path: root/net
2012-01-06ipip, sit: copy parms.name after register_netdeviceTed Feng
commit 72b36015ba43a3cca5303f5534d2c3e1899eae29 upstream. Same fix as 731abb9cb2 for ipip and sit tunnel. Commit 1c5cae815d removed an explicit call to dev_alloc_name in ipip_tunnel_locate and ipip6_tunnel_locate, because register_netdevice will now create a valid name, however the tunnel keeps a copy of the name in the private parms structure. Fix this by copying the name back after register_netdevice has successfully returned. This shows up if you do a simple tunnel add, followed by a tunnel show: $ sudo ip tunnel add mode ipip remote 10.2.20.211 $ ip tunnel tunl0: ip/ip remote any local any ttl inherit nopmtudisc tunl%d: ip/ip remote 10.2.20.211 local any ttl inherit $ sudo ip tunnel add mode sit remote 10.2.20.212 $ ip tunnel sit0: ipv6/ip remote any local any ttl 64 nopmtudisc 6rd-prefix 2002::/16 sit%d: ioctl 89f8 failed: No such device sit%d: ipv6/ip remote 10.2.20.212 local any ttl inherit Signed-off-by: Ted Feng <artisdom@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-14Merge branch 'linux-3.1.5' into android-tegra-nv-3.1Varun Wadekar
Conflicts: arch/arm/Kconfig Change-Id: If8aaaf3efcbbf6c9017b38efb6d76ef933f147fa Signed-off-by: Varun Wadekar <vwadekar@nvidia.com>
2011-12-09sch_red: fix red_changeEric Dumazet
[ Upstream commit 1ee5fa1e9970a16036e37c7b9d5ce81c778252fc ] Le mercredi 30 novembre 2011 à 14:36 -0800, Stephen Hemminger a écrit : > (Almost) nobody uses RED because they can't figure it out. > According to Wikipedia, VJ says that: > "there are not one, but two bugs in classic RED." RED is useful for high throughput routers, I doubt many linux machines act as such devices. I was considering adding Adaptative RED (Sally Floyd, Ramakrishna Gummadi, Scott Shender), August 2001 In this version, maxp is dynamic (from 1% to 50%), and user only have to setup min_th (target average queue size) (max_th and wq (burst in linux RED) are automatically setup) By the way it seems we have a small bug in red_change() if (skb_queue_empty(&sch->q)) red_end_of_idle_period(&q->parms); First, if queue is empty, we should call red_start_of_idle_period(&q->parms); Second, since we dont use anymore sch->q, but q->qdisc, the test is meaningless. Oh well... [PATCH] sch_red: fix red_change() Now RED is classful, we must check q->qdisc->q.qlen, and if queue is empty, we start an idle period, not end it. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09ipv4: make sure RTO_ONLINK is saved in routing cacheJulian Anastasov
[ Upstream commit f61759e6b831a55b89e584b198c3da325e2bc379 ] __mkroute_output fails to work with the original tos and uses value with stripped RTO_ONLINK bit. Make sure we put the original TOS bits into rt_key_tos because it used to match cached route. Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09ipv4: Perform peer validation on cached route lookup.David S. Miller
[ Upstream commit efbc368dcc6426d5430b9b8eeda944cf2cb74b8c, incorporating a follow-on change to prevent an OOPS ] Otherwise we won't notice the peer GENID change. Reported-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09inet: add a redirect generation id in inetpeerEric Dumazet
[ Upstream commit de68dca1816660b0d3ac89fa59ffb410007a143f ] Now inetpeer is the place where we cache redirect information for ipv4 destinations, we must be able to invalidate informations when a route is added/removed on host. As inetpeer is not yet namespace aware, this patch adds a shared redirect_genid, and a per inetpeer redirect_genid. This might be changed later if inetpeer becomes ns aware. Cache information for one inerpeer is valid as long as its redirect_genid has the same value than global redirect_genid. Reported-by: Arkadiusz Miśkiewicz <a.miskiewicz@gmail.com> Tested-by: Arkadiusz Miśkiewicz <a.miskiewicz@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09ipv4: fix redirect handlingEric Dumazet
