commit e860d2c904d1a9f38a24eb44c9f34b8f915a6ea3 upstream.
Validate the output buffer length for L2CAP config requests and responses
to avoid overflowing the stack buffer used for building the option blocks.
Signed-off-by: Ben Seri <ben@armis.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
commit 7bab09631c2a303f87a7eb7e3d69e888673b9b7e upstream.
The 'dir' parameter in xfrm_migrate() is a user-controlled byte which is used
as an array index. This can lead to an out-of-bound access, kernel lockup and
DoS. Add a check for the 'dir' value.
This fixes CVE-2017-11600.
References: https://bugzilla.redhat.com/show_bug.cgi?id=1474928
Fixes: 80c9abaabf42 ("[XFRM]: Extension for dynamic update of endpoint address(es)")
Reported-by: "bo Zhang" <zhangbo5891001@gmail.com>
Signed-off-by: Vladis Dronov <vdronov@redhat.com>
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
commit 25717382c1dd0ddced2059053e3ca5088665f7a5 upstream.
It looks like bnep_session has same pattern as the issue reported in
old rfcomm:
while (1) {
set_current_state(TASK_INTERRUPTIBLE);
if (condition)
break;
// may call might_sleep here
schedule();
__set_current_state(TASK_RUNNING);
Which fixed at:
dfb2fae Bluetooth: Fix nested sleeps
So let's fix it at the same way, also follow the suggestion of:
https://lwn.net/Articles/628628/
Signed-off-by: Jeffy Chen <jeffy.chen@rock-chips.com>
Reviewed-by: Brian Norris <briannorris@chromium.org>
Reviewed-by: AL Yu-Chen Cho <acho@suse.com>
Cc: Jiri Slaby <jslaby@suse.cz>
commit f06d977309d09253c744e54e75c5295ecc52b7b4 upstream.
It looks like cmtp_session has same pattern as the issue reported in
old rfcomm:
while (1) {
if (condition)
break;
schedule();
Which fixed at:
commit 5da8e47d849d3d37b14129f038782a095b9ad049 upstream.
It looks like hidp_session_thread has same pattern as the issue reported in
old rfcomm:
while (1) {
if (condition)
break;
schedule();
Which fixed at:
Tested-by: AL Yu-Chen Cho <acho@suse.com>
Tested-by: Rohit Vaswani <rvaswani@nvidia.com>
[ Upstream commit 4f8a881acc9d1adaf1e552349a0b1df28933a04c ]
As we know in some target's checkentry it may dereference par.entryinfo
to check entry stuff inside. But when sched action calls xt_check_target,
par.entryinfo is set with NULL. It would cause kernel panic when calling
some targets.
It can be reproduce with:
# tc qd add dev eth1 ingress handle ffff:
# tc filter add dev eth1 parent ffff: u32 match u32 0 0 action xt \
-j ECN --ecn-tcp-remove
It could also crash kernel when using target CLUSTERIP or TPROXY.
By now there's no proper value for par.entryinfo in ipt_init_target,
but it can not be set with NULL. This patch is to void all these
panics by setting it with an ipt_entry obj with all members = 0.
Note that this issue has been there since the very beginning.
Signed-off-by: Xin Long <lucien.xin@gmail.com>
Acked-by: Pablo Neira Ayuso <pablo@netfilter.org>
[ Upstream commit b024d949a3c24255a7ef1a470420eb478949aa4c ]
list.dev has not been initialized and so the copy_to_user is copying
data from the stack back to user space which is a potential
information leak. Fix this ensuring all of list is initialized to
zero.
Detected by CoverityScan, CID#1357894 ("Uninitialized scalar variable")
[ Upstream commit cdbeb633ca71a02b7b63bfeb94994bf4e1a0b894 ]
In some situations tcp_send_loss_probe() can realize that it's unable
to send a loss probe (TLP), and falls back to calling tcp_rearm_rto()
to schedule an RTO timer. In such cases, sometimes tcp_rearm_rto()
realizes that the RTO was eligible to fire immediately or at some
point in the past (delta_us <= 0). Previously in such cases
tcp_rearm_rto() was scheduling such "overdue" RTOs to happen at now +
icsk_rto, which caused needless delays of hundreds of milliseconds
(and non-linear behavior that made reproducible testing
difficult). This commit changes the logic to schedule "overdue" RTOs
ASAP, rather than at now + icsk_rto.
Fixes: 6ba8a3b19e76 ("tcp: Tail loss probe (TLP)")
Suggested-by: Yuchung Cheng <ycheng@google.com>
Signed-off-by: Neal Cardwell <ncardwell@google.com>
Signed-off-by: Yuchung Cheng <ycheng@google.com>
[ Upstream commit 348a4002729ccab8b888b38cbc099efa2f2a2036 ]
In fib6_add(), it is possible that fib6_add_1() picks an intermediate
node and sets the node's fn->leaf to NULL in order to add this new
route. However, if fib6_add_rt2node() fails to add the new
route for some reason, fn->leaf will be left as NULL and could
potentially cause crash when fn->leaf is accessed in fib6_locate().
This patch makes sure fib6_repair_tree() is called to properly repair
fn->leaf in the above failure case.
Here is the syzkaller reported general protection fault in fib6_locate:
kasan: CONFIG_KASAN_INLINE enabled
kasan: GPF could be caused by NULL-ptr deref or user memory access
general protection fault: 0000 [#1] SMP KASAN
Modules linked in:
CPU: 0 PID: 40937 Comm: syz-executor3 Not tainted
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
task: ffff8801d7d64100 ti: ffff8801d01a0000 task.ti: ffff8801d01a0000
RIP: 0010:[<ffffffff82a3e0e1>] [<ffffffff82a3e0e1>] __ipv6_prefix_equal64_half include/net/ipv6.h:475 [inline]
RIP: 0010:[<ffffffff82a3e0e1>] [<ffffffff82a3e0e1>] ipv6_prefix_equal include/net/ipv6.h:492 [inline]
RIP: 0010:[<ffffffff82a3e0e1>] [<ffffffff82a3e0e1>] fib6_locate_1 net/ipv6/ip6_fib.c:1210 [inline]
RIP: 0010:[<ffffffff82a3e0e1>] [<ffffffff82a3e0e1>] fib6_locate+0x281/0x3c0 net/ipv6/ip6_fib.c:1233
RSP: 0018:ffff8801d01a36a8 EFLAGS: 00010202
RAX: 0000000000000020 RBX: ffff8801bc790e00 RCX: ffffc90002983000
RDX: 0000000000001219 RSI: ffff8801d01a37a0 RDI: 0000000000000100
RBP: ffff8801d01a36f0 R08: 00000000000000ff R09: 0000000000000000
R10: 0000000000000003 R11: 0000000000000000 R12: 0000000000000001
R13: dffffc0000000000 R14: ffff8801d01a37a0 R15: 0000000000000000
FS: 00007f6afd68c700(0000) GS:ffff8801db400000(0000) knlGS:0000000000000000
CR2: 00000000004c6340 CR3: 00000000ba41f000 CR4: 00000000001426f0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Stack:
ffff8801d01a37a8 ffff8801d01a3780 ffffed003a0346f5 0000000c82a23ea0
ffff8800b7bd7700 ffff8801d01a3780 ffff8800b6a1c940 ffffffff82a23ea0
ffff8801d01a3920 ffff8801d01a3748 ffffffff82a223d6 ffff8801d7d64988
Call Trace:
[<ffffffff82a223d6>] ip6_route_del+0x106/0x570 net/ipv6/route.c:2109
[<ffffffff82a23f9d>] inet6_rtm_delroute+0xfd/0x100 net/ipv6/route.c:3075
[<ffffffff82621359>] rtnetlink_rcv_msg+0x549/0x7a0 net/core/rtnetlink.c:3450
[<ffffffff8274c1d1>] netlink_rcv_skb+0x141/0x370 net/netlink/af_netlink.c:2281
[<ffffffff82613ddf>] rtnetlink_rcv+0x2f/0x40 net/core/rtnetlink.c:3456
[<ffffffff8274ad38>] netlink_unicast_kernel net/netlink/af_netlink.c:1206 [inline]
[<ffffffff8274ad38>] netlink_unicast+0x518/0x750 net/netlink/af_netlink.c:1232
[<ffffffff8274b83e>] netlink_sendmsg+0x8ce/0xc30 net/netlink/af_netlink.c:1778
[<ffffffff82564aff>] sock_sendmsg_nosec net/socket.c:609 [inline]
[<ffffffff82564aff>] sock_sendmsg+0xcf/0x110 net/socket.c:619
[<ffffffff82564d62>] sock_write_iter+0x222/0x3a0 net/socket.c:834
[<ffffffff8178523d>] new_sync_write+0x1dd/0x2b0 fs/read_write.c:478
[<ffffffff817853f4>] __vfs_write+0xe4/0x110 fs/read_write.c:491
[<ffffffff81786c38>] vfs_write+0x178/0x4b0 fs/read_write.c:538
[<ffffffff817892a9>] SYSC_write fs/read_write.c:585 [inline]
[<ffffffff817892a9>] SyS_write+0xd9/0x1b0 fs/read_write.c:577
[<ffffffff82c71e32>] entry_SYSCALL_64_fastpath+0x12/0x17
Note: there is no "Fixes" tag as this seems to be a bug introduced
very early.
