path: root/net
2009-08-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs: 9p: update documentation pointers 9p: remove unnecessary v9fses->options which duplicates the mount string net/9p: insulate the client against an invalid error code sent by a 9p server 9p: Add missing cast for the error return value in v9fs_get_inode 9p: Remove redundant inode uid/gid assignment 9p: Fix possible regressions when ->get_sb fails. 9p: Fix v9fs show_options 9p: Fix possible memleak in v9fs_inode_from fid. 9p: minor comment fixes 9p: Fix possible inode leak in v9fs_get_inode. 9p: Check for error in return value of v9fs_fid_add
2009-08-27ipv4: make ip_append_data() handle NULL routing tableJulien TINNES
Add a check in ip_append_data() for NULL *rtp to prevent future bugs in callers from being exploitable. Signed-off-by: Julien Tinnes <julien@cr0.org> Signed-off-by: Tavis Ormandy <taviso@sdf.lonestar.org> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: irda/sa1100_ir: fix broken netdev_ops conversion irda/au1k_ir: fix broken netdev_ops conversion pkt_sched: Fix bogon in tasklet_hrtimer changes.
2009-08-24pkt_sched: Fix bogon in tasklet_hrtimer changes.David S. Miller
Reported by Stephen Rothwell, luckily it's harmless: net/sched/sch_api.c: In function 'qdisc_watchdog': net/sched/sch_api.c:460: warning: initialization from incompatible pointer type net/sched/sch_cbq.c: In function 'cbq_undelay': net/sched/sch_cbq.c:595: warning: initialization from incompatible pointer type Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: smc91x: let smc91x work well under netpoll pxaficp-ir: remove incorrect net_device_ops NET: llc, zero sockaddr_llc struct drivers/net: fixed drivers that support netpoll use ndo_start_xmit() netpoll: warning for ndo_start_xmit returns with interrupts enabled net: Fix Micrel KSZ8842 Kconfig description netfilter: xt_quota: fix wrong return value (error case) ipv6: Fix commit 63d9950b08184e6531adceb65f64b429909cc101 (ipv6: Make v4-mapped bindings consistent with IPv4) E100: fix interaction with swiotlb on X86. pkt_sched: Convert CBQ to tasklet_hrtimer. pkt_sched: Convert qdisc_watchdog to tasklet_hrtimer rtl8187: always set MSR_LINK_ENEDCA flag with RTL8187B ibm_newemac: emac_close() needs to call netif_carrier_off() net: fix ks8851 build errors net: Rename MAC platform driver for w90p910 platform yellowfin: Fix buffer underrun after dev_alloc_skb() failure orinoco: correct key bounds check in orinoco_hw_get_tkip_iv mac80211: fix todo lock
2009-08-23NET: llc, zero sockaddr_llc structJiri Slaby
sllc_arphrd member of sockaddr_llc might not be changed. Zero sllc before copying to the above layer's structure. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-23netpoll: warning for ndo_start_xmit returns with interrupts enabledDongdong Deng
WARN_ONCE for ndo_start_xmit() enable interrupts in netpoll_send_skb(), because the NETPOLL API requires that interrupts remain disabled in netpoll_send_skb(). Signed-off-by: Dongdong Deng <dongdong.deng@windriver.com> Acked-by: Matt Mackall <mpm@selenic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-23netfilter: xt_quota: fix wrong return value (error case)Patrick McHardy
