A couple of small cleanups for patches:
[net-next-2.6 PATCH 1/3] dcbnl: add support for ieee8021Qaz attributes
[net-next-2.6 PATCH 2/3] dcbnl: add appliction tlv handlers
[net-next-2.6 PATCH 3/3] net_dcb: add application notifiers
Signed-off-by: Shmulik Ravid <shmulikr@broadcom.com>
Adding a pair of set-get routines to dcbnl for setting the negotiation
flags of the various DCB features. Conforms to the CEE flavor of DCBX
The user sets these flags (enable, advertise, willing) for each feature
to be used by the DCBX engine. The 'get' routine returns which of the
features is enabled after the negotiation.
This patch is dependent on the following patches:
Adding an optional DCBX capability and a pair for get-set routines for
setting the device DCBX mode. The DCBX capability is a bit field of
supported attributes. The user is expected to set the DCBX mode with a
subset of the advertised attributes.
Acked-by: John Fastabend <john.r.fastabend@intel.com>
DCBx applications priorities can be changed dynamically. If
application stacks are expected to keep the skb priority
consistent with the dcbx priority the stack will need to
be notified when these changes occur.
This patch adds application notifiers for the stack to register
with.
Signed-off-by: John Fastabend <john.r.fastabend@intel.com>
This patch adds application tlv handlers. Networking stacks
may use the application priority to set the skb priority of
their stack using the negoatiated dcbx priority.
This patch provides the dcb_{get|set}app() routines for the
stack to query these parameters. Notice lower layer drivers
can use the dcbnl_ops routines if additional handling is
needed. Perhaps in the firmware case for example
The IEEE8021Qaz is the IEEE standard version of CEE. The
standard has had enough significant changes from the CEE
version that many of the CEE attributes have no meaning
in the new spec or do not easily map to IEEE standards.
Rather then attempt to create a complicated mapping
between CEE and IEEE standards this patch adds a nested
IEEE attribute to the list of DCB attributes. The policy
is,
[DCB_ATTR_IFNAME]
[DCB_ATTR_STATE]
[DCB_ATTR_IEEE]
[DCB_ATTR_IEEE_ETS]
[DCB_ATTR_IEEE_PFC]
[DCB_ATTR_IEEE_APP_TABLE]
[DCB_ATTR_IEEE_APP]
The following dcbnl_rtnl_ops routines were added to handle
the IEEE standard,
int (*ieee_getets) (struct net_device *, struct ieee_ets *);
int (*ieee_setets) (struct net_device *, struct ieee_ets *);
int (*ieee_getpfc) (struct net_device *, struct ieee_pfc *);
int (*ieee_setpfc) (struct net_device *, struct ieee_pfc *);
int (*ieee_getapp) (struct net_device *, struct dcb_app *);
int (*ieee_setapp) (struct net_device *, struct dcb_app *);
net/ipv4/fib_frontend.c
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (42 commits)
ipv4: dont create routes on down devices
epic100: hamachi: yellowfin: Fix skb allocation size
sundance: Fix oopses with corrupted skb_shared_info
Revert "ipv4: Allow configuring subnets as local addresses"
USB: mcs7830: return negative if auto negotiate fails
irda: prevent integer underflow in IRLMP_ENUMDEVICES
tcp: fix listening_get_next()
atl1c: Do not use legacy PCI power management
mac80211: fix mesh forwarding
MAINTAINERS: email address change
net: Fix range checks in tcf_valid_offset().
net_sched: sch_sfq: fix allot handling
hostap: remove netif_stop_queue from init
mac80211/rt2x00: add ieee80211_tx_status_ni()
typhoon: memory corruption in typhoon_get_drvinfo()
net: Add USB PID for new MOSCHIP USB ethernet controller MCS7832 variant
net_sched: always clone skbs
ipv6: Fragment locally generated tunnel-mode IPSec6 packets as needed.
netlink: fix gcc -Wconversion compilation warning
asix: add USB ID for Logitec LAN-GTJ U2A
In ip_route_output_slow(), instead of allowing a route to be created on
a not UPed device, report -ENETUNREACH immediately.