[ Upstream commit 9cc20b268a5a14f5e57b8ad405a83513ab0d78dc ] commit f39925dbde77 (ipv4: Cache learned redirect information in inetpeer.) introduced a regression in ICMP redirect handling. It assumed ipv4_dst_check() would be called because all possible routes were attached to the inetpeer we modify in ip_rt_redirect(), but thats not true. commit 7cc9150ebe (route: fix ICMP redirect validation) tried to fix this but solution was not complete. (It fixed only one route) So we must lookup existing routes (including different TOS values) and call check_peer_redir() on them. Reported-by: Ivan Zahariev <famzah@icdsoft.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Flavio Leitner <fbl@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09route: fix ICMP redirect validationFlavio Leitner
[ Upstream commit 7cc9150ebe8ec06cafea9f1c10d92ddacf88d8ae ] The commit f39925dbde7788cfb96419c0f092b086aa325c0f (ipv4: Cache learned redirect information in inetpeer.) removed some ICMP packet validations which are required by RFC 1122, section 3.2.2.2: ... A Redirect message SHOULD be silently discarded if the new gateway address it specifies is not on the same connected (sub-) net through which the Redirect arrived [INTRO:2, Appendix A], or if the source of the Redirect is not the current first-hop gateway for the specified destination (see Section 3.3.1). Signed-off-by: Flavio Leitner <fbl@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09ipv4: avoid useless call of the function check_peer_pmtuGao feng
[ Upstream commit 59445b6b1f90b97c4e28062b96306bacfa4fb170 ] In func ipv4_dst_check,check_peer_pmtu should be called only when peer is updated. So,if the peer is not updated in ip_rt_frag_needed,we can not inc __rt_peer_genid. Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09sch_teql: fix lockdep splatEric Dumazet
[ Upstream commit f7e57044eeb1841847c24aa06766c8290c202583 ] We need rcu_read_lock() protection before using dst_get_neighbour(), and we must cache its value (pass it to __teql_resolve()) teql_master_xmit() is called under rcu_read_lock_bh() protection, its not enough. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09ipv4: fix lockdep splat in rt_cache_seq_showEric Dumazet
[ Upstream commit 218fa90f072e4aeff9003d57e390857f4f35513e ] After commit f2c31e32b378 (fix NULL dereferences in check_peer_redir()), dst_get_neighbour() should be guarded by rcu_read_lock() / rcu_read_unlock() section. Reported-by: Miles Lane <miles.lane@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09ipv4: fix for ip_options_rcv_srr() daddr update.Li Wei
[ Upstream commit b12f62efb8ec0b9523bdb6c2d412c07193086de9 ] When opt->srr_is_hit is set skb_rtable(skb) has been updated for 'nexthop' and iph->daddr should always equals to skb_rtable->rt_dst holds, We need update iph->daddr either. Signed-off-by: Li Wei <lw@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09ah: Read nexthdr value before overwriting it in ahash input callback.Nick Bowler
[ Upstream commit b7ea81a58adc123a4e980cb0eff9eb5c144b5dc7 ] The AH4/6 ahash input callbacks read out the nexthdr field from the AH header *after* they overwrite that header. This is obviously not going to end well. Fix it up. Signed-off-by: Nick Bowler <nbowler@elliptictech.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09ah: Correctly pass error codes in ahash output callback.Nick Bowler
[ Upstream commit 069294e813ed5f27f82613b027609bcda5f1b914 ] The AH4/6 ahash output callbacks pass nexthdr to xfrm_output_resume instead of the error code. This appears to be a copy+paste error from the input case, where nexthdr is expected. This causes the driver to continuously add AH headers to the datagram until either an allocation fails and the packet is dropped or the ahash driver hits a synchronous fallback and the resulting monstrosity is transmitted. Correct this issue by simply passing the error code unadulterated. Signed-off-by: Nick Bowler <nbowler@elliptictech.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09cfg80211: amend regulatory NULL dereference fixLuis R. Rodriguez
