path: root/net
2011-08-11ipv4: some rt_iif -> rt_route_iif conversionsJulian Anastasov
As rt_iif represents input device even for packets coming from loopback with output route, it is not an unique key specific to input routes. Now rt_route_iif has such role, it was fl.iif in 2.6.38, so better to change the checks at some places to save CPU cycles and to restore 2.6.38 semantics. compare_keys: - input routes: only rt_route_iif matters, rt_iif is same - output routes: only rt_oif matters, rt_iif is not used for matching in __ip_route_output_key - now we are back to 2.6.38 state ip_route_input_common: - matching rt_route_iif implies input route - compared to 2.6.38 we eliminated one rth->fl.oif check because it was not needed even for 2.6.38 compare_hash_inputs: Only the change here is not an optimization, it has effect only for output routes. I assume I'm restoring the original intention to ignore oif, it was using fl.iif - now we are back to 2.6.38 state Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-11net/bridge/netfilter/ebtables.c: use available error handling codeJulia Lawall
Free the locally allocated table and newinfo as done in adjacent error handling code. Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-11net/netlabel/netlabel_kapi.c: add missing cleanup codeJulia Lawall
Call cipso_v4_doi_putdef in the case of the failure of the allocation of entry. Reverse the order of the error handling code at the end of the function and insert more labels in order to reduce the number of unnecessary calls to kfree. Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-11scm: Capture the full credentials of the scm senderTim Chen
This patch corrects an erroneous update of credential's gid with uid introduced in commit 257b5358b32f17 since 2.6.36. Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Reviewed-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-10tcp: initialize variable ecn_ok in syncookies pathMike Waychison
Using a gcc 4.4.3, warnings are emitted for a possibly uninitialized use of ecn_ok. This can happen if cookie_check_timestamp() returns due to not having seen a timestamp. Defaulting to ecn off seems like a reasonable thing to do in this case, so initialized ecn_ok to false. Signed-off-by: Mike Waychison <mikew@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-09net_sched: prio: use qdisc_dequeue_peekedFlorian Westphal
commit 07bd8df5df4369487812bf85a237322ff3569b77 (sch_sfq: fix peek() implementation) changed sfq to use generic peek helper. This makes HFSC complain about a non-work-conserving child qdisc, if prio with sfq child is used within hfsc: hfsc peeks into prio qdisc, which will then peek into sfq. returned skb is stashed in sch->gso_skb. Next, hfsc tries to dequeue from prio, but prio will call sfq dequeue directly, which may return NULL instead of previously peeked-at skb. Have prio call qdisc_dequeue_peeked, so sfq->dequeue() is not called in this case. Cc: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-09Bridge: Always send NETDEV_CHANGEADDR up on br MAC change.Andrei Warkentin
This ensures the neighbor entries associated with the bridge dev are flushed, also invalidating the associated cached L2 headers. This means we br_add_if/br_del_if ports to implement hand-over and not wind up with bridge packets going out with stale MAC. This means we can also change MAC of port device and also not wind up with bridge packets going out with stale MAC. This builds on Stephen Hemminger's patch, also handling the br_del_if case and the port MAC change case. Cc: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Andrei Warkentin <andreiw@motorola.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-07ipv4: use dst with ref during bcast/mcast loopbackJulian Anastasov
Make sure skb dst has reference when moving to another context. Currently, I don't see protocols that can hit it when sending broadcasts/multicasts to loopback using noref dsts, so it is just a precaution. Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-07ipv4: route non-local sources for raw socketJulian Anastasov
The raw sockets can provide source address for routing but their privileges are not considered. We can provide non-local source address, make sure the FLOWI_FLAG_ANYSRC flag is set if socket has privileges for this, i.e. based on hdrincl (IP_HDRINCL) and transparent flags. Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-07netfilter: TCP and raw fix for ip_route_me_harderJulian Anastasov
TCP in some cases uses different global (raw) socket to send RST and ACK. The transparent flag is not set there. Currently, it is a problem for rerouting after the previous change. Fix it by simplifying the checks in ip_route_me_harder and use FLOWI_FLAG_ANYSRC even for sockets. It looks safe because the initial routing allowed this source address to be used and now we just have to make sure the packet is rerouted. As a side effect this also allows rerouting for normal raw sockets that use spoofed source addresses which was not possible even before we eliminated the ip_route_input call. Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-07ipv4: Fix ip_getsockopt for IP_PKTOPTIONSDaniel Baluta
