path: root/net
2008-11-09net: unix: fix inflight counting bug in garbage collectorMiklos Szeredi
Previously I assumed that the receive queues of candidates don't change during the GC. This is only half true, nothing can be received from the queues (see comment in unix_gc()), but buffers could be added through the other half of the socket pair, which may still have file descriptors referring to it. This can result in inc_inflight_move_tail() erronously increasing the "inflight" counter for a unix socket for which dec_inflight() wasn't previously called. This in turn can trigger the "BUG_ON(total_refs < inflight_refs)" in a later garbage collection run. Fix this by only manipulating the "inflight" counter for sockets which are candidates themselves. Duplicating the file references in unix_attach_fds() is also needed to prevent a socket becoming a candidate for GC while the skb that contains it is not yet queued. Reported-by: Andrea Bittau <a.bittau@cs.ucl.ac.uk> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> CC: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: net: Fix recursive descent in __scm_destroy(). iwl3945: fix deadlock on suspend iwl3945: do not send scan command if channel count zero iwl3945: clear scanning bits upon failure ath5k: correct handling of rx status fields zd1211rw: Add 2 device IDs Fix logic error in rfkill_check_duplicity iwlagn: avoid sleep in softirq context iwlwifi: clear scanning bits upon failure Revert "ath5k: honor FIF_BCN_PRBRESP_PROMISC in STA mode" tcp: Fix recvmsg MSG_PEEK influence of blocking behavior. netfilter: netns ct: walk netns list under RTNL ipv6: fix run pending DAD when interface becomes ready net/9p: fix printk format warnings net: fix packet socket delivery in rx irq handler xfrm: Have af-specific init_tempsel() initialize family field of temporary selector
2008-11-06Merge branch 'master' of ↵David S. Miller
2008-11-06Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs: net/9p: fix printk format warnings unsigned fid->fid cannot be negative 9p: rdma: remove duplicated #include p9: Fix leak of waitqueue in request allocation path 9p: Remove unneeded free of fcall for Flush 9p: Make all client spin locks IRQ safe 9p: rdma: Set trans prior to requesting async connection ops
2008-11-06net: Fix recursive descent in __scm_destroy().David S. Miller
__scm_destroy() walks the list of file descriptors in the scm_fp_list pointed to by the scm_cookie argument. Those, in turn, can close sockets and invoke __scm_destroy() again. There is nothing which limits how deeply this can occur. The idea for how to fix this is from Linus. Basically, we do all of the fput()s at the top level by collecting all of the scm_fp_list objects hit by an fput(). Inside of the initial __scm_destroy() we keep running the list until it is empty. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-06net: Fix recursive descent in __scm_destroy().David Miller
__scm_destroy() walks the list of file descriptors in the scm_fp_list pointed to by the scm_cookie argument. Those, in turn, can close sockets and invoke __scm_destroy() again. There is nothing which limits how deeply this can occur. The idea for how to fix this is from Linus. Basically, we do all of the fput()s at the top level by collecting all of the scm_fp_list objects hit by an fput(). Inside of the initial __scm_destroy() we keep running the list until it is empty. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-06Fix logic error in rfkill_check_duplicityJonathan McDowell
> I'll have a prod at why the [hso] rfkill stuff isn't working next Ok, I believe this is due to the addition of rfkill_check_duplicity in rfkill and the fact that test_bit actually returns a negative value rather than the postive one expected (which is of course equally true). So when the second WLAN device (the hso device, with the EEE PC WLAN being the first) comes along rfkill_check_duplicity returns a negative value and so rfkill_register returns an error. Patch below fixes this for me. Signed-Off-By: Jonathan McDowell <noodles@earth.li> Acked-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-11-05net/9p: fix printk format warningsRandy Dunlap