commit 0bac71af6e66dc798bf07d0c0dd14ee5503362f9 upstream. Johannes' patch for "cfg80211: fix regulatory NULL dereference" broke user regulaotry hints and it did not address the fact that last_request was left populated even if the previous regulatory hint was stale due to the wiphy disappearing. Fix user reguluatory hints by only bailing out if for those regulatory hints where a request_wiphy is expected. The stale last_request considerations are addressed through the previous fixes on last_request where we reset the last_request to a static world regdom request upon reset_regdomains(). In this case though we further enhance the effect by simply restoring reguluatory settings completely. Cc: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09cfg80211: fix race on init and driver registrationLuis R. Rodriguez
commit a042994dd377d86bff9446ee76151ceb6267c9ba upstream. There is a theoretical race that if hit will trigger a crash. The race is between when we issue the first regulatory hint, regulatory_hint_core(), gets processed by the workqueue and between when the first device gets registered to the wireless core. This is not easy to reproduce but it was easy to do so through the regulatory simulator I have been working on. This is a port of the fix I implemented there [1]. [1] https://github.com/mcgrof/regsim/commit/a246ccf81f059cb662eee288aa13100f631e4cc8 Cc: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09mac80211: fix race condition caused by late addBA responseNikolay Martynov
Upstream commit d305a6557b2c4dca0110f05ffe745b1ef94adb80. If addBA responses comes in just after addba_resp_timer has expired mac80211 will still accept it and try to open the aggregation session. This causes drivers to be confused and in some cases even crash. This patch fixes the race condition and makes sure that if addba_resp_timer has expired addBA response is not longer accepted and we do not try to open half-closed session. Signed-off-by: Nikolay Martynov <mar.kolya@gmail.com> [some adjustments] Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-12-09mac80211: fill rate filter for internal scan requestsSimon Wunderlich
commit c72e8d335e2c6a309b6281f2abcf491f37b8b92b upstream. The rates bitmap for internal scan requests shoud be filled, otherwise there will be probe requests with zero rates supported. Signed-off-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de> Signed-off-by: Mathias Kretschmer <mathias.kretschmer@fokus.fraunhofer.de> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09bridge: correct IPv6 checksum after pullstephen hemminger
commit fa2da8cdae1dd64f78fc915ca1d1a4a93c71e7cb upstream. Bridge multicast snooping of ICMPv6 would incorrectly report a checksum problem when used with Ethernet devices like sky2 that use CHECKSUM_COMPLETE. When bytes are removed from skb, the computed checksum needs to be adjusted. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Tested-by: Martin Volf <martin.volf.42@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09mac80211: fix race between the AGG SM and the Tx data pathEmmanuel Grumbach
commit 2a1e0fd175dcfd72096ba9291d31e3b1b5342e60 upstream. When a packet is supposed to sent be as an a-MPDU, mac80211 sets IEEE80211_TX_CTL_AMPDU to let the driver know. On the other hand, mac80211 configures the driver for aggregration with the ampdu_action callback. There is race between these two mechanisms since the following scenario can occur when the BA agreement is torn down: Tx softIRQ drv configuration ========== ================= check OPERATIONAL bit Set the TX_CTL_AMPDU bit in the packet clear OPERATIONAL bit stop Tx AGG Pass Tx packet to the driver. In that case the driver would get a packet with TX_CTL_AMPDU set although it has already been notified that the BA session has been torn down. To fix this, we need to synchronize all the Qdisc activity after we cleared the OPERATIONAL bit. After that step, all the following packets will be buffered until the driver reports it is ready to get new packets for this RA / TID. This buffering allows not to run into another race that would send packets with TX_CTL_AMPDU unset while the driver hasn't been requested to tear down the BA session yet. This race occurs in practice and iwlwifi complains with a WARN_ON when it happens. Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09mac80211: don't stop a single aggregation session twiceJohannes Berg