IP_PKTOPTIONS is broken for 32-bit applications running in COMPAT mode on 64-bit kernels. This happens because msghdr's msg_flags field is always set to zero. When running in COMPAT mode this should be set to MSG_CMSG_COMPAT instead. Signed-off-by: Tiberiu Szocs-Mihai <tszocs@ixiacom.com> Signed-off-by: Daniel Baluta <dbaluta@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-07ipv4: fix the reusing of routing cache entriesJulian Anastasov
compare_keys and ip_route_input_common rely on rt_oif for distinguishing of input and output routes with same keys values. But sometimes the input route has also same hash chain (keyed by iif != 0) with the output routes (keyed by orig_oif=0). Problem visible if running with small number of rhash_entries. Fix them to use rt_route_iif instead. By this way input route can not be returned to users that request output route. The patch fixes the ip_rt_bug errors that were reported in ip_local_out context, mostly for 255.255.255.255 destinations. Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-07netfilter: avoid double free in nf_reinjectJulian Anastasov
NF_STOLEN means skb was already freed Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-06net: Compute protocol sequence numbers and fragment IDs using MD5.David S. Miller
Computers have become a lot faster since we compromised on the partial MD4 hash which we use currently for performance reasons. MD5 is a much safer choice, and is inline with both RFC1948 and other ISS generators (OpenBSD, Solaris, etc.) Furthermore, only having 24-bits of the sequence number be truly unpredictable is a very serious limitation. So the periodic regeneration and 8-bit counter have been removed. We compute and use a full 32-bit sequence number. For ipv6, DCCP was found to use a 32-bit truncated initial sequence number (it needs 43-bits) and that is fixed here as well. Reported-by: Dan Kaminsky <dan@doxpara.com> Tested-by: Willy Tarreau <w@1wt.eu> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-05ipv6: check for IPv4 mapped addresses when connecting IPv6 socketsMax Matveev
When support for binding to 'mapped INADDR_ANY (::ffff.0.0.0.0)' was added in 0f8d3c7ac3693d7b6c731bf2159273a59bf70e12 the rest of the code wasn't told so now it's possible to bind IPv6 datagram socket to ::ffff.0.0.0.0, connect it to another IPv4 address and it will all work except for getsockhame() which does not return the local address as expected. To give getsockname() something to work with check for 'mapped INADDR_ANY' when connecting and update the in-core source addresses appropriately. Signed-off-by: Max Matveev <makc@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-05net: Fix security_socket_sendmsg() bypass problem.Tetsuo Handa
The sendmmsg() introduced by commit 228e548e "net: Add sendmmsg socket system call" is capable of sending to multiple different destination addresses. SMACK is using destination's address for checking sendmsg() permission. However, security_socket_sendmsg() is called for only once even if multiple different destination addresses are passed to sendmmsg(). Therefore, we need to call security_socket_sendmsg() for each destination address rather than only the first destination address. Since calling security_socket_sendmsg() every time when only single destination address was passed to sendmmsg() is a waste of time, omit calling security_socket_sendmsg() unless destination address of previous datagram and that of current datagram differs. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Acked-by: Anton Blanchard <anton@samba.org> Cc: stable <stable@kernel.org> [3.0+] Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-05net: Cap number of elements for sendmmsgAnton Blanchard
To limit the amount of time we can spend in sendmmsg, cap the number of elements to UIO_MAXIOV (currently 1024). For error handling an application using sendmmsg needs to retry at the first unsent message, so capping is simpler and requires less application logic than returning EINVAL. Signed-off-by: Anton Blanchard <anton@samba.org> Cc: stable <stable@kernel.org> [3.0+] Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-05net: sendmmsg should only return an error if no messages were sentAnton Blanchard
sendmmsg uses a similar error return strategy as recvmmsg but it turns out to be a confusing way to communicate errors. The current code stores the error code away and returns it on the next sendmmsg call. This means a call with completely valid arguments could get an error from a previous call. Change things so we only return an error if no datagrams could be sent. If less than the requested number of messages were sent, the application must retry starting at the first failed one and if the problem is persistent the error will be returned. This matches the behaviour of other syscalls like read/write - it is not an error if less than the requested number of elements are sent. Signed-off-by: Anton Blanchard <anton@samba.org> Cc: stable <stable@kernel.org> [3.0+] Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-03Merge branch 'for-davem' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless
2011-08-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next ↵John W. Linville
into for-davem
2011-08-03net: fix NULL dereferences in check_peer_redir()Eric Dumazet
Gergely Kalman reported crashes in check_peer_redir(). It appears commit f39925dbde778 (ipv4: Cache learned redirect information in inetpeer.) added a race, leading to possible NULL ptr dereference. Since we can now change dst neighbour, we should make sure a reader can safely use a neighbour. Add RCU protection to dst neighbour, and make sure check_peer_redir() can be called safely by different cpus in parallel. As neighbours are already freed after one RCU grace period, this patch should not add typical RCU penalty (cache cold effects) Many thanks to Gergely for providing a pretty report pointing to the bug. Reported-by: Gergely Kalman <synapse@hippy.csoma.elte.hu> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-01net: add kerneldoc to skb_copy_bits()Eric Dumazet
Since skb_copy_bits() is called from assembly, add a fat comment to make clear we should think twice before changing its prototype. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-01doc: Update the email address for Paul Moore in various source filesPaul Moore
My @hp.com will no longer be valid starting August 5, 2011 so an update is necessary. My new email address is employer independent so we don't have to worry about doing this again any time soon. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: Paul Moore <paul@paul-moore.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-01atm: br2864: sent packets truncated in VC routed modeChas Williams
Reported-by: Pascal Hambourg <pascal@plouf.fr.eu.org> Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-01cfg80211: off by one in nl80211_trigger_scan()Dan Carpenter
The test is off by one so we'd read past the end of the wiphy->bands[] array on the next line. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-01sch_sfq: fix sfq_enqueue()Eric Dumazet
commit 8efa88540635 (sch_sfq: avoid giving spurious NET_XMIT_CN signals) forgot to call qdisc_tree_decrease_qlen() to signal upper levels that a packet (from another flow) was dropped, leading to various problems. With help from Michal Soltys and Michal Pokrywka, who did a bisection. Bugzilla ref: https://bugzilla.kernel.org/show_bug.cgi?id=39372 Debian ref: http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=631945 Reported-by: Lucas Bocchi <lucas.bocchi@gmail.com> Reported-and-bisected-by: Michal Pokrywka <wolfmoon@o2.pl> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Michal Soltys <soltys@ziu.info> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-01net: adjust array indexJulia Lawall
Convert array index from the loop bound to the loop index. A simplified version of the semantic patch that fixes this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression e1,e2,ar; @@ for(e1 = 0; e1 < e2; e1++) { <... ar[ - e2 + e1 ] ...> } // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-28Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/horms/ipvs-2.6
2011-07-28net: fix new sunrpc kernel-doc warningRandy Dunlap
Fix new kernel-doc warning in sunrpc: Warning(net/sunrpc/xprt.c:196): No description found for parameter 'xprt' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-28xfrm: Fix key lengths for rfc3686(ctr(aes))Tushar Gohad
Fix the min and max bit lengths for AES-CTR (RFC3686) keys. The number of bits in key spec is the key length (128/256) plus 32 bits of nonce. This change takes care of the "Invalid key length" errors reported by setkey when specifying 288 bit keys for aes-ctr. Signed-off-by: Tushar Gohad <tgohad@mvista.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (32 commits) tg3: Remove 5719 jumbo frames and TSO blocks tg3: Break larger frags into 4k chunks for 5719 tg3: Add tx BD budgeting code tg3: Consolidate code that calls tg3_tx_set_bd() tg3: Add partial fragment unmapping code tg3: Generalize tg3_skb_error_unmap() tg3: Remove short DMA check for 1st fragment tg3: Simplify tx bd assignments tg3: Reintroduce tg3_tx_ring_info ASIX: Use only 11 bits of header for data size ASIX: Simplify condition in rx_fixup() Fix cdc-phonet build bonding: reduce noise during init bonding: fix string comparison errors net: Audit drivers to identify those needing IFF_TX_SKB_SHARING cleared net: add IFF_SKB_TX_SHARED flag to priv_flags net: sock_sendmsg_nosec() is static forcedeth: fix vlans gianfar: fix bug caused by 87c288c6e9aa31720b72e2bc2d665e24e1653c3e gro: Only reset frag0 when skb can be pulled ...