Signed-off-by: Wei Wang <weiwan@google.com>
[ Upstream commit 383143f31d7d3525a1dbff733d52fff917f82f15 ]
syzcaller reported the following use-after-free issue in rt6_select():
BUG: KASAN: use-after-free in rt6_select net/ipv6/route.c:755 [inline] at addr ffff8800bc6994e8
BUG: KASAN: use-after-free in ip6_pol_route.isra.46+0x1429/0x1470 net/ipv6/route.c:1084 at addr ffff8800bc6994e8
Read of size 4 by task syz-executor1/439628
CPU: 0 PID: 439628 Comm: syz-executor1 Not tainted 4.3.5+ #8
0000000000000000 ffff88018fe435b0 ffffffff81ca384d ffff8801d3588c00
ffff8800bc699380 ffff8800bc699500 dffffc0000000000 ffff8801d40a47c0
ffff88018fe435d8 ffffffff81735751 ffff88018fe43660 ffff8800bc699380
Call Trace:
[<ffffffff81ca384d>] __dump_stack lib/dump_stack.c:15 [inline]
[<ffffffff81ca384d>] dump_stack+0xc1/0x124 lib/dump_stack.c:51
sctp: [Deprecated]: syz-executor0 (pid 439615) Use of struct sctp_assoc_value in delayed_ack socket option.
Use struct sctp_sack_info instead
[<ffffffff81735751>] kasan_object_err+0x21/0x70 mm/kasan/report.c:158
[<ffffffff817359c4>] print_address_description mm/kasan/report.c:196 [inline]
[<ffffffff817359c4>] kasan_report_error+0x1b4/0x4a0 mm/kasan/report.c:285
[<ffffffff81735d93>] kasan_report mm/kasan/report.c:305 [inline]
[<ffffffff81735d93>] __asan_report_load4_noabort+0x43/0x50 mm/kasan/report.c:325
[<ffffffff82a28e39>] rt6_select net/ipv6/route.c:755 [inline]
[<ffffffff82a28e39>] ip6_pol_route.isra.46+0x1429/0x1470 net/ipv6/route.c:1084
[<ffffffff82a28fb1>] ip6_pol_route_output+0x81/0xb0 net/ipv6/route.c:1203
[<ffffffff82ab0a50>] fib6_rule_action+0x1f0/0x680 net/ipv6/fib6_rules.c:95
[<ffffffff8265cbb6>] fib_rules_lookup+0x2a6/0x7a0 net/core/fib_rules.c:223
[<ffffffff82ab1430>] fib6_rule_lookup+0xd0/0x250 net/ipv6/fib6_rules.c:41
[<ffffffff82a22006>] ip6_route_output+0x1d6/0x2c0 net/ipv6/route.c:1224
[<ffffffff829e83d2>] ip6_dst_lookup_tail+0x4d2/0x890 net/ipv6/ip6_output.c:943
[<ffffffff829e889a>] ip6_dst_lookup_flow+0x9a/0x250 net/ipv6/ip6_output.c:1079
[<ffffffff82a9f7d8>] ip6_datagram_dst_update+0x538/0xd40 net/ipv6/datagram.c:91
[<ffffffff82aa0978>] __ip6_datagram_connect net/ipv6/datagram.c:251 [inline]
[<ffffffff82aa0978>] ip6_datagram_connect+0x518/0xe50 net/ipv6/datagram.c:272
[<ffffffff82aa1313>] ip6_datagram_connect_v6_only+0x63/0x90 net/ipv6/datagram.c:284
[<ffffffff8292f790>] inet_dgram_connect+0x170/0x1f0 net/ipv4/af_inet.c:564
[<ffffffff82565547>] SYSC_connect+0x1a7/0x2f0 net/socket.c:1582
[<ffffffff8256a649>] SyS_connect+0x29/0x30 net/socket.c:1563
[<ffffffff82c72032>] entry_SYSCALL_64_fastpath+0x12/0x17
Object at ffff8800bc699380, in cache ip6_dst_cache size: 384
The root cause of it is that in fib6_add_rt2node(), when it replaces an
existing route with the new one, it does not update fn->rr_ptr.
This commit resets fn->rr_ptr to NULL when it points to a route which is
replaced in fib6_add_rt2node().
Fixes: 27596472473a ("ipv6: fix ECMP route replacement")
[ Upstream commit 5bfd37b4de5c98e86b12bd13be5aa46c7484a125 ]
syszkaller reported use-after-free in tipc [1]
When msg->rep skb is freed, set the pointer to NULL,
so that caller does not free it again.
[1]
BUG: KASAN: use-after-free in skb_push+0xd4/0xe0 net/core/skbuff.c:1466
Read of size 8 at addr ffff8801c6e71e90 by task syz-executor5/4115
CPU: 1 PID: 4115 Comm: syz-executor5 Not tainted 4.13.0-rc4+ #32
Call Trace:
__dump_stack lib/dump_stack.c:16 [inline]
dump_stack+0x194/0x257 lib/dump_stack.c:52
print_address_description+0x73/0x250 mm/kasan/report.c:252
kasan_report_error mm/kasan/report.c:351 [inline]
kasan_report+0x24e/0x340 mm/kasan/report.c:409
__asan_report_load8_noabort+0x14/0x20 mm/kasan/report.c:430
tipc_nl_compat_recv+0x833/0x18f0 net/tipc/netlink_compat.c:1209
genl_family_rcv_msg+0x7b7/0xfb0 net/netlink/genetlink.c:598
genl_rcv_msg+0xb2/0x140 net/netlink/genetlink.c:623
netlink_rcv_skb+0x216/0x440 net/netlink/af_netlink.c:2397
genl_rcv+0x28/0x40 net/netlink/genetlink.c:634
netlink_unicast_kernel net/netlink/af_netlink.c:1265 [inline]
netlink_unicast+0x4e8/0x6f0 net/netlink/af_netlink.c:1291
netlink_sendmsg+0xa4a/0xe60 net/netlink/af_netlink.c:1854
sock_sendmsg_nosec net/socket.c:633 [inline]
sock_sendmsg+0xca/0x110 net/socket.c:643
sock_write_iter+0x31a/0x5d0 net/socket.c:898
call_write_iter include/linux/fs.h:1743 [inline]
new_sync_write fs/read_write.c:457 [inline]
__vfs_write+0x684/0x970 fs/read_write.c:470
vfs_write+0x189/0x510 fs/read_write.c:518
SYSC_write fs/read_write.c:565 [inline]
SyS_write+0xef/0x220 fs/read_write.c:557
entry_SYSCALL_64_fastpath+0x1f/0xbe
RIP: 0033:0x4512e9
RSP: 002b:00007f3bc8184c08 EFLAGS: 00000216 ORIG_RAX: 0000000000000001
RAX: ffffffffffffffda RBX: 0000000000718000 RCX: 00000000004512e9
RDX: 0000000000000020 RSI: 0000000020fdb000 RDI: 0000000000000006
RBP: 0000000000000086 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000216 R12: 00000000004b5e76
R13: 00007f3bc8184b48 R14: 00000000004b5e86 R15: 0000000000000000
Allocated by task 4115:
save_stack_trace+0x16/0x20 arch/x86/kernel/stacktrace.c:59
save_stack+0x43/0xd0 mm/kasan/kasan.c:447
set_track mm/kasan/kasan.c:459 [inline]
kasan_kmalloc+0xad/0xe0 mm/kasan/kasan.c:551
kasan_slab_alloc+0x12/0x20 mm/kasan/kasan.c:489
kmem_cache_alloc_node+0x13d/0x750 mm/slab.c:3651
__alloc_skb+0xf1/0x740 net/core/skbuff.c:219
alloc_skb include/linux/skbuff.h:903 [inline]
tipc_tlv_alloc+0x26/0xb0 net/tipc/netlink_compat.c:148
tipc_nl_compat_dumpit+0xf2/0x3c0 net/tipc/netlink_compat.c:248
tipc_nl_compat_handle net/tipc/netlink_compat.c:1130 [inline]
tipc_nl_compat_recv+0x756/0x18f0 net/tipc/netlink_compat.c:1199
Freed by task 4115:
kasan_slab_free+0x71/0xc0 mm/kasan/kasan.c:524
__cache_free mm/slab.c:3503 [inline]
kmem_cache_free+0x77/0x280 mm/slab.c:3763
kfree_skbmem+0x1a1/0x1d0 net/core/skbuff.c:622
__kfree_skb net/core/skbuff.c:682 [inline]
kfree_skb+0x165/0x4c0 net/core/skbuff.c:699
tipc_nl_compat_dumpit+0x36a/0x3c0 net/tipc/netlink_compat.c:260
The buggy address belongs to the object at ffff8801c6e71dc0
which belongs to the cache skbuff_head_cache of size 224
The buggy address is located 208 bytes inside of
224-byte region [ffff8801c6e71dc0, ffff8801c6e71ea0)
The buggy address belongs to the page:
page:ffffea00071b9c40 count:1 mapcount:0 mapping:ffff8801c6e71000 index:0x0
flags: 0x200000000000100(slab)
raw: 0200000000000100 ffff8801c6e71000 0000000000000000 000000010000000c
raw: ffffea0007224a20 ffff8801d98caf48 ffff8801d9e79040 0000000000000000
page dumped because: kasan: bad access detected
Memory state around the buggy address:
ffff8801c6e71d80: fc fc fc fc fc fc fc fc fb fb fb fb fb fb fb fb
ffff8801c6e71e00: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
>ffff8801c6e71e80: fb fb fb fb fc fc fc fc fc fc fc fc fc fc fc fc
ffff8801c6e71f00: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
ffff8801c6e71f80: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
Cc: Jon Maloy <jon.maloy@ericsson.com>
Cc: Ying Xue <ying.xue@windriver.com>
[ Upstream commit 15339e441ec46fbc3bf3486bb1ae4845b0f1bb8d ]
KMSAN reported use of uninitialized sctp_addr->v4.sin_addr.s_addr and
sctp_addr->v6.sin6_scope_id in sctp_v6_cmp_addr() (see below).
