path: root/net
2007-10-15[IPV6]: Consolidate the ip6_pol_route_(input|output) pairPavel Emelyanov
The difference in both functions is in the "id" passed to the rt6_select, so just pass it as an extra argument from two outer helpers. This is minus 60 lines of code and 360 bytes of .text Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[NEIGH]: Ensure that pneigh_lookup is protected with RTNLPavel Emelyanov
The pnigh_lookup is used to lookup proxy entries and to create them in case lookup failed. However, the "creation" code does not perform the re-lookup after GFP_KERNEL allocation. This is done because the code is expected to be protected with the RTNL lock, so add the assertion (mainly to address future questions from new network developers like me :) ). Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[INET]: kmalloc+memset -> kzalloc in frag_alloc_queueDenis V. Lunev
kmalloc + memset -> kzalloc in frag_alloc_queue Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[IPV6]: Replace sk_buff ** with sk_buff * in input handlersHerbert Xu
With all the users of the double pointers removed from the IPv6 input path, this patch converts all occurances of sk_buff ** to sk_buff * in IPv6 input handlers. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[INET]: Consolidate the xxx_putPavel Emelyanov
These ones use the generic data types too, so move them in one place. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[INET]: Small cleanup for xxx_put after evictor consolidationPavel Emelyanov
After the evictor code is consolidated there is no need in passing the extra pointer to the xxx_put() functions. The only place when it made sense was the evictor code itself. Maybe this change must got with the previous (or with the next) patch, but I try to make them shorter as much as possible to simplify the review (but they are still large anyway), so this change goes in a separate patch. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[INET]: Consolidate the xxx_evictorPavel Emelyanov
The evictors collect some statistics for ipv4 and ipv6, so make it return the number of evicted queues and account them all at once in the caller. The XXX_ADD_STATS_BH() macros are just for this case, but maybe there are places in code, that can make use of them as well. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[INET]: Consolidate the xxx_frag_destroyPavel Emelyanov
To make in possible we need to know the exact frag queue size for inet_frags->mem management and two callbacks: * to destoy the skb (optional, used in conntracks only) * to free the queue itself (mandatory, but later I plan to move the allocation and the destruction of frag_queues into the common place, so this callback will most likely be optional too). Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[INET]: Consolidate xxx_the secret_rebuildPavel Emelyanov
This code works with the generic data types as well, so move this into inet_fragment.c This move makes it possible to hide the secret_timer management and the secret_rebuild routine completely in the inet_fragment.c Introduce the ->hashfn() callback in inet_frags() to get the hashfun for a given inet_frag_queue() object. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[INET]: Consolidate the xxx_frag_killPavel Emelyanov
Since now all the xxx_frag_kill functions now work with the generic inet_frag_queue data type, this can be moved into a common place. The xxx_unlink() code is moved as well. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[INET]: Collect common frag sysctl variables togetherPavel Emelyanov
Some sysctl variables are used to tune the frag queues management and it will be useful to work with them in a common way in the future, so move them into one structure, moreover they are the same for all the frag management codes. I don't place them in the existing inet_frags object, introduced in the previous patch for two reasons: 1. to keep them in the __read_mostly section; 2. not to export the whole inet_frags objects outside. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[INET]: Collect frag queues management objects togetherPavel Emelyanov
There are some objects that are common in all the places which are used to keep track of frag queues, they are: * hash table * LRU list * rw lock * rnd number for hash function * the number of queues * the amount of memory occupied by queues * secret timer Move all this stuff into one structure (struct inet_frags) to make it possible use them uniformly in the future. Like with the previous patch this mostly consists of hunks like - write_lock(&ipfrag_lock); + write_lock(&ip4_frags.lock); To address the issue with exporting the number of queues and the amount of memory occupied by queues outside the .c file they are declared in, I introduce a couple of helpers. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[INET]: Move common fields from frag_queues in one place.Pavel Emelyanov
