This uses the NETLINK NETLINK_NFLOG family to log a single message
when the quota limit is reached.
It uses the same packet type as ipt_ULOG, but
- never copies skb data,
- uses 112 as the event number (ULOG's +1)
It doesn't log if the module param "event_num" is 0.
Change-Id: I6f31736b568bb31a4ff0b9ac2ee58380e6b675ca
Signed-off-by: JP Abgrall <jpa@google.com>
The xt_quota2 came from
http://sourceforge.net/projects/xtables-addons/develop
It needed tweaking for it to compile within the kernel tree.
Fixed kmalloc() and create_proc_entry() invocations within
a non-interruptible context.
Removed useless copying of current quota back to the iptable's
struct matchinfo:
- those are per CPU: they will change randomly based on which
cpu gets to update the value.
- they prevent matching a rule: e.g.
-A chain -m quota2 --name q1 --quota 123
can't be followed by
-D chain -m quota2 --name q1 --quota 123
as the 123 will be compared to the struct matchinfo's quota member.
Change-Id: I021d3b743db3b22158cc49acb5c94d905b501492
The original xt_quota in the kernel is plain broken:
- counts quota at a per CPU level
(was written back when ubiquitous SMP was just a dream)
- provides no way to count across IPV4/IPV6.
This patch is the original unaltered code from:
at commit e84391ce665cef046967f796dd91026851d6bbf3
Change-Id: I19d49858840effee9ecf6cff03c23b45a97efdeb
This patch adds support for disconnecting the link when SMP procedure
takes more than 30 seconds.
SMP begins when either the Pairing Request command is sent or the
Pairing Response is received, and it ends when the link is encrypted
(or terminated). Vol 3, Part H Section 3.4.
Signed-off-by: Vinicius Costa Gomes <vinicius.gomes@openbossa.org>
Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
This time the symptom is caused by tagging the same socket twice
without untagging it in between.
This would cause it to not unlock, and return.
When processing args passed to the procfs ctrl, if the tag was
invalid it would exit without releasing the spin_lock...
Bye bye scheduling.
Change-Id: Ic1480ae9d37bba687586094cf6d0274db9c5b28a
(This is a direct cherry-pick from 2.6.39: I3b925802)
Fixed procreader for /proc/net/xt_qtaguid/ctrl: it would just
fill the output with the same entry.
Simplify the **start handling.
Change-Id: I3b92580228f2b57795bb2d0d6197fc95ab6be552
(This is a direct cherry pick from 2.6.39: Id2a9912b)
* xt_socket_get_sk() returns invalid sockets when the sk_state is TCP_TIME_WAIT.
Added detection of time-wait.
* Added more constrained usage: qtaguid insures that xt_socket_get*_sk() is
not invoked for unexpected hooks or protocols (but I have not seen those
active at the point where the returned sk is bad).
Change-Id: Id2a9912bb451a3e59d012fc55bbbd40fbb90693f
ip_route_output_key can return an ERR_PTR, don't dereference it.
Change-Id: I6b86a451b2bdb33873d79b3cf90c11dbe72bc081
Signed-off-by: Colin Cross <ccross@android.com>
Allow the REJECT --reject-with icmp*blabla to also set the matching error
locally on the socket affected by the reject.
This allows the process to see an error almost as if it received it
via ICMP.
It avoids the local process who's ingress packet is rejected to have to
wait for a pseudo-eternity until some timeout kicks in.
Ideally, this should be enabled with a new iptables flag similar to
--reject-with-sock-err
For now it is enabled with CONFIG_IP*_NF_TARGET_REJECT_SKERR option.
Change-Id: I649a4fd5940029ec0b3233e5abb205da6984891e
This module allows tracking stats at the socket level for given UIDs.
It replaces xt_owner.
If the --uid-owner is not specified, it will just count stats based on
who the skb belongs to. This will even happen on incoming skbs as it
looks into the skb via xt_socket magic to see who owns it.
If an skb is lost, it will be assigned to uid=0.