Make sure all fields of an IPv6 address are initialized, which
guarantees that the IPv4 fields are also initialized.
BUG: KMSAN: use of uninitialized memory in sctp_v6_cmp_addr+0x8d4/0x9f0
net/sctp/ipv6.c:517
CPU: 2 PID: 31056 Comm: syz-executor1 Not tainted 4.11.0-rc5+ #2944
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs
01/01/2011
Call Trace:
dump_stack+0x172/0x1c0 lib/dump_stack.c:42
is_logbuf_locked mm/kmsan/kmsan.c:59 [inline]
kmsan_report+0x12a/0x180 mm/kmsan/kmsan.c:938
native_save_fl arch/x86/include/asm/irqflags.h:18 [inline]
arch_local_save_flags arch/x86/include/asm/irqflags.h:72 [inline]
arch_local_irq_save arch/x86/include/asm/irqflags.h:113 [inline]
__msan_warning_32+0x61/0xb0 mm/kmsan/kmsan_instr.c:467
sctp_v6_cmp_addr+0x8d4/0x9f0 net/sctp/ipv6.c:517
sctp_v6_get_dst+0x8c7/0x1630 net/sctp/ipv6.c:290
sctp_transport_route+0x101/0x570 net/sctp/transport.c:292
sctp_assoc_add_peer+0x66d/0x16f0 net/sctp/associola.c:651
sctp_sendmsg+0x35a5/0x4f90 net/sctp/socket.c:1871
inet_sendmsg+0x498/0x670 net/ipv4/af_inet.c:762
sock_sendmsg net/socket.c:643 [inline]
SYSC_sendto+0x608/0x710 net/socket.c:1696
SyS_sendto+0x8a/0xb0 net/socket.c:1664
entry_SYSCALL_64_fastpath+0x13/0x94
RIP: 0033:0x44b479
RSP: 002b:00007f6213f21c08 EFLAGS: 00000286 ORIG_RAX: 000000000000002c
RAX: ffffffffffffffda RBX: 0000000020000000 RCX: 000000000044b479
RDX: 0000000000000041 RSI: 0000000020edd000 RDI: 0000000000000006
RBP: 00000000007080a8 R08: 0000000020b85fe4 R09: 000000000000001c
R10: 0000000000040005 R11: 0000000000000286 R12: 00000000ffffffff
R13: 0000000000003760 R14: 00000000006e5820 R15: 0000000000ff8000
origin description: ----dst_saddr@sctp_v6_get_dst
local variable created at:
sk_fullsock include/net/sock.h:2321 [inline]
inet6_sk include/linux/ipv6.h:309 [inline]
sctp_v6_get_dst+0x91/0x1630 net/sctp/ipv6.c:241
net/sctp/ipv6.c:517
01/01/2011
Call Trace:
RIP: 0033:0x44b479
Signed-off-by: Alexander Potapenko <glider@google.com>
Reviewed-by: Xin Long <lucien.xin@gmail.com>
Acked-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
[ Upstream commit c780a049f9bf442314335372c9abc4548bfe3e44 ]
While working on yet another syzkaller report, I found
that our IP_MAX_MTU enforcements were not properly done.
gcc seems to reload dev->mtu for min(dev->mtu, IP_MAX_MTU), and
final result can be bigger than IP_MAX_MTU :/
This is a problem because device mtu can be changed on other cpus or
threads.
While this patch does not fix the issue I am working on, it is
probably worth addressing it.
[ Upstream commit 325d5dc3f7e7c2840b65e4a2988c082c2c0025c5 ]
When sfq_enqueue() drops head packet or packet from another queue it
have to update backlog at upper qdiscs too.
Fixes: 2ccccf5fb43f ("net_sched: update hierarchical backlog too")
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
[ Upstream commit 187e5b3ac84d3421d2de3aca949b2791fbcad554 ]
If fi->fib_metrics could not be allocated in fib_create_info()
we attempt to dereference a NULL pointer in free_fib_info_rcu() :
m = fi->fib_metrics;
if (m != &dst_default_metrics && atomic_dec_and_test(&m->refcnt))
kfree(m);
Before my recent patch, we used to call kfree(NULL) and nothing wrong
happened.
Instead of using RCU to defer freeing while we are under memory stress,
it seems better to take immediate action.
This was reported by syzkaller team.
Fixes: 3fb07daff8e9 ("ipv4: add reference counting to metrics")
[ Upstream commit 120e9dabaf551c6dc03d3a10a1f026376cb1811c ]
syszkaller team reported another problem in DCCP [1]
Problem here is that the structure holding RTO timer
(ccid2_hc_tx_rto_expire() handler) is freed too soon.
We can not use del_timer_sync() to cancel the timer
since this timer wants to grab socket lock (that would risk a dead lock)
Solution is to defer the freeing of memory when all references to
the socket were released. Socket timers do own a reference, so this
should fix the issue.
[1]
BUG: KASAN: use-after-free in ccid2_hc_tx_rto_expire+0x51c/0x5c0 net/dccp/ccids/ccid2.c:144
Read of size 4 at addr ffff8801d2660540 by task kworker/u4:7/3365
CPU: 1 PID: 3365 Comm: kworker/u4:7 Not tainted 4.13.0-rc4+ #3
Workqueue: events_unbound call_usermodehelper_exec_work
Call Trace:
<IRQ>
__asan_report_load4_noabort+0x14/0x20 mm/kasan/report.c:429
call_timer_fn+0x233/0x830 kernel/time/timer.c:1268
expire_timers kernel/time/timer.c:1307 [inline]
__run_timers+0x7fd/0xb90 kernel/time/timer.c:1601
run_timer_softirq+0x21/0x80 kernel/time/timer.c:1614
__do_softirq+0x2f5/0xba3 kernel/softirq.c:284
invoke_softirq kernel/softirq.c:364 [inline]
irq_exit+0x1cc/0x200 kernel/softirq.c:405
exiting_irq arch/x86/include/asm/apic.h:638 [inline]
smp_apic_timer_interrupt+0x76/0xa0 arch/x86/kernel/apic/apic.c:1044
apic_timer_interrupt+0x93/0xa0 arch/x86/entry/entry_64.S:702
RIP: 0010:arch_local_irq_enable arch/x86/include/asm/paravirt.h:824 [inline]
RIP: 0010:__raw_write_unlock_irq include/linux/rwlock_api_smp.h:267 [inline]
RIP: 0010:_raw_write_unlock_irq+0x56/0x70 kernel/locking/spinlock.c:343
RSP: 0018:ffff8801cd50eaa8 EFLAGS: 00000286 ORIG_RAX: ffffffffffffff10
RAX: dffffc0000000000 RBX: ffffffff85a090c0 RCX: 0000000000000006
RDX: 1ffffffff0b595f3 RSI: 1ffff1003962f989 RDI: ffffffff85acaf98
RBP: ffff8801cd50eab0 R08: 0000000000000001 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: ffff8801cc96ea60
R13: dffffc0000000000 R14: ffff8801cc96e4c0 R15: ffff8801cc96e4c0
</IRQ>
release_task+0xe9e/0x1a40 kernel/exit.c:220
wait_task_zombie kernel/exit.c:1162 [inline]
wait_consider_task+0x29b8/0x33c0 kernel/exit.c:1389
do_wait_thread kernel/exit.c:1452 [inline]
do_wait+0x441/0xa90 kernel/exit.c:1523
kernel_wait4+0x1f5/0x370 kernel/exit.c:1665
SYSC_wait4+0x134/0x140 kernel/exit.c:1677
SyS_wait4+0x2c/0x40 kernel/exit.c:1673
call_usermodehelper_exec_sync kernel/kmod.c:286 [inline]
call_usermodehelper_exec_work+0x1a0/0x2c0 kernel/kmod.c:323
process_one_work+0xbf3/0x1bc0 kernel/workqueue.c:2097
worker_thread+0x223/0x1860 kernel/workqueue.c:2231
kthread+0x35e/0x430 kernel/kthread.c:231
ret_from_fork+0x2a/0x40 arch/x86/entry/entry_64.S:425
Allocated by task 21267:
kmem_cache_alloc+0x127/0x750 mm/slab.c:3561
ccid_new+0x20e/0x390 net/dccp/ccid.c:151
dccp_hdlr_ccid+0x27/0x140 net/dccp/feat.c:44
__dccp_feat_activate+0x142/0x2a0 net/dccp/feat.c:344
dccp_feat_activate_values+0x34e/0xa90 net/dccp/feat.c:1538
dccp_rcv_request_sent_state_process net/dccp/input.c:472 [inline]
dccp_rcv_state_process+0xed1/0x1620 net/dccp/input.c:677
dccp_v4_do_rcv+0xeb/0x160 net/dccp/ipv4.c:679
sk_backlog_rcv include/net/sock.h:911 [inline]
__release_sock+0x124/0x360 net/core/sock.c:2269
release_sock+0xa4/0x2a0 net/core/sock.c:2784