Fix printk format warnings in net/9p. Built cleanly on 7 arches. net/9p/client.c:820: warning: format '%llx' expects type 'long long unsigned int', but argument 4 has type 'u64' net/9p/client.c:820: warning: format '%llx' expects type 'long long unsigned int', but argument 5 has type 'u64' net/9p/client.c:867: warning: format '%llx' expects type 'long long unsigned int', but argument 4 has type 'u64' net/9p/client.c:867: warning: format '%llx' expects type 'long long unsigned int', but argument 5 has type 'u64' net/9p/client.c:932: warning: format '%llx' expects type 'long long unsigned int', but argument 5 has type 'u64' net/9p/client.c:932: warning: format '%llx' expects type 'long long unsigned int', but argument 6 has type 'u64' net/9p/client.c:982: warning: format '%llx' expects type 'long long unsigned int', but argument 4 has type 'u64' net/9p/client.c:982: warning: format '%llx' expects type 'long long unsigned int', but argument 5 has type 'u64' net/9p/client.c:1025: warning: format '%llx' expects type 'long long unsigned int', but argument 4 has type 'u64' net/9p/client.c:1025: warning: format '%llx' expects type 'long long unsigned int', but argument 5 has type 'u64' net/9p/client.c:1227: warning: format '%llx' expects type 'long long unsigned int', but argument 7 has type 'u64' net/9p/client.c:1227: warning: format '%llx' expects type 'long long unsigned int', but argument 12 has type 'u64' net/9p/client.c:1227: warning: format '%llx' expects type 'long long unsigned int', but argument 8 has type 'u64' net/9p/client.c:1227: warning: format '%llx' expects type 'long long unsigned int', but argument 13 has type 'u64' net/9p/client.c:1252: warning: format '%llx' expects type 'long long unsigned int', but argument 7 has type 'u64' net/9p/client.c:1252: warning: format '%llx' expects type 'long long unsigned int', but argument 12 has type 'u64' net/9p/client.c:1252: warning: format '%llx' expects type 'long long unsigned int', but argument 8 has type 'u64' net/9p/client.c:1252: warning: format '%llx' expects type 'long long unsigned int', but argument 13 has type 'u64' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2008-11-05unsigned fid->fid cannot be negativeRoel Kluin
Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2008-11-059p: rdma: remove duplicated #includeHuang Weiyi
Removed duplicated #include <rdma/ib_verbs.h> in net/9p/trans_rdma.c. Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2008-11-05p9: Fix leak of waitqueue in request allocation pathTom Tucker
If a T or R fcall cannot be allocated, the function returns an error but neglects to free the wait queue that was successfully allocated. If it comes through again a second time this wq will be overwritten with a new allocation and the old allocation will be leaked. Also, if the client is subsequently closed, the close path will attempt to clean up these allocations, so set the req fields to NULL to avoid duplicate free. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2008-11-059p: Remove unneeded free of fcall for FlushTom Tucker
T and R fcall are reused until the client is destroyed. There does not need to be a special case for Flush Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2008-11-059p: Make all client spin locks IRQ safeTom Tucker
The client lock must be IRQ safe. Some of the lock acquisition paths took regular spin locks. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2008-11-059p: rdma: Set trans prior to requesting async connection opsTom Tucker
The RDMA connection manager is fundamentally asynchronous. Since the async callback context is the client pointer, the transport in the client struct needs to be set prior to calling the first async op. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2008-11-05tcp: Fix recvmsg MSG_PEEK influence of blocking behavior.David S. Miller