To control what sockets of what UIDs are tagged by what, one uses:
echo t $sock_fd $accounting_tag $the_billed_uid \
So whenever an skb belongs to a sock_fd, it will be accounted against
$the_billed_uid
and matching stats will show up under the uid with the given
$accounting_tag.
Because the number of allocations for the stats structs is not that big:
~500 apps * 32 per app
we'll just do it atomic. This avoids walking lists many times, and
the fancy worker thread handling. Slabs will grow when needed later.
It use netdevice and inetaddr notifications instead of hooks in the core dev
code to track when a device comes and goes. This removes the need for
exposed iface_stat.h.
Put procfs dirs in /proc/net/xt_qtaguid/
ctrl
stats
iface_stat/<iface>/...
The uid stats are obtainable in ./stats.
Change-Id: I01af4fd91c8de651668d3decb76d9bdc1e343919
The socket matching function has some nifty logic to get the struct sock
from the skb or from the connection tracker.
We export this so other xt_* can use it, similarly to ho how
xt_socket uses nf_tproxy_get_sock.
Change-Id: I11c58f59087e7f7ae09e4abd4b937cd3370fa2fd
__u16 sco_pkt_type is introduced to struct sockaddr_sco. It allows bitwise
selection of SCO/eSCO packet types. Currently those bits are:
0x0001 HV1 may be used.
0x0002 HV2 may be used.
0x0004 HV3 may be used.
0x0008 EV3 may be used.
0x0010 EV4 may be used.
0x0020 EV5 may be used.
0x0040 2-EV3 may be used.
0x0080 3-EV3 may be used.
0x0100 2-EV5 may be used.
0x0200 3-EV5 may be used.
This is similar to the Packet Type parameter in the HCI Setup Synchronous
Connection Command, except that we are not reversing the logic on the EDR bits.
This makes the use of sco_pkt_tpye forward portable for the use case of
white-listing packet types, which we expect will be the primary use case.
If sco_pkt_type is zero, or userspace uses the old struct sockaddr_sco,
then the default behavior is to allow all packet types.
Packet type selection is just a request made to the Bluetooth chipset, and
it is up to the link manager on the chipset to negiotiate and decide on the
actual packet types used. Furthermore, when a SCO/eSCO connection is eventually
made there is no way for the host stack to determine which packet type was used
(however it is possible to get the link type of SCO or eSCO).
sco_pkt_type is ignored for incoming SCO connections. It is possible
to add this in the future as a parameter to the Accept Synchronous Connection
Command, however its a little trickier because the kernel does not
currently preserve sockaddr_sco data between userspace calls to accept().
The most common use for sco_pkt_type will be to white-list only SCO packets,
which can be done with the hci.h constant SCO_ESCO_MASK.
This patch is motivated by broken Bluetooth carkits such as the Motorolo
HF850 (it claims to support eSCO, but will actually reject eSCO connections
after 5 seconds) and the 2007/2008 Infiniti G35/37 (fails to route audio
if a 2-EV5 packet type is negiotiated). With this patch userspace can maintain
a list of compatible packet types to workaround remote devices such as these.
Based on a patch by Marcel Holtmann.
Rebased to 2.6.39.
Change-Id: Ide1c89574fa4f6f1b9218282e1af17051eb86315
Signed-off-by: Nick Pelly <npelly@google.com>
Change-Id: I247b8dc2e32bb83e731209928600e92892dd042c
On Linux, when an interface goes down all its IPv6
addresses are deleted, so relying on knowing the previous
IPv6 addresses on the interface is brittle. Instead,
support nuking all sockets that are bound to IP addresses
that are not configured and up on the system. This
behaviour is triggered by specifying the unspecified
address (:: or 0.0.0.0). If an IP address is specified, the
behaviour is unchanged, except the ioctl now supports IPv6
as well as IPv4.
Signed-off-by: Lorenzo Colitti <lorenzo@google.com>
Signed-off-by: Dmitry Shmidt <dimitrysh@google.com>
When enabled, tracks the frequency of network transmissions
(inbound and outbound) and buckets them accordingly.
Buckets are determined by time between network activity.
Each bucket represents the number of network transmisions that were
N sec or longer apart. Where N is defined as 1 << bucket index.