Success was indicated on a memory allocation failure, thereby causing a crash due to a later NULL deref. (Affects v2.6.30-rc1 up to here.) Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-23ipv6: Fix commit 63d9950b08184e6531adceb65f64b429909cc101 (ipv6: Make ↵Bruno Prémont
v4-mapped bindings consistent with IPv4) Commit 63d9950b08184e6531adceb65f64b429909cc101 (ipv6: Make v4-mapped bindings consistent with IPv4) changes behavior of inet6_bind() for v4-mapped addresses so it should behave the same way as inet_bind(). During this change setting of err to -EADDRNOTAVAIL got lost: af_inet.c:469 inet_bind() err = -EADDRNOTAVAIL; if (!sysctl_ip_nonlocal_bind && !(inet->freebind || inet->transparent) && addr->sin_addr.s_addr != htonl(INADDR_ANY) && chk_addr_ret != RTN_LOCAL && chk_addr_ret != RTN_MULTICAST && chk_addr_ret != RTN_BROADCAST) goto out; af_inet6.c:463 inet6_bind() if (addr_type == IPV6_ADDR_MAPPED) { int chk_addr_ret; /* Binding to v4-mapped address on a v6-only socket * makes no sense */ if (np->ipv6only) { err = -EINVAL; goto out; } /* Reproduce AF_INET checks to make the bindings consitant */ v4addr = addr->sin6_addr.s6_addr32[3]; chk_addr_ret = inet_addr_type(net, v4addr); if (!sysctl_ip_nonlocal_bind && !(inet->freebind || inet->transparent) && v4addr != htonl(INADDR_ANY) && chk_addr_ret != RTN_LOCAL && chk_addr_ret != RTN_MULTICAST && chk_addr_ret != RTN_BROADCAST) goto out; } else { Signed-off-by Bruno Prémont <bonbons@linux-vserver.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-23pkt_sched: Convert CBQ to tasklet_hrtimer.David S. Miller
This code expects to run in softirq context, and bare hrtimers run in hw IRQ context. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Thomas Gleixner <tglx@linutronix.de>
2009-08-22pkt_sched: Convert qdisc_watchdog to tasklet_hrtimerDavid S. Miller
None of this stuff should execute in hw IRQ context, therefore use a tasklet_hrtimer so that it runs in softirq context. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Thomas Gleixner <tglx@linutronix.de>
2009-08-18Merge branch 'master' of ↵David S. Miller
2009-08-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (60 commits) net: restore gnet_stats_basic to previous definition NETROM: Fix use of static buffer e1000e: fix use of pci_enable_pcie_error_reporting e1000e: WoL does not work on 82577/82578 with manageability enabled cnic: Fix locking in init/exit calls. cnic: Fix locking in start/stop calls. bnx2: Use mutex on slow path cnic calls. cnic: Refine registration with bnx2. cnic: Fix symbol_put_addr() panic on ia64. gre: Fix MTU calculation for bound GRE tunnels pegasus: Add new device ID. drivers/net: fixed drivers that support netpoll use ndo_start_xmit() via-velocity: Fix test of mii_status bit VELOCITY_DUPLEX_FULL rt2x00: fix memory corruption in rf cache, add a sanity check ixgbe: Fix receive on real device when VLANs are configured ixgbe: Do not return 0 in ixgbe_fcoe_ddp() upon FCP_RSP in DDP completion netxen: free napi resources during detach netxen: remove netxen workqueue ixgbe: fix issues setting rx-usecs with legacy interrupts can: fix oops caused by wrong rtnl newlink usage ...
