path: root/net
2011-06-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (40 commits) tg3: Fix tg3_skb_error_unmap() net: tracepoint of net_dev_xmit sees freed skb and causes panic drivers/net/can/flexcan.c: add missing clk_put net: dm9000: Get the chip in a known good state before enabling interrupts drivers/net/davinci_emac.c: add missing clk_put af-packet: Add flag to distinguish VID 0 from no-vlan. caif: Fix race when conditionally taking rtnl lock usbnet/cdc_ncm: add missing .reset_resume hook vlan: fix typo in vlan_dev_hard_start_xmit() net/ipv4: Check for mistakenly passed in non-IPv4 address iwl4965: correctly validate temperature value bluetooth l2cap: fix locking in l2cap_global_chan_by_psm ath9k: fix two more bugs in tx power cfg80211: don't drop p2p probe responses Revert "net: fix section mismatches" drivers/net/usb/catc.c: Fix potential deadlock in catc_ctrl_run() sctp: stop pending timers and purge queues when peer restart asoc drivers/net: ks8842 Fix crash on received packet when in PIO mode. ip_options_compile: properly handle unaligned pointer iwlagn: fix incorrect PCI subsystem id for 6150 devices ...
2011-06-03Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6 into for-davem
2011-06-02net: tracepoint of net_dev_xmit sees freed skb and causes panicKoki Sanagi
Because there is a possibility that skb is kfree_skb()ed and zero cleared after ndo_start_xmit, we should not see the contents of skb like skb->len and skb->dev->name after ndo_start_xmit. But trace_net_dev_xmit does that and causes panic by NULL pointer dereference. This patch fixes trace_net_dev_xmit not to see the contents of skb directly. If you want to reproduce this panic, 1. Get tracepoint of net_dev_xmit on 2. Create 2 guests on KVM 2. Make 2 guests use virtio_net 4. Execute netperf from one to another for a long time as a network burden 5. host will panic(It takes about 30 minutes) Signed-off-by: Koki Sanagi <sanagi.koki@jp.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-01af-packet: Add flag to distinguish VID 0 from no-vlan.Ben Greear
Currently, user-space cannot determine if a 0 tcp_vlan_tci means there is no VLAN tag or the VLAN ID was zero. Add flag to make this explicit. User-space can check for TP_STATUS_VLAN_VALID || tp_vlan_tci > 0, which will be backwards compatible. Older could would have just checked for tp_vlan_tci, so it will work no worse than before. Signed-off-by: Ben Greear <greearb@candelatech.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-01caif: Fix race when conditionally taking rtnl locksjur.brandeland@stericsson.com
Take the RTNL lock unconditionally when calling dev_close. Taking the lock conditionally may cause race conditions. Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-01vlan: fix typo in vlan_dev_hard_start_xmit()Wei Yongjun
commit 4af429d29b341bb1735f04c2fb960178ed5d52e7 (vlan: lockless transmit path) have a typo in vlan_dev_hard_start_xmit(), using u64_stats_update_begin() to end the stat update, it should be u64_stats_update_end(). Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-01net/ipv4: Check for mistakenly passed in non-IPv4 addressMarcus Meissner
Check against mistakenly passing in IPv6 addresses (which would result in an INADDR_ANY bind) or similar incompatible sockaddrs. Signed-off-by: Marcus Meissner <meissner@suse.de> Cc: Reinhard Max <max@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-01bluetooth l2cap: fix locking in l2cap_global_chan_by_psmJohannes Berg
read_lock() ... read_unlock_bh() is clearly bogus. This was broken by commit 23691d75cdc69c3b285211b4d77746aa20a17d18 Author: Gustavo F. Padovan <padovan@profusion.mobi> Date: Wed Apr 27 18:26:32 2011 -0300 Bluetooth: Remove l2cap_sk_list Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-06-01cfg80211: don't drop p2p probe responsesEliad Peller
Commit 0a35d36 ("cfg80211: Use capability info to detect mesh beacons") assumed that probe response with both ESS and IBSS bits cleared means that the frame was sent by a mesh sta. However, these capabilities are also being used in the p2p_find phase, and the mesh-validation broke it. Rename the WLAN_CAPABILITY_IS_MBSS macro, and verify that mesh ies exist before assuming this frame was sent by a mesh sta. Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-31sctp: stop pending timers and purge queues when peer restart asocWei Yongjun