This network pattern tracking is particularly useful for wireless
networks (ie: 3G) where batching network activity closely together
is more power efficient than far apart.
New file: /proc/net/stat/activity
output:
Min Bucket(sec) Count
1 7
2 0
4 1
8 0
16 0
32 2
64 1
128 0
Change-Id: I4c4cd8627b872a55f326b1715c51bc3bdd6e8d92
Signed-off-by: Mike Chan <mike@android.com>
This provides userspace debugging tools access to ACL flow control state.
This is to support the Motorola HF850 carkit which reports the error code 0x10
for an eSCO attempt, even though it advertises eSCO support. Here is the
hcidump:
2009-09-22 15:40:24.492391 < HCI Command: Setup Synchronous Connection
(0x01|0x0028) plen 17
handle 1 voice setting 0x0060
2009-09-22 15:40:24.493002 > HCI Event: Command Status (0x0f) plen 4
Setup Synchronous Connection (0x01|0x0028) status 0x00 ncmd 1
2009-09-22 15:40:30.594869 > HCI Event: Synchronous Connect Complete (0x2c)
plen 17
status 0x10 handle 257 bdaddr 00:50:CD:20:C6:84 type eSCO
Error: Connection Accept Timeout Exceeded
With this patch we will retry with a SCO connection, which succeeds.
Unfortunately the Moto HF850 also takes 5 seconds to return the error for the
eSCO attempt, so it will still take 5 seconds to fallback to SCO with this
patch.
This fixes a bug where shutdown() and close() on a rfcomm socket during ACL
connection would not cause HCI Create Connection Cancel.
Some platforms do not want to power down rfkill devices on suspend.
Change-Id: I62a11630521c636d54a4a02ab9037a43435925f5
Signed-off-by: Chia-chi Yeh <chiachi@android.com>
Add a family of knobs to /sys/kernel/ipv4 for controlling the TCP window size:
tcp_wmem_min
tcp_wmem_def
tcp_wmem_max
tcp_rmem_min
tcp_rmem_def
tcp_rmem_max
This six values mirror the sysctl knobs in /proc/sys/net/ipv4/tcp_wmem and
/proc/sys/net/ipv4/tcp_rmem.
Sysfs, unlike sysctl, allows us to set and manage the files' permissions and
owners.
Signed-off-by: Robert Love <rlove@google.com>
Introduce a new socket ioctl, SIOCKILLADDR, that nukes all sockets
bound to the same local address. This is useful in situations with
dynamic IPs, to kill stuck connections.
Signed-off-by: Brian Swetland <swetland@google.com>
net: fix tcp_v4_nuke_addr
Signed-off-by: Dima Zavin <dima@android.com>
net: ipv4: Fix a spinlock recursion bug in tcp_v4_nuke.
We can't hold the lock while calling to tcp_done(), so we drop
it before calling. We then have to start at the top of the chain again.
net: ipv4: Fix race in tcp_v4_nuke_addr().
To fix a recursive deadlock in 2.6.29, we stopped holding the hash table lock
across tcp_done() calls. This fixed the deadlock, but introduced a race where
the socket could die or change state.
Fix: Before unlocking the hash table, we grab a reference to the socket. We
can then unlock the hash table without risk of the socket going away. We then
lock the socket, which is safe because it is pinned. We can then call
tcp_done() without recursive deadlock and without race. Upon return, we unlock
the socket and then unpin it, killing it.
Change-Id: Idcdae072b48238b01bdbc8823b60310f1976e045
Acked-by: Dima Zavin <dima@android.com>
ipv4: disable bottom halves around call to tcp_done().
ipv4: Move sk_error_report inside bh_lock_sock in tcp_v4_nuke_addr
When sk_error_report is called, it wakes up the user-space thread, which then
calls tcp_close. When the tcp_close is interrupted by the tcp_v4_nuke_addr
ioctl thread running tcp_done, it leaks 392 bytes and triggers a WARN_ON.
This patch moves the call to sk_error_report inside the bh_lock_sock, which
matches the locking used in tcp_v4_err.