# ip tunnel add mode ipip remote 10.16.0.164 local
10.16.0.72 dev eth0
# (Note : tunl1 is down)
# ping -I tunl1 10.1.2.3
PING 10.1.2.3 (10.1.2.3) from 192.168.18.5 tunl1: 56(84) bytes of data.
(nothing)
# ./a.out tunl1
# ip tunnel del tunl1
Message from syslogd@shelby at Dec 22 10:12:08 ...
kernel: unregister_netdevice: waiting for tunl1 to become free.
Usage count = 3
After patch:
connect: Network is unreachable
Reported-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Reviewed-by: Octavian Purdila <opurdila@ixiacom.com>
This reverts commit 4465b469008bc03b98a1b8df4e9ae501b6c69d4b.
As reported by Ben Greear, this causes regressions:
> Change 4465b469008bc03b98a1b8df4e9ae501b6c69d4b caused rules
> to stop matching the input device properly because the
> FLOWI_FLAG_MATCH_ANY_IIF is always defined in ip_dev_find().
> This breaks rules such as:
> ip rule add pref 512 lookup local
> ip rule del pref 0 lookup local
> ip link set eth2 up
> ip -4 addr add 172.16.0.102/24 broadcast 172.16.0.255 dev eth2
> ip rule add to 172.16.0.102 iif eth2 lookup local pref 10
> ip rule add iif eth2 lookup 10001 pref 20
> ip route add 172.16.0.0/24 dev eth2 table 10001
> ip route add unreachable 0/0 table 10001
> If you had a second interface 'eth0' that was on a different
> subnet, pinging a system on that interface would fail:
> [root@ct503-60 ~]# ping 192.168.100.1
> connect: Invalid argument
Reported-by: Ben Greear <greearb@candelatech.com>
ssh://master.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
If the user-provided len is less than the expected offset, the
IRLMP_ENUMDEVICES getsockopt will do a copy_to_user() with a very large
size value. While this isn't be a security issue on x86 because it will
get caught by the access_ok() check, it may leak large amounts of kernel
heap on other architectures. In any event, this patch fixes it.
Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com>
Commit 86bcebafc5e7f5 ("tcp: fix >2 iw selection") fixed a case
when congestion window initialization has been mistakenly omitted
by introducing cwnd label and putting backwards goto from the
end of the function.
This makes the code unnecessarily tricky to read and understand
on a first sight.
Shuffle the code around a little bit to make it more obvious.
Alexey Vlasov found /proc/net/tcp could sometime loop and display
millions of sockets in LISTEN state.
In 2.6.29, when we converted TCP hash tables to RCU, we left two
sk_next() calls in listening_get_next().
We must instead use sk_nulls_next() to properly detect an end of chain.
Reported-by: Alexey Vlasov <renton@renton.name>
ssh://master.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6
sfq_walk() runs without qdisc lock. By the time it selects a non empty
hash slot and sfq_dump_class_stats() is run (with lock held), slot might
have been freed : We then access q->slots[SFQ_EMPTY_SLOT], out of
bounds, and crash in slot_queue_walk()
On previous kernels, bug is here but out of bounds qs[SFQ_DEPTH] and
allot[SFQ_DEPTH] are located in struct sfq_sched_data, so no illegal
memory access happens, only possibly wrong data reported to user.
Also, slot_dequeue_tail() should make sure slot skb chain is correctly
terminated, or sfq_dump_class_stats() can access freed skbs.
If CONFIG_MAC80211_LEDS is not set, ieee80211_i.h was failing to compile,
because struct led_trigger is only declared when CONFIG_LEDS_TRIGGERS is
set.
This patch adds ifdefs around the tpt_led_trigger declaration in
ieee80211_i.h to avoid the problem.