2009-08-17net: restore gnet_stats_basic to previous definitionEric Dumazet
In 5e140dfc1fe87eae27846f193086724806b33c7d "net: reorder struct Qdisc for better SMP performance" the definition of struct gnet_stats_basic changed incompatibly, as copies of this struct are shipped to userland via netlink. Restoring old behavior is not welcome, for performance reason. Fix is to use a private structure for kernel, and teach gnet_stats_copy_basic() to convert from kernel to user land, using legacy structure (struct gnet_stats_basic) Based on a report and initial patch from Michael Spang. Reported-by: Michael Spang <mspang@csclub.uwaterloo.ca> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-17NETROM: Fix use of static bufferRalf Baechle
The static variable used by nr_call_to_digi might result in corruption if multiple threads are trying to usee a node or neighbour via ioctl. Fixed by having the caller pass a structure in. This is safe because nr_add_node rsp. nr_add_neigh will allocate a permanent structure, if needed. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-17net/9p: insulate the client against an invalid error code sent by a 9p serverAbhishek Kulkarni
A looney tunes server sending an invalid error code (which is !IS_ERR_VALUE) can result in a client oops. So fix it by adding a check and converting unknown or invalid error codes to -ESERVERFAULT. Signed-off-by: Abhishek Kulkarni <adkulkar@umail.iu.edu> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2009-08-179p: minor comment fixesAbhishek Kulkarni
Fix the comments -- mostly the improper and/or missing descriptions of function parameters. Signed-off-by: Abhishek Kulkarni <adkulkar@umail.iu.edu> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2009-08-17mac80211: fix todo lockJohannes Berg
The key todo lock can be taken from different locks that require it to be _bh to avoid lock inversion due to (soft)irqs. This should fix the two problems reported by Bob and Gabor: http://mid.gmane.org/20090619113049.GB18956@hash.localnet http://mid.gmane.org/4A3FA376.8020307@openwrt.org Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: Bob Copeland <me@bobcopeland.com> Cc: Gabor Juhos <juhosg@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-14gre: Fix MTU calculation for bound GRE tunnelsTom Goff
The GRE header length should be subtracted when the tunnel MTU is calculated. This just corrects for the associativity change introduced by commit 42aa916265d740d66ac1f17290366e9494c884c2 ("gre: Move MTU setting out of ipgre_tunnel_bind_dev"). Signed-off-by: Tom Goff <thomas.goff@boeing.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-13mac80211: fix panic when splicing unprepared TIDsLuis R. Rodriguez
We splice skbs from the pending queue for a TID onto the local pending queue when tearing down a block ack request. This is not necessary unless we actually have received a request to start a block ack request (rate control, for example). If we never received that request we should not be splicing the tid pending queue as it would be null, causing a panic. Not sure yet how exactly we allowed through a call when the tid state does not have at least HT_ADDBA_REQUESTED_MSK set, that will require some further review as it is not quite obvious. For more information see the bug report: http://bugzilla.kernel.org/show_bug.cgi?id=13922 This fixes this oops: BUG: unable to handle kernel NULL pointer dereference at 00000030 IP: [<f8806c70>] ieee80211_agg_splice_packets+0x40/0xc0 [mac80211] *pdpt = 0000000002d1e001 *pde = 0000000000000000 Thread overran stack, or stack corrupted Oops: 0000 [#1] SMP last sysfs file: /sys/module/aes_generic/initstate Modules linked in: <bleh> Pid: 0, comm: swapper Not tainted (2.6.31-rc5-wl #2) Dell DV051 EIP: 0060:[<f8806c70>] EFLAGS: 00010292 CPU: 0 