If the peer restart the asoc, we should not only fail any unsent/unacked data, but also stop the T3-rtx, SACK, T4-rto timers, and teardown ASCONF queues. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-31ip_options_compile: properly handle unaligned pointerChris Metcalf
The current code takes an unaligned pointer and does htonl() on it to make it big-endian, then does a memcpy(). The problem is that the compiler decides that since the pointer is to a __be32, it is legal to optimize the copy into a processor word store. However, on an architecture that does not handled unaligned writes in kernel space, this produces an unaligned exception fault. The solution is to track the pointer as a "char *" (which removes a bunch of unpleasant casts in any case), and then just use put_unaligned_be32() to write the value to memory. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: David S. Miller <davem@zippy.davemloft.net>
2011-05-29Merge branch 'pnfs-submit' of git://git.open-osd.org/linux-open-osdLinus Torvalds
* 'pnfs-submit' of git://git.open-osd.org/linux-open-osd: (32 commits) pnfs-obj: pg_test check for max_io_size NFSv4.1: define nfs_generic_pg_test NFSv4.1: use pnfs_generic_pg_test directly by layout driver NFSv4.1: change pg_test return type to bool NFSv4.1: unify pnfs_pageio_init functions pnfs-obj: objlayout_encode_layoutcommit implementation pnfs: encode_layoutcommit pnfs-obj: report errors and .encode_layoutreturn Implementation. pnfs: encode_layoutreturn pnfs: layoutret_on_setattr pnfs: layoutreturn pnfs-obj: osd raid engine read/write implementation pnfs: support for non-rpc layout drivers pnfs-obj: define per-inode private structure pnfs: alloc and free layout_hdr layoutdriver methods pnfs-obj: objio_osd device information retrieval and caching pnfs-obj: decode layout, alloc/free lseg pnfs-obj: pnfs_osd XDR client implementation pnfs-obj: pnfs_osd XDR definitions pnfs-obj: objlayoutdriver module skeleton ...
2011-05-29Merge branch 'for-2.6.40' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.40' of git://linux-nfs.org/~bfields/linux: (22 commits) nfsd: make local functions static NFSD: Remove unused variable from nfsd4_decode_bind_conn_to_session() NFSD: Check status from nfsd4_map_bcts_dir() NFSD: Remove setting unused variable in nfsd_vfs_read() nfsd41: error out on repeated RECLAIM_COMPLETE nfsd41: compare request's opcnt with session's maxops at nfsd4_sequence nfsd v4.1 lOCKT clientid field must be ignored nfsd41: add flag checking for create_session nfsd41: make sure nfs server process OPEN with EXCLUSIVE4_1 correctly nfsd4: fix wrongsec handling for PUTFH + op cases nfsd4: make fh_verify responsibility of nfsd_lookup_dentry caller nfsd4: introduce OPDESC helper nfsd4: allow fh_verify caller to skip pseudoflavor checks nfsd: distinguish functions of NFSD_MAY_* flags svcrpc: complete svsk processing on cb receive failure svcrpc: take advantage of tcp autotuning SUNRPC: Don't wait for full record to receive tcp data svcrpc: copy cb reply instead of pages svcrpc: close connection if client sends short packet svcrpc: note network-order types in svc_process_calldir ...
2011-05-29Merge branch 'nfs-for-2.6.40' of ↵Linus Torvalds
git://git.linux-nfs.org/projects/trondmy/nfs-2.6 * 'nfs-for-2.6.40' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: SUNRPC: Support for RPC over AF_LOCAL transports SUNRPC: Remove obsolete comment SUNRPC: Use AF_LOCAL for rpcbind upcalls SUNRPC: Clean up use of curly braces in switch cases NFS: Revert NFSROOT default mount options SUNRPC: Rename xs_encode_tcp_fragment_header() nfs,rcu: convert call_rcu(nfs_free_delegation_callback) to kfree_rcu() nfs41: Correct offset for LAYOUTCOMMIT NFS: nfs_update_inode: print current and new inode size in debug output NFSv4.1: Fix the handling of NFS4ERR_SEQ_MISORDERED errors NFSv4: Handle expired stateids when the lease is still valid SUNRPC: Deal with the lack of a SYN_SENT sk->sk_state_change callback...