Vito Caputo noticed that tcp_recvmsg() returns immediately from partial reads when MSG_PEEK is used. In particular, this means that SO_RCVLOWAT is not respected. Simply remove the test. And this matches the behavior of several other systems, including BSD. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-05netfilter: netns ct: walk netns list under RTNLAlexey Dobriyan
netns list (just list) is under RTNL. But helper and proto unregistration happen during rmmod when RTNL is not held, and that's how it was tested: modprobe/rmmod vs clone(CLONE_NEWNET)/exit. BUG: unable to handle kernel paging request at 0000000000100100 <=== IP: [<ffffffffa009890f>] nf_conntrack_l4proto_unregister+0x96/0xae [nf_conntrack] PGD 15e300067 PUD 15e1d8067 PMD 0 Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC last sysfs file: /sys/kernel/uevent_seqnum CPU 0 Modules linked in: nf_conntrack_proto_sctp(-) nf_conntrack_proto_dccp(-) af_packet iptable_nat nf_nat nf_conntrack_ipv4 nf_conntrack nf_defrag_ipv4 iptable_filter ip_tables xt_tcpudp ip6table_filter ip6_tables x_tables ipv6 sr_mod cdrom [last unloaded: nf_conntrack_proto_sctp] Pid: 16758, comm: rmmod Not tainted 2.6.28-rc2-netns-xfrm #3 RIP: 0010:[<ffffffffa009890f>] [<ffffffffa009890f>] nf_conntrack_l4proto_unregister+0x96/0xae [nf_conntrack] RSP: 0018:ffff88015dc1fec8 EFLAGS: 00010212 RAX: 0000000000000000 RBX: 00000000001000f8 RCX: 0000000000000000 RDX: ffffffffa009575c RSI: 0000000000000003 RDI: ffffffffa00956b5 RBP: ffff88015dc1fed8 R08: 0000000000000002 R09: 0000000000000000 R10: 0000000000000000 R11: ffff88015dc1fe48 R12: ffffffffa0458f60 R13: 0000000000000880 R14: 00007fff4c361d30 R15: 0000000000000880 FS: 00007f624435a6f0(0000) GS:ffffffff80521580(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 0000000000100100 CR3: 0000000168969000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process rmmod (pid: 16758, threadinfo ffff88015dc1e000, task ffff880179864218) Stack: ffffffffa0459100 0000000000000000 ffff88015dc1fee8 ffffffffa0457934 ffff88015dc1ff78 ffffffff80253fef 746e6e6f635f666e 6f72705f6b636172 00707463735f6f74 ffffffff8024cb30 00000000023b8010 0000000000000000 Call Trace: [<ffffffffa0457934>] nf_conntrack_proto_sctp_fini+0x10/0x1e [nf_conntrack_proto_sctp] [<ffffffff80253fef>] sys_delete_module+0x19f/0x1fe [<ffffffff8024cb30>] ? trace_hardirqs_on_caller+0xf0/0x114 [<ffffffff803ea9b2>] ? trace_hardirqs_on_thunk+0x3a/0x3f [<ffffffff8020b52b>] system_call_fastpath+0x16/0x1b Code: 13 35 e0 e8 c4 6c 1a e0 48 8b 1d 6d c6 46 e0 eb 16 48 89 df 4c 89 e2 48 c7 c6 fc 85 09 a0 e8 61 cd ff ff 48 8b 5b 08 48 83 eb 08 <48> 8b 43 08 0f 18 08 48 8d 43 08 48 3d 60 4f 50 80 75 d3 5b 41 RIP [<ffffffffa009890f>] nf_conntrack_l4proto_unregister+0x96/0xae [nf_conntrack] RSP <ffff88015dc1fec8> CR2: 0000000000100100 ---[ end trace bde8ac82debf7192 ]--- Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-05ipv6: fix run pending DAD when interface becomes readyBenjamin Thery
With some net devices types, an IPv6 address configured while the interface was down can stay 'tentative' forever, even after the interface is set up. In some case, pending IPv6 DADs are not executed when the device becomes ready. I observed this while doing some tests with kvm. If I assign an IPv6 address to my interface eth0 (kvm driver rtl8139) when it is still down then the address is flagged tentative (IFA_F_TENTATIVE). Then, I set eth0 up, and to my surprise, the address stays 'tentative', no DAD is executed and the address can't be pinged. I also observed the same behaviour, without kvm, with virtual interfaces types macvlan and veth. Some easy steps to reproduce the issue with macvlan: 1. ip link add link eth0 type macvlan 2. ip -6 addr add 2003::ab32/64 dev macvlan0 3. ip addr show dev macvlan0 ... inet6 2003::ab32/64 scope global tentative ... 