inet_wait_for_connect net/ipv4/af_inet.c:557 [inline]
__inet_stream_connect+0x671/0xf00 net/ipv4/af_inet.c:643
inet_stream_connect+0x58/0xa0 net/ipv4/af_inet.c:682
SYSC_connect+0x204/0x470 net/socket.c:1642
SyS_connect+0x24/0x30 net/socket.c:1623
Freed by task 3049:
ccid_hc_tx_delete+0xc5/0x100 net/dccp/ccid.c:190
dccp_destroy_sock+0x1d1/0x2b0 net/dccp/proto.c:225
inet_csk_destroy_sock+0x166/0x3f0 net/ipv4/inet_connection_sock.c:833
dccp_done+0xb7/0xd0 net/dccp/proto.c:145
dccp_time_wait+0x13d/0x300 net/dccp/minisocks.c:72
dccp_rcv_reset+0x1d1/0x5b0 net/dccp/input.c:160
dccp_rcv_state_process+0x8fc/0x1620 net/dccp/input.c:663
__sk_receive_skb+0x33e/0xc00 net/core/sock.c:521
dccp_v4_rcv+0xef1/0x1c00 net/dccp/ipv4.c:871
ip_local_deliver_finish+0x2e2/0xba0 net/ipv4/ip_input.c:216
NF_HOOK include/linux/netfilter.h:248 [inline]
ip_local_deliver+0x1ce/0x6d0 net/ipv4/ip_input.c:257
dst_input include/net/dst.h:477 [inline]
ip_rcv_finish+0x8db/0x19c0 net/ipv4/ip_input.c:397
ip_rcv+0xc3f/0x17d0 net/ipv4/ip_input.c:488
__netif_receive_skb_core+0x19af/0x33d0 net/core/dev.c:4417
__netif_receive_skb+0x2c/0x1b0 net/core/dev.c:4455
process_backlog+0x203/0x740 net/core/dev.c:5130
napi_poll net/core/dev.c:5527 [inline]
net_rx_action+0x792/0x1910 net/core/dev.c:5593
The buggy address belongs to the object at ffff8801d2660100
which belongs to the cache ccid2_hc_tx_sock of size 1240
The buggy address is located 1088 bytes inside of
1240-byte region [ffff8801d2660100, ffff8801d26605d8)
page:ffffea0007499800 count:1 mapcount:0 mapping:ffff8801d2660100 index:0x0 compound_mapcount: 0
flags: 0x200000000008100(slab|head)
raw: 0200000000008100 ffff8801d2660100 0000000000000000 0000000100000005
raw: ffffea00075271a0 ffffea0007538820 ffff8801d3aef9c0 0000000000000000
ffff8801d2660400: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff8801d2660480: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
>ffff8801d2660500: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff8801d2660580: fb fb fb fb fb fb fb fb fb fb fb fc fc fc fc fc
ffff8801d2660600: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
Cc: Gerrit Renker <gerrit@erg.abdn.ac.uk>
[ Upstream commit 7749d4ff88d31b0be17c8683143135adaaadc6a7 ]
syzkaller reported that DCCP could have a non empty
write queue at dismantle time.
WARNING: CPU: 1 PID: 2953 at net/core/stream.c:199 sk_stream_kill_queues+0x3ce/0x520 net/core/stream.c:199
Kernel panic - not syncing: panic_on_warn set ...
CPU: 1 PID: 2953 Comm: syz-executor0 Not tainted 4.13.0-rc4+ #2
Call Trace:
panic+0x1e4/0x417 kernel/panic.c:180
__warn+0x1c4/0x1d9 kernel/panic.c:541
report_bug+0x211/0x2d0 lib/bug.c:183
fixup_bug+0x40/0x90 arch/x86/kernel/traps.c:190
do_trap_no_signal arch/x86/kernel/traps.c:224 [inline]
do_trap+0x260/0x390 arch/x86/kernel/traps.c:273
do_error_trap+0x120/0x390 arch/x86/kernel/traps.c:310
do_invalid_op+0x1b/0x20 arch/x86/kernel/traps.c:323
invalid_op+0x1e/0x30 arch/x86/entry/entry_64.S:846
RIP: 0010:sk_stream_kill_queues+0x3ce/0x520 net/core/stream.c:199
RSP: 0018:ffff8801d182f108 EFLAGS: 00010297
RAX: ffff8801d1144140 RBX: ffff8801d13cb280 RCX: 0000000000000000
RDX: 0000000000000000 RSI: ffffffff85137b00 RDI: ffff8801d13cb280
RBP: ffff8801d182f148 R08: 0000000000000001 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: ffff8801d13cb4d0
R13: ffff8801d13cb3b8 R14: ffff8801d13cb300 R15: ffff8801d13cb3b8
inet_csk_destroy_sock+0x175/0x3f0 net/ipv4/inet_connection_sock.c:835
dccp_close+0x84d/0xc10 net/dccp/proto.c:1067
inet_release+0xed/0x1c0 net/ipv4/af_inet.c:425
sock_release+0x8d/0x1e0 net/socket.c:597
sock_close+0x16/0x20 net/socket.c:1126
__fput+0x327/0x7e0 fs/file_table.c:210
____fput+0x15/0x20 fs/file_table.c:246
task_work_run+0x18a/0x260 kernel/task_work.c:116
exit_task_work include/linux/task_work.h:21 [inline]
do_exit+0xa32/0x1b10 kernel/exit.c:865
do_group_exit+0x149/0x400 kernel/exit.c:969
get_signal+0x7e8/0x17e0 kernel/signal.c:2330
do_signal+0x94/0x1ee0 arch/x86/kernel/signal.c:808
exit_to_usermode_loop+0x21c/0x2d0 arch/x86/entry/common.c:157
prepare_exit_to_usermode arch/x86/entry/common.c:194 [inline]
syscall_return_slowpath+0x3a7/0x450 arch/x86/entry/common.c:263
[ Upstream commit 36f41f8fc6d8aa9f8c9072d66ff7cf9055f5e69b ]
pfkey_broadcast() might be called from non process contexts,
we can not use GFP_KERNEL in these cases [1].
This patch partially reverts commit ba51b6be38c1 ("net: Fix RCU splat in
af_key"), only keeping the GFP_ATOMIC forcing under rcu_read_lock()
section.
[1] : syzkaller reported :
in_atomic(): 1, irqs_disabled(): 0, pid: 2932, name: syzkaller183439
3 locks held by syzkaller183439/2932:
#0: (&net->xfrm.xfrm_cfg_mutex){+.+.+.}, at: [<ffffffff83b43888>] pfkey_sendmsg+0x4c8/0x9f0 net/key/af_key.c:3649
#1: (&pfk->dump_lock){+.+.+.}, at: [<ffffffff83b467f6>] pfkey_do_dump+0x76/0x3f0 net/key/af_key.c:293
#2: (&(&net->xfrm.xfrm_policy_lock)->rlock){+...+.}, at: [<ffffffff83957632>] spin_lock_bh include/linux/spinlock.h:304 [inline]
#2: (&(&net->xfrm.xfrm_policy_lock)->rlock){+...+.}, at: [<ffffffff83957632>] xfrm_policy_walk+0x192/0xa30 net/xfrm/xfrm_policy.c:1028
CPU: 0 PID: 2932 Comm: syzkaller183439 Not tainted 4.13.0-rc4+ #24
Call Trace:
___might_sleep+0x2b2/0x470 kernel/sched/core.c:5994
__might_sleep+0x95/0x190 kernel/sched/core.c:5947
slab_pre_alloc_hook mm/slab.h:416 [inline]
slab_alloc mm/slab.c:3383 [inline]
kmem_cache_alloc+0x24b/0x6e0 mm/slab.c:3559
skb_clone+0x1a0/0x400 net/core/skbuff.c:1037
pfkey_broadcast_one+0x4b2/0x6f0 net/key/af_key.c:207
pfkey_broadcast+0x4ba/0x770 net/key/af_key.c:281
dump_sp+0x3d6/0x500 net/key/af_key.c:2685
xfrm_policy_walk+0x2f1/0xa30 net/xfrm/xfrm_policy.c:1042
pfkey_dump_sp+0x42/0x50 net/key/af_key.c:2695
pfkey_do_dump+0xaa/0x3f0 net/key/af_key.c:299
pfkey_spddump+0x1a0/0x210 net/key/af_key.c:2722
pfkey_process+0x606/0x710 net/key/af_key.c:2814
pfkey_sendmsg+0x4d6/0x9f0 net/key/af_key.c:3650
___sys_sendmsg+0x755/0x890 net/socket.c:2035
__sys_sendmsg+0xe5/0x210 net/socket.c:2069
SYSC_sendmsg net/socket.c:2080 [inline]
SyS_sendmsg+0x2d/0x50 net/socket.c:2076
RIP: 0033:0x445d79
RSP: 002b:00007f32447c1dc8 EFLAGS: 00000202 ORIG_RAX: 000000000000002e
RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 0000000000445d79
RDX: 0000000000000000 RSI: 000000002023dfc8 RDI: 0000000000000008
RBP: 0000000000000086 R08: 00007f32447c2700 R09: 00007f32447c2700
R10: 00007f32447c2700 R11: 0000000000000202 R12: 0000000000000000
R13: 00007ffe33edec4f R14: 00007f32447c29c0 R15: 0000000000000000
Fixes: ba51b6be38c1 ("net: Fix RCU splat in af_key")
Cc: David Ahern <dsa@cumulusnetworks.com>
Acked-by: David Ahern <dsahern@gmail.com>
commit 9c3f3794926a997b1cab6c42480ff300efa2d162 upstream.
