path: root/net
2011-01-20kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERTDavid Rientjes
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option is used to configure any non-standard kernel with a much larger scope than only small devices. This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes references to the option throughout the kernel. A new CONFIG_EMBEDDED option is added that automatically selects CONFIG_EXPERT when enabled and can be used in the future to isolate options that should only be considered for embedded systems (RISC architectures, SLOB, etc). Calling the option "EXPERT" more accurately represents its intention: only expert users who understand the impact of the configuration changes they are making should enable it. Reviewed-by: Ingo Molnar <mingo@elte.hu> Acked-by: David Woodhouse <david.woodhouse@intel.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Greg KH <gregkh@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <axboe@kernel.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Robin Holt <holt@sgi.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (41 commits) sctp: user perfect name for Delayed SACK Timer option net: fix can_checksum_protocol() arguments swap Revert "netlink: test for all flags of the NLM_F_DUMP composite" gianfar: Fix misleading indentation in startup_gfar() net/irda/sh_irda: return to RX mode when TX error net offloading: Do not mask out NETIF_F_HW_VLAN_TX for vlan. USB CDC NCM: tx_fixup() race condition fix ns83820: Avoid bad pointer deref in ns83820_init_one(). ipv6: Silence privacy extensions initialization bnx2x: Update bnx2x version to 1.62.00-4 bnx2x: Fix AER setting for BCM57712 bnx2x: Fix BCM84823 LED behavior bnx2x: Mark full duplex on some external PHYs bnx2x: Fix BCM8073/BCM8727 microcode loading bnx2x: LED fix for BCM8727 over BCM57712 bnx2x: Common init will be executed only once after POR bnx2x: Swap BCM8073 PHY polarity if required iwlwifi: fix valid chain reading from EEPROM ath5k: fix locking in tx_complete_poll_work ath9k_hw: do PA offset calibration only on longcal interval ...
2011-01-19sctp: user perfect name for Delayed SACK Timer optionShan Wei
The option name of Delayed SACK Timer should be SCTP_DELAYED_SACK, not SCTP_DELAYED_ACK. Left SCTP_DELAYED_ACK be concomitant with SCTP_DELAYED_SACK, for making compatibility with existing applications. Reference: 8.1.19. Get or Set Delayed SACK Timer (SCTP_DELAYED_SACK) (http://tools.ietf.org/html/draft-ietf-tsvwg-sctpsocket-25) Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Acked-by: Wei Yongjun <yjwei@cn.fujitsu.com> Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-19net: fix can_checksum_protocol() arguments swapEric Dumazet
commit 0363466866d901fbc (net offloading: Convert checksums to use centrally computed features.) mistakenly swapped can_checksum_protocol() arguments. This broke IPv6 on bnx2 for instance, on NIC without TCPv6 checksum offloads. Reported-by: Hans de Bruin <jmdebruin@xmsnet.nl> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Jesse Gross <jesse@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-19Revert "netlink: test for all flags of the NLM_F_DUMP composite"David S. Miller
This reverts commit 0ab03c2b1478f2438d2c80204f7fef65b1bca9cf. It breaks several things including the avahi daemon. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-18net offloading: Do not mask out NETIF_F_HW_VLAN_TX for vlan.Jesse Gross
In netif_skb_features() we return only the features that are valid for vlans if we have a vlan packet. However, we should not mask out NETIF_F_HW_VLAN_TX since it enables transmission of vlan tags and is obviously valid. Reported-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Jesse Gross <jesse@nicira.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-18ipv6: Silence privacy extensions initializationRomain Francoise