Introduce the struct inet_frag_queue in include/net/inet_frag.h file and place there all the common fields from three structs: * struct ipq in ipv4/ip_fragment.c * struct nf_ct_frag6_queue in nf_conntrack_reasm.c * struct frag_queue in ipv6/reassembly.c After this, replace these fields on appropriate structures with this structure instance and fix the users to use correct names i.e. hunks like - atomic_dec(&fq->refcnt); + atomic_dec(&fq->q.refcnt); (these occupy most of the patch) Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[TCP]: high_seq parameter removed (all callers use tp->high_seq)Ilpo Järvinen
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[IPV6]: Uninline netfilter okfnsPatrick McHardy
Uninline netfilter okfns for those cases where gcc can generate tail-calls. Before: text data bss dec hex filename 8994153 1016524 524652 10535329 a0c1a1 vmlinux After: text data bss dec hex filename 8992761 1016524 524652 10533937 a0bc31 vmlinux ------------------------------------------------------- -1392 All cases have been verified to generate tail-calls with and without netfilter. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[BRIDGE]: Remove SKB share checks in br_nf_pre_routing().Patrick McHardy
2007-10-15[IPV4]: Uninline netfilter okfnsPatrick McHardy
Now that we don't pass double skb pointers to nf_hook_slow anymore, gcc can generate tail calls for some of the netfilter hook okfn invocations, so there is no need to inline the functions anymore. This caused huge code bloat since we ended up with one inlined version and one out-of-line version since we pass the address to nf_hook_slow. Before: text data bss dec hex filename 8997385 1016524 524652 10538561 a0ce41 vmlinux After: text data bss dec hex filename 8994009 1016524 524652 10535185 a0c111 vmlinux ------------------------------------------------------- -3376 All cases have been verified to generate tail-calls with and without netfilter. The okfns in ipmr and xfrm4_input still remain inline because gcc can't generate tail-calls for them. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[NET]: Avoid copying TCP packets unnecessarilyHerbert Xu
TCP packets all have writable heads, that is, even though it's cloned, it is writable up to the end of the TCP header. This patch makes skb_checksum_help aware of this fact by using skb_clone_writable and avoiding a copy for TCP. I've also modified the BUG_ON tests to be unsigned. The only case where this makes a difference is if csum_start points to a location before skb->data. Since skb->data should always include the header where the checksum field is (and all currently callers adhere to that), this change is safe and may uncover bugs later. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[NET]: Fix csum_start update in pskb_expand_headHerbert Xu
I got confused by the dual nature of the off variable in the function pskb_expand_head. The csum_start offset should use nhead instead of off which can change depending on whether we are using offsets or pointers. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[NETLINK]: Don't leak 'listeners' in netlink_kernel_create()Jesper Juhl
The Coverity checker spotted that we'll leak the storage allocated to 'listeners' in netlink_kernel_create() when the if (!nl_table[unit].registered) check is false. This patch avoids the leak. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[IPV6] __inet6_csk_dst_store(): fix check-after-useAdrian Bunk
The Coverity checker spotted that we have already oops'ed if "dst" was NULL. Since "dst" being NULL doesn't seem to be possible at this point this patch removes the NULL check. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Acked-by: Noriaki TAKAMIYA <takamiya@po.ntts.co.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[IPV6]: Avoid skb_copy/pskb_copy/skb_realloc_headroom on inputHerbert Xu
This patch replaces unnecessary uses of skb_copy by pskb_expand_head on the IPv6 input path. This allows us to remove the double pointers later. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[IPV6]: Make ipv6_frag_rcv return the same packetHerbert Xu
This patch implements the same change taht was done to ip_defrag. It makes ipv6_frag_rcv return the last packet received of a train of fragments rather than the head of that sequence. This allows us to get rid of the sk_buff ** argument later. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[NETFILTER]: Replace sk_buff ** with sk_buff *Herbert Xu
With all the users of the double pointers removed, this patch mops up by finally replacing all occurances of sk_buff ** in the netfilter API by sk_buff *. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[NETFILTER]: Avoid skb_copy/pskb_copy/skb_realloc_headroomHerbert Xu
This patch replaces unnecessary uses of skb_copy, pskb_copy and skb_realloc_headroom by functions such as skb_make_writable and pskb_expand_head. This allows us to remove the double pointers later. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[IPVS]: Replace local version of skb_make_writableHerbert Xu
This patch removes the IPVS-specific version of skb_make_writable and replaces it with the netfilter one. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[NETFILTER]: Do not copy skb in skb_make_writableHerbert Xu