With CONFIG_ANDROID_PARANOID_NETWORK, require specific uids/gids to instantiate
network sockets.
paranoid networking: Use in_egroup_p() to check group membership
The previous group_search() caused trouble for partners with module builds.
in_egroup_p() is also cleaner.
Fix 2.6.29 build.
Signed-off-by: Arve Hjønnevåg <arve@android.com>
net: Fix compilation of the IPv6 module
Fix compilation of the IPv6 module -- current->euid does not exist anymore,
current_euid() is what needs to be used.
Signed-off-by: Steinar H. Gunderson <sesse@google.com>
commit 93840ac40bb0d0f177ef8af74e64671be67e8c37 upstream.
Function tt_response_fill_table() actually uses a tt_local_entry pointer to
iterate either over the local or the global table entries (it depends on the
what hash table is passed as argument). To iterate over such entries the
hlist_for_each_entry_rcu() macro has to access their "hash_entry" field which
MUST be at the same position in both the tt_global/local_entry structures.
Reported-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de>
Signed-off-by: Antonio Quartulli <ordex@autistici.org>
Signed-off-by: Marek Lindner <lindner_marek@yahoo.de>
commit 6e8014947d6469df1566e9e253805557c5c0e4e0 upstream.
After removing the batman-adv module, the hash may be already gone
when tt_global_del_orig() tries to clean the hash. This patch adds
a sanity check to avoid this.
Signed-off-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de>
Tested-by: Alexey Fisher <bug-track@fisher-privat.net>
commit 531027fcddbcf81c9937dd04f08a7e8f11fd47d2 upstream.
struct tt_global_entry holds a reference to an orig_node which must be
decremented before deallocating the structure.
commit 9d8523931f7f5eb8900077f0da0fbe6b8ad0010b upstream.
In the TT_RESPONSE packet, the number of carried entries is not correctly set.
This leads to a wrong interpretation of the packet payload on the receiver side
causing random entries to be added to the global translation table. Therefore
the latter gets always corrupted, triggering a table recovery all the time.
commit 31901264511cf20c5ed33b8649a3ca9ce28df60b upstream.
Currently the counter of tt_local_entry structures (tt_local_num) is incremented
each time the tt_local_reset_flags() is invoked causing the node to send wrong
TT_REPONSE packets containing a copy of non-initialised memory thus corrupting
other nodes global translation table and making higher level communication
impossible.
Reported-by: Junkeun Song <jun361@gmail.com>
Acked-by: Junkeun Song <jun361@gmail.com>
commit 731abb9cb27aef6013ce60808a04e04a545f3f4e upstream.
Commit 1c5cae815d removed an explicit call to dev_alloc_name in ip6_tnl_create
because register_netdevice will now create a valid name. This works for the
net_device itself.
However the tunnel keeps a copy of the name in the parms structure for the
ip6_tnl associated with the tunnel. parms.name is set by copying the net_device
name in ip6_tnl_dev_init_gen. That function is called from ip6_tnl_dev_init in
ip6_tnl_create, but it is done before register_netdevice is called so the name
is set to a bogus value in the parms.name structure.
This shows up if you do a simple tunnel add, followed by a tunnel show:
[root@localhost ~]# ip -6 tunnel add remote fec0::100 local fec0::200
[root@localhost ~]# ip -6 tunnel show
ip6tnl0: ipv6/ipv6 remote :: local :: encaplimit 0 hoplimit 0 tclass 0x00 flowlabel 0x00000 (flowinfo 0x00000000)
ip6tnl%d: ipv6/ipv6 remote fec0::100 local fec0::200 encaplimit 4 hoplimit 64 tclass 0x00 flowlabel 0x00000 (flowinfo 0x00000000)
[root@localhost ~]#
Fix this by moving the strcpy out of ip6_tnl_dev_init_gen, and calling it after
register_netdevice has successfully returned.
Signed-off-by: Josh Boyer <jwboyer@redhat.com>
commit 58ebacc66bd11be2327edcefc79de94bd6f5bb4a upstream.