2011-07-27net: Audit drivers to identify those needing IFF_TX_SKB_SHARING clearedNeil Horman
After the last patch, We are left in a state in which only drivers calling ether_setup have IFF_TX_SKB_SHARING set (we assume that drivers touching real hardware call ether_setup for their net_devices and don't hold any state in their skbs. There are a handful of drivers that violate this assumption of course, and need to be fixed up. This patch identifies those drivers, and marks them as not being able to support the safe transmission of skbs by clearning the IFF_TX_SKB_SHARING flag in priv_flags Signed-off-by: Neil Horman <nhorman@tuxdriver.com> CC: Karsten Keil <isdn@linux-pingi.de> CC: "David S. Miller" <davem@davemloft.net> CC: Jay Vosburgh <fubar@us.ibm.com> CC: Andy Gospodarek <andy@greyhouse.net> CC: Patrick McHardy <kaber@trash.net> CC: Krzysztof Halasa <khc@pm.waw.pl> CC: "John W. Linville" <linville@tuxdriver.com> CC: Greg Kroah-Hartman <gregkh@suse.de> CC: Marcel Holtmann <marcel@holtmann.org> CC: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-27net: add IFF_SKB_TX_SHARED flag to priv_flagsNeil Horman
Pktgen attempts to transmit shared skbs to net devices, which can't be used by some drivers as they keep state information in skbs. This patch adds a flag marking drivers as being able to handle shared skbs in their tx path. Drivers are defaulted to being unable to do so, but calling ether_setup enables this flag, as 90% of the drivers calling ether_setup touch real hardware and can handle shared skbs. A subsequent patch will audit drivers to ensure that the flag is set properly Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Reported-by: Jiri Pirko <jpirko@redhat.com> CC: Robert Olsson <robert.olsson@its.uu.se> CC: Eric Dumazet <eric.dumazet@gmail.com> CC: Alexey Dobriyan <adobriyan@gmail.com> CC: David S. Miller <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-27net: sock_sendmsg_nosec() is staticEric Dumazet
Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Anton Blanchard <anton@samba.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-27Merge branch 'for-davem' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
2011-07-27Merge branch 'nfs-for-3.1' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
* 'nfs-for-3.1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (44 commits) NFSv4: Don't use the delegation->inode in nfs_mark_return_delegation() nfs: don't use d_move in nfs_async_rename_done RDMA: Increasing RPCRDMA_MAX_DATA_SEGS SUNRPC: Replace xprt->resend and xprt->sending with a priority queue SUNRPC: Allow caller of rpc_sleep_on() to select priority levels SUNRPC: Support dynamic slot allocation for TCP connections SUNRPC: Clean up the slot table allocation SUNRPC: Initalise the struct xprt upon allocation SUNRPC: Ensure that we grab the XPRT_LOCK before calling xprt_alloc_slot pnfs: simplify pnfs files module autoloading nfs: document nfsv4 sillyrename issues NFS: Convert nfs4_set_ds_client to EXPORT_SYMBOL_GPL SUNRPC: Convert the backchannel exports to EXPORT_SYMBOL_GPL SUNRPC: sunrpc should not explicitly depend on NFS config options NFS: Clean up - simplify the switch to read/write-through-MDS NFS: Move the pnfs write code into pnfs.c NFS: Move the pnfs read code into pnfs.c NFS: Allow the nfs_pageio_descriptor to signal that a re-coalesce is needed NFS: Use the nfs_pageio_descriptor->pg_bsize in the read/write request NFS: Cache rpc_ops in struct nfs_pageio_descriptor ...
