drivers/cpufreq/cpufreq_interactive.c
Add new netlink msg type for IDLETIMER.
Send notifications when the label becomes active after an idle period.
Send netlink message notifications in addition to sysfs notifications.
Change-Id: I31677ef00c94b5f82c8457e5bf9e5e584c23c523
Signed-off-by: Ashish Sharma <ashishsharma@google.com>
Introduce filtering for scheduled scans to reduce the number of
unnecessary results (which cause useless wake-ups).
Add a new nested attribute where sets of parameters to be matched can
be passed when starting a scheduled scan. Only scan results that
match any of the sets will be returned.
At this point, the set consists of a single parameter, an SSID. This
can be easily extended in the future to support more complex matches.
Signed-off-by: Luciano Coelho <coelho@ti.com>
include/linux/nl80211.h
net/wireless/nl80211.c
Some chips may support different lengths of user-supplied IEs with a
single scheduled scan command than with a single normal scan command.
To support this, this patch creates a separate hardware description
element that describes the maximum size of user-supplied information
element data supported in scheduled scans.
Some chips can scan more SSIDs with a single scheduled scan command
than with a single normal scan command (eg. wl12xx chips).
element that describes the amount of SSIDs supported in scheduled
scans.
mac80211 leaves sinfo->assoc_req_ies uninitialized, causing a random
pointer memory access in nl80211_send_station.
Instead of checking if the pointer is null, use sinfo->filled, like
the rest of the fields.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
drivers/misc/Kconfig
drivers/misc/Makefile
drivers/net/wireless/Makefile
kernel/power/main.c
sound/soc/soc-core.c
Remove linux/mm.h inclusion from netdevice.h -- it's unused (I've checked manually).
To prevent mm.h inclusion via other channels also extract "enum dma_data_direction"
definition into separate header. This tiny piece is what gluing netdevice.h with mm.h
via "netdevice.h => dmaengine.h => dma-mapping.h => scatterlist.h => mm.h".
Removal of mm.h from scatterlist.h was tried and was found not feasible
on most archs, so the link was cutoff earlier.
Hope people are OK with tiny include file.
Note, that mm_types.h is still dragged in, but it is a separate story.
Add a comment pointing out the use of enum station_info_flags for
all new struct station_info fields. In addition, memset the sinfo
buffer to zero before use on all paths in the current tree to avoid
leaving uninitialized pointers in the data.
Signed-off-by: Jouni Malinen <jouni@qca.qualcomm.com>
Signed-off-by: Dmitry Shmidt <dimitrysh@google.com>
When user space SME/MLME (e.g., hostapd) is not used in AP mode, the
IEs from the (Re)Association Request frame that was processed in
firmware need to be made available for user space (e.g., RSN IE for
hostapd). Allow this to be done with cfg80211_new_sta().
Acked-by: Johannes Berg <johannes@sipsolutions.net>
Upstream commit d305a6557b2c4dca0110f05ffe745b1ef94adb80.
If addBA responses comes in just after addba_resp_timer has
expired mac80211 will still accept it and try to open the
aggregation session. This causes drivers to be confused and
in some cases even crash.
This patch fixes the race condition and makes sure that if
addba_resp_timer has expired addBA response is not longer
accepted and we do not try to open half-closed session.
Signed-off-by: Nikolay Martynov <mar.kolya@gmail.com>
[some adjustments]
commit 0bac71af6e66dc798bf07d0c0dd14ee5503362f9 upstream.
Johannes' patch for "cfg80211: fix regulatory NULL dereference"
broke user regulaotry hints and it did not address the fact that
last_request was left populated even if the previous regulatory
hint was stale due to the wiphy disappearing.
Fix user reguluatory hints by only bailing out if for those
regulatory hints where a request_wiphy is expected. The stale last_request
considerations are addressed through the previous fixes on last_request
where we reset the last_request to a static world regdom request upon
reset_regdomains(). In this case though we further enhance the effect
by simply restoring reguluatory settings completely.