If one cpu is doing nf_ct_extend_unregister while another cpu is doing
__nf_ct_ext_add_length, then we may hit BUG_ON(t == NULL). Moreover,
there's no synchronize_rcu invocation after set nf_ct_ext_types[id] to
NULL, so it's possible that we may access invalid pointer.
But actually, most of the ct extends are built-in, so the problem listed
above will not happen. However, there are two exceptions: NF_CT_EXT_NAT
and NF_CT_EXT_SYNPROXY.
For _EXT_NAT, the panic will not happen, since adding the nat extend and
unregistering the nat extend are located in the same file(nf_nat_core.c),
this means that after the nat module is removed, we cannot add the nat
extend too.
For _EXT_SYNPROXY, synproxy extend may be added by init_conntrack, while
synproxy extend unregister will be done by synproxy_core_exit. So after
nf_synproxy_core.ko is removed, we may still try to add the synproxy
extend, then kernel panic may happen.
I know it's very hard to reproduce this issue, but I can play a tricky
game to make it happen very easily :)
Step 1. Enable SYNPROXY for tcp dport 1234 at FORWARD hook:
# iptables -I FORWARD -p tcp --dport 1234 -j SYNPROXY
Step 2. Queue the syn packet to the userspace at raw table OUTPUT hook.
Also note, in the userspace we only add a 20s' delay, then
reinject the syn packet to the kernel:
# iptables -t raw -I OUTPUT -p tcp --syn -j NFQUEUE --queue-num 1
Step 3. Using "nc 2.2.2.2 1234" to connect the server.
Step 4. Now remove the nf_synproxy_core.ko quickly:
# iptables -F FORWARD
# rmmod ipt_SYNPROXY
# rmmod nf_synproxy_core
Step 5. After 20s' delay, the syn packet is reinjected to the kernel.
Now you will see the panic like this:
kernel BUG at net/netfilter/nf_conntrack_extend.c:91!
Call Trace:
? __nf_ct_ext_add_length+0x53/0x3c0 [nf_conntrack]
init_conntrack+0x12b/0x600 [nf_conntrack]
nf_conntrack_in+0x4cc/0x580 [nf_conntrack]
ipv4_conntrack_local+0x48/0x50 [nf_conntrack_ipv4]
nf_reinject+0x104/0x270
nfqnl_recv_verdict+0x3e1/0x5f9 [nfnetlink_queue]
? nfqnl_recv_verdict+0x5/0x5f9 [nfnetlink_queue]
? nla_parse+0xa0/0x100
nfnetlink_rcv_msg+0x175/0x6a9 [nfnetlink]
One possible solution is to make NF_CT_EXT_SYNPROXY extend built-in, i.e.
introduce nf_conntrack_synproxy.c and only do ct extend register and
unregister in it, similar to nf_conntrack_timeout.c.
But having such a obscure restriction of nf_ct_extend_unregister is not a
good idea, so we should invoke synchronize_rcu after set nf_ct_ext_types
to NULL, and check the NULL pointer when do __nf_ct_ext_add_length. Then
it will be easier if we add new ct extend in the future.
Last, we use kfree_rcu to free nf_ct_ext, so rcu_barrier() is unnecessary
anymore, remove it too.
Signed-off-by: Liping Zhang <zlpnobody@gmail.com>
Acked-by: Florian Westphal <fw@strlen.de>
Cc: Stefan Bader <stefan.bader@canonical.com>
commit a5cb659bbc1c8644efa0c3138a757a1e432a4880 upstream.
Our customer encountered stuck NFS writes for blocks starting at specific
offsets w.r.t. page boundary caused by networking stack sending packets via
UFO enabled device with wrong checksum. The problem can be reproduced by
composing a long UDP datagram from multiple parts using MSG_MORE flag:
sendto(sd, buff, 1000, MSG_MORE, ...);
sendto(sd, buff, 3000, 0, ...);
Assume this packet is to be routed via a device with MTU 1500 and
NETIF_F_UFO enabled. When second sendto() gets into __ip_append_data(),
this condition is tested (among others) to decide whether to call
ip_ufo_append_data():
((length + fragheaderlen) > mtu) || (skb && skb_is_gso(skb))
At the moment, we already have skb with 1028 bytes of data which is not
marked for GSO so that the test is false (fragheaderlen is usually 20).
Thus we append second 1000 bytes to this skb without invoking UFO. Third
sendto(), however, has sufficient length to trigger the UFO path so that we
end up with non-UFO skb followed by a UFO one. Later on, udp_send_skb()
uses udp_csum() to calculate the checksum but that assumes all fragments
have correct checksum in skb->csum which is not true for UFO fragments.
When checking against MTU, we need to add skb->len to length of new segment
if we already have a partially filled skb and fragheaderlen only if there
isn't one.
In the IPv6 case, skb can only be null if this is the first segment so that
we have to use headersize (length of the first IPv6 header) rather than
fragheaderlen (length of IPv6 header of further fragments) for skb == NULL.
Fixes: e89e9cf539a2 ("[IPv4/IPv6]: UFO Scatter-gather approach")
Fixes: e4c5e13aa45c ("ipv6: Should use consistent conditional judgement for
ip6 fragment between __ip6_append_data and ip6_finish_output")
Signed-off-by: Michal Kubecek <mkubecek@suse.cz>
Acked-by: Vlad Yasevich <vyasevic@redhat.com>
__ip_append_data and ip_finish_output
commit 0a28cfd51e17f4f0a056bcf66bfbe492c3b99f38 upstream.
There is an inconsistent conditional judgement in __ip_append_data and
ip_finish_output functions, the variable length in __ip_append_data just
include the length of application's payload and udp header, don't include
the length of ip header, but in ip_finish_output use
(skb->len > ip_skb_dst_mtu(skb)) as judgement, and skb->len include the
length of ip header.
That causes some particular application's udp payload whose length is
between (MTU - IP Header) and MTU were fragmented by ip_fragment even
though the rst->dev support UFO feature.
Add the length of ip header to length in __ip_append_data to keep
consistent conditional judgement as ip_finish_output for ip fragment.
Signed-off-by: Zheng Li <james.z.li@ericsson.com>
[ Upstream commit 85f1bd9a7b5a79d5baa8bf44af19658f7bf77bfa ]
When iteratively building a UDP datagram with MSG_MORE and that
datagram exceeds MTU, consistently choose UFO or fragmentation.
Once skb_is_gso, always apply ufo. Conversely, once a datagram is
split across multiple skbs, do not consider ufo.
Sendpage already maintains the first invariant, only add the second.
IPv6 does not have a sendpage implementation to modify.
A gso skb must have a partial checksum, do not follow sk_no_check_tx
in udp_send_skb.
Found by syzkaller.
Reported-by: Andrey Konovalov <andreyknvl@google.com>
Signed-off-by: Willem de Bruijn <willemb@google.com>
__ip_append_data and ip_finish_output"
This reverts commit f102bb7164c9020e12662998f0fd99c3be72d4f6 which is
commit 0a28cfd51e17f4f0a056bcf66bfbe492c3b99f38 upstream as there is
another patch that needs to be applied instead of this one.
Cc: Zheng Li <james.z.li@ericsson.com>
Cc: Sasha Levin <alexander.levin@verizon.com>
This reverts commit ef09c9ff343122a0b245416066992d096416ff19 which is
commit a5cb659bbc1c8644efa0c3138a757a1e432a4880 upstream as it causes
merge issues with later patches that are much more important...
Cc: Michal Kubecek <mkubecek@suse.cz>
Cc: Vlad Yasevich <vyasevic@redhat.com>
[ Upstream commit c27927e372f0785f3303e8fad94b85945e2c97b7 ]
Updates to tp_reserve can race with reads of the field in
packet_set_ring. Avoid this by holding the socket lock during
updates in setsockopt PACKET_RESERVE.
This bug was discovered by syzkaller.
Fixes: 8913336a7e8d ("packet: add PACKET_RESERVE sockopt")
[ Upstream commit 8d63bee643f1fb53e472f0e135cae4eb99d62d19 ]
skb_warn_bad_offload triggers a warning when an skb enters the GSO
stack at __skb_gso_segment that does not have CHECKSUM_PARTIAL
checksum offload set.