commit 24f50a9d165745fd0701c6e089d35f58a229ea69 upstream. Nikolay noticed (by code review) that mac80211 can attempt to stop an aggregation session while it is already being stopped. So to fix it, check whether stop is already being done and bail out if so. Also move setting the STOPPING state into the lock so things are properly atomic. Reported-by: Nikolay Martynov <mar.kolya@gmail.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09cfg80211: fix regulatory NULL dereferenceJohannes Berg
commit de3584bd62d87b4c250129fbc46ca52c80330add upstream. By the time userspace returns with a response to the regulatory domain request, the wiphy causing the request might have gone away. If this is so, reject the update but mark the request as having been processed anyway. Cc: Luis R. Rodriguez <lrodriguez@qca.qualcomm.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09nl80211: fix MAC address validationEliad Peller
commit e007b857e88097c96c45620bf3b04a4e309053d1 upstream. MAC addresses have a fixed length. The current policy allows passing < ETH_ALEN bytes, which might result in reading beyond the buffer. Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09SUNRPC: Ensure we return EAGAIN in xs_nospace if congestion is clearedTrond Myklebust
commit 24ca9a847791fd53d9b217330b15f3c285827a18 upstream. By returning '0' instead of 'EAGAIN' when the tests in xs_nospace() fail to find evidence of socket congestion, we are making the RPC engine believe that the message was incorrectly sent and so it disconnects the socket instead of just retrying. The bug appears to have been introduced by commit 5e3771ce2d6a69e10fcc870cdf226d121d868491 (SUNRPC: Ensure that xs_nospace return values are propagated). Reported-by: Andrew Cooper <andrew.cooper3@citrix.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Tested-by: Andrew Cooper <andrew.cooper3@citrix.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-30tegra bluesleep: Bluetooth active power management driverAnantha Idapalapati
A new driver is implemented to actively manage the bluetooth module power. bluesleep also tries to manage the power of the transport used. Two signals (GPIOs) are used to manage the power events. BT_WAKE : signal from HOST to BT chip to intimate BT chip can sleep. HOST_WAKE: signal from BT chip to HOST to intimate HOST should wakeup/ activate the transport modules required for BT communication. Bug 791669, 773186 (cherry picked from commit 111f4ccd3c4cfde2fa52ae4c0c56a2288c3af3a8) Original-Change-Id: Iff1e81bb22d9bd43113f7cdd01329da3ae852a15 Reviewed-on: http://git-master/r/19858 Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com> Tested-by: Bharat Nihalani <bnihalani@nvidia.com> Rebase-Id: R1eca7f2f51475daf6104e71e90ad5db1213fa6ea
2011-11-30Bluetooth: Keep master role when SCO or eSCO is activehyungseoung.yoo
This improves compatbility with a lot of headset / chipset combinations. Ideally this should not be needed. Change-Id: I8b676701e12e416aa7d60801b9d353b15d102709 Signed-off-by: hyungseoung.yoo <hyungseoung.yoo@samsung.com> Signed-off-by: Jaikumar Ganesh <jaikumarg@android.com>
2011-11-30tcp: Don't nuke connections for the wrong protocolLorenzo Colitti
Currently, calling tcp_nuke_addr to reset IPv6 connections resets IPv4 connections as well, because all Android framework sockets are dual-stack (i.e., IPv6) sockets, and we don't check the source address to see if the connection was in fact an IPv4 connection. Fix this by checking the source address and not resetting the connection if it's a mapped address. Also slightly tweak the IPv4 code path, which doesn't check for mapped addresses either. This was not causing any problems because tcp_is_local normally always returns true for LOOPBACK4_IPV6 (127.0.0.6), because the loopback interface is configured as as 127.0.0.0/8. However, checking explicitly for LOOPBACK4_IPV6 makes the code a bit more robust. Bug: 5535055 Change-Id: I4d6ed3497c5b8643c864783cf681f088cf6b8d2a Signed-off-by: Lorenzo Colitti <lorenzo@google.com>