Now that all callers of netfilter can guarantee that the skb is not shared, we no longer have to copy the skb in skb_make_writable. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[BRIDGE]: Unshare skb upon entryHerbert Xu
Due to the special location of the bridging hook, it should never see a shared packet anyway (certainly not with any in-kernel code). So it makes sense to unshare the skb there if necessary as that will greatly simplify the code below it (in particular, netfilter). Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[NET]: Avoid unnecessary cloning for ingress filteringHerbert Xu
As it is we always invoke pt_prev before ing_filter, even if there are no ingress filters attached. This can cause unnecessary cloning in pt_prev. This patch changes it so that we only invoke pt_prev if there are ingress filters attached. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[IPV4]: Change ip_defrag to return an integerHerbert Xu
Now that ip_frag always returns the packet given to it on input, we can change it to return an integer indicating error instead. This patch does that and updates all its callers accordingly. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[IPV4]: Make ip_defrag return the same packetHerbert Xu
This patch is a bit of a hack. However it is worth it if you consider that this is the only reason why we have to carry around the struct sk_buff ** pointers in netfilter. It makes ip_defrag always return the packet that was given to it on input. It does this by cloning the packet and replacing its original contents with the head fragment if necessary. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[SKBUFF]: Add skb_morphHerbert Xu
This patch creates a new function skb_morph that's just like skb_clone except that it lets user provide the spare skb that will be overwritten by the one that's to be cloned. This will be used by IP fragment reassembly so that we get back the same skb that went in last (rather than the head skb that we get now which requires us to carry around double pointers all over the place). Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[SKBUFF]: Merge common code between copy_skb_header and skb_cloneHerbert Xu
This patch creates a new function __copy_skb_header to merge the common code between copy_skb_header and skb_clone. Having two functions which are largely the same is a source of wasted labour as well as confusion. In fact the tc_verd stuff is almost certainly a bug since it's treated differently in skb_clone compared to the callers of copy_skb_header (skb_copy/pskb_copy/skb_copy_expand). I've kept that difference in tact with a comment added asking for clarification. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15Merge git://git.linux-nfs.org/pub/linux/nfs-2.6Linus Torvalds
* git://git.linux-nfs.org/pub/linux/nfs-2.6: (131 commits) NFSv4: Fix a typo in nfs_inode_reclaim_delegation NFS: Add a boot parameter to disable 64 bit inode numbers NFS: nfs_refresh_inode should clear cache_validity flags on success NFS: Fix a connectathon regression in NFSv3 and NFSv4 NFS: Use nfs_refresh_inode() in ops that aren't expected to change the inode SUNRPC: Don't call xprt_release in call refresh SUNRPC: Don't call xprt_release() if call_allocate fails SUNRPC: Fix buggy UDP transmission [23/37] Clean up duplicate includes in [2.6 patch] net/sunrpc/rpcb_clnt.c: make struct rpcb_program static SUNRPC: Use correct type in buffer length calculations SUNRPC: Fix default hostname created in rpc_create() nfs: add server port to rpc_pipe info file NFS: Get rid of some obsolete macros NFS: Simplify filehandle revalidation NFS: Ensure that nfs_link() returns a hashed dentry NFS: Be strict about dentry revalidation when doing exclusive create NFS: Don't zap the readdir caches upon error NFS: Remove the redundant nfs_reval_fsid() NFSv3: Always use directory post-op attributes in nfs3_proc_lookup ... Fix up trivial conflict due to sock_owned_by_user() cleanup manually in net/sunrpc/xprtsock.c
2007-10-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-schedLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-sched: (140 commits) sched: sync wakeups preempt too sched: affine sync wakeups sched: guest CPU accounting: maintain guest state in KVM sched: guest CPU accounting: maintain stats in account_system_time() sched: guest CPU accounting: add guest-CPU /proc/<pid>/stat fields sched: guest CPU accounting: add guest-CPU /proc/stat field sched: domain sysctl fixes: add terminator comment sched: domain sysctl fixes: do not crash on allocation failure sched: domain sysctl fixes: unregister the sysctl table before domains sched: domain sysctl fixes: use for_each_online_cpu() sched: domain sysctl fixes: use kcalloc() Make scheduler debug file operations const sched: enable wake-idle on CONFIG_SCHED_MC=y sched: reintroduce topology.h tunings sched: allow the immediate migration of cache-cold tasks sched: debug, improve migration statistics sched: debug: increase width of debug line sched: activate task_hot() only on fair-scheduled tasks sched: reintroduce cache-hot affinity sched: speed up context-switches a bit ...
