path: root/net
2017-06-17tipc: ignore requests when the connection state is not CONNECTEDParthasarathy Bhuvaragan
[ Upstream commit 4c887aa65d38633885010277f3482400681be719 ] In tipc_conn_sendmsg(), we first queue the request to the outqueue followed by the connection state check. If the connection is not connected, we should not queue this message. In this commit, we reject the messages if the connection state is not CF_CONNECTED. Acked-by: Ying Xue <ying.xue@windriver.com> Acked-by: Jon Maloy <jon.maloy@ericsson.com> Tested-by: John Thompson <thompa.atl@gmail.com> Signed-off-by: Parthasarathy Bhuvaragan <parthasarathy.bhuvaragan@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-17sctp: sctp_addr_id2transport should verify the addr before looking up assocXin Long
[ Upstream commit 6f29a130613191d3c6335169febe002cba00edf5 ] sctp_addr_id2transport is a function for sockopt to look up assoc by address. As the address is from userspace, it can be a v4-mapped v6 address. But in sctp protocol stack, it always handles a v4-mapped v6 address as a v4 address. So it's necessary to convert it to a v4 address before looking up assoc by address. This patch is to fix it by calling sctp_verify_addr in which it can do this conversion before calling sctp_endpoint_lookup_assoc, just like what sctp_sendmsg and __sctp_connect do for the address from users. Signed-off-by: Xin Long <lucien.xin@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-17ethtool: do not vzalloc(0) on registers dumpStanislaw Gruszka
[ Upstream commit 3808d34838184fd29088d6b3a364ba2f1c018fb6 ] If ->get_regs_len() callback return 0, we allocate 0 bytes of memory, what print ugly warning in dmesg, which can be found further below. This happen on mac80211 devices where ieee80211_get_regs_len() just return 0 and driver only fills ethtool_regs structure and actually do not provide any dump. However I assume this can happen on other drivers i.e. when for some devices driver provide regs dump and for others do not. Hence preventing to to print warning in ethtool code seems to be reasonable. ethtool: vmalloc: allocation failure: 0 bytes, mode:0x24080c2(GFP_KERNEL|__GFP_HIGHMEM|__GFP_ZERO) <snip> Call Trace: [<ffffffff813bde47>] dump_stack+0x63/0x8c [<ffffffff811b0a1f>] warn_alloc+0x13f/0x170 [<ffffffff811f0476>] __vmalloc_node_range+0x1e6/0x2c0 [<ffffffff811f0874>] vzalloc+0x54/0x60 [<ffffffff8169986c>] dev_ethtool+0xb4c/0x1b30 [<ffffffff816adbb1>] dev_ioctl+0x181/0x520 [<ffffffff816714d2>] sock_do_ioctl+0x42/0x50 <snip> Mem-Info: active_anon:435809 inactive_anon:173951 isolated_anon:0 active_file:835822 inactive_file:196932 isolated_file:0 unevictable:0 dirty:8 writeback:0 unstable:0 slab_reclaimable:157732 slab_unreclaimable:10022 mapped:83042 shmem:306356 pagetables:9507 bounce:0 free:130041 free_pcp:1080 free_cma:0 Node 0 active_anon:1743236kB inactive_anon:695804kB active_file:3343288kB inactive_file:787728kB unevictable:0kB isolated(anon):0kB isolated(file):0kB mapped:332168kB dirty:32kB writeback:0kB shmem:0kB shmem_thp: 0kB shmem_pmdmapped: 0kB anon_thp: 1225424kB writeback_tmp:0kB unstable:0kB pages_scanned:0 all_unreclaimable? no Node 0 DMA free:15900kB min:136kB low:168kB high:200kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB writepending:0kB present:15984kB managed:15900kB mlocked:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB lowmem_reserve[]: 0 3187 7643 7643 Node 0 DMA32 free:419732kB min:28124kB low:35152kB high:42180kB active_anon:541180kB inactive_anon:248988kB active_file:1466388kB inactive_file:389632kB unevictable:0kB writepending:0kB present:3370280kB managed:3290932kB mlocked:0kB slab_reclaimable:217184kB slab_unreclaimable:4180kB kernel_stack:160kB pagetables:984kB bounce:0kB free_pcp:2236kB local_pcp:660kB free_cma:0kB lowmem_reserve[]: 0 0 4456 4456 Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-17ipv6: Fix IPv6 packet loss in scenarios involving roaming + snooping switchesLinus Lüssing
[ Upstream commit a088d1d73a4bcfd7bc482f8d08375b9b665dc3e5 ] When for instance a mobile Linux device roams from one access point to another with both APs sharing the same broadcast domain and a multicast snooping switch in between: 1) (c) <~~~> (AP1) <--[SSW]--> (AP2) 2) (AP1) <--[SSW]--> (AP2) <~~~> (c) Then currently IPv6 multicast packets will get lost for (c) until an MLD Querier sends its next query message. The packet loss occurs because upon roaming the Linux host so far stayed silent regarding MLD and the snooping switch will therefore be unaware of the multicast topology change for a while. This patch fixes this by always resending MLD reports when an interface change happens, for instance from NO-CARRIER to CARRIER state. Signed-off-by: Linus Lüssing <linus.luessing@c0d3.blue> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-17NET: Fix /proc/net/arp for AX.25Ralf Baechle
[ Upstream commit 4872e57c812dd312bf8193b5933fa60585cda42f ] When sending ARP requests over AX.25 links the hwaddress in the neighbour cache are not getting initialized. For such an incomplete arp entry ax2asc2 will generate an empty string resulting in /proc/net/arp output like the following: $ cat /proc/net/arp IP address HW type Flags HW address Mask Device 192.168.122.1 0x1 0x2 52:54:00:00:5d:5f * ens3 172.20.1.99 0x3 0x0 * bpq0 The missing field will confuse the procfs parsing of arp(8) resulting in incorrect output for the device such as the following: $ arp Address HWtype HWaddress Flags Mask Iface gateway ether 52:54:00:00:5d:5f C ens3 172.20.1.99 (incomplete) ens3 This changes the content of /proc/net/arp to: $ cat /proc/net/arp IP address HW type Flags HW address Mask Device 172.20.1.99 0x3 0x0 * * bpq0 192.168.122.1 0x1 0x2 52:54:00:00:5d:5f * ens3 To do so it change ax2asc to put the string "*" in buf for a NULL address argument. Finally the HW address field is left aligned in a 17 character field (the length of an ethernet HW address in the usual hex notation) for readability. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-17ipv6: Inhibit IPv4-mapped src address on the wire.Jonathan T. Leighton
[ Upstream commit ec5e3b0a1d41fbda0cc33a45bc9e54e91d9d12c7 ] This patch adds a check for the problematic case of an IPv4-mapped IPv6 source address and a destination address that is neither an IPv4-mapped IPv6 address nor in6addr_any, and returns an appropriate error. The check in done before returning from looking up the route. Signed-off-by: Jonathan T. Leighton <jtleight@udel.edu> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-17ipv6: Handle IPv4-mapped src to in6addr_any dst.Jonathan T. Leighton
[ Upstream commit 052d2369d1b479cdbbe020fdd6d057d3c342db74 ] This patch adds a check on the type of the source address for the case where the destination address is in6addr_any. If the source is an IPv4-mapped IPv6 source address, the destination is changed to ::ffff:127.0.0.1, and otherwise the destination is changed to ::1. This is done in three locations to handle UDP calls to either connect() or sendmsg() and TCP calls to connect(). Note that udpv6_sendmsg() delays handling an in6addr_any destination until very late, so the patch only needs to handle the case where the source is an IPv4-mapped IPv6 address. Signed-off-by: Jonathan T. Leighton <jtleight@udel.edu> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14net: better skb->sender_cpu and skb->napi_id cohabitationEric Dumazet
