path: root/net
2010-05-16rtnetlink: make SR-IOV VF interface symmetricChris Wright
Now we have a set of nested attributes: IFLA_VFINFO_LIST (NESTED) IFLA_VF_INFO (NESTED) IFLA_VF_MAC IFLA_VF_VLAN IFLA_VF_TX_RATE This allows a single set to operate on multiple attributes if desired. Among other things, it means a dump can be replayed to set state. The current interface has yet to be released, so this seems like something to consider for 2.6.34. Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-16sctp: delete active ICMP proto unreachable timer when free transportWei Yongjun
transport may be free before ICMP proto unreachable timer expire, so we should delete active ICMP proto unreachable timer when transport is going away. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-16tcp: fix MD5 (RFC2385) supportEric Dumazet
TCP MD5 support uses percpu data for temporary storage. It currently disables preemption so that same storage cannot be reclaimed by another thread on same cpu. We also have to make sure a softirq handler wont try to use also same context. Various bug reports demonstrated corruptions. Fix is to disable preemption and BH. Reported-by: Bhaskar Dutta <bhaskie@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: net: Fix FDDI and TR config checks in ipv4 arp and LLC. IPv4: unresolved multicast route cleanup mac80211: remove association work when processing deauth request ar9170: wait for asynchronous firmware loading ipv4: udp: fix short packet and bad checksum logging phy: Fix initialization in micrel driver. sctp: Fix a race between ICMP protocol unreachable and connect() veth: Dont kfree_skb() after dev_forward_skb() IPv6: fix IPV6_RECVERR handling of locally-generated errors net/gianfar: drop recycled skbs on MTU change iwlwifi: work around passive scan issue
2010-05-10Merge branch 'master' of ↵David S. Miller
2010-05-10net: Fix FDDI and TR config checks in ipv4 arp and LLC.David S. Miller
Need to check both CONFIG_FOO and CONFIG_FOO_MODULE Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-10IPv4: unresolved multicast route cleanupAndreas Meissner
Fixes the expiration timer for unresolved multicast route entries. In case new multicast routing requests come in faster than the expiration timeout occurs (e.g. zap through multicast TV streams), the timer is prevented from being called at time for already existing entries. As the single timer is resetted to default whenever a new entry is made, the timeout for existing unresolved entires are missed and/or not updated. As a consequence new requests are denied when the limit of unresolved entries has been reached because old entries live longer than they are supposed to. The solution is to reset the timer only for the first unresolved entry in the multicast routing cache. All other timers are already set and updated correctly within the timer function itself by now. Signed-off by: Andreas Meissner <andreas.meissner@sphairon.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-07mac80211: remove association work when processing deauth requestReinette Chatre
In https://bugzilla.kernel.org/show_bug.cgi?id=15794 a user encountered the following: [18967.469098] wlan0: authenticated [18967.472527] wlan0: associate with 00:1c:10:b8:e3:ea (try 1) [18967.472585] wlan0: deauthenticating from 00:1c:10:b8:e3:ea by local choice (reason=3) [18967.672057] wlan0: associate with 00:1c:10:b8:e3:ea (try 2) [18967.872357] wlan0: associate with 00:1c:10:b8:e3:ea (try 3) [18968.072960] wlan0: association with 00:1c:10:b8:e3:ea timed out [18968.076890] ------------[ cut here ]------------ [18968.076898] WARNING: at net/wireless/mlme.c:341 cfg80211_send_assoc_timeout+0xa8/0x140() [18968.076900] Hardware name: GX628 [18968.076924] Pid: 1408, comm: phy0 Not tainted 2.6.34-rc4-00082-g250541f-dirty #3 [18968.076926] Call Trace: [18968.076931] [<ffffffff8103459e>] ? warn_slowpath_common+0x6e/0xb0 [18968.076934] [<ffffffff8157c2d8>] ? cfg80211_send_assoc_timeout+0xa8/0x140 [18968.076937] [<ffffffff8103ff8b>] ? mod_timer+0x10b/0x180 [18968.076940] [<ffffffff8158f0fc>] ? ieee80211_assoc_done+0xbc/0xc0 [18968.076943] [<ffffffff81590d53>] ? ieee80211_work_work+0x553/0x11c0 [18968.076945] [<ffffffff8102d931>] ? finish_task_switch+0x41/0xb0 [18968.076948] [<ffffffff81590800>] ? ieee80211_work_work+0x0/0x11c0 [18968.076951] [<ffffffff810476fb>] ? worker_thread+0x13b/0x210 [18968.076954] [<ffffffff8104b6b0>] ? autoremove_wake_function+0x0/0x30 [18968.076956] [<ffffffff810475c0>] ? worker_thread+0x0/0x210 [18968.076959] [<ffffffff8104b21e>] ? kthread+0x8e/0xa0 [18968.076962] [<ffffffff810031f4>] ? kernel_thread_helper+0x4/0x10 [18968.076964] [<ffffffff8104b190>] ? kthread+0x0/0xa0 [18968.076966] [<ffffffff810031f0>] ? kernel_thread_helper+0x0/0x10 [18968.076968] ---[ end trace 8aa6265f4b1adfe0 ]--- As explained by Johannes Berg <johannes@sipsolutions.net>: We authenticate successfully, and then userspace requests association. Then we start that process, but the AP doesn't respond. While we're still waiting for an AP response, userspace asks for a deauth. We do the deauth, but don't abort the association work. Then once the association work times out we tell cfg80211, but it no longer wants to know since for all it is concerned we accepted the deauth that also kills the association attempt. Fix this by, upon receipt of deauth request, removing the association work and continuing to send the deauth. Unfortunately the user reporting the issue is not able to reproduce this problem anymore and cannot verify this fix. This seems like a well understood issue though and I thus present the patch. Bug-identified-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-05-06ipv4: udp: fix short packet and bad checksum loggingBjørn Mork
commit 2783ef23 moved the initialisation of saddr and daddr after pskb_may_pull() to avoid a potential data corruption. Unfortunately also placing it after the short packet and bad checksum error paths, where these variables are used for logging. The result is bogus output like [92238.389505] UDP: short packet: From 2.0.0.0:65535 23715/178 to 0.0.0.0:65535 Moving the saddr and daddr initialisation above the error paths, while still keeping it after the pskb_may_pull() to keep the fix from commit 2783ef23. Signed-off-by: Bjørn Mork <bjorn@mork.no> Cc: stable@kernel.org Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-06sctp: Fix a race between ICMP protocol unreachable and connect()Vlad Yasevich
ICMP protocol unreachable handling completely disregarded the fact that the user may have locked the socket. It proceeded to destroy the association, even though the user may have held the lock and had a ref on the association. This resulted in the following: Attempt to release alive inet socket f6afcc00 ========================= [ BUG: held lock freed! ] ------------------------- somenu/2672 is freeing memory f6afcc00-f6afcfff, with a lock still held there! (sk_lock-AF_INET){+.+.+.}, at: [<c122098a>] sctp_connect+0x13/0x4c 1 lock held by somenu/2672: #0: (sk_lock-AF_INET){+.+.+.}, at: [<c122098a>] sctp_connect+0x13/0x4c stack backtrace: Pid: 2672, comm: somenu Not tainted 2.6.32-telco #55 Call Trace: [<c1232266>] ? printk+0xf/0x11 [<c1038553>] debug_check_no_locks_freed+0xce/0xff [<c10620b4>] kmem_cache_free+0x21/0x66 [<c1185f25>] __sk_free+0x9d/0xab [<c1185f9c>] sk_free+0x1c/0x1e [<c1216e38>] sctp_association_put+0x32/0x89 [<c1220865>] __sctp_connect+0x36d/0x3f4 [<c122098a>] ? sctp_connect+0x13/0x4c [<c102d073>] ? autoremove_wake_function+0x0/0x33 [<c12209a8>] sctp_connect+0x31/0x4c [<c11d1e80>] inet_dgram_connect+0x4b/0x55 [<c11834fa>] sys_connect+0x54/0x71 [<c103a3a2>] ? lock_release_non_nested+0x88/0x239 [<c1054026>] ? might_fault+0x42/0x7c [<c1054026>] ? might_fault+0x42/0x7c [<c11847ab>] sys_socketcall+0x6d/0x178 [<c10da994>] ? trace_hardirqs_on_thunk+0xc/0x10 [<c1002959>] syscall_call+0x7/0xb This was because the sctp_wait_for_connect() would aqcure the socket lock and then proceed to release the last reference count on the association, thus cause the fully destruction path to finish freeing the socket. The simplest solution is to start a very short timer in case the socket is owned by user. When the timer expires, we can do some verification and be able to do the release properly. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-06veth: Dont kfree_skb() after dev_forward_skb()Eric Dumazet
In case of congestion, netif_rx() frees the skb, so we must assume dev_forward_skb() also consume skb. Bug introduced by commit 445409602c092 (veth: move loopback logic to common location) We must change dev_forward_skb() to always consume skb, and veth to not double free it. Bug report : http://marc.info/?l=linux-netdev&m=127310770900442&w=3 Reported-by: Martín Ferrari <martin.ferrari@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-05IPv6: fix IPV6_RECVERR handling of locally-generated errorsBrian Haley
I noticed when I added support for IPV6_DONTFRAG that if you set IPV6_RECVERR and tried to send a UDP packet larger than 64K to an IPv6 destination, you'd correctly get an EMSGSIZE, but reading from MSG_ERRQUEUE returned the incorrect address in the cmsg: struct msghdr: msg_name 0x7fff8f3c96d0 msg_namelen 28 struct sockaddr_in6: sin6_family 10 sin6_port 7639 sin6_flowinfo 0 sin6_addr ::ffff:38.32.0.0 sin6_scope_id 0 ((null)) It should have returned this in my case: struct msghdr: msg_name 0x7fffd866b510 msg_namelen 28 struct sockaddr_in6: sin6_family 10 sin6_port 7639 sin6_flowinfo 0 sin6_addr 2620:0:a09:e000:21f:29ff:fe57:f88b sin6_scope_id 0 ((null)) The problem is that ipv6_recv_error() assumes that if the error wasn't generated by ICMPv6, it's an IPv4 address sitting