4. ip link set macvlan0 up 5. ip addr show dev macvlan0 ... inet6 2003::ab32/64 scope global tentative ... Address is still tentative I think there's a bug in net/ipv6/addrconf.c, addrconf_notify(): addrconf_dad_run() is not always run when the interface is flagged IF_READY. Currently it is only run when receiving NETDEV_CHANGE event. Looks like some (virtual) devices doesn't send this event when becoming up. For both NETDEV_UP and NETDEV_CHANGE events, when the interface becomes ready, run_pending should be set to 1. Patch below. 'run_pending = 1' could be moved below the if/else block but it makes the code less readable. Signed-off-by: Benjamin Thery <benjamin.thery@bull.net> Signed-off-by: David S. Miller <davem@davemloft.net>
Fix printk format warnings in net/9p. Built cleanly on 7 arches. net/9p/client.c:820: warning: format '%llx' expects type 'long long unsigned int', but argument 4 has type 'u64' net/9p/client.c:820: warning: format '%llx' expects type 'long long unsigned int', but argument 5 has type 'u64' net/9p/client.c:867: warning: format '%llx' expects type 'long long unsigned int', but argument 4 has type 'u64' net/9p/client.c:867: warning: format '%llx' expects type 'long long unsigned int', but argument 5 has type 'u64' net/9p/client.c:932: warning: format '%llx' expects type 'long long unsigned int', but argument 5 has type 'u64' net/9p/client.c:932: warning: format '%llx' expects type 'long long unsigned int', but argument 6 has type 'u64' net/9p/client.c:982: warning: format '%llx' expects type 'long long unsigned int', but argument 4 has type 'u64' net/9p/client.c:982: warning: format '%llx' expects type 'long long unsigned int', but argument 5 has type 'u64' net/9p/client.c:1025: warning: format '%llx' expects type 'long long unsigned int', but argument 4 has type 'u64' net/9p/client.c:1025: warning: format '%llx' expects type 'long long unsigned int', but argument 5 has type 'u64' net/9p/client.c:1227: warning: format '%llx' expects type 'long long unsigned int', but argument 7 has type 'u64' net/9p/client.c:1227: warning: format '%llx' expects type 'long long unsigned int', but argument 12 has type 'u64' net/9p/client.c:1227: warning: format '%llx' expects type 'long long unsigned int', but argument 8 has type 'u64' net/9p/client.c:1227: warning: format '%llx' expects type 'long long unsigned int', but argument 13 has type 'u64' net/9p/client.c:1252: warning: format '%llx' expects type 'long long unsigned int', but argument 7 has type 'u64' net/9p/client.c:1252: warning: format '%llx' expects type 'long long unsigned int', but argument 12 has type 'u64' net/9p/client.c:1252: warning: format '%llx' expects type 'long long unsigned int', but argument 8 has type 'u64' net/9p/client.c:1252: warning: format '%llx' expects type 'long long unsigned int', but argument 13 has type 'u64' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-04net: fix packet socket delivery in rx irq handlerPatrick McHardy
The changes to deliver hardware accelerated VLAN packets to packet sockets (commit bc1d0411) caused a warning for non-NAPI drivers. The __vlan_hwaccel_rx() function is called directly from the drivers RX function, for non-NAPI drivers that means its still in RX IRQ context: [ 27.779463] ------------[ cut here ]------------ [ 27.779509] WARNING: at kernel/softirq.c:136 local_bh_enable+0x37/0x81() ... [ 27.782520] [<c0264755>] netif_nit_deliver+0x5b/0x75 [ 27.782590] [<c02bba83>] __vlan_hwaccel_rx+0x79/0x162 [ 27.782664] [<f8851c1d>] atl1_intr+0x9a9/0xa7c [atl1] [ 27.782738] [<c0155b17>] handle_IRQ_event+0x23/0x51 [ 27.782808] [<c015692e>] handle_edge_irq+0xc2/0x102 [ 27.782878] [<c0105fd5>] do_IRQ+0x4d/0x64 Split hardware accelerated VLAN reception into two parts to fix this: - __vlan_hwaccel_rx just stores the VLAN TCI and performs the VLAN device lookup, then calls netif_receive_skb()/netif_rx() - vlan_hwaccel_do_receive(), which is invoked by netif_receive_skb() in softirq context, performs the real reception and delivery to packet sockets. Reported-and-tested-by: Ramon Casellas <ramon.casellas@cttc.es> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-04xfrm: Have af-specific init_tempsel() initialize family field of temporary ↵Andreas Steffen