Cc: Johannes Berg <johannes.berg@intel.com>
Signed-off-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com>
Reviewed-by: Johannes Berg <johannes@sipsolutions.net>
commit a042994dd377d86bff9446ee76151ceb6267c9ba upstream.
There is a theoretical race that if hit will trigger
a crash. The race is between when we issue the first
regulatory hint, regulatory_hint_core(), gets processed
by the workqueue and between when the first device
gets registered to the wireless core. This is not easy
to reproduce but it was easy to do so through the
regulatory simulator I have been working on. This
is a port of the fix I implemented there [1].
[1] https://github.com/mcgrof/regsim/commit/a246ccf81f059cb662eee288aa13100f631e4cc8
commit 2a1e0fd175dcfd72096ba9291d31e3b1b5342e60 upstream.
When a packet is supposed to sent be as an a-MPDU, mac80211 sets
IEEE80211_TX_CTL_AMPDU to let the driver know. On the other
hand, mac80211 configures the driver for aggregration with the
ampdu_action callback.
There is race between these two mechanisms since the following
scenario can occur when the BA agreement is torn down:
Tx softIRQ drv configuration
check OPERATIONAL bit
Set the TX_CTL_AMPDU bit in the packet
clear OPERATIONAL bit
stop Tx AGG
Pass Tx packet to the driver.
In that case the driver would get a packet with TX_CTL_AMPDU set
although it has already been notified that the BA session has been
torn down.
To fix this, we need to synchronize all the Qdisc activity after we
cleared the OPERATIONAL bit. After that step, all the following
packets will be buffered until the driver reports it is ready to get
new packets for this RA / TID. This buffering allows not to run into
another race that would send packets with TX_CTL_AMPDU unset while
the driver hasn't been requested to tear down the BA session yet.
This race occurs in practice and iwlwifi complains with a WARN_ON
when it happens.
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
commit 24f50a9d165745fd0701c6e089d35f58a229ea69 upstream.
Nikolay noticed (by code review) that mac80211 can
attempt to stop an aggregation session while it is
already being stopped. So to fix it, check whether
stop is already being done and bail out if so.
Also move setting the STOPPING state into the lock
so things are properly atomic.
Reported-by: Nikolay Martynov <mar.kolya@gmail.com>
commit de3584bd62d87b4c250129fbc46ca52c80330add upstream.
By the time userspace returns with a response to
the regulatory domain request, the wiphy causing
the request might have gone away. If this is so,
reject the update but mark the request as having
been processed anyway.
Cc: Luis R. Rodriguez <lrodriguez@qca.qualcomm.com>
commit e007b857e88097c96c45620bf3b04a4e309053d1 upstream.
MAC addresses have a fixed length. The current
policy allows passing < ETH_ALEN bytes, which
might result in reading beyond the buffer.
Signed-off-by: Eliad Peller <eliad@wizery.com>
commit 24ca9a847791fd53d9b217330b15f3c285827a18 upstream.
By returning '0' instead of 'EAGAIN' when the tests in xs_nospace() fail
to find evidence of socket congestion, we are making the RPC engine believe
that the message was incorrectly sent and so it disconnects the socket
instead of just retrying.
The bug appears to have been introduced by commit
5e3771ce2d6a69e10fcc870cdf226d121d868491 (SUNRPC: Ensure that xs_nospace
return values are propagated).
Reported-by: Andrew Cooper <andrew.cooper3@citrix.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Tested-by: Andrew Cooper <andrew.cooper3@citrix.com>
This improves compatbility with a lot of headset / chipset
combinations. Ideally this should not be needed.
Change-Id: I8b676701e12e416aa7d60801b9d353b15d102709
Signed-off-by: hyungseoung.yoo <hyungseoung.yoo@samsung.com>
Signed-off-by: Jaikumar Ganesh <jaikumarg@android.com>
commit 731abb9cb27aef6013ce60808a04e04a545f3f4e upstream.