EIP is at ieee80211_agg_splice_packets+0x40/0xc0 [mac80211] EAX: 00000030 EBX: 0000004c ECX: 00000003 EDX: 00000000 ESI: c1c98000 EDI: f745a1c0 EBP: c076be58 ESP: c076be38 DS: 007b ES: 007b FS: 00d8 GS: 0000 SS: 0068 Process swapper (pid: 0, ti=c076a000 task=c0709160 task.ti=c076a000) Stack: <bleh2> Call Trace: [<f8806edb>] ? ieee80211_stop_tx_ba_cb+0xab/0x150 [mac80211] [<f8802f1e>] ? ieee80211_tasklet_handler+0xce/0x110 [mac80211] [<c04862ff>] ? net_rx_action+0xef/0x1d0 [<c0149378>] ? tasklet_action+0x58/0xc0 [<c014a0f2>] ? __do_softirq+0xc2/0x190 [<c018eb48>] ? handle_IRQ_event+0x58/0x140 [<c01205fe>] ? ack_apic_level+0x7e/0x270 [<c014a1fd>] ? do_softirq+0x3d/0x40 [<c014a345>] ? irq_exit+0x65/0x90 [<c010a6af>] ? do_IRQ+0x4f/0xc0 [<c014a35d>] ? irq_exit+0x7d/0x90 [<c011d547>] ? smp_apic_timer_interrupt+0x57/0x90 [<c01094a9>] ? common_interrupt+0x29/0x30 [<c010fd9e>] ? mwait_idle+0xbe/0x100 [<c0107e42>] ? cpu_idle+0x52/0x90 [<c054b1a5>] ? rest_init+0x55/0x60 [<c077492d>] ? start_kernel+0x315/0x37d [<c07743ce>] ? unknown_bootoption+0x0/0x1f9 [<c0774099>] ? i386_start_kernel+0x79/0x81 Code: <bleh3> EIP: [<f8806c70>] ieee80211_agg_splice_packets+0x40/0xc0 [mac80211] SS:ESP 0068:c076be38 CR2: 0000000000000030 Cc: stable@kernel.org Testedy-by: Jack Lau <jackelectronics@hotmail.com> Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-13Make sock_sendpage() use kernel_sendpage()Linus Torvalds
kernel_sendpage() does the proper default case handling for when the socket doesn't have a native sendpage implementation. Now, arguably this might be something that we could instead solve by just specifying that all protocols should do it themselves at the protocol level, but we really only care about the common protocols. Does anybody really care about sendpage on something like Appletalk? Not likely. Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Julien TINNES <julien@cr0.org> Acked-by: Tavis Ormandy <taviso@sdf.lonestar.org> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-09sctp: fix missing destroy of percpu counter variable in sctp_proc_exit()Rafael Laufer
Commit 1748376b6626acf59c24e9592ac67b3fe2a0e026, net: Use a percpu_counter for sockets_allocated added percpu_counter function calls to sctp_proc_init code path, but forgot to add them to sctp_proc_exit(). This resulted in a following Ooops when performing this test # modprobe sctp # rmmod -f sctp # modprobe sctp [ 573.862512] BUG: unable to handle kernel paging request at f8214a24 [ 573.862518] IP: [<c0308b8f>] __percpu_counter_init+0x3f/0x70 [ 573.862530] *pde = 37010067 *pte = 00000000 [ 573.862534] Oops: 0002 [#1] SMP [ 573.862537] last sysfs file: /sys/module/libcrc32c/initstate [ 573.862540] Modules linked in: sctp(+) crc32c libcrc32c binfmt_misc bridge stp bnep lp snd_hda_codec_analog snd_hda_intel snd_hda_codec snd_hwdep snd_pcm_oss snd_mixer_oss arc4 joydev snd_pcm ecb pcmcia snd_seq_dummy snd_seq_oss iwlagn iwlcore snd_seq_midi snd_rawmidi snd_seq_midi_event yenta_socket rsrc_nonstatic thinkpad_acpi snd_seq snd_timer snd_seq_device mac80211 psmouse sdhci_pci sdhci nvidia(P) ppdev video snd soundcore serio_raw pcspkr iTCO_wdt iTCO_vendor_support led_class ricoh_mmc pcmcia_core intel_agp nvram agpgart usbhid parport_pc parport output snd_page_alloc cfg80211 btusb ohci1394 ieee1394 e1000e [last unloaded: sctp] [ 573.862589] [ 573.862593] Pid: 5373, comm: modprobe Tainted: P R (2.6.31-rc3 #6) 7663B15 [ 573.862596] EIP: 0060:[<c0308b8f>] EFLAGS: 00010286 CPU: 1 [ 573.862599] EIP is at __percpu_counter_init+0x3f/0x70 [ 573.862602] EAX: f8214a20 EBX: f80faa14 ECX: c48c0000 EDX: f80faa20 [ 573.862604] ESI: f80a7000 EDI: 00000000 EBP: f69d5ef0 ESP: f69d5eec [ 573.862606] DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 [ 573.862610] Process modprobe (pid: 5373, ti=f69d4000 