Signed-off-by: Luciano Coelho <luciano.coelho@nokia.com>
Acked-by: Johannes Berg <johannes@sipsolutions.net>
The throughput LED trigger was always active when
the radio was enabled. In most cases that's likely
the desired behaviour, but iwlwifi requires it to
be only active when one of the virtual interfaces
is actually "connected" in some way.
iwlwifi and other drivers like to blink their LED
based on throughput. Implement this generically in
mac80211, based on a throughput table the driver
specifies. That way, drivers can set the blink
frequencies depending on their desired behaviour
and max throughput.
All the drivers need to do is provide an LED class
device, best with blink hardware offload.
The throughput trigger will require doing LED
classdev/trigger handling before register_hw(),
so drivers should have access to the trigger
names before it. If trigger registration fails,
this will still make the trigger name available,
but that's not a big problem since the default
trigger will the simply not be found.
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
drivers/net/wireless/iwlwifi/iwl-1000.c
drivers/net/wireless/iwlwifi/iwl-6000.c
drivers/net/wireless/iwlwifi/iwl-core.h
Under memory pressure, the mac80211 mesh code
may helpfully print a message that it failed
to clone a mesh frame and then will proceed
to crash trying to use it anyway. Fix that.
Cc: stable@kernel.org [2.6.27+]
Acked-by: Javier Cardona <javier@cozybit.com>
We can translate pseudo load instructions at filter check time to
dedicated instructions to speed up filtering and avoid one switch().
libpcap currently uses SKF_AD_PROTOCOL, but custom filters probably use
other ancillary accesses.
Note : I made the assertion that ancillary data was always accessed with
BPF_LD|BPF_?|BPF_ABS instructions, not with BPF_LD|BPF_?|BPF_IND ones
(offset given by K constant, not by K + X register)
On x86_64, this saves a few bytes of text :
# size net/core/filter.o.*
4864 0 0 4864 1300 net/core/filter.o.new
4944 0 0 4944 1350 net/core/filter.o.old
Le vendredi 17 décembre 2010 à 10:26 +0100, Eric Dumazet a écrit :
> I think we can add this after latest Changli patch :
> He does one skb_clone() before calling the sniffers.
> We could set timestamp on this clone, instead of original skb.
> Problem solved.
[PATCH net-next-2.6] net: timestamp cloned packet in dev_queue_xmit_nit
Now we do one clone of skb if at least one sniffer might take packet,
we also can do the skb timestamping on the clone and let original packet
unchanged.
This is a generalization of commit 8caf153974f2 (net: sch_netem: Fix an
inconsistency in ingress netem timestamps.)
This way, we can have a good idea when packets are delivered to our
stack (tcpdump -i ifb0), while a tcpdump on original device gives
timestamps right before ingressing.
This also speedup our stack, avoiding taking timestamps if not needed.
Cc: Changli Gao <xiaosuo@gmail.com>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Jarek Poplawski <jarkao2@gmail.com>
Acked-by: Changli Gao <xiaosuo@gmail.com>
This patch changes the default initial receive window to 10 mss
(defined constant). The default window is limited to the maximum
of 10*1460 and 2*mss (when mss > 1460).
draft-ietf-tcpm-initcwnd-00 is a proposal to the IETF that recommends
increasing TCP's initial congestion window to 10 mss or about 15KB.
Leading up to this proposal were several large-scale live Internet
experiments with an initial congestion window of 10 mss (IW10), where
we showed that the average latency of HTTP responses improved by
approximately 10%. This was accompanied by a slight increase in
retransmission rate (0.5%), most of which is coming from applications
opening multiple simultaneous connections. To understand the extreme
worst case scenarios, and fairness issues (IW10 versus IW3), we further
conducted controlled testbed experiments. We came away finding minimal
negative impact even under low link bandwidths (dial-ups) and small
buffers. These results are extremely encouraging to adopting IW10.