selector While adding MIGRATE support to strongSwan, Andreas Steffen noticed that the selectors provided in XFRM_MSG_ACQUIRE have their family field uninitialized (those in MIGRATE do have their family set). Looking at the code, this is because the af-specific init_tempsel() (called via afinfo->init_tempsel() in xfrm_init_tempsel()) do not set the value. Reported-by: Andreas Steffen <andreas.steffen@strongswan.org> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Arnaud Ebalard <arno@natisbad.org>
2008-11-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: xfrm: Fix xfrm_policy_gc_lock handling. niu: Use pci_ioremap_bar(). bnx2x: Version Update bnx2x: Calling netif_carrier_off at the end of the probe bnx2x: PCI configuration bug on big-endian bnx2x: Removing the PMF indication when unloading mv643xx_eth: fix SMI bus access timeouts net: kconfig cleanup fs_enet: fix polling XFRM: copy_to_user_kmaddress() reports local address twice SMC91x: Fix compilation on some platforms. udp: Fix the SNMP counter of UDP_MIB_INERRORS udp: Fix the SNMP counter of UDP_MIB_INDATAGRAMS drivers/net/smc911x.c: Fix lockdep warning on xmit.
2008-11-03xfrm: Fix xfrm_policy_gc_lock handling.Alexey Dobriyan
From: Alexey Dobriyan <adobriyan@gmail.com> Based upon a lockdep trace by Simon Arlott. xfrm_policy_kill() can be called from both BH and non-BH contexts, so we have to grab xfrm_policy_gc_lock with BH disabling. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03XFRM: copy_to_user_kmaddress() reports local address twiceArnaud Ebalard
While adding support for MIGRATE/KMADDRESS in strongSwan (as specified in draft-ebalard-mext-pfkey-enhanced-migrate-00), Andreas Steffen noticed that XFRMA_KMADDRESS attribute passed to userland contains the local address twice (remote provides local address instead of remote one). This bug in copy_to_user_kmaddress() affects only key managers that use native XFRM interface (key managers that use PF_KEY are not affected). For the record, the bug was in the initial changeset I posted which added support for KMADDRESS (13c1d18931ebb5cf407cb348ef2cd6284d68902d 'xfrm: MIGRATE enhancements (draft-ebalard-mext-pfkey-enhanced-migrate)'). Signed-off-by: Arnaud Ebalard <arno@natisbad.org> Reported-by: Andreas Steffen <andreas.steffen@strongswan.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-02udp: Fix the SNMP counter of UDP_MIB_INERRORSWei Yongjun
UDP packets received in udpv6_recvmsg() are not only IPv6 UDP packets, but also have IPv4 UDP packets, so when do the counter of UDP_MIB_INERRORS in udpv6_recvmsg(), we should check whether the packet is a IPv6 UDP packet or a IPv4 UDP packet. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-02udp: Fix the SNMP counter of UDP_MIB_INDATAGRAMSWei Yongjun
If UDP echo is sent to xinetd/echo-dgram, the UDP reply will be received at the sender. But the SNMP counter of UDP_MIB_INDATAGRAMS will be not increased, UDP6_MIB_INDATAGRAMS will be increased instead. Endpoint A Endpoint B UDP Echo request -----------> (IPv4, Dst port=7) <---------- UDP Echo Reply (IPv4, Src port=7) This bug is come from this patch cb75994ec311b2cd50e5205efdcc0696abd6675d. It do counter UDP[6]_MIB_INDATAGRAMS until udp[v6]_recvmsg. Because xinetd used IPv6 socket to receive UDP messages, thus, when received UDP packet, the UDP6_MIB_INDATAGRAMS will be increased in function udpv6_recvmsg() even if the packet is a IPv4 UDP packet. This patch fixed the problem. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (33 commits) af_unix: netns: fix problem of return value IRDA: remove double inclusion of module.h udp: multicast packets need to check namespace net: add documentation for skb recycling key: fix setkey(8) policy set breakage bpa10x: free sk_buff with kfree_skb xfrm: do not leak ESRCH to user space net: Really remove all of LOOPBACK_TSO code. netfilter: nf_conntrack_proto_gre: switch to register_pernet_gen_subsys() netns: add register_pernet_gen_subsys/unregister_pernet_gen_subsys net: delete excess kernel-doc notation pppoe: Fix socket leak. gianfar: Don't reset TBI<->SerDes link if it's already up gianfar: Fix race in TBI/SerDes configuration at91_ether: request/free GPIO for PHY interrupt amd8111e: fix dma_free_coherent context atl1: fix vlan tag regression SMC91x: delete unused local variable "lp" myri10ge: fix stop/go mmio ordering bonding: fix panic when taking bond interface down before removing module ...
2008-11-01af_unix: netns: fix problem of return valueJianjun Kong
fix problem of return value net/unix/af_unix.c: unix_net_init() when error appears, it should return 'error', not always return 0. Signed-off-by: Jianjun Kong <jianjun@zeuux.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-01udp: multicast packets need to check namespaceEric Dumazet
Current UDP multicast delivery is not namespace aware. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Acked-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-01net: add documentation for skb recyclingStephen Hemminger
Commit 04a4bb55bcf35b63d40fd2725e58599ff8310dd7 ("net: add skb_recycle_check() to enable netdriver skb recycling") added a method for network drivers to recycle skbuffs, but while use of this mechanism was documented in the commit message, it should really have been added as a docbook comment as well -- this patch does that. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-01saner FASYNC handling on file closeAl Viro
As it is, all instances of ->release() for files that have ->fasync() need to remember to evict file from fasync lists; forgetting that creates a hole and we actually have a bunch that *does* forget. So let's keep our lives simple - let __fput() check FASYNC in file->f_flags and call ->fasync() there if it's been set. And lose that crap in ->release() instances - leaving it there is still valid, but we don't have to bother anymore. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-31key: fix setkey(8) policy set breakageAlexey Dobriyan
Steps to reproduce: #/usr/sbin/setkey -f flush; spdflush; add 192.168.0.42 192.168.0.1 ah 24500 -A hmac-md5 "1234567890123456"; add 192.168.0.42 192.168.0.1 esp 24501 -E 3des-cbc "123456789012123456789012"; spdadd 192.168.0.42 192.168.0.1 any -P out ipsec esp/transport//require ah/transport//require; setkey: invalid keymsg length Policy dump will bail out with the same message after that. -recv(4, "\2\16\0\0\32\0\3\0\0\0\0\0\37\r\0\0\3\0\5\0\377 \0\0\2\0\0\0\300\250\0*\0"..., 32768, 0) = 208 +recv(4, "\2\16\0\0\36\0\3\0\0\0\0\0H\t\0\0\3\0\5\0\377 \0\0\2\0\0\0\300\250\0*\0"..., 32768, 0) = 208 Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-31xfrm: do not leak ESRCH to user spacefernando@oss.ntt.co
I noticed that, under certain conditions, ESRCH can be leaked from the xfrm layer to user space through sys_connect. In particular, this seems to happen reliably when the kernel fails to resolve a template either because the AF_KEY receive buffer being used by racoon is full or because the SA entry we are trying to use is in XFRM_STATE_EXPIRED state. However, since this could be a transient issue it could be argued that EAGAIN would be more appropriate. Besides this error code is not even documented in the man page for sys_connect (as of man-pages 3.07). Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-30Merge branch 'master' of git://git.infradead.org/users/pcmoore/lblnet-2.6David S. Miller
2008-10-30netfilter: nf_conntrack_proto_gre: switch to register_pernet_gen_subsys()Alexey Dobriyan