2011-07-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: merge fchmod() and fchmodat() guts, kill ancient broken kludge xfs: fix misspelled S_IS...() xfs: get rid of open-coded S_ISREG(), etc. vfs: document locking requirements for d_move, __d_move and d_materialise_unique omfs: fix (mode & S_IFDIR) abuse btrfs: S_ISREG(mode) is not mode & S_IFREG... ima: fmode_t misspelled as mode_t... pci-label.c: size_t misspelled as mode_t jffs2: S_ISLNK(mode & S_IFMT) is pointless snd_msnd ->mode is fmode_t, not mode_t v9fs_iop_get_acl: get rid of unused variable vfs: dont chain pipe/anon/socket on superblock s_inodes list Documentation: Exporting: update description of d_splice_alias fs: add missing unlock in default_llseek()
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (23 commits) ceph: document unlocked d_parent accesses ceph: explicitly reference rename old_dentry parent dir in request ceph: document locking for ceph_set_dentry_offset ceph: avoid d_parent in ceph_dentry_hash; fix ceph_encode_fh() hashing bug ceph: protect d_parent access in ceph_d_revalidate ceph: protect access to d_parent ceph: handle racing calls to ceph_init_dentry ceph: set dir complete frag after adding capability rbd: set blk_queue request sizes to object size ceph: set up readahead size when rsize is not passed rbd: cancel watch request when releasing the device ceph: ignore lease mask ceph: fix ceph_lookup_open intent usage ceph: only link open operations to directory unsafe list if O_CREAT|O_TRUNC ceph: fix bad parent_inode calc in ceph_lookup_open ceph: avoid carrying Fw cap during write into page cache libceph: don't time out osd requests that haven't been received ceph: report f_bfree based on kb_avail rather than diffing. ceph: only queue capsnap if caps are dirty ceph: fix snap writeback when racing with writes ...
2011-07-26wireless: fix a typo in ignore_reg_updateMihai Moldovan
Just a typo fix changing regulaotry to regulatory. Signed-off-by: Mihai Moldovan <ionic@ionic.de> CC: John W. Linville <linville@tuxdriver.com> CC: Mohammed Shafi <shafi.wireless@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-26cfg80211: really ignore the regulatory requestSven Neumann
At the beginning of wiphy_update_regulatory() a check is performed whether the request is to be ignored. Then the request is sent to the driver nevertheless. This happens even if last_request points to NULL, leading to a crash in the driver: [<bf01d864>] (lbs_set_11d_domain_info+0x28/0x1e4 [libertas]) from [<c03b714c>] (wiphy_update_regulatory+0x4d0/0x4f4) [<c03b714c>] (wiphy_update_regulatory+0x4d0/0x4f4) from [<c03b4008>] (wiphy_register+0x354/0x420) [<c03b4008>] (wiphy_register+0x354/0x420) from [<bf01b17c>] (lbs_cfg_register+0x80/0x164 [libertas]) [<bf01b17c>] (lbs_cfg_register+0x80/0x164 [libertas]) from [<bf020e64>] (lbs_start_card+0x20/0x88 [libertas]) [<bf020e64>] (lbs_start_card+0x20/0x88 [libertas]) from [<bf02cbd8>] (if_sdio_probe+0x898/0x9c0 [libertas_sdio]) Fix this by returning early. Also remove the out: label as it is not any longer needed. Signed-off-by: Sven Neumann <s.neumann@raumfeld.com> Cc: linux-wireless@vger.kernel.org Cc: Johannes Berg <johannes@sipsolutions.net> Cc: Daniel Mack <daniel@zonque.org> Cc: stable@kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-26libceph: don't time out osd requests that haven't been receivedSage Weil
Keep track of when an outgoing message is ACKed (i.e., the server fully received it and, presumably, queued it for processing). Time out OSD requests only if it's been too long since they've been received. This prevents timeouts and connection thrashing when the OSDs are simply busy and are throttling the requests they read off the network. Reviewed-by: Yehuda Sadeh <yehuda@hq.newdream.net> Signed-off-by: Sage Weil <sage@newdream.net>
2011-07-26vfs: dont chain pipe/anon/socket on superblock s_inodes listEric Dumazet