Commit b2504a5dbef3 ("net: reduce skb_warn_bad_offload() noise")
observed that SKB_GSO_DODGY producers can trigger the check and
that passing those packets through the GSO handlers will fix it
up. But, the software UFO handler will set ip_summed to
CHECKSUM_NONE.
When __skb_gso_segment is called from the receive path, this
triggers the warning again.
Make UFO set CHECKSUM_UNNECESSARY instead of CHECKSUM_NONE. On
Tx these two are equivalent. On Rx, this better matches the
skb state (checksum computed), as CHECKSUM_NONE here means no
checksum computed.
See also this thread for context:
http://patchwork.ozlabs.org/patch/799015/
Fixes: b2504a5dbef3 ("net: reduce skb_warn_bad_offload() noise")
[ Upstream commit 8ba60924710cde564a3905588b6219741d6356d0 ]
With new TCP_FASTOPEN_CONNECT socket option, there is a possibility
to call tcp_connect() while socket sk_dst_cache is either NULL
or invalid.
+0 socket(..., SOCK_STREAM, IPPROTO_TCP) = 4
+0 fcntl(4, F_SETFL, O_RDWR|O_NONBLOCK) = 0
+0 setsockopt(4, SOL_TCP, TCP_FASTOPEN_CONNECT, [1], 4) = 0
+0 connect(4, ..., ...) = 0
<< sk->sk_dst_cache becomes obsolete, or even set to NULL >>
+1 sendto(4, ..., 1000, MSG_FASTOPEN, ..., ...) = 1000
We need to refresh the route otherwise bad things can happen,
especially when syzkaller is running on the host :/
Fixes: 19f6d3f3c8422 ("net/tcp-fastopen: Add new API support")
Cc: Wei Wang <weiwan@google.com>
Cc: Yuchung Cheng <ycheng@google.com>
Acked-by: Wei Wang <weiwan@google.com>
Acked-by: Yuchung Cheng <ycheng@google.com>
[ Upstream commit 96d9703050a0036a3360ec98bb41e107c90664fe ]
Commit 55917a21d0cc ("netfilter: x_tables: add context to know if
extension runs from nft_compat") introduced a member nft_compat to
xt_tgchk_param structure.
But it didn't set it's value for ipt_init_target. With unexpected
value in par.nft_compat, it may return unexpected result in some
target's checkentry.
This patch is to set all it's fields as 0 and only initialize the
non-zero fields in ipt_init_target.
v1->v2:
As Wang Cong's suggestion, fix it by setting all it's fields as
0 and only initializing the non-zero fields.
Fixes: 55917a21d0cc ("netfilter: x_tables: add context to know if extension runs from nft_compat")
Suggested-by: Cong Wang <xiyou.wangcong@gmail.com>
[ Upstream commit 2dda640040876cd8ae646408b69eea40c24f9ae9 ]
syzkaller was able to trigger a divide by 0 in TCP stack [1]
Issue here is that keepalive timer needs to be updated to not attempt
to send a probe if the connection setup was deferred using
TCP_FASTOPEN_CONNECT socket option added in linux-4.11
[1]
divide error: 0000 [#1] SMP
CPU: 18 PID: 0 Comm: swapper/18 Not tainted
task: ffff986f62f4b040 ti: ffff986f62fa2000 task.ti: ffff986f62fa2000
RIP: 0010:[<ffffffff8409cc0d>] [<ffffffff8409cc0d>] __tcp_select_window+0x8d/0x160
Call Trace:
<IRQ>
[<ffffffff8409d951>] tcp_transmit_skb+0x11/0x20
[<ffffffff8409da21>] tcp_xmit_probe_skb+0xc1/0xe0
[<ffffffff840a0ee8>] tcp_write_wakeup+0x68/0x160
[<ffffffff840a151b>] tcp_keepalive_timer+0x17b/0x230
[<ffffffff83b3f799>] call_timer_fn+0x39/0xf0
[<ffffffff83b40797>] run_timer_softirq+0x1d7/0x280
[<ffffffff83a04ddb>] __do_softirq+0xcb/0x257
[<ffffffff83ae03ac>] irq_exit+0x9c/0xb0
[<ffffffff83a04c1a>] smp_apic_timer_interrupt+0x6a/0x80
[<ffffffff83a03eaf>] apic_timer_interrupt+0x7f/0x90
<EOI>
[<ffffffff83fed2ea>] ? cpuidle_enter_state+0x13a/0x3b0
[<ffffffff83fed2cd>] ? cpuidle_enter_state+0x11d/0x3b0
Tested:
Following packetdrill no longer crashes the kernel
`echo 0 >/proc/sys/net/ipv4/tcp_timestamps`
// Cache warmup: send a Fast Open cookie request
0 socket(..., SOCK_STREAM, IPPROTO_TCP) = 3
+0 fcntl(3, F_SETFL, O_RDWR|O_NONBLOCK) = 0
+0 setsockopt(3, SOL_TCP, TCP_FASTOPEN_CONNECT, [1], 4) = 0
+0 connect(3, ..., ...) = -1 EINPROGRESS (Operation is now in progress)
+0 > S 0:0(0) <mss 1460,nop,nop,sackOK,nop,wscale 8,FO,nop,nop>
+.01 < S. 123:123(0) ack 1 win 14600 <mss 1460,nop,nop,sackOK,nop,wscale 6,FO abcd1234,nop,nop>
+0 > . 1:1(0) ack 1
+0 close(3) = 0
+0 > F. 1:1(0) ack 1
+0 < F. 1:1(0) ack 2 win 92
+0 > . 2:2(0) ack 2
+0 setsockopt(4, SOL_SOCKET, SO_KEEPALIVE, [1], 4) = 0
+.01 connect(4, ..., ...) = 0
+0 setsockopt(4, SOL_TCP, TCP_KEEPIDLE, [5], 4) = 0
+10 close(4) = 0
`echo 1 >/proc/sys/net/ipv4/tcp_timestamps`
Fixes: 19f6d3f3c842 ("net/tcp-fastopen: Add new API support")
[ Upstream commit ed254971edea92c3ac5c67c6a05247a92aa6075e ]
If the sender switches the congestion control during ECN-triggered
cwnd-reduction state (CA_CWR), upon exiting recovery cwnd is set to
the ssthresh value calculated by the previous congestion control. If
the previous congestion control is BBR that always keep ssthresh
to TCP_INIFINITE_SSTHRESH, cwnd ends up being infinite. The safe
step is to avoid assigning invalid ssthresh value when recovery ends.
[ Upstream commit a5cb659bbc1c8644efa0c3138a757a1e432a4880 ]
isn't one.
[ Upstream commit 0a28cfd51e17f4f0a056bcf66bfbe492c3b99f38 ]
[ Upstream commit e90ce2fc27cad7e7b1e72b9e66201a7a4c124c2b ]
In dccp_feat_init, when ccid_get_builtin_ccids failsto alloc
memory for rx.val, it should free tx.val before returning an
error.
[ Upstream commit b7953d3c0e30a5fc944f6b7bd0bcceb0794bcd85 ]
The patch "dccp: fix a memleak that dccp_ipv6 doesn't put reqsk
properly" fixed reqsk refcnt leak for dccp_ipv6. The same issue
exists on dccp_ipv4.
This patch is to fix it for dccp_ipv4.
[ Upstream commit 0c2232b0a71db0ac1d22f751aa1ac0cadb950fd2 ]
In dccp_v6_conn_request, after reqsk gets alloced and hashed into
ehash table, reqsk's refcnt is set 3. one is for req->rsk_timer,
one is for hlist, and the other one is for current using.
The problem is when dccp_v6_conn_request returns and finishes using
reqsk, it doesn't put reqsk. This will cause reqsk refcnt leaks and
reqsk obj never gets freed.
Jianlin found this issue when running dccp_memleak.c in a loop, the
system memory would run out.
dccp_memleak.c:
int s1 = socket(PF_INET6, 6, IPPROTO_IP);
bind(s1, &sa1, 0x20);
listen(s1, 0x9);
int s2 = socket(PF_INET6, 6, IPPROTO_IP);
connect(s2, &sa1, 0x20);
close(s1);
close(s2);
This patch is to put the reqsk before dccp_v6_conn_request returns,
just as what tcp_conn_request does.
Reported-by: Jianlin Shi <jishi@redhat.com>
[ Upstream commit afce615aaabfbaad02550e75c0bec106dafa1adf ]
RFC 2465 defines ipv6IfStatsOutFragFails as:
"The number of IPv6 datagrams that have been discarded
because they needed to be fragmented at this output
interface but could not be."
The existing implementation, instead, would increase the counter
twice in case we fail to allocate room for single fragments:
once for the fragment, once for the datagram.
This didn't look intentional though. In one of the two affected
affected failure paths, the double increase was simply a result
of a new 'goto fail' statement, introduced to avoid a skb leak.
The other path appears to be affected since at least 2.6.12-rc2.
Reported-by: Sabrina Dubroca <sdubroca@redhat.com>
Fixes: 1d325d217c7f ("ipv6: ip6_fragment: fix headroom tests and skb leak")
Signed-off-by: Stefano Brivio <sbrivio@redhat.com>
[ Upstream commit c800aaf8d869f2b9b47b10c5c312fe19f0a94042 ]
There are multiple reports showing we have a use-after-free in
the timer prb_retire_rx_blk_timer_expired(), where we use struct
tpacket_kbdq_core::pkbdq, a pg_vec, after it gets freed by
free_pg_vec().