task=c2130c70 task.ti=f69d4000) [ 573.862612] Stack: [ 573.862613] 00000000 f69d5f18 f80a70a8 f80fa9fc 00000000 fffffffc f69d5f30 c018e2d4 [ 573.862619] <0> 00000000 f80a7000 00000000 f69d5f88 c010112b 00000000 c07029c0 fffffffb [ 573.862626] <0> 00000000 f69d5f38 c018f83f f69d5f54 c0557cad f80fa860 00000001 c07010c0 [ 573.862634] Call Trace: [ 573.862644] [<f80a70a8>] ? sctp_init+0xa8/0x7d4 [sctp] [ 573.862650] [<c018e2d4>] ? marker_update_probe_range+0x184/0x260 [ 573.862659] [<f80a7000>] ? sctp_init+0x0/0x7d4 [sctp] [ 573.862662] [<c010112b>] ? do_one_initcall+0x2b/0x160 [ 573.862666] [<c018f83f>] ? tracepoint_module_notify+0x2f/0x40 [ 573.862671] [<c0557cad>] ? notifier_call_chain+0x2d/0x70 [ 573.862678] [<c01588fd>] ? __blocking_notifier_call_chain+0x4d/0x60 [ 573.862682] [<c016b2f1>] ? sys_init_module+0xb1/0x1f0 [ 573.862686] [<c0102ffc>] ? sysenter_do_call+0x12/0x28 [ 573.862688] Code: 89 48 08 b8 04 00 00 00 e8 df aa ec ff ba f4 ff ff ff 85 c0 89 43 14 74 31 b8 b0 18 71 c0 e8 19 b9 24 00 a1 c4 18 71 c0 8d 53 0c <89> 50 04 89 43 0c b8 b0 18 71 c0 c7 43 10 c4 18 71 c0 89 15 c4 [ 573.862725] EIP: [<c0308b8f>] __percpu_counter_init+0x3f/0x70 SS:ESP 0068:f69d5eec [ 573.862730] CR2: 00000000f8214a24 [ 573.862734] ---[ end trace 39c4e0b55e7cf54d ]--- Signed-off-by: Rafael Laufer <rlaufer@cisco.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-09can: Fix raw_getname() leakEric Dumazet
raw_getname() can leak 10 bytes of kernel memory to user (two bytes hole between can_family and can_ifindex, 8 bytes at the end of sockaddr_can structure) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Oliver Hartkopp <oliver@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-09Fix xfrm hash collisions by changing __xfrm4_daddr_saddr_hash to hash ↵Jussi Mäki
addresses with addition This patch fixes hash collisions in cases where number of entries have incrementing IP source and destination addresses from single respective subnets (i.e. 192.168.0.1-172.16.0.1, 192.168.0.2-172.16.0.2, and so on.). Signed-off-by: Jussi Maki <joamaki@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-09Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
2009-08-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: net: Fix spinlock use in alloc_netdev_mq()
2009-08-06Merge branch 'for-linus' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/lowpan/lowpan
2009-08-06irda: Fix irda_getname() leakEric Dumazet
irda_getname() can leak kernel memory to user. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-06appletalk: fix atalk_getname() leakEric Dumazet
atalk_getname() can leak 8 bytes of kernel memory to user Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-06netrom: Fix nr_getname() leakEric Dumazet
nr_getname() can leak kernel memory to user. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-06econet: Fix econet_getname() leakEric Dumazet
econet_getname() can leak kernel memory to user. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-06rose: Fix rose_getname() leakEric Dumazet
rose_getname() can leak kernel memory to user. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-06af_ieee802154: provide dummy get/setsockoptDmitry Eremin-Solenikov
Provide dummt get/setsockopt implementations to stop these syscalls from oopsing on our sockets. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
2009-08-06af_ieee802154: fix ioctl processingDmitry Eremin-Solenikov
fix two errors in ioctl processing: 1) if the ioctl isn't supported one should return -ENOIOCTLCMD 2) don't call ndo_do_ioctl if the device doesn't provide it Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
2009-08-05phonet: phonet_device_get() fixEric Dumazet