2011-05-29SUNRPC: introduce xdr_init_decode_pagesBenny Halevy
Initialize xdr_stream and xdr_buf using an array of page pointers and length of buffer. Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2011-05-27SUNRPC: Support for RPC over AF_LOCAL transportsChuck Lever
TI-RPC introduces the capability of performing RPC over AF_LOCAL sockets. It uses this mainly for registering and unregistering local RPC services securely with the local rpcbind, but we could also conceivably use it as a generic upcall mechanism. This patch provides a client-side only implementation for the moment. We might also consider a server-side implementation to provide AF_LOCAL access to NLM (for statd downcalls, and such like). Autobinding is not supported on kernel AF_LOCAL transports at this time. Kernel ULPs must specify the pathname of the remote endpoint when an AF_LOCAL transport is created. rpcbind supports registering services available via AF_LOCAL, so the kernel could handle it with some adjustment to ->rpcbind and ->set_port. But we don't need this feature for doing upcalls via well-known named sockets. This has not been tested with ULPs that move a substantial amount of data. Thus, I can't attest to how robust the write_space and congestion management logic is. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-05-27SUNRPC: Remove obsolete commentChuck Lever
Clean up. The documenting comment at the top of net/sunrpc/clnt.c is out of date. We adopted BSD's RTO estimation mechanism years ago. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-05-27SUNRPC: Use AF_LOCAL for rpcbind upcallsChuck Lever
As libtirpc does in user space, have our registration API try using an AF_LOCAL transport first when registering and unregistering. This means we don't chew up privileged ports, and our registration is bound to an "owner" (the effective uid of the process on the sending end of the transport). Only that "owner" may unregister the service. The kernel could probe rpcbind via an rpcbind query to determine whether rpcbind has an AF_LOCAL service. For simplicity, we use the same technique that libtirpc uses: simply fail over to network loopback if creating an AF_LOCAL transport to the well-known rpcbind service socket fails. This means we open-code the pathname of the rpcbind socket in the kernel. For now we have to do that anyway because the kernel's RPC over AF_LOCAL implementation does not support autobind. That may be undesirable in the long term. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-05-27SUNRPC: Clean up use of curly braces in switch casesChuck Lever
Clean up. Preferred style is not to use curly braces around switch cases. I'm about to add another case that needs a third type cast. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-05-27SUNRPC: Rename xs_encode_tcp_fragment_header()Chuck Lever
Clean up: Use a more generic name for xs_encode_tcp_fragment_header(); it's appropriate to use for all stream transport types. We're about to add new stream transport. Also, move it to a place where it is more easily shared amongst the various send_request methods. And finally, replace the "htonl" macro invocation with its modern equivalent. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-05-27SUNRPC: Deal with the lack of a SYN_SENT sk->sk_state_change callback...Trond Myklebust
The TCP connection state code depends on the state_change() callback being called when the SYN_SENT state is set. However the networking layer doesn't actually call us back in that case. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: stable@kernel.org
2011-05-27Merge ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
2011-05-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: net: Kill ratelimit.h dependency in linux/net.h net: Add linux/sysctl.h includes where needed. net: Kill ether_table[] declaration. inetpeer: fix race in unused_list manipulations atm: expose ATM device index in sysfs IPVS: bug in ip_vs_ftp, same list heaad used in all netns. bug.h: Move ratelimit warn interfaces to ratelimit.h bonding: cleanup module option descriptions net:8021q:vlan.c Fix pr_info to just give the vlan fullname and version. net: davinci_emac: fix dev_err use at probe can: convert to %pK for kptr_restrict support net: fix ETHTOOL_SFEATURES compatibility with old ethtool_ops.set_flags netfilter: Fix several warnings in compat_mtw_from_user(). netfilter: ipset: fix ip_set_flush return code netfilter: ipset: remove unused variable from type_pf_tdel() netfilter: ipset: Use proper timeout value to jiffies conversion
2011-05-27net: Kill ratelimit.h dependency in linux/net.hDavid S. Miller