there, and proceeds to create a v4-mapped address from it. Change ipv6_icmp_error() and ipv6_local_error() to set skb->protocol to htons(ETH_P_IPV6) so that ipv6_recv_error() knows the address sitting right after the extended error is IPv6, else it will incorrectly map the first octet into an IPv4-mapped IPv6 address in the cmsg structure returned in a recvmsg() call to obtain the error. Signed-off-by: Brian Haley <brian.haley@hp.com> -- To unsubscribe from this list: send the line "unsubscribe netdev" in the body of a message to majordomo@vger.kernel.org More majordomo info at http://vger.kernel.org/majordomo-info.html Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: FEC: Fix kernel panic in fec_set_mac_address. ipv6: Fix default multicast hops setting. net: ep93xx_eth stops receiving packets drivers/net/phy: micrel phy driver dm9601: fix phy/eeprom write routine ppp_generic: handle non-linear skbs when passing them to pppd ppp_generic: pull 2 bytes so that PPP_PROTO(skb) is valid net: fix compile error due to double return type in SOCK_DEBUG net/usb: initiate sync sequence in sierra_net.c driver net/usb: remove default in Kconfig for sierra_net driver r8169: Fix rtl8169_rx_interrupt() e1000e: Fix oops caused by ASPM patch. net/sb1250: register mdio bus in probe sctp: Fix skb_over_panic resulting from multiple invalid parameter errors (CVE-2010-1173) (v4) p54pci: fix bugs in p54p_check_tx_ring
2010-05-03ipv6: Fix default multicast hops setting.David S. Miller
As per RFC 3493 the default multicast hops setting for a socket should be "1" just like ipv4. Ironically we have a IPV6_DEFAULT_MCASTHOPS macro it just wasn't being used. Reported-by: Elliot Hughes <enh@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-29Merge branch 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6Linus Torvalds
* 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: nfs: fix memory leak in nfs_get_sb with CONFIG_NFS_V4 nfs: fix some issues in nfs41_proc_reclaim_complete() NFS: Ensure that nfs_wb_page() waits for Pg_writeback to clear NFS: Fix an unstable write data integrity race nfs: testing for null instead of ERR_PTR() NFS: rsize and wsize settings ignored on v4 mounts NFSv4: Don't attempt an atomic open if the file is a mountpoint SUNRPC: Fix a bug in rpcauth_prune_expired
2010-04-28sctp: Fix skb_over_panic resulting from multiple invalid parameter errors ↵Neil Horman
(CVE-2010-1173) (v4) Ok, version 4 Change Notes: 1) Minor cleanups, from Vlads notes Summary: Hey- Recently, it was reported to me that the kernel could oops in the following way: <5> kernel BUG at net/core/skbuff.c:91! <5> invalid operand: 0000 [#1] <5> Modules linked in: sctp netconsole nls_utf8 autofs4 sunrpc iptable_filter ip_tables cpufreq_powersave parport_pc lp parport vmblock(U) vsock(U) vmci(U) vmxnet(U) vmmemctl(U) vmhgfs(U) acpiphp dm_mirror dm_mod button battery ac md5 ipv6 uhci_hcd ehci_hcd snd_ens1371 snd_rawmidi snd_seq_device snd_pcm_oss snd_mixer_oss snd_pcm snd_timer snd_page_alloc snd_ac97_codec snd soundcore pcnet32 mii floppy ext3 jbd ata_piix libata mptscsih mptsas mptspi mptscsi mptbase sd_mod scsi_mod <5> CPU: 0 <5> EIP: 0060:[<c02bff27>] Not tainted VLI <5> EFLAGS: 00010216 (2.6.9-89.0.25.EL) <5> EIP is at skb_over_panic+0x1f/0x2d <5> eax: 0000002c ebx: c033f461 ecx: c0357d96 edx: c040fd44 <5> esi: c033f461 edi: df653280 ebp: 00000000 esp: c040fd40 <5> ds: 007b es: 007b ss: 0068 <5> Process swapper (pid: 0, threadinfo=c040f000 task=c0370be0) <5> Stack: c0357d96 e0c29478 00000084 00000004 c033f461 df653280 d7883180 e0c2947d <5> 00000000 00000080 df653490 00000004 de4f1ac0 de4f1ac0 00000004 df653490 <5> 00000001 e0c2877a 08000800 de4f1ac0 df653490 00000000 e0c29d2e 00000004 <5> Call Trace: <5> [<e0c29478>] sctp_addto_chunk+0xb0/0x128 [sctp] <5> [<e0c2947d>] sctp_addto_chunk+0xb5/0x128 [sctp] <5> [<e0c2877a>] sctp_init_cause+0x3f/0x47 [sctp] <5> [<e0c29d2e>] sctp_process_unk_param+0xac/0xb8 [sctp] <5> [<e0c29e90>] sctp_verify_init+0xcc/0x134 [sctp] <5> [<e0c20322>] sctp_sf_do_5_1B_init+0x83/0x28e [sctp] <5> [<e0c25333>] sctp_do_sm+0x41/0x77 [sctp] <5> [<c01555a4>] cache_grow+0x140/0x233 <5> [<e0c26ba1>] sctp_endpoint_bh_rcv+0xc5/0x108 [sctp] <5> [<e0c2b863>] sctp_inq_push+0xe/0x10 [sctp] <5> [<e0c34600>] sctp_rcv+0x454/0x509 [sctp] <5> [<e084e017>] ipt_hook+0x17/0x1c [iptable_filter] <5> [<c02d005e>] nf_iterate+0x40/0x81 <5> [<c02e0bb9>] ip_local_deliver_finish+0x0/0x151 <5> [<c02e0c7f>] ip_local_deliver_finish+0xc6/0x151 <5> [<c02d0362>] nf_hook_slow+0x83/0xb5 <5> [<c02e0bb2>] ip_local_deliver+0x1a2/0x1a9 <5> [<c02e0bb9>] ip_local_deliver_finish+0x0/0x151 <5> [<c02e103e>] ip_rcv+0x334/0x3b4 <5> [<c02c66fd>] netif_receive_skb+0x320/0x35b <5> [<e0a0928b>] init_stall_timer+0x67/0x6a [uhci_hcd] <5> [<c02c67a4>] process_backlog+0x6c/0xd9 <5> [<c02c690f>] net_rx_action+0xfe/0x1f8 <5> [<c012a7b1>] __do_softirq+0x35/0x79 <5> [<c0107efb>] handle_IRQ_event+0x0/0x4f <5> [<c01094de>] do_softirq+0x46/0x4d Its an skb_over_panic BUG halt that results from processing an init chunk in which too many of its variable length parameters are in some way malformed. The problem is in sctp_process_unk_param: if (NULL == *errp) *errp = sctp_make_op_error_space(asoc, chunk, ntohs(chunk->chunk_hdr->length)); if (*errp) { sctp_init_cause(*errp, SCTP_ERROR_UNKNOWN_PARAM, WORD_ROUND(ntohs(param.p->length))); sctp_addto_chunk(*errp, WORD_ROUND(ntohs(param.p->length)), param.v); When we allocate an error chunk, we assume that the worst case scenario requires that we have chunk_hdr->length data allocated, which would be correct nominally, given that we call sctp_addto_chunk for the violating parameter. Unfortunately, we also, in sctp_init_cause insert a sctp_errhdr_t structure into the error chunk, so the worst case situation in which all parameters are in violation requires chunk_hdr->length+(sizeof(sctp_errhdr_t)*param_count) bytes of data. The result of this error is that a deliberately malformed packet sent to a listening host can cause a remote DOS, described in CVE-2010-1173: http://cve.mitre.org/cgi-bin/cvename.cgi?name=2010-1173 I've tested the below fix and confirmed that it fixes the issue. We move to a strategy whereby we allocate a fixed size error chunk and ignore errors we don't have space to report. Tested by me successfully Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-28sctp: Fix oops when sending queued ASCONF chunksVlad Yasevich
When we finish processing ASCONF_ACK chunk, we try to send the next queued ASCONF. This action runs the sctp state machine recursively and it's not prepared to do so. kernel BUG at kernel/timer.c:790! invalid opcode: 0000 [#1] SMP last sysfs file: /sys/module/ipv6/initstate Modules linked in: sha256_generic sctp libcrc32c ipv6 dm_multipath uinput 8139too i2c_piix4 8139cp mii i2c_core pcspkr virtio_net joydev floppy virtio_blk virtio_pci [last unloaded: scsi_wait_scan] Pid: 0, comm: swapper Not tainted 2.6.34-rc4 #15 /Bochs EIP: 0060:[<c044a2ef>] EFLAGS: 00010286 CPU: 0 EIP is at add_timer+0xd/0x1b EAX: cecbab14 EBX: 000000f0 ECX: c0957b1c EDX: 03595cf4 ESI: cecba800 EDI: cf276f00 EBP: c0957aa0 ESP: c0957aa0 DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068 Process swapper (pid: 0, ti=c0956000 task=c0988ba0 task.ti=c0956000) Stack: c0957ae0 d1851214 c0ab62e4 c0ab5f26 0500ffff 00000004 00000005 00000004 <0> 00000000 d18694fd 00000004 1666b892 cecba800 cecba800 c0957b14 00000004 <0> c0957b94 d1851b11 ceda8b00 cecba800 cf276f00 00000001 c0957b14 000000d0 Call Trace: [<d1851214>] ? sctp_side_effects+0x607/0xdfc [sctp] [<d1851b11>] ? sctp_do_sm+0x108/0x159 [sctp] [<d1863386>] ? sctp_pname+0x0/0x1d [sctp] [<d1861a56>] ? sctp_primitive_ASCONF+0x36/0x3b [sctp] [<d185657c>] ? sctp_process_asconf_ack+0x2a4/0x2d3 [sctp] [<d184e35c>] ? sctp_sf_do_asconf_ack+0x1dd/0x2b4 [sctp] [<d1851ac1>] ? sctp_do_sm+0xb8/0x159 [sctp] [<d1863334>] ? sctp_cname+0x0/0x52 [sctp] [<d1854377>] ? sctp_assoc_bh_rcv+0xac/0xe1 [sctp] [<d1858f0f>] ? sctp_inq_push+0x2d/0x30 [sctp] [<d186329d>] ? sctp_rcv+0x797/0x82e [sctp] Tested-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Yuansong Qiao <ysqiao@research.ait.ie> Signed-off-by: Shuaijun Zhang <szhang@research.ait.ie> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-28sctp: fix to calc the INIT/INIT-ACK chunk length correctly is setWei Yongjun
When calculating the INIT/INIT-ACK chunk length, we should not only account the length of parameters, but also the parameters zero padding length, such as AUTH HMACS parameter and CHUNKS parameter. Without the parameters zero padding length we may get following oops. skb_over_panic: text:ce2068d2 len:130 put:6 head:cac3fe00 data:cac3fe00 tail:0xcac3fe82 end:0xcac3fe80 dev:<NULL> ------------[ cut here ]------------ kernel BUG at net/core/skbuff.c:127! invalid opcode: 0000 [#2] SMP last sysfs file: /sys/module/aes_generic/initstate Modules linked in: authenc ...... Pid: 4102, comm: sctp_darn Tainted: G D 2.6.34-rc2 #6 EIP: 0060:[<c0607630>] EFLAGS: 00010282 CPU: 0 EIP is at skb_over_panic+0x37/0x3e EAX: 00000078 EBX: c07c024b ECX: c07c02b9 EDX: cb607b78 ESI: 00000000 EDI: cac3fe7a EBP: 00000002 ESP: cb607b74 DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 Process sctp_darn (pid: 4102, ti=cb607000 task=cabdc990 task.ti=cb607000) Stack: c07c02b9 ce2068d2 00000082 00000006 cac3fe00 cac3fe00 cac3fe82 cac3fe80 <0> c07c024b cac3fe7c cac3fe7a c0608dec ca986e80 ce2068d2 00000006 0000007a <0> cb8120ca ca986e80 cb812000 00000003 cb8120c4 ce208a25 cb8120ca cadd9400 Call Trace: [<ce2068d2>] ? sctp_addto_chunk+0x45/0x85 [sctp] [<c0608dec>] ? skb_put+0x2e/0x32 [<ce2068d2>] ? sctp_addto_chunk+0x45/0x85 [sctp] [<ce208a25>] ? sctp_make_init+0x279/0x28c [sctp] [<c0686a92>] ? apic_timer_interrupt+0x2a/0x30 [<ce1fdc0b>] ? sctp_sf_do_prm_asoc+0x2b/0x7b [sctp] [<ce202823>] ? sctp_do_sm+0xa0/0x14a [sctp] [<ce2133b9>] ? sctp_pname+0x0/0x14 [sctp] [<ce211d72>] ? sctp_primitive_ASSOCIATE+0x2b/0x31 [sctp] [<ce20f3cf>] ? sctp_sendmsg+0x7a0/0x9eb [sctp] [<c064eb1e>] ? inet_sendmsg+0x3b/0x43 [<c04244b7>] ? task_tick_fair+0x2d/0xd9 [<c06031e1>] ? sock_sendmsg+0xa7/0xc1 [<c0416afe>] ? smp_apic_timer_interrupt+0x6b/0x75 [<c0425123>] ? dequeue_task_fair+0x34/0x19b [<c0446abb>] ? sched_clock_local+0x17/0x11e [<c052ea87>] ? _copy_from_user+0x2b/0x10c [<c060ab3a>] ? verify_iovec+0x3c/0x6a [<c06035ca>] ? sys_sendmsg+0x186/0x1e2 [<c042176b>] ? __wake_up_common+0x34/0x5b [<c04240c2>] ? __wake_up+0x2c/0x3b [<c057e35c>] ? tty_wakeup+0x43/0x47 [<c04430f2>] ? remove_wait_queue+0x16/0x24 [<c0580c94>] ? n_tty_read+0x5b8/0x65e [<c042be02>] ? default_wake_function+0x0/0x8 [<c0604e0e>] ? sys_socketcall+0x17f/0x1cd [<c040264c>] ? sysenter_do_call+0x12/0x22 Code: 0f 45 de 53 ff b0 98 00 00 00 ff b0 94 ...... EIP: [<c0607630>] skb_over_panic+0x37/0x3e SS:ESP 0068:cb607b74 To reproduce: # modprobe sctp # echo 1 > /proc/sys/net/sctp/addip_enable # echo 1 > /proc/sys/net/sctp/auth_enable # sctp_test -H 3ffe:501:ffff:100:20c:29ff:fe4d:f37e -P 800 -l # sctp_darn -H 3ffe:501:ffff:100:20c:29ff:fe4d:f37e -P 900 -h 192.168.0.21 -p 800 -I -s -t sctp_darn ready to send... 3ffe:501:ffff:100:20c:29ff:fe4d:f37e:900-192.168.0.21:800 Interactive mode> bindx-add=192.168.0.21 3ffe:501:ffff:100:20c:29ff:fe4d:f37e:900-192.168.0.21:800 Interactive mode> bindx-add=192.168.1.21 3ffe:501:ffff:100:20c:29ff:fe4d:f37e:900-192.168.0.21:800 Interactive mode> snd=10 ------------------------------------------------------------------ eth0 has addresses: 3ffe:501:ffff:100:20c:29ff:fe4d:f37e and 192.168.0.21 eth1 has addresses: 192.168.1.21 ------------------------------------------------------------------ Reported-by: George Cheimonidis <gchimon@gmail.com> Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-28sctp: per_cpu variables should be in bh_disabled sectionVlad Yasevich
Since the change of the atomics to percpu variables, we now have to disable BH in process context when touching percpu variables. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-28sctp: fix potential reference of a freed pointerVlad Yasevich
When sctp attempts to update an assocition, it removes any addresses that were not in the updated INITs. However, the loop may attempt to refrence a transport with address after removing it. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-28sctp: avoid irq lock inversion while call sk->sk_data_ready()Wei Yongjun
sk->sk_data_ready() of sctp socket can be called from both BH and non-BH contexts, but the default sk->sk_data_ready(), sock_def_readable(), can not be used in this case. Therefore, we have to make a new function sctp_data_ready() to grab sk->sk_data_ready() with BH disabling. ========================================================= [ INFO: possible irq lock inversion dependency detected ] 2.6.33-rc6 #129 --------------------------------------------------------- sctp_darn/1517 just changed the state of lock: (clock-AF_INET){++.?..}, at: [<c06aab60>] sock_def_readable+0x20/0x80 but this lock took another, SOFTIRQ-unsafe lock in the past: (slock-AF_INET){+.-...} and interrupts could create inverse lock ordering between them. other info that might help us debug this: 1 lock held by sctp_darn/1517: #0: (sk_lock-AF_INET){+.+.+.}, at: [<cdfe363d>] sctp_sendmsg+0x23d/0xc00 [sctp] Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-28Revert "tcp: bind() fix when many ports are bound"David S. Miller
This reverts two commits: fda48a0d7a8412cedacda46a9c0bf8ef9cd13559 tcp: bind() fix when many ports are bound and a follow-on fix for it: 6443bb1fc2050ca2b6585a3fa77f7833b55329ed ipv6: Fix inet6_csk_bind_conflict() It causes problems with binding listening sockets when time-wait sockets from a previous instance still are alive. It's too late to keep fiddling with this so late in the -rc series, and we'll deal with it in net-next-2.6 instead. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27bluetooth: handle l2cap_create_connless_pdu() errorsDan Carpenter
l2cap_create_connless_pdu() can sometimes return ERR_PTR(-ENOMEM) or ERR_PTR(-EFAULT). Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-26bridge br_multicast: Ensure to initialize BR_INPUT_SKB_CB(skb)->mrouters_only.YOSHIFUJI Hideaki / 吉藤英明
Even with commit 32dec5dd0233ebffa9cae25ce7ba6daeb7df4467 ("bridge br_multicast: Don't refer to BR_INPUT_SKB_CB(skb)->mrouters_only without IGMP snooping."), BR_INPUT_SKB_CB(skb)->mrouters_only is not appropriately initialized if IGMP snooping support is compiled and disabled, so we can see garbage. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-26ieee802154: Fix oops during ieee802154_sock_ioctlStefan Schmidt