Workloads using pipes and sockets hit inode_sb_list_lock contention. superblock s_inodes list is needed for quota, dirty, pagecache and fsnotify management. pipe/anon/socket fs are clearly not candidates for these. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25Merge branch 'for-3.1' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-3.1' of git://linux-nfs.org/~bfields/linux: nfsd: don't break lease on CLAIM_DELEGATE_CUR locks: rename lock-manager ops nfsd4: update nfsv4.1 implementation notes nfsd: turn on reply cache for NFSv4 nfsd4: call nfsd4_release_compoundargs from pc_release nfsd41: Deny new lock before RECLAIM_COMPLETE done fs: locks: remove init_once nfsd41: check the size of request nfsd41: error out when client sets maxreq_sz or maxresp_sz too small nfsd4: fix file leak on open_downgrade nfsd4: remember to put RW access on stateid destruction NFSD: Added TEST_STATEID operation NFSD: added FREE_STATEID operation svcrpc: fix list-corrupting race on nfsd shutdown rpc: allow autoloading of gss mechanisms svcauth_unix.c: quiet sparse noise svcsock.c: include sunrpc.h to quiet sparse noise nfsd: Remove deprecated nfsctl system call and related code. NFSD: allow OP_DESTROY_CLIENTID to be only op in COMPOUND Fix up trivial conflicts in Documentation/feature-removal-schedule.txt
2011-07-25Merge 'akpm' patch seriesLinus Torvalds
* Merge akpm patch series: (122 commits) drivers/connector/cn_proc.c: remove unused local Documentation/SubmitChecklist: add RCU debug config options reiserfs: use hweight_long() reiserfs: use proper little-endian bitops pnpacpi: register disabled resources drivers/rtc/rtc-tegra.c: properly initialize spinlock drivers/rtc/rtc-twl.c: check return value of twl_rtc_write_u8() in twl_rtc_set_time() drivers/rtc: add support for Qualcomm PMIC8xxx RTC drivers/rtc/rtc-s3c.c: support clock gating drivers/rtc/rtc-mpc5121.c: add support for RTC on MPC5200 init: skip calibration delay if previously done misc/eeprom: add eeprom access driver for digsy_mtc board misc/eeprom: add driver for microwire 93xx46 EEPROMs checkpatch.pl: update $logFunctions checkpatch: make utf-8 test --strict checkpatch.pl: add ability to ignore various messages checkpatch: add a "prefer __aligned" check checkpatch: validate signature styles and To: and Cc: lines checkpatch: add __rcu as a sparse modifier checkpatch: suggest using min_t or max_t ... Did this as a merge because of (trivial) conflicts in - Documentation/feature-removal-schedule.txt - arch/xtensa/include/asm/uaccess.h that were just easier to fix up in the merge than in the patch series.
2011-07-25notifiers: cpu: move cpu notifiers into cpu.hAmerigo Wang
We presently define all kinds of notifiers in notifier.h. This is not necessary at all, since different subsystems use different notifiers, they are almost non-related with each other. This can also save much build time. Suppose I add a new netdevice event, really I don't have to recompile all the source, just network related. Without this patch, all the source will be recompiled. I move the notify events near to their subsystem notifier registers, so that they can be found more easily. This patch: It is not necessary to share the same notifier.h. Signed-off-by: WANG Cong <amwang@redhat.com> Cc: David Miller <davem@davemloft.net> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25net: Convert struct net_device uc_promisc to boolJoe Perches
No need to use int, its uses are boolean. May save a few bytes one day. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-25net: fix eth.c kernel-doc warningRandy Dunlap
From: Randy Dunlap <rdunlap@xenotime.net> Fix new kernel-doc warning in eth.c: Warning(net/ethernet/eth.c:237): No description found for parameter 'type' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-25IPv4: Send gratuitous ARP for secondary IP addresses alsoZoltan Kiss
If a device event generates gratuitous ARP messages, only primary address is used for sending. This patch iterates through the whole list. Tested with 2 IP addresses configuration on bonding interface. Signed-off-by: Zoltan Kiss <schaman@sch.bme.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
