeeded!
kernel: nf_conntrack_ftp: conntrack_ftp: match `172,17,0,100,200,207' (20 bytes at 4150681645)
kernel: nf_conntrack_ftp: find_pattern `PORT': dlen = 8
Signed-off-by: Thomas Jarosch <thomas.jarosch@intra2net.com>
[ Upstream commit 0ff0f15a32c093381ad1abc06abe85afb561ab28 ]
Multiple batadv_ogm2_packet can be stored in an skbuff. The functions
batadv_v_ogm_send_to_if() uses batadv_v_ogm_aggr_packet() to check if there
is another additional batadv_ogm2_packet in the skb or not before they
continue processing the packet.
The length for such an OGM2 is BATADV_OGM2_HLEN +
batadv_ogm2_packet->tvlv_len. The check must first check that at least
BATADV_OGM2_HLEN bytes are available before it accesses tvlv_len (which is
part of the header. Otherwise it might try read outside of the currently
available skbuff to get the content of tvlv_len.
Fixes: 9323158ef9f4 ("batman-adv: OGMv2 - implement originators logic")
Signed-off-by: Sven Eckelmann <sven@narfation.org>
Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de>
[ Upstream commit 89a26cd4b501e9511d3cd3d22327fc76a75a38b3 ]
When running a 64-bit kernel with a 32-bit iptables binary, the size of
the xt_nfacct_match_info struct diverges.
kernel: sizeof(struct xt_nfacct_match_info) : 40
iptables: sizeof(struct xt_nfacct_match_info)) : 36
Trying to append nfacct related rules results in an unhelpful message.
Although it is suggested to look for more information in dmesg, nothing
can be found there.
# iptables -A <chain> -m nfacct --nfacct-name <acct-object>
iptables: Invalid argument. Run `dmesg' for more information.
This patch fixes the memory misalignment by enforcing 8-byte alignment
within the struct's first revision. This solution is often used in many
other uapi netfilter headers.
Signed-off-by: Juliana Rodrigueiro <juliana.rodrigueiro@intra2net.com>
Acked-by: Florian Westphal <fw@strlen.de>
commit 4b2c5a14cd8005a900075f7dfec87473c6ee66fb upstream.
commit 1222a1601488 ("nl80211: Fix possible Spectre-v1 for CQM
RSSI thresholds") was incomplete and requires one more fix to
prevent accessing to rssi_thresholds[n] because user can control
rssi_thresholds[i] values to make i reach to n. For example,
rssi_thresholds = {-400, -300, -200, -100} when last is -34.
Fixes: 1222a1601488 ("nl80211: Fix possible Spectre-v1 for CQM RSSI thresholds")
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Masashi Honma <masashi.honma@gmail.com>
Link: https://lore.kernel.org/r/20190908005653.17433-1-masashi.honma@gmail.com
[ Upstream commit 6efb971ba8edfbd80b666f29de12882852f095ae ]
When tcf_block_get() fails in sfb_init(), q->qdisc is still a NULL
pointer which leads to a crash in sfb_destroy(). Similar for
sch_dsmark.
Instead of fixing each separately, Linus suggested to just accept
NULL pointer in qdisc_put(), which would make callers easier.
(For sch_dsmark, the bug probably exists long before commit
6529eaba33f0.)