net/phonet/pn_dev.c: In function `phonet_device_get': net/phonet/pn_dev.c:99: warning: 'dev' might be used uninitialized in this function Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-05dccp: missing destroy of percpu counter variable while unload moduleWei Yongjun
percpu counter dccp_orphan_count is init in dccp_init() by percpu_counter_init() while dccp module is loaded, but the destroy of it is missing while dccp module is unloaded. We can get the kernel WARNING about this. Reproduct by the following commands: $ modprobe dccp $ rmmod dccp $ modprobe dccp WARNING: at lib/list_debug.c:26 __list_add+0x27/0x5c() Hardware name: VMware Virtual Platform list_add corruption. next->prev should be prev (c080c0c4), but was (null). (next =ca7188cc). Modules linked in: dccp(+) nfsd lockd nfs_acl auth_rpcgss exportfs sunrpc Pid: 1956, comm: modprobe Not tainted 2.6.31-rc5 #55 Call Trace: [<c042f8fa>] warn_slowpath_common+0x6a/0x81 [<c053a6cb>] ? __list_add+0x27/0x5c [<c042f94f>] warn_slowpath_fmt+0x29/0x2c [<c053a6cb>] __list_add+0x27/0x5c [<c053c9b3>] __percpu_counter_init+0x4d/0x5d [<ca9c90c7>] dccp_init+0x19/0x2ed [dccp] [<c0401141>] do_one_initcall+0x4f/0x111 [<ca9c90ae>] ? dccp_init+0x0/0x2ed [dccp] [<c06971b5>] ? notifier_call_chain+0x26/0x48 [<c0444943>] ? __blocking_notifier_call_chain+0x45/0x51 [<c04516f7>] sys_init_module+0xac/0x1bd [<c04028e4>] sysenter_do_call+0x12/0x22 Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-05net: Fix spinlock use in alloc_netdev_mq()Ingo Molnar
-tip testing found this lockdep warning: [ 2.272010] calling net_dev_init+0x0/0x164 @ 1 [ 2.276033] device class 'net': registering [ 2.280191] INFO: trying to register non-static key. [ 2.284005] the code is fine but needs lockdep annotation. [ 2.284005] turning off the locking correctness validator. [ 2.284005] Pid: 1, comm: swapper Not tainted 2.6.31-rc5-tip #1145 [ 2.284005] Call Trace: [ 2.284005] [<7958eb4e>] ? printk+0xf/0x11 [ 2.284005] [<7904f83c>] __lock_acquire+0x11b/0x622 [ 2.284005] [<7908c9b7>] ? alloc_debug_processing+0xf9/0x144 [ 2.284005] [<7904e2be>] ? mark_held_locks+0x3a/0x52 [ 2.284005] [<7908dbc4>] ? kmem_cache_alloc+0xa8/0x13f [ 2.284005] [<7904e475>] ? trace_hardirqs_on_caller+0xa2/0xc3 [ 2.284005] [<7904fdf6>] lock_acquire+0xb3/0xd0 [ 2.284005] [<79489678>] ? alloc_netdev_mq+0xf5/0x1ad [ 2.284005] [<79591514>] _spin_lock_bh+0x2d/0x5d [ 2.284005] [<79489678>] ? alloc_netdev_mq+0xf5/0x1ad [ 2.284005] [<79489678>] alloc_netdev_mq+0xf5/0x1ad [ 2.284005] [<793a38f2>] ? loopback_setup+0x0/0x74 [ 2.284005] [<798eecd0>] loopback_net_init+0x20/0x5d [ 2.284005] [<79483efb>] register_pernet_device+0x23/0x4b [ 2.284005] [<798f5c9f>] net_dev_init+0x115/0x164 [ 2.284005] [<7900104f>] do_one_initcall+0x4a/0x11a [ 2.284005] [<798f5b8a>] ? net_dev_init+0x0/0x164 [ 2.284005] [<79066f6d>] ? register_irq_proc+0x8c/0xa8 [ 2.284005] [<798cc29a>] do_basic_setup+0x42/0x52 [ 2.284005] [<798cc30a>] kernel_init+0x60/0xa1 [ 2.284005] [<798cc2aa>] ? kernel_init+0x0/0xa1 [ 2.284005] [<79003e03>] kernel_thread_helper+0x7/0x10 [ 2.284078] device: 'lo': device_add [ 2.288248] initcall net_dev_init+0x0/0x164 returned 0 after 11718 usecs [ 2.292010] calling neigh_init+0x0/0x66 @ 1 [ 2.296010] initcall neigh_init+0x0/0x66 returned 0 after 0 usecs it's using an zero-initialized spinlock. This is a side-effect of: dev_unicast_init(dev); in alloc_netdev_mq() making use of dev->addr_list_lock. The device has just been allocated freshly, it's not accessible anywhere yet so no locking is needed at all - in fact it's wrong to lock it here (the lock isnt initialized yet). This bug was introduced via: | commit a6ac65db2329e7685299666f5f7b6093c7b0f3a0 | Date: Thu Jul 30 01:06:12 2009 +0000 | | net: restore the original spinlock to protect unicast list Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Jiri Pirko <jpirko@redhat.com> Tested-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (47 