commit 52bd2d62ce6758d811edcbd2256eb9ea7f6a56cb upstream. skb->sender_cpu and skb->napi_id share a common storage, and we had various bugs about this. We had to call skb_sender_cpu_clear() in some places to not leave a prior skb->napi_id and fool netdev_pick_tx() As suggested by Alexei, we could split the space so that these errors can not happen. 0 value being reserved as the common (not initialized) value, let's reserve [1 .. NR_CPUS] range for valid sender_cpu, and [NR_CPUS+1 .. ~0U] for valid napi_id. This will allow proper busy polling support over tunnels. Signed-off-by: Eric Dumazet <edumazet@google.com> Suggested-by: Alexei Starovoitov <ast@kernel.org> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Paul Menzel <pmenzel@molgen.mpg.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14net: bridge: start hello timer only if device is upNikolay Aleksandrov
[ Upstream commit aeb073241fe7a2b932e04e20c60e47718332877f ] When the transition of NO_STP -> KERNEL_STP was fixed by always calling mod_timer in br_stp_start, it introduced a new regression which causes the timer to be armed even when the bridge is down, and since we stop the timers in its ndo_stop() function, they never get disabled if the device is destroyed before it's upped. To reproduce: $ while :; do ip l add br0 type bridge hello_time 100; brctl stp br0 on; ip l del br0; done; CC: Xin Long <lucien.xin@gmail.com> CC: Ivan Vecera <cera@cera.cz> CC: Sebastian Ott <sebott@linux.vnet.ibm.com> Reported-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Fixes: 6d18c732b95c ("bridge: start hello_timer when enabling KERNEL_STP in br_stp_start") Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14net: ping: do not abuse udp_poll()Eric Dumazet
[ Upstream commit 77d4b1d36926a9b8387c6b53eeba42bcaaffcea3 ] Alexander reported various KASAN messages triggered in recent kernels The problem is that ping sockets should not use udp_poll() in the first place, and recent changes in UDP stack finally exposed this old bug. Fixes: c319b4d76b9e ("net: ipv4: add IPPROTO_ICMP socket kind") Fixes: 6d0bfe226116 ("net: ipv6: Add IPv6 support to the ping socket.") Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Sasha Levin <alexander.levin@verizon.com> Cc: Solar Designer <solar@openwall.com> Cc: Vasiliy Kulikov <segoon@openwall.com> Cc: Lorenzo Colitti <lorenzo@google.com> Acked-By: Lorenzo Colitti <lorenzo@google.com> Tested-By: Lorenzo Colitti <lorenzo@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14ipv6: Fix leak in ipv6_gso_segment().David S. Miller
[ Upstream commit e3e86b5119f81e5e2499bea7ea1ebe8ac6aab789 ] If ip6_find_1stfragopt() fails and we return an error we have to free up 'segs' because nobody else is going to. Fixes: 2423496af35d ("ipv6: Prevent overrun when parsing v6 header options") Reported-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14tcp: disallow cwnd undo when switching congestion controlYuchung Cheng
[ Upstream commit 44abafc4cc094214a99f860f778c48ecb23422fc ] When the sender switches its congestion control during loss recovery, if the recovery is spurious then it may incorrectly revert cwnd and ssthresh to the older values set by a previous congestion control. Consider a congestion control (like BBR) that does not use ssthresh and keeps it infinite: the connection may incorrectly revert cwnd to an infinite value when switching from BBR to another congestion control. This patch fixes it by disallowing such cwnd undo operation upon switching congestion control. Note that undo_marker is not reset s.t. the packets that were incorrectly marked lost would be corrected. We only avoid undoing the cwnd in tcp_undo_cwnd_reduction(). Signed-off-by: Yuchung Cheng <ycheng@google.com> Signed-off-by: Soheil Hassas Yeganeh <soheil@google.com> Signed-off-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14ipv6: xfrm: Handle errors reported by xfrm6_find_1stfragopt()Ben Hutchings
[ Upstream commit 6e80ac5cc992ab6256c3dae87f7e57db15e1a58c ] xfrm6_find_1stfragopt() may now return an error code and we must not treat it as a length. Fixes: 2423496af35d ("ipv6: Prevent overrun when parsing v6 header options") Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Acked-by: Craig Gallek <kraig@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-07netem: fix skb_orphan_partial()Eric Dumazet
commit f6ba8d33cfbb46df569972e64dbb5bb7e929bfd9 upstream. I should have known that lowering skb->truesize was dangerous :/ In case packets are not leaving the host via a standard Ethernet device, but looped back to local sockets, bad things can happen, as reported by Michael Madsen ( https://bugzilla.kernel.org/show_bug.cgi?id=195713 ) So instead of tweaking skb->truesize, lets change skb->destructor and keep a reference on the owner socket via its sk_refcnt. Fixes: f2f872f9272a ("netem: Introduce skb_orphan_partial() helper") Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Michael Madsen <mkm@nabto.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-07ipv4: add reference counting to metricsEric Dumazet
[ Upstream commit 3fb07daff8e99243366a081e5129560734de4ada ] Andrey Konovalov reported crashes in ipv4_mtu() I could reproduce the issue with KASAN kernels, between 10.246.7.151 and 10.246.7.152 : 1) 20 concurrent netperf -t TCP_RR -H 10.246.7.152 -l 1000 & 2) At the same time run following loop : while : do ip ro add 10.246.7.152 dev eth0 src 10.246.7.151 mtu 1500 ip ro del 10.246.7.152 dev eth0 src 10.246.7.151 mtu 1500 done Cong Wang attempted to add back rt->fi in commit 82486aa6f1b9 ("ipv4: restore rt->fi for reference counting") but this proved to add some issues that were complex to solve. Instead, I suggested to add a refcount to the metrics themselves, being a standalone object (in particular, no reference to other objects) I tried to make this patch as small as possible to ease its backport, instead of being super clean. Note that we believe that only ipv4 dst need to take care of the metric refcount. But if this is wrong, this patch adds the basic infrastructure to extend this to other families. Many thanks to Julian Anastasov for reviewing this patch, and Cong Wang for his efforts on this problem. Fixes: 2860583fe840 ("ipv4: Kill rt->fi") Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Andrey Konovalov <andreyknvl@google.com> Reviewed-by: Julian Anastasov <ja@ssi.bg> Acked-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-07sctp: fix ICMP processing if skb is non-linearDavide Caratti
[ Upstream commit 804ec7ebe8ea003999ca8d1bfc499edc6a9e07df ] sometimes ICMP replies to INIT chunks are ignored by the client, even if the encapsulated SCTP headers match an open socket. This happens when the ICMP packet is carried by a paged skb: use skb_header_pointer() to read packet contents beyond the SCTP header, so that chunk header and initiate tag are validated correctly. v2: - don't use skb_header_pointer() to read the transport header, since icmp_socket_deliver() already puts these 8 bytes in the linear area. - change commit message to make specific reference to INIT chunks. Signed-off-by: Davide Caratti <dcaratti@redhat.com> Acked-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Reviewed-by: Xin Long <lucien.xin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-07tcp: avoid fastopen API to be used on AF_UNSPECWei Wang