Fixes: 6529eaba33f0 ("net: sched: introduce tcf block infractructure")
Reported-by: syzbot+d5870a903591faaca4ae@syzkaller.appspotmail.com
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Jiri Pirko <jiri@resnulli.us>
[ Upstream commit 42dec1dbe38239cf91cc1f4df7830c66276ced37 ]
Unlike kfree(p), kfree_rcu(p, rcu) won't do NULL pointer check. When
tipc_nametbl_remove_publ returns NULL, the panic below happens:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000068
RIP: 0010:__call_rcu+0x1d/0x290
Call Trace:
<IRQ>
tipc_publ_notify+0xa9/0x170 [tipc]
tipc_node_write_unlock+0x8d/0x100 [tipc]
tipc_node_link_down+0xae/0x1d0 [tipc]
tipc_node_check_dest+0x3ea/0x8f0 [tipc]
? tipc_disc_rcv+0x2c7/0x430 [tipc]
? tipc_rcv+0x6bb/0xf20 [tipc]
? ip_route_input_slow+0x9cf/0xb10
tipc_udp_recv+0x195/0x1e0 [tipc]
? tipc_udp_is_known_peer+0x80/0x80 [tipc]
udp_queue_rcv_skb+0x180/0x460
udp_unicast_rcv_skb.isra.56+0x75/0x90
__udp4_lib_rcv+0x4ce/0xb90
ip_local_deliver_finish+0x11c/0x210
ip_local_deliver+0x6b/0xe0
? ip_rcv_finish+0xa9/0x410
ip_rcv+0x273/0x362
Fixes: 97ede29e80ee ("tipc: convert name table read-write lock to RCU")
Reported-by: Li Shuang <shuali@redhat.com>
Signed-off-by: Xin Long <lucien.xin@gmail.com>
[ Upstream commit af38d07ed391b21f7405fa1f936ca9686787d6d2 ]
Fix tcp_ecn_withdraw_cwr() to clear the correct bit:
TCP_ECN_QUEUE_CWR.
Rationale: basically, TCP_ECN_DEMAND_CWR is a bit that is purely about
the behavior of data receivers, and deciding whether to reflect
incoming IP ECN CE marks as outgoing TCP th->ece marks. The
TCP_ECN_QUEUE_CWR bit is purely about the behavior of data senders,
and deciding whether to send CWR. The tcp_ecn_withdraw_cwr() function
is only called from tcp_undo_cwnd_reduction() by data senders during
an undo, so it should zero the sender-side state,
TCP_ECN_QUEUE_CWR. It does not make sense to stop the reflection of
incoming CE bits on incoming data packets just because outgoing
packets were spuriously retransmitted.
The bug has been reproduced with packetdrill to manifest in a scenario
with RFC3168 ECN, with an incoming data packet with CE bit set and
carrying a TCP timestamp value that causes cwnd undo. Before this fix,
the IP CE bit was ignored and not reflected in the TCP ECE header bit,
and sender sent a TCP CWR ('W') bit on the next outgoing data packet,
even though the cwnd reduction had been undone. After this fix, the
sender properly reflects the CE bit and does not set the W bit.
Note: the bug actually predates 2005 git history; this Fixes footer is
chosen to be the oldest SHA1 I have tested (from Sep 2007) for which
the patch applies cleanly (since before this commit the code was in a
.h file).
Fixes: bdf1ee5d3bd3 ("[TCP]: Move code from tcp_ecn.h to tcp*.c and tcp.h & remove it")
Signed-off-by: Neal Cardwell <ncardwell@google.com>
Acked-by: Yuchung Cheng <ycheng@google.com>
Acked-by: Soheil Hassas Yeganeh <soheil@google.com>
[ Upstream commit 10eb56c582c557c629271f1ee31e15e7a9b2558b ]
Transport should use its own pf_retrans to do the error_count
check, instead of asoc's. Otherwise, it's meaningless to make
pf_retrans per transport.
Fixes: 5aa93bcf66f4 ("sctp: Implement quick failover draft from tsvwg")
Acked-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
[ Upstream commit b456d72412ca8797234449c25815e82f4e1426c0 ]
The '.exit' functions from 'pernet_operations' structure should be marked
as __net_exit, not __net_init.
Fixes: 8e2d61e0aed2 ("sctp: fix race on protocol/netns initialization")
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
[ Upstream commit d4d6ec6dac07f263f06d847d6f732d6855522845 ]
In case of TCA_HHF_NON_HH_WEIGHT or TCA_HHF_QUANTUM is zero,
it would make no progress inside the loop in hhf_dequeue() thus
kernel would get stuck.