Commit 4d9d88d1 by Scott James Remnant <keybuk@google.com> added
the .uevent() callback for the regulatory device used during
the platform device registration. The change was done to account
for queuing up udev change requests through udevadm triggers.
The change also meant that upon regulatory core exit we will now
send a uevent() but the uevent() callback, reg_device_uevent(),
also accessed last_request. Right before commiting device suicide
we free'd last_request but never set it to NULL so
platform_device_unregister() would lead to bogus kernel paging
request. Fix this and also simply supress uevents right before
we commit suicide as they are pointless.
This fix is required for kernels >= v2.6.39
$ git describe --contains 4d9d88d1
v2.6.39-rc1~468^2~25^2^2~21
The impact of not having this present is that a bogus paging
access may occur (only read) upon cfg80211 unload time. You
may also get this BUG complaint below. Although Johannes
could not reproduce the issue this fix is theoretically correct.
mac80211_hwsim: unregister radios
mac80211_hwsim: closing netlink
BUG: unable to handle kernel paging request at ffff88001a06b5ab
IP: [<ffffffffa030df9a>] reg_device_uevent+0x1a/0x50 [cfg80211]
PGD 1836063 PUD 183a063 PMD 1ffcb067 PTE 1a06b160
Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC
CPU 0
Modules linked in: cfg80211(-) [last unloaded: mac80211]
Pid: 2279, comm: rmmod Tainted: G W 3.1.0-wl+ #663 Bochs Bochs
RIP: 0010:[<ffffffffa030df9a>] [<ffffffffa030df9a>] reg_device_uevent+0x1a/0x50 [cfg80211]
RSP: 0000:ffff88001c5f9d58 EFLAGS: 00010286
RAX: 0000000000000000 RBX: ffff88001d2eda88 RCX: ffff88001c7468fc
RDX: ffff88001a06b5a0 RSI: ffff88001c7467b0 RDI: ffff88001c7467b0
RBP: ffff88001c5f9d58 R08: 000000000000ffff R09: 000000000000ffff
R10: 0000000000000000 R11: 0000000000000001 R12: ffff88001c7467b0
R13: ffff88001d2eda78 R14: ffffffff8164a840 R15: 0000000000000001
FS: 00007f8a91d8a6e0(0000) GS:ffff88001fc00000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: ffff88001a06b5ab CR3: 000000001c62e000 CR4: 00000000000006f0
Process rmmod (pid: 2279, threadinfo ffff88001c5f8000, task ffff88000023c780)
Stack:
ffff88001c5f9d98 ffffffff812ff7e5 ffffffff8176ab3d ffff88001c7468c2
000000000000ffff ffff88001d2eda88 ffff88001c7467b0 ffff880000114820
ffff88001c5f9e38 ffffffff81241dc7 ffff88001c5f9db8 ffffffff81040189
Call Trace:
[<ffffffff812ff7e5>] dev_uevent+0xc5/0x170
[<ffffffff81241dc7>] kobject_uevent_env+0x1f7/0x490
[<ffffffff81040189>] ? sub_preempt_count+0x29/0x60
[<ffffffff814cab1a>] ? _raw_spin_unlock_irqrestore+0x4a/0x90
[<ffffffff81305307>] ? devres_release_all+0x27/0x60
[<ffffffff8124206b>] kobject_uevent+0xb/0x10
[<ffffffff812fee27>] device_del+0x157/0x1b0
[<ffffffff8130377d>] platform_device_del+0x1d/0x90
[<ffffffff81303b76>] platform_device_unregister+0x16/0x30
[<ffffffffa030fffd>] regulatory_exit+0x5d/0x180 [cfg80211]
[<ffffffffa032bec3>] cfg80211_exit+0x2b/0x45 [cfg80211]
[<ffffffff8109a84c>] sys_delete_module+0x16c/0x220
[<ffffffff8108a23e>] ? trace_hardirqs_on_caller+0x7e/0x120
[<ffffffff814cba02>] system_call_fastpath+0x16/0x1b
Code: <all your base are belong to me>
RIP [<ffffffffa030df9a>] reg_device_uevent+0x1a/0x50 [cfg80211]
RSP <ffff88001c5f9d58>
---[ end trace 147c5099a411e8c0 ]---
Reported-by: Johannes Berg <johannes@sipsolutions.net>
Cc: Scott James Remnant <keybuk@google.com>
Signed-off-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com>
commit 6c7394197af90f6a332180e33f5d025d3037d883 upstream.