Ingo Molnar noticed that we have this unnecessary ratelimit.h dependency in linux/net.h, which hid compilation problems from people doing builds only with CONFIG_NET enabled. Move this stuff out to a seperate net/net_ratelimit.h file and include that in the only two places where this thing is needed. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Ingo Molnar <mingo@elte.hu>
2011-05-27inetpeer: fix race in unused_list manipulationsEric Dumazet
Several crashes in cleanup_once() were reported in recent kernels. Commit d6cc1d642de9 (inetpeer: various changes) added a race in unlink_from_unused(). One way to avoid taking unused_peers.lock before doing the list_empty() test is to catch 0->1 refcnt transitions, using full barrier atomic operations variants (atomic_cmpxchg() and atomic_inc_return()) instead of previous atomic_inc() and atomic_add_unless() variants. We then call unlink_from_unused() only for the owner of the 0->1 transition. Add a new atomic_add_unless_return() static helper With help from Arun Sharma. Refs: https://bugzilla.kernel.org/show_bug.cgi?id=32772 Reported-by: Arun Sharma <asharma@fb.com> Reported-by: Maximilian Engelhardt <maxi@daemonizer.de> Reported-by: Yann Dupont <Yann.Dupont@univ-nantes.fr> Reported-by: Denys Fedoryshchenko <denys@visp.net.lb> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-27Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: [S390] mm: add ZONE_DMA to 31-bit config again [S390] mm: add page fault retry handling [S390] mm: handle kernel caused page fault oom situations [S390] delay: implement ndelay [S390] topology,sched: fix cpu_coregroup_mask/cpu_book_mask definitions [S390] hwsampler: allow cpu hotplug [S390] uaccess: turn __access_ok() into a define [S390] irq: merge irq.c and s390_ext.c [S390] irq: fix service signal external interrupt handling [S390] pfault: always enable service signal interrupt
2011-05-27atm: expose ATM device index in sysfsDan Williams
It's currently exposed only through /proc which, besides requiring screen-scraping, doesn't allow userspace to distinguish between two identical ATM adapters with different ATM indexes. The ATM device index is required when using PPPoATM on a system with multiple ATM adapters. Signed-off-by: Dan Williams <dcbw@redhat.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Tested-by: David Woodhouse <dwmw2@infradead.org> Cc: stable@kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-27Merge branch 'pablo/nf-2.6-updates' of git://1984.lsi.us.es/net-2.6David S. Miller
2011-05-27mac80211: Remove duplicate linux/slab.h include from net/mac80211/scan.cJesper Juhl
Commit 79f460ca49d8d5700756ab7071c951311c7f29cc add a duplicate linux/slab.h include to net/mac80211/scan.c - remove it. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Acked-by: Luciano Coelho <coelho@ti.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-27mac80211: clear local->ps_data on disassocEliad Peller
local->ps_data wasn't cleared on disassociation, which (in some corner cases) caused reconnections to enter psm before association completed. Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-27IPVS: bug in ip_vs_ftp, same list heaad used in all netns.Hans Schillstrom
When ip_vs was adapted to netns the ftp application was not adapted in a correct way. However this is a fix to avoid kernel errors. In the long term another solution might be chosen. I.e the ports that the ftp appl, uses should be per netns. Signed-off-by: Hans Schillstrom <hans.schillstrom@ericsson.com> Acked-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2011-05-26Merge branch 'trivial' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: gfs2: Drop __TIME__ usage isdn/diva: Drop __TIME__ usage atm: Drop __TIME__ usage dlm: Drop __TIME__ usage wan/pc300: Drop __TIME__ usage parport: Drop __TIME__ usage hdlcdrv: Drop __TIME__ usage baycom: Drop __TIME__ usage pmcraid: Drop __DATE__ usage edac: Drop __DATE__ usage rio: Drop __DATE__ usage scsi/wd33c93: Drop __TIME__ usage scsi/in2000: Drop __TIME__ usage aacraid: Drop __TIME__ usage media/cx231xx: Drop __TIME__ usage media/radio-maxiradio: Drop __TIME__ usage nozomi: Drop __TIME__ usage cyclades: Drop __TIME__ usage
2011-05-26mac80211: stop queues before rate control updationRajkumar Manoharan
Stop tx queues before updating rate control to ensure proper rate selection. Otherwise packets can be transmitted in 40 Mhz whereas hw is configured in HT20. Signed-off-by: Rajkumar Manoharan <rmanoharan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-26nl80211: fix check for valid SSID size in scan operationsLuciano Coelho