[ Upstream commit ba615f675281d76fd19aa03558777f81fb6b6084 ] Fastopen API should be used to perform fastopen operations on the TCP socket. It does not make sense to use fastopen API to perform disconnect by calling it with AF_UNSPEC. The fastopen data path is also prone to race conditions and bugs when using with AF_UNSPEC. One issue reported and analyzed by Vegard Nossum is as follows: +++++++++++++++++++++++++++++++++++++++++++++++++++++++++ Thread A: Thread B: ------------------------------------------------------------------------ sendto() - tcp_sendmsg() - sk_stream_memory_free() = 0 - goto wait_for_sndbuf - sk_stream_wait_memory() - sk_wait_event() // sleep | sendto(flags=MSG_FASTOPEN, dest_addr=AF_UNSPEC) | - tcp_sendmsg() | - tcp_sendmsg_fastopen() | - __inet_stream_connect() | - tcp_disconnect() //because of AF_UNSPEC | - tcp_transmit_skb()// send RST | - return 0; // no reconnect! | - sk_stream_wait_connect() | - sock_error() | - xchg(&sk->sk_err, 0) | - return -ECONNRESET - ... // wake up, see sk->sk_err == 0 - skb_entail() on TCP_CLOSE socket If the connection is reopened then we will send a brand new SYN packet after thread A has already queued a buffer. At this point I think the socket internal state (sequence numbers etc.) becomes messed up. When the new connection is closed, the FIN-ACK is rejected because the sequence number is outside the window. The other side tries to retransmit, but __tcp_retransmit_skb() calls tcp_trim_head() on an empty skb which corrupts the skb data length and hits a BUG() in copy_and_csum_bits(). +++++++++++++++++++++++++++++++++++++++++++++++++++++++++ Hence, this patch adds a check for AF_UNSPEC in the fastopen data path and return EOPNOTSUPP to user if such case happens. Fixes: cf60af03ca4e7 ("tcp: Fast Open client - sendmsg(MSG_FASTOPEN)") Reported-by: Vegard Nossum <vegard.nossum@oracle.com> Signed-off-by: Wei Wang <weiwan@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-07ipv6: fix out of bound writes in __ip6_append_data()Eric Dumazet
[ Upstream commit 232cd35d0804cc241eb887bb8d4d9b3b9881c64a ] Andrey Konovalov and idaifish@gmail.com reported crashes caused by one skb shared_info being overwritten from __ip6_append_data() Andrey program lead to following state : copy -4200 datalen 2000 fraglen 2040 maxfraglen 2040 alloclen 2048 transhdrlen 0 offset 0 fraggap 6200 The skb_copy_and_csum_bits(skb_prev, maxfraglen, data + transhdrlen, fraggap, 0); is overwriting skb->head and skb_shared_info Since we apparently detect this rare condition too late, move the code earlier to even avoid allocating skb and risking crashes. Once again, many thanks to Andrey and syzkaller team. Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Andrey Konovalov <andreyknvl@google.com> Tested-by: Andrey Konovalov <andreyknvl@google.com> Reported-by: <idaifish@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-07bridge: start hello_timer when enabling KERNEL_STP in br_stp_startXin Long
[ Upstream commit 6d18c732b95c0a9d35e9f978b4438bba15412284 ] Since commit 76b91c32dd86 ("bridge: stp: when using userspace stp stop kernel hello and hold timers"), bridge would not start hello_timer if stp_enabled is not KERNEL_STP when br_dev_open. The problem is even if users set stp_enabled with KERNEL_STP later, the timer will still not be started. It causes that KERNEL_STP can not really work. Users have to re-ifup the bridge to avoid this. This patch is to fix it by starting br->hello_timer when enabling KERNEL_STP in br_stp_start. As an improvement, it's also to start hello_timer again only when br->stp_enabled is KERNEL_STP in br_hello_timer_expired, there is no reason to start the timer again when it's NO_STP. Fixes: 76b91c32dd86 ("bridge: stp: when using userspace stp stop kernel hello and hold timers") Reported-by: Haidong Li <haili@redhat.com> Signed-off-by: Xin Long <lucien.xin@gmail.com> Acked-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com> Reviewed-by: Ivan Vecera <cera@cera.cz> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-07bridge: netlink: check vlan_default_pvid rangeTobias Jungel
[ Upstream commit a285860211bf257b0e6d522dac6006794be348af ] Currently it is allowed to set the default pvid of a bridge to a value above VLAN_VID_MASK (0xfff). This patch adds a check to br_validate and returns -EINVAL in case the pvid is out of bounds. Reproduce by calling: [root@test ~]# ip l a type bridge [root@test ~]# ip l a type dummy [root@test ~]# ip l s bridge0 type bridge vlan_filtering 1 [root@test ~]# ip l s bridge0 type bridge vlan_default_pvid 9999 [root@test ~]# ip l s dummy0 master bridge0 [root@test ~]# bridge vlan port vlan ids bridge0 9999 PVID Egress Untagged dummy0 9999 PVID Egress Untagged Fixes: 0f963b7592ef ("bridge: netlink: add support for default_pvid") Acked-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com> Signed-off-by: Tobias Jungel <tobias.jungel@bisdn.de> Acked-by: Sabrina Dubroca <sd@queasysnail.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-07ipv6: Check ip6_find_1stfragopt() return value properly.David S. Miller
[ Upstream commit 7dd7eb9513bd02184d45f000ab69d78cb1fa1531 ] Do not use unsigned variables to see if it returns a negative error or not. Fixes: 2423496af35d ("ipv6: Prevent overrun when parsing v6 header options") Reported-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-07ipv6: Prevent overrun when parsing v6 header optionsCraig Gallek
[ Upstream commit 2423496af35d94a87156b063ea5cedffc10a70a1 ] The KASAN warning repoted below was discovered with a syzkaller program. The reproducer is basically: int s = socket(AF_INET6, SOCK_RAW, NEXTHDR_HOP); send(s, &one_byte_of_data, 1, MSG_MORE); send(s, &more_than_mtu_bytes_data, 2000, 0); The socket() call sets the nexthdr field of the v6 header to NEXTHDR_HOP, the first send call primes the payload with a non zero byte of data, and the second send call triggers the fragmentation path. The fragmentation code tries to parse the header options in order to figure out where to insert the fragment option. Since nexthdr points to an invalid option, the calculation of the size of the network header can made to be much larger than the linear section of the skb and data is read outside of it. This fix makes ip6_find_1stfrag return an error if it detects running out-of-bounds. [ 42.361487] ================================================================== [ 42.364412] BUG: KASAN: slab-out-of-bounds in ip6_fragment+0x11c8/0x3730 [ 42.365471] Read of size 840 at addr ffff88000969e798 by task ip6_fragment-oo/3789 [ 42.366469] [ 42.366696] CPU: 1 PID: 3789 Comm: ip6_fragment-oo Not tainted 4.11.0+ #41 [ 42.367628] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.1-1ubuntu1 04/01/2014 [ 42.368824] Call Trace: [ 42.369183] dump_stack+0xb3/0x10b [ 42.369664] print_address_description+0x73/0x290 [ 42.370325] kasan_report+0x252/0x370 [ 42.370839] ? ip6_fragment+0x11c8/0x3730 [ 42.371396] check_memory_region+0x13c/0x1a0 [ 42.371978] memcpy+0x23/0x50 [ 42.372395] ip6_fragment+0x11c8/0x3730 [ 42.372920] ? nf_ct_expect_unregister_notifier+0x110/0x110 [ 42.373681] ? ip6_copy_metadata+0x7f0/0x7f0 [ 42.374263] ? ip6_forward+0x2e30/0x2e30 [ 42.374803] ip6_finish_output+0x584/0x990 [ 42.375350] ip6_output+0x1b7/0x690 [ 42.375836] ? ip6_finish_output+0x990/0x990 [ 42.376411] ? ip6_fragment+0x3730/0x3730 [ 42.376968] ip6_local_out+0x95/0x160 [ 42.377471] ip6_send_skb+0xa1/0x330 [ 42.377969] ip6_push_pending_frames+0xb3/0xe0 [ 42.378589] rawv6_sendmsg+0x2051/0x2db0 [ 42.379129] ? rawv6_bind+0x8b0/0x8b0 [ 42.379633] ? _copy_from_user+0x84/0xe0 [ 42.380193] ? debug_check_no_locks_freed+0x290/0x290 [ 42.380878] ? ___sys_sendmsg+0x162/0x930 [ 42.381427] ? rcu_read_lock_sched_held+0xa3/0x120 [ 42.382074] ? sock_has_perm+0x1f6/0x290 [ 42.382614] ? ___sys_sendmsg+0x167/0x930 [ 42.383173] ? lock_downgrade+0x660/0x660 [ 42.383727] inet_sendmsg+0x123/0x500 [ 42.384226] ? inet_sendmsg+0x123/0x500 [ 42.384748] ? inet_recvmsg+0x540/0x540 [ 42.385263] sock_sendmsg+0xca/0x110 [ 42.385758] SYSC_sendto+0x217/0x380 [ 42.386249] ? SYSC_connect+0x310/0x310 [ 42.386783] ? __might_fault+0x110/0x1d0 [ 42.387324] ? lock_downgrade+0x660/0x660 [ 42.387880] ? __fget_light+0xa1/0x1f0 [ 42.388403] ? __fdget+0x18/0x20 [ 42.388851] ? sock_common_setsockopt+0x95/0xd0 [ 42.389472] ? SyS_setsockopt+0x17f/0x260 [ 42.390021] ? entry_SYSCALL_64_fastpath+0x5/0xbe [ 42.390650] SyS_sendto+0x40/0x50 [ 42.391103] entry_SYSCALL_64_fastpath+0x1f/0xbe [ 42.391731] RIP: 0033:0x7fbbb711e383 [ 42.392217] RSP: 002b:00007ffff4d34f28 EFLAGS: 00000246 ORIG_RAX: 000000000000002c [ 42.393235] RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007fbbb711e383 [ 42.394195] RDX: 0000000000001000 RSI: 00007ffff4d34f60 RDI: 0000000000000003 [ 42.395145] RBP: 0000000000000046 R08: 00007ffff4d34f40 R09: 0000000000000018 [ 42.396056] R10: 0000000000000000 R11: 0000000000000246 R12: 0000000000400aad [ 42.396598] R13: 0000000000000066 R14: 00007ffff4d34ee0 R15: 00007fbbb717af00 [ 42.397257] [ 42.397411] Allocated by task 3789: [ 42.397702] save_stack_trace+0x16/0x20 [ 42.398005] save_stack+0x46/0xd0 [ 42.398267] kasan_kmalloc+0xad/0xe0 [ 42.398548] kasan_slab_alloc+0x12/0x20 [ 42.398848] __kmalloc_node_track_caller+0xcb/0x380 [ 42.399224] __kmalloc_reserve.isra.32+0x41/0xe0 [ 42.399654] __alloc_skb+0xf8/0x580 [ 42.400003] sock_wmalloc+0xab/0xf0 [ 42.400346] __ip6_append_data.isra.41+0x2472/0x33d0 [ 42.400813] ip6_append_data+0x1a8/0x2f0 [ 42.401122] rawv6_sendmsg+0x11ee/0x2db0 [ 42.401505] inet_sendmsg+0x123/0x500 [ 42.401860] sock_sendmsg+0xca/0x110 [ 42.402209] ___sys_sendmsg+0x7cb/0x930 [ 42.402582] __sys_sendmsg+0xd9/0x190 [ 42.402941] SyS_sendmsg+0x2d/0x50 [ 42.403273] entry_SYSCALL_64_fastpath+0x1f/0xbe [ 42.403718] [ 42.403871] Freed by task 1794: [ 42.404146] save_stack_trace+0x16/0x20 [ 42.404515] save_stack+0x46/0xd0 [ 42.404827] kasan_slab_free+0x72/0xc0 [ 42.405167] kfree+0xe8/0x2b0 [ 42.405462] skb_free_head+0x74/0xb0 [ 42.405806] skb_release_data+0x30e/0x3a0 [ 42.406198] skb_release_all+0x4a/0x60 [ 42.406563] consume_skb+0x113/0x2e0 [ 42.406910] skb_free_datagram+0x1a/0xe0 [ 42.407288] netlink_recvmsg+0x60d/0xe40 [ 42.407667] sock_recvmsg+0xd7/0x110 [ 42.408022] ___sys_recvmsg+0x25c/0x580 [ 42.408395] __sys_recvmsg+0xd6/0x190 [ 42.408753] SyS_recvmsg+0x2d/0x50 [ 42.409086] entry_SYSCALL_64_fastpath+0x1f/0xbe [ 42.409513] [ 42.409665] The buggy address belongs to the object at ffff88000969e780 [ 42.409665] which belongs to the cache kmalloc-512 of size 512 [ 42.410846] The buggy address is located 24 bytes inside of [ 42.410846] 512-byte region [ffff88000969e780, ffff88000969e980) [ 42.411941] The buggy address belongs to the page: [ 42.412405] page:ffffea000025a780 count:1 mapcount:0 mapping: (null) index:0x0 compound_mapcount: 0 [ 42.413298] flags: 0x100000000008100(slab|head) [ 42.413729] raw: 0100000000008100 0000000000000000 0000000000000000 00000001800c000c [ 42.414387] raw: ffffea00002a9500 0000000900000007 ffff88000c401280 0000000000000000 [ 42.415074] page dumped because: kasan: bad access detected [ 42.415604] [ 42.415757] Memory state around the buggy address: [ 42.416222] ffff88000969e880: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [ 42.416904] ffff88000969e900: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [ 42.417591] >ffff88000969e980: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc [ 42.418273] ^ [ 42.418588] ffff88000969ea00: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb [ 42.419273] ffff88000969ea80: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb [ 42.419882] ================================================================== Reported-by: Andrey Konovalov <andreyknvl@google.com> Signed-off-by: Craig Gallek <kraig@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-07net: Improve handling of failures on link and route dumpsDavid Ahern
[ Upstream commit f6c5775ff0bfa62b072face6bf1d40f659f194b2 ] In general, rtnetlink dumps do not anticipate failure to dump a single object (e.g., link or route) on a single pass. As both route and link objects have grown via more attributes, that is no longer a given. netlink dumps can handle a failure if the dump function returns an error; specifically, netlink_dump adds the return code to the response if it is <= 0 so userspace is notified of the failure. The missing piece is the rtnetlink dump functions returning the error. Fix route and link dump functions to return the errors if no object is added to an skb (detected by skb->len != 0). IPv6 route dumps (rt6_dump_route) already return the error; this patch updates IPv4 and link dumps. Other dump functions may need to be ajusted as well. Reported-by: Jan Moskyto Matejka <mq@ucw.cz> Signed-off-by: David Ahern <dsahern@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-07tcp: eliminate negative reordering in tcp_clean_rtx_queueSoheil Hassas Yeganeh
[ Upstream commit bafbb9c73241760023d8981191ddd30bb1c6dbac ] tcp_ack() can call tcp_fragment() which may dededuct the value tp->fackets_out when MSS changes. When prior_fackets is larger than tp->fackets_out, tcp_clean_rtx_queue() can invoke tcp_update_reordering() with negative values. This results in absurd tp->reodering values higher than sysctl_tcp_max_reordering. Note that tcp_update_reordering indeeds sets tp->reordering to min(sysctl_tcp_max_reordering, metric), but because the comparison is signed, a negative metric always wins. Fixes: c7caf8d3ed7a ("[TCP]: Fix reord detection due to snd_una covered holes") Reported-by: Rebecca Isaacs <risaacs@google.com> Signed-off-by: Soheil Hassas Yeganeh <soheil@google.com> Signed-off-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: Yuchung Cheng <ycheng@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-07sctp: do not inherit ipv6_{mc|ac|fl}_list from parentEric Dumazet
[ Upstream commit fdcee2cbb8438702ea1b328fb6e0ac5e9a40c7f8 ] SCTP needs fixes similar to 83eaddab4378 ("ipv6/dccp: do not inherit ipv6_mc_list from parent"), otherwise bad things can happen. Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Andrey Konovalov <andreyknvl@google.com> Tested-by: Andrey Konovalov <andreyknvl@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-07sctp: fix src address selection if using secondary addresses for ipv6Xin Long
[ Upstream commit dbc2b5e9a09e9a6664679a667ff81cff6e5f2641 ] Commit 0ca50d12fe46 ("sctp: fix src address selection if using secondary addresses") has fixed a src address selection issue when using secondary addresses for ipv4. Now sctp ipv6 also has the similar issue. When using a secondary address, sctp_v6_get_dst tries to choose the saddr which has the most same bits with the daddr by sctp_v6_addr_match_len. It may make some cases not work as expected. hostA: [1] fd21:356b:459a:cf10::11 (eth1) [2] fd21:356b:459a:cf20::11 (eth2) hostB: [a] fd21:356b:459a:cf30::2 (eth1) [b] fd21:356b:459a:cf40::2 (eth2) route from hostA to hostB: fd21:356b:459a:cf30::/64 dev eth1 metric 1024 mtu 1500 The expected path should be: fd21:356b:459a:cf10::11 <-> fd21:356b:459a:cf30::2 But addr[2] matches addr[a] more bits than addr[1] does, according to sctp_v6_addr_match_len. It causes the path to be: fd21:356b:459a:cf20::11 <-> fd21:356b:459a:cf30::2 This patch is to fix it with the same way as Marcelo's fix for sctp ipv4. As no ip_dev_find for ipv6, this patch is to use ipv6_chk_addr to check if the saddr is in a dev instead. Note that for backwards compatibility, it will still do the addr_match_len check here when no optimal is found. Reported-by: Patrick Talbert <ptalbert@redhat.com> Signed-off-by: Xin Long <lucien.xin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-07tcp: avoid fragmenting peculiar skbs in SACKYuchung Cheng