2011-11-30net: wireless: Skip connect warning for CONFIG_CFG80211_ALLOW_RECONNECTDmitry Shmidt
Signed-off-by: Dmitry Shmidt <dimitrysh@google.com>
2011-11-30net: wireless: Fix CFG80211_ALLOW_RECONNECT option for disconnectDmitry Shmidt
2011-11-30netfilter: xt_qtaguid: fix crash on ctrl delete commandJP Abgrall
Because for now the xt_qtaguid module allows procs to use tags without having /dev/xt_qtaguid open, there was a case where it would try to delete a resources from a list that was proc specific. But that resource was never added to that list which is only used when /dev/xt_qtaguid has been opened by the proc. Once our userspace is fully updated, we won't need those exceptions. Change-Id: Idd4bfea926627190c74645142916e10832eb2504 Signed-off-by: JP Abgrall <jpa@google.com>
2011-11-30bridge: Have tx_bytes count headers like rx_bytes.Ashish Sharma
Since rx_bytes accounting does not include Ethernet Headers in br_input.c, excluding ETH_HLEN on the transmit path for consistent measurement of packet length on both the Tx and Rx chains. The clean way would be for Rx to include the eth header, but the skb len has already been adjusted by the time the br code sees the skb. This is only a temporary workaround until we can completely ignore or cleanly fix the skb->len handling. Change-Id: I910de95a4686b2119da7f1f326e2154ef31f9972 Signed-off-by: Ashish Sharma <ashishsharma@google.com>
2011-11-30netfilter: xt_qtaguid: Fix the stats info display orderAshish Sharma
Change-Id: I3bf165c31f35a6c7dc212f23df5eefaeb8129d0d Signed-off-by: Ashish Sharma <ashishsharma@google.com>
2011-11-30netfilter: ipv6: fix crash caused by ipv6_find_hdr()JP Abgrall
When calling: ipv6_find_hdr(skb, &thoff, -1, NULL) on a fragmented packet, thoff would be left with a random value causing callers to read random memory offsets with: skb_header_pointer(skb, thoff, ...) Now we force ipv6_find_hdr() to return a failure in this case. Calling: ipv6_find_hdr(skb, &thoff, -1, &fragoff) will set fragoff as expected, and not return a failure. Change-Id: Ib474e8a4267dd2b300feca325811330329684a88 Signed-off-by: JP Abgrall <jpa@google.com>
2011-11-30netfilter: xt_qtaguid: add missing tracking for no filp caseJP Abgrall
In cases where the skb would have an sk_socket but no file, that skb would not be counted at all. Assigning to uid 0 now. Adding extra counters to track skb counts. Change-Id: If049b4b525e1fbd5afc9c72b4a174c0a435f2ca7 Signed-off-by: JP Abgrall <jpa@google.com>
2011-11-30netfilter: xt_qtaguid: fix crash after using delete ctrl commandJP Abgrall
* Crash fix The delete command would delete a socket tag entry without removing it from the proc_qtu_data { ..., sock_tag_list, }. This in turn would cause an exiting process to crash while cleaning up its matching proc_qtu_data. * Added more aggressive tracking/cleanup of proc_qtu_data This should allow one process to cleanup qtu_tag_data{} left around from processes that didn't use resource tracking via /dev/xt_qtaguid. * Debug printing tweaks Better code inclusion/exclusion handling, and extra debug out of full state. Change-Id: I735965af2962ffcd7f3021cdc0068b3ab21245c2 Signed-off-by: JP Abgrall <jpa@google.com>
2011-11-30netfilter: xt_qtaguid: change WARN_ONCE into pr_warn_onceJP Abgrall
Make the warning less scary. Change-Id: I0276c5413e37ec991f24db57aeb90333fb1b5a65 Signed-off-by: JP Abgrall <jpa@google.com>
2011-11-30netfilter: xt_qtaguid: provide an iface_stat_all proc entryJP Abgrall
There is a /proc/net/xt_qtaguid/iface/<iface>/{rx_bytes,rx_packets,tx_bytes,...} but for better convenience and to avoid getting overly stale net/dev stats we now have /proc/net/xt_qtaguid/iface_stat_all which outputs lines of: iface_name active rx_bytes rx_packets tx_bytes tx_packets net_dev_rx_bytes net_dev_rx_packets net_dev_tx_bytes net_dev_tx_packets Change-Id: I12cc10d2d123b86b56d4eb489b1d77b2ce72ebcf Signed-off-by: JP Abgrall <jpa@google.com>