When a network namespace is created (via CLONE_NEWNET), the loopback interface is automatically added to the new namespace, triggering a printk in ipv6_add_dev() if CONFIG_IPV6_PRIVACY is set. This is problematic for applications which use CLONE_NEWNET as part of a sandbox, like Chromium's suid sandbox or recent versions of vsftpd. On a busy machine, it can lead to thousands of useless "lo: Disabled Privacy Extensions" messages appearing in dmesg. It's easy enough to check the status of privacy extensions via the use_tempaddr sysctl, so just removing the printk seems like the most sensible solution. Signed-off-by: Romain Francoise <romain@orebokech.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-18Merge branch 'master' of ↵David S. Miller
2011-01-15caif: checking the wrong variableDan Carpenter
In the original code we check if (servl == NULL) twice. The first time should print the message that cfmuxl_remove_uplayer() failed and set "ret" correctly, but instead it just returns success. The second check should be checking the value of "ret" instead of "servl". Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Sjur Braendeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-15can: test size of struct sockaddr in sendmsgKurt Van Dijck
This patch makes the CAN socket code conform to the manpage of sendmsg. Signed-off-by: Kurt Van Dijck <kurt.van.dijck@eia.be> Acked-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-15Merge branch 'for-david' of git://git.open-mesh.org/ecsv/linux-mergeDavid S. Miller
2011-01-16batman-adv: Use "__attribute__" shortcut macrosSven Eckelmann
Linux 2.6.21 defines different macros for __attribute__ which are also used inside batman-adv. The next version of checkpatch.pl warns about the usage of __attribute__((packed))). Linux 2.6.33 defines an extra macro __always_unused which is used to assist source code analyzers and can be used to removed the last existing __attribute__ inside the source code. Signed-off-by: Sven Eckelmann <sven@narfation.org>
2011-01-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (47 commits) GRETH: resolve SMP issues and other problems GRETH: handle frame error interrupts GRETH: avoid writing bad speed/duplex when setting transfer mode GRETH: fixed skb buffer memory leak on frame errors GRETH: GBit transmit descriptor handling optimization GRETH: fix opening/closing GRETH: added raw AMBA vendor/device number to match against. cassini: Fix build bustage on x86. e1000e: consistent use of Rx/Tx vs. RX/TX/rx/tx in comments/logs e1000e: update Copyright for 2011 e1000: Avoid unhandled IRQ r8169: keep firmware in memory. netdev: tilepro: Use is_unicast_ether_addr helper etherdevice.h: Add is_unicast_ether_addr function ks8695net: Use default implementation of ethtool_ops::get_link ks8695net: Disable non-working ethtool operations USB CDC NCM: Don't deref NULL in cdc_ncm_rx_fixup() and don't use uninitialized variable. vxge: Remember to release firmware after upgrading firmware netdev: bfin_mac: Remove is_multicast_ether_addr use in netdev_for_each_mc_addr ipsec: update MAX_AH_AUTH_LEN to support sha512 ...
2011-01-14Merge branch 'for-2.6.38' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.38' of git://linux-nfs.org/~bfields/linux: (62 commits) nfsd4: fix callback restarting nfsd: break lease on unlink, link, and rename nfsd4: break lease on nfsd setattr nfsd: don't support msnfs export option nfsd4: initialize cb_per_client nfsd4: allow restarting callbacks nfsd4: simplify nfsd4_cb_prepare nfsd4: give out delegations more quickly in 4.1 case nfsd4: add helper function to run callbacks nfsd4: make sure sequence flags are set after destroy_session nfsd4: re-probe callback on connection loss nfsd4: set sequence flag when backchannel is down nfsd4: keep finer-grained callback status rpc: allow xprt_class->setup to return a preexisting xprt rpc: keep backchannel xprt as long as server connection rpc: move sk_bc_xprt to svc_xprt nfsd4: allow backchannel recovery nfsd4: support BIND_CONN_TO_SESSION nfsd4: modify session list under cl_lock Documentation: fl_mylease no longer exists ... Fix up conflicts in fs/nfsd/vfs.c with the vfs-scale work. The vfs-scale work touched some msnfs cases, and this merge removes support for that entirely, so the conflict was trivial to resolve.