[ Upstream commit b451e5d24ba6687c6f0e7319c727a709a1846c06 ] This patch fixes a bug in splitting an SKB during SACK processing. Specifically if an skb contains multiple packets and is only partially sacked in the higher sequences, tcp_match_sack_to_skb() splits the skb and marks the second fragment as SACKed. The current code further attempts rounding up the first fragment to MSS boundaries. But it misses a boundary condition when the rounded-up fragment size (pkt_len) is exactly skb size. Spliting such an skb is pointless and causses a kernel warning and aborts the SACK processing. This patch universally checks such over-split before calling tcp_fragment to prevent these unnecessary warnings. Fixes: adb92db857ee ("tcp: Make SACK code to split only at mss boundaries") Signed-off-by: Yuchung Cheng <ycheng@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: Soheil Hassas Yeganeh <soheil@google.com> Acked-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-07ipv6/dccp: do not inherit ipv6_mc_list from parentWANG Cong
[ Upstream commit 83eaddab4378db256d00d295bda6ca997cd13a52 ] Like commit 657831ffc38e ("dccp/tcp: do not inherit mc_list from parent") we should clear ipv6_mc_list etc. for IPv6 sockets too. Cc: Eric Dumazet <edumazet@google.com> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-07dccp/tcp: do not inherit mc_list from parentEric Dumazet
[ Upstream commit 657831ffc38e30092a2d5f03d385d710eb88b09a ] syzkaller found a way to trigger double frees from ip_mc_drop_socket() It turns out that leave a copy of parent mc_list at accept() time, which is very bad. Very similar to commit 8b485ce69876 ("tcp: do not inherit fastopen_req from parent") Initial report from Pray3r, completed by Andrey one. Thanks a lot to them ! Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Pray3r <pray3r.z@gmail.com> Reported-by: Andrey Konovalov <andreyknvl@google.com> Tested-by: Andrey Konovalov <andreyknvl@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-25ipx: call ipxitf_put() in ioctl error pathDan Carpenter
commit ee0d8d8482345ff97a75a7d747efc309f13b0d80 upstream. We should call ipxitf_put() if the copy_to_user() fails. Reported-by: 李强 <liqiang6-s@360.cn> Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-20mac80211: RX BA support for sta max_rx_aggregation_subframesMaxim Altshul
commit 480dd46b9d6812e5fb7172c305ee0f1154c26eed upstream. The ability to change the max_rx_aggregation frames is useful in cases of IOP. There exist some devices (latest mobile phones and some AP's) that tend to not respect a BA sessions maximum size (in Kbps). These devices won't respect the AMPDU size that was negotiated during association (even though they do respect the maximal number of packets). This violation is characterized by a valid number of packets in a single AMPDU. Even so, the total size will exceed the size negotiated during association. Eventually, this will cause some undefined behavior, which in turn causes the hw to drop packets, causing the throughput to plummet. This patch will make the subframe limitation to be held by each station, instead of being held only by hw. Signed-off-by: Maxim Altshul <maxim.altshul@ti.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Amit Pundir <amit.pundir@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-20mac80211: pass block ack session timeout to to driverSara Sharon
commit 50ea05efaf3bed7dd34bcc2635a8b3f53bd0ccc1 upstream. Currently mac80211 does not inform the driver of the session block ack timeout when starting a rx aggregation session. Drivers that manage the reorder buffer need to know this parameter. Seeing that there are now too many arguments for the drv_ampdu_action() function, wrap them inside a structure. Signed-off-by: Sara Sharon <sara.sharon@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Amit Pundir <amit.pundir@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-20mac80211: pass RX aggregation window size to driverSara Sharon
commit fad471860c097844432c7cf5d3ae6a0a059c2bdc upstream. Currently mac80211 does not inform the driver of the window size when starting an RX aggregation session. To enable managing the reorder buffer in the driver or hardware the window size is needed. Signed-off-by: Sara Sharon <sara.sharon@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Amit Pundir <amit.pundir@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-20Bluetooth: Fix user channel for 32bit userspace on 64bit kernelSzymon Janc
commit ab89f0bdd63a3721f7cd3f064f39fc4ac7ca14d4 upstream. Running 32bit userspace on 64bit kernel results in MSG_CMSG_COMPAT being defined as 0x80000000. This results in sendmsg failure if used from 32bit userspace running on 64bit kernel. Fix this by accounting for MSG_CMSG_COMPAT in flags check in hci_sock_sendmsg. Signed-off-by: Szymon Janc <szymon.janc@codecoup.pl> Signed-off-by: Marko Kiiskila <marko@runtime.io> Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-14ipv6: reorder ip6_route_dev_notifier after ipv6_dev_notfWANG Cong
[ Upstream commit 242d3a49a2a1a71d8eb9f953db1bcaa9d698ce00 ] For each netns (except init_net), we initialize its null entry in 3 places: 1) The template itself, as we use kmemdup() 2) Code around dst_init_metrics() in ip6_route_net_init() 3) ip6_route_dev_notify(), which is supposed to initialize it after loopback registers Unfortunately the last one still happens in a wrong order because we expect to initialize net->ipv6.ip6_null_entry->rt6i_idev to net->loopback_dev's idev, thus we have to do that after we add idev to loopback. However, this notifier has priority == 0 same as ipv6_dev_notf, and ipv6_dev_notf is registered after ip6_route_dev_notifier so it is called actually after ip6_route_dev_notifier. This is similar to commit 2f460933f58e ("ipv6: initialize route null entry in addrconf_init()") which fixes init_net. Fix it by picking a smaller priority for ip6_route_dev_notifier. Also, we have to release the refcnt accordingly when unregistering loopback_dev because device exit functions are called before subsys exit functions. Acked-by: David Ahern <dsahern@gmail.com> Tested-by: David Ahern <dsahern@gmail.com> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-14ipv6: initialize route null entry in addrconf_init()WANG Cong
[ Upstream commit 2f460933f58eee3393aba64f0f6d14acb08d1724 ] Andrey reported a crash on init_net.ipv6.ip6_null_entry->rt6i_idev since it is always NULL. This is clearly wrong, we have code to initialize it to loopback_dev, unfortunately the order is still not correct. loopback_dev is registered very early during boot, we lose a chance to re-initialize it in notifier. addrconf_init() is called after ip6_route_init(), which means we have no chance to correct it. Fix it by moving this initialization explicitly after ipv6_add_dev(init_net.loopback_dev) in addrconf_init(). Reported-by: Andrey Konovalov <andreyknvl@google.com> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Tested-by: Andrey Konovalov <andreyknvl@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-14rtnetlink: NUL-terminate IFLA_PHYS_PORT_NAME stringMichal Schmidt