Since the NL80211_ATTR_HT_CAPABILITY attribute is
used as a struct, it needs a minimum, not maximum
length. Enforce that properly. Not doing so could
potentially lead to reading after the buffer.
commit 5b2bbf75a24d6b06afff6de0eb4819413fd81971 upstream.
ieee80211_probereq_get() can return NULL in
which case we should clean up & return NULL
in ieee80211_build_probe_req() as well.
commit f8d1ccf15568268c76f913b45ecdd33134387f1a upstream.
When receiving failed PLCP frames is enabled, there
won't be a rate pointer when we add the radiotap
header and thus the kernel will crash. Fix this by
not assuming the rate pointer is always valid. It's
still always valid for frames that have good PLCP
though, and that is checked & enforced.
This was broken by my
commit fc88518916793af8ad6a02e05ff254d95c36d875
Author: Johannes Berg <johannes.berg@intel.com>
Date: Fri Jul 30 13:23:12 2010 +0200
mac80211: don't check rates on PLCP error frames
where I removed the check in this case but didn't
take into account that the rate info would be used.
Reported-by: Xiaokang Qin <xiaokang.qin@intel.com>
commit 05cb91085760ca378f28fc274fbf77fc4fd9886c upstream.
Only AID values 1-2007 are valid, but some APs have been
found to send random bogus values, in the reported case an
AP that was sending the AID field value 0xffff, an AID of
0x3fff (16383).
There isn't much we can do but disable powersave since
there's no way it can work properly in this case.
Reported-by: Bill C Riemers <briemers@redhat.com>
commit 6911bf0453e0d6ea8eb694a4ce67a68d071c538e upstream.
When going back on-channel, we should reconfigure
the hw iff the hardware is not already configured
to the operational channel.
Signed-off-by: Eliad Peller <eliad@wizery.com>
commit eaa7af2ae582c9a8c51b374c48d5970b748a5ce2 upstream.
The offchannel code is currently broken - we should
remain_off_channel if the work was started, and
the work's channel and channel_type are the same
as local->tmp_channel and local->tmp_channel_type.
However, if wk->chan_type and local->tmp_channel_type
coexist (e.g. have the same channel type), we won't
remain_off_channel.
This behavior was introduced by commit da2fd1f
("mac80211: Allow work items to use existing
channel type.")
Tested-by: Ben Greear <greearb@candelatech.com>
commit dc6f55e9f8dac4b6479be67c5c9128ad37bb491f upstream.
The sunrpc layer keeps a cache of recently used credentials and
'unx_match' is used to find the credential which matches the current
process.
However unx_match allows a match when the cached credential has extra
groups at the end of uc_gids list which are not in the process group list.
So if a process with a list of (say) 4 group accesses a file and gains
access because of the last group in the list, then another process
with the same uid and gid, and a gid list being the first tree of the
gids of the original process tries to access the file, it will be
granted access even though it shouldn't as the wrong rpc credential
will be used.
Signed-off-by: NeilBrown <neilb@suse.de>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
[ Upstream commit b0691c8ee7c28a72748ff32e91b165ec12ae4de6 ]
[ Upstream commit 7011687f0f2f12cc348f6a693fafe63d89167eac ]
in func icmp6_dst_alloc,dst_metric_set call ipv6_cow_metrics to set metric.
ipv6_cow_metrics may will call rt6_bind_peer to set rt6_info->rt6i_peer.
So,we should move ipv6_addr_copy before dst_metric_set to make sure rt6_bind_peer success.
Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com>
[ Upstream commit b73233960a59ee66e09d642f13d0592b13651e94 ]
There is bug in commit 5e2b61f(ipv4: Remove flowi from struct rtable).