register_pernet_gen_device() can't be used is nf_conntrack_pptp module is also used (compiled in or loaded). Right now, proto_gre_net_exit() is called before nf_conntrack_pptp_net_exit(). The former shutdowns and frees GRE piece of netns, however the latter absolutely needs it to flush keymap. Oops is inevitable. Switch to shiny new register_pernet_gen_subsys() to get correct ordering in netns ops list. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-30netns: add register_pernet_gen_subsys/unregister_pernet_gen_subsysAlexey Dobriyan
netns ops which are registered with register_pernet_gen_device() are shutdown strictly before those which are registered with register_pernet_subsys(). Sometimes this leads to opposite (read: buggy) shutdown ordering between two modules. Add register_pernet_gen_subsys()/unregister_pernet_gen_subsys() for modules which aren't elite enough for entry in struct net, and which can't use register_pernet_gen_device(). PPTP conntracking module is such one. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-30Merge branch 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6Linus Torvalds
* 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: SUNRPC: Fix potential race in put_rpccred() SUNRPC: Fix rpcauth_prune_expired NFS: Convert nfs_attr_generation_counter into an atomic_long SUNRPC: Respond promptly to server TCP resets
2008-10-30netlabel: Fix compilation warnings in net/netlabel/netlabel_addrlist.cManish Katiyar
Enable netlabel auditing functions only when CONFIG_AUDIT is set Signed-off-by: Manish Katiyar <mkatiyar@gmail.com> Signed-off-by: Paul Moore <paul.moore@hp.com>
2008-10-29netlabel: Fix compiler warnings in netlabel_mgmt.cPaul Moore
Fix the compiler warnings below, thanks to Andrew Morton for finding them. net/netlabel/netlabel_mgmt.c: In function `netlbl_mgmt_listentry': net/netlabel/netlabel_mgmt.c:268: warning: 'ret_val' might be used uninitialized in this function Signed-off-by: Paul Moore <paul.moore@hp.com>
2008-10-29cipso: unsigned buf_len cannot be negativeroel kluin
unsigned buf_len cannot be negative Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Paul Moore <paul.moore@hp.com>
2008-10-28pktgen: fix multiple queue warningJesse Brandeburg
when testing the new pktgen module with multiple queues and ixgbe with: pgset "flag QUEUE_MAP_CPU" I found that I was getting errors in dmesg like: pktgen: WARNING: QUEUE_MAP_CPU disabled because CPU count (8) exceeds number <4>pktgen: WARNING: of tx queues (8) on eth15 you'll note, 8 really doesn't exceed 8. This patch seemed to fix the logic errors and also the attempts at limiting line length in printk (which didn't work anyway) Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Robert Olsson <robert.olsson@its.uu.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-28SUNRPC: Fix potential race in put_rpccred()Trond Myklebust
We have to be careful when we try to unhash the credential in put_rpccred(), because we're not holding the credcache lock, so the call to rpcauth_unhash_cred() may fail if someone else has looked the cred up, and obtained a reference to it. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-10-28SUNRPC: Fix rpcauth_prune_expiredTrond Myklebust
We need to make sure that we don't remove creds from the cred_unused list if they are still under the moratorium, or else they will never get garbage collected. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-10-28SUNRPC: Respond promptly to server TCP resetsTrond Myklebust
If the server sends us an RST error while we're in the TCP_ESTABLISHED state, then that will not result in a state change, and so the RPC client ends up hanging forever (see http://bugzilla.kernel.org/show_bug.cgi?id=11154) We can intercept the reset by setting up an sk->sk_error_report callback, which will then allow us to initiate a proper shutdown and retry... We also make sure that if the send request receives an ECONNRESET, then we shutdown too... Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-10-27mac80211: correct warnings in minstrel rate control algorithmJohn W. Linville