In both trigger_scan and sched_scan operations, we were checking for the SSID length before assigning the value correctly. Since the memory was just kzalloc'ed, the check was always failing and SSID with over 32 characters were allowed to go through. This was causing a buffer overflow when copying the actual SSID to the proper place. This bug has been there since 2.6.29-rc4. Cc: stable@kernel.org Signed-off-by: Luciano Coelho <coelho@ti.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-26Merge branches 'core-fixes-for-linus' and 'irq-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: seqlock: Get rid of SEQLOCK_UNLOCKED * 'irq-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: irq: Remove smp_affinity_list when unregister irq proc
2011-05-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: RDMA/cma: Save PID of ID's owner RDMA/cma: Add support for netlink statistics export RDMA/cma: Pass QP type into rdma_create_id() RDMA: Update exported headers list RDMA/cma: Export enum cma_state in <rdma/rdma_cm.h> RDMA/nes: Add a check for strict_strtoul() RDMA/cxgb3: Don't post zero-byte read if endpoint is going away RDMA/cxgb4: Use completion objects for event blocking IB/srp: Fix integer -> pointer cast warnings IB: Add devnode methods to cm_class and umad_class IB/mad: Return EPROTONOSUPPORT when an RDMA device lacks the QP required IB/uverbs: Add devnode method to set path/mode RDMA/ucma: Add .nodename/.mode to tell userspace where to create device node RDMA: Add netlink infrastructure RDMA: Add error handling to ib_core_init()
2011-05-26bug.h: Move ratelimit warn interfaces to ratelimit.hDavid S. Miller
As reported by Ingo Molnar, we still have configuration combinations where use of the WARN_RATELIMIT interfaces break the build because dependencies don't get met. Instead of going down the long road of trying to make it so that ratelimit.h can get included by kernel.h or asm-generic/bug.h, just move the interface into ratelimit.h and make users have to include that. Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Randy Dunlap <randy.dunlap@oracle.com>
2011-05-26net:8021q:vlan.c Fix pr_info to just give the vlan fullname and version.Justin Mattock
The below patch removes vlan_buggyright and vlan_copyright from vlan_proto_init, so that it prints out just the fullname of vlan and the version number. before: [ 30.438203] 802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com> [ 30.441542] All bugs added by David S. Miller <davem@redhat.com> after: [ 31.513910] 802.1Q VLAN Support v1.8 Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> CC: Joe Perches <joe@perches.com> CC: David S. Miller <davem@davemloft.net> CC: Ben Greear <greearb@candelatech.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-26can: convert to %pK for kptr_restrict supportOliver Hartkopp
As these pointers have been printed without using %p they were missed in the big network kptr_restrict conversion patch %p -> %pK from Dan Rosenberg. Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-26net: fix ETHTOOL_SFEATURES compatibility with old ethtool_ops.set_flagsMichał Mirosław
Current code squashes flags to bool - this makes set_flags fail whenever some ETH_FLAG_* equivalent features are set. Fix this. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-26netfilter: Fix several warnings in compat_mtw_from_user().David Miller
Kill set but not used 'entry_offset'. Add a default case to the switch statement so the compiler can see that we always initialize off and size_kern before using them. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2011-05-26netfilter: ipset: fix ip_set_flush return codeJozsef Kadlecsik
ip_set_flush returned -EPROTO instead of -IPSET_ERR_PROTOCOL, fixed Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2011-05-26[S390] irq: merge irq.c and s390_ext.cHeiko Carstens
Merge irq.c and s390_ext.c into irq.c. That way all external interrupt related functions are together. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-05-26atm: Drop __TIME__ usageMichal Marek
The kernel already prints its build timestamp during boot, no need to repeat it in random drivers and produce different object files each time. Acked-by: David S. Miller <davem@davemloft.net> Cc: netdev@vger.kernel.org Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-05-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/linux-2.6-nsfdLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/linux-2.6-nsfd: net: fix get_net_ns_by_fd for !CONFIG_NET_NS ns proc: Return -ENOENT for a nonexistent /proc/self/ns/ entry. ns: Declare sys_setns in syscalls.h net: Allow setting the network namespace by fd ns proc: Add support for the ipc namespace ns proc: Add support for the uts namespace ns proc: Add support for the network namespace. ns: Introduce the setns syscall ns: proc files for namespace naming policy.