Commit 1c5cae815d removed an explicit call to dev_alloc_name in ip6_tnl_create
because register_netdevice will now create a valid name. This works for the
net_device itself.
However the tunnel keeps a copy of the name in the parms structure for the
ip6_tnl associated with the tunnel. parms.name is set by copying the net_device
name in ip6_tnl_dev_init_gen. That function is called from ip6_tnl_dev_init in
ip6_tnl_create, but it is done before register_netdevice is called so the name
is set to a bogus value in the parms.name structure.
This shows up if you do a simple tunnel add, followed by a tunnel show:
[root@localhost ~]# ip -6 tunnel add remote fec0::100 local fec0::200
[root@localhost ~]# ip -6 tunnel show
ip6tnl0: ipv6/ipv6 remote :: local :: encaplimit 0 hoplimit 0 tclass 0x00 flowlabel 0x00000 (flowinfo 0x00000000)
ip6tnl%d: ipv6/ipv6 remote fec0::100 local fec0::200 encaplimit 4 hoplimit 64 tclass 0x00 flowlabel 0x00000 (flowinfo 0x00000000)
[root@localhost ~]#
Fix this by moving the strcpy out of ip6_tnl_dev_init_gen, and calling it after
register_netdevice has successfully returned.
Signed-off-by: Josh Boyer <jwboyer@redhat.com>
commit 58ebacc66bd11be2327edcefc79de94bd6f5bb4a upstream.
Commit 4d9d88d1 by Scott James Remnant <keybuk@google.com> added
the .uevent() callback for the regulatory device used during
the platform device registration. The change was done to account
for queuing up udev change requests through udevadm triggers.
The change also meant that upon regulatory core exit we will now
send a uevent() but the uevent() callback, reg_device_uevent(),
also accessed last_request. Right before commiting device suicide
we free'd last_request but never set it to NULL so
platform_device_unregister() would lead to bogus kernel paging
request. Fix this and also simply supress uevents right before
we commit suicide as they are pointless.
This fix is required for kernels >= v2.6.39
$ git describe --contains 4d9d88d1
v2.6.39-rc1~468^2~25^2^2~21
The impact of not having this present is that a bogus paging
access may occur (only read) upon cfg80211 unload time. You
may also get this BUG complaint below. Although Johannes
could not reproduce the issue this fix is theoretically correct.
mac80211_hwsim: unregister radios
mac80211_hwsim: closing netlink
BUG: unable to handle kernel paging request at ffff88001a06b5ab
IP: [<ffffffffa030df9a>] reg_device_uevent+0x1a/0x50 [cfg80211]
PGD 1836063 PUD 183a063 PMD 1ffcb067 PTE 1a06b160
Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC
CPU 0
Modules linked in: cfg80211(-) [last unloaded: mac80211]
Pid: 2279, comm: rmmod Tainted: G W 3.1.0-wl+ #663 Bochs Bochs
RIP: 0010:[<ffffffffa030df9a>] [<ffffffffa030df9a>] reg_device_uevent+0x1a/0x50 [cfg80211]
RSP: 0000:ffff88001c5f9d58 EFLAGS: 00010286
RAX: 0000000000000000 RBX: ffff88001d2eda88 RCX: ffff88001c7468fc
RDX: ffff88001a06b5a0 RSI: ffff88001c7467b0 RDI: ffff88001c7467b0
RBP: ffff88001c5f9d58 R08: 000000000000ffff R09: 000000000000ffff
R10: 0000000000000000 R11: 0000000000000001 R12: ffff88001c7467b0
R13: ffff88001d2eda78 R14: ffffffff8164a840 R15: 0000000000000001