commits) ehea: Fix napi list corruption on ifconfig down igbvf: Allow VF driver to correctly recognize failure to set mac 3c59x: Fix build failure with gcc 3.2 sky2: Avoid transmits during sky2_down() iwlagn: do not send key clear commands when rfkill enabled libertas: Read buffer overflow drivers/net/wireless: introduce missing kfree drivers/net/wireless/iwlwifi: introduce missing kfree zd1211rw: fix unaligned access in zd_mac_rx cfg80211: fix regression on beacon world roaming feature cfg80211: add two missing NULL pointer checks ixgbe: Patch to modify 82598 PCIe completion timeout values bluetooth: rfcomm_init bug fix mlx4_en: Fix double pci unmapping. mISDN: Fix handling of receive buffer size in L1oIP pcnet32: VLB support fixes pcnet32: remove superfluous NULL pointer check in pcnet32_probe1() net: restore the original spinlock to protect unicast list netxen: fix coherent dma mask setting mISDN: Read buffer overflow ...
2009-08-03Merge branch 'master' of ↵David S. Miller
2009-08-03cfg80211: fix regression on beacon world roaming featureLuis R. Rodriguez
A regression was added through patch a4ed90d6: "cfg80211: respect API on orig_flags on channel for beacon hint" We did indeed respect _orig flags but the intention was not clearly stated in the commit log. This patch fixes firmware issues picked up by iwlwifi when we lift passive scan of beaconing restrictions on channels its EEPROM has been configured to always enable. By doing so though we also disallowed beacon hints on devices registering their wiphy with custom world regulatory domains enabled, this happens to be currently ath5k, ath9k and ar9170. The passive scan and beacon restrictions on those devices would never be lifted even if we did find a beacon and the hardware did support such enhancements when world roaming. Since Johannes indicates iwlwifi firmware cannot be changed to allow beacon hinting we set up a flag now to specifically allow drivers to disable beacon hints for devices which cannot use them. We enable the flag on iwlwifi to disable beacon hints and by default enable it for all other drivers. It should be noted beacon hints lift passive scan flags and beacon restrictions when we receive a beacon from an AP on any 5 GHz non-DFS channels, and channels 12-14 on the 2.4 GHz band. We don't bother with channels 1-11 as those channels are allowed world wide. This should fix world roaming for ath5k, ath9k and ar9170, thereby improving scan time when we receive the first beacon from any AP, and also enabling beaconing operation (AP/IBSS/Mesh) on cards which would otherwise not be allowed to do so. Drivers not using custom regulatory stuff (wiphy_apply_custom_regulatory()) were not affected by this as the orig_flags for the channels would have been cleared upon wiphy registration. I tested this with a world roaming ath5k card. Cc: Jouni Malinen <jouni.malinen@atheros.com> Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-03cfg80211: add two missing NULL pointer checksJohannes Berg
These pointers can be NULL, the is_mesh() case isn't ever hit in the current kernel, but cmp_ies() can be hit under certain conditions. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: stable@kernel.org [2.6.29, 2.6.30] Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-03bluetooth: rfcomm_init bug fixDave Young
rfcomm tty may be used before rfcomm_tty_driver initilized, The problem is that now socket layer init before tty layer, if userspace program do socket callback right here then oops will happen. reporting in: http://marc.info/?l=linux-bluetooth&m=124404919324542&w=2 make 3 changes: 1. remove #ifdef in rfcomm/core.c, make it blank function when rfcomm tty not selected in rfcomm.h 2. tune the rfcomm_init error patch to ensure tty driver initilized before rfcomm socket usage. 3. remove __exit for rfcomm_cleanup_sockets because above change need call it in a __init function. Reported-by: Oliver Hartkopp <oliver@hartkopp.net> Tested-by: Oliver Hartkopp <oliver@hartkopp.net> Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-02net: restore the original spinlock to protect unicast listJiri Pirko