Trying to run izlisten (from lowpan-tools tests) on a device that does not exists I got the oops below. The problem is that we are using get_dev_by_name without checking if we really get a device back. We don't in this case and writing to dev->type generates this oops. [Oops code removed by Dmitry Eremin-Solenikov] If possible this patch should be applied to the current -rc fixes branch. Signed-off-by: Stefan Schmidt <stefan@datenfreihafen.org> Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-25ipv6: Fix inet6_csk_bind_conflict()Eric Dumazet
Commit fda48a0d7a84 (tcp: bind() fix when many ports are bound) introduced a bug on IPV6 part. We should not call ipv6_addr_any(inet6_rcv_saddr(sk2)) but ipv6_addr_any(inet6_rcv_saddr(sk)) because sk2 can be IPV4, while sk is IPV6. Reported-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Tested-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-22tcp: bind() fix when many ports are boundEric Dumazet
Port autoselection done by kernel only works when number of bound sockets is under a threshold (typically 30000). When this threshold is over, we must check if there is a conflict before exiting first loop in inet_csk_get_port() Change inet_csk_bind_conflict() to forbid two reuse-enabled sockets to bind on same (address,port) tuple (with a non ANY address) Same change for inet6_csk_bind_conflict() Reported-by: Gaspar Chilingarov <gasparch@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-22rdma: potential ERR_PTR dereferenceDan Carpenter
In the original code, the "goto out" calls "rdma_destroy_id(cm_id);" That isn't needed here and would cause problems because "cm_id" is an ERR_PTR. The new code just returns directly. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-22rtnetlink: potential ERR_PTR dereferenceDan Carpenter
In the original code, if rtnl_create_link() returned an ERR_PTR then that would get passed to rtnl_configure_link() which dereferences it. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-22SUNRPC: Fix a bug in rpcauth_prune_expiredTrond Myklebust
Don't want to evict a credential if cred->cr_expire == jiffies, since that means that it was just placed on the cred_unused list. We therefore need to use time_in_range() rather than time_in_range_open(). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-04-21net: ipv6 bind to device issueJiri Olsa
The issue raises when having 2 NICs both assigned the same IPv6 global address. If a sender binds to a particular NIC (SO_BINDTODEVICE), the outgoing traffic is being sent via the first found. The bonded device is thus not taken into an account during the routing. From the ip6_route_output function: If the binding address is multicast, linklocal or loopback, the RT6_LOOKUP_F_IFACE bit is set, but not for global address. So binding global address will neglect SO_BINDTODEVICE-binded device, because the fib6_rule_lookup function path won't check for the flowi::oif field and take first route that fits. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Scott Otto <scott.otto@alcatel-lucent.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-21ipv6: allow to send packet after receiving ICMPv6 Too Big message with MTU ↵Shan Wei
field less than IPV6_MIN_MTU According to RFC2460, PMTU is set to the IPv6 Minimum Link MTU (1280) and a fragment header should always be included after a node receiving Too Big message reporting PMTU is less than the IPv6 Minimum Link MTU. After receiving a ICMPv6 Too Big message reporting PMTU is less than the IPv6 Minimum Link MTU, sctp *can't* send any data/control chunk that total length including IPv6 head and IPv6 extend head is less than IPV6_MIN_MTU(1280 bytes). The failure occured in p6_fragment(), about reason see following(take SHUTDOWN chunk for example): sctp_packet_transmit (SHUTDOWN chunk, len=16 byte) |------sctp_v6_xmit (local_df=0) |------ip6_xmit |------ip6_output (dst_allfrag is ture) |------ip6_fragment In ip6_fragment(), for local_df=0, drops the the packet and returns EMSGSIZE. The patch fixes it with adding check length of skb->len. In this case, Ipv6 not to fragment upper protocol data, just only add a fragment header before it. Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-21X25 fix dead unaccepted socketsandrew hendry
1, An X25 program binds and listens 2, calls arrive waiting to be accepted 3, Program exits without accepting 4, Sockets time out but don't get correctly cleaned up 5, cat /proc/net/x25/socket shows the dead sockets with bad inode fields. This line borrowed from AX25 sets the dying socket so the timers clean up later. Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-21xfrm6: ensure to use the same dev when building a bundleNicolas Dichtel