Fix this by checking this corner case in hhf_change().
Fixes: 10239edf86f1 ("net-qdisc-hhf: Heavy-Hitter Filter (HHF) qdisc")
Reported-by: syzbot+bc6297c11f19ee807dc2@syzkaller.appspotmail.com
Reported-by: syzbot+041483004a7f45f1f20a@syzkaller.appspotmail.com
Reported-by: syzbot+55be5f513bed37fc4367@syzkaller.appspotmail.com
Cc: Terry Lam <vtlam@google.com>
linear-headed frag_list
[ Upstream commit 3dcbdb134f329842a38f0e6797191b885ab00a00 ]
Historically, support for frag_list packets entering skb_segment() was
limited to frag_list members terminating on exact same gso_size
boundaries. This is verified with a BUG_ON since commit 89319d3801d1
("net: Add frag_list support to skb_segment"), quote:
As such we require all frag_list members terminate on exact MSS
boundaries. This is checked using BUG_ON.
As there should only be one producer in the kernel of such packets,
namely GRO, this requirement should not be difficult to maintain.
However, since commit 6578171a7ff0 ("bpf: add bpf_skb_change_proto helper"),
the "exact MSS boundaries" assumption no longer holds:
An eBPF program using bpf_skb_change_proto() DOES modify 'gso_size', but
leaves the frag_list members as originally merged by GRO with the
original 'gso_size'. Example of such programs are bpf-based NAT46 or
NAT64.
This lead to a kernel BUG_ON for flows involving:
- GRO generating a frag_list skb
- bpf program performing bpf_skb_change_proto() or bpf_skb_adjust_room()
- skb_segment() of the skb
See example BUG_ON reports in [0].
In commit 13acc94eff12 ("net: permit skb_segment on head_frag frag_list skb"),
skb_segment() was modified to support the "gso_size mangling" case of
a frag_list GRO'ed skb, but *only* for frag_list members having
head_frag==true (having a page-fragment head).
Alas, GRO packets having frag_list members with a linear kmalloced head
(head_frag==false) still hit the BUG_ON.
This commit adds support to skb_segment() for a 'head_skb' packet having
a frag_list whose members are *non* head_frag, with gso_size mangled, by
disabling SG and thus falling-back to copying the data from the given
'head_skb' into the generated segmented skbs - as suggested by Willem de
Bruijn [1].
Since this approach involves the penalty of skb_copy_and_csum_bits()
when building the segments, care was taken in order to enable this
solution only when required:
- untrusted gso_size, by testing SKB_GSO_DODGY is set
(SKB_GSO_DODGY is set by any gso_size mangling functions in
net/core/filter.c)
- the frag_list is non empty, its item is a non head_frag, *and* the
headlen of the given 'head_skb' does not match the gso_size.
[0]
https://lore.kernel.org/netdev/20190826170724.25ff616f@pixies/
https://lore.kernel.org/netdev/9265b93f-253d-6b8c-f2b8-4b54eff1835c@fb.com/
[1]
https://lore.kernel.org/netdev/CA+FuTSfVsgNDi7c=GUU8nMg2hWxF2SjCNLXetHeVPdnxAW5K-w@mail.gmail.com/
Fixes: 6578171a7ff0 ("bpf: add bpf_skb_change_proto helper")
Suggested-by: Willem de Bruijn <willemdebruijn.kernel@gmail.com>
Cc: Daniel Borkmann <daniel@iogearbox.net>
Cc: Alexander Duyck <alexander.duyck@gmail.com>
Signed-off-by: Shmulik Ladkani <shmulik.ladkani@gmail.com>
Reviewed-by: Willem de Bruijn <willemb@google.com>
Reviewed-by: Alexander Duyck <alexander.h.duyck@linux.intel.com>
[ Upstream commit 10cc514f451a0f239aa34f91bc9dc954a9397840 ]
In event of failure during register_netdevice, free_netdev is
invoked immediately. free_netdev assumes that all the netdevice
refcounts have been dropped prior to it being called and as a
result frees and clears out the refcount pointer.