It makes xfrm4_fill_dst() modify wrong data structure.
Signed-off-by: Zheng Yan <zheng.z.yan@intel.com>
Reported-by: Kim Phillips <kim.phillips@freescale.com>
commit da92b194cc36b5dc1fbd85206aeeffd80bee0c39 upstream.
The pair of functions,
* skb_clone_tx_timestamp()
* skb_complete_tx_timestamp()
were designed to allow timestamping in PHY devices. The first
function, called during the MAC driver's hard_xmit method, identifies
PTP protocol packets, clones them, and gives them to the PHY device
driver. The PHY driver may hold onto the packet and deliver it at a
later time using the second function, which adds the packet to the
socket's error queue.
As pointed out by Johannes, nothing prevents the socket from
disappearing while the cloned packet is sitting in the PHY driver
awaiting a timestamp. This patch fixes the issue by taking a reference
on the socket for each such packet. In addition, the comments
regarding the usage of these function are expanded to highlight the
rule that PHY drivers must use skb_complete_tx_timestamp() to release
the packet, in order to release the socket reference, too.
These functions first appeared in v2.6.36.
Signed-off-by: Richard Cochran <richard.cochran@omicron.at>
Reviewed-by: Johannes Berg <johannes@sipsolutions.net>
commit 28a1bcdb57d50f3038a255741ecc83e391e5282e upstream.
When I introduced in-kernel off-channel TX I
introduced a bug -- the work can't be canceled
again because the code clear the skb pointer.
Fix this by keeping track separately of whether
TX status has already been reported.
Reported-by: Jouni Malinen <j@w1.fi>
Tested-by: Jouni Malinen <j@w1.fi>
commit d2237d35748e7f448a9c2d9dc6a85ef637466e24 upstream.
Renato Westphal noticed that since commit a2835763e130c343ace5320c20d33c281e7097b7
"rtnetlink: handle rtnl_link netlink notifications manually" was merged
we no longer send a netlink message when a networking device is moved
from one network namespace to another.
Fix this by adding the missing manual notification in dev_change_net_namespaces.
Since all network devices that are processed by dev_change_net_namspaces are
in the initialized state the complicated tests that guard the manual
rtmsg_ifinfo calls in rollback_registered and register_netdevice are
unnecessary and we can just perform a plain notification.
Tested-by: Renato Westphal <renatowestphal@gmail.com>
commit c1225158a8dad9e9d5eee8a17dbbd9c7cda05ab9 upstream.
The same function is used by idmap, gss and blocklayout code. Make it
generic.
Signed-off-by: Peng Tao <peng_tao@emc.com>
Signed-off-by: Jim Rees <rees@umich.edu>
commit 08613e4626c06ca408fc55071f6aedee36986a87 upstream.
The caif code will register its own pernet_operations, and then register
a netdevice_notifier. Each time the netdevice_notifier is triggered,
it'll do some stuff... including a lookup of its own pernet stuff with
net_generic().
If the net_generic() call ever returns NULL, the caif code will BUG().
That doesn't seem *so* unreasonable, I suppose — it does seem like it
should never happen.
However, it *does* happen. When we clone a network namespace,
setup_net() runs through all the pernet_operations one at a time. It
gets to loopback before it gets to caif. And loopback_net_init()
registers a netdevice... while caif hasn't been initialised. So the caif
netdevice notifier triggers, and immediately goes BUG().
We could imagine a complex and overengineered solution to this generic
class of problems, but this patch takes the simple approach. It just
makes caif_device_notify() *not* go looking for its pernet data
structures if the device it's being notified about isn't a caif device
in the first place.
Acked-by: Sjur Brændeland <sjur.brandeland@stericsson.com>
we should decrease ops->unresolved_rules when deleting a unresolved rule.
The transparent socket option setting was not copied to the time wait
socket when an inet socket was being replaced by a time wait socket. This
broke the --transparent option of the socket match and may have caused
that FIN packets belonging to sockets in FIN_WAIT2 or TIME_WAIT state
were being dropped by the packet filter.
Signed-off-by: KOVACS Krisztian <hidden@balabit.hu>