2008-10-27RFKILL: fix input layer initialisationDmitry Baryshkov
Initialise correctly last fields, so tasks can be actually executed. On some architectures the initial jiffies value is not zero, so later all rfkill incorrectly decides that rfkill_*.last is in future. Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-26syncookies: fix inclusion of tcp options in syn-ackFlorian Westphal
David Miller noticed that commit 33ad798c924b4a1afad3593f2796d465040aadd5 '(tcp: options clean up') did not move the req->cookie_ts check. This essentially disabled commit 4dfc2817025965a2fc78a18c50f540736a6b5c24 '[Syncookies]: Add support for TCP options via timestamps.'. This restores the original logic. Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-26Phonet: do not reply to indication reset packetsRemi Denis-Courmont
This fixes a potential error packet loop. Signed-off-by: Remi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-26wireless: fix regression caused by regulatory config optionArjan van de Ven
The default for the regulatory compatibility option is wrong; if you picked the default you ended up with a non-functional wifi system (at least I did on Fedora 9 with iwl4965). I don't think even the October 2008 releases of the various distros has the new userland so clearly the default is wrong, and also we can't just go about deleting this in 2.6.29... Change the default to "y" and also adjust the config text a little to reflect this. This patch fixes regression #11859 With thanks to Johannes Berg for the diagnostics Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (29 commits) tcp: Restore ordering of TCP options for the sake of inter-operability net: Fix disjunct computation of netdev features sctp: Fix to handle SHUTDOWN in SHUTDOWN_RECEIVED state sctp: Fix to handle SHUTDOWN in SHUTDOWN-PENDING state sctp: Add check for the TSN field of the SHUTDOWN chunk sctp: Drop ICMP packet too big message with MTU larger than current PMTU p54: enable 2.4/5GHz spectrum by eeprom bits. orinoco: reduce stack usage in firmware download path ath5k: fix suspend-related oops on rmmod [netdrvr] fec_mpc52xx: Implement polling, to make netconsole work. qlge: Fix MSI/legacy single interrupt bug. smc911x: Make the driver safer on SMP smc911x: Add IRQ polarity configuration smc911x: Allow Kconfig dependency on ARM sis190: add identifier for Atheros AR8021 PHY 8139x: reduce message severity on driver overlap igb: add IGB_DCA instead of selecting INTEL_IOATDMA igb: fix tx data corruption with transition to L0s on 82575 ehea: Fix memory hotplug support netdev: DM9000: remove BLACKFIN hacking in DM9000 netdev driver ...
2008-10-23tcp: Restore ordering of TCP options for the sake of inter-operabilityIlpo Järvinen
This is not our bug! Sadly some devices cannot cope with the change of TCP option ordering which was a result of the recent rewrite of the option code (not that there was some particular reason steming from the rewrite for the reordering) though any ordering of TCP options is perfectly legal. Thus we restore the original ordering to allow interoperability with/through such broken devices and add some warning about this trap. Since the reordering just happened without any particular reason, this change shouldn't cost us anything. There are already couple of known failure reports (within close proximity of the last release), so the problem might be more wide-spread than a single device. And other reports which may be due to the same problem though the symptoms were less obvious. Analysis of one of the case revealed (with very high probability) that sack capability cannot be negotiated as the first option (SYN never got a response). Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Reported-by: Aldo Maggi <sentiniate@tiscali.it> Tested-by: Aldo Maggi <sentiniate@tiscali.it> Signed-off-by: David S. Miller <davem@davemloft.net>