However, this is not necessarily true as some of the operations
in the NETDEV_UNREGISTER notifier handlers queue RCU callbacks for
invocation after a grace period. The IPv4 callback in_dev_rcu_put
tries to access the refcount after free_netdev is called which
leads to a null de-reference-
44837.761523: <6> Unable to handle kernel paging request at
virtual address 0000004a88287000
44837.761651: <2> pc : in_dev_finish_destroy+0x4c/0xc8
44837.761654: <2> lr : in_dev_finish_destroy+0x2c/0xc8
44837.762393: <2> Call trace:
44837.762398: <2> in_dev_finish_destroy+0x4c/0xc8
44837.762404: <2> in_dev_rcu_put+0x24/0x30
44837.762412: <2> rcu_nocb_kthread+0x43c/0x468
44837.762418: <2> kthread+0x118/0x128
44837.762424: <2> ret_from_fork+0x10/0x1c
Fix this by waiting for the completion of the call_rcu() in
case of register_netdevice errors.
Fixes: 93ee31f14f6f ("[NET]: Fix free_netdev on register_netdev failure.")
Cc: Sean Tranchetti <stranche@codeaurora.org>
Signed-off-by: Subash Abhinov Kasiviswanathan <subashab@codeaurora.org>
[ Upstream commit d23dbc479a8e813db4161a695d67da0e36557846 ]
Fixes: d862e5461423 ("net: ipv6: Implement /proc/net/icmp6.")
[ Upstream commit 94a72b3f024fc7e9ab640897a1e38583a470659d ]
NLM_F_MULTI must be used only when a NLMSG_DONE message is sent at the end.
In fact, NLMSG_DONE is sent only at the end of a dump.
Libraries like libnl will wait forever for NLMSG_DONE.
Fixes: 949f1e39a617 ("bridge: mdb: notify on router port add and del")
CC: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Acked-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
[ Upstream commit 685703b497bacea8765bb409d6b73455b73c540e ]
There is a race condition for an established connection that is being closed
by the guest: the refcnt is 4 at the end of hvs_release() (Note: here the
'remove_sock' is false):
1 for the initial value;
1 for the sk being in the bound list;
1 for the sk being in the connected list;
1 for the delayed close_work.
After hvs_release() finishes, __vsock_release() -> sock_put(sk) *may*
decrease the refcnt to 3.
Concurrently, hvs_close_connection() runs in another thread:
calls vsock_remove_sock() to decrease the refcnt by 2;
call sock_put() to decrease the refcnt to 0, and free the sk;
next, the "release_sock(sk)" may hang due to use-after-free.
In the above, after hvs_release() finishes, if hvs_close_connection() runs
faster than "__vsock_release() -> sock_put(sk)", then there is not any issue,
because at the beginning of hvs_close_connection(), the refcnt is still 4.
The issue can be resolved if an extra reference is taken when the
connection is established.
Fixes: a9eeb998c28d ("hv_sock: Add support for delayed close")
Reviewed-by: Sunil Muthuswamy <sunilmut@microsoft.com>
commit a15d56a60760aa9dbe26343b9a0ac5228f35d445 upstream.
Multiple batadv_ogm_packet can be stored in an skbuff. The functions
batadv_iv_ogm_send_to_if()/batadv_iv_ogm_receive() use
batadv_iv_ogm_aggr_packet() to check if there is another additional
batadv_ogm_packet in the skb or not before they continue processing the
packet.