When building a bundle, we set dst.dev and rt6.rt6i_idev. We must ensure to set the same device for both fields. Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-21net: Fix an RCU warning in dev_pick_tx()David Howells
Fix the following RCU warning in dev_pick_tx(): =================================================== [ INFO: suspicious rcu_dereference_check() usage. ] --------------------------------------------------- net/core/dev.c:1993 invoked rcu_dereference_check() without protection! other info that might help us debug this: rcu_scheduler_active = 1, debug_locks = 0 2 locks held by swapper/0: #0: (&idev->mc_ifc_timer){+.-...}, at: [<ffffffff81039e65>] run_timer_softirq+0x17b/0x278 #1: (rcu_read_lock_bh){.+....}, at: [<ffffffff812ea3eb>] dev_queue_xmit+0x14e/0x4dc stack backtrace: Pid: 0, comm: swapper Not tainted 2.6.34-rc5-cachefs #4 Call Trace: <IRQ> [<ffffffff810516c4>] lockdep_rcu_dereference+0xaa/0xb2 [<ffffffff812ea4f6>] dev_queue_xmit+0x259/0x4dc [<ffffffff812ea3eb>] ? dev_queue_xmit+0x14e/0x4dc [<ffffffff81052324>] ? trace_hardirqs_on+0xd/0xf [<ffffffff81035362>] ? local_bh_enable_ip+0xbc/0xc1 [<ffffffff812f0954>] neigh_resolve_output+0x24b/0x27c [<ffffffff8134f673>] ip6_output_finish+0x7c/0xb4 [<ffffffff81350c34>] ip6_output2+0x256/0x261 [<ffffffff81052324>] ? trace_hardirqs_on+0xd/0xf [<ffffffff813517fb>] ip6_output+0xbbc/0xbcb [<ffffffff8135bc5d>] ? fib6_force_start_gc+0x2b/0x2d [<ffffffff81368acb>] mld_sendpack+0x273/0x39d [<ffffffff81368858>] ? mld_sendpack+0x0/0x39d [<ffffffff81052099>] ? mark_held_locks+0x52/0x70 [<ffffffff813692fc>] mld_ifc_timer_expire+0x24f/0x288 [<ffffffff81039ed6>] run_timer_softirq+0x1ec/0x278 [<ffffffff81039e65>] ? run_timer_softirq+0x17b/0x278 [<ffffffff813690ad>] ? mld_ifc_timer_expire+0x0/0x288 [<ffffffff81035531>] ? __do_softirq+0x69/0x140 [<ffffffff8103556a>] __do_softirq+0xa2/0x140 [<ffffffff81002e0c>] call_softirq+0x1c/0x28 [<ffffffff81004b54>] do_softirq+0x38/0x80 [<ffffffff81034f06>] irq_exit+0x45/0x47 [<ffffffff810177c3>] smp_apic_timer_interrupt+0x88/0x96 [<ffffffff810028d3>] apic_timer_interrupt+0x13/0x20 <EOI> [<ffffffff810488dd>] ? __atomic_notifier_call_chain+0x0/0x86 [<ffffffff810096bf>] ? mwait_idle+0x6e/0x78 [<ffffffff810096b6>] ? mwait_idle+0x65/0x78 [<ffffffff810011cb>] cpu_idle+0x4d/0x83 [<ffffffff81380b05>] rest_init+0xb9/0xc0 [<ffffffff81380a4c>] ? rest_init+0x0/0xc0 [<ffffffff8168dcf0>] start_kernel+0x392/0x39d [<ffffffff8168d2a3>] x86_64_start_reservations+0xb3/0xb7 [<ffffffff8168d38b>] x86_64_start_kernel+0xe4/0xeb An rcu_dereference() should be an rcu_dereference_bh(). Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-21Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
2010-04-21ipv6: Fix tcp_v6_send_response transport header setting.Herbert Xu
My recent patch to remove the open-coded checksum sequence in tcp_v6_send_response broke it as we did not set the transport header pointer on the new packet. Actually, there is code there trying to set the transport header properly, but it sets it for the wrong skb ('skb' instead of 'buff'). This bug was introduced by commit a8fdf2b331b38d61fb5f11f3aec4a4f9fb2dedcb ("ipv6: Fix tcp_v6_send_response(): it didn't set skb transport header") Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-20bridge: add a missing ntohs()Eric Dumazet
grec_nsrcs is in network order, we should convert to host horder in br_multicast_igmp3_report() Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-20Merge branch 'master' of ↵David S. Miller
2010-04-19mac80211: pass HT changes to driver when off channelReinette Chatre
Since "mac80211: make off-channel work generic" drivers have not been notified of configuration changes after association or authentication. This caused more dependence on current state to ensure driver will be notified when configuration changes occur. One such problem arises if off-channel is in progress when HT information changes. Since HT is only enabled on the "oper_channel" the driver will never be notified of this change. Usually the driver is notified soon after of a BSS information change (BSS_CHANGED_HT) ... but since the driver did not get a notification that this is a HT channel the new BSS information does not make sense. Fix this by also changing the off-channel information when HT is enabled and thus cause driver to be notified correctly. This fixes a problem in 4965 when associated with 5GHz 40MHz channel. Without this patch the system can associate but is unable to transfer any data, not even ping. See http://bugzilla.intellinuxwireless.org/show_bug.cgi?id=2158 Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-04-19mac80211: remove bogus TX agg state assignmentJohannes Berg