FS: 00007f8a91d8a6e0(0000) GS:ffff88001fc00000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: ffff88001a06b5ab CR3: 000000001c62e000 CR4: 00000000000006f0
Process rmmod (pid: 2279, threadinfo ffff88001c5f8000, task ffff88000023c780)
Stack:
ffff88001c5f9d98 ffffffff812ff7e5 ffffffff8176ab3d ffff88001c7468c2
000000000000ffff ffff88001d2eda88 ffff88001c7467b0 ffff880000114820
ffff88001c5f9e38 ffffffff81241dc7 ffff88001c5f9db8 ffffffff81040189
Call Trace:
[<ffffffff812ff7e5>] dev_uevent+0xc5/0x170
[<ffffffff81241dc7>] kobject_uevent_env+0x1f7/0x490
[<ffffffff81040189>] ? sub_preempt_count+0x29/0x60
[<ffffffff814cab1a>] ? _raw_spin_unlock_irqrestore+0x4a/0x90
[<ffffffff81305307>] ? devres_release_all+0x27/0x60
[<ffffffff8124206b>] kobject_uevent+0xb/0x10
[<ffffffff812fee27>] device_del+0x157/0x1b0
[<ffffffff8130377d>] platform_device_del+0x1d/0x90
[<ffffffff81303b76>] platform_device_unregister+0x16/0x30
[<ffffffffa030fffd>] regulatory_exit+0x5d/0x180 [cfg80211]
[<ffffffffa032bec3>] cfg80211_exit+0x2b/0x45 [cfg80211]
[<ffffffff8109a84c>] sys_delete_module+0x16c/0x220
[<ffffffff8108a23e>] ? trace_hardirqs_on_caller+0x7e/0x120
[<ffffffff814cba02>] system_call_fastpath+0x16/0x1b
Code: <all your base are belong to me>
RIP [<ffffffffa030df9a>] reg_device_uevent+0x1a/0x50 [cfg80211]
RSP <ffff88001c5f9d58>
---[ end trace 147c5099a411e8c0 ]---
Reported-by: Johannes Berg <johannes@sipsolutions.net>
Cc: Scott James Remnant <keybuk@google.com>
commit 6c7394197af90f6a332180e33f5d025d3037d883 upstream.
Since the NL80211_ATTR_HT_CAPABILITY attribute is
used as a struct, it needs a minimum, not maximum
length. Enforce that properly. Not doing so could
potentially lead to reading after the buffer.
commit 5b2bbf75a24d6b06afff6de0eb4819413fd81971 upstream.
ieee80211_probereq_get() can return NULL in
which case we should clean up & return NULL
in ieee80211_build_probe_req() as well.
commit f8d1ccf15568268c76f913b45ecdd33134387f1a upstream.
When receiving failed PLCP frames is enabled, there
won't be a rate pointer when we add the radiotap
header and thus the kernel will crash. Fix this by
not assuming the rate pointer is always valid. It's
still always valid for frames that have good PLCP
though, and that is checked & enforced.
This was broken by my
commit fc88518916793af8ad6a02e05ff254d95c36d875
Author: Johannes Berg <johannes.berg@intel.com>
Date: Fri Jul 30 13:23:12 2010 +0200
mac80211: don't check rates on PLCP error frames
where I removed the check in this case but didn't
take into account that the rate info would be used.
Reported-by: Xiaokang Qin <xiaokang.qin@intel.com>
commit aa1c366e4febc7f5c2b84958a2dd7cd70e28f9d0 upstream.
With the conversion of struct flowi to a union of AF-specific structs, some
operations on the flow cache need to account for the exact size of the key.
Signed-off-by: David Ward <david.ward@ll.mit.edu>
Cc: Kim Phillips <kim.phillips@freescale.com>
commit 05cb91085760ca378f28fc274fbf77fc4fd9886c upstream.
Only AID values 1-2007 are valid, but some APs have been
found to send random bogus values, in the reported case an
AP that was sending the AID field value 0xffff, an AID of
0x3fff (16383).
There isn't much we can do but disable powersave since
there's no way it can work properly in this case.