The length for such an OGM is BATADV_OGM_HLEN +
batadv_ogm_packet->tvlv_len. The check must first check that at least
BATADV_OGM_HLEN bytes are available before it accesses tvlv_len (which is
Fixes: ef26157747d4 ("batman-adv: tvlv - basic infrastructure")
Reported-by: syzbot+355cab184197dbbfa384@syzkaller.appspotmail.com
Acked-by: Antonio Quartulli <a@unstable.cc>
commit 3ee1bb7aae97324ec9078da1f00cb2176919563f upstream.
batadv_netlink_get_ifindex() needs to make sure user passed
a correct u32 attribute.
syzbot reported :
BUG: KMSAN: uninit-value in batadv_netlink_dump_hardif+0x70d/0x880 net/batman-adv/netlink.c:968
CPU: 1 PID: 11705 Comm: syz-executor888 Not tainted 5.1.0+ #1
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x191/0x1f0 lib/dump_stack.c:113
kmsan_report+0x130/0x2a0 mm/kmsan/kmsan.c:622
__msan_warning+0x75/0xe0 mm/kmsan/kmsan_instr.c:310
genl_lock_dumpit+0xc6/0x130 net/netlink/genetlink.c:482
netlink_dump+0xa84/0x1ab0 net/netlink/af_netlink.c:2253
__netlink_dump_start+0xa3a/0xb30 net/netlink/af_netlink.c:2361
genl_family_rcv_msg net/netlink/genetlink.c:550 [inline]
genl_rcv_msg+0xfc1/0x1a40 net/netlink/genetlink.c:627
netlink_rcv_skb+0x431/0x620 net/netlink/af_netlink.c:2486
genl_rcv+0x63/0x80 net/netlink/genetlink.c:638
netlink_unicast_kernel net/netlink/af_netlink.c:1311 [inline]
netlink_unicast+0xf3e/0x1020 net/netlink/af_netlink.c:1337
netlink_sendmsg+0x127e/0x12f0 net/netlink/af_netlink.c:1926
sock_sendmsg_nosec net/socket.c:651 [inline]
sock_sendmsg net/socket.c:661 [inline]
___sys_sendmsg+0xcc6/0x1200 net/socket.c:2260
__sys_sendmsg net/socket.c:2298 [inline]
__do_sys_sendmsg net/socket.c:2307 [inline]
__se_sys_sendmsg+0x305/0x460 net/socket.c:2305
__x64_sys_sendmsg+0x4a/0x70 net/socket.c:2305
do_syscall_64+0xbc/0xf0 arch/x86/entry/common.c:291
entry_SYSCALL_64_after_hwframe+0x63/0xe7
RIP: 0033:0x440209
Fixes: b60620cf567b ("batman-adv: netlink: hardif query")
commit dbb2483b2a46fbaf833cfb5deb5ed9cace9c7399 upstream.
In commit 6a53b7593233 ("xfrm: check id proto in validate_tmpl()")
I introduced a check for xfrm protocol, but according to Herbert
IPSEC_PROTO_ANY should only be used as a wildcard for lookup, so
it should be removed from validate_tmpl().
And, IPSEC_PROTO_ANY is expected to only match 3 IPSec-specific
protocols, this is why xfrm_state_flush() could still miss
IPPROTO_ROUTING, which leads that those entries are left in
net->xfrm.state_all before exit net. Fix this by replacing
IPSEC_PROTO_ANY with zero.
This patch also extracts the check from validate_tmpl() to
xfrm_id_proto_valid() and uses it in parse_ipsecrequest().
With this, no other protocols should be added into xfrm.
Fixes: 6a53b7593233 ("xfrm: check id proto in validate_tmpl()")
Reported-by: syzbot+0bf0519d6e0de15914fe@syzkaller.appspotmail.com
Cc: Steffen Klassert <steffen.klassert@secunet.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
Signed-off-by: Zubin Mithra <zsm@chromium.org>
[ Upstream commit a84d016479896b5526a2cc54784e6ffc41c9d6f6 ]
Similar to the fix done for IPv4 in commit e5b1c6c6277d
("igmp: fix memory leak in igmpv3_del_delrec()"), we need to
make sure mca_tomb and mca_sources are not blindly overwritten.
Using swap() then a call to ip6_mc_clear_src() will take care
of the missing free.