When the addba timer expires but has no work to do, it should not affect the state machine. If it does, TX will not see the successfully established and we can also crash trying to re-establish the session. Cc: stable@kernel.org [2.6.32, 2.6.33] Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-04-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: gigaset: include cleanup cleanup packet : remove init_net restriction WAN: flush tx_queue in hdlc_ppp to prevent panic on rmmod hw_driver. ip: Fix ip_dev_loopback_xmit() net: dev_pick_tx() fix fib: suppress lockdep-RCU false positive in FIB trie. tun: orphan an skb on tx forcedeth: fix tx limit2 flag check iwlwifi: work around bogus active chains detection
2010-04-16packet : remove init_net restrictionDaniel Lezcano
The af_packet protocol is used by Perl to do ioctls as reported by Stephane Riviere: "Net::RawIP relies on SIOCGIFADDR et SIOCGIFHWADDR to get the IP and MAC addresses of the network interface." But in a new network namespace these ioctl fail because it is disabled for a namespace different from the init_net_ns. These two lines should not be there as af_inet and af_packet are namespace aware since a long time now. I suppose we forget to remove these lines because we sent the af_packet first, before af_inet was supported. Signed-off-by: Daniel Lezcano <daniel.lezcano@free.fr> Reported-by: Stephane Riviere <stephane.riviere@regis-dgac.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-15ip: Fix ip_dev_loopback_xmit()Eric Dumazet
Eric Paris got following trace with a linux-next kernel [ 14.203970] BUG: using smp_processor_id() in preemptible [00000000] code: avahi-daemon/2093 [ 14.204025] caller is netif_rx+0xfa/0x110 [ 14.204035] Call Trace: [ 14.204064] [<ffffffff81278fe5>] debug_smp_processor_id+0x105/0x110 [ 14.204070] [<ffffffff8142163a>] netif_rx+0xfa/0x110 [ 14.204090] [<ffffffff8145b631>] ip_dev_loopback_xmit+0x71/0xa0 [ 14.204095] [<ffffffff8145b892>] ip_mc_output+0x192/0x2c0 [ 14.204099] [<ffffffff8145d610>] ip_local_out+0x20/0x30 [ 14.204105] [<ffffffff8145d8ad>] ip_push_pending_frames+0x28d/0x3d0 [ 14.204119] [<ffffffff8147f1cc>] udp_push_pending_frames+0x14c/0x400 [ 14.204125] [<ffffffff814803fc>] udp_sendmsg+0x39c/0x790 [ 14.204137] [<ffffffff814891d5>] inet_sendmsg+0x45/0x80 [ 14.204149] [<ffffffff8140af91>] sock_sendmsg+0xf1/0x110 [ 14.204189] [<ffffffff8140dc6c>] sys_sendmsg+0x20c/0x380 [ 14.204233] [<ffffffff8100ad82>] system_call_fastpath+0x16/0x1b While current linux-2.6 kernel doesnt emit this warning, bug is latent and might cause unexpected failures. ip_dev_loopback_xmit() runs in process context, preemption enabled, so must call netif_rx_ni() instead of netif_rx(), to make sure that we process pending software interrupt. Same change for ip6_dev_loopback_xmit() Reported-by: Eric Paris <eparis@redhat.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-15net: dev_pick_tx() fixEric Dumazet
When dev_pick_tx() caches tx queue_index on a socket, we must check socket dst_entry matches skb one, or risk a crash later, as reported by Denys Fedorysychenko, if old packets are in flight during a route change, involving devices with different number of queues. Bug introduced by commit a4ee3ce3 (net: Use sk_tx_queue_mapping for connected sockets) Reported-by: Denys Fedorysychenko <nuclearcat@nuclearcat.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-14fib: suppress lockdep-RCU false positive in FIB trie.Eric Dumazet
Followup of commit 634a4b20 Allow tnode_get_child_rcu() to be called either under rcu_read_lock() protection or with RTNL held. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (25 commits) smc91c92_cs: define multicast_table as unsigned char can: avoids a false warning e1000e: stop cleaning when we reach tx_ring->next_to_use igb: restrict WoL for 82576 ET2 Quad Port Server Adapter virtio_net: missing sg_init_table Revert "tcp: Set CHECKSUM_UNNECESSARY in tcp_init_nondata_skb" iwlwifi: need check for valid qos packet before free tcp: Set CHECKSUM_UNNECESSARY in tcp_init_nondata_skb udp: fix for unicast RX path optimization myri10ge: fix rx_pause in myri10ge_set_pauseparam net: corrected documentation for hardware time stamping stmmac: use resource_size() x.25 attempts to negotiate invalid throughput x25: Patch to fix bug 15678 - x25 accesses fields beyond end of packet. bridge: Fix IGMP3 report parsing cnic: Fix crash during bnx2x MTU change. qlcnic: fix set mac addr r6040: fix r6040_multicast_list vhost-net: fix vq_memory_access_ok error checking ath9k: fix double calls to ath_radio_enable ...
2010-04-13can: avoids a false warningEric Dumazet
At this point optlen == sizeof(sfilter) but some compilers are dumb. Reported-by: Németh Márton <nm127@freemail.h Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Oliver Hartkopp <oliver@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-12Merge branch 'for-2.6.34' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.34' of git://linux-nfs.org/~bfields/linux: svcrdma: RDMA support not yet compatible with RPC6
2010-04-11Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