The interesting part is it is not freed via packet_release() but
via packet_setsockopt(), which means we are not closing the socket.
Looking into the big and fat function packet_set_ring(), this could
happen if we satisfy the following conditions:
1. closing == 0, not on packet_release() path
2. req->tp_block_nr == 0, we don't allocate a new pg_vec
3. rx_ring->pg_vec is already set as V3, which means we already called
packet_set_ring() wtih req->tp_block_nr > 0 previously
4. req->tp_frame_nr == 0, pass sanity check
5. po->mapped == 0, never called mmap()
In this scenario we are clearing the old rx_ring->pg_vec, so we need
to free this pg_vec, but we don't stop the timer on this path because
of closing==0.
The timer has to be stopped as long as we need to free pg_vec, therefore
the check on closing!=0 is wrong, we should check pg_vec!=NULL instead.
Thanks to liujian for testing different fixes.
Reported-by: alexander.levin@verizon.com
Reported-by: Dave Jones <davej@codemonkey.org.uk>
Reported-by: liujian (CE) <liujian56@huawei.com>
Tested-by: liujian (CE) <liujian56@huawei.com>
Cc: Ding Tianhong <dingtianhong@huawei.com>
Cc: Willem de Bruijn <willemdebruijn.kernel@gmail.com>
[ Upstream commit 69ec932e364b1ba9c3a2085fe96b76c8a3f71e7c ]
Before the 'type' is validated, we shouldn't use it to fetch the
ovs_ct_attr_lens's minlen and maxlen, else, out of bound access
may happen.
Fixes: 7f8a436eaa2c ("openvswitch: Add conntrack action")
Acked-by: Pravin B Shelar <pshelar@ovn.org>
[ Upstream commit 153711f9421be5dbc973dc57a4109dc9d54c89b1 ]
virtnet_set_mac_address() interprets mac address as struct
sockaddr, but upper layer only allocates dev->addr_len
which is ETH_ALEN + sizeof(sa_family_t) in this case.
We lack a unified definition for mac address, so just fix
the upper layer, this also allows drivers to interpret it
to struct sockaddr freely.
Reported-by: David Ahern <dsahern@gmail.com>
[ Upstream commit 8799a221f5944a7d74516ecf46d58c28ec1d1f75 ]
Net stack initialization currently initializes fib-trie after the
first call to netdevice_notifier() call. In fact fib_trie initialization
needs to happen before first rtnl_register(). It does not cause any problem
since there are no devices UP at this moment, but trying to bring 'lo'
UP at initialization would make this assumption wrong and exposes the issue.
Fixes following crash
Call Trace:
? alternate_node_alloc+0x76/0xa0
fib_table_insert+0x1b7/0x4b0
fib_magic.isra.17+0xea/0x120
fib_add_ifaddr+0x7b/0x190
fib_netdev_event+0xc0/0x130
register_netdevice_notifier+0x1c1/0x1d0
ip_fib_init+0x72/0x85
ip_rt_init+0x187/0x1e9
ip_init+0xe/0x1a
inet_init+0x171/0x26c
? ipv4_offload_init+0x66/0x66
do_one_initcall+0x43/0x160
kernel_init_freeable+0x191/0x219
? rest_init+0x80/0x80
kernel_init+0xe/0x150
ret_from_fork+0x22/0x30
Code: f6 46 23 04 74 86 4c 89 f7 e8 ae 45 01 00 49 89 c7 4d 85 ff 0f 85 7b ff ff ff 31 db eb 08 4c 89 ff e8 16 47 01 00 48 8b 44 24 38 <45> 8b 6e 14 4d 63 76 74 48 89 04 24 0f 1f 44 00 00 48 83 c4 08
RIP: kmem_cache_alloc+0xcf/0x1c0 RSP: ffff9b1500017c28
CR2: 0000000000000014
Fixes: 7b1a74fdbb9e ("[NETNS]: Refactor fib initialization so it can handle multiple namespaces.")
Fixes: 7f9b80529b8a ("[IPV4]: fib hash|trie initialization")
Signed-off-by: Mahesh Bandewar <maheshb@google.com>
Acked-by: "Eric W. Biederman" <ebiederm@xmission.com>
[ Upstream commit 6399f1fae4ec29fab5ec76070435555e256ca3a6 ]
In some cases, offset can overflow and can cause an infinite loop in
ip6_find_1stfragopt(). Make it unsigned int to prevent the overflow, and
cap it at IPV6_MAXPLEN, since packets larger than that should be invalid.
This problem has been here since before the beginning of git history.
Signed-off-by: Sabrina Dubroca <sd@queasysnail.net>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
[ Upstream commit 63679112c536289826fec61c917621de95ba2ade ]
The ifr.ifr_name is passed around and assumed to be NULL terminated.
[ Upstream commit 18bcf2907df935981266532e1e0d052aff2e6fae ]
KMSAN reported use of uninitialized memory in skb_set_hash_from_sk(),
which originated from the TCP request socket created in
cookie_v6_check():
BUG: KMSAN: use of uninitialized memory in tcp_transmit_skb+0xf77/0x3ec0
CPU: 1 PID: 2949 Comm: syz-execprog Not tainted 4.11.0-rc5+ #2931
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
TCP: request_sock_TCPv6: Possible SYN flooding on port 20028. Sending cookies. Check SNMP counters.
Call Trace:
<IRQ>
dump_stack+0x172/0x1c0 lib/dump_stack.c:52
kmsan_report+0x12a/0x180 mm/kmsan/kmsan.c:927
__msan_warning_32+0x61/0xb0 mm/kmsan/kmsan_instr.c:469
skb_set_hash_from_sk ./include/net/sock.h:2011
tcp_transmit_skb+0xf77/0x3ec0 net/ipv4/tcp_output.c:983
tcp_send_ack+0x75b/0x830 net/ipv4/tcp_output.c:3493
tcp_delack_timer_handler+0x9a6/0xb90 net/ipv4/tcp_timer.c:284
tcp_delack_timer+0x1b0/0x310 net/ipv4/tcp_timer.c:309
call_timer_fn+0x240/0x520 kernel/time/timer.c:1268
__run_timers+0xc13/0xf10 kernel/time/timer.c:1601
run_timer_softirq+0x36/0xa0 kernel/time/timer.c:1614
__do_softirq+0x485/0x942 kernel/softirq.c:284
irq_exit+0x1fa/0x230 kernel/softirq.c:405
exiting_irq+0xe/0x10 ./arch/x86/include/asm/apic.h:657
smp_apic_timer_interrupt+0x5a/0x80 arch/x86/kernel/apic/apic.c:966
apic_timer_interrupt+0x86/0x90 arch/x86/entry/entry_64.S:489
RIP: 0010:native_restore_fl ./arch/x86/include/asm/irqflags.h:36
RIP: 0010:arch_local_irq_restore ./arch/x86/include/asm/irqflags.h:77
RIP: 0010:__msan_poison_alloca+0xed/0x120 mm/kmsan/kmsan_instr.c:440
RSP: 0018:ffff880024917cd8 EFLAGS: 00000246 ORIG_RAX: ffffffffffffff10
RAX: 0000000000000246 RBX: ffff8800224c0000 RCX: 0000000000000005
RDX: 0000000000000004 RSI: ffff880000000000 RDI: ffffea0000b6d770
RBP: ffff880024917d58 R08: 0000000000000dd8 R09: 0000000000000004
R10: 0000160000000000 R11: 0000000000000000 R12: ffffffff85abf810
R13: ffff880024917dd8 R14: 0000000000000010 R15: ffffffff81cabde4
</IRQ>
poll_select_copy_remaining+0xac/0x6b0 fs/select.c:293
SYSC_select+0x4b4/0x4e0 fs/select.c:653
SyS_select+0x76/0xa0 fs/select.c:634
entry_SYSCALL_64_fastpath+0x13/0x94 arch/x86/entry/entry_64.S:204
RIP: 0033:0x4597e7
RSP: 002b:000000c420037ee0 EFLAGS: 00000246 ORIG_RAX: 0000000000000017
RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00000000004597e7
RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000000000000
RBP: 000000c420037ef0 R08: 000000c420037ee0 R09: 0000000000000059
R10: 0000000000000000 R11: 0000000000000246 R12: 000000000042dc20
R13: 00000000000000f3 R14: 0000000000000030 R15: 0000000000000003
chained origin:
save_stack_trace+0x37/0x40 arch/x86/kernel/stacktrace.c:59
kmsan_save_stack_with_flags mm/kmsan/kmsan.c:302
kmsan_save_stack mm/kmsan/kmsan.c:317
kmsan_internal_chain_origin+0x12a/0x1f0 mm/kmsan/kmsan.c:547
__msan_store_shadow_origin_4+0xac/0x110 mm/kmsan/kmsan_instr.c:259
tcp_create_openreq_child+0x709/0x1ae0 net/ipv4/tcp_minisocks.c:472
tcp_v6_syn_recv_sock+0x7eb/0x2a30 net/ipv6/tcp_ipv6.c:1103
tcp_get_cookie_sock+0x136/0x5f0 net/ipv4/syncookies.c:212
cookie_v6_check+0x17a9/0x1b50 net/ipv6/syncookies.c:245
tcp_v6_cookie_check net/ipv6/tcp_ipv6.c:989
tcp_v6_do_rcv+0xdd8/0x1c60 net/ipv6/tcp_ipv6.c:1298
tcp_v6_rcv+0x41a3/0x4f00 net/ipv6/tcp_ipv6.c:1487
ip6_input_finish+0x82f/0x1ee0 net/ipv6/ip6_input.c:279
NF_HOOK ./include/linux/netfilter.h:257
ip6_input+0x239/0x290 net/ipv6/ip6_input.c:322
dst_input ./include/net/dst.h:492
ip6_rcv_finish net/ipv6/ip6_input.c:69
ipv6_rcv+0x1dbd/0x22e0 net/ipv6/ip6_input.c:203
__netif_receive_skb_core+0x2f6f/0x3a20 net/core/dev.c:4208
__netif_receive_skb net/core/dev.c:4246
process_backlog+0x667/0xba0 net/core/dev.c:4866
napi_poll net/core/dev.c:5268
net_rx_action+0xc95/0x1590 net/core/dev.c:5333
origin:
kmsan_internal_poison_shadow+0xb1/0x1a0 mm/kmsan/kmsan.c:198
kmsan_kmalloc+0x7f/0xe0 mm/kmsan/kmsan.c:337
kmem_cache_alloc+0x1c2/0x1e0 mm/slub.c:2766
reqsk_alloc ./include/net/request_sock.h:87
inet_reqsk_alloc+0xa4/0x5b0 net/ipv4/tcp_input.c:6200
cookie_v6_check+0x4f4/0x1b50 net/ipv6/syncookies.c:169
Similar error is reported for cookie_v4_check().