BUG: memory leak
unreferenced object 0xffff888117d9db00 (size 64):
comm "syz-executor247", pid 6918, jiffies 4294943989 (age 25.350s)
00 00 00 00 00 00 00 00 fe 88 00 00 00 00 00 00 ................
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
backtrace:
[<000000005b463030>] kmemleak_alloc_recursive include/linux/kmemleak.h:43 [inline]
[<000000005b463030>] slab_post_alloc_hook mm/slab.h:522 [inline]
[<000000005b463030>] slab_alloc mm/slab.c:3319 [inline]
[<000000005b463030>] kmem_cache_alloc_trace+0x145/0x2c0 mm/slab.c:3548
[<00000000939cbf94>] kmalloc include/linux/slab.h:552 [inline]
[<00000000939cbf94>] kzalloc include/linux/slab.h:748 [inline]
[<00000000939cbf94>] ip6_mc_add1_src net/ipv6/mcast.c:2236 [inline]
[<00000000939cbf94>] ip6_mc_add_src+0x31f/0x420 net/ipv6/mcast.c:2356
[<00000000d8972221>] ip6_mc_source+0x4a8/0x600 net/ipv6/mcast.c:449
[<000000002b203d0d>] do_ipv6_setsockopt.isra.0+0x1b92/0x1dd0 net/ipv6/ipv6_sockglue.c:748
[<000000001f1e2d54>] ipv6_setsockopt+0x89/0xd0 net/ipv6/ipv6_sockglue.c:944
[<00000000c8f7bdf9>] udpv6_setsockopt+0x4e/0x90 net/ipv6/udp.c:1558
[<000000005a9a0c5e>] sock_common_setsockopt+0x38/0x50 net/core/sock.c:3139
[<00000000910b37b2>] __sys_setsockopt+0x10f/0x220 net/socket.c:2084
[<00000000e9108023>] __do_sys_setsockopt net/socket.c:2100 [inline]
[<00000000e9108023>] __se_sys_setsockopt net/socket.c:2097 [inline]
[<00000000e9108023>] __x64_sys_setsockopt+0x26/0x30 net/socket.c:2097
[<00000000f4818160>] do_syscall_64+0x76/0x1a0 arch/x86/entry/common.c:296
[<000000008d367e8f>] entry_SYSCALL_64_after_hwframe+0x44/0xa9
Fixes: 1666d49e1d41 ("mld: do not remove mld souce list info when set link down")
Fixes: 9c8bb163ae78 ("igmp, mld: Fix memory leak in igmpv3/mld_del_delrec()")
[ Upstream commit dbf47a2a094edf58983265e323ca4bdcdb58b5ee ]
Action sample doesn't properly handle psample_group pointer in overwrite
case. Following issues need to be fixed:
- In tcf_sample_init() function RCU_INIT_POINTER() is used to set
s->psample_group, even though we neither setting the pointer to NULL, nor
preventing concurrent readers from accessing the pointer in some way.
Use rcu_swap_protected() instead to safely reset the pointer.
- Old value of s->psample_group is not released or deallocated in any way,
which results resource leak. Use psample_group_put() on non-NULL value
obtained with rcu_swap_protected().
- The function psample_group_put() that released reference to struct
psample_group pointed by rcu-pointer s->psample_group doesn't respect rcu
grace period when deallocating it. Extend struct psample_group with rcu
head and use kfree_rcu when freeing it.
Signed-off-by: Vlad Buslov <vladbu@mellanox.com>
[ Upstream commit fdfc5c8594c24c5df883583ebd286321a80e0a67 ]
Vladimir Rutsky reported stuck TCP sessions after memory pressure
events. Edge Trigger epoll() user would never receive an EPOLLOUT
notification allowing them to retry a sendmsg().
Jason tested the case of sk_stream_alloc_skb() returning NULL,
but there are other paths that could lead both sendmsg() and sendpage()
to return -1 (EAGAIN), with an empty skb queued on the write queue.