[ Upstream commit 77ef033b687c3e030017c94a29bf6ea3aaaef678 ] IFLA_PHYS_PORT_NAME is a string attribute, so terminate it with \0. Otherwise libnl3 fails to validate netlink messages with this attribute. "ip -detail a" assumes too that the attribute is NUL-terminated when printing it. It often was, due to padding. I noticed this as libvirtd failing to start on a system with sfc driver after upgrading it to Linux 4.11, i.e. when sfc added support for phys_port_name. Signed-off-by: Michal Schmidt <mschmidt@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-14ipv4, ipv6: ensure raw socket message is big enough to hold an IP headerAlexander Potapenko
[ Upstream commit 86f4c90a1c5c1493f07f2d12c1079f5bf01936f2 ] raw_send_hdrinc() and rawv6_send_hdrinc() expect that the buffer copied from the userspace contains the IPv4/IPv6 header, so if too few bytes are copied, parts of the header may remain uninitialized. This bug has been detected with KMSAN. For the record, the KMSAN report: ================================================================== BUG: KMSAN: use of unitialized memory in nf_ct_frag6_gather+0xf5a/0x44a0 inter: 0 CPU: 0 PID: 1036 Comm: probe Not tainted 4.11.0-rc5+ #2455 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011 Call Trace: __dump_stack lib/dump_stack.c:16 dump_stack+0x143/0x1b0 lib/dump_stack.c:52 kmsan_report+0x16b/0x1e0 mm/kmsan/kmsan.c:1078 __kmsan_warning_32+0x5c/0xa0 mm/kmsan/kmsan_instr.c:510 nf_ct_frag6_gather+0xf5a/0x44a0 net/ipv6/netfilter/nf_conntrack_reasm.c:577 ipv6_defrag+0x1d9/0x280 net/ipv6/netfilter/nf_defrag_ipv6_hooks.c:68 nf_hook_entry_hookfn ./include/linux/netfilter.h:102 nf_hook_slow+0x13f/0x3c0 net/netfilter/core.c:310 nf_hook ./include/linux/netfilter.h:212 NF_HOOK ./include/linux/netfilter.h:255 rawv6_send_hdrinc net/ipv6/raw.c:673 rawv6_sendmsg+0x2fcb/0x41a0 net/ipv6/raw.c:919 inet_sendmsg+0x3f8/0x6d0 net/ipv4/af_inet.c:762 sock_sendmsg_nosec net/socket.c:633 sock_sendmsg net/socket.c:643 SYSC_sendto+0x6a5/0x7c0 net/socket.c:1696 SyS_sendto+0xbc/0xe0 net/socket.c:1664 do_syscall_64+0x72/0xa0 arch/x86/entry/common.c:285 entry_SYSCALL64_slow_path+0x25/0x25 arch/x86/entry/entry_64.S:246 RIP: 0033:0x436e03 RSP: 002b:00007ffce48baf38 EFLAGS: 00000246 ORIG_RAX: 000000000000002c RAX: ffffffffffffffda RBX: 00000000004002b0 RCX: 0000000000436e03 RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000000000003 RBP: 00007ffce48baf90 R08: 00007ffce48baf50 R09: 000000000000001c R10: 0000000000000000 R11: 0000000000000246 R12: 0000000000000000 R13: 0000000000401790 R14: 0000000000401820 R15: 0000000000000000 origin: 00000000d9400053 save_stack_trace+0x16/0x20 arch/x86/kernel/stacktrace.c:59 kmsan_save_stack_with_flags mm/kmsan/kmsan.c:362 kmsan_internal_poison_shadow+0xb1/0x1a0 mm/kmsan/kmsan.c:257 kmsan_poison_shadow+0x6d/0xc0 mm/kmsan/kmsan.c:270 slab_alloc_node mm/slub.c:2735 __kmalloc_node_track_caller+0x1f4/0x390 mm/slub.c:4341 __kmalloc_reserve net/core/skbuff.c:138 __alloc_skb+0x2cd/0x740 net/core/skbuff.c:231 alloc_skb ./include/linux/skbuff.h:933 alloc_skb_with_frags+0x209/0xbc0 net/core/skbuff.c:4678 sock_alloc_send_pskb+0x9ff/0xe00 net/core/sock.c:1903 sock_alloc_send_skb+0xe4/0x100 net/core/sock.c:1920 rawv6_send_hdrinc net/ipv6/raw.c:638 rawv6_sendmsg+0x2918/0x41a0 net/ipv6/raw.c:919 inet_sendmsg+0x3f8/0x6d0 net/ipv4/af_inet.c:762 sock_sendmsg_nosec net/socket.c:633 sock_sendmsg net/socket.c:643 SYSC_sendto+0x6a5/0x7c0 net/socket.c:1696 SyS_sendto+0xbc/0xe0 net/socket.c:1664 do_syscall_64+0x72/0xa0 arch/x86/entry/common.c:285 return_from_SYSCALL_64+0x0/0x6a arch/x86/entry/entry_64.S:246 ================================================================== , triggered by the following syscalls: socket(PF_INET6, SOCK_RAW, IPPROTO_RAW) = 3 sendto(3, NULL, 0, 0, {sa_family=AF_INET6, sin6_port=htons(0), inet_pton(AF_INET6, "ff00::", &sin6_addr), sin6_flowinfo=0, sin6_scope_id=0}, 28) = -1 EPERM A similar report is triggered in net/ipv4/raw.c if we use a PF_INET socket instead of a PF_INET6 one. Signed-off-by: Alexander Potapenko <glider@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-14tcp: do not inherit fastopen_req from parentEric Dumazet
[ Upstream commit 8b485ce69876c65db12ed390e7f9c0d2a64eff2c ] Under fuzzer stress, it is possible that a child gets a non NULL fastopen_req pointer from its parent at accept() time, when/if parent morphs from listener to active session. We need to make sure this can not happen, by clearing the field after socket cloning. BUG: Double free or freeing an invalid pointer Unexpected shadow byte: 0xFB CPU: 3 PID: 20933 Comm: syz-executor3 Not tainted 4.11.0+ #306 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011 Call Trace: <IRQ> __dump_stack lib/dump_stack.c:16 [inline] dump_stack+0x292/0x395 lib/dump_stack.c:52 kasan_object_err+0x1c/0x70 mm/kasan/report.c:164 kasan_report_double_free+0x5c/0x70 mm/kasan/report.c:185 kasan_slab_free+0x9d/0xc0 mm/kasan/kasan.c:580 slab_free_hook mm/slub.c:1357 [inline] slab_free_freelist_hook mm/slub.c:1379 [inline] slab_free mm/slub.c:2961 [inline] kfree+0xe8/0x2b0 mm/slub.c:3882 tcp_free_fastopen_req net/ipv4/tcp.c:1077 [inline] tcp_disconnect+0xc15/0x13e0 net/ipv4/tcp.c:2328 inet_child_forget+0xb8/0x600 net/ipv4/inet_connection_sock.c:898 inet_csk_reqsk_queue_add+0x1e7/0x250 net/ipv4/inet_connection_sock.c:928 tcp_get_cookie_sock+0x21a/0x510 net/ipv4/syncookies.c:217 cookie_v4_check+0x1a19/0x28b0 net/ipv4/syncookies.c:384 tcp_v4_cookie_check net/ipv4/tcp_ipv4.c:1384 [inline] tcp_v4_do_rcv+0x731/0x940 net/ipv4/tcp_ipv4.c:1421 tcp_v4_rcv+0x2dc0/0x31c0 net/ipv4/tcp_ipv4.c:1715 ip_local_deliver_finish+0x4cc/0xc20 net/ipv4/ip_input.c:216 NF_HOOK include/linux/netfilter.h:257 [inline] ip_local_deliver+0x1ce/0x700 net/ipv4/ip_input.c:257 dst_input include/net/dst.h:492 [inline] ip_rcv_finish+0xb1d/0x20b0 net/ipv4/ip_input.c:396 NF_HOOK include/linux/netfilter.h:257 [inline] ip_rcv+0xd8c/0x19c0 net/ipv4/ip_input.c:487 __netif_receive_skb_core+0x1ad1/0x3400 net/core/dev.c:4210 __netif_receive_skb+0x2a/0x1a0 net/core/dev.c:4248 process_backlog+0xe5/0x6c0 net/core/dev.c:4868 napi_poll net/core/dev.c:5270 [inline] net_rx_action+0xe70/0x18e0 net/core/dev.c:5335 __do_softirq+0x2fb/0xb99 kernel/softirq.c:284 do_softirq_own_stack+0x1c/0x30 arch/x86/entry/entry_64.S:899 </IRQ> do_softirq.part.17+0x1e8/0x230 kernel/softirq.c:328 do_softirq kernel/softirq.c:176 [inline] __local_bh_enable_ip+0x1cf/0x1e0 kernel/softirq.c:181 local_bh_enable include/linux/bottom_half.h:31 [inline] rcu_read_unlock_bh include/linux/rcupdate.h:931 [inline] ip_finish_output2+0x9ab/0x15e0 net/ipv4/ip_output.c:230 ip_finish_output+0xa35/0xdf0 net/ipv4/ip_output.c:316 NF_HOOK_COND include/linux/netfilter.h:246 [inline] ip_output+0x1f6/0x7b0 net/ipv4/ip_output.c:404 dst_output include/net/dst.h:486 [inline] ip_local_out+0x95/0x160 net/ipv4/ip_output.c:124 ip_queue_xmit+0x9a8/0x1a10 net/ipv4/ip_output.c:503 tcp_transmit_skb+0x1ade/0x3470 net/ipv4/tcp_output.c:1057 tcp_write_xmit+0x79e/0x55b0 net/ipv4/tcp_output.c:2265 __tcp_push_pending_frames+0xfa/0x3a0 net/ipv4/tcp_output.c:2450 tcp_push+0x4ee/0x780 net/ipv4/tcp.c:683 tcp_sendmsg+0x128d/0x39b0 net/ipv4/tcp.c:1342 inet_sendmsg+0x164/0x5b0 net/ipv4/af_inet.c:762 sock_sendmsg_nosec net/socket.c:633 [inline] sock_sendmsg+0xca/0x110 net/socket.c:643 SYSC_sendto+0x660/0x810 net/socket.c:1696 SyS_sendto+0x40/0x50 net/socket.c:1664 entry_SYSCALL_64_fastpath+0x1f/0xbe RIP: 0033:0x446059 RSP: 002b:00007faa6761fb58 EFLAGS: 00000282 ORIG_RAX: 000000000000002c RAX: ffffffffffffffda RBX: 0000000000000017 RCX: 0000000000446059 RDX: 0000000000000001 RSI: 0000000020ba3fcd RDI: 0000000000000017 RBP: 00000000006e40a0 R08: 0000000020ba4ff0 R09: 0000000000000010 R10: 0000000020000000 R11: 0000000000000282 R12: 0000000000708150 