However, an initial congestion window of 10 mss is useless unless a TCP
receiver advertises an initial receive window of at least 10 mss.
Fortunately, in the large-scale Internet experiments we found that most
widely used operating systems advertised large initial receive windows
of 64KB, allowing us to experiment with a wide range of initial
congestion windows. Linux systems were among the few exceptions that
advertised a small receive window of 6KB. The purpose of this patch is
to fix this shortcoming.
References:
1. A comprehensive list of all IW10 references to date.
http://code.google.com/speed/protocols/tcpm-IW10.html
2. Paper describing results from large-scale Internet experiments with IW10.
http://ccr.sigcomm.org/drupal/?q=node/621
3. Controlled testbed experiments under worst case scenarios and a
fairness study.
http://www.ietf.org/proceedings/79/slides/tcpm-0.pdf
4. Raw test data from testbed experiments (Linux senders/receivers)
with initial congestion and receive windows of both 10 mss.
http://research.csc.ncsu.edu/netsrv/?q=content/iw10
5. Internet-Draft. Increasing TCP's Initial Window.
https://datatracker.ietf.org/doc/draft-ietf-tcpm-initcwnd/
Signed-off-by: Nandita Dukkipati <nanditad@google.com>
Here is a respin of patch.
I'll send a short patch to make SFQ more fair in presence of large
packets as well.
[PATCH v3 net-next-2.6] net_sched: sch_sfq: better struct layouts
This patch shrinks sizeof(struct sfq_sched_data)
from 0x14f8 (or more if spinlocks are bigger) to 0x1180 bytes, and
reduce text size as well.
4821 152 0 4973 136d old/net/sched/sch_sfq.o
4627 136 0 4763 129b new/net/sched/sch_sfq.o
All data for a slot/flow is now grouped in a compact and cache friendly
structure, instead of being spreaded in many different points.
struct sfq_slot {
struct sk_buff *skblist_next;
struct sk_buff *skblist_prev;
sfq_index qlen; /* number of skbs in skblist */
sfq_index next; /* next slot in sfq chain */
struct sfq_head dep; /* anchor in dep[] chains */
unsigned short hash; /* hash value (index in ht[]) */
short allot; /* credit for this slot */
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client:
ceph: handle partial result from get_user_pages
ceph: mark user pages dirty on direct-io reads
ceph: fix null pointer dereference in ceph_init_dentry for nfs reexport
ceph: fix direct-io on non-page-aligned buffers
ceph: fix msgr_init error path
When deploying SFQ/IFB here at work, I found the allot management was
pretty wrong in sfq, even changing allot from short to int...
We should init allot for each new flow, not using a previous value found
in slot.
Before patch, I saw bursts of several packets per flow, apparently
denying the default "quantum 1514" limit I had on my SFQ class.
class sfq 11:1 parent 11:
(dropped 0, overlimits 0 requeues 0)
backlog 0b 7p requeues 0
allot 11546
class sfq 11:46 parent 11:
backlog 0b 1p requeues 0
allot -23873
class sfq 11:78 parent 11:
backlog 0b 5p requeues 0
allot 11393
After patch, better fairness among each flow, allot limit being
respected, allot is positive :
class sfq 11:e parent 11:
(dropped 0, overlimits 0 requeues 86)
backlog 0b 3p requeues 86
allot 596
class sfq 11:94 parent 11:
backlog 0b 3p requeues 0
allot 1468
class sfq 11:a4 parent 11:
backlog 0b 4p requeues 0
allot 650
class sfq 11:bb parent 11:
allot 596
We currently return for each active SFQ slot the number of packets in
queue. We can also give number of bytes accounted for these packets.
tc -s class show dev ifb0
Before patch :
class sfq 11:3d9 parent 11:
allot 1266
After patch :
class sfq 11:3e4 parent 11:
backlog 4380b 3p requeues 0
allot 1212
When an skb is shared, it needs to be duplicated, along with its data buffer.