This patch makes sure we remove this empty skb so that
Jason code can detect that the queue is empty, and
call sk->sk_write_space(sk) accordingly.
Fixes: ce5ec440994b ("tcp: ensure epoll edge trigger wakeup when write queue is empty")
Reported-by: Vladimir Rutsky <rutsky@google.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
[ Upstream commit 888a5c53c0d8be6e98bc85b677f179f77a647873 ]
TCP associates tx timestamp requests with a byte in the bytestream.
If merging skbs in tcp_mtu_probe, migrate the tstamp request.
Similar to MSG_EOR, do not allow moving a timestamp from any segment
in the probe but the last. This to avoid merging multiple timestamps.
Tested with the packetdrill script at
https://github.com/wdebruij/packetdrill/commits/mtu_probe-1
Link: http://patchwork.ozlabs.org/patch/1143278/#2232897
Fixes: 4ed2d765dfac ("net-timestamp: TCP timestamping")
Signed-off-by: Willem de Bruijn <willemb@google.com>
[ Upstream commit 981471bd3abf4d572097645d765391533aac327d ]
The net pointer in struct xt_tgdtor_param is not explicitly
initialized therefore is still NULL when dereferencing it.
So we have to find a way to pass the correct net pointer to
ipt_destroy_target().
The best way I find is just saving the net pointer inside the per
netns struct tcf_idrinfo, which could make this patch smaller.
Fixes: 0c66dc1ea3f0 ("netfilter: conntrack: register hooks in netns when needed by ruleset")
Reported-and-tested-by: itugrok@yahoo.com
[ Upstream commit 2c1644cf6d46a8267d79ed95cb9b563839346562 ]
After commit baeababb5b85d5c4e6c917efe2a1504179438d3b
("tun: return NET_XMIT_DROP for dropped packets"),
when tun_net_xmit drop packets, it will free skb and return NET_XMIT_DROP,
netpoll_send_skb_on_dev will run into following use after free cases:
1. retry netpoll_start_xmit with freed skb;
2. queue freed skb in npinfo->txq.
queue_process will also run into use after free case.
hit netpoll_send_skb_on_dev first case with following kernel log:
[ 117.864773] kernel BUG at mm/slub.c:306!
[ 117.864773] invalid opcode: 0000 [#1] SMP PTI
[ 117.864774] CPU: 3 PID: 2627 Comm: loop_printmsg Kdump: loaded Tainted: P OE 5.3.0-050300rc5-generic #201908182231
[ 117.864775] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
[ 117.864775] RIP: 0010:kmem_cache_free+0x28d/0x2b0
[ 117.864781] Call Trace:
[ 117.864781] ? tun_net_xmit+0x21c/0x460
[ 117.864781] kfree_skbmem+0x4e/0x60
[ 117.864782] kfree_skb+0x3a/0xa0
[ 117.864782] tun_net_xmit+0x21c/0x460
[ 117.864782] netpoll_start_xmit+0x11d/0x1b0
[ 117.864788] netpoll_send_skb_on_dev+0x1b8/0x200
[ 117.864789] __br_forward+0x1b9/0x1e0 [bridge]
[ 117.864789] ? skb_clone+0x53/0xd0
[ 117.864790] ? __skb_clone+0x2e/0x120
[ 117.864790] deliver_clone+0x37/0x50 [bridge]
[ 117.864790] maybe_deliver+0x89/0xc0 [bridge]
[ 117.864791] br_flood+0x6c/0x130 [bridge]
[ 117.864791] br_dev_xmit+0x315/0x3c0 [bridge]
[ 117.864792] netpoll_start_xmit+0x11d/0x1b0
[ 117.864792] netpoll_send_skb_on_dev+0x1b8/0x200
[ 117.864792] netpoll_send_udp+0x2c6/0x3e8
[ 117.864793] write_msg+0xd9/0xf0 [netconsole]
[ 117.864793] console_unlock+0x386/0x4e0
[ 117.864793] vprintk_emit+0x17e/0x280
[ 117.864794] vprintk_default+0x29/0x50
[ 117.864794] vprintk_func+0x4c/0xbc
[ 117.864794] printk+0x58/0x6f
[ 117.864795] loop_fun+0x24/0x41 [printmsg_loop]
[ 117.864795] kthread+0x104/0x140
[ 117.864795] ? 0xffffffffc05b1000
[ 117.864796] ? kthread_park+0x80/0x80
[ 117.864796] ret_from_fork+0x35/0x40
Signed-off-by: Feng Sun <loyou85@gmail.com>
Signed-off-by: Xiaojun Zhao <xiaojunzhao141@gmail.com>
commit 5fd2f91ad483baffdbe798f8a08f1b41442d1e24 upstream.