R13: 0000000000000000 R14: 00007faa676209c0 R15: 00007faa67620700 Object at ffff88003b5bbcb8, in cache kmalloc-64 size: 64 Allocated: PID = 20909 save_stack_trace+0x16/0x20 arch/x86/kernel/stacktrace.c:59 save_stack+0x43/0xd0 mm/kasan/kasan.c:513 set_track mm/kasan/kasan.c:525 [inline] kasan_kmalloc+0xad/0xe0 mm/kasan/kasan.c:616 kmem_cache_alloc_trace+0x82/0x270 mm/slub.c:2745 kmalloc include/linux/slab.h:490 [inline] kzalloc include/linux/slab.h:663 [inline] tcp_sendmsg_fastopen net/ipv4/tcp.c:1094 [inline] tcp_sendmsg+0x221a/0x39b0 net/ipv4/tcp.c:1139 inet_sendmsg+0x164/0x5b0 net/ipv4/af_inet.c:762 sock_sendmsg_nosec net/socket.c:633 [inline] sock_sendmsg+0xca/0x110 net/socket.c:643 SYSC_sendto+0x660/0x810 net/socket.c:1696 SyS_sendto+0x40/0x50 net/socket.c:1664 entry_SYSCALL_64_fastpath+0x1f/0xbe Freed: PID = 20909 save_stack_trace+0x16/0x20 arch/x86/kernel/stacktrace.c:59 save_stack+0x43/0xd0 mm/kasan/kasan.c:513 set_track mm/kasan/kasan.c:525 [inline] kasan_slab_free+0x73/0xc0 mm/kasan/kasan.c:589 slab_free_hook mm/slub.c:1357 [inline] slab_free_freelist_hook mm/slub.c:1379 [inline] slab_free mm/slub.c:2961 [inline] kfree+0xe8/0x2b0 mm/slub.c:3882 tcp_free_fastopen_req net/ipv4/tcp.c:1077 [inline] tcp_disconnect+0xc15/0x13e0 net/ipv4/tcp.c:2328 __inet_stream_connect+0x20c/0xf90 net/ipv4/af_inet.c:593 tcp_sendmsg_fastopen net/ipv4/tcp.c:1111 [inline] tcp_sendmsg+0x23a8/0x39b0 net/ipv4/tcp.c:1139 inet_sendmsg+0x164/0x5b0 net/ipv4/af_inet.c:762 sock_sendmsg_nosec net/socket.c:633 [inline] sock_sendmsg+0xca/0x110 net/socket.c:643 SYSC_sendto+0x660/0x810 net/socket.c:1696 SyS_sendto+0x40/0x50 net/socket.c:1664 entry_SYSCALL_64_fastpath+0x1f/0xbe Fixes: e994b2f0fb92 ("tcp: do not lock listener to process SYN packets") Fixes: 7db92362d2fe ("tcp: fix potential double free issue for fastopen_req") Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Andrey Konovalov <andreyknvl@google.com> Acked-by: Wei Wang <weiwan@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-14tcp: fix wraparound issue in tcp_lpEric Dumazet
[ Upstream commit a9f11f963a546fea9144f6a6d1a307e814a387e7 ] Be careful when comparing tcp_time_stamp to some u32 quantity, otherwise result can be surprising. Fixes: 7c106d7e782b ("[TCP]: TCP Low Priority congestion control") Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-14tcp: do not underestimate skb->truesize in tcp_trim_head()Eric Dumazet
[ Upstream commit 7162fb242cb8322beb558828fd26b33c3e9fc805 ] Andrey found a way to trigger the WARN_ON_ONCE(delta < len) in skb_try_coalesce() using syzkaller and a filter attached to a TCP socket over loopback interface. I believe one issue with looped skbs is that tcp_trim_head() can end up producing skb with under estimated truesize. It hardly matters for normal conditions, since packets sent over loopback are never truncated. Bytes trimmed from skb->head should not change skb truesize, since skb->head is not reallocated. Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Andrey Konovalov <andreyknvl@google.com> Tested-by: Andrey Konovalov <andreyknvl@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-08netlink: Allow direct reclaim for fallback allocationRoss Lagerwall
The backport of d35c99ff77ec ("netlink: do not enter direct reclaim from netlink_dump()") to the 4.4 branch (first in 4.4.32) mistakenly removed direct claim from the initial large allocation _and_ the fallback allocation which means that allocations can spuriously fail. Fix the issue by adding back the direct reclaim flag to the fallback allocation. Fixes: 6d123f1d396b ("netlink: do not enter direct reclaim from netlink_dump()") Signed-off-by: Ross Lagerwall <ross.lagerwall@citrix.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-02p9_client_readdir() fixAl Viro
commit 71d6ad08379304128e4bdfaf0b4185d54375423e upstream. Don't assume that server is sane and won't return more data than asked for. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-02ipv6: check raw payload size correctly in ioctlJamie Bainbridge
[ Upstream commit 105f5528b9bbaa08b526d3405a5bcd2ff0c953c8 ] In situations where an skb is paged, the transport header pointer and tail pointer can be the same because the skb contents are in frags. This results in ioctl(SIOCINQ/FIONREAD) incorrectly returning a length of 0 when the length to receive is actually greater than zero. skb->len is already correctly set in ip6_input_finish() with pskb_pull(), so use skb->len as it always returns the correct result for both linear and paged data. Signed-off-by: Jamie Bainbridge <jbainbri@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-02ipv6: check skb->protocol before lookup for nexthopWANG Cong
[ Upstream commit 199ab00f3cdb6f154ea93fa76fd80192861a821d ] Andrey reported a out-of-bound access in ip6_tnl_xmit(), this is because we use an ipv4 dst in ip6_tnl_xmit() and cast an IPv4 neigh key as an IPv6 address: neigh = dst_neigh_lookup(skb_dst(skb), &ipv6_hdr(skb)->daddr); if (!neigh) goto tx_err_link_failure; addr6 = (struct in6_addr *)&neigh->primary_key; // <=== HERE addr_type = ipv6_addr_type(addr6); if (addr_type == IPV6_ADDR_ANY) addr6 = &ipv6_hdr(skb)->daddr; memcpy(&fl6->daddr, addr6, sizeof(fl6->daddr)); Also the network header of the skb at this point should be still IPv4 for 4in6 tunnels, we shold not just use it as IPv6 header. This patch fixes it by checking if skb->protocol is ETH_P_IPV6: if it is, we are safe to do the nexthop lookup using skb_dst() and ipv6_hdr(skb)->daddr; if not (aka IPv4), we have no clue about which dest address we can pick here, we have to rely on callers to fill it from tunnel config, so just fall to ip6_route_output() to make the decision. Fixes: ea3dc9601bda ("ip6_tunnel: Add support for wildcard tunnel endpoints.") Reported-by: Andrey Konovalov <andreyknvl@google.com> Tested-by: Andrey Konovalov <andreyknvl@google.com> Cc: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-02ip6mr: fix notification device destructionNikolay Aleksandrov
[ Upstream commit 723b929ca0f79c0796f160c2eeda4597ee98d2b8 ] Andrey Konovalov reported a BUG caused by the ip6mr code which is caused because we call unregister_netdevice_many for a device that is already being destroyed. In IPv4's ipmr that has been resolved by two commits long time ago by introducing the "notify" parameter to the delete function and avoiding the unregister when called from a notifier, so let's do the same for ip6mr. The trace from Andrey: ------------[ cut here ]------------ kernel BUG at net/core/dev.c:6813! invalid opcode: 0000 [#1] SMP KASAN Modules linked in: CPU: 1 PID: 1165 Comm: kworker/u4:3 Not tainted 4.11.0-rc7+ #251 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011 Workqueue: netns cleanup_net task: ffff880069208000 task.stack: ffff8800692d8000 RIP: 0010:rollback_registered_many+0x348/0xeb0 net/core/dev.c:6813 RSP: 0018:ffff8800692de7f0 EFLAGS: 00010297 RAX: ffff880069208000 RBX: 0000000000000002 RCX: 0000000000000001 RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffff88006af90569 RBP: ffff8800692de9f0 R08: ffff8800692dec60 R09: 0000000000000000 R10: 0000000000000006 R11: 0000000000000000 R12: ffff88006af90070 R13: ffff8800692debf0 R14: dffffc0000000000 R15: ffff88006af90000 FS: 0000000000000000(0000) GS:ffff88006cb00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 00007fe7e897d870 CR3: 00000000657e7000 CR4: 00000000000006e0 Call Trace: unregister_netdevice_many.part.105+0x87/0x440 net/core/dev.c:7881 unregister_netdevice_many+0xc8/0x120 net/core/dev.c:7880 ip6mr_device_event+0x362/0x3f0 net/ipv6/ip6mr.c:1346 