2007-10-15Merge branch 'nfs-server-stable' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'nfs-server-stable' of git://linux-nfs.org/~bfields/linux: knfsd: query filesystem for NFSv4 getattr of FATTR4_MAXNAME knfsd: nfsv4 delegation recall should take reference on client knfsd: don't shutdown callbacks until nfsv4 client is freed knfsd: let nfsd manage timing out its own leases knfsd: Add source address to sunrpc svc errors knfsd: 64 bit ino support for NFS server svcgss: move init code into separate function knfsd: remove code duplication in nfsd4_setclientid() nfsd warning fix knfsd: fix callback rpc cred knfsd: move nfsv4 slab creation/destruction to module init/exit knfsd: spawn kernel thread to probe callback channel knfsd: nfs4 name->id mapping not correctly parsing negative downcall knfsd: demote some printk()s to dprintk()s knfsd: cleanup of nfsd4 cmp_* functions knfsd: delete code made redundant by map_new_errors nfsd: fix horrible indentation in nfsd_setattr nfsd: remove unused cache_for_each macro nfsd: tone down inaccurate dprintk
2007-10-15sched: affine sync wakeupsIngo Molnar
make sync wakeups affine for cache-cold tasks: if a cache-cold task is woken up by a sync wakeup then use the opportunity to migrate it straight away. (the two tasks are 'related' because they communicate) Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-14fix endianness bug in inet_lroAl Viro
all uses of and almost all assignments to lro_desc->tcp_ack assume that it's net-endian; one converts net-endian to host-endian and sticks it in lro_desc->tcp_ack. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-14inet_lro: trivial endianness annotationsAl Viro
2007-10-14fix breakage in sctp getsockoptAl Viro
copy_to_user() into on-stack array Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-13net core: fix kernel-doc for new function parametersRandy Dunlap
Fix networking code kernel-doc for newly added parameters. Warning(linux-2.6.23-git2//net/core/sock.c:879): No description found for parameter 'net' Warning(linux-2.6.23-git2//net/core/dev.c:570): No description found for parameter 'net' Warning(linux-2.6.23-git2//net/core/dev.c:594): No description found for parameter 'net' Warning(linux-2.6.23-git2//net/core/dev.c:617): No description found for parameter 'net' Warning(linux-2.6.23-git2//net/core/dev.c:641): No description found for parameter 'net' Warning(linux-2.6.23-git2//net/core/dev.c:667): No description found for parameter 'net' Warning(linux-2.6.23-git2//net/core/dev.c:722): No description found for parameter 'net' Warning(linux-2.6.23-git2//net/core/dev.c:959): No description found for parameter 'net' Warning(linux-2.6.23-git2//net/core/dev.c:1195): No description found for parameter 'dev' Warning(linux-2.6.23-git2//net/core/dev.c:2105): No description found for parameter 'n' Warning(linux-2.6.23-git2//net/core/dev.c:3272): No description found for parameter 'net' Warning(linux-2.6.23-git2//net/core/dev.c:3445): No description found for parameter 'net' Warning(linux-2.6.23-git2//include/linux/netdevice.h:1301): No description found for parameter 'cpu' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-12kobjects: fix up improper use of the kobject name fieldGreg Kroah-Hartman
A number of different drivers incorrect access the kobject name field directly. This is not correct as the name might not be in the array. Use the proper accessor function instead.