If TDLS station addition is rejected, the sta memory is leaked.
Avoid this by moving the check before the allocation.
Fixes: 7ed5285396c2 ("mac80211: don't initiate TDLS connection if station is not associated to AP")
Link: https://lore.kernel.org/r/20190801073033.7892-1-johannes@sipsolutions.net
commit 0d31d4dbf38412f5b8b11b4511d07b840eebe8cb upstream.
This reverts commit 96cce12ff6e0 ("cfg80211: fix processing world
regdomain when non modular").
Re-triggering a reg_process_hint with the last request on all events,
can make the regulatory domain fail in case of multiple WiFi modules. On
slower boards (espacially with mdev), enumeration of the WiFi modules
can end up in an intersected regulatory domain, and user cannot set it
with 'iw reg set' anymore.
This is happening, because:
- 1st module enumerates, queues up a regulatory request
- request gets processed by __reg_process_hint_driver():
- checks if previous was set by CORE -> yes
- checks if regulator domain changed -> yes, from '00' to e.g. 'US'
-> sends request to the 'crda'
- 2nd module enumerates, queues up a regulator request (which triggers
the reg_todo() work)
- reg_todo() -> reg_process_pending_hints() sees, that the last request
is not processed yet, so it tries to process it again.
__reg_process_hint driver() will run again, and:
- checks if the last request's initiator was the core -> no, it was
the driver (1st WiFi module)
- checks, if the previous initiator was the driver -> yes
- checks if the regulator domain changed -> yes, it was '00' (set by
core, and crda call did not return yet), and should be changed to 'US'
------> __reg_process_hint_driver calls an intersect
Besides, the reg_process_hint call with the last request is meaningless
since the crda call has a timeout work. If that timeout expires, the
first module's request will lost.
Fixes: 96cce12ff6e0 ("cfg80211: fix processing world regdomain when non modular")
Signed-off-by: Robert Hodaszi <robert.hodaszi@digi.com>
Link: https://lore.kernel.org/r/20190614131600.GA13897@a1-hr
[ Upstream commit ef8d8ccdc216f797e66cb4a1372f5c4c285ce1e4 ]
As Jason Baron explained in commit 790ba4566c1a ("tcp: set SOCK_NOSPACE
under memory pressure"), it is crucial we properly set SOCK_NOSPACE
when needed.
However, Jason patch had a bug, because the 'nonblocking' status
as far as sk_stream_wait_memory() is concerned is governed
by MSG_DONTWAIT flag passed at sendmsg() time :
long timeo = sock_sndtimeo(sk, flags & MSG_DONTWAIT);
So it is very possible that tcp sendmsg() calls sk_stream_wait_memory(),
and that sk_stream_wait_memory() returns -EAGAIN with SOCK_NOSPACE
cleared, if sk->sk_sndtimeo has been set to a small (but not zero)
value.
This patch removes the 'noblock' variable since we must always
set SOCK_NOSPACE if -EAGAIN is returned.
It also renames the do_nonblock label since we might reach this
code path even if we were in blocking mode.
Fixes: 790ba4566c1a ("tcp: set SOCK_NOSPACE under memory pressure")
Acked-by: Jason Baron <jbaron@akamai.com>