2011-11-30netfilter: xt_qtaguid: work around devices that reset their statsJP Abgrall
Most net devs will not reset their stats when just going down/up, unless a NETDEV_UNREGISTER was notified. But some devs will not send out a NETDEV_UNREGISTER but still reset their stats just before a NETDEV_UP. Now we just track the dev stats during NETDEV_DOWN... just in case. Then on NETDEV_UP we check the stats: if the device didn't do a NETDEV_UNREGISTER and a prior NETDEV_DOWN captured stats, then we treat it as an UNREGISTER and save the totals from the stashed values. Added extra netdev event debugging. Change-Id: Iec79e74bfd40269aa3e5892f161be71e09de6946 Signed-off-by: JP Abgrall <jpa@google.com>
2011-11-30net: wireless: Add CFG80211_ALLOW_RECONNECT optionDmitry Shmidt
2011-11-30netfilter: xt_qtaguid: warn only once for missing proc qtaguid dataJP Abgrall
When a process doesn't have /dev/xt_qtaguid open, only warn once instead of for every ctrl access. Change-Id: I98a462a8731254ddc3bf6d2fefeef9823659b1f0 Signed-off-by: JP Abgrall <jpa@google.com>
2011-11-30netfilter: xt_qtaguid: 1st pass at tracking tag based data resourcesJP Abgrall
* Added global resource tracking based on tags. - Can be put into passive mode via /sys/modules/xt_qtaguid/params/tag_tracking_passive - The number of socket tags per UID is now limited - Adding /dev/xt_qtaguid that each process should open before starting to tag sockets. A later change will make it a "must". - A process should not create new tags unless it has the dev open. A later change will make it a must. - On qtaguid_resources release, the process' matching socket tag info is deleted. * Support run-time debug mask via /sys/modules parameter "debug_mask". * split module into prettyprinting code, includes, main. * Removed ptrdiff_t usage which didn't work in all cases. Change-Id: I4a21d3bea55d23c1c3747253904e2a79f7d555d9 Signed-off-by: JP Abgrall <jpa@google.com>
2011-11-30net: wireless: change the expire time about each entry of scan resultsjun.ho.lee
Change-Id: I6e8d838d91bebc28f4cd09dcb8b9f1de775be13d Signed-off-by: jun.ho.lee <jun.ho.lee@samsung.com> Signed-off-by: Dmitry Shmidt <dimitrysh@google.com>
2011-11-30netfilter: qtaguid: fix proc/.../stats uid filtered outputJP Abgrall
"cat /proc/net/xt_qtaguid/stats" for a non-priviledged UID would output multiple twice its own stats. The fix tweaks the way lines are counted. Non-root: idx iface acct_tag_hex uid_tag_int cnt_set ... 2 wlan0 0x0 10022 0 ... 3 wlan0 0x0 10022 1 ... 4 wlan0 0x3010000000000000 10022 0 ... 5 wlan0 0x3010000000000000 10022 1 ... Root: idx iface acct_tag_hex uid_tag_int cnt_set 2 wlan0 0x0 0 0 ... 3 wlan0 0x0 0 1 ... 4 wlan0 0x0 1000 0 ... ... 12 wlan0 0x0 10022 0 ... 13 wlan0 0x0 10022 1 ... ... 18 wlan0 0x3010000000000000 10022 0 ... 19 wlan0 0x3010000000000000 10022 1 ... Change-Id: I3cae1f4fee616bc897831350374656b0c718c45b Signed-off-by: JP Abgrall <jpa@google.com>
2011-11-30Bluetooth: Fix l2cap conn failures for ssp devicesPeter Hurley
Commit 330605423c fixed l2cap conn establishment for non-ssp remote devices by not setting HCI_CONN_ENCRYPT_PEND every time conn security is tested (which was always returning failure on any subsequent security checks). However, this broke l2cap conn establishment for ssp remote devices when an ACL link was already established at SDP-level security. This fix ensures that encryption must be pending whenever authentication is also pending. Change-Id: I6876ea5134e90d1f3d0f84e8ed40b92977b3df64 Signed-off-by: Peter Hurley <peter@xxxxxxxxxxxxxxxxxx>
2011-11-30netfilter: xt_qtaguid: fix dev_stats for missing NETDEV_UNREGISTERJP Abgrall
Turns out that some devices don't call the notifier chains with NETDEV_UNREGISTER. So now we only track up/down as the points for tracking active/inactive transitions and saving the get_dev_stats(). Change-Id: I948755962b4c64150b4d04f294fb4889f151e42b Signed-off-by: JP Abgrall <jpa@google.com>