Reported-by: Bill C Riemers <briemers@redhat.com>
commit 6911bf0453e0d6ea8eb694a4ce67a68d071c538e upstream.
When going back on-channel, we should reconfigure
the hw iff the hardware is not already configured
to the operational channel.
commit eaa7af2ae582c9a8c51b374c48d5970b748a5ce2 upstream.
The offchannel code is currently broken - we should
remain_off_channel if the work was started, and
the work's channel and channel_type are the same
as local->tmp_channel and local->tmp_channel_type.
However, if wk->chan_type and local->tmp_channel_type
coexist (e.g. have the same channel type), we won't
remain_off_channel.
This behavior was introduced by commit da2fd1f
("mac80211: Allow work items to use existing
channel type.")
Tested-by: Ben Greear <greearb@candelatech.com>
commit dc6f55e9f8dac4b6479be67c5c9128ad37bb491f upstream.
The sunrpc layer keeps a cache of recently used credentials and
'unx_match' is used to find the credential which matches the current
process.
However unx_match allows a match when the cached credential has extra
groups at the end of uc_gids list which are not in the process group list.
So if a process with a list of (say) 4 group accesses a file and gains
access because of the last group in the list, then another process
with the same uid and gid, and a gid list being the first tree of the
gids of the original process tries to access the file, it will be
granted access even though it shouldn't as the wrong rpc credential
will be used.
Signed-off-by: NeilBrown <neilb@suse.de>
[ Upstream commit b0691c8ee7c28a72748ff32e91b165ec12ae4de6 ]
[ Upstream commit b64b73d7d0c480f75684519c6134e79d50c1b341 ]
This resolves a regression seen by some users of bridging.
Some users use the bridge like a dummy device.
They expect to be able to put an IPv6 address on the device
with no ports attached. Although there are better ways of doing
this, there is no reason to not allow it.
Note: the bridge still will reflect the state of ports in the
bridge if there are any added.
commit 12d0d0d3a7349daa95dbfd5d7df8146255bc7c67 upstream.
The commit aabdcb0b553b9c9547b1a506b34d55a764745870 ("can bcm: fix tx_setup
off-by-one errors") fixed only a part of the original problem reported by
Andre Naujoks. It turned out that the original code needed to be re-ordered
to reduce complexity and to finally fix the reported frame counting issues.
Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net>
[ Upstream commit 7091fbd82cd5686444ffe9935ed6a8190101fe9d ]
This is a minor change.
Up until kernel 2.6.32, getsockopt(fd, SOL_PACKET, PACKET_STATISTICS,
...) would return total and dropped packets since its last invocation. The
introduction of socket queue overflow reporting [1] changed drop
rate calculation in the normal packet socket path, but not when using a
packet ring. As a result, the getsockopt now returns different statistics
depending on the reception method used. With a ring, it still returns the
count since the last call, as counts are incremented in tpacket_rcv and
reset in getsockopt. Without a ring, it returns 0 if no drops occurred
since the last getsockopt and the total drops over the lifespan of
the socket otherwise. The culprit is this line in packet_rcv, executed
on a drop:
drop_n_acct:
po->stats.tp_drops = atomic_inc_return(&sk->sk_drops);
As it shows, the new drop number it taken from the socket drop counter,
which is not reset at getsockopt. I put together a small example
that demonstrates the issue [2]. It runs for 10 seconds and overflows
the queue/ring on every odd second. The reported drop rates are:
ring: 16, 0, 16, 0, 16, ...
non-ring: 0, 15, 0, 30, 0, 46, 0, 60, 0 , 74.
Note how the even ring counts monotonically increase. Because the
getsockopt adds tp_drops to tp_packets, total counts are similarly
reported cumulatively. Long story short, reinstating the original code, as
the below patch does, fixes the issue at the cost of additional per-packet
cycles. Another solution that does not introduce per-packet overhead
is be to keep the current data path, record the value of sk_drops at
getsockopt() at call N in a new field in struct packetsock and subtract
that when reporting at call N+1. I'll be happy to code that, instead,
it's just more messy.