2007-10-12Driver core: change add_uevent_var to use a structKay Sievers
This changes the uevent buffer functions to use a struct instead of a long list of parameters. It does no longer require the caller to do the proper buffer termination and size accounting, which is currently wrong in some places. It fixes a known bug where parts of the uevent environment are overwritten because of wrong index calculations. Many thanks to Mathieu Desnoyers for finding bugs and improving the error handling. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-11[TCP]: Limit processing lost_retrans loop to work-to-do casesIlpo Järvinen
This addition of lost_retrans_low to tcp_sock might be unnecessary, it's not clear how often lost_retrans worker is executed when there wasn't work to do. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-11[TCP]: Fix lost_retrans loop vs fastpath problemsIlpo Järvinen
Detection implemented with lost_retrans must work also when fastpath is taken, yet most of the queue is skipped including (very likely) those retransmitted skb's we're interested in. This problem appeared when the hints got added, which removed a need to always walk over the whole write queue head. Therefore decicion for the lost_retrans worker loop entry must be separated from the sacktag processing more than it was necessary before. It turns out to be problematic to optimize the worker loop very heavily because ack_seqs of skb may have a number of discontinuity points. Maybe similar approach as currently is implemented could be attempted but that's becoming more and more complex because the trend is towards less skb walking in sacktag marker. Trying a simple work until all rexmitted skbs heve been processed approach. Maybe after(highest_sack_end_seq, tp->high_seq) checking is not sufficiently accurate and causes entry too often in no-work-to-do cases. Since that's not known, I've separated solution to that from this patch. Noticed because of report against a related problem from TAKANO Ryousei <takano@axe-inc.co.jp>. He also provided a patch to that part of the problem. This patch includes solution to it (though this patch has to use somewhat different placement). TAKANO's description and patch is available here: http://marc.info/?l=linux-netdev&m=119149311913288&w=2 ...In short, TAKANO's problem is that end_seq the loop is using not necessarily the largest SACK block's end_seq because the current ACK may still have higher SACK blocks which are later by the loop. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-11[TCP]: No need to re-count fackets_out/sacked_out at RTOIlpo Järvinen
Both sacked_out and fackets_out are directly known from how parameter. Since fackets_out is accurate, there's no need for recounting (sacked_out was previously unnecessarily counted in the loop anyway). Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-11[TCP]: Extract tcp_match_queue_to_sack from sacktag codeIlpo Järvinen
This is necessary for upcoming DSACK bugfix. Reduces sacktag length which is not very sad thing at all... :-) Notice that there's a need to handle out-of-mem at caller's place. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-11[TCP]: Kill almost unused variable pcount from sacktagIlpo Järvinen
It's on the way for future cutting of that function. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-11[TCP]: Fix mark_head_lost to ignore R-bit when trying to mark LIlpo Järvinen
This condition (plain R) can arise at least in recovery that is triggered after tcp_undo_loss. There isn't any reason why they should not be marked as lost, not marking makes in_flight estimator to return too large values. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-11[TCP]: Add bytes_acked (ABC) clearing to FRTO tooIlpo Järvinen
I was reading tcp_enter_loss while looking for Cedric's bug and noticed bytes_acked adjustment is missing from FRTO side. Since bytes_acked will only be used in tcp_cong_avoid, I think it's safe to assume RTO would be spurious. During FRTO cwnd will be not controlled by tcp_cong_avoid and if FRTO calls for conventional recovery, cwnd is adjusted and the result of wrong assumption is cleared from bytes_acked. If RTO was in fact spurious, we did normal ABC already and can continue without any additional adjustments. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