2011-01-14rxrpc: rxrpc_workqueue isn't used during memory reclaimTejun Heo
rxrpc_workqueue isn't depended upon while reclaiming memory. Convert to alloc_workqueue() without WQ_MEM_RECLAIM. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: David Howells <dhowells@redhat.com> Cc: linux-afs@lists.infradead.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13net: remove dev_txq_stats_fold()Eric Dumazet
After recent changes, (percpu stats on vlan/tunnels...), we dont need anymore per struct netdev_queue tx_bytes/tx_packets/tx_dropped counters. Only remaining users are ixgbe, sch_teql, gianfar & macvlan : 1) ixgbe can be converted to use existing tx_ring counters. 2) macvlan incremented txq->tx_dropped, it can use the dev->stats.tx_dropped counter. 3) sch_teql : almost revert ab35cd4b8f42 (Use net_device internal stats) Now we have ndo_get_stats64(), use it, even for "unsigned long" fields (No need to bring back a struct net_device_stats) 4) gianfar adds a stats structure per tx queue to hold tx_bytes/tx_packets This removes a lockdep warning (and possible lockup) in rndis gadget, calling dev_get_stats() from hard IRQ context. Ref: http://www.spinics.net/lists/netdev/msg149202.html Reported-by: Neil Jones <neiljay@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Jarek Poplawski <jarkao2@gmail.com> CC: Alexander Duyck <alexander.h.duyck@intel.com> CC: Jeff Kirsher <jeffrey.t.kirsher@intel.com> CC: Sandeep Gopalpet <sandeep.kumar@freescale.com> CC: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-13batman-adv: Even Batman should not dereference NULL pointersJesper Juhl
There's a problem in net/batman-adv/unicast.c::frag_send_skb(). dev_alloc_skb() allocates memory and may fail, thus returning NULL. If this happens we'll pass a NULL pointer on to skb_split() which in turn hands it to skb_split_inside_header() from where it gets passed to skb_put() that lets skb_tail_pointer() play with it and that function dereferences it. And thus the bat dies. While I was at it I also moved the call to dev_alloc_skb() above the assignment to 'unicast_packet' since there's no reason to do that assignment if the memory allocation fails. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Sven Eckelmann <sven@narfation.org>
2011-01-13mac80211: use maximum number of AMPDU frames as default in BA RXLuciano Coelho
When the buffer size is set to zero in the block ack parameter set field, we should use the maximum supported number of subframes. The existing code was bogus and was doing some unnecessary calculations that lead to wrong values. Thanks Johannes for helping me figure this one out. Cc: stable@kernel.org Cc: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Luciano Coelho <coelho@ti.com> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-13mac80211: fix lockdep warningJohannes Berg
Since the introduction of the fixes for the reorder timer, mac80211 will cause lockdep warnings because lockdep confuses local->skb_queue and local->rx_skb_queue and treats their lock as the same. However, their locks are different, and are valid in different contexts (the former is used in IRQ context, the latter in BH only) and the only thing to be done is mark the former as a different lock class so that lockdep can tell the difference. Reported-by: Larry Finger <Larry.Finger@lwfinger.net> Reported-by: Sujith <m.sujith@gmail.com> Reported-by: Miles Lane <miles.lane@gmail.com> Tested-by: Sujith <m.sujith@gmail.com> Tested-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-13Merge branch 'master' of git://1984.lsi.us.es/net-2.6David S. Miller
2011-01-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (41 commits) fs: add documentation on fallocate hole punching Gfs2: fail if we try to use hole punch Btrfs: fail if we try to use hole punch Ext4: fail if we try to use hole punch Ocfs2: handle hole punching via fallocate properly XFS: handle hole punching via fallocate properly fs: add hole punching to fallocate vfs: pass struct file to do_truncate on O_TRUNC opens (try #2) fix signedness mess in rw_verify_area() on 64bit architectures fs: fix kernel-doc for dcache::prepend_path fs: fix kernel-doc for dcache::d_validate sanitize ecryptfs ->mount() switch afs move internal-only parts of ncpfs headers to fs/ncpfs switch ncpfs switch 9p pass default dentry_operations to mount_pseudo() switch hostfs switch affs switch configfs ...
2011-01-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (46 commits) hwrng: via_rng - Fix memory scribbling on some CPUs crypto: padlock - Move padlock.h into include/crypto hwrng: via_rng - Fix asm constraints crypto: n2 - use __devexit not __exit in n2_unregister_algs crypto: mark crypto workqueues CPU_INTENSIVE crypto: mv_cesa - dont return PTR_ERR() of wrong pointer crypto: ripemd - Set module author and update email address crypto: omap-sham - backlog handling fix crypto: gf128mul - Remove experimental tag crypto: af_alg - fix af_alg memory_allocated data type crypto: aesni-intel - Fixed build with binutils 2.16 crypto: af_alg - Make sure sk_security is initialized on accept()ed sockets net: Add missing lockdep class names for af_alg include: Install linux/if_alg.h for user-space crypto API crypto: omap-aes - checkpatch --file warning fixes crypto: omap-aes - initialize aes module once per request crypto: omap-aes - unnecessary code removed crypto: omap-aes - error handling implementation improved crypto: omap-aes - redundant locking is removed crypto: omap-aes - DMA initialization fixes for OMAP off mode ...