Fixes: 58d607d3e52f ("tcp: provide skb->hash to synack packets")
commit 4c86d77743a54fb2d8a4d18a037a074c892bb3be upstream.
On IPv4-mapped IPv6 addresses sk_family is AF_INET6,
but the flow informations are created based on AF_INET.
So the routing set up 'struct flowi4' but we try to
access 'struct flowi6' what leads to an out of bounds
access. Fix this by using the family we get with the
dst_entry, like we do it for the standard policy lookup.
Tested-by: Dmitry Vyukov <dvyukov@google.com>
[ Upstream commit e4c5e13aa45c23692e4acf56f0b3533f328199b2 ]
There is an inconsistent conditional judgement between __ip6_append_data
and ip6_finish_output functions, the variable length in __ip6_append_data
just include the length of application's payload and udp6 header, don't
include the length of ipv6 header, but in ip6_finish_output use
(skb->len > ip6_skb_dst_mtu(skb)) as judgement, and skb->len include the
length of ipv6 header.
That causes some particular application's udp6 payloads whose length are
between (MTU - IPv6 Header) and MTU were fragmented by ip6_fragment even
Add the length of ipv6 header to length in __ip6_append_data to keep
consistent conditional judgement as ip6_finish_output for ip6 fragment.
commit 6e7bc478c9a006c701c14476ec9d389a484b4864 upstream.
My recent change missed fact that UFO would perform a complete
UDP checksum before segmenting in frags.
In this case skb->ip_summed is set to CHECKSUM_NONE.
We need to add this valid case to skb_needs_check()
Cc: Willem de Bruijn <willemb@google.com>
commit 308453aa9156a3b8ee382c0949befb507a32b0c1 upstream.
The MAC address of the physical interface is only copied to the VLAN
when it is first created, resulting in an inconsistency after MAC
address changes of only newly created VLANs having an up-to-date MAC.
The VLANs should continue inheriting the MAC address of the physical
interface until the VLAN MAC address is explicitly set to any value.
This allows IPv6 EUI64 addresses for the VLAN to reflect any changes
to the MAC of the physical interface and thus for DAD to behave as
expected.
Signed-off-by: Mike Manning <mmanning@brocade.com>
Signed-off-by: Sumit Semwal <sumit.semwal@linaro.org>
commit b2504a5dbef3305ef41988ad270b0e8ec289331c upstream.
Dmitry reported warnings occurring in __skb_gso_segment() [1]
All SKB_GSO_DODGY producers can allow user space to feed
packets that trigger the current check.
We could prevent them from doing so, rejecting packets, but
this might add regressions to existing programs.
It turns out our SKB_GSO_DODGY handlers properly set up checksum
information that is needed anyway when packets needs to be segmented.
By checking again skb_needs_check() after skb_mac_gso_segment(),
we should remove these pesky warnings, at a very minor cost.
With help from Willem de Bruijn
[1]
WARNING: CPU: 1 PID: 6768 at net/core/dev.c:2439 skb_warn_bad_offload+0x2af/0x390 net/core/dev.c:2434
lo: caps=(0x000000a2803b7c69, 0x0000000000000000) len=138 data_len=0 gso_size=15883 gso_type=4 ip_summed=0
CPU: 1 PID: 6768 Comm: syz-executor1 Not tainted 4.9.0 #5
ffff8801c063ecd8 ffffffff82346bdf ffffffff00000001 1ffff100380c7d2e
ffffed00380c7d26 0000000041b58ab3 ffffffff84b37e38 ffffffff823468f1
ffffffff84820740 ffffffff84f289c0 dffffc0000000000 ffff8801c063ee20
Call Trace:
[<ffffffff82346bdf>] __dump_stack lib/dump_stack.c:15 [inline]
[<ffffffff82346bdf>] dump_stack+0x2ee/0x3ef lib/dump_stack.c:51
[<ffffffff81827e34>] panic+0x1fb/0x412 kernel/panic.c:179
[<ffffffff8141f704>] __warn+0x1c4/0x1e0 kernel/panic.c:542
[<ffffffff8141f7e5>] warn_slowpath_fmt+0xc5/0x100 kernel/panic.c:565
[<ffffffff8356cbaf>] skb_warn_bad_offload+0x2af/0x390 net/core/dev.c:2434
[<ffffffff83585cd2>] __skb_gso_segment+0x482/0x780 net/core/dev.c:2706
[<ffffffff83586f19>] skb_gso_segment include/linux/netdevice.h:3985 [inline]
[<ffffffff83586f19>] validate_xmit_skb+0x5c9/0xc20 net/core/dev.c:2969
[<ffffffff835892bb>] __dev_queue_xmit+0xe6b/0x1e70 net/core/dev.c:3383
[<ffffffff8358a2d7>] dev_queue_xmit+0x17/0x20 net/core/dev.c:3424
[<ffffffff83ad161d>] packet_snd net/packet/af_packet.c:2930 [inline]
[<ffffffff83ad161d>] packet_sendmsg+0x32ed/0x4d30 net/packet/af_packet.c:2955
[<ffffffff834f0aaa>] sock_sendmsg_nosec net/socket.c:621 [inline]
[<ffffffff834f0aaa>] sock_sendmsg+0xca/0x110 net/socket.c:631
[<ffffffff834f329a>] ___sys_sendmsg+0x8fa/0x9f0 net/socket.c:1954
[<ffffffff834f5e58>] __sys_sendmsg+0x138/0x300 net/socket.c:1988
[<ffffffff834f604d>] SYSC_sendmsg net/socket.c:1999 [inline]
[<ffffffff834f604d>] SyS_sendmsg+0x2d/0x50 net/socket.c:1995
[<ffffffff84371941>] entry_SYSCALL_64_fastpath+0x1f/0xc2
Cc: Mark Salyzyn <salyzyn@android.com>
commit 89e357d83c06b6fac581c3ca7f0ee3ae7e67109e upstream.
A dump may come in the middle of another dump, modifying its dump
structure members. This race condition will result in NULL pointer
dereference in kernel. So add a lock to prevent that race.
Fixes: 83321d6b9872 ("[AF_KEY]: Dump SA/SP entries non-atomically")
Signed-off-by: Yuejie Shi <syjcnss@gmail.com>
Signed-off-by: Mark Salyzyn <salyzyn@android.com>
commit 3c5ab3f395d66a9e4e937fcfdf6ebc63894f028b upstream.
We do not check if packet from real server is for NAT
connection before performing SNAT. This causes problems
for setups that use DR/TUN and allow local clients to
access the real server directly, for example:
- local client in director creates IPVS-DR/TUN connection
CIP->VIP and the request packets are routed to RIP.
Talks are finished but IPVS connection is not expired yet.
- second local client creates non-IPVS connection CIP->RIP
with same reply tuple RIP->CIP and when replies are received
on LOCAL_IN we wrongly assign them for the first client
connection because RIP->CIP matches the reply direction.
As result, IPVS SNATs replies for non-IPVS connections.
The problem is more visible to local UDP clients but in rare
cases it can happen also for TCP or remote clients when the
real server sends the reply traffic via the director.
So, better to be more precise for the reply traffic.
As replies are not expected for DR/TUN connections, better
to not touch them.
Reported-by: Nick Moriarty <nick.moriarty@york.ac.uk>
Tested-by: Nick Moriarty <nick.moriarty@york.ac.uk>
Signed-off-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Simon Horman <horms@verge.net.au>