2011-11-30netfilter: xt_qtaguid: add some tagging/matching statsJP Abgrall
/proc/net/xt_qtaguid/ctrl will now show: active tagged sockets: lines of "sock=%p tag=0x%llx (uid=%u)" sockets_tagged, : the number of sockets successfully tagged. sockets_untagged: the number of sockets successfully untagged. counter_set_changes: ctrl counter set change requests. delete_cmds: ctrl delete commands completed. iface_events: number of NETDEV_* events handled. match_found_sk: sk found in skbuff without ct assist. match_found_sk_in_ct: the number of times the connection tracker found a socket for us. This happens when the skbuff didn't have info. match_found_sk_none: the number of times no sk could be determined successfully looked up. This indicates we don't know who the data actually belongs to. This could be unsolicited traffic. Change-Id: I3a65613bb24852e1eea768ab0320a6a7073ab9be Signed-off-by: JP Abgrall <jpa@google.com>
2011-11-30netfilter: xt_qtaguid: Fix sockfd_put() call within spinlockJP Abgrall
sockfd_put() risks sleeping. So when doing a delete ctrl command, defer the sockfd_put() and kfree() to outside of the spinlock. Change-Id: I5f8ab51d05888d885b2fbb035f61efa5b7abb88a Signed-off-by: JP Abgrall <jpa@google.com>
2011-11-30netfilter: xt_qtaguid: Fix socket refcounts when taggingJP Abgrall
* Don't hold the sockets after tagging. sockfd_lookup() does a get() on the associated file. There was no matching put() so a closed socket could never be freed. * Don't rely on struct member order for tag_node The structs that had a struct tag_node member would work with the *_tree_* routines only because tag_node was 1st. * Improve debug messages Provide info on who the caller is. Use unsigned int for uid. * Only process NETDEV_UP events. * Pacifier: disable netfilter matching. Leave .../stats header. Change-Id: Iccb8ae3cca9608210c417597287a2391010dff2c Signed-off-by: JP Abgrall <jpa@google.com>
2011-11-30netfilter: xt_qtaguid: recognize IPV6 interfaces. root is procfs privileged.JP Abgrall
* Allow tracking interfaces that only have an ipv6 address. Deal with ipv6 notifier chains that do NETDEV_UP without the rtnl_lock() * Allow root all access to procfs ctrl/stats. To disable all checks: echo 0 > /sys/module/xt_qtaguid/parameters/ctrl_write_gid echo 0 > /sys/module/xt_qtaguid/parameters/stats_readall_gid * Add CDEBUG define to enable pr_debug output specific to procfs ctrl/stats access. Change-Id: I9a469511d92fe42734daff6ea2326701312a161b Signed-off-by: JP Abgrall <jpa@google.com>
2011-11-30netfilter: xt_qtaguid: add counter sets and matching controlJP Abgrall
* Added support for sets of counters. By default set 0 is active. Userspace can control which set is active for a given UID by writing to .../ctrl s <set_num> <uid> Changing the active set is only permitted for processes in the AID_NET_BW_ACCT group. The active set tracking is reset when the uid tag is deleted with the .../ctrl command d 0 <uid> * New output format for the proc .../stats - Now has cnt_set in the list. """ idx iface acct_tag_hex uid_tag_int cnt_set rx_bytes rx_packets tx_bytes tx_packets rx_tcp_packets rx_tcp_bytes rx_udp_packets rx_udp_bytes rx_other_packets rx_other_bytes tx_tcp_packets tx_tcp_bytes tx_udp_packets tx_udp_bytes tx_other_packets tx_other_bytes ... 2 rmnet0 0x0 1000 0 27729 29 1477 27 27501 26 228 3 0 0 1249 24 228 3 0 0 2 rmnet0 0x0 1000 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 3 rmnet0 0x0 10005 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 3 rmnet0 0x0 10005 1 46407 57 8008 64 46407 57 0 0 0 0 8008 64 0 0 0 0 ... 6 rmnet0 0x7fff000100000000 10005 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 6 rmnet0 0x7fff000100000000 10005 1 27493 24 1564 22 27493 24 0 0 0 0 1564 22 0 0 0 0 """ * Refactored for proc stats output code. * Silenced some of the per packet debug output. * Reworded some of the debug messages. * Replaced all the spin_lock_irqsave/irqrestore with *_bh(): netfilter handling is done in softirq. Change-Id: Ibe89f9d754579fd97335617186c614b43333cfd3 Signed-off-by: JP Abgrall <jpa@google.com>