notifier_call_chain+0x145/0x2f0 kernel/notifier.c:93 __raw_notifier_call_chain kernel/notifier.c:394 raw_notifier_call_chain+0x2d/0x40 kernel/notifier.c:401 call_netdevice_notifiers_info+0x51/0x90 net/core/dev.c:1647 call_netdevice_notifiers net/core/dev.c:1663 rollback_registered_many+0x919/0xeb0 net/core/dev.c:6841 unregister_netdevice_many.part.105+0x87/0x440 net/core/dev.c:7881 unregister_netdevice_many net/core/dev.c:7880 default_device_exit_batch+0x4fa/0x640 net/core/dev.c:8333 ops_exit_list.isra.4+0x100/0x150 net/core/net_namespace.c:144 cleanup_net+0x5a8/0xb40 net/core/net_namespace.c:463 process_one_work+0xc04/0x1c10 kernel/workqueue.c:2097 worker_thread+0x223/0x19c0 kernel/workqueue.c:2231 kthread+0x35e/0x430 kernel/kthread.c:231 ret_from_fork+0x31/0x40 arch/x86/entry/entry_64.S:430 Code: 3c 32 00 0f 85 70 0b 00 00 48 b8 00 02 00 00 00 00 ad de 49 89 47 78 e9 93 fe ff ff 49 8d 57 70 49 8d 5f 78 eb 9e e8 88 7a 14 fe <0f> 0b 48 8b 9d 28 fe ff ff e8 7a 7a 14 fe 48 b8 00 00 00 00 00 RIP: rollback_registered_many+0x348/0xeb0 RSP: ffff8800692de7f0 ---[ end trace e0b29c57e9b3292c ]--- Reported-by: Andrey Konovalov <andreyknvl@google.com> Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com> Tested-by: Andrey Konovalov <andreyknvl@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-02netpoll: Check for skb->queue_mappingTushar Dave
[ Upstream commit c70b17b775edb21280e9de7531acf6db3b365274 ] Reducing real_num_tx_queues needs to be in sync with skb queue_mapping otherwise skbs with queue_mapping greater than real_num_tx_queues can be sent to the underlying driver and can result in kernel panic. One such event is running netconsole and enabling VF on the same device. Or running netconsole and changing number of tx queues via ethtool on same device. e.g. Unable to handle kernel NULL pointer dereference tsk->{mm,active_mm}->context = 0000000000001525 tsk->{mm,active_mm}->pgd = fff800130ff9a000 \|/ ____ \|/ "@'/ .. \`@" /_| \__/ |_\ \__U_/ kworker/48:1(475): Oops [#1] CPU: 48 PID: 475 Comm: kworker/48:1 Tainted: G OE 4.11.0-rc3-davem-net+ #7 Workqueue: events queue_process task: fff80013113299c0 task.stack: fff800131132c000 TSTATE: 0000004480e01600 TPC: 00000000103f9e3c TNPC: 00000000103f9e40 Y: 00000000 Tainted: G OE TPC: <ixgbe_xmit_frame_ring+0x7c/0x6c0 [ixgbe]> g0: 0000000000000000 g1: 0000000000003fff g2: 0000000000000000 g3: 0000000000000001 g4: fff80013113299c0 g5: fff8001fa6808000 g6: fff800131132c000 g7: 00000000000000c0 o0: fff8001fa760c460 o1: fff8001311329a50 o2: fff8001fa7607504 o3: 0000000000000003 o4: fff8001f96e63a40 o5: fff8001311d77ec0 sp: fff800131132f0e1 ret_pc: 000000000049ed94 RPC: <set_next_entity+0x34/0xb80> l0: 0000000000000000 l1: 0000000000000800 l2: 0000000000000000 l3: 0000000000000000 l4: 000b2aa30e34b10d l5: 0000000000000000 l6: 0000000000000000 l7: fff8001fa7605028 i0: fff80013111a8a00 i1: fff80013155a0780 i2: 0000000000000000 i3: 0000000000000000 i4: 0000000000000000 i5: 0000000000100000 i6: fff800131132f1a1 i7: 00000000103fa4b0 I7: <ixgbe_xmit_frame+0x30/0xa0 [ixgbe]> Call Trace: [00000000103fa4b0] ixgbe_xmit_frame+0x30/0xa0 [ixgbe] [0000000000998c74] netpoll_start_xmit+0xf4/0x200 [0000000000998e10] queue_process+0x90/0x160 [0000000000485fa8] process_one_work+0x188/0x480 [0000000000486410] worker_thread+0x170/0x4c0 [000000000048c6b8] kthread+0xd8/0x120 [0000000000406064] ret_from_fork+0x1c/0x2c [0000000000000000] (null) Disabling lock debugging due to kernel taint Caller[00000000103fa4b0]: ixgbe_xmit_frame+0x30/0xa0 [ixgbe] Caller[0000000000998c74]: netpoll_start_xmit+0xf4/0x200 Caller[0000000000998e10]: queue_process+0x90/0x160 Caller[0000000000485fa8]: process_one_work+0x188/0x480 Caller[0000000000486410]: worker_thread+0x170/0x4c0 Caller[000000000048c6b8]: kthread+0xd8/0x120 Caller[0000000000406064]: ret_from_fork+0x1c/0x2c Caller[0000000000000000]: (null) Signed-off-by: Tushar Dave <tushar.n.dave@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-02net: ipv6: RTF_PCPU should not be settable from userspaceDavid Ahern
[ Upstream commit 557c44be917c322860665be3d28376afa84aa936 ] Andrey reported a fault in the IPv6 route code: kasan: GPF could be caused by NULL-ptr deref or user memory access general protection fault: 0000 [#1] SMP KASAN Modules linked in: CPU: 1 PID: 4035 Comm: a.out Not tainted 4.11.0-rc7+ #250 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011 task: ffff880069809600 task.stack: ffff880062dc8000 RIP: 0010:ip6_rt_cache_alloc+0xa6/0x560 net/ipv6/route.c:975 RSP: 0018:ffff880062dced30 EFLAGS: 00010206 RAX: dffffc0000000000 RBX: ffff8800670561c0 RCX: 0000000000000006 RDX: 0000000000000003 RSI: ffff880062dcfb28 RDI: 0000000000000018 RBP: ffff880062dced68 R08: 0000000000000001 R09: 0000000000000000 R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000000 R13: ffff880062dcfb28 R14: dffffc0000000000 R15: 0000000000000000 FS: 00007feebe37e7c0(0000) GS:ffff88006cb00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 00000000205a0fe4 CR3: 000000006b5c9000 CR4: 00000000000006e0 Call Trace: ip6_pol_route+0x1512/0x1f20 net/ipv6/route.c:1128 ip6_pol_route_output+0x4c/0x60 net/ipv6/route.c:1212 ... Andrey's syzkaller program passes rtmsg.rtmsg_flags with the RTF_PCPU bit set. Flags passed to the kernel are blindly copied to the allocated rt6_info by ip6_route_info_create making a newly inserted route appear as though it is a per-cpu route. ip6_rt_cache_alloc sees the flag set and expects rt->dst.from to be set - which it is not since it is not really a per-cpu copy. The subsequent call to __ip6_dst_alloc then generates the fault. Fix by checking for the flag and failing with EINVAL. Fixes: d52d3997f843f ("ipv6: Create percpu rt6_info") Reported-by: Andrey Konovalov <andreyknvl@google.com> Signed-off-by: David Ahern <dsa@cumulusnetworks.com> Acked-by: Martin KaFai Lau <kafai@fb.com> Tested-by: Andrey Konovalov <andreyknvl@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-02tcp: clear saved_syn in tcp_disconnect()Eric Dumazet
[ Upstream commit 17c3060b1701fc69daedb4c90be6325d3d9fca8e ] In the (very unlikely) case a passive socket becomes a listener, we do not want to duplicate its saved SYN headers. This would lead to double frees, use after free, and please hackers and various fuzzers Tested: 0 socket(..., SOCK_STREAM, IPPROTO_TCP) = 3 +0 setsockopt(3, IPPROTO_TCP, TCP_SAVE_SYN, [1], 4) = 0 +0 fcntl(3, F_SETFL, O_RDWR|O_NONBLOCK) = 0 +0 bind(3, ..., ...) = 0 +0 listen(3, 5) = 0 +0 < S 0:0(0) win 32972 <mss 1460,nop,wscale 7> +0 > S. 0:0(0) ack 1 <...> +.1 < . 1:1(0) ack 1 win 257 +0 accept(3, ..., ...) = 4 +0 connect(4, AF_UNSPEC, ...) = 0 +0 close(3) = 0 +0 bind(4, ..., ...) = 0 +0 listen(4, 5) = 0 +0 < S 0:0(0) win 32972 <mss 1460,nop,wscale 7> +0 > S. 0:0(0) ack 1 <...> +.1 < . 1:1(0) ack 1 win 257 Fixes: cd8ae85299d5 ("tcp: provide SYN headers for passive connections") Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-02sctp: listen on the sock only when it's state is listening or closedXin Long
[ Upstream commit 34b2789f1d9bf8dcca9b5cb553d076ca2cd898ee ] Now sctp doesn't check sock's state before listening on it. It could even cause changing a sock with any state to become a listening sock when doing sctp_listen. This patch is to fix it by checking sock's state in sctp_listen, so that it will listen on the sock with right state. Reported-by: Andrey Konovalov <andreyknvl@google.com> Tested-by: Andrey Konovalov <andreyknvl@google.com> Signed-off-by: Xin Long <lucien.xin@gmail.com> Acked-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