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: rbd: fix cleanup when trying to mount inexistent image net/ceph: make ceph_msgr_wq non-reentrant ceph: fsc->*_wq's aren't used in memory reclaim path ceph: Always free allocated memory in osdmap_decode() ceph: Makefile: Remove unnessary code ceph: associate requests with opening sessions ceph: drop redundant r_mds field ceph: implement DIRLAYOUTHASH feature to get dir layout from MDS ceph: add dir_layout to inode
2011-01-13Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) Documentation/trace/events.txt: Remove obsolete sched_signal_send. writeback: fix global_dirty_limits comment runtime -> real-time ppc: fix comment typo singal -> signal drivers: fix comment typo diable -> disable. m68k: fix comment typo diable -> disable. wireless: comment typo fix diable -> disable. media: comment typo fix diable -> disable. remove doc for obsolete dynamic-printk kernel-parameter remove extraneous 'is' from Documentation/iostats.txt Fix spelling milisec -> ms in snd_ps3 module parameter description Fix spelling mistakes in comments Revert conflicting V4L changes i7core_edac: fix typos in comments mm/rmap.c: fix comment sound, ca0106: Fix assignment to 'channel'. hrtimer: fix a typo in comment init/Kconfig: fix typo anon_inodes: fix wrong function name in comment fix comment typos concerning "consistent" poll: fix a typo in comment ... Fix up trivial conflicts in: - drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c) - fs/ext4/ext4.h Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
2011-01-13netfilter: ctnetlink: fix loop in ctnetlink_get_conntrack()Pablo Neira Ayuso
This patch fixes a loop in ctnetlink_get_conntrack() that can be triggered if you use the same socket to receive events and to perform a GET operation. Under heavy load, netlink_unicast() may return -EAGAIN, this error code is reserved in nfnetlink for the module load-on-demand. Instead, we return -ENOBUFS which is the appropriate error code that has to be propagated to user-space. Reported-by: Holger Eitzenberger <holger@eitzenberger.org> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2011-01-12eth: fix new kernel-doc warningRandy Dunlap
Fix new kernel-doc warning (copy-paste typo): Warning(net/ethernet/eth.c:366): No description found for parameter 'rxqs' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-12Merge branch 'master' of git://1984.lsi.us.es/net-2.6David S. Miller
2011-01-12inet6: prevent network storms caused by linux IPv6 routersAlexey Kuznetsov
Linux IPv6 forwards unicast packets, which are link layer multicasts... The hole was present since day one. I was 100% this check is there, but it is not. The problem shows itself, f.e. when Microsoft Network Load Balancer runs on a network. This software resolves IPv6 unicast addresses to multicast MAC addresses. Signed-off-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-12pass default dentry_operations to mount_pseudo()Al Viro
2011-01-12net/ceph: make ceph_msgr_wq non-reentrantTejun Heo
ceph messenger code does a rather complex dancing around multithread workqueue to make sure the same work item isn't executed concurrently on different CPUs. This restriction can be provided by workqueue with WQ_NON_REENTRANT. Make ceph_msgr_wq non-reentrant workqueue with the default concurrency level and remove the QUEUED/BUSY logic. * This removes backoff handling in con_work() but it couldn't reliably block execution of con_work() to begin with - queue_con() can be called after the work started but before BUSY is set. It seems that it was an optimization for a rather cold path and can be safely removed. * The number of concurrent work items is bound by the number of connections and connetions are independent from each other. With the default concurrency level, different connections will be executed independently. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Sage Weil <sage@newdream.net> Cc: ceph-devel@vger.kernel.org Signed-off-by: Sage Weil <sage@newdream.net>