There is a path when an assetion in dev_unicast_sync() appears. igmp6_group_added -> dev_mc_add -> __dev_set_rx_mode -> -> vlan_dev_set_rx_mode -> dev_unicast_sync Therefore we cannot protect this list with rtnl. This patch restores the original protecting this list with spinlock. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Tested-by: Meelis Roos <mroos@linux.ee> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-02net: net_assign_generic() fixEric Dumazet
memcpy() should take into account size of pointers, not only number of pointers to copy. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-30ipv4: ARP neigh procfs buffer overflowroel kluin
If arp_format_neigh_entry() can be called with n->dev->addr_len == 0, then a write to hbuffer[-1] occurs. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-30net/netlabel: Add kmalloc NULL testsJulia Lawall
The test on map4 should be a test on map6. The semantic match that finds this problem is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ expression *x; identifier f; constant char *C; @@ x = \(kmalloc\|kcalloc\|kzalloc\)(...); ... when != x == NULL when != x != NULL when != (x || ...) ( kfree(x) | f(...,C,...,x,...) | *f(...,x,...) | *x->f ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-30Merge branch 'master' of ↵David S. Miller
2009-07-29net-dccp: suppress warning about large allocations from DCCPMel Gorman
The DCCP protocol tries to allocate some large hash tables during initialisation using the largest size possible. This can be larger than what the page allocator can provide so it prints a warning. However, the caller is able to handle the situation so this patch suppresses the warning. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-29mac80211: fix suspendJohannes Berg
Jan reported that his b43-based laptop hangs during suspend. The problem turned out to be mac80211 asking the driver to stop the hardware before removing interfaces, and interface removal caused b43 to touch the hardware (while down, which causes the hang). This patch fixes mac80211 to do reorder these operations to have them in the correct order -- first remove interfaces and then stop the hardware. Some more code is necessary to be able to do so in a race-free manner, in particular it is necessary to not process frames received during quiescing. Fixes http://bugzilla.kernel.org/show_bug.cgi?id=13337. Reported-by: Jan Scholz <scholz@fias.uni-frankfurt.de> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (45 commits) cnic: Fix ISCSI_KEVENT_IF_DOWN message handling. net: irda: init spinlock after memcpy ixgbe: fix for 82599 errata marking UDP checksum errors r8169: WakeOnLan fix for the 8168 netxen: reset ring consumer during cleanup net/bridge: use kobject_put to release kobject in br_add_if error path smc91x.h: add config for Nomadik evaluation kit NET: ROSE: Don't use static buffer. eepro: Read buffer overflow tokenring: Read buffer overflow at1700: Read buffer overflow fealnx: Write outside array bounds ixgbe: remove unnecessary call to device_init_wakeup ixgbe: Don't priority tag control frames in DCB mode ixgbe: Enable FCoE offload when DCB is enabled for 82599 net: Rework mdio-ofgpio driver to use of_mdio infrastructure register at91_ether using platform_driver_probe skge: Enable WoL by default if supported net: KS8851 needs to depend on MII be2net: Bug fix in the non-lro path. Size of received packet was not updated in statistics properly. ...