[1] http://patchwork.ozlabs.org/patch/35665/
[2] http://kernel.googlecode.com/files/test-packetsock-getstatistics.c
Signed-off-by: Willem de Bruijn <willemb@google.com>
[ Upstream commit 676a1184e8afd4fed7948232df1ff91517400859 ]
ipv6_ac_list and ipv6_fl_list from listening socket are inadvertently
shared with new socket created for connection.
Signed-off-by: Zheng Yan <zheng.z.yan@intel.com>
[ Upstream commit 1e5289e121372a3494402b1b131b41bfe1cf9b7f ]
lost_skb_hint is used by tcp_mark_head_lost() to mark the first unhandled skb.
lost_cnt_hint is the number of packets or sacked packets before the lost_skb_hint;
When shifting a skb that is before the lost_skb_hint, if tcp_is_fack() is ture,
the skb has already been counted in the lost_cnt_hint; if tcp_is_fack() is false,
tcp_sacktag_one() will increase the lost_cnt_hint. So tcp_shifted_skb() does not
need to adjust the lost_cnt_hint by itself. When shifting a skb that is equal to
lost_skb_hint, the shifted packets will not be counted by tcp_mark_head_lost().
So tcp_shifted_skb() should adjust the lost_cnt_hint even tcp_is_fack(tp) is true.
[ Upstream commit 260fcbeb1ae9e768a44c9925338fbacb0d7e5ba9 ]
tcp_v4_clear_md5_list() assumes that multiple tcp md5sig peers
only hold one reference to md5sig_pool. but tcp_v4_md5_do_add()
increases use count of md5sig_pool for each peer. This patch
makes tcp_v4_md5_do_add() only increases use count for the first
tcp md5sig peer.
[ Upstream commit 835acf5da239b91edb9f7ebe36516999e156e6ee ]
l2tp_xmit_skb() can leak one skb if skb_cow_head() returns an error.
[ Upstream commit b73233960a59ee66e09d642f13d0592b13651e94 ]
There is bug in commit 5e2b61f(ipv4: Remove flowi from struct rtable).
It makes xfrm4_fill_dst() modify wrong data structure.
Reported-by: Kim Phillips <kim.phillips@freescale.com>
[ Upstream commit aabdcb0b553b9c9547b1a506b34d55a764745870 ]
This patch fixes two off-by-one errors that canceled each other out.
Checking for the same condition two times in bcm_tx_timeout_tsklet() reduced
the count of frames to be sent by one. This did not show up the first time
tx_setup is invoked as an additional frame is sent due to TX_ANNONCE.
Invoking a second tx_setup on the same item led to a reduced (by 1) number of
sent frames.
Reported-by: Andre Naujoks <nautsch@gmail.com>
[ Upstream commit 1ce5cce895309862d2c35d922816adebe094fe4a ]
Need to cleanup bridge device timers and ports when being bridge
device is being removed via netlink.
This fixes the problem of observed when doing:
ip link add br0 type bridge
ip link set dev eth1 master br0
ip link set br0 up
ip link del br0
which would cause br0 to hang in unregister_netdev because
of leftover reference count.
Reported-by: Sridhar Samudrala <sri@us.ibm.com>
Acked-by: Sridhar Samudrala <sri@us.ibm.com>
commit da92b194cc36b5dc1fbd85206aeeffd80bee0c39 upstream.
The pair of functions,
* skb_clone_tx_timestamp()
* skb_complete_tx_timestamp()
were designed to allow timestamping in PHY devices. The first
function, called during the MAC driver's hard_xmit method, identifies
PTP protocol packets, clones them, and gives them to the PHY device
driver. The PHY driver may hold onto the packet and deliver it at a
later time using the second function, which adds the packet to the
socket's error queue.