2011-05-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (89 commits) bonding: documentation and code cleanup for resend_igmp bonding: prevent deadlock on slave store with alb mode (v3) net: hold rtnl again in dump callbacks Add Fujitsu 1000base-SX PCI ID to tg3 bnx2x: protect sequence increment with mutex sch_sfq: fix peek() implementation isdn: netjet - blacklist Digium TDM400P via-velocity: don't annotate MAC registers as packed xen: netfront: hold RTNL when updating features. sctp: fix memory leak of the ASCONF queue when free asoc net: make dev_disable_lro use physical device if passed a vlan dev (v2) net: move is_vlan_dev into public header file (v2) bug.h: Fix build with CONFIG_PRINTK disabled. wireless: fix fatal kernel-doc error + warning in mac80211.h wireless: fix cfg80211.h new kernel-doc warnings iwlagn: dbg_fixed_rate only used when CONFIG_MAC80211_DEBUGFS enabled dst: catch uninitialized metrics be2net: hash key for rss-config cmd not set bridge: initialize fake_rtable metrics net: fix __dst_destroy_metrics_generic() ... Fix up trivial conflicts in drivers/staging/brcm80211/brcmfmac/wl_cfg80211.c
2011-05-25net: hold rtnl again in dump callbacksEric Dumazet
Commit e67f88dd12f6 (dont hold rtnl mutex during netlink dump callbacks) missed fact that rtnl_fill_ifinfo() must be called with rtnl held. Because of possible deadlocks between two mutexes (cb_mutex and rtnl), its not easy to solve this problem, so revert this part of the patch. It also forgot one rcu_read_unlock() in FIB dump_rules() Add one ASSERT_RTNL() in rtnl_fill_ifinfo() to remind us the rule. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Patrick McHardy <kaber@trash.net> CC: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-25sch_sfq: fix peek() implementationEric Dumazet
Since commit eeaeb068f139 (sch_sfq: allow big packets and be fair), sfq_peek() can return a different skb that would be normally dequeued by sfq_dequeue() [ if current slot->allot is negative ] Use generic qdisc_peek_dequeued() instead of custom implementation, to get consistent result. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Jarek Poplawski <jarkao2@gmail.com> CC: Patrick McHardy <kaber@trash.net> CC: Jesper Dangaard Brouer <hawk@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-25sctp: fix memory leak of the ASCONF queue when free asocWei Yongjun
If an ASCONF chunk is outstanding, then the following ASCONF chunk will be queued for later transmission. But when we free the asoc, we forget to free the ASCONF queue at the same time, this will cause memory leak. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-25net: make dev_disable_lro use physical device if passed a vlan dev (v2)Neil Horman
If the device passed into dev_disable_lro is a vlan, then repoint the dev poniter so that we actually modify the underlying physical device. Signed-of-by: Neil Horman <nhorman@tuxdriver.com> CC: davem@davemloft.net CC: bhutchings@solarflare.com Signed-off-by: David S. Miller <davem@davemloft.net>