If the skb does not have enough headroom, using skb_copy might cause the data
buffer to be copied twice (once by skb_copy and once by pskb_expand_head).
Fix this by using skb_clone initially and letting ieee80211_skb_resize sort
out the rest.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
If the skb is not cloned and we don't need any extra headroom, there
is no point in reallocating the skb head.
The change 'mac80211: Fix BUG in pskb_expand_head when transmitting shared skbs'
added a check for copying the skb if it's shared, however the tx info variable
still points at the cb of the old skb
Acked-by: Helmut Schaa <helmut.schaa@googlemail.com>
The Mesh Control header only includes 0, 1 or 2 addresses. If there is
one address, it should be interpreted as Address 4. If there are 2,
they are interpreted as Addresses 5 and 6 (Address 4 being the 4th
address in the 802.11 header).
The address extension used to hold up to 3 addresses instead of the current 2.
I'm not sure which draft version changed this, but it is very unlikely that it
will change again given the state of the approval process of this draft. See
section 7.1.3.6.3 in current draft (8.0).
Also, note that the extra address that I'm removing was not being used, so this
change has no effect on over-the-air frame formats. But I thought I better
remove it before someone does start using it.
Signed-off-by: Javier Cardona <javier@cozybit.com>
Export the information which antennas are available for configuration as TX or
RX antennas via nl80211.
Signed-off-by: Bruno Randolf <br1@einfach.org>
As has been pointed out by Daniel Halperin some devices (e.g. Intel IWL5100)
can only TX from a subset of RX antennas, so use separate availability masks
for RX and TX.
Let path selection frames for protocols other than HWMP be sent to
userspace via NL80211_CMD_REGISTER_FRAME. Also allow userspace to send
and receive mesh path selection frames.
Userspace will now be allowed to toggle between the default path
selection algorithm (HWMP, implemented in the kernel), and a vendor
specific alternative. Also in the same patch, allow userspace to add
information elements to mesh beacons. This is accordance with the
Extensible Path Selection Framework specified in version 7.0 of the
802.11s draft.
Mesh parameters can be to setup a mesh or to configure it.
This patch renames the ambiguous name mesh_params to mesh_config
in preparation for mesh_setup.
Flush the routing cache only of entries that match the
network namespace in which the purge event occurred.
hna_local_fill_buffer must return the number of added hna entries and
not the last checked hash bucket.
Signed-off-by: Sven Eckelmann <sven@narfation.org>
Remove "pktgen: " prefix string from one pr_info.
pr_fmt adds it, so this is a duplicate.
These macros never be used, so remove them.
Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com>
In dev_queue_xmit_nit(), we have to clone skbs as we need to mangle skbs,
however, we don't need to clone skbs for all the packet_types.
Except for the first packet_type, we increase skb->users instead of
skb_clone().
Signed-off-by: Changli Gao <xiaosuo@gmail.com>
This patch modifies IPsec6 to fragment IPv6 packets that are
locally generated as needed.
This version of the patch only fragments in tunnel mode, so that fragment
headers will not be obscured by ESP in transport mode.
Signed-off-by: David L Stevens <dlstevens@us.ibm.com>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
When device is being set to down, neigh_ifdown was being called
twice. Once from addrconf notifier and once from ndisc notifier.
Remove (unnecessary) casts to make code cleaner.
drivers/net/bnx2x/bnx2x.h
drivers/vhost/vhost.c
The get_user_pages() helper can return fewer than the requested pages.
Error out in that case, and clean up the partial result.
Signed-off-by: Henry C Chang <henry_c_chang@tcloudcomputing.com>
Signed-off-by: Sage Weil <sage@newdream.net>
For read operation, we have to set the argument _write_ of get_user_pages
to 1 since we will write data to pages. Also, we need to SetPageDirty before
releasing these pages.