2011-01-12ceph: Always free allocated memory in osdmap_decode()Jesper Juhl
Always free memory allocated to 'pi' in net/ceph/osdmap.c::osdmap_decode(). Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Sage Weil <sage@newdream.net>
2011-01-12ceph: add dir_layout to inodeSage Weil
Add a ceph_dir_layout to the inode, and calculate dentry hash values based on the parent directory's specified dir_hash function. This is needed because the old default Linux dcache hash function is extremely week and leads to a poor distribution of files among dir fragments. Signed-off-by: Sage Weil <sage@newdream.net>
2011-01-12netfilter: fix compilation when conntrack is disabled but tproxy is enabledKOVACS Krisztian
The IPv6 tproxy patches split IPv6 defragmentation off of conntrack, but failed to update the #ifdef stanzas guarding the defragmentation related fields and code in skbuff and conntrack related code in nf_defrag_ipv6.c. This patch adds the required #ifdefs so that IPv6 tproxy can truly be used without connection tracking. Original report: http://marc.info/?l=linux-netdev&m=129010118516341&w=2 Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: KOVACS Krisztian <hidden@balabit.hu> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2011-01-12net: ax25: fix information leak to userland harderKees Cook
Commit fe10ae53384e48c51996941b7720ee16995cbcb7 adds a memset() to clear the structure being sent back to userspace, but accidentally used the wrong size. Reported-by: Brad Spengler <spender@grsecurity.net> Signed-off-by: Kees Cook <kees.cook@canonical.com> Cc: stable@kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (67 commits) cxgb4vf: recover from failure in cxgb4vf_open() netfilter: ebtables: make broute table work again netfilter: fix race in conntrack between dump_table and destroy ah: reload pointers to skb data after calling skb_cow_data() ah: update maximum truncated ICV length xfrm: check trunc_len in XFRMA_ALG_AUTH_TRUNC ehea: Increase the skb array usage net/fec: remove config FEC2 as it's used nowhere pcnet_cs: add new_id tcp: disallow bind() to reuse addr/port net/r8169: Update the function of parsing firmware net: ppp: use {get,put}_unaligned_be{16,32} CAIF: Fix IPv6 support in receive path for GPRS/3G arp: allow to invalidate specific ARP entries net_sched: factorize qdisc stats handling mlx4: Call alloc_etherdev to allocate RX and TX queues net: Add alloc_netdev_mqs function caif: don't set connection request param size before copying data cxgb4vf: fix mailbox data/control coherency domain race qlcnic: change module parameter permissions ...
2011-01-11Merge branch 'master' of git://1984.lsi.us.es/net-2.6David S. Miller
2011-01-11Merge branch 'nfs-for-2.6.38' of ↵Linus Torvalds
git://git.linux-nfs.org/projects/trondmy/nfs-2.6 * 'nfs-for-2.6.38' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: (89 commits) NFS fix the setting of exchange id flag NFS: Don't use vm_map_ram() in readdir NFSv4: Ensure continued open and lockowner name uniqueness NFS: Move cl_delegations to the nfs_server struct NFS: Introduce nfs_detach_delegations() NFS: Move cl_state_owners and related fields to the nfs_server struct NFS: Allow walking nfs_client.cl_superblocks list outside client.c pnfs: layout roc code pnfs: update nfs4_callback_recallany to handle layouts pnfs: add CB_LAYOUTRECALL handling pnfs: CB_LAYOUTRECALL xdr code pnfs: change lo refcounting to atomic_t pnfs: check that partial LAYOUTGET return is ignored pnfs: add layout to client list before sending rpc pnfs: serialize LAYOUTGET(openstateid) pnfs: layoutget rpc code cleanup pnfs: change how lsegs are removed from layout list pnfs: change layout state seqlock to a spinlock pnfs: add prefix to struct pnfs_layout_hdr fields pnfs: add prefix to struct pnfs_layout_segment fields ...