As pointed out by Johannes, nothing prevents the socket from
disappearing while the cloned packet is sitting in the PHY driver
awaiting a timestamp. This patch fixes the issue by taking a reference
on the socket for each such packet. In addition, the comments
regarding the usage of these function are expanded to highlight the
rule that PHY drivers must use skb_complete_tx_timestamp() to release
the packet, in order to release the socket reference, too.
These functions first appeared in v2.6.36.
Signed-off-by: Richard Cochran <richard.cochran@omicron.at>
commit 28a1bcdb57d50f3038a255741ecc83e391e5282e upstream.
When I introduced in-kernel off-channel TX I
introduced a bug -- the work can't be canceled
again because the code clear the skb pointer.
Fix this by keeping track separately of whether
TX status has already been reported.
Reported-by: Jouni Malinen <j@w1.fi>
Tested-by: Jouni Malinen <j@w1.fi>
commit d2237d35748e7f448a9c2d9dc6a85ef637466e24 upstream.
Renato Westphal noticed that since commit a2835763e130c343ace5320c20d33c281e7097b7
"rtnetlink: handle rtnl_link netlink notifications manually" was merged
we no longer send a netlink message when a networking device is moved
from one network namespace to another.
Fix this by adding the missing manual notification in dev_change_net_namespaces.
Since all network devices that are processed by dev_change_net_namspaces are
in the initialized state the complicated tests that guard the manual
rtmsg_ifinfo calls in rollback_registered and register_netdevice are
unnecessary and we can just perform a plain notification.
Tested-by: Renato Westphal <renatowestphal@gmail.com>
commit 08613e4626c06ca408fc55071f6aedee36986a87 upstream.
The caif code will register its own pernet_operations, and then register
a netdevice_notifier. Each time the netdevice_notifier is triggered,
it'll do some stuff... including a lookup of its own pernet stuff with
net_generic().
If the net_generic() call ever returns NULL, the caif code will BUG().
That doesn't seem *so* unreasonable, I suppose — it does seem like it
should never happen.
However, it *does* happen. When we clone a network namespace,
setup_net() runs through all the pernet_operations one at a time. It
gets to loopback before it gets to caif. And loopback_net_init()
registers a netdevice... while caif hasn't been initialised. So the caif
netdevice notifier triggers, and immediately goes BUG().
We could imagine a complex and overengineered solution to this generic
class of problems, but this patch takes the simple approach. It just
makes caif_device_notify() *not* go looking for its pernet data
structures if the device it's being notified about isn't a caif device
in the first place.
Acked-by: Sjur Brændeland <sjur.brandeland@stericsson.com>
Currently, calling tcp_nuke_addr to reset IPv6 connections
resets IPv4 connections as well, because all Android
framework sockets are dual-stack (i.e., IPv6) sockets, and
we don't check the source address to see if the connection
was in fact an IPv4 connection.
Fix this by checking the source address and not resetting
the connection if it's a mapped address.
Also slightly tweak the IPv4 code path, which doesn't check
for mapped addresses either. This was not causing any
problems because tcp_is_local normally always returns true
for LOOPBACK4_IPV6 (127.0.0.6), because the loopback
interface is configured as as 127.0.0.0/8. However,
checking explicitly for LOOPBACK4_IPV6 makes the code a bit
more robust.
Bug: 5535055
Change-Id: I4d6ed3497c5b8643c864783cf681f088cf6b8d2a
Signed-off-by: Lorenzo Colitti <lorenzo@google.com>
commit 7f81e25befdfb3272345a2e775f520e1d515fa20 upstream.
x25_find_listener does not check that the amount of call user data given
in the skb is big enough in per-socket comparisons, hence buffer
overreads may occur. Fix this by adding a check.
Signed-off-by: Matthew Daley <mattjd@gmail.com>
Cc: Andrew Hendry <andrew.hendry@gmail.com>
Acked-by: Andrew Hendry <andrew.hendry@gmail.com>