2011-01-11netfilter: fix race in conntrack between dump_table and destroyStephen Hemminger
The netlink interface to dump the connection tracking table has a race when entries are deleted at the same time. A customer reported a crash and the backtrace showed thatctnetlink_dump_table was running while a conntrack entry was being destroyed. (see https://bugzilla.vyatta.com/show_bug.cgi?id=6402). According to RCU documentation, when using hlist_nulls the reader must handle the case of seeing a deleted entry and not proceed further down the linked list. The old code would continue which caused the scan to walk into the free list. This patch uses locking (rather than RCU) for this operation which is guaranteed safe, and no longer requires getting reference while doing dump operation. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2011-01-11ah: reload pointers to skb data after calling skb_cow_data()Dang Hongwu
skb_cow_data() may allocate a new data buffer, so pointers on skb should be set after this function. Bug was introduced by commit dff3bb06 ("ah4: convert to ahash") and 8631e9bd ("ah6: convert to ahash"). Signed-off-by: Wang Xuefu <xuefu.wang@6wind.com> Acked-by: Krzysztof Witek <krzysztof.witek@6wind.com> Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-11xfrm: check trunc_len in XFRMA_ALG_AUTH_TRUNCNicolas Dichtel
Maximum trunc length is defined by MAX_AH_AUTH_LEN (in bytes) and need to be checked when this value is set (in bits) by the user. In ah4.c and ah6.c a BUG_ON() checks this condiftion. Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-11tcp: disallow bind() to reuse addr/portEric Dumazet
inet_csk_bind_conflict() logic currently disallows a bind() if it finds a friend socket (a socket bound on same address/port) satisfying a set of conditions : 1) Current (to be bound) socket doesnt have sk_reuse set OR 2) other socket doesnt have sk_reuse set OR 3) other socket is in LISTEN state We should add the CLOSE state in the 3) condition, in order to avoid two REUSEADDR sockets in CLOSE state with same local address/port, since this can deny further operations. Note : a prior patch tried to address the problem in a different (and buggy) way. (commit fda48a0d7a8412ced tcp: bind() fix when many ports are bound). Reported-by: Gaspar Chilingarov <gasparch@gmail.com> Reported-by: Daniel Baluta <daniel.baluta@gmail.com> Tested-by: Daniel Baluta <daniel.baluta@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-11rpc: allow xprt_class->setup to return a preexisting xprtJ. Bruce Fields
This allows us to reuse the xprt associated with a server connection if one has already been set up. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-01-11rpc: keep backchannel xprt as long as server connectionJ. Bruce Fields
Multiple backchannels can share the same tcp connection; from rfc 5661 section 2.10.3.1: A connection's association with a session is not exclusive. A connection associated with the channel(s) of one session may be simultaneously associated with the channel(s) of other sessions including sessions associated with other client IDs. However, multiple backchannels share a connection, they must all share the same xid stream (hence the same rpc_xprt); the only way we have to match replies with calls at the rpc layer is using the xid. So, keep the rpc_xprt around as long as the connection lasts, in case we're asked to use the connection as a backchannel again. Requests to create new backchannel clients over a given server connection should results in creating new clients that reuse the existing rpc_xprt. But to start, just reject attempts to associate multiple rpc_xprt's with the same underlying bc_xprt. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-01-11rpc: move sk_bc_xprt to svc_xprtJ. Bruce Fields
This seems obviously transport-level information even if it's currently used only by the server socket code. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-01-11Merge commit 'v2.6.37' into for-2.6.38-incomingJ. Bruce Fields
I made a slight mess of Documentation/filesystems/Locking; resolve conflicts with upstream before fixing it up.
2011-01-11net/9p: Use proper data typesM. Mohan Kumar
Use proper data types for storing the count of the binary blob and length of a string. Without this patch length calculation of string will always result in -1 because of comparision between signed and unsigned integer. Signed-off-by: M. Mohan Kumar <mohan@in.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-01-10CAIF: Fix IPv6 support in receive path for GPRS/3GKumar Sanghvi
Checks version field of IP in the receive path for GPRS/3G data and appropriately sets the value of skb->protocol. Signed-off-by: Sjur Braendeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-10arp: allow to invalidate specific ARP entriesMaxim Levitsky
IPv4 over firewire needs to be able to remove ARP entries from the ARP cache that belong to nodes that are removed, because IPv4 over firewire uses ARP packets for private information about nodes. This information becomes invalid as soon as node drops off the bus and when it reconnects, its only possible to start talking to it after it responded to an ARP packet. But ARP cache prevents such packets from being sent. Signed-off-by: Maxim Levitsky <maximlevitsky@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-10net_sched: factorize qdisc stats handlingEric Dumazet
HTB takes into account skb is segmented in stats updates. Generalize this to all schedulers. They should use qdisc_bstats_update() helper instead of manipulating bstats.bytes and bstats.packets Add bstats_update() helper too for classes that use gnet_stats_basic_packed fields. Note : Right now, TCQ_F_CAN_BYPASS shortcurt can be taken only if no stab is setup on qdisc. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-10net: Add alloc_netdev_mqs functionTom Herbert
Added alloc_netdev_mqs function which allows the number of transmit and receive queues to be specified independenty. alloc_netdev_mq was changed to a macro to call the new function. Also added alloc_etherdev_mqs with